--- ray/src/hd/sm_ogl.c 1998/12/28 18:07:35 3.10 +++ ray/src/hd/sm_ogl.c 1999/01/05 16:52:38 3.12 @@ -168,10 +168,10 @@ int lvl; if (QT_IS_TREE(qt) && (QT_IS_EMPTY(le->qt) || lvl > 0)) { /* compute children */ qtSubdivide_tri(v0,v1,v2,a,b,c); - rc[0] = qtRender_level(QT_NTH_CHILD(qt,0),v0,a,c,sm,lvl-1); - rc[1] = qtRender_level(QT_NTH_CHILD(qt,1),a,v1,b,sm,lvl-1); - rc[2] = qtRender_level(QT_NTH_CHILD(qt,2),c,b,v2,sm,lvl-1); - rc[3] = qtRender_level(QT_NTH_CHILD(qt,3),b,c,a,sm,lvl-1); + rc[0] = qtRender_level(QT_NTH_CHILD(qt,0),v0,c,b,sm,lvl-1); + rc[1] = qtRender_level(QT_NTH_CHILD(qt,1),c,v1,a,sm,lvl-1); + rc[2] = qtRender_level(QT_NTH_CHILD(qt,2),b,a,v2,sm,lvl-1); + rc[3] = qtRender_level(QT_NTH_CHILD(qt,3),a,b,c,sm,lvl-1); } if (QT_IS_EMPTY(le->qt)) { /* let's make some data! */ @@ -194,16 +194,16 @@ int lvl; { /* from triangle set */ OBJECT *os; int s0, s1, s2; - + os = qtqueryset(qt); - for (n = os[0]; n; n--) + for (i = os[0]; i; i--) { - if(SM_IS_NTH_T_BASE(sm,os[n])) + if(SM_IS_NTH_T_BASE(sm,os[i])) continue; - tri = SM_NTH_TRI(sm,os[n]); + tri = SM_NTH_TRI(sm,os[i]); if(!T_IS_VALID(tri)) continue; - + n++; s0 = T_NTH_V(tri,0); s1 = T_NTH_V(tri,1); s2 = T_NTH_V(tri,2); @@ -223,7 +223,7 @@ int lvl; rgbs[2] += SM_NTH_RGB(sm,s0)[2] + SM_NTH_RGB(sm,s1)[2] + SM_NTH_RGB(sm,s2)[2]; } - n = 3*os[0]; + n *= 3; } if (!n) return(NULL); @@ -260,7 +260,7 @@ int lvl; STREE *st; - if (lvl < 1) + if (lvl < 0) return; st = SM_LOCATOR(sm); glPushAttrib(GL_LIGHTING_BIT); @@ -270,7 +270,7 @@ int lvl; { qt = ST_ROOT_QT(st,i); qtRender_level(qt,ST_NTH_V(st,i,0),ST_NTH_V(st,i,1),ST_NTH_V(st,i,2), - sm,lvl-1); + sm,lvl); } glEnd(); glPopAttrib(); @@ -309,122 +309,151 @@ int qual; } -smRender_tri(sm,i,vp,clr) -SM *sm; -int i; -FVECT vp; -int clr; -{ - TRI *tri; - double ptr[3]; - int j; - tri = SM_NTH_TRI(sm,i); - if (clr) SM_CLR_NTH_T_NEW(sm,i); - for(j=0; j <= 2; j++) - { -#ifdef DEBUG - if(SM_BG_SAMPLE(sm,T_NTH_V(tri,j))) - eputs("SmRenderTri(): shouldnt have bg samples\n"); -#endif - glColor3ub(SM_NTH_RGB(sm,T_NTH_V(tri,j))[0], - SM_NTH_RGB(sm,T_NTH_V(tri,j))[1], - SM_NTH_RGB(sm,T_NTH_V(tri,j))[2]); - VCOPY(ptr,SM_T_NTH_WV(sm,tri,j)); - glVertex3d(ptr[0],ptr[1],ptr[2]); - } -} +#define render_tri(v0,v1,v2,rgb0,rgb1,rgb2) \ + {glColor3ub(rgb0[0],rgb0[1],rgb0[2]); glVertex3fv(v0); \ + glColor3ub(rgb1[0],rgb1[1],rgb1[2]); glVertex3fv(v1); \ + glColor3ub(rgb2[0],rgb2[1],rgb2[2]); glVertex3fv(v2);} \ -smRender_mixed_tri(sm,i,vp,clr) -SM *sm; -int i; -FVECT vp; -int clr; +render_mixed_tri(v0,v1,v2,rgb0,rgb1,rgb2,bg0,bg1,bg2,vp,vc) +float v0[3],v1[3],v2[3]; +BYTE rgb0[3],rgb1[3],rgb2[3]; +int bg0,bg1,bg2; +FVECT vp,vc; { - TRI *tri; double p[3],d; int j,ids[3],cnt; int rgb[3]; - tri = SM_NTH_TRI(sm,i); - if (clr) SM_CLR_NTH_T_NEW(sm,i); - /* NOTE:Triangles are defined clockwise:historical relative to spherical tris: could change */ cnt = 0; d = 0.0; rgb[0] = rgb[1] = rgb[2] = 0; - for(j=0;j < 3;j++) + + if(bg0 && bg1 && bg2) + return; + + if(!bg0) { - ids[j] = T_NTH_V(tri,j); - if(!SM_BG_SAMPLE(sm,ids[j])) - { - rgb[0] += SM_NTH_RGB(sm,ids[j])[0]; - rgb[1] += SM_NTH_RGB(sm,ids[j])[1]; - rgb[2] += SM_NTH_RGB(sm,ids[j])[2]; - cnt++; - d += DIST(vp,SM_NTH_WV(sm,ids[j])); - } + rgb[0] += rgb0[0]; + rgb[1] += rgb0[1]; + rgb[2] += rgb0[2]; + cnt++; + d += DIST(vp,v0); } + if(!bg1) + { + rgb[0] += rgb1[0]; + rgb[1] += rgb1[1]; + rgb[2] += rgb1[2]; + cnt++; + d += DIST(vp,v1); + } + if(!bg2) + { + rgb[0] += rgb2[0]; + rgb[1] += rgb2[1]; + rgb[2] += rgb2[2]; + cnt++; + d += DIST(vp,v2); + } if(cnt > 1) { rgb[0]/=cnt; rgb[1]/=cnt; rgb[2]/=cnt; d /= (double)cnt; } - for(j=0; j <= 2; j++) + if(bg0) { - if(SM_BG_SAMPLE(sm,ids[j])) - { - glColor3ub(rgb[0],rgb[1],rgb[2]); - VSUB(p,SM_NTH_WV(sm,ids[j]),SM_VIEW_CENTER(sm)); - p[0] *= d; - p[1] *= d; - p[2] *= d; - VADD(p,p,SM_VIEW_CENTER(sm)); - } - else - { - glColor3ub(SM_NTH_RGB(sm,ids[j])[0],SM_NTH_RGB(sm,ids[j])[1], - SM_NTH_RGB(sm,ids[j])[2]); - VCOPY(p,SM_NTH_WV(sm,ids[j])); - } - glVertex3d(p[0],p[1],p[2]); + glColor3ub(rgb[0],rgb[1],rgb[2]); + VSUB(p,v0,vc); + p[0] *= d; + p[1] *= d; + p[2] *= d; + VADD(p,p,vc); + glVertex3dv(p); + } + else + { + glColor3ub(rgb0[0],rgb0[1],rgb0[2]); + glVertex3fv(v0); } + if(bg1) + { + glColor3ub(rgb[0],rgb[1],rgb[2]); + VSUB(p,v1,vc); + p[0] *= d; + p[1] *= d; + p[2] *= d; + VADD(p,p,vc); + glVertex3dv(p); + } + else + { + glColor3ub(rgb1[0],rgb1[1],rgb1[2]); + glVertex3fv(v1); + } + if(bg2) + { + glColor3ub(rgb[0],rgb[1],rgb[2]); + VSUB(p,v2,vc); + p[0] *= d; + p[1] *= d; + p[2] *= d; + VADD(p,p,vc); + glVertex3dv(p); + } + else + { + glColor3ub(rgb2[0],rgb2[1],rgb2[2]); + glVertex3fv(v2); + } + } -smRender_bg_tri(sm,i,vp,d,clr) -SM *sm; -int i; -FVECT vp; +render_bg_tri(v0,v1,v2,rgb0,rgb1,rgb2,vp,vc,d) +float v0[3],v1[3],v2[3]; +BYTE rgb0[3],rgb1[3],rgb2[3]; +FVECT vp,vc; double d; -int clr; { double p[3]; - int j,id; - TRI *tri; - tri = SM_NTH_TRI(sm,i); - if (clr) SM_CLR_NTH_T_NEW(sm,i); + glColor3ub(rgb0[0],rgb0[1],rgb0[2]); + VSUB(p,v0,vc); + if(dev_zmin >= 0.99) + { + p[0] *= d; + p[1] *= d; + p[2] *= d; + } + VADD(p,p,vp); + glVertex3dv(p); - /* NOTE:Triangles are defined clockwise:historical relative to spherical - tris: could change - */ - for(j=0; j <= 2; j++) + glColor3ub(rgb1[0],rgb1[1],rgb1[2]); + VSUB(p,v1,vc); + if(dev_zmin >= 0.99) { - id = T_NTH_V(tri,j); - glColor3ub(SM_NTH_RGB(sm,id)[0],SM_NTH_RGB(sm,id)[1], - SM_NTH_RGB(sm,id)[2]); - VSUB(p,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm)); - if(dev_zmin >= 0.99) - { - p[0] *= d; - p[1] *= d; - p[2] *= d; - } - VADD(p,p,vp); - glVertex3d(p[0],p[1],p[2]); + p[0] *= d; + p[1] *= d; + p[2] *= d; } + VADD(p,p,vp); + glVertex3dv(p); + + + glColor3ub(rgb2[0],rgb2[1],rgb2[2]); + VSUB(p,v2,vc); + if(dev_zmin >= 0.99) + { + p[0] *= d; + p[1] *= d; + p[2] *= d; + } + VADD(p,p,vp); + glVertex3dv(p); + } smRender_mesh(sm,vp,clr) @@ -432,56 +461,86 @@ SM *sm; FVECT vp; int clr; { - int i; + int i,bg0,bg1,bg2; + double d; + int v0_id,v1_id,v2_id; TRI *tri; - double ptr[3],d; - int j; + float (*wp)[3]; + BYTE (*rgb)[3]; + wp = SM_WP(sm); + rgb =SM_RGB(sm); d = (dev_zmin+dev_zmax)/2.0; glPushAttrib(GL_DEPTH_BUFFER_BIT); /* First draw background polygons */ glDisable(GL_DEPTH_TEST); glBegin(GL_TRIANGLES); + /* Maintain a list? */ SM_FOR_ALL_ACTIVE_BG_TRIS(sm,i) - smRender_bg_tri(sm,i,vp,d,clr); + { + if (clr) + SM_CLR_NTH_T_NEW(sm,i); + tri = SM_NTH_TRI(sm,i); + v0_id = T_NTH_V(tri,0); + v1_id = T_NTH_V(tri,1); + v2_id = T_NTH_V(tri,2); + render_bg_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id],vp,SM_VIEW_CENTER(sm),d); + } glEnd(); glEnable(GL_DEPTH_TEST); glBegin(GL_TRIANGLES); SM_FOR_ALL_ACTIVE_FG_TRIS(sm,i) { - if(!SM_MIXED_TRI(sm,i)) - smRender_tri(sm,i,vp,clr); + if (clr) + SM_CLR_NTH_T_NEW(sm,i); + tri = SM_NTH_TRI(sm,i); + v0_id = T_NTH_V(tri,0); + v1_id = T_NTH_V(tri,1); + v2_id = T_NTH_V(tri,2); + bg0 = SM_DIR_ID(sm,v0_id) || SM_BASE_ID(sm,v0_id); + bg1 = SM_DIR_ID(sm,v1_id) || SM_BASE_ID(sm,v1_id); + bg2 = SM_DIR_ID(sm,v2_id) || SM_BASE_ID(sm,v2_id); + if(!(bg0 || bg1 || bg2)) + render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id]) else - smRender_mixed_tri(sm,i,vp,clr); + render_mixed_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id],bg0,bg1,bg2,vp,SM_VIEW_CENTER(sm)); } glEnd(); glPopAttrib(); } -smRender_tri_edges(sm,i) -SM *sm; -int i; +int +compare_tri_depths(T_DEPTH *td1,T_DEPTH *td2) { - TRI *tri; - int j; - double ptr[3]; + double d; + if(td1->tri==-1) + { + if(td2->tri==-1) + return(0); + else + return(-1); + } + if(td2->tri==-1) + return(1); - tri = SM_NTH_TRI(sm,i); - - for(j=0; j <= 2; j++) - { - VCOPY(ptr,SM_NTH_WV(sm,T_NTH_V(tri,j))); - glVertex3d(ptr[0],ptr[1],ptr[2]); - VCOPY(ptr,SM_NTH_WV(sm,T_NTH_V(tri,(j+1)%3))); - glVertex3d(ptr[0],ptr[1],ptr[2]); - } + d = td2->depth-td1->depth; + + if(d > 0.0) + return(1); + if(d < 0.0) + return(-1); + + return(0); } int -compare_tri_depths(T_DEPTH *td1,T_DEPTH *td2) +compare_tri_depths_old(T_DEPTH *td1,T_DEPTH *td2) { double d; @@ -505,6 +564,7 @@ T_DEPTH *td; TRI *tri; double d,min_d; LIST *tlist=NULL; + FVECT diff; i = 0; SM_FOR_ALL_NEW_TRIS(sm,t_id) @@ -515,13 +575,6 @@ T_DEPTH *td; continue; } tri = SM_NTH_TRI(sm,t_id); -#ifdef DEBUG - if(i >= smNew_tri_cnt) - { - eputs("smDepth_sort_tris():More tris than reported by smNew_tri_cnt\n"); - break; - } -#endif td[i].tri = t_id; min_d = -1; for(j=0;j < 3;j++) @@ -529,7 +582,8 @@ T_DEPTH *td; v = T_NTH_V(tri,j); if(!SM_BG_SAMPLE(sm,v)) { - d = DIST(vp,SM_NTH_WV(sm,v)); + VSUB(diff,SM_NTH_WV(sm,v),vp); + d = DOT(diff,diff); if(min_d == -1 || d < min_d) min_d = d; } @@ -544,6 +598,60 @@ T_DEPTH *td; } + +LIST +*smOrder_new_tris(sm,vp,td,sort) +SM *sm; +FVECT vp; +T_DEPTH *td; +int sort; +{ + int i,j,t_id,v; + TRI *tri; + double d,min_d; + LIST *tlist=NULL; + FVECT diff; + + i = 0; + for(i=0; i < smNew_tri_cnt;i++) + { + t_id = smNew_tris[i].tri; + + tri = SM_NTH_TRI(sm,t_id); + if(!T_IS_VALID(tri)) + { + smNew_tris[i].tri = -1; + continue; + } + if(SM_BG_TRI(sm,t_id)) + { + tlist = push_data(tlist,t_id); + smNew_tris[i].tri = -1; + continue; + } + if(!sort) + continue; + min_d = -1; + for(j=0;j < 3;j++) + { + v = T_NTH_V(tri,j); + if(!SM_BG_SAMPLE(sm,v)) + { + VSUB(diff,SM_NTH_WV(sm,v),vp); + d = DOT(diff,diff); + if(min_d == -1 || d < min_d) + min_d = d; + } + } + td[i].depth = min_d; + } + if(!sort) + return(tlist); + qsort((void *)td,smNew_tri_cnt,sizeof(T_DEPTH),compare_tri_depths); + return(tlist); +} + + smUpdate_Rendered_mesh(sm,vp,clr) SM *sm; FVECT vp; @@ -551,15 +659,20 @@ int clr; { static T_DEPTH *td= NULL; static int tsize = 0; - int i; + int i,v0_id,v1_id,v2_id,bg0,bg1,bg2; GLint depth_test; double d; LIST *bglist; + TRI *tri; + float (*wp)[3]; + BYTE (*rgb)[3]; + /* For all of the NEW triangles (since last update): assume ACTIVE. Go through and sort on depth value (from vp). Turn Depth Buffer test off and render back-front */ /* NOTE: could malloc each time or hard code */ +#if 0 if(smNew_tri_cnt > tsize) { if(td) @@ -572,7 +685,15 @@ int clr; error(SYSTEM,"smUpdate_Rendered_mesh:Cannot allocate memory\n"); } bglist = smDepth_sort_tris(sm,vp,td); - +#else + td = smNew_tris; + if(!EQUAL_VEC3(SM_VIEW_CENTER(sm),vp)) + bglist = smOrder_new_tris(sm,vp,td,1); + else + bglist = smOrder_new_tris(sm,vp,td,0); +#endif + wp = SM_WP(sm); + rgb =SM_RGB(sm); /* Turn Depth Test off -- using Painter's algorithm */ glPushAttrib(GL_DEPTH_BUFFER_BIT); glDepthFunc(GL_ALWAYS); @@ -581,17 +702,46 @@ int clr; /* First render bg triangles */ glBegin(GL_TRIANGLES); while(bglist) - smRender_bg_tri(sm,pop_list(&bglist),vp,d,clr); + { + i = pop_list(&bglist); + if (clr) + SM_CLR_NTH_T_NEW(sm,i); + tri = SM_NTH_TRI(sm,i); + v0_id = T_NTH_V(tri,0); + v1_id = T_NTH_V(tri,1); + v2_id = T_NTH_V(tri,2); + render_bg_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id],vp,SM_VIEW_CENTER(sm),d); + } glEnd(); glBegin(GL_TRIANGLES); i=0; - while(td[i].tri != -1) - if(!SM_MIXED_TRI(sm,td[i].tri)) - smRender_tri(sm,td[i++].tri,vp,clr); - else - smRender_mixed_tri(sm,td[i++].tri,vp,clr); + while(i != smNew_tri_cnt) + { + if(td[i].tri == -1) + { + i++; + continue; + } + if (clr) + SM_CLR_NTH_T_NEW(sm,td[i].tri); + tri = SM_NTH_TRI(sm,td[i].tri); + v0_id = T_NTH_V(tri,0); + v1_id = T_NTH_V(tri,1); + v2_id = T_NTH_V(tri,2); + bg0 = SM_DIR_ID(sm,v0_id) || SM_BASE_ID(sm,v0_id); + bg1 = SM_DIR_ID(sm,v1_id) || SM_BASE_ID(sm,v1_id); + bg2 = SM_DIR_ID(sm,v2_id) || SM_BASE_ID(sm,v2_id); + if(!(bg0 || bg1 || bg2)) + render_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id]) + else + render_mixed_tri(wp[v0_id],wp[v1_id],wp[v2_id],rgb[v0_id],rgb[v1_id], + rgb[v2_id],bg0,bg1,bg2,vp,SM_VIEW_CENTER(sm)); + i++; + } glEnd(); /* Restore Depth Test */ @@ -626,8 +776,6 @@ smUpdate(view,qual) if(!smMesh) return; - - d = DIST(view->vp,SM_VIEW_CENTER(smMesh)); if(qual >= 100 && d > SM_ALLOWED_VIEW_CHANGE(smMesh)) { @@ -637,6 +785,7 @@ smUpdate(view,qual) #endif mark_tris_in_frustum(view); smRebuild_mesh(smMesh,view); + smClean_notify = TRUE; } /* This is our final update iff qual==100 and view==&odev.v */ last_update = qual>=100 && view==&(odev.v); @@ -698,7 +847,9 @@ smUpdate(view,qual) { smClean_notify = FALSE; smNew_tri_cnt = 0; +#if 0 smClear_flags(smMesh,T_NEW_FLAG); +#endif qtCache_init(0); }
