root/radiance/ray/src/hd/sm_list.c
Revision: 3.4
Committed: Mon Dec 28 18:07:35 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.3: +34 -0 lines
New insertion routine
New Culling routine based on insertion algorithm
Adapted old insertion code: now used by picking
Point location code returns on-vertex,on-edge, or in-triangle
Added on_edge case for subdivision
Implemented unordered sets
Removed deletion from quadtree- added set compression to replace functionality
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * sm_list.c
9 * Routines for handling linked generic linked lists, stack, and
10 * circular lists. Data element is an int (can be cast to hold
11 * pointer to more general data element)
12 */
13
14 #include "standard.h"
15 #include "sm_list.h"
16
17 /* List of available edges */
18 static LIST *free_lists = NULL;
19 #ifdef DEBUG
20 extern int Malloc_cnt;
21 #endif
22 LIST
23 *new_list()
24 {
25 LIST *l;
26
27 /* check free list for available edges */
28 if( free_lists )
29 {
30 l = free_lists;
31 free_lists = LIST_NEXT(free_lists);
32 }
33 /* if no free edges- allocate the memory */
34 else
35 {
36 if( !(l = (LIST *)malloc(sizeof(LIST))))
37 error(SYSTEM,"new_list():Unable to allocate memory");
38 }
39 /* clear the memory */
40 bzero(l, sizeof(LIST));
41
42 return(l);
43 }
44
45
46 /* attaches list a at the end of list b */
47 LIST
48 *append_list(a,b)
49 LIST *a,*b;
50 {
51 LIST * l;
52
53 if(!b)
54 return(a);
55
56 l = b;
57 while(LIST_NEXT(l) && LIST_NEXT(l) != b)
58 l = LIST_NEXT(l);
59
60 SET_LIST_NEXT(l,a);
61
62 return(b);
63 }
64
65 /* attaches list a at the end of list b */
66 LIST
67 *add_data(l,d,end)
68 LIST *l;
69 int d;
70 LIST **end;
71
72 {
73 LIST *list,*lptr;
74
75 list = new_list();
76 SET_LIST_DATA(list,d);
77
78 if(!l)
79 {
80 if(end)
81 *end = list;
82 return(list);
83 }
84 if(end)
85 lptr = *end;
86 else
87 {
88 lptr = l;
89 while(LIST_NEXT(lptr))
90 lptr = LIST_NEXT(lptr);
91 }
92 LIST_NEXT(lptr) = list;
93 if(end)
94 *end = list;
95
96 return(l);
97 }
98
99 /* Adds data to the end of a circular list. If set, "end"
100 * is a pointer to the last element in the list
101 */
102 LIST
103 *add_data_to_circular_list(l,end,d)
104 LIST *l,**end;
105 int d;
106 {
107 LIST *list;
108
109 list = new_list();
110 SET_LIST_DATA(list,d);
111
112 if(!l)
113 l = list;
114 else
115 {
116 if(*end)
117 SET_LIST_NEXT(*end,list);
118 else
119 l = append_list(list,l);
120 }
121
122 *end = list;
123 SET_LIST_NEXT(list,l);
124 return(l);
125 }
126
127 /* Pushes data element d at the top of the list- returns pointer
128 to new top of list
129 */
130 LIST
131 *push_data(l,d)
132 LIST *l;
133 int d;
134 {
135 LIST * list;
136
137 list = new_list();
138 SET_LIST_DATA(list,d);
139 SET_LIST_NEXT(list,l);
140 return(list);
141 }
142
143 /* frees the list */
144 LIST
145 *free_list(l)
146 LIST * l;
147 {
148 if(!l)
149 return(NULL);
150
151 free_lists = append_list(free_lists,l);
152
153 return(NULL);
154 }
155
156 /* Returns data element d at the top of the list- returns pointer
157 to new top of list
158 */
159 int
160 pop_list(l)
161 LIST **l;
162 {
163 LIST *p;
164 int d;
165
166 if(!l)
167 return(NULL);
168 if(!(p = *l))
169 return(NULL);
170
171 d = LIST_DATA(p);
172
173 *l = LIST_NEXT(p);
174
175 LIST_NEXT(p) =NULL;
176 free_list(p);
177
178 return(d);
179 }
180
181 /* Search through list for data element "d", and remove from
182 * list: Returns TRUE if found, false otherwise
183 */
184 int
185 remove_from_list(d,list)
186 int d;
187 LIST **list;
188 {
189 LIST *l,*prev;
190
191 l = *list;
192 prev = NULL;
193
194 while(l)
195 {
196 if(LIST_DATA(l) == d)
197 {
198 if(l == *list)
199 *list = LIST_NEXT(*list);
200 else
201 SET_LIST_NEXT(prev,LIST_NEXT(l));
202
203 SET_LIST_NEXT(l,NULL);
204 free_list(l);
205 return(TRUE);
206 }
207 prev = l;
208 l = LIST_NEXT(l);
209 }
210 return(FALSE);
211 }
212
213
214
215
216
217
218
219
220
221
