root/radiance/ray/src/hd/sm_list.c
Revision: 3.6
Committed: Sun Jan 10 10:27:45 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.5: +0 -0 lines
sm.c, sm_del.c sm_ogl.c sm.h
Fixed failure to tone-map on start up
added code for temporary buffer allocation
added bg flag, and fast flag checking routines for drawing
provided graceful backout if deletion triangulation fails
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * sm_list.c
9 * Routines for handling linked generic linked lists, stack, and
10 * circular lists. Data element is an int (can be cast to hold
11 * pointer to more general data element)
12 */
13
14 #include "standard.h"
15 #include "sm_list.h"
16
17 /* List of available edges */
18 static LIST *free_lists = NULL;
19 #ifdef DEBUG
20 extern int Malloc_cnt;
21 #endif
22 LIST
23 *new_list()
24 {
25 LIST *l;
26
27 /* check free list for available edges */
28 if( free_lists )
29 {
30 l = free_lists;
31 free_lists = LIST_NEXT(free_lists);
32 }
33 /* if no free edges- allocate the memory */
34 else
35 {
36 if( !(l = (LIST *)malloc(sizeof(LIST))))
37 error(SYSTEM,"new_list():Unable to allocate memory");
38 }
39 /* clear the memory */
40 bzero(l, sizeof(LIST));
41
42 return(l);
43 }
44
45
46 /* attaches list a at the end of list b */
47 LIST
48 *append_list(a,b)
49 LIST *a,*b;
50 {
51 LIST * l;
52
53 if(!b)
54 return(a);
55
56 l = b;
57 while(LIST_NEXT(l) && LIST_NEXT(l) != b)
58 l = LIST_NEXT(l);
59
60 SET_LIST_NEXT(l,a);
61
62 return(b);
63 }
64
65 /* attaches list a at the end of list b */
66 LIST
67 *add_data(l,d,end)
68 LIST *l;
69 int d;
70 LIST **end;
71
72 {
73 LIST *list,*lptr;
74
75 list = new_list();
76 SET_LIST_DATA(list,d);
77
78 if(!l)
79 {
80 if(end)
81 *end = list;
82 return(list);
83 }
84 if(end)
85 lptr = *end;
86 else
87 {
88 lptr = l;
89 while(LIST_NEXT(lptr))
90 lptr = LIST_NEXT(lptr);
91 }
92 LIST_NEXT(lptr) = list;
93 if(end)
94 *end = list;
95
96 return(l);
97 }
98
99 /* Adds data to the end of a circular list. If set, "end"
100 * is a pointer to the last element in the list
101 */
102 LIST
103 *add_data_to_circular_list(l,end,d)
104 LIST *l,**end;
105 int d;
106 {
107 LIST *list;
108
109 list = new_list();
110 SET_LIST_DATA(list,d);
111
112 if(!l)
113 l = list;
114 else
115 {
116 if(*end)
117 SET_LIST_NEXT(*end,list);
118 else
119 l = append_list(list,l);
120 }
121
122 *end = list;
123 SET_LIST_NEXT(list,l);
124 return(l);
125 }
126
127
128
129 /* frees the list */
130 LIST
131 *free_list(l)
132 LIST * l;
133 {
134 if(!l)
135 return(NULL);
136
137 free_lists = append_list(free_lists,l);
138
139 return(NULL);
140 }
141
142 /* Pushes data element d at the top of the list- returns pointer
143 to new top of list
144 */
145 LIST
146 *push_data(l,d)
147 LIST *l;
148 int d;
149 {
150 LIST *list;
151
152 list = new_list();
153 SET_LIST_DATA(list,d);
154 SET_LIST_NEXT(list,l);
155 return(list);
156 }
157 /* Returns data element d at the top of the list- returns pointer
158 to new top of list
159 */
160 int
161 pop_list(l)
162 LIST **l;
163 {
164 LIST *p;
165 int d;
166
167 if(!l)
168 return(NULL);
169 if(!(p = *l))
170 return(NULL);
171
172 d = LIST_DATA(p);
173
174 *l = LIST_NEXT(p);
175
176 LIST_NEXT(p) =NULL;
177 free_list(p);
178
179 return(d);
180 }
181
182 /* Search through list for data element "d", and remove from
183 * list: Returns TRUE if found, false otherwise
184 */
185 int
186 remove_from_list(d,list)
187 int d;
188 LIST **list;
189 {
190 LIST *l,*prev;
191
192 l = *list;
193 prev = NULL;
194
195 while(l)
196 {
197 if(LIST_DATA(l) == d)
198 {
199 if(l == *list)
200 *list = LIST_NEXT(*list);
201 else
202 SET_LIST_NEXT(prev,LIST_NEXT(l));
203
204 SET_LIST_NEXT(l,NULL);
205 free_list(l);
206 return(TRUE);
207 }
208 prev = l;
209 l = LIST_NEXT(l);
210 }
211 return(FALSE);
212 }
213
214
215
216
217
218
219
220
221
222
