--- ray/src/hd/sm_ogl.c 1998/11/11 12:05:39 3.9 +++ ray/src/hd/sm_ogl.c 1998/12/28 18:07:35 3.10 @@ -47,195 +47,12 @@ static QT_LUENT *qt_htbl = NULL; /* quadtree cache */ static int qt_hsiz = 0; /* quadtree cache size */ - -mark_active_tris(qtptr,fptr) -QUADTREE *qtptr; -int *fptr; -{ - QUADTREE qt = *qtptr; - OBJECT *os,*optr; - register int i,t_id; - TRI *tri; - - if(!QT_FLAG_FILL_TRI(*fptr)) - (*fptr)++; - if(QT_IS_EMPTY(qt) || QT_LEAF_IS_FLAG(qt)) - return; - - /* For each triangle in the set, set the which flag*/ - os = qtqueryset(qt); - - for (i = QT_SET_CNT(os), optr = QT_SET_PTR(os); i > 0; i--) - { - t_id = QT_SET_NEXT_ELEM(optr); - /* Set the render flag */ - tri = SM_NTH_TRI(smMesh,t_id); - if(!T_IS_VALID(tri) || SM_IS_NTH_T_BASE(smMesh,t_id)) - continue; - SM_SET_NTH_T_ACTIVE(smMesh,t_id); - /* Set the Active bits of the Vertices */ - S_SET_FLAG(T_NTH_V(tri,0)); - S_SET_FLAG(T_NTH_V(tri,1)); - S_SET_FLAG(T_NTH_V(tri,2)); - - } -} - -#define mark_active_interior mark_active_tris - -mark_tris_in_frustum(view) -VIEW *view; -{ - FVECT nr[4],far[4]; - FPEQ peq; - int debug=0; - /* Mark triangles in approx. view frustum as being active:set - LRU counter: for use in discarding samples when out - of space - Radiance often has no far clipping plane: but driver will set - dev_zmin,dev_zmax to satisfy OGL - */ - - /* First clear all the quadtree node and triangle active flags */ - qtClearAllFlags(); - smClear_flags(smMesh,T_ACTIVE_FLAG); - /* Clear all of the active sample flags*/ - sClear_all_flags(SM_SAMP(smMesh)); - - - /* calculate the world space coordinates of the view frustum */ - calculate_view_frustum(view->vp,view->hvec,view->vvec,view->horiz, - view->vert, dev_zmin,dev_zmax,nr,far); - -#ifdef TEST_DRIVER - VCOPY(FrustumFar[0],far[0]); - VCOPY(FrustumFar[1],far[1]); - VCOPY(FrustumFar[2],far[2]); - VCOPY(FrustumFar[3],far[3]); - VCOPY(FrustumNear[0],nr[0]); - VCOPY(FrustumNear[1],nr[1]); - VCOPY(FrustumNear[2],nr[2]); - VCOPY(FrustumNear[3],nr[3]); -#endif - /* Project the view frustum onto the spherical quadtree */ - /* For every cell intersected by the projection of the faces - - of the frustum: mark all triangles in the cell as ACTIVE- - Also set the triangles LRU clock counter - */ - - if(EQUAL_VEC3(view->vp,SM_VIEW_CENTER(smMesh))) - {/* Near face triangles */ - - smLocator_apply_func(smMesh,nr[0],nr[2],nr[3],mark_active_tris, - mark_active_interior,NULL); - smLocator_apply_func(smMesh,nr[2],nr[0],nr[1],mark_active_tris, - mark_active_interior,NULL); - return; - } - - /* Test the view against the planes: and swap orientation if inside:*/ - tri_plane_equation(nr[0],nr[2],nr[3], &peq,FALSE); - if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) - {/* Near face triangles */ - smLocator_apply_func(smMesh,nr[3],nr[2],nr[0],mark_active_tris, - mark_active_interior,NULL); - smLocator_apply_func(smMesh,nr[1],nr[0],nr[2],mark_active_tris, - mark_active_interior,NULL); - } - else - {/* Near face triangles */ - smLocator_apply_func(smMesh,nr[0],nr[2],nr[3],mark_active_tris, - mark_active_interior,NULL); - smLocator_apply_func(smMesh,nr[2],nr[0],nr[1],mark_active_tris, - mark_active_interior,NULL); - } - tri_plane_equation(nr[0],far[3],far[0], &peq,FALSE); - if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) - { /* Right face triangles */ - smLocator_apply_func(smMesh,far[0],far[3],nr[0],mark_active_tris, - mark_active_interior,NULL); - smLocator_apply_func(smMesh,nr[3],nr[0],far[3],mark_active_tris, - mark_active_interior,NULL); - } - else - {/* Right face triangles */ - smLocator_apply_func(smMesh,nr[0],far[3],far[0],mark_active_tris, - mark_active_interior,NULL); - smLocator_apply_func(smMesh,far[3],nr[0],nr[3],mark_active_tris, - mark_active_interior,NULL); - } - - tri_plane_equation(nr[1],far[2],nr[2], &peq,FALSE); - if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) - { /* Left face triangles */ - smLocator_apply_func(smMesh,nr[2],far[2],nr[1],mark_active_tris, - mark_active_interior,NULL); - smLocator_apply_func(smMesh,far[1],nr[1],far[2],mark_active_tris, - mark_active_interior,NULL); - } - else - { /* Left face triangles */ - smLocator_apply_func(smMesh,nr[1],far[2],nr[2],mark_active_tris, - mark_active_interior,NULL); - smLocator_apply_func(smMesh,far[2],nr[1],far[1],mark_active_tris, - mark_active_interior,NULL); - - } - tri_plane_equation(nr[0],far[0],nr[1], &peq,FALSE); - if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) - {/* Top face triangles */ - smLocator_apply_func(smMesh,nr[1],far[0],nr[0],mark_active_tris, - mark_active_interior,NULL); - smLocator_apply_func(smMesh,far[1],far[0],nr[1],mark_active_tris, - mark_active_interior,NULL); - } - else - {/* Top face triangles */ - smLocator_apply_func(smMesh,nr[0],far[0],nr[1],mark_active_tris, - mark_active_interior,NULL); - smLocator_apply_func(smMesh,nr[1],far[0],far[1],mark_active_tris, - mark_active_interior,NULL); - } - tri_plane_equation(nr[3],nr[2],far[3], &peq,FALSE); - if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) - {/* Bottom face triangles */ - smLocator_apply_func(smMesh,far[3],nr[2],nr[3],mark_active_tris, - mark_active_interior,NULL); - smLocator_apply_func(smMesh,far[3],far[2],nr[2],mark_active_tris, - mark_active_interior,NULL); - } - else - { /* Bottom face triangles */ - smLocator_apply_func(smMesh,nr[3],nr[2],far[3],mark_active_tris, - mark_active_interior,NULL); - smLocator_apply_func(smMesh,nr[2],far[2],far[3],mark_active_tris, - mark_active_interior,NULL); - } - tri_plane_equation(far[2],far[0],far[1], &peq,FALSE); - if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) - {/* Far face triangles */ - smLocator_apply_func(smMesh,far[0],far[2],far[1],mark_active_tris, - mark_active_interior,NULL); - smLocator_apply_func(smMesh,far[2],far[0],far[3],mark_active_tris, - mark_active_interior,NULL); - } - else - {/* Far face triangles */ - smLocator_apply_func(smMesh,far[1],far[2],far[0],mark_active_tris, - mark_active_interior,NULL); - smLocator_apply_func(smMesh,far[3],far[0],far[2],mark_active_tris, - mark_active_interior,NULL); - } - -} - -/* - * smClean() : display has been wiped clean - * - * Called after display has been effectively cleared, meaning that all - * geometry must be resent down the pipeline in the next call to smUpdate(). - */ + /* + * smClean() : display has been wiped clean + * + * Called after display has been effectively cleared, meaning that all + * geometry must be resent down the pipeline in the next call to smUpdate(). + */ smClean() { smClean_notify = TRUE; @@ -322,7 +139,8 @@ register QUADTREE qt; stCount_level_leaves(lcnt+1, QT_NTH_CHILD(qt,3)); } else - lcnt[0]++; + if(QT_LEAF_IS_FLAG(qt)) + lcnt[0]++; } @@ -342,6 +160,8 @@ int lvl; return(NULL); if (QT_IS_TREE(qt) && !QT_IS_FLAG(qt)) /* not in our frustum */ return(NULL); + if(QT_IS_LEAF(qt) && !QT_LEAF_IS_FLAG(qt)) /* not in our frustum */ + return(NULL); /* else look up node */ if ((le = qtCache_find(qt)) == NULL) error(SYSTEM, "out of memory in qtRender_level"); @@ -434,7 +254,7 @@ smRender_stree_level(sm,lvl) SM *sm; int lvl; { - QUADTREE root; + QUADTREE qt; int i; FVECT t0,t1,t2; STREE *st; @@ -448,8 +268,8 @@ int lvl; glBegin(GL_TRIANGLES); for(i=0; i < ST_NUM_ROOT_NODES; i++) { - root = ST_NTH_ROOT(st,i); - qtRender_level(root,ST_NTH_V(st,i,0),ST_NTH_V(st,i,1),ST_NTH_V(st,i,2), + qt = ST_ROOT_QT(st,i); + qtRender_level(qt,ST_NTH_V(st,i,0),ST_NTH_V(st,i,1),ST_NTH_V(st,i,2), sm,lvl-1); } glEnd(); @@ -463,6 +283,7 @@ int qual; { int i, ntarget; int lvlcnt[QT_MAX_LEVELS]; + STREE *st; if (qual <= 0) return; @@ -475,8 +296,11 @@ int qual; return; for (i = QT_MAX_LEVELS; i--; ) lvlcnt[i] = 0; - stCount_level_leaves(lvlcnt, ST_TOP_ROOT(SM_LOCATOR(sm))); - stCount_level_leaves(lvlcnt, ST_BOTTOM_ROOT(SM_LOCATOR(sm))); + + st = SM_LOCATOR(sm); + for(i=0; i < ST_NUM_ROOT_NODES;i++) + stCount_level_leaves(lvlcnt, ST_ROOT_QT(st,i)); + for (ntarget -= lvlcnt[i=0]; i < QT_MAX_LEVELS-1; ntarget -= lvlcnt[++i]) if (ntarget < lvlcnt[i+1]) break; @@ -801,6 +625,9 @@ smUpdate(view,qual) if(!smMesh) return; + + + d = DIST(view->vp,SM_VIEW_CENTER(smMesh)); if(qual >= 100 && d > SM_ALLOWED_VIEW_CHANGE(smMesh)) { @@ -823,10 +650,9 @@ smUpdate(view,qual) { tmClearHisto(); tmAddHisto(SM_BRT(smMesh),SM_NUM_SAMP(smMesh),1); - if(tmComputeMapping(0.,0.,0.) != TM_E_OK || - tmMapPixels(SM_RGB(smMesh),SM_BRT(smMesh),SM_CHR(smMesh), - SM_NUM_SAMP(smMesh)) != TM_E_OK) - return; + tmComputeMapping(0.,0.,0.); + tmMapPixels(SM_RGB(smMesh),SM_BRT(smMesh),SM_CHR(smMesh), + SM_NUM_SAMP(smMesh)); } #endif mark_tris_in_frustum(view); @@ -855,9 +681,9 @@ smUpdate(view,qual) if(tmComputeMapping(0.,0.,0.) != TM_E_OK) return; } - if(tmMapPixels(SM_NTH_RGB(smMesh,t),&SM_NTH_BRT(smMesh,t), - SM_NTH_CHR(smMesh,t), SM_NUM_SAMP(smMesh)-t) != TM_E_OK) - return; + tmMapPixels(SM_NTH_RGB(smMesh,t),&SM_NTH_BRT(smMesh,t), + SM_NTH_CHR(smMesh,t), SM_NUM_SAMP(smMesh)-t); + #endif smUpdate_Rendered_mesh(smMesh,view->vp,last_update);
