--- ray/src/hd/sm_ogl.c 1998/09/14 10:33:47 3.6 +++ ray/src/hd/sm_ogl.c 2003/02/22 02:07:25 3.16 @@ -1,35 +1,56 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: sm_ogl.c,v 3.16 2003/02/22 02:07:25 greg Exp $"; #endif - /* * sm_ogl.c -*/ + * + * Rendering routines for triangle mesh representation utilizing OpenGL + * + * smClean(tmflag) : display has been wiped clean + * int tmflag; + * Called after display has been effectively cleared, meaning that all + * geometry must be resent down the pipeline in the next call to smUpdate(). + * If tmflag is set, tone-mapping should be performed + * + * smUpdate(vp, qua) : update OpenGL output geometry for view vp + * VIEW *vp; : desired view + * int qua; : quality level (percentage on linear time scale) + * + * Draw new geometric representation using OpenGL calls. Assume that the + * view has already been set up and the correct frame buffer has been + * selected for drawing. The quality level is on a linear scale, where 100% + * is full (final) quality. It is not necessary to redraw geometry that has + * been output since the last call to smClean(). (The last view drawn will + * be vp==&odev.v each time.) + */ #include "standard.h" #include -#ifdef TEST_DRIVER -#include -#include -#include -#endif +#include "sm_flag.h" #include "sm_list.h" #include "sm_geom.h" #include "sm.h" -#ifdef TEST_DRIVER -#include "sm_draw.h" -/*static char smClean_notify = TRUE; -MAKE STATIC LATER: ui.c using for now; - */ -char smClean_notify = TRUE; -#else -static int smClean_notify = TRUE; -#endif +int smClean_notify = TRUE; /*If TRUE:Do full redraw on next update*/ +static int smCompute_mapping = TRUE; /*If TRUE:re-tonemap on next update */ +static int smIncremental = FALSE; /*If TRUE: there has been incremental + rendering since last full draw */ +#define NEW_TRI_CNT 1000 /* Default number of tris to allocate + space to sort for incremental update*/ +#define SM_RENDER_FG 0 /* Render foreground tris only*/ +#define SM_RENDER_BG 1 /* Render background tris only */ +#define SM_RENDER_CULL 8 /* Perform view frustum culling */ +#define BASE 1 /* Indicates base triangle */ +#define DIR 2 /* Indicates triangle w/directional pts*/ +/* FOR DISPLAY LIST RENDERING: **********************************************/ +#define SM_DL_LEVELS 2 /* # of levels down to create display lists */ +#define SM_DL_LISTS 42 /* # of qtree nodes in tree at above level: + should be 2*(4^(SM_DL_LEVELS+1)-1)/(4-1) */ +static GLuint Display_lists[SM_DL_LISTS][2] = {0}; +/****************************************************************************/ +/* FOR APPROXIMATION RENDERING **********************************************/ typedef struct { float dist; /* average distance */ BYTE rgb[3]; /* average color */ @@ -42,166 +63,93 @@ typedef struct { static QT_LUENT *qt_htbl = NULL; /* quadtree cache */ static int qt_hsiz = 0; /* quadtree cache size */ +/****************************************************************************/ +/* For DEPTH SORTING ********************************************************/ +typedef struct _T_DEPTH { + int tri; + double depth; +}T_DEPTH; +/**********************************************************************/ -int -mark_active_tris(qtptr,arg) -QUADTREE *qtptr; -int *arg; + /* + * smClean(tmflag) : display has been wiped clean + * int tmflag; + * Called after display has been effectively cleared, meaning that all + * geometry must be resent down the pipeline in the next call to smUpdate(). + * If tmflag is set, tone-mapping should be performed + */ +smClean(tmflag) + int tmflag; { - QUADTREE qt = *qtptr; - OBJECT *os,*optr; - register int i,t_id; - - if (!QT_IS_LEAF(qt)) - return(TRUE); - /* For each triangle in the set, set the which flag*/ - os = qtqueryset(qt); - - for (i = QT_SET_CNT(os), optr = QT_SET_PTR(os); i > 0; i--) - { - t_id = QT_SET_NEXT_ELEM(optr); - /* Set the render flag */ - if(SM_IS_NTH_T_BASE(smMesh,t_id)) - continue; - SM_SET_NTH_T_ACTIVE(smMesh,t_id); - /* NOTE:Also set the LRU clock bit: MAY WANT TO CHANGE: */ - SM_SET_NTH_T_LRU(smMesh,t_id); - } - return(TRUE); -} - -mark_tris_in_frustum(view) -VIEW *view; -{ - FVECT nr[4],far[4]; - - /* Mark triangles in approx. view frustum as being active:set - LRU counter: for use in discarding samples when out - of space - Radiance often has no far clipping plane: but driver will set - dev_zmin,dev_zmax to satisfy OGL - */ - - /* First clear all the quadtree node and triangle active flags */ - qtClearAllFlags(); - smClear_flags(smMesh,T_ACTIVE_FLAG); - - /* calculate the world space coordinates of the view frustum */ - calculate_view_frustum(view->vp,view->hvec,view->vvec,view->horiz, - view->vert, dev_zmin,dev_zmax,nr,far); - - /* Project the view frustum onto the spherical quadtree */ - /* For every cell intersected by the projection of the faces - of the frustum: mark all triangles in the cell as ACTIVE- - Also set the triangles LRU clock counter - */ - /* Near face triangles */ - smLocator_apply_func(smMesh,nr[0],nr[2],nr[3],mark_active_tris,NULL); - smLocator_apply_func(smMesh,nr[2],nr[0],nr[1],mark_active_tris,NULL); - /* Right face triangles */ - smLocator_apply_func(smMesh,nr[0],far[3],far[0],mark_active_tris,NULL); - smLocator_apply_func(smMesh,far[3],nr[0],nr[3],mark_active_tris,NULL); - /* Left face triangles */ - smLocator_apply_func(smMesh,nr[1],far[2],nr[2],mark_active_tris,NULL); - smLocator_apply_func(smMesh,far[2],nr[1],far[1],mark_active_tris,NULL); - /* Top face triangles */ - smLocator_apply_func(smMesh,nr[0],far[0],nr[1],mark_active_tris,NULL); - smLocator_apply_func(smMesh,nr[1],far[0],far[1],mark_active_tris,NULL); - /* Bottom face triangles */ - smLocator_apply_func(smMesh,nr[3],nr[2],far[3],mark_active_tris,NULL); - smLocator_apply_func(smMesh,nr[2],far[2],far[3],mark_active_tris,NULL); - /* Far face triangles */ - smLocator_apply_func(smMesh,far[0],far[2],far[1],mark_active_tris,NULL); - smLocator_apply_func(smMesh,far[2],far[0],far[3],mark_active_tris,NULL); - -#ifdef TEST_DRIVER - VCOPY(FrustumFar[0],far[0]); - VCOPY(FrustumFar[1],far[1]); - VCOPY(FrustumFar[2],far[2]); - VCOPY(FrustumFar[3],far[3]); - VCOPY(FrustumNear[0],nr[0]); - VCOPY(FrustumNear[1],nr[1]); - VCOPY(FrustumNear[2],nr[2]); - VCOPY(FrustumNear[3],nr[3]); -#endif -} - -/* - * smClean() : display has been wiped clean - * - * Called after display has been effectively cleared, meaning that all - * geometry must be resent down the pipeline in the next call to smUpdate(). - */ -smClean() -{ smClean_notify = TRUE; + smCompute_mapping = tmflag; } int qtCache_init(nel) /* initialize for at least nel elements */ int nel; { - static int hsiztab[] = { - 8191, 16381, 32749, 65521, 131071, 262139, 524287, 1048573, 0 - }; - register int i; + static int hsiztab[] = { + 8191, 16381, 32749, 65521, 131071, 262139, 524287, 1048573, 0 + }; + register int i; - if (nel <= 0) { /* call to free table */ - if (qt_hsiz) { - free((char *)qt_htbl); - qt_htbl = NULL; - qt_hsiz = 0; - } - return(0); + if (nel <= 0) { /* call to free table */ + if (qt_hsiz) { + free((void *)qt_htbl); + qt_htbl = NULL; + qt_hsiz = 0; } - nel += nel>>1; /* 66% occupancy */ - for (i = 0; hsiztab[i]; i++) - if (hsiztab[i] > nel) - break; - if (!(qt_hsiz = hsiztab[i])) - qt_hsiz = nel*2 + 1; /* not always prime */ - qt_htbl = (QT_LUENT *)calloc(qt_hsiz, sizeof(QT_LUENT)); - if (qt_htbl == NULL) - qt_hsiz = 0; - for (i = qt_hsiz; i--; ) - qt_htbl[i].qt = EMPTY; - return(qt_hsiz); + return(0); + } + nel += nel>>1; /* 66% occupancy */ + for (i = 0; hsiztab[i]; i++) + if (hsiztab[i] > nel) + break; + if (!(qt_hsiz = hsiztab[i])) + qt_hsiz = nel*2 + 1; /* not always prime */ + qt_htbl = (QT_LUENT *)calloc(qt_hsiz, sizeof(QT_LUENT)); + if (qt_htbl == NULL) + qt_hsiz = 0; + for (i = qt_hsiz; i--; ) + qt_htbl[i].qt = EMPTY; + return(qt_hsiz); } QT_LUENT * qtCache_find(qt) /* find a quadtree table entry */ QUADTREE qt; { - int i, n; - register int ndx; - register QT_LUENT *le; + int i, n; + register int ndx; + register QT_LUENT *le; - if (qt_hsiz == 0 && !qtCache_init(1)) - return(NULL); + if (qt_hsiz == 0 && !qtCache_init(1)) + return(NULL); tryagain: /* hash table lookup */ - ndx = (unsigned long)qt % qt_hsiz; - for (i = 0, n = 1; i < qt_hsiz; i++, n += 2) { - le = &qt_htbl[ndx]; - if (QT_IS_EMPTY(le->qt) || le->qt == qt) - return(le); - if ((ndx += n) >= qt_hsiz) /* this happens rarely */ - ndx = ndx % qt_hsiz; - } - /* table is full, reallocate */ - le = qt_htbl; - ndx = qt_hsiz; - if (!qtCache_init(ndx+1)) { /* no more memory! */ - qt_htbl = le; - qt_hsiz = ndx; - return(NULL); - } + ndx = (unsigned long)qt % qt_hsiz; + for (i = 0, n = 1; i < qt_hsiz; i++, n += 2) { + le = &qt_htbl[ndx]; + if (QT_IS_EMPTY(le->qt) || le->qt == qt) + return(le); + if ((ndx += n) >= qt_hsiz) /* this happens rarely */ + ndx = ndx % qt_hsiz; + } + /* table is full, reallocate */ + le = qt_htbl; + ndx = qt_hsiz; + if (!qtCache_init(ndx+1)) { /* no more memory! */ + qt_htbl = le; + qt_hsiz = ndx; + return(NULL); + } /* copy old table to new and free */ - while (ndx--) - if (!QT_IS_EMPTY(le[ndx].qt)) - copystruct(qtCache_find(le[ndx].qt), &le[ndx]); - free((char *)le); - goto tryagain; /* should happen only once! */ + while (ndx--) + if (!QT_IS_EMPTY(le[ndx].qt)) + copystruct(qtCache_find(le[ndx].qt), &le[ndx]); + free((void *)le); + goto tryagain; /* should happen only once! */ } stCount_level_leaves(lcnt, qt) /* count quadtree leaf nodes at each level */ @@ -219,10 +167,10 @@ register QUADTREE qt; stCount_level_leaves(lcnt+1, QT_NTH_CHILD(qt,3)); } else - lcnt[0]++; + if(QT_LEAF_IS_FLAG(qt)) + lcnt[0]++; } - QTRAVG * qtRender_level(qt,v0,v1,v2,sm,lvl) QUADTREE qt; @@ -233,21 +181,24 @@ int lvl; FVECT a,b,c; register QT_LUENT *le; QTRAVG *rc[4]; + TRI *tri; if (QT_IS_EMPTY(qt)) /* empty leaf node */ return(NULL); if (QT_IS_TREE(qt) && !QT_IS_FLAG(qt)) /* not in our frustum */ return(NULL); + if(QT_IS_LEAF(qt) && !QT_LEAF_IS_FLAG(qt)) /* not in our frustum */ + return(NULL); /* else look up node */ if ((le = qtCache_find(qt)) == NULL) error(SYSTEM, "out of memory in qtRender_level"); if (QT_IS_TREE(qt) && (QT_IS_EMPTY(le->qt) || lvl > 0)) { /* compute children */ qtSubdivide_tri(v0,v1,v2,a,b,c); - rc[0] = qtRender_level(QT_NTH_CHILD(qt,0),v0,a,c,sm,lvl-1); - rc[1] = qtRender_level(QT_NTH_CHILD(qt,1),a,v1,b,sm,lvl-1); - rc[2] = qtRender_level(QT_NTH_CHILD(qt,2),c,b,v2,sm,lvl-1); - rc[3] = qtRender_level(QT_NTH_CHILD(qt,3),b,c,a,sm,lvl-1); + rc[0] = qtRender_level(QT_NTH_CHILD(qt,0),v0,c,b,sm,lvl-1); + rc[1] = qtRender_level(QT_NTH_CHILD(qt,1),c,v1,a,sm,lvl-1); + rc[2] = qtRender_level(QT_NTH_CHILD(qt,2),b,a,v2,sm,lvl-1); + rc[3] = qtRender_level(QT_NTH_CHILD(qt,3),a,b,c,sm,lvl-1); } if (QT_IS_EMPTY(le->qt)) { /* let's make some data! */ @@ -268,27 +219,48 @@ int lvl; } else { /* from triangle set */ - OBJECT *os; - int s0, s1, s2; + S_ID *os; + S_ID s0, s1, s2,s_id; + int t_id; + TRI *tri,*t; os = qtqueryset(qt); - for (n = os[0]; n; n--) + for (i = os[0]; i; i--) { - qtTri_from_id(os[n],a,b,c,NULL,NULL,NULL,&s0,&s1,&s2); - distsum += SM_BG_SAMPLE(sm,s0) ? dev_zmax + s_id = os[i]; + t_id = SM_NTH_VERT(smMesh,s_id); + tri = t = SM_NTH_TRI(smMesh,t_id); + do + { + if(!SM_IS_NTH_T_BASE(sm,t_id)) + { + n++; + s0 = T_NTH_V(t,0); + s1 = T_NTH_V(t,1); + s2 = T_NTH_V(t,2); + VCOPY(a,SM_NTH_WV(sm,s0)); + VCOPY(b,SM_NTH_WV(sm,s1)); + VCOPY(c,SM_NTH_WV(sm,s2)); + distsum += SM_BG_SAMPLE(sm,s0) ? dev_zmax : sqrt(dist2(a,SM_VIEW_CENTER(sm))); - distsum += SM_BG_SAMPLE(sm,s1) ? dev_zmax - : sqrt(dist2(b,SM_VIEW_CENTER(sm))); - distsum += SM_BG_SAMPLE(sm,s2) ? dev_zmax + distsum += SM_BG_SAMPLE(sm,s1) ? dev_zmax + : sqrt(dist2(b,SM_VIEW_CENTER(sm))); + distsum += SM_BG_SAMPLE(sm,s2) ? dev_zmax : sqrt(dist2(c,SM_VIEW_CENTER(sm))); - rgbs[0] += SM_NTH_RGB(sm,s0)[0] + SM_NTH_RGB(sm,s1)[0] - + SM_NTH_RGB(sm,s2)[0]; - rgbs[1] += SM_NTH_RGB(sm,s0)[1] + SM_NTH_RGB(sm,s1)[1] - + SM_NTH_RGB(sm,s2)[1]; - rgbs[2] += SM_NTH_RGB(sm,s0)[2] + SM_NTH_RGB(sm,s1)[2] - + SM_NTH_RGB(sm,s2)[2]; + rgbs[0] += SM_NTH_RGB(sm,s0)[0] + SM_NTH_RGB(sm,s1)[0] + + SM_NTH_RGB(sm,s2)[0]; + rgbs[1] += SM_NTH_RGB(sm,s0)[1] + SM_NTH_RGB(sm,s1)[1] + + SM_NTH_RGB(sm,s2)[1]; + rgbs[2] += SM_NTH_RGB(sm,s0)[2] + SM_NTH_RGB(sm,s1)[2] + + SM_NTH_RGB(sm,s2)[2]; + } + + t_id = smTri_next_ccw_nbr(smMesh,t,s_id); + t = SM_NTH_TRI(smMesh,t_id); + + }while(t != tri); } - n = 3*os[0]; + n *= 3; } if (!n) return(NULL); @@ -306,366 +278,1178 @@ int lvl; VSUM(c,SM_VIEW_CENTER(sm),c,le->av.dist); /* draw triangle */ glColor3ub(le->av.rgb[0],le->av.rgb[1],le->av.rgb[2]); - /* NOTE: Triangle vertex order may change */ - glVertex3d(c[0],c[1],c[2]); - glVertex3d(b[0],b[1],b[2]); glVertex3d(a[0],a[1],a[2]); + glVertex3d(b[0],b[1],b[2]); + glVertex3d(c[0],c[1],c[2]); + } return(&le->av); } -smRender_stree_level(sm,lvl) +smRender_approx_stree_level(sm,lvl) SM *sm; int lvl; { - QUADTREE root; + QUADTREE qt; int i; FVECT t0,t1,t2; - - if (lvl < 1) + STREE *st; + + if (lvl < 0) return; + st = SM_LOCATOR(sm); glPushAttrib(GL_LIGHTING_BIT); glShadeModel(GL_FLAT); glBegin(GL_TRIANGLES); - for(i=0; i < 4; i++) + for(i=0; i < ST_NUM_ROOT_NODES; i++) { - root = ST_NTH_ROOT(SM_LOCATOR(sm),i); - stNth_base_verts(SM_LOCATOR(sm),i,t0,t1,t2); - qtRender_level(root,t0,t1,t2,sm,lvl-1); + qt = ST_ROOT_QT(st,i); + qtRender_level(qt,ST_NTH_V(st,i,0),ST_NTH_V(st,i,1),ST_NTH_V(st,i,2), + sm,lvl); } glEnd(); glPopAttrib(); } - -smRender_stree(sm, qual) /* render some quadtree triangles */ +/* + * smRender_approx(sm,qual,view) + * SM *sm; : mesh + * int qual; : quality level + * VIEW *view; : current view + * + * Renders an approximation to the current mesh based on the quadtree + * subdivision. The quadtree is traversed to a level (based upon the quality: + * the lower the quality, the fewer levels visited, and the coarser, and + * faster, the approximation). The quadtree triangles are drawn relative to + * the current viewpoint, with a depth and color averaged from all of the + * triangles that lie beneath the node. + */ +smRender_approx(sm, qual,view) SM *sm; int qual; +VIEW *view; { - int i, ntarget; + int i, n,ntarget; int lvlcnt[QT_MAX_LEVELS]; + STREE *st; + int4 *active_flag; if (qual <= 0) return; + smCull(sm,view,SM_ALL_LEVELS); /* compute rendering target */ ntarget = 0; - SM_FOR_ALL_ACTIVE_TRIS(sm,i) - ntarget++; - ntarget = ntarget*qual/100; + + active_flag = SM_NTH_FLAGS(sm,T_ACTIVE_FLAG); + for(n=((SM_NUM_TRI(sm)+31)>>5) +1; --n;) + if(active_flag[n]) + for(i=0; i < 32; i++) + if(active_flag[n] & (1L << i)) + ntarget++; + + ntarget = ntarget*qual/MAXQUALITY; if (!ntarget) return; for (i = QT_MAX_LEVELS; i--; ) lvlcnt[i] = 0; - stCount_level_leaves(lvlcnt, SM_LOCATOR(sm)->root); + + st = SM_LOCATOR(sm); + for(i=0; i < ST_NUM_ROOT_NODES;i++) + stCount_level_leaves(lvlcnt, ST_ROOT_QT(st,i)); + for (ntarget -= lvlcnt[i=0]; i < QT_MAX_LEVELS-1; ntarget -= lvlcnt[++i]) if (ntarget < lvlcnt[i+1]) break; /* compute and render target level */ - smRender_stree_level(sm,i); + smRender_approx_stree_level(sm,i); } -smRender_tri(sm,i,vp,clr) +#define GLVERTEX3V(v) glVertex3fv(v) + + +#define render_tri(v0,v1,v2,rgb0,rgb1,rgb2) \ + {glColor3ub(rgb0[0],rgb0[1],rgb0[2]); GLVERTEX3V(v0); \ + glColor3ub(rgb1[0],rgb1[1],rgb1[2]); GLVERTEX3V(v1); \ + glColor3ub(rgb2[0],rgb2[1],rgb2[2]); GLVERTEX3V(v2);} + +/* + * render_mixed_tri(v0,v1,v2,rgb0,rgb1,rgb2,b0,b1,b2) + * SFLOAT v0[3],v1[3],v2[3]; : triangle vertex coordinates + * BYTE rgb0[3],rgb1[3],rgb2[3]; : vertex RGBs + * int b0,b1,b2; : background or base vertex flag + * + * For triangles with one or more base or directional vertices. + * render base vertex color as average of the background and foreground + * vertex RGBs. The coordinates for a fg vertex are calculated by + * subtracting off the current view,normalizing, then scaling to fit + * into the current frustum. + */ +render_mixed_tri(v0,v1,v2,rgb0,rgb1,rgb2,vp,vc,bg0,bg1,bg2) +SFLOAT v0[3],v1[3],v2[3]; +BYTE rgb0[3],rgb1[3],rgb2[3]; +FVECT vp,vc; +int bg0,bg1,bg2; +{ + double d,p[3]; + int j,cnt,rgb[3]; + + /* Average color from bg vertices */ + cnt = 0; + if(bg0 == BASE || bg1==BASE || bg2 == BASE) + { + rgb[0] = rgb[1] = rgb[2] = 0; + if(bg0 != BASE) + { + IADDV3(rgb,rgb0); + cnt++; + } + if(bg1 != BASE) + { + IADDV3(rgb,rgb1); + cnt++; + } + if(bg2 != BASE) + { + IADDV3(rgb,rgb2); + cnt++; + } + IDIVV3(rgb,cnt); + } + if(bg0 == BASE) + glColor3i(rgb[0],rgb[1],rgb[2]); + else + glColor3ub(rgb0[0],rgb0[1],rgb0[2]); + + if(!bg0) + { + VSUB(p,v0,vp); + normalize(p); + IADDV3(p,vc); + glVertex3dv(p); + } + else + GLVERTEX3V(v0); + + if(bg1 == BASE) + glColor3i(rgb[0],rgb[1],rgb[2]); + else + glColor3ub(rgb1[0],rgb1[1],rgb1[2]); + + if(!bg1) + { + VSUB(p,v1,vp); + normalize(p); + IADDV3(p,vc); + glVertex3dv(p); + } + else + GLVERTEX3V(v1); + + if(bg2 == BASE) + glColor3i(rgb[0],rgb[1],rgb[2]); + else + glColor3ub(rgb2[0],rgb2[1],rgb2[2]); + + if(!bg2) + { + VSUB(p,v2,vp); + normalize(p); + IADDV3(p,vc); + glVertex3dv(p); + } + else + GLVERTEX3V(v2); +} + +/* + * smRender_bg_tris(sm,vp,t_flag,bg_flag,wp,rgb) + * SM *sm; : mesh + * FVECT vp; : current viewpoint + * int4 *t_flag,*bg_flag; : triangle flags: t_flag is generic, + * and bg_flag indicates if background tri; + * SFLOAT (*wp)[3];BYTE (*rgb)[3]; : arrays of sample points and RGB colors + * + * Sequentially traverses triangle list and renders all valid tris who + * have t_flag set, and bg_flag set. + */ + +smRender_bg_tris(sm,vp,t_flag,bg_flag,wp,rgb) SM *sm; -int i; FVECT vp; -int clr; +int4 *t_flag,*bg_flag; +SFLOAT (*wp)[3]; +BYTE (*rgb)[3]; { + double d; + int v0_id,v1_id,v2_id; + int i,n,bg0,bg1,bg2; TRI *tri; - double ptr[3]; - int j; - tri = SM_NTH_TRI(sm,i); - if (clr) SM_CLEAR_NTH_T_NEW(sm,i); + glMatrixMode(GL_MODELVIEW); - /* NOTE:Triangles are defined clockwise:historical relative to spherical - tris: could change - */ - for(j=2; j>= 0; j--) + glPushMatrix(); + glTranslated(vp[0],vp[1],vp[2]); + /* The points are a distance of 1 away from the origin: if necessary scale + so that they fit in frustum and are therefore not clipped away + */ + if(dev_zmin >= 0.99) { -#ifdef DEBUG - if(SM_BG_SAMPLE(sm,T_NTH_V(tri,j))) - eputs("SmRenderTri(): shouldnt have bg samples\n"); -#endif - glColor3ub(SM_NTH_RGB(sm,T_NTH_V(tri,j))[0], - SM_NTH_RGB(sm,T_NTH_V(tri,j))[1], - SM_NTH_RGB(sm,T_NTH_V(tri,j))[2]); - VCOPY(ptr,SM_T_NTH_WV(sm,tri,j)); - glVertex3d(ptr[0],ptr[1],ptr[2]); + d = (dev_zmin+dev_zmax)/2.0; + glScaled(d,d,d); } -} + /* move relative to the new view */ + /* move points to unit sphere at origin */ + glTranslated(-SM_VIEW_CENTER(sm)[0],-SM_VIEW_CENTER(sm)[1], + -SM_VIEW_CENTER(sm)[2]); + glBegin(GL_TRIANGLES); + for(n=((SM_NUM_TRI(sm)+31)>>5) +1; --n;) + if(t_flag[n] & bg_flag[n]) + for(i=0; i < 32; i++) + if(t_flag[n] & bg_flag[n] & (1L << i)) + { + tri = SM_NTH_TRI(sm,(n<<5)+i); + v0_id = T_NTH_V(tri,0); + v1_id = T_NTH_V(tri,1); + v2_id = T_NTH_V(tri,2); + bg0 = SM_DIR_ID(sm,v0_id)?DIR:SM_BASE_ID(sm,v0_id)?BASE:0; + bg1 = SM_DIR_ID(sm,v1_id)?DIR:SM_BASE_ID(sm,v1_id)?BASE:0; + bg2 = SM_DIR_ID(sm,v2_id)?DIR:SM_BASE_ID(sm,v2_id)?BASE:0; + if(bg0==DIR && bg1==DIR && bg2==DIR) + render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id]) + else + render_mixed_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id], + rgb[v1_id],rgb[v2_id],vp,SM_VIEW_CENTER(sm),bg0,bg1,bg2); + } + glEnd(); -smRender_mixed_tri(sm,i,vp,clr) + glPopMatrix(); + +} +/* + * smRender_new_bg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb) + * SM *sm; : mesh + * FVECT vp; : current viewpoint + * int4 *new_flag,*active,*bg_flag; : triangle flags: idicates if tri is, + * new,active,bg_flag + * SFLOAT (*wp)[3];BYTE (*rgb)[3]; : arrays of sample points and RGB colors + * + * Sequentially traverses triangle list and renders all valid tris who + * have new_flag set and active_flag and bg_flag set. + */ +smRender_new_bg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb) SM *sm; -int i; FVECT vp; -int clr; +int4 *new_flag,*active_flag,*bg_flag; +SFLOAT (*wp)[3]; +BYTE (*rgb)[3]; { + double d; + int v0_id,v1_id,v2_id; + int i,n,bg0,bg1,bg2; TRI *tri; - double p[3],d; - int j,ids[3],cnt; - int rgb[3]; - tri = SM_NTH_TRI(sm,i); - if (clr) SM_CLEAR_NTH_T_NEW(sm,i); + glMatrixMode(GL_MODELVIEW); - /* NOTE:Triangles are defined clockwise:historical relative to spherical - tris: could change - */ - cnt = 0; - d = 0.0; - rgb[0] = rgb[1] = rgb[2] = 0; - for(j=0;j < 3;j++) + glPushMatrix(); + glTranslated(vp[0],vp[1],vp[2]); + /* The points are a distance of 1 away from the origin: if necessary scale + so that they fit in frustum and are therefore not clipped away + */ + if(dev_zmin >= 0.99) { - ids[j] = T_NTH_V(tri,j); - if(!SM_BG_SAMPLE(sm,ids[j])) - { - rgb[0] += SM_NTH_RGB(sm,ids[j])[0]; - rgb[1] += SM_NTH_RGB(sm,ids[j])[1]; - rgb[2] += SM_NTH_RGB(sm,ids[j])[2]; - cnt++; - d += DIST(vp,SM_NTH_WV(sm,ids[j])); - } + d = (dev_zmin+dev_zmax)/2.0; + glScaled(d,d,d); } - if(cnt > 1) - { - rgb[0]/=cnt; rgb[1]/=cnt; rgb[2]/=cnt; - d /= (double)cnt; - } - for(j=2; j>= 0; j--) - { - if(SM_BG_SAMPLE(sm,ids[j])) - { - glColor3ub(rgb[0],rgb[1],rgb[2]); - VSUB(p,SM_NTH_WV(sm,ids[j]),SM_VIEW_CENTER(sm)); - p[0] *= d; - p[1] *= d; - p[2] *= d; - VADD(p,p,SM_VIEW_CENTER(sm)); - } - else - { - glColor3ub(SM_NTH_RGB(sm,ids[j])[0],SM_NTH_RGB(sm,ids[j])[1], - SM_NTH_RGB(sm,ids[j])[2]); - VCOPY(p,SM_NTH_WV(sm,ids[j])); - } - glVertex3d(p[0],p[1],p[2]); - } + /* move relative to the new view */ + /* move points to unit sphere at origin */ + glTranslated(-SM_VIEW_CENTER(sm)[0],-SM_VIEW_CENTER(sm)[1], + -SM_VIEW_CENTER(sm)[2]); + glBegin(GL_TRIANGLES); + for(n=((SM_NUM_TRI(sm)+31)>>5) +1; --n;) + if(new_flag[n] & active_flag[n] & bg_flag[n]) + for(i=0; i < 32; i++) + if(new_flag[n] & active_flag[n] & bg_flag[n] & (1L << i)) + { + tri = SM_NTH_TRI(sm,(n<<5)+i); + v0_id = T_NTH_V(tri,0); + v1_id = T_NTH_V(tri,1); + v2_id = T_NTH_V(tri,2); + bg0 = SM_DIR_ID(sm,v0_id)?DIR:SM_BASE_ID(sm,v0_id)?BASE:0; + bg1 = SM_DIR_ID(sm,v1_id)?DIR:SM_BASE_ID(sm,v1_id)?BASE:0; + bg2 = SM_DIR_ID(sm,v2_id)?DIR:SM_BASE_ID(sm,v2_id)?BASE:0; + if(bg0==DIR && bg1==DIR && bg2==DIR) + render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id]) + else + render_mixed_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id], + rgb[v1_id],rgb[v2_id],vp,SM_VIEW_CENTER(sm),bg0,bg1,bg2); + } + glEnd(); + + glPopMatrix(); + } -smRender_bg_tri(sm,i,vp,d,clr) -SM *sm; -int i; +/* + * render_base_tri(v0,v1,v2,rgb0,rgb1,rgb2,vp,b0,b1,b2) + * SFLOAT v0[3],v1[3],v2[3]; : triangle vertex coordinates + * BYTE rgb0[3],rgb1[3],rgb2[3]; : vertex RGBs + * FVECT vp; : current viewpoint + * int b0,b1,b2; : vertex base flag + * + * render base vertex color as average of the non-base vertex RGBs. The + * base vertex coordinate is taken as the stored vector, scaled out by + * the average distance to the non-base vertices + */ +render_base_tri(v0,v1,v2,rgb0,rgb1,rgb2,vp,b0,b1,b2) +SFLOAT v0[3],v1[3],v2[3]; +BYTE rgb0[3],rgb1[3],rgb2[3]; FVECT vp; -double d; -int clr; +int b0,b1,b2; { + int cnt; + int rgb[3]; + double d; double p[3]; - int j,id; - TRI *tri; - - tri = SM_NTH_TRI(sm,i); - if (clr) SM_CLEAR_NTH_T_NEW(sm,i); - /* NOTE:Triangles are defined clockwise:historical relative to spherical - tris: could change - */ - for(j=2; j>= 0; j--) + cnt = 0; + rgb[0] = rgb[1] = rgb[2] = 0; + d = 0.0; + /* If all vertices are base: don't render */ + if(b0&&b1&&b2) + return; + /* First calculate color and coordinates + for base vertices based on world space vertices*/ + if(!b0) { - id = T_NTH_V(tri,j); - glColor3ub(SM_NTH_RGB(sm,id)[0],SM_NTH_RGB(sm,id)[1], - SM_NTH_RGB(sm,id)[2]); - VSUB(p,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm)); - if(dev_zmin >= 0.99) - { - p[0] *= d; - p[1] *= d; - p[2] *= d; - } - VADD(p,p,vp); - glVertex3d(p[0],p[1],p[2]); + IADDV3(rgb,rgb0); + d += DIST(v0,vp); + cnt++; } + if(!b1) + { + IADDV3(rgb,rgb1); + d += DIST(v1,vp); + cnt++; + } + if(!b2) + { + IADDV3(rgb,rgb2); + d += DIST(v2,vp); + cnt++; + } + IDIVV3(rgb,cnt); + d /= (double)cnt; + + /* Now render triangle */ + if(b0) + { + glColor3ub(rgb[0],rgb[1],rgb[2]); + SUBV3(p,v0,vp); + ISCALEV3(p,d); + IADDV3(p,vp); + glVertex3dv(p); + } + else + { + glColor3ub(rgb0[0],rgb0[1],rgb0[2]); + GLVERTEX3V(v0); + } + if(b1) + { + glColor3ub(rgb[0],rgb[1],rgb[2]); + SUBV3(p,v1,vp); + ISCALEV3(p,d); + IADDV3(p,vp); + glVertex3dv(p); + } + else + { + glColor3ub(rgb1[0],rgb1[1],rgb1[2]); + GLVERTEX3V(v1); + } + if(b2) + { + glColor3ub(rgb[0],rgb[1],rgb[2]); + SUBV3(p,v2,vp); + ISCALEV3(p,d); + IADDV3(p,vp); + glVertex3dv(p); + } + else + { + glColor3ub(rgb2[0],rgb2[1],rgb2[2]); + GLVERTEX3V(v2); + } } - -smRender_mesh(sm,vp,clr) +/* + * smRender_fg_tris(sm,vp,t_flag,bg_flag,wp,rgb) + * SM *sm; : mesh + * FVECT vp; : current viewpoint + * int4 *t_flag,*bg_flag; : triangle flags: t_flag is generic,bg_flag + * indicates if background tri; + * SFLOAT (*wp)[3];BYTE (*rgb)[3]; : arrays of sample points and RGB colors + * + * Sequentially gos through triangle list and renders all valid tris who + * have t_flag set, and NOT bg_flag set. + */ +smRender_fg_tris(sm,vp,t_flag,bg_flag,wp,rgb) SM *sm; FVECT vp; -int clr; +int4 *t_flag,*bg_flag; +SFLOAT (*wp)[3]; +BYTE (*rgb)[3]; { - int i; TRI *tri; - double ptr[3],d; - int j; - - d = (dev_zmin+dev_zmax)/2.0; - glPushAttrib(GL_DEPTH_BUFFER_BIT); + int i,n,b0,b1,b2; + S_ID v0_id,v1_id,v2_id; - /* First draw background polygons */ - - glDisable(GL_DEPTH_TEST); glBegin(GL_TRIANGLES); - SM_FOR_ALL_ACTIVE_BG_TRIS(sm,i) - smRender_bg_tri(sm,i,vp,d,clr); + for(n=((SM_NUM_TRI(sm)+31)>>5) +1; --n;) + if(t_flag[n]) + for(i=0; i < 32; i++) + if(t_flag[n] & (1L << i) & ~bg_flag[n]) + { + tri = SM_NTH_TRI(sm,(n<<5)+i); + v0_id = T_NTH_V(tri,0); + v1_id = T_NTH_V(tri,1); + v2_id = T_NTH_V(tri,2); + b0 = SM_BASE_ID(sm,v0_id); + b1 = SM_BASE_ID(sm,v1_id); + b2 = SM_BASE_ID(sm,v2_id); + if(b0 || b1 || b2) + render_base_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id], + rgb[v1_id],rgb[v2_id],SM_VIEW_CENTER(sm),b0,b1,b2); + else + render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id]) + + } glEnd(); - - glEnable(GL_DEPTH_TEST); - glBegin(GL_TRIANGLES); - SM_FOR_ALL_ACTIVE_FG_TRIS(sm,i) - { - if(!SM_MIXED_TRI(sm,i)) - smRender_tri(sm,i,vp,clr); - else - smRender_mixed_tri(sm,i,vp,clr); - } - glEnd(); - glPopAttrib(); } -smRender_tri_edges(sm,i) +/* + * smRender_new_fg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb) + * SM *sm; : mesh + * FVECT vp; : current viewpoint + * int4 *new_flag,*active_flag,*bg_flag; : triangle flags: indicate if + * tri is new,active,background + * SFLOAT (*wp)[3];BYTE (*rgb)[3]; : arrays of sample points and RGB colors + * + * Sequentially gos through triangle list and renders all valid tris who + * have new_flag and active_flag set, and NOT bg_flag set. + */ +smRender_new_fg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb) SM *sm; -int i; +FVECT vp; +int4 *new_flag,*active_flag,*bg_flag; +SFLOAT (*wp)[3]; +BYTE (*rgb)[3]; { TRI *tri; - int j; - double ptr[3]; + int i,n,b0,b1,b2; + S_ID v0_id,v1_id,v2_id; + + glBegin(GL_TRIANGLES); + for(n=((SM_NUM_TRI(sm)+31)>>5) +1; --n;) + if(new_flag[n] & active_flag[n]) + for(i=0; i < 32; i++) + if(new_flag[n] & active_flag[n] & (1L << i) & ~bg_flag[n]) + { + tri = SM_NTH_TRI(sm,(n<<5)+i); + v0_id = T_NTH_V(tri,0); + v1_id = T_NTH_V(tri,1); + v2_id = T_NTH_V(tri,2); + b0 = SM_BASE_ID(sm,v0_id); + b1 = SM_BASE_ID(sm,v1_id); + b2 = SM_BASE_ID(sm,v2_id); + if(b0 || b1 || b2) + render_base_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id], + rgb[v1_id],rgb[v2_id],SM_VIEW_CENTER(sm),b0,b1,b2); + else + render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id]) + } + glEnd(); - - tri = SM_NTH_TRI(sm,i); - - /* Triangles are defined clockwise:historical relative to spherical - tris: could change - */ - for(j=2; j >=0; j--) - { - VCOPY(ptr,SM_NTH_WV(sm,T_NTH_V(tri,j))); - glVertex3d(ptr[0],ptr[1],ptr[2]); - VCOPY(ptr,SM_NTH_WV(sm,T_NTH_V(tri,(j+1)%3))); - glVertex3d(ptr[0],ptr[1],ptr[2]); - } } +/* Test for qsort to depth sort triangles */ int compare_tri_depths(T_DEPTH *td1,T_DEPTH *td2) { double d; d = td2->depth-td1->depth; - if(d > 0.0) return(1); if(d < 0.0) return(-1); - return(0); } -LIST -*smDepth_sort_tris(sm,vp,td) + +/* + * smOrder_new_tris(sm,vp,td) + * SM *sm; : mesh + * FVECT vp; : current viewpoint + * T_DEPTH *td; : holds returned list of depth sorted tris + * + * Creates list of all new tris, with their distance from the current + * viewpoint, and sorts the list based on this distance + */ +T_DEPTH +*smOrder_new_tris(sm,vp) SM *sm; FVECT vp; -T_DEPTH *td; { - int i,j,t_id,v; + T_DEPTH *td; + int n,i,j,tcnt,v,size; TRI *tri; double d,min_d; - LIST *tlist=NULL; + FVECT diff; + int4 *new_flag,*bg_flag,*active_flag; + + td = (T_DEPTH *)tempbuf(NEW_TRI_CNT*sizeof(T_DEPTH),FALSE); + size = NEW_TRI_CNT; - i = 0; - SM_FOR_ALL_NEW_TRIS(sm,t_id) + tcnt=0; + new_flag = SM_NTH_FLAGS(sm,T_NEW_FLAG); + bg_flag = SM_NTH_FLAGS(sm,T_BG_FLAG); + active_flag = SM_NTH_FLAGS(sm,T_ACTIVE_FLAG); + for(n=((SM_NUM_TRI(sm)+31)>>5) +1; --n;) + if(active_flag[n] & new_flag[n] & ~bg_flag[n]) + for(i=0; i < 32; i++) + if(active_flag[n] & new_flag[n] & (1L << i) & ~bg_flag[n]) + { + tri = SM_NTH_TRI(sm,(n<<5)+i); + if(tcnt+1 >= size) + { + size += 100; + td = (T_DEPTH *)tempbuf(size*sizeof(T_DEPTH),TRUE); + } + td[tcnt].tri = (n << 5)+i; + min_d = -1; + for(j=0;j < 3;j++) + { + v = T_NTH_V(tri,j); + VSUB(diff,SM_NTH_WV(sm,v),vp); + d = DOT(diff,diff); + if(min_d == -1 || d < min_d) + min_d = d; + } + td[tcnt++].depth = min_d; + } + td[tcnt].tri = -1; + if(tcnt) + qsort((void *)td,tcnt,sizeof(T_DEPTH),compare_tri_depths); + return(td); +} + +/* + * smUpdate_tm(sm) : Update the tone-mapping + * SM *sm; : mesh + * + */ +smUpdate_tm(sm) +SM *sm; +{ + int t = SM_TONE_MAP(sm); + + if(t==0 || smCompute_mapping) { - if(SM_BG_TRI(sm,t_id)) + tmClearHisto(); + tmAddHisto(SM_BRT(sm),SM_NUM_SAMP(sm),1); + if(tmComputeMapping(0.,0.,0.) != TM_E_OK) + return; + t = 0; + smCompute_mapping = FALSE; + } + tmMapPixels(SM_NTH_RGB(sm,t),&SM_NTH_BRT(sm,t),SM_NTH_CHR(sm,t), + SM_NUM_SAMP(sm)-t); + SM_TONE_MAP(sm) = SM_NUM_SAMP(sm); +} + +/* + * smRender_inc(sm,vp) : Incremental update of mesh + * SM * sm; : mesh + * FVECT vp; : current view point + * + * If a relatively small number of new triangles have been created, + * do an incremental update. Render new triangles with depth buffering + * turned off, if the current viewpoint is not the same as canonical view- + * point, must use painter's approach to resolve visibility:first depth sort + * triangles, then render back-to-front. +*/ +smRender_inc(sm,vp) +SM *sm; +FVECT vp; +{ + S_ID v0_id,v1_id,v2_id; + int i,n,b0,b1,b2; + TRI *tri; + SFLOAT (*wp)[3]; + BYTE (*rgb)[3]; + int4 *new_flag,*bg_flag,*active_flag; + T_DEPTH *td = NULL; + + + /* For all of the NEW and ACTIVE triangles (since last update): + Go through and sort on depth value (from vp). Turn + Depth Buffer test off and render back-front + */ + + /* Must depth sort if current view point is not same as canonical */ + if(!EQUAL_VEC3(SM_VIEW_CENTER(sm),vp)) + td = smOrder_new_tris(sm,vp); + wp = SM_WP(sm); + rgb =SM_RGB(sm); + new_flag = SM_NTH_FLAGS(sm,T_NEW_FLAG); + active_flag = SM_NTH_FLAGS(sm,T_ACTIVE_FLAG); + bg_flag = SM_NTH_FLAGS(sm,T_BG_FLAG); + /* Turn Depth Test off -- using Painter's algorithm */ + glPushAttrib(GL_DEPTH_BUFFER_BIT); + glDepthFunc(GL_ALWAYS); + + smRender_new_bg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb); + if(!td) + smRender_new_fg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb); + else + { + glBegin(GL_TRIANGLES); + for(i=0; td[i].tri != -1;i++) { - tlist = push_data(tlist,t_id); - continue; + tri = SM_NTH_TRI(sm,td[i].tri); + /* Dont need to check for valid tri because flags are + cleared on delete + */ + v0_id = T_NTH_V(tri,0); + v1_id = T_NTH_V(tri,1); + v2_id = T_NTH_V(tri,2); + b0 = SM_BASE_ID(sm,v0_id); + b1 = SM_BASE_ID(sm,v1_id); + b2 = SM_BASE_ID(sm,v2_id); + if(b0 || b1 || b2) + render_base_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id], + rgb[v1_id],rgb[v2_id],SM_VIEW_CENTER(sm),b0,b1,b2); + else + render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id]) } - tri = SM_NTH_TRI(sm,t_id); -#ifdef DEBUG - if(i >= smNew_tri_cnt) + glEnd(); + freebuf(td); + } + /* Restore Depth Test */ + glPopAttrib(); +} + +/* + * smRender_qtree_dl(sm,qt,vp,wp,rgb,i,level_i,max_level,leaf_cnt,which) + * SM *sm; : mesh + * QUADTREE qt; : quadtree base node + * FVECT vp; : current viewpoint + * SFLOAT (*wp)[3]; : array of sample points + * BYTE (*rgb)[3]; : array of RGB values for samples + * int i,level_i,level,max_level,leaf_cnt; + * : variables to keep track of where + * we are in the quadtree traversal in order to map nodes to + * corresponding array locations, where nodes are stored in breadth- + * first order. i is the index of the current node,level_i is the + * index of the first node on the current quadtree level, max_level is + * the maximum number of levels to traverse, and leaf_cnt is the number + * of leaves on the current level + * int which; flag indicates whether to render fg or bg tris + * + * + * Render the tris stored in qtree using display lists. For each node at + * the leaf or max_level, call the display_list if it exists, else traverse + * down the subtree and render the nodes into a new display list which is + * stored for future use. + */ +smRender_qtree_dl(sm,qt,vp,wp,rgb,i,level_i,level,max_level,leaf_cnt,which) +SM *sm; +QUADTREE qt; +FVECT vp; +SFLOAT (*wp)[3]; +BYTE (*rgb)[3]; +int i,level_i,level,max_level,leaf_cnt; +int which; +{ + int j; + + if(QT_IS_EMPTY(qt)) + return; + + if(QT_IS_LEAF(qt) || level == max_level) + { + if(QT_IS_LEAF(qt)) { - eputs("smDepth_sort_tris():More tris than reported by smNew_tri_cnt\n"); - break; + if(!QT_LEAF_IS_FLAG(qt)) + return; } -#endif - td[i].tri = t_id; - min_d = -1; - for(j=0;j < 3;j++) + else + if(!QT_IS_FLAG(qt)) + return; + + if(!Display_lists[i][which]) { - v = T_NTH_V(tri,j); - if(!SM_BG_SAMPLE(sm,v)) - { - d = DIST(vp,SM_NTH_WV(sm,v)); - if(min_d == -1 || d < min_d) - min_d = d; - } + Display_lists[i][which] = i+1 + which*SM_DL_LISTS; + glNewList(Display_lists[i][which],GL_COMPILE_AND_EXECUTE); + smClear_flags(sm,T_NEW_FLAG); + glBegin(GL_TRIANGLES); + smRender_qtree(sm,qt,vp,wp,rgb,which,FALSE); + glEnd(); + glEndList(); } - td[i].depth = min_d; - i++; + else + { + glCallList(Display_lists[i][which]); + } } - td[i].tri = -1; - if(i) - qsort((void *)td,i,sizeof(T_DEPTH),compare_tri_depths); - return(tlist); + else + if(QT_IS_FLAG(qt)) + { + i = ((i - level_i)<< 2) + level_i + leaf_cnt; + level_i += leaf_cnt; + leaf_cnt <<= 2; + for(j=0; j < 4; j++) + smRender_qtree_dl(sm,QT_NTH_CHILD(qt,j),vp,wp,rgb, + i+j,level_i,level+1,max_level,leaf_cnt,which); + } + } - -smUpdate_Rendered_mesh(sm,vp,clr) +/* + * smRender_qtree(sm,qt,vp,wp,rgb,which,cull) : Render the tris stored in qtree + * SM *sm; : mesh + * QUADTREE qt; : quadtree base node + * FVECT vp; : current viewpoint + * SFLOAT (*wp)[3] : array of sample points + * BYTE (*rgb)[3] : array of RGB values for samples + * int which; : flag indicates whether to render fg or bg tris + * int cull; : if true, only traverse active (flagged) nodes + * + */ +smRender_qtree(sm,qt,vp,wp,rgb,which,cull) SM *sm; +QUADTREE qt; FVECT vp; -int clr; +SFLOAT (*wp)[3]; +BYTE (*rgb)[3]; +int which,cull; { - static T_DEPTH *td= NULL; - static int tsize = 0; int i; - GLint depth_test; - double d; - LIST *bglist; - /* For all of the NEW triangles (since last update): assume - ACTIVE. Go through and sort on depth value (from vp). Turn - Depth Buffer test off and render back-front - */ - /* NOTE: could malloc each time or hard code */ - if(smNew_tri_cnt > tsize) + + if(QT_IS_EMPTY(qt)) + return; + + if(QT_IS_LEAF(qt)) { - if(td) - free((char *)td); - td = (T_DEPTH *)malloc(smNew_tri_cnt*sizeof(T_DEPTH)); - tsize = smNew_tri_cnt; + TRI *t,*tri; + S_ID *optr,s_id,v0_id,v1_id,v2_id; + int bg0,bg1,bg2,t_id; + + if(cull && !QT_LEAF_IS_FLAG(qt)) + return; + + optr = qtqueryset(qt); + for (i = QT_SET_CNT(optr);i > 0; i--) + { + s_id = QT_SET_NEXT_ELEM(optr); + t_id = SM_NTH_VERT(smMesh,s_id); + tri = t = SM_NTH_TRI(smMesh,t_id); + do + { + if((!cull || SM_IS_NTH_T_ACTIVE(sm,t_id)) && !SM_IS_NTH_T_NEW(sm,t_id)) + { + bg0 = SM_IS_NTH_T_BG(sm,t_id); + if((which == SM_RENDER_FG && !bg0) || (which== SM_RENDER_BG && bg0)) + { + v0_id = T_NTH_V(t,0); + v1_id = T_NTH_V(t,1); + v2_id = T_NTH_V(t,2); + if(bg0) + { + bg0 = SM_DIR_ID(sm,v0_id)?DIR:SM_BASE_ID(sm,v0_id)?BASE:0; + bg1 = SM_DIR_ID(sm,v1_id)?DIR:SM_BASE_ID(sm,v1_id)?BASE:0; + bg2 = SM_DIR_ID(sm,v2_id)?DIR:SM_BASE_ID(sm,v2_id)?BASE:0; + SM_SET_NTH_T_NEW(sm,t_id); + if(bg0==DIR && bg1==DIR && bg2==DIR) + render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id]) + else + render_mixed_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id], + rgb[v1_id],rgb[v2_id],vp,SM_VIEW_CENTER(sm),bg0,bg1,bg2); + } + else + { + SM_SET_NTH_T_NEW(sm,t_id); + bg0 = SM_BASE_ID(sm,v0_id); + bg1 = SM_BASE_ID(sm,v1_id); + bg2 = SM_BASE_ID(sm,v2_id); + if(bg0 || bg1 || bg2) + render_base_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id], + rgb[v1_id],rgb[v2_id],SM_VIEW_CENTER(sm),bg0,bg1,bg2); + else + render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id]) + } + } + } + t_id = smTri_next_ccw_nbr(smMesh,t,s_id); + t = SM_NTH_TRI(smMesh,t_id); + }while(t!=tri); + } } - if(!td) - { - error(SYSTEM,"smUpdate_Rendered_mesh:Cannot allocate memory\n"); - } - bglist = smDepth_sort_tris(sm,vp,td); + else + if(!cull || QT_IS_FLAG(qt)) + for(i=0; i < 4; i++) + smRender_qtree(sm,QT_NTH_CHILD(qt,i),vp,wp,rgb,which,cull); +} - /* Turn Depth Test off -- using Painter's algorithm */ + +/* + * smRender_mesh(sm,view,cull) : Render mesh Triangles + * SM *sm; : mesh + * VIEW *view; : current view + * int cull; : cull Flag + * + * If cull is TRUE, first mark tris in current + * frustum and only render them. Normally, cull will be FALSE only if + * it is known that all tris lie in frustum, e.g. after a rebuild + * + */ +smRender_mesh(sm,view,cull) +SM *sm; +VIEW *view; +int cull; +{ + SFLOAT (*wp)[3]; + BYTE (*rgb)[3]; + int i; + STREE *st= SM_LOCATOR(sm); + + wp = SM_WP(sm); + rgb =SM_RGB(sm); + + smClear_flags(sm,T_NEW_FLAG); + + if(cull) + smCull(sm,view,SM_ALL_LEVELS); + glPushAttrib(GL_DEPTH_BUFFER_BIT); glDisable(GL_DEPTH_TEST); - d = (dev_zmin+dev_zmax)/2.0; - /* Now render back-to front */ - /* First render bg triangles */ + + glMatrixMode(GL_MODELVIEW); + glPushMatrix(); + /* move relative to the new view */ + glTranslated(view->vp[0],view->vp[1],view->vp[2]); + + /* The points are a distance of 1 away from the origin: if necessary + scale so that they fit in frustum and are therefore not clipped away + */ + if(dev_zmin >= 0.99) + { + double d; + + d = (dev_zmin+dev_zmax)/2.0; + glScaled(d,d,d); + } + /* move points to unit sphere at origin */ + glTranslated(-SM_VIEW_CENTER(sm)[0],-SM_VIEW_CENTER(sm)[1], + -SM_VIEW_CENTER(sm)[2]); + glBegin(GL_TRIANGLES); - while(bglist) - smRender_bg_tri(sm,pop_list(&bglist),vp,d,clr); + for(i=0; i < ST_NUM_ROOT_NODES; i++) + smRender_qtree(sm,ST_ROOT_QT(st,i),view->vp,wp,rgb,SM_RENDER_BG,cull); glEnd(); + glPopMatrix(); + glEnable(GL_DEPTH_TEST); + glBegin(GL_TRIANGLES); - i=0; - while(td[i].tri != -1) - if(!SM_MIXED_TRI(sm,td[i].tri)) - smRender_tri(sm,td[i++].tri,vp,clr); - else - smRender_mixed_tri(sm,td[i++].tri,vp,clr); + for(i=0; i < ST_NUM_ROOT_NODES; i++) + smRender_qtree(sm,ST_ROOT_QT(st,i),view->vp,wp,rgb,SM_RENDER_FG,cull); glEnd(); - /* Restore Depth Test */ glPopAttrib(); } +/* + * smRender_mesh_dl(sm,view) : Render stree utilizing display lists + * SM *sm; : mesh + * VIEW *view; : current view + */ +smRender_mesh_dl(sm,view) +SM *sm; +VIEW *view; +{ + SFLOAT (*wp)[3]; + BYTE (*rgb)[3]; + STREE *st; + int i; + + if(SM_DL_LEVELS == 0) + { + if(!Display_lists[0][0]) + { + Display_lists[0][0] = 1; + glNewList(Display_lists[0][0],GL_COMPILE_AND_EXECUTE); + smRender_mesh(sm,view,FALSE); + glEndList(); + } + else + glCallList(Display_lists[0][0]); + + return; + } + smClear_flags(sm,T_NEW_FLAG); + + smCull(sm,view,SM_DL_LEVELS); + + st = SM_LOCATOR(sm); + + wp = SM_WP(sm); + rgb =SM_RGB(sm); + + /* For all active quadtree nodes- first render bg tris, then fg */ + /* If display list exists, use otherwise create/display list */ + glPushAttrib(GL_DEPTH_BUFFER_BIT); + glDisable(GL_DEPTH_TEST); + + glMatrixMode(GL_MODELVIEW); + glPushMatrix(); + + /* move relative to the new view */ + glTranslated(view->vp[0],view->vp[1],view->vp[2]); + + /* The points are a distance of 1 away from the origin: if necessary + scale so that they fit in frustum and are therefore not clipped away + */ + if(dev_zmin >= 0.99) + { + double d; + d = (dev_zmin+dev_zmax)/2.0; + glScaled(d,d,d); + } + /* move points to unit sphere at origin */ + glTranslated(-SM_VIEW_CENTER(sm)[0],-SM_VIEW_CENTER(sm)[1], + -SM_VIEW_CENTER(sm)[2]); + for(i=0; i < ST_NUM_ROOT_NODES; i++) + smRender_qtree_dl(sm,ST_ROOT_QT(st,i),view->vp,wp,rgb,i,0,1, + SM_DL_LEVELS,8,SM_RENDER_BG); + glPopMatrix(); + + glEnable(GL_DEPTH_TEST); + for(i=0; i < ST_NUM_ROOT_NODES; i++) + smRender_qtree_dl(sm,ST_ROOT_QT(st,i),view->vp,wp,rgb,i,0,1, + SM_DL_LEVELS,8,SM_RENDER_FG); + glPopAttrib(); +} + + + /* - * smUpdate(view, qua) : update OpenGL output geometry for view vp + * smRender_tris(sm,view,render_flag) : Render all of the mesh triangles + * SM *sm : current geometry + * VIEW *view : current view + * int render_flag : if render_flag & SM_RENDER_CULL: do culling first + * + * Renders mesh by traversing triangle list and drawing all active tris- + * background tris first, then foreground and mixed tris + */ +smRender_tris(sm,view,render_flag) +SM *sm; +VIEW *view; +int render_flag; +{ + int4 *active_flag,*bg_flag; + SFLOAT (*wp)[3]; + BYTE (*rgb)[3]; + + wp = SM_WP(sm); + rgb = SM_RGB(sm); + active_flag = SM_NTH_FLAGS(sm,T_ACTIVE_FLAG); + bg_flag = SM_NTH_FLAGS(sm,T_BG_FLAG); + + if(render_flag & SM_RENDER_CULL) + smCull(sm,view,SM_ALL_LEVELS); + + /* Render triangles made up of points at infinity by turning off + depth-buffering and projecting the points onto a sphere around the view*/ + glPushAttrib(GL_DEPTH_BUFFER_BIT); + glDisable(GL_DEPTH_TEST); + smRender_bg_tris(sm,view->vp,active_flag,bg_flag,wp,rgb); + + /* Render triangles containing world-space points */ + glEnable(GL_DEPTH_TEST); + smRender_fg_tris(sm,view->vp,active_flag,bg_flag,wp,rgb); + + glPopAttrib(); + +} + +/* Clear all of the display lists */ +clear_display_lists() +{ + int i; + for(i=0; i< SM_DL_LISTS; i++) + { + if(Display_lists[i][0]) + { /* Clear the foreground display list */ + glDeleteLists(Display_lists[i][0],1); + Display_lists[i][0] = 0; + } + if(Display_lists[i][1]) + { /* Clear the background display list */ + glDeleteLists(Display_lists[i][1],1); + Display_lists[i][1] = 0; + } + } +} + +/* + * qtClear_dl(qt,i,level_i,level,max_level,leaf_cnt) :clear display lists + * QUADTREE *qt; : Quadtree node + * int i; : index into list of display lists for this node + * int level_i; : index for first node at this level + * int level,max_level; : current level, maximum level to descend + * int leaf_cnt; : number of leaves at this level + * + * For each node under this node that has its flag set: delete all + * existing display lists. Display lists are stored in an array indexed as + * if the quadtree was traversed in a breadth first order (indices 0-7 are + * the 8 quadtree roots, indices 8-11 the first level children of root 0, + * indices 12-15 the children of root 1, etc). It is assumes that the display + * lists will only be stored for a small number of levels: if this is not + * true, a hashing scheme would work better for storing/retrieving the + * display lists + */ +qtClear_dl(qt,i,level_i,level,max_level,leaf_cnt) +QUADTREE qt; +int i,level_i,level,max_level,leaf_cnt; +{ + int j; + + if(QT_IS_EMPTY(qt)) + return; + if(QT_IS_LEAF(qt) || level== max_level) + { + if(QT_IS_LEAF(qt)) + { + if(!QT_LEAF_IS_FLAG(qt)) + return; + } + else + if(!QT_IS_FLAG(qt)) + return; + if(Display_lists[i][0]) + { + glDeleteLists(Display_lists[i][0],1); + Display_lists[i][0] = 0; + } + if(Display_lists[i][1]) + { + glDeleteLists(Display_lists[i][1],1); + Display_lists[i][1] = 0; + } + } + else + if(QT_IS_FLAG(qt)) + { + /* Calculate the index for the first child given the values + of the parent at the current level + */ + i = ((i - level_i)<< 2) + level_i + leaf_cnt; + level_i += leaf_cnt; + leaf_cnt <<= 2; + for(j=0; j < 4; j++) + qtClear_dl(QT_NTH_CHILD(qt,j),i+j,level_i,level+1,max_level, + leaf_cnt); + } +} + +/* + * smInvalidate_view(sm,view) : Invalidate rendering representation for view + * SM *sm; : mesh + * VIEW *view; : current view + * + * Delete the existing display lists for geometry in the current + * view frustum: Called when the geometry in the frustum has been changed + */ +smInvalidate_view(sm,view) +SM *sm; +VIEW *view; +{ + int i; + + if(SM_DL_LEVELS == 0) + { + if(Display_lists[0][0]) + { + glDeleteLists(Display_lists[0][0],1); + Display_lists[0][0] = 0; + } + return; + } + /* Mark qtree nodes/tris in frustum */ + smCull(sm,view,SM_DL_LEVELS); + + /* Invalidate display_lists in marked qtree nodes */ + for(i=0; i < ST_NUM_ROOT_NODES; i++) + qtClear_dl(ST_ROOT_QT(SM_LOCATOR(sm),i),i,0,1,SM_DL_LEVELS,8); + +} + + +/* + * smRender(sm,view, qual): render OpenGL output geometry + * SM *sm; : current mesh representation + * VIEW *view; : desired view + * int qual; : quality level (percentage on linear time scale) + * + * Render the current mesh: + * recompute tone mapping if full redraw and specified: + * if moving (i.e. qual < MAXQUALITY) + * render the cached display lists, if quality drops + * below threshold, render approximation instead + * if stationary + * render mesh geometry without display lists, unless up-to-date + * display lists already exist. + */ +smRender(sm,view,qual) +SM *sm; +VIEW *view; +int qual; +{ + /* Unless quality > MAXQUALITY, render using display lists */ + if(qual <= MAXQUALITY) + { + /* If quality above threshold: render mesh*/ + if(qual > (MAXQUALITY*2/4) ) + /* render stree using display lists */ + smRender_mesh_dl(sm,view); + else + { + /* If quality below threshold, use approximate rendering */ + smRender_approx(sm,qual,view); + } + } + else + { + /* render stree without display lists */ + smRender_mesh(sm,view,TRUE); + } +} + + +/* + * smUpdate(view, qual) : update OpenGL output geometry * VIEW *view; : desired view * int qual; : quality level (percentage on linear time scale) * @@ -673,91 +1457,79 @@ int clr; * view has already been set up and the correct frame buffer has been * selected for drawing. The quality level is on a linear scale, where 100% * is full (final) quality. It is not necessary to redraw geometry that has - * been output since the last call to smClean(). (The last view drawn will + * been output since the last call to smClean().(The last view drawn will * be view==&odev.v each time.) */ smUpdate(view,qual) VIEW *view; int qual; { - double d; - int last_update; - int t; - - /* If view has moved beyond epsilon from canonical: must rebuild - - epsilon is calculated as running avg of distance of sample points - from canonical view: m = 1/(AVG(1/r)): some fraction of this - */ - d = DIST(view->vp,SM_VIEW_CENTER(smMesh)); - if(qual >= 100 && d > SM_ALLOWED_VIEW_CHANGE(smMesh)) + + /* Is there anything to render? */ + if(!smMesh || SM_NUM_TRI(smMesh)<=0) + return; + + /* Is viewer MOVING?*/ + if(qual < MAXQUALITY) { - /* Re-build the mesh */ -#ifdef TEST_DRIVER - odev.v = *view; -#endif - smRebuild_mesh(smMesh,view->vp); + if(smIncremental) + smUpdate_tm(smMesh); + + /* Render mesh using display lists */ + smRender(smMesh,view,qual); + return; } - /* This is our final update iff qual==100 and view==&odev.v */ - last_update = qual>=100 && view==&(odev.v); - /* Check if we should draw ALL triangles in current frustum */ - if(smClean_notify || smNew_tri_cnt > SM_NUM_TRIS(smMesh)*SM_INC_PERCENT) + /* Viewer is STATIONARY */ + /* Has view moved epsilon from canonical view? (epsilon= percentage + (SM_VIEW_FRAC) of running average of the distance of the sample points + from the canonical view */ + if(DIST(view->vp,SM_VIEW_CENTER(smMesh)) > SM_ALLOWED_VIEW_CHANGE(smMesh)) { -#ifdef TEST_DRIVER - glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); -#else - if (SM_TONE_MAP(smMesh) < SM_NUM_SAMP(smMesh)) + /* Must rebuild mesh with current view as new canonical view */ + smRebuild(smMesh,view); + /* Existing display lists and tonemapping are no longer valid */ + clear_display_lists(); + smCompute_mapping = FALSE; + smUpdate_tm(smMesh); + /* Render all the triangles in the new mesh */ + smRender(smMesh,view,qual+1); + } + else + /* Has a complete redraw been requested ?*/ + if(smClean_notify) { - tmClearHisto(); - tmAddHisto(SM_BRT(smMesh),SM_NUM_SAMP(smMesh),1); - if(tmComputeMapping(0.,0.,0.) != TM_E_OK || - tmMapPixels(SM_RGB(smMesh),SM_BRT(smMesh),SM_CHR(smMesh), - SM_NUM_SAMP(smMesh)) != TM_E_OK) - return; + if(smIncremental) + smUpdate_tm(smMesh); + smIncremental = FALSE; + smRender(smMesh,view,qual); } -#endif - mark_tris_in_frustum(view); - if (qual <= 75) - smRender_stree(smMesh,qual); else - smRender_mesh(smMesh,view->vp,last_update); -#ifdef TEST_DRIVER - glFlush(); - glutSwapBuffers(); -#endif - } - /* Do an incremental update instead */ - else - { - if(!smNew_tri_cnt) - return; -#ifdef TEST_DRIVER - glDrawBuffer(GL_FRONT); -#else - t = SM_TONE_MAP(smMesh); - if(t == 0) { - tmClearHisto(); - tmAddHisto(SM_BRT(smMesh),SM_NUM_SAMP(smMesh),1); - if(tmComputeMapping(0.,0.,0.) != TM_E_OK) - return; - } - if(tmMapPixels(SM_NTH_RGB(smMesh,t),&SM_NTH_BRT(smMesh,t), - SM_NTH_CHR(smMesh,t), SM_NUM_SAMP(smMesh)-t) != TM_E_OK) - return; -#endif - smUpdate_Rendered_mesh(smMesh,view->vp,last_update); - -#ifdef TEST_DRIVER - glDrawBuffer(GL_BACK); -#endif + smUpdate_tm(smMesh); + /* If number of new triangles relatively small: do incremental update */ + /* Mark Existing display lists in frustum invalid */ + if(!smIncremental) + { + smInvalidate_view(smMesh,view); + smIncremental = TRUE; + } + smRender_inc(smMesh,view->vp); } - SM_TONE_MAP(smMesh) = SM_NUM_SAMP(smMesh); - if (last_update) + /* This is our final update iff qual==MAXQUALITY and view==&odev.v */ + if( (qual >= MAXQUALITY) && (view == &(odev.v))) { + /* reset rendering flags */ smClean_notify = FALSE; - smNew_tri_cnt = 0; - smClear_flags(smMesh,T_NEW_FLAG); + if(smIncremental) + smClear_flags(smMesh,T_NEW_FLAG); qtCache_init(0); } } + + + + + + +
