--- ray/src/hd/sm_ogl.c 1999/03/05 16:33:32 3.14 +++ ray/src/hd/sm_ogl.c 2003/06/20 00:25:49 3.17 @@ -1,14 +1,28 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: sm_ogl.c,v 3.17 2003/06/20 00:25:49 greg Exp $"; #endif - /* * sm_ogl.c * * Rendering routines for triangle mesh representation utilizing OpenGL -*/ + * + * smClean(tmflag) : display has been wiped clean + * int tmflag; + * Called after display has been effectively cleared, meaning that all + * geometry must be resent down the pipeline in the next call to smUpdate(). + * If tmflag is set, tone-mapping should be performed + * + * smUpdate(vp, qua) : update OpenGL output geometry for view vp + * VIEW *vp; : desired view + * int qua; : quality level (percentage on linear time scale) + * + * Draw new geometric representation using OpenGL calls. Assume that the + * view has already been set up and the correct frame buffer has been + * selected for drawing. The quality level is on a linear scale, where 100% + * is full (final) quality. It is not necessary to redraw geometry that has + * been output since the last call to smClean(). (The last view drawn will + * be vp==&odev.v each time.) + */ #include "standard.h" #include @@ -16,24 +30,23 @@ static char SCCSid[] = "$SunId$ SGI"; #include "sm_flag.h" #include "sm_list.h" #include "sm_geom.h" -#include "sm_qtree.h" -#include "sm_stree.h" #include "sm.h" -static int smClean_notify = TRUE; /*If true:Do full redraw on next update*/ -static int smCompute_mapping = TRUE;/*If true:re-tonemap on next update */ -static int smIncremental = FALSE; /*If true: there has been incremental - rendering since last full draw */ +int smClean_notify = TRUE; /*If TRUE:Do full redraw on next update*/ +static int smCompute_mapping = TRUE; /*If TRUE:re-tonemap on next update */ +static int smIncremental = FALSE; /*If TRUE: there has been incremental + rendering since last full draw */ +#define NEW_TRI_CNT 1000 /* Default number of tris to allocate + space to sort for incremental update*/ #define SM_RENDER_FG 0 /* Render foreground tris only*/ #define SM_RENDER_BG 1 /* Render background tris only */ -#define SM_RENDER_MIXED 4 /* Render mixed tris only */ -#define SM_RENDER_CULL 8 /* Perform view frustum culling */ -#define BASE 1 -#define DIR 2 +#define SM_RENDER_CULL 8 /* Perform view frustum culling */ +#define BASE 1 /* Indicates base triangle */ +#define DIR 2 /* Indicates triangle w/directional pts*/ /* FOR DISPLAY LIST RENDERING: **********************************************/ -#define SM_DL_LEVELS 2 /* # of levels down to create display lists */ -#define SM_DL_LISTS 42 /* # of qtree nodes in tree at above level: - should be 2*(4^(SM_DL_LEVELS+1)-1)/(4-1) */ +#define SM_DL_LEVELS 2 /* # of levels down to create display lists */ +#define SM_DL_LISTS 42 /* # of qtree nodes in tree at above level: + should be 2*(4^(SM_DL_LEVELS+1)-1)/(4-1) */ static GLuint Display_lists[SM_DL_LISTS][2] = {0}; /****************************************************************************/ @@ -59,7 +72,6 @@ typedef struct _T_DEPTH { }T_DEPTH; /**********************************************************************/ - /* * smClean(tmflag) : display has been wiped clean * int tmflag; @@ -71,74 +83,73 @@ smClean(tmflag) int tmflag; { smClean_notify = TRUE; - if(tmflag) - smCompute_mapping = TRUE; + smCompute_mapping = tmflag; } int qtCache_init(nel) /* initialize for at least nel elements */ int nel; { - static int hsiztab[] = { - 8191, 16381, 32749, 65521, 131071, 262139, 524287, 1048573, 0 - }; - register int i; + static int hsiztab[] = { + 8191, 16381, 32749, 65521, 131071, 262139, 524287, 1048573, 0 + }; + register int i; - if (nel <= 0) { /* call to free table */ - if (qt_hsiz) { - free((char *)qt_htbl); - qt_htbl = NULL; - qt_hsiz = 0; - } - return(0); + if (nel <= 0) { /* call to free table */ + if (qt_hsiz) { + free((void *)qt_htbl); + qt_htbl = NULL; + qt_hsiz = 0; } - nel += nel>>1; /* 66% occupancy */ - for (i = 0; hsiztab[i]; i++) - if (hsiztab[i] > nel) - break; - if (!(qt_hsiz = hsiztab[i])) - qt_hsiz = nel*2 + 1; /* not always prime */ - qt_htbl = (QT_LUENT *)calloc(qt_hsiz, sizeof(QT_LUENT)); - if (qt_htbl == NULL) - qt_hsiz = 0; - for (i = qt_hsiz; i--; ) - qt_htbl[i].qt = EMPTY; - return(qt_hsiz); + return(0); + } + nel += nel>>1; /* 66% occupancy */ + for (i = 0; hsiztab[i]; i++) + if (hsiztab[i] > nel) + break; + if (!(qt_hsiz = hsiztab[i])) + qt_hsiz = nel*2 + 1; /* not always prime */ + qt_htbl = (QT_LUENT *)calloc(qt_hsiz, sizeof(QT_LUENT)); + if (qt_htbl == NULL) + qt_hsiz = 0; + for (i = qt_hsiz; i--; ) + qt_htbl[i].qt = EMPTY; + return(qt_hsiz); } QT_LUENT * qtCache_find(qt) /* find a quadtree table entry */ QUADTREE qt; { - int i, n; - register int ndx; - register QT_LUENT *le; + int i, n; + register int ndx; + register QT_LUENT *le; - if (qt_hsiz == 0 && !qtCache_init(1)) - return(NULL); + if (qt_hsiz == 0 && !qtCache_init(1)) + return(NULL); tryagain: /* hash table lookup */ - ndx = (unsigned long)qt % qt_hsiz; - for (i = 0, n = 1; i < qt_hsiz; i++, n += 2) { - le = &qt_htbl[ndx]; - if (QT_IS_EMPTY(le->qt) || le->qt == qt) - return(le); - if ((ndx += n) >= qt_hsiz) /* this happens rarely */ - ndx = ndx % qt_hsiz; - } - /* table is full, reallocate */ - le = qt_htbl; - ndx = qt_hsiz; - if (!qtCache_init(ndx+1)) { /* no more memory! */ - qt_htbl = le; - qt_hsiz = ndx; - return(NULL); - } + ndx = (unsigned long)qt % qt_hsiz; + for (i = 0, n = 1; i < qt_hsiz; i++, n += 2) { + le = &qt_htbl[ndx]; + if (QT_IS_EMPTY(le->qt) || le->qt == qt) + return(le); + if ((ndx += n) >= qt_hsiz) /* this happens rarely */ + ndx = ndx % qt_hsiz; + } + /* table is full, reallocate */ + le = qt_htbl; + ndx = qt_hsiz; + if (!qtCache_init(ndx+1)) { /* no more memory! */ + qt_htbl = le; + qt_hsiz = ndx; + return(NULL); + } /* copy old table to new and free */ - while (ndx--) - if (!QT_IS_EMPTY(le[ndx].qt)) - copystruct(qtCache_find(le[ndx].qt), &le[ndx]); - free((char *)le); - goto tryagain; /* should happen only once! */ + while (ndx--) + if (!QT_IS_EMPTY(le[ndx].qt)) + copystruct(qtCache_find(le[ndx].qt), &le[ndx]); + free((void *)le); + goto tryagain; /* should happen only once! */ } stCount_level_leaves(lcnt, qt) /* count quadtree leaf nodes at each level */ @@ -160,7 +171,6 @@ register QUADTREE qt; lcnt[0]++; } - QTRAVG * qtRender_level(qt,v0,v1,v2,sm,lvl) QUADTREE qt; @@ -209,36 +219,46 @@ int lvl; } else { /* from triangle set */ - OBJECT *os; - int s0, s1, s2; - + S_ID *os; + S_ID s0, s1, s2,s_id; + int t_id; + TRI *tri,*t; + os = qtqueryset(qt); for (i = os[0]; i; i--) { - if(SM_IS_NTH_T_BASE(sm,os[i])) - continue; - tri = SM_NTH_TRI(sm,os[i]); - if(!T_IS_VALID(tri)) - continue; - n++; - s0 = T_NTH_V(tri,0); - s1 = T_NTH_V(tri,1); - s2 = T_NTH_V(tri,2); - VCOPY(a,SM_NTH_WV(sm,s0)); - VCOPY(b,SM_NTH_WV(sm,s1)); - VCOPY(c,SM_NTH_WV(sm,s2)); - distsum += SM_BG_SAMPLE(sm,s0) ? dev_zmax + s_id = os[i]; + t_id = SM_NTH_VERT(smMesh,s_id); + tri = t = SM_NTH_TRI(smMesh,t_id); + do + { + if(!SM_IS_NTH_T_BASE(sm,t_id)) + { + n++; + s0 = T_NTH_V(t,0); + s1 = T_NTH_V(t,1); + s2 = T_NTH_V(t,2); + VCOPY(a,SM_NTH_WV(sm,s0)); + VCOPY(b,SM_NTH_WV(sm,s1)); + VCOPY(c,SM_NTH_WV(sm,s2)); + distsum += SM_BG_SAMPLE(sm,s0) ? dev_zmax : sqrt(dist2(a,SM_VIEW_CENTER(sm))); - distsum += SM_BG_SAMPLE(sm,s1) ? dev_zmax - : sqrt(dist2(b,SM_VIEW_CENTER(sm))); - distsum += SM_BG_SAMPLE(sm,s2) ? dev_zmax + distsum += SM_BG_SAMPLE(sm,s1) ? dev_zmax + : sqrt(dist2(b,SM_VIEW_CENTER(sm))); + distsum += SM_BG_SAMPLE(sm,s2) ? dev_zmax : sqrt(dist2(c,SM_VIEW_CENTER(sm))); - rgbs[0] += SM_NTH_RGB(sm,s0)[0] + SM_NTH_RGB(sm,s1)[0] - + SM_NTH_RGB(sm,s2)[0]; - rgbs[1] += SM_NTH_RGB(sm,s0)[1] + SM_NTH_RGB(sm,s1)[1] - + SM_NTH_RGB(sm,s2)[1]; - rgbs[2] += SM_NTH_RGB(sm,s0)[2] + SM_NTH_RGB(sm,s1)[2] - + SM_NTH_RGB(sm,s2)[2]; + rgbs[0] += SM_NTH_RGB(sm,s0)[0] + SM_NTH_RGB(sm,s1)[0] + + SM_NTH_RGB(sm,s2)[0]; + rgbs[1] += SM_NTH_RGB(sm,s0)[1] + SM_NTH_RGB(sm,s1)[1] + + SM_NTH_RGB(sm,s2)[1]; + rgbs[2] += SM_NTH_RGB(sm,s0)[2] + SM_NTH_RGB(sm,s1)[2] + + SM_NTH_RGB(sm,s2)[2]; + } + + t_id = smTri_next_ccw_nbr(smMesh,t,s_id); + t = SM_NTH_TRI(smMesh,t_id); + + }while(t != tri); } n *= 3; } @@ -275,7 +295,6 @@ int lvl; int i; FVECT t0,t1,t2; STREE *st; - if (lvl < 0) return; @@ -314,7 +333,7 @@ VIEW *view; int i, n,ntarget; int lvlcnt[QT_MAX_LEVELS]; STREE *st; - int4 *active_flag; + int32 *active_flag; if (qual <= 0) return; @@ -346,100 +365,60 @@ VIEW *view; smRender_approx_stree_level(sm,i); } -#define render_tri(v0,v1,v2,rgb0,rgb1,rgb2) \ - {glColor3ub(rgb0[0],rgb0[1],rgb0[2]); glVertex3fv(v0); \ - glColor3ub(rgb1[0],rgb1[1],rgb1[2]); glVertex3fv(v1); \ - glColor3ub(rgb2[0],rgb2[1],rgb2[2]); glVertex3fv(v2);} +#define GLVERTEX3V(v) glVertex3fv(v) -render_bg_tri(v0,v1,v2,rgb0,rgb1,rgb2,vp,vc,d) - float v0[3],v1[3],v2[3]; - BYTE rgb0[3],rgb1[3],rgb2[3]; - FVECT vp,vc; - double d; - { - double p[3]; - - glColor3ub(rgb0[0],rgb0[1],rgb0[2]); - VSUB(p,v0,vc); - if(dev_zmin >= 0.99) - { - p[0] *= d; - p[1] *= d; - p[2] *= d; - } - VADD(p,p,vp); - glVertex3dv(p); - - glColor3ub(rgb1[0],rgb1[1],rgb1[2]); - VSUB(p,v1,vc); - if(dev_zmin >= 0.99) - { - p[0] *= d; - p[1] *= d; - p[2] *= d; - } - VADD(p,p,vp); - glVertex3dv(p); - - - glColor3ub(rgb2[0],rgb2[1],rgb2[2]); - VSUB(p,v2,vc); - if(dev_zmin >= 0.99) - { - p[0] *= d; - p[1] *= d; - p[2] *= d; - VADD(p,p,vp); - glVertex3dv(p); - } - } +#define render_tri(v0,v1,v2,rgb0,rgb1,rgb2) \ + {glColor3ub(rgb0[0],rgb0[1],rgb0[2]); GLVERTEX3V(v0); \ + glColor3ub(rgb1[0],rgb1[1],rgb1[2]); GLVERTEX3V(v1); \ + glColor3ub(rgb2[0],rgb2[1],rgb2[2]); GLVERTEX3V(v2);} /* * render_mixed_tri(v0,v1,v2,rgb0,rgb1,rgb2,b0,b1,b2) - * float v0[3],v1[3],v2[3]; : triangle vertex coordinates + * SFLOAT v0[3],v1[3],v2[3]; : triangle vertex coordinates * BYTE rgb0[3],rgb1[3],rgb2[3]; : vertex RGBs * int b0,b1,b2; : background or base vertex flag * - * render foreground or base vertex color as average of the background - * vertex RGBs. + * For triangles with one or more base or directional vertices. + * render base vertex color as average of the background and foreground + * vertex RGBs. The coordinates for a fg vertex are calculated by + * subtracting off the current view,normalizing, then scaling to fit + * into the current frustum. */ render_mixed_tri(v0,v1,v2,rgb0,rgb1,rgb2,vp,vc,bg0,bg1,bg2) -float v0[3],v1[3],v2[3]; +SFLOAT v0[3],v1[3],v2[3]; BYTE rgb0[3],rgb1[3],rgb2[3]; FVECT vp,vc; int bg0,bg1,bg2; { double d,p[3]; - int j,cnt,rgb[3],base; + int j,cnt,rgb[3]; - base = bg0==BASE || bg1==BASE || bg2==BASE; - - if(base) + /* Average color from bg vertices */ + cnt = 0; + if(bg0 == BASE || bg1==BASE || bg2 == BASE) { - cnt = 0; rgb[0] = rgb[1] = rgb[2] = 0; if(bg0 != BASE) - { - IADDV3(rgb,rgb0); - cnt++; - } - if(bg1 !=BASE) - { - IADDV3(rgb,rgb1); - cnt++; - } + { + IADDV3(rgb,rgb0); + cnt++; + } + if(bg1 != BASE) + { + IADDV3(rgb,rgb1); + cnt++; + } if(bg2 != BASE) - { - IADDV3(rgb,rgb2); - cnt++; - } + { + IADDV3(rgb,rgb2); + cnt++; + } IDIVV3(rgb,cnt); } - - if(bg0== BASE) - glColor3ub(rgb[0],rgb[1],rgb[2]); + if(bg0 == BASE) + glColor3i(rgb[0],rgb[1],rgb[2]); else glColor3ub(rgb0[0],rgb0[1],rgb0[2]); @@ -451,10 +430,10 @@ int bg0,bg1,bg2; glVertex3dv(p); } else - glVertex3fv(v0); + GLVERTEX3V(v0); - if(bg1== BASE) - glColor3ub(rgb[0],rgb[1],rgb[2]); + if(bg1 == BASE) + glColor3i(rgb[0],rgb[1],rgb[2]); else glColor3ub(rgb1[0],rgb1[1],rgb1[2]); @@ -466,10 +445,10 @@ int bg0,bg1,bg2; glVertex3dv(p); } else - glVertex3fv(v1); + GLVERTEX3V(v1); - if(bg2== BASE) - glColor3ub(rgb[0],rgb[1],rgb[2]); + if(bg2 == BASE) + glColor3i(rgb[0],rgb[1],rgb[2]); else glColor3ub(rgb2[0],rgb2[1],rgb2[2]); @@ -481,26 +460,26 @@ int bg0,bg1,bg2; glVertex3dv(p); } else - glVertex3fv(v2); + GLVERTEX3V(v2); } /* * smRender_bg_tris(sm,vp,t_flag,bg_flag,wp,rgb) * SM *sm; : mesh * FVECT vp; : current viewpoint - * int4 *t_flag,*bg_flag; : triangle flags: t_flag is generic, + * int32 *t_flag,*bg_flag; : triangle flags: t_flag is generic, * and bg_flag indicates if background tri; - * float (*wp)[3];BYTE (*rgb)[3]; : arrays of sample points and RGB colors + * SFLOAT (*wp)[3];BYTE (*rgb)[3]; : arrays of sample points and RGB colors * - * Sequentially gos through triangle list and renders all valid tris who + * Sequentially traverses triangle list and renders all valid tris who * have t_flag set, and bg_flag set. */ smRender_bg_tris(sm,vp,t_flag,bg_flag,wp,rgb) SM *sm; FVECT vp; -int4 *t_flag,*bg_flag; -float (*wp)[3]; +int32 *t_flag,*bg_flag; +SFLOAT (*wp)[3]; BYTE (*rgb)[3]; { double d; @@ -542,7 +521,7 @@ BYTE (*rgb)[3]; rgb[v2_id]) else render_mixed_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id], - rgb[v1_id],rgb[v2_id],vp,SM_VIEW_CENTER(sm),bg0,bg1,bg2); + rgb[v1_id],rgb[v2_id],vp,SM_VIEW_CENTER(sm),bg0,bg1,bg2); } glEnd(); @@ -550,8 +529,73 @@ BYTE (*rgb)[3]; } /* + * smRender_new_bg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb) + * SM *sm; : mesh + * FVECT vp; : current viewpoint + * int32 *new_flag,*active,*bg_flag; : triangle flags: idicates if tri is, + * new,active,bg_flag + * SFLOAT (*wp)[3];BYTE (*rgb)[3]; : arrays of sample points and RGB colors + * + * Sequentially traverses triangle list and renders all valid tris who + * have new_flag set and active_flag and bg_flag set. + */ +smRender_new_bg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb) +SM *sm; +FVECT vp; +int32 *new_flag,*active_flag,*bg_flag; +SFLOAT (*wp)[3]; +BYTE (*rgb)[3]; +{ + double d; + int v0_id,v1_id,v2_id; + int i,n,bg0,bg1,bg2; + TRI *tri; + + glMatrixMode(GL_MODELVIEW); + + glPushMatrix(); + glTranslated(vp[0],vp[1],vp[2]); + /* The points are a distance of 1 away from the origin: if necessary scale + so that they fit in frustum and are therefore not clipped away + */ + if(dev_zmin >= 0.99) + { + d = (dev_zmin+dev_zmax)/2.0; + glScaled(d,d,d); + } + /* move relative to the new view */ + /* move points to unit sphere at origin */ + glTranslated(-SM_VIEW_CENTER(sm)[0],-SM_VIEW_CENTER(sm)[1], + -SM_VIEW_CENTER(sm)[2]); + glBegin(GL_TRIANGLES); + for(n=((SM_NUM_TRI(sm)+31)>>5) +1; --n;) + if(new_flag[n] & active_flag[n] & bg_flag[n]) + for(i=0; i < 32; i++) + if(new_flag[n] & active_flag[n] & bg_flag[n] & (1L << i)) + { + tri = SM_NTH_TRI(sm,(n<<5)+i); + v0_id = T_NTH_V(tri,0); + v1_id = T_NTH_V(tri,1); + v2_id = T_NTH_V(tri,2); + bg0 = SM_DIR_ID(sm,v0_id)?DIR:SM_BASE_ID(sm,v0_id)?BASE:0; + bg1 = SM_DIR_ID(sm,v1_id)?DIR:SM_BASE_ID(sm,v1_id)?BASE:0; + bg2 = SM_DIR_ID(sm,v2_id)?DIR:SM_BASE_ID(sm,v2_id)?BASE:0; + if(bg0==DIR && bg1==DIR && bg2==DIR) + render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id]) + else + render_mixed_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id], + rgb[v1_id],rgb[v2_id],vp,SM_VIEW_CENTER(sm),bg0,bg1,bg2); + } + glEnd(); + + glPopMatrix(); + +} + +/* * render_base_tri(v0,v1,v2,rgb0,rgb1,rgb2,vp,b0,b1,b2) - * float v0[3],v1[3],v2[3]; : triangle vertex coordinates + * SFLOAT v0[3],v1[3],v2[3]; : triangle vertex coordinates * BYTE rgb0[3],rgb1[3],rgb2[3]; : vertex RGBs * FVECT vp; : current viewpoint * int b0,b1,b2; : vertex base flag @@ -561,7 +605,7 @@ BYTE (*rgb)[3]; * the average distance to the non-base vertices */ render_base_tri(v0,v1,v2,rgb0,rgb1,rgb2,vp,b0,b1,b2) -float v0[3],v1[3],v2[3]; +SFLOAT v0[3],v1[3],v2[3]; BYTE rgb0[3],rgb1[3],rgb2[3]; FVECT vp; int b0,b1,b2; @@ -574,7 +618,7 @@ int b0,b1,b2; cnt = 0; rgb[0] = rgb[1] = rgb[2] = 0; d = 0.0; - + /* If all vertices are base: don't render */ if(b0&&b1&&b2) return; /* First calculate color and coordinates @@ -612,7 +656,7 @@ int b0,b1,b2; else { glColor3ub(rgb0[0],rgb0[1],rgb0[2]); - glVertex3fv(v0); + GLVERTEX3V(v0); } if(b1) { @@ -625,7 +669,7 @@ int b0,b1,b2; else { glColor3ub(rgb1[0],rgb1[1],rgb1[2]); - glVertex3fv(v1); + GLVERTEX3V(v1); } if(b2) { @@ -638,16 +682,16 @@ int b0,b1,b2; else { glColor3ub(rgb2[0],rgb2[1],rgb2[2]); - glVertex3fv(v2); + GLVERTEX3V(v2); } } /* * smRender_fg_tris(sm,vp,t_flag,bg_flag,wp,rgb) * SM *sm; : mesh * FVECT vp; : current viewpoint - * int4 *t_flag,*bg_flag; : triangle flags: t_flag is generic,bg_flag + * int32 *t_flag,*bg_flag; : triangle flags: t_flag is generic,bg_flag * indicates if background tri; - * float (*wp)[3];BYTE (*rgb)[3]; : arrays of sample points and RGB colors + * SFLOAT (*wp)[3];BYTE (*rgb)[3]; : arrays of sample points and RGB colors * * Sequentially gos through triangle list and renders all valid tris who * have t_flag set, and NOT bg_flag set. @@ -655,13 +699,13 @@ int b0,b1,b2; smRender_fg_tris(sm,vp,t_flag,bg_flag,wp,rgb) SM *sm; FVECT vp; -int4 *t_flag,*bg_flag; -float (*wp)[3]; +int32 *t_flag,*bg_flag; +SFLOAT (*wp)[3]; BYTE (*rgb)[3]; { TRI *tri; int i,n,b0,b1,b2; - int v0_id,v1_id,v2_id; + S_ID v0_id,v1_id,v2_id; glBegin(GL_TRIANGLES); for(n=((SM_NUM_TRI(sm)+31)>>5) +1; --n;) @@ -682,12 +726,59 @@ BYTE (*rgb)[3]; else render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], rgb[v2_id]) + } glEnd(); } +/* + * smRender_new_fg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb) + * SM *sm; : mesh + * FVECT vp; : current viewpoint + * int32 *new_flag,*active_flag,*bg_flag; : triangle flags: indicate if + * tri is new,active,background + * SFLOAT (*wp)[3];BYTE (*rgb)[3]; : arrays of sample points and RGB colors + * + * Sequentially gos through triangle list and renders all valid tris who + * have new_flag and active_flag set, and NOT bg_flag set. + */ +smRender_new_fg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb) +SM *sm; +FVECT vp; +int32 *new_flag,*active_flag,*bg_flag; +SFLOAT (*wp)[3]; +BYTE (*rgb)[3]; +{ + TRI *tri; + int i,n,b0,b1,b2; + S_ID v0_id,v1_id,v2_id; + + glBegin(GL_TRIANGLES); + for(n=((SM_NUM_TRI(sm)+31)>>5) +1; --n;) + if(new_flag[n] & active_flag[n]) + for(i=0; i < 32; i++) + if(new_flag[n] & active_flag[n] & (1L << i) & ~bg_flag[n]) + { + tri = SM_NTH_TRI(sm,(n<<5)+i); + v0_id = T_NTH_V(tri,0); + v1_id = T_NTH_V(tri,1); + v2_id = T_NTH_V(tri,2); + b0 = SM_BASE_ID(sm,v0_id); + b1 = SM_BASE_ID(sm,v1_id); + b2 = SM_BASE_ID(sm,v2_id); + if(b0 || b1 || b2) + render_base_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id], + rgb[v1_id],rgb[v2_id],SM_VIEW_CENTER(sm),b0,b1,b2); + else + render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id]) + } + glEnd(); +} + +/* Test for qsort to depth sort triangles */ int compare_tri_depths(T_DEPTH *td1,T_DEPTH *td2) { @@ -699,48 +790,9 @@ compare_tri_depths(T_DEPTH *td1,T_DEPTH *td2) if(d < 0.0) return(-1); return(0); - } -#ifdef DEBUG -#define freebuf(b) tempbuf(-1) -#endif -char * -tempbuf(len) /* get a temporary buffer */ -unsigned len; -{ - extern char *malloc(), *realloc(); - static char *tempbuf = NULL; - static unsigned tempbuflen = 0; - -#ifdef DEBUG - static int in_use=FALSE; - - if(len == -1) - { - in_use = FALSE; - return(NULL); - } - if(in_use) - { - eputs("Buffer in use:cannot allocate:tempbuf()\n"); - return(NULL); - } -#endif - if (len > tempbuflen) { - if (tempbuflen > 0) - tempbuf = realloc(tempbuf, len); - else - tempbuf = malloc(len); - tempbuflen = tempbuf==NULL ? 0 : len; - } -#ifdef DEBUG - in_use = TRUE; -#endif - return(tempbuf); -} - /* * smOrder_new_tris(sm,vp,td) * SM *sm; : mesh @@ -750,26 +802,36 @@ unsigned len; * Creates list of all new tris, with their distance from the current * viewpoint, and sorts the list based on this distance */ -smOrder_new_tris(sm,vp,td) +T_DEPTH +*smOrder_new_tris(sm,vp) SM *sm; FVECT vp; -T_DEPTH *td; { - int n,i,j,tcnt,v; + T_DEPTH *td; + int n,i,j,tcnt,v,size; TRI *tri; double d,min_d; FVECT diff; - int4 *new_flag,*bg_flag; + int32 *new_flag,*bg_flag,*active_flag; + + td = (T_DEPTH *)tempbuf(NEW_TRI_CNT*sizeof(T_DEPTH),FALSE); + size = NEW_TRI_CNT; tcnt=0; new_flag = SM_NTH_FLAGS(sm,T_NEW_FLAG); bg_flag = SM_NTH_FLAGS(sm,T_BG_FLAG); + active_flag = SM_NTH_FLAGS(sm,T_ACTIVE_FLAG); for(n=((SM_NUM_TRI(sm)+31)>>5) +1; --n;) - if(new_flag[n] & ~bg_flag[n]) + if(active_flag[n] & new_flag[n] & ~bg_flag[n]) for(i=0; i < 32; i++) - if(new_flag[n] & (1L << i) & ~bg_flag[n]) + if(active_flag[n] & new_flag[n] & (1L << i) & ~bg_flag[n]) { tri = SM_NTH_TRI(sm,(n<<5)+i); + if(tcnt+1 >= size) + { + size += 100; + td = (T_DEPTH *)tempbuf(size*sizeof(T_DEPTH),TRUE); + } td[tcnt].tri = (n << 5)+i; min_d = -1; for(j=0;j < 3;j++) @@ -785,6 +847,7 @@ T_DEPTH *td; td[tcnt].tri = -1; if(tcnt) qsort((void *)td,tcnt,sizeof(T_DEPTH),compare_tri_depths); + return(td); } /* @@ -826,41 +889,35 @@ smRender_inc(sm,vp) SM *sm; FVECT vp; { - int i,n,v0_id,v1_id,v2_id,b0,b1,b2; + S_ID v0_id,v1_id,v2_id; + int i,n,b0,b1,b2; TRI *tri; - float (*wp)[3]; + SFLOAT (*wp)[3]; BYTE (*rgb)[3]; - int4 *new_flag,*bg_flag; + int32 *new_flag,*bg_flag,*active_flag; T_DEPTH *td = NULL; - smUpdate_tm(sm); - /* For all of the NEW triangles (since last update): assume - ACTIVE. Go through and sort on depth value (from vp). Turn + /* For all of the NEW and ACTIVE triangles (since last update): + Go through and sort on depth value (from vp). Turn Depth Buffer test off and render back-front - */ + */ + + /* Must depth sort if current view point is not same as canonical */ if(!EQUAL_VEC3(SM_VIEW_CENTER(sm),vp)) - { - /* Must depth sort if view points do not coincide */ - td = (T_DEPTH *)tempbuf(smNew_tri_cnt*sizeof(T_DEPTH)); - if(td) - smOrder_new_tris(sm,vp,td); -#ifdef DEBUG - else - eputs("Cant create list:wont depth sort:smUpdate_incremental\n"); -#endif - } + td = smOrder_new_tris(sm,vp); wp = SM_WP(sm); rgb =SM_RGB(sm); new_flag = SM_NTH_FLAGS(sm,T_NEW_FLAG); + active_flag = SM_NTH_FLAGS(sm,T_ACTIVE_FLAG); bg_flag = SM_NTH_FLAGS(sm,T_BG_FLAG); /* Turn Depth Test off -- using Painter's algorithm */ glPushAttrib(GL_DEPTH_BUFFER_BIT); glDepthFunc(GL_ALWAYS); - smRender_bg_tris(sm,vp,new_flag,bg_flag,wp,rgb); + smRender_new_bg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb); if(!td) - smRender_fg_tris(sm,vp,new_flag,bg_flag,wp,rgb); + smRender_new_fg_tris(sm,vp,new_flag,active_flag,bg_flag,wp,rgb); else { glBegin(GL_TRIANGLES); @@ -895,10 +952,10 @@ FVECT vp; * SM *sm; : mesh * QUADTREE qt; : quadtree base node * FVECT vp; : current viewpoint - * float (*wp)[3]; : array of sample points + * SFLOAT (*wp)[3]; : array of sample points * BYTE (*rgb)[3]; : array of RGB values for samples * int i,level_i,level,max_level,leaf_cnt; - * : variables to keep track of where + * : variables to keep track of where * we are in the quadtree traversal in order to map nodes to * corresponding array locations, where nodes are stored in breadth- * first order. i is the index of the current node,level_i is the @@ -917,7 +974,7 @@ smRender_qtree_dl(sm,qt,vp,wp,rgb,i,level_i,level,max_ SM *sm; QUADTREE qt; FVECT vp; -float (*wp)[3]; +SFLOAT (*wp)[3]; BYTE (*rgb)[3]; int i,level_i,level,max_level,leaf_cnt; int which; @@ -971,7 +1028,7 @@ int which; * SM *sm; : mesh * QUADTREE qt; : quadtree base node * FVECT vp; : current viewpoint - * float (*wp)[3] : array of sample points + * SFLOAT (*wp)[3] : array of sample points * BYTE (*rgb)[3] : array of RGB values for samples * int which; : flag indicates whether to render fg or bg tris * int cull; : if true, only traverse active (flagged) nodes @@ -981,7 +1038,7 @@ smRender_qtree(sm,qt,vp,wp,rgb,which,cull) SM *sm; QUADTREE qt; FVECT vp; -float (*wp)[3]; +SFLOAT (*wp)[3]; BYTE (*rgb)[3]; int which,cull; { @@ -992,55 +1049,60 @@ int which,cull; if(QT_IS_LEAF(qt)) { - TRI *t; - OBJECT *optr; - int t_id,v0_id,v1_id,v2_id,bg0,bg1,bg2; + TRI *t,*tri; + S_ID *optr,s_id,v0_id,v1_id,v2_id; + int bg0,bg1,bg2,t_id; if(cull && !QT_LEAF_IS_FLAG(qt)) return; optr = qtqueryset(qt); - for (i = QT_SET_CNT(optr),optr = QT_SET_PTR(optr);i > 0; i--) + for (i = QT_SET_CNT(optr);i > 0; i--) { - t_id = QT_SET_NEXT_ELEM(optr); - t = SM_NTH_TRI(sm,t_id); - if(!T_IS_VALID(t) || (cull &&!SM_IS_NTH_T_ACTIVE(sm,t_id)) || - SM_IS_NTH_T_NEW(sm,t_id)) - continue; - - bg0 = SM_IS_NTH_T_BG(sm,t_id); - if((which== SM_RENDER_FG && bg0) || (which== SM_RENDER_BG && !bg0)) - continue; - - v0_id = T_NTH_V(t,0); - v1_id = T_NTH_V(t,1); - v2_id = T_NTH_V(t,2); - if(bg0) + s_id = QT_SET_NEXT_ELEM(optr); + t_id = SM_NTH_VERT(smMesh,s_id); + tri = t = SM_NTH_TRI(smMesh,t_id); + do { - bg0 = SM_DIR_ID(sm,v0_id)?DIR:SM_BASE_ID(sm,v0_id)?BASE:0; - bg1 = SM_DIR_ID(sm,v1_id)?DIR:SM_BASE_ID(sm,v1_id)?BASE:0; - bg2 = SM_DIR_ID(sm,v2_id)?DIR:SM_BASE_ID(sm,v2_id)?BASE:0; - SM_SET_NTH_T_NEW(sm,t_id); - if(bg0==DIR && bg1==DIR && bg2==DIR) - render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], - rgb[v2_id]) - else - render_mixed_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id], - rgb[v1_id],rgb[v2_id],vp,SM_VIEW_CENTER(sm),bg0,bg1,bg2); - } - else - { - SM_SET_NTH_T_NEW(sm,t_id); - bg0 = SM_BASE_ID(sm,v0_id); - bg1 = SM_BASE_ID(sm,v1_id); - bg2 = SM_BASE_ID(sm,v2_id); - if(bg0 || bg1 || bg2) - render_base_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id], - rgb[v1_id],rgb[v2_id],SM_VIEW_CENTER(sm),bg0,bg1,bg2); - else - render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], - rgb[v2_id]) - } + if((!cull || SM_IS_NTH_T_ACTIVE(sm,t_id)) && !SM_IS_NTH_T_NEW(sm,t_id)) + { + bg0 = SM_IS_NTH_T_BG(sm,t_id); + if((which == SM_RENDER_FG && !bg0) || (which== SM_RENDER_BG && bg0)) + { + v0_id = T_NTH_V(t,0); + v1_id = T_NTH_V(t,1); + v2_id = T_NTH_V(t,2); + if(bg0) + { + bg0 = SM_DIR_ID(sm,v0_id)?DIR:SM_BASE_ID(sm,v0_id)?BASE:0; + bg1 = SM_DIR_ID(sm,v1_id)?DIR:SM_BASE_ID(sm,v1_id)?BASE:0; + bg2 = SM_DIR_ID(sm,v2_id)?DIR:SM_BASE_ID(sm,v2_id)?BASE:0; + SM_SET_NTH_T_NEW(sm,t_id); + if(bg0==DIR && bg1==DIR && bg2==DIR) + render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id]) + else + render_mixed_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id], + rgb[v1_id],rgb[v2_id],vp,SM_VIEW_CENTER(sm),bg0,bg1,bg2); + } + else + { + SM_SET_NTH_T_NEW(sm,t_id); + bg0 = SM_BASE_ID(sm,v0_id); + bg1 = SM_BASE_ID(sm,v1_id); + bg2 = SM_BASE_ID(sm,v2_id); + if(bg0 || bg1 || bg2) + render_base_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id], + rgb[v1_id],rgb[v2_id],SM_VIEW_CENTER(sm),bg0,bg1,bg2); + else + render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id]) + } + } + } + t_id = smTri_next_ccw_nbr(smMesh,t,s_id); + t = SM_NTH_TRI(smMesh,t_id); + }while(t!=tri); } } else @@ -1049,6 +1111,7 @@ int which,cull; smRender_qtree(sm,QT_NTH_CHILD(qt,i),vp,wp,rgb,which,cull); } + /* * smRender_mesh(sm,view,cull) : Render mesh Triangles * SM *sm; : mesh @@ -1065,13 +1128,11 @@ SM *sm; VIEW *view; int cull; { - float (*wp)[3]; + SFLOAT (*wp)[3]; BYTE (*rgb)[3]; int i; STREE *st= SM_LOCATOR(sm); - smUpdate_tm(sm); - wp = SM_WP(sm); rgb =SM_RGB(sm); @@ -1080,7 +1141,6 @@ int cull; if(cull) smCull(sm,view,SM_ALL_LEVELS); - glPushAttrib(GL_DEPTH_BUFFER_BIT); glDisable(GL_DEPTH_TEST); @@ -1089,7 +1149,6 @@ int cull; /* move relative to the new view */ glTranslated(view->vp[0],view->vp[1],view->vp[2]); - /* The points are a distance of 1 away from the origin: if necessary scale so that they fit in frustum and are therefore not clipped away */ @@ -1130,7 +1189,7 @@ smRender_mesh_dl(sm,view) SM *sm; VIEW *view; { - float (*wp)[3]; + SFLOAT (*wp)[3]; BYTE (*rgb)[3]; STREE *st; int i; @@ -1149,6 +1208,8 @@ VIEW *view; return; } + smClear_flags(sm,T_NEW_FLAG); + smCull(sm,view,SM_DL_LEVELS); st = SM_LOCATOR(sm); @@ -1207,12 +1268,12 @@ SM *sm; VIEW *view; int render_flag; { - int4 *active_flag,*bg_flag; - float (*wp)[3]; + int32 *active_flag,*bg_flag; + SFLOAT (*wp)[3]; BYTE (*rgb)[3]; wp = SM_WP(sm); - rgb =SM_RGB(sm); + rgb = SM_RGB(sm); active_flag = SM_NTH_FLAGS(sm,T_ACTIVE_FLAG); bg_flag = SM_NTH_FLAGS(sm,T_BG_FLAG); @@ -1366,25 +1427,24 @@ SM *sm; VIEW *view; int qual; { - - /* Recompute tone mapping if specified */ - if( qual >= MAXQUALITY && smCompute_mapping) - smUpdate_tm(sm); - /* Unless quality > MAXQUALITY, render using display lists */ if(qual <= MAXQUALITY) { /* If quality above threshold: render mesh*/ - if(qual > (MAXQUALITY*2/4)) + if(qual > (MAXQUALITY*2/4) ) /* render stree using display lists */ smRender_mesh_dl(sm,view); else + { /* If quality below threshold, use approximate rendering */ smRender_approx(sm,qual,view); + } } else - /* render stree without display lists */ + { + /* render stree without display lists */ smRender_mesh(sm,view,TRUE); + } } @@ -1404,30 +1464,33 @@ smUpdate(view,qual) VIEW *view; int qual; { + /* Is there anything to render? */ if(!smMesh || SM_NUM_TRI(smMesh)<=0) return; - + /* Is viewer MOVING?*/ if(qual < MAXQUALITY) { + if(smIncremental) + smUpdate_tm(smMesh); + /* Render mesh using display lists */ smRender(smMesh,view,qual); return; } - /* Viewer is STATIONARY */ - /* Has view moved epsilon from canonical view? (epsilon= percentage (SM_VIEW_FRAC) of running average of the distance of the sample points from the canonical view */ if(DIST(view->vp,SM_VIEW_CENTER(smMesh)) > SM_ALLOWED_VIEW_CHANGE(smMesh)) { /* Must rebuild mesh with current view as new canonical view */ - smRebuild_mesh(smMesh,view); + smRebuild(smMesh,view); /* Existing display lists and tonemapping are no longer valid */ clear_display_lists(); - smCompute_mapping = TRUE; + smCompute_mapping = FALSE; + smUpdate_tm(smMesh); /* Render all the triangles in the new mesh */ smRender(smMesh,view,qual+1); } @@ -1435,38 +1498,38 @@ smUpdate(view,qual) /* Has a complete redraw been requested ?*/ if(smClean_notify) { + if(smIncremental) + smUpdate_tm(smMesh); smIncremental = FALSE; smRender(smMesh,view,qual); } else { - /* Viewer fixed and receiving new samples for the same view */ - if(!smNew_tri_cnt) - return; - + smUpdate_tm(smMesh); /* If number of new triangles relatively small: do incremental update */ - if(smNew_tri_cnt < SM_SAMPLE_TRIS(smMesh)*SM_INC_PERCENT) - { - /* Mark Existing display lists in frustum invalid */ - if(!smIncremental) - { - smInvalidate_view(smMesh,view); - smIncremental = TRUE; - } - smRender_inc(smMesh,view->vp); - } - else - /* Otherwise render all of the active triangles */ - smRender(smMesh,view,qual+1); + /* Mark Existing display lists in frustum invalid */ + if(!smIncremental) + { + smInvalidate_view(smMesh,view); + smIncremental = TRUE; + } + smRender_inc(smMesh,view->vp); } /* This is our final update iff qual==MAXQUALITY and view==&odev.v */ if( (qual >= MAXQUALITY) && (view == &(odev.v))) { /* reset rendering flags */ smClean_notify = FALSE; - smNew_tri_cnt = 0; - smClear_flags(smMesh,T_NEW_FLAG); + if(smIncremental) + smClear_flags(smMesh,T_NEW_FLAG); qtCache_init(0); } } + + + + + + +
