root/radiance/ray/src/hd/sm_list.c
Revision: 3.2
Committed: Fri Sep 11 11:52:26 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.1: +2 -3 lines
fixed triangle insertion using edge tracing
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * sm_list.c
9 * Routines for handling linked generic linked lists, stack, and
10 * circular lists. Data element is an int (can be cast to hold
11 * pointer to more general data element)
12 */
13
14 #include "standard.h"
15 #include "sm_list.h"
16
17 /* List of available edges */
18 static LIST *free_lists = NULL;
19 #ifdef DEBUG
20 extern int Malloc_cnt;
21 #endif
22 LIST
23 *new_list()
24 {
25 LIST *l;
26
27 /* check free list for available edges */
28 if( free_lists )
29 {
30 l = free_lists;
31 free_lists = LIST_NEXT(free_lists);
32 }
33 /* if no free edges- allocate the memory */
34 else
35 {
36 if( !(l = (LIST *)malloc(sizeof(LIST))))
37 error(SYSTEM,"new_list():Unable to allocate memory");
38 }
39 /* clear the memory */
40 bzero(l, sizeof(LIST));
41
42 return(l);
43 }
44
45
46 /* attaches list a at the end of list b */
47 LIST
48 *append_list(a,b)
49 LIST *a,*b;
50 {
51 LIST * l;
52
53 if(!a)
54 return(b);
55
56 if(!b)
57 return(a);
58
59 l = b;
60 while(LIST_NEXT(l) && LIST_NEXT(l) != b)
61 l = LIST_NEXT(l);
62
63 SET_LIST_NEXT(l,a);
64
65 return(b);
66 }
67
68 /* Adds data to the end of a circular list. If set, "end"
69 * is a pointer to the last element in the list
70 */
71 LIST
72 *add_data_to_circular_list(l,end,d)
73 LIST *l,**end;
74 int d;
75 {
76 LIST *list;
77
78 list = new_list();
79 SET_LIST_DATA(list,d);
80
81 if(!l)
82 l = list;
83 else
84 {
85 if(*end)
86 SET_LIST_NEXT(*end,list);
87 else
88 l = append_list(list,l);
89 }
90
91 *end = list;
92 SET_LIST_NEXT(list,l);
93 return(l);
94 }
95
96 /* Pushes data element d at the top of the list- returns pointer
97 to new top of list
98 */
99 LIST
100 *push_data(l,d)
101 LIST *l;
102 int d;
103 {
104 LIST * list;
105
106 list = new_list();
107 SET_LIST_DATA(list,d);
108 SET_LIST_NEXT(list,l);
109 return(list);
110 }
111
112 /* frees the list */
113 LIST
114 *free_list(l)
115 LIST * l;
116 {
117 if(!l)
118 return(NULL);
119
120 free_lists = append_list(free_lists,l);
121
122 return(NULL);
123 }
124
125 /* Returns data element d at the top of the list- returns pointer
126 to new top of list
127 */
128 int
129 pop_list(l)
130 LIST **l;
131 {
132 LIST *p;
133 int d;
134
135 if(!l)
136 return(NULL);
137 if(!(p = *l))
138 return(NULL);
139
140 d = LIST_DATA(p);
141
142 *l = LIST_NEXT(p);
143
144 LIST_NEXT(p) =NULL;
145 free_list(p);
146
147 return(d);
148 }
149
150 /* Search through list for data element "d", and remove from
151 * list: Returns TRUE if found, false otherwise
152 */
153 int
154 remove_from_list(d,list)
155 int d;
156 LIST **list;
157 {
158 LIST *l,*prev;
159
160 l = *list;
161 prev = NULL;
162
163 while(l)
164 {
165 if(LIST_DATA(l) == d)
166 {
167 if(l == *list)
168 *list = LIST_NEXT(*list);
169 else
170 SET_LIST_NEXT(prev,LIST_NEXT(l));
171
172 SET_LIST_NEXT(l,NULL);
173 free_list(l);
174 return(TRUE);
175 }
176 prev = l;
177 l = LIST_NEXT(l);
178 }
179 return(FALSE);
180 }
181
182
183
184
185
186
187
188
189
190
