root/radiance/ray/src/hd/sm_geom.h
Revision: 3.6
Committed: Wed Nov 11 12:05:39 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.5: +8 -1 lines
new triangulation code
changed triangle vertex order to CCW
changed numbering of triangle neighbors to match quadtree
fixed tone-mapping bug
removed errant printf() statements
redid logic for adding and testing samples with new epsilon
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * sm_geom.h
7 */
8
9 /* Assumes included after standard.h */
10
11 #include <values.h>
12
13 #define F_TINY 1e-3
14
15 #define FZERO(x) ((x) < F_TINY && (x) > -F_TINY)
16 #define FEQUAL(a,b) FZERO((a) - (b))
17
18 #define ZERO(x) ((x) < FTINY && (x) > -FTINY)
19 #define EQUAL(a,b) ZERO((a) - (b))
20
21 #ifndef TRUE
22 #define TRUE 1
23 #define FALSE 0
24 #endif
25
26 typedef struct _FPEQ {
27 FVECT n;
28 double d;
29 char x,y,z;
30 }FPEQ;
31
32 #define FP_N(f) ((f).n)
33 #define FP_D(f) ((f).d)
34 #define FP_X(f) ((f).x)
35 #define FP_Y(f) ((f).y)
36 #define FP_Z(f) ((f).z)
37
38 typedef long BCOORD;
39 typedef long BDIR;
40 typedef long TINT;
41 #define BITS_BCOORD (BITS(long)>>1)
42 #define SHIFT_MAXBCOORD (BITS_BCOORD-2)
43 #define MAXBCOORD (1L << SHIFT_MAXBCOORD)
44 #define MAXBCOORD2 (MAXBCOORD>>1)
45 #define MAXBDIR MAXBCOORD
46 #define MAXT MAXBCOORD
47 #define HUGET MAXLONG
48
49 #define M_2_3_PI PI*2/3
50
51 #ifndef INVALID
52 #define INVALID -1
53 #endif
54
55 #define GT_INVALID 0
56 #define GT_VERTEX 1
57 #define GT_EDGE 2
58 #define GT_FACE 4
59 #define GT_INTERIOR 8
60 #define GT_INTERSECT 16
61 #define GT_ADJACENT 32
62 #define GT_OUT 64
63
64 #define ZERO_VEC3(v) (ZERO(v[0]) && ZERO(v[1]) && ZERO(v[2]) )
65 #define EQUAL_VEC3(a,b) (EQUAL(a[0],b[0])&&EQUAL(a[1],b[1])&&EQUAL(a[2],b[2]))
66 #define FZERO_VEC3(v) (FZERO(v[0]) && FZERO(v[1]) && FZERO(v[2]) )
67 #define FEQUAL_VEC3(a,b) (FEQUAL(a[0],b[0])&&FEQUAL(a[1],b[1])&&FEQUAL(a[2],b[2]))
68 #define NEGATE_VEC3(v) ((v)[0] *= -1.0,(v)[1] *= -1.0,(v)[2] *= -1.0)
69 #define COPY_VEC2(v1,v2) ((v1)[0]=(v2)[0],(v1)[1]=(v2)[1])
70 #define DIST(a,b) (sqrt(((a)[0]-(b)[0])*((a)[0]-(b)[0]) + \
71 ((a)[1]-(b)[1])*((a)[1]-(b)[1]) + \
72 ((a)[2]-(b)[2])*((a)[2]-(b)[2])))
73 #define DIST_SQ(a,b) (((a)[0]-(b)[0])*((a)[0]-(b)[0]) + \
74 ((a)[1]-(b)[1])*((a)[1]-(b)[1]) + \
75 ((a)[2]-(b)[2])*((a)[2]-(b)[2]))
76
77 #define CROSS_VEC2(v1,v2) (((v1)[0]*(v2)[1]) - ((v1)[1]*(v2)[0]))
78 #define DOT_VEC2(v1,v2) ((v1)[0]*(v2)[0] + (v1)[1]*(v2)[1])
79
80 #define EDGE_MIDPOINT_VEC3(a,v1,v2) ((a)[0]=((v1)[0]+(v2)[0])*0.5, \
81 (a)[1]=((v1)[1]+(v2)[1])*0.5,(a)[2] = ((v1)[2]+(v2)[2])*0.5)
82
83 #define MIN_VEC3(v) ((v)[0]<(v)[1]?((v)[0]<(v)[2]?(v)[0]:v[2]): \
84 (v)[1]<(v)[2]?(v)[1]:(v)[2])
85 #define MAX3(a,b,c) (((b)>(a))?((b) > (c))?(b):(c):((a)>(c))?(a):(c))
86 #define MIN3(a,b,c) (((b)<(a))?((b) < (c))?(b):(c):((a)<(c))?(a):(c))
87 #define MAX(a,b) (((b)>(a))?(b):(a))
88 #define MIN(a,b) (((b)<(a))?(b):(a))
89
90 #define SUM_3VEC3(r,a,b,c) ((r)[0]=(a)[0]+(b)[0]+(c)[0], \
91 (r)[1]=(a)[1]+(b)[1]+(c)[1],(r)[2]=(a)[2]+(b)[2]+(c)[2])
92
93 #define NTH_BIT(n,i) ((n) & (1<<(i)))
94 #define SET_NTH_BIT(n,i) ((n) |= (1<<(i)))
95
96
97 /* int convex_angle(FVECT v0,FVECT v1,FVECT v2) */
98 /* void triangle_centroid(FVECT v0,FVECT v1,FVECT v2,FVECT c) */
99 /* void triangle_plane_equation(FVECT v0,FVECT v1,FVECT v2,FVECT n,double *nd,
100 char norm) */
101 /* int vec3_equal(FVECT v1,v2) */
102 /* int point_relative_to_plane(FVECT p,FVECT n, double nd) */
103 /* int point_in_circle(FVECT p,FVECT p0,FVECT p1) */
104 /* int intersect_line_plane(FVECT r,FVECT p1,FVECT p2,float *plane) */
105 /* int point_in_cone(FVECT p,FVECT p1,FVECT p2,FVECT p3,FVECT p4) */
106 /* void point_on_sphere(FVECT ps,FVECT p,FVECT c) */
107 /* int test_point_against_spherical_tri(FVECT v0,FVECT v1,FVECT v2,FVECT p,
108 FVECT n,char *nset,char *which,char sides[3]) */
109 /* int test_single_point_against_spherical_tri(FVECT v0,FVECT v1,FVECT v2,
110 FVECT p,char *which )*/
111 /* int test_vertices_for_tri_inclusion(FVECT tri[3],FVECT pts[3],char *nset,
112 FVECT n[3],FVECT avg,char pt_sides[3][3]); */
113 /* void set_sidedness_tests(FVECT tri[3],FVECT pts[3],char test[3],
114 char sides[3][3],char nset,FVECT n[3])
115 */
116 /* int cs_spherical_edge_edge_test(FVECT n[2][3],int i,int j,FVECT avg[2]) */
117 /* int spherical_tri_tri_intersect(FVECT a1,FVECT a2,FVECT a3,
118 FVECT b1,FVECT b2,FVECT b3) */
119
120 /* void calculate_view_frustum(FVECT vp,hv,vv,double horiz,vert,near,far,
121 FVECT fnear[4],FVECT ffar[4])
122 */
123 /* double triangle_normal_Newell(FVECT v0,FVECT v1,FVECT v2,FVECT n,char n)*/
124 double tri_normal();
125 /* double spherical_edge_normal(FVECT v0,FVECT v1,FVECT n,char norm) */
126 double spherical_edge_normal();
127
128 #define point_in_stri_n(n0,n1,n2,p) \
129 ((DOT(n0,p)<=F_TINY)&&(DOT(n1,p)<=F_TINY)&&(DOT(n2,p)<=F_TINY))
130
131 #define PT_ON_PLANE(p,peq) (DOT(FP_N(peq),p)+FP_D(peq))
