root/radiance/ray/src/hd/sm_list.c
Sat Feb 22 02:07:25 2003 UTC (21 years, 1 month ago) by greg
Changes since 3.7: +1 -4 lines
Diff to previous 3.7 , to selected 3.6
Thu Jun 10 15:22:23 1999 UTC (24 years, 9 months ago) by gwlarson
Changes since 3.6: +6 -4 lines
Diff to previous 3.6
Implemented sample quadtree in place of triangle quadtree
Made geometric predicates more robust
Added #define LORES which utilizes a single precision floating point
  sample array, the default is a double sample array
Added topology DEBUG commands (for DEBUG > 1)
Made code optimizations
Revision 3.6 - (view) (download) (annotate) - [selected]
Sun Jan 10 10:27:45 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.5: +0 -0 lines
Diff to previous 3.5
sm.c, sm_del.c sm_ogl.c sm.h
Fixed failure to tone-map on start up
added code for temporary buffer allocation
added bg flag, and fast flag checking routines for drawing
provided graceful backout if deletion triangulation fails
Tue Jan 5 16:52:38 1999 UTC (25 years, 2 months ago) by gwlarson
Changes since 3.4: +16 -15 lines
Diff to previous 3.4 , to selected 3.6
fixed logic in smTest to handle nearby and coincident points, added base tris to rendering, made list of new triangles to speed up rendering
Mon Dec 28 18:07:35 1998 UTC (25 years, 3 months ago) by gwlarson
Changes since 3.3: +34 -0 lines
Diff to previous 3.3 , to selected 3.6
New insertion routine
New Culling routine based on insertion algorithm
Adapted old insertion code: now used by picking
Point location code returns on-vertex,on-edge, or in-triangle
Added on_edge case for subdivision
Implemented unordered sets
Removed deletion from quadtree- added set compression to replace functionality
Wed Sep 16 18:16:28 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.2: +0 -3 lines
Diff to previous 3.2 , to selected 3.6
implemented integer triangle tracing
Fri Sep 11 11:52:26 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 3.1: +2 -3 lines
Diff to previous 3.1 , to selected 3.6
fixed triangle insertion using edge tracing
Wed Aug 19 17:45:24 1998 UTC (25 years, 7 months ago) by gwlarson
Diff to selected 3.6
