--- ray/src/hd/sm_geom.h 1999/01/10 10:27:46 3.9 +++ ray/src/hd/sm_geom.h 2003/02/22 02:07:25 3.12 @@ -1,7 +1,4 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - -/* SCCSid "$SunId$ SGI" */ - +/* RCSid: $Id: sm_geom.h,v 3.12 2003/02/22 02:07:25 greg Exp $ */ /* * sm_geom.h */ @@ -10,7 +7,13 @@ #include -#define F_TINY 1e-5 +#ifdef SMLFLT +#define EQUALITY_EPS 1e-6 +#else +#define EQUALITY_EPS 1e-10 +#endif + +#define F_TINY 1e-10 #define FZERO(x) ((x) < F_TINY && (x) > -F_TINY) #define FEQUAL(a,b) FZERO((a) - (b)) @@ -36,7 +39,6 @@ typedef struct _FPEQ { typedef long BCOORD; typedef long BDIR; -typedef long TINT; #define BITS_BCOORD (BITS(long)-2) #define SHIFT_MAXBCOORD (BITS_BCOORD-1) @@ -49,16 +51,19 @@ typedef long TINT; #ifndef INVALID #define INVALID -1 #endif +#define IADDV3(v,a) ((v)[0] += (a)[0],(v)[1] += (a)[1],(v)[2] += (a)[2]) +#define ISUBV3(v,a) ((v)[0] -= (a)[0],(v)[1] -= (a)[1],(v)[2] -= (a)[2]) +#define ISCALEV3(v,a) ((v)[0] *= (a),(v)[1] *= (a),(v)[2] *= (a)) +#define IDIVV3(v,a) ((v)[0] /= (a),(v)[1] /= (a),(v)[2] /= (a)) -#define GT_INVALID 0 -#define GT_VERTEX 1 -#define GT_EDGE 2 -#define GT_FACE 4 -#define GT_INTERIOR 8 -#define GT_INTERSECT 16 -#define GT_ADJACENT 32 -#define GT_OUT 64 +#define ADDV3(v,a,b) ((v)[0] = (a)[0]+(b)[0],(v)[1] = (a)[1]+(b)[1],\ + (v)[2] = (a)[2]+(b)[2]) +#define SUBV3(v,a,b) ((v)[0] = (a)[0]-(b)[0],(v)[1] = (a)[1]-(b)[1],\ + (v)[2] = (a)[2]-(b)[2]) +#define SUMV3(v,a,b,s) ((v)[0] = (a)[0]+(s)*(b)[0],(v)[1]=(a)[1]+(s)*(b)[1],\ + (v)[2] = (a)[2]+(s)*(b)[2]) +#define SCALEV3(v,a,s) ((v)[0]=(a)[0]*(s),(v)[1]=(a)[1]*(s),(v)[2]=(a)[2]*(s)) #define ZERO_VEC3(v) (ZERO(v[0]) && ZERO(v[1]) && ZERO(v[2]) ) #define EQUAL_VEC3(a,b) (FEQUAL(a[0],b[0])&&FEQUAL(a[1],b[1])&&FEQUAL(a[2],b[2])) #define OPP_EQUAL_VEC3(a,b) (EQUAL(a[0],-b[0])&&EQUAL(a[1],-b[1])&&EQUAL(a[2],-b[2])) @@ -83,7 +88,8 @@ typedef long TINT; #define MIN_VEC3(v) ((v)[0]<(v)[1]?((v)[0]<(v)[2]?(v)[0]:v[2]): \ (v)[1]<(v)[2]?(v)[1]:(v)[2]) #define MAX3(a,b,c) (((b)>(a))?((b) > (c))?(b):(c):((a)>(c))?(a):(c)) -#define MIN3(a,b,c) (((b)<(a))?((b) < (c))?(b):(c):((a)<(c))?(a):(c)) +#define MIN3(a,b,c) (((b)<(a))?((b) < (c))?(b):(c):((a)<(c))?(a):(c)) + #define MAX(a,b) (((b)>(a))?(b):(a)) #define MIN(a,b) (((b)<(a))?(b):(a)) @@ -93,41 +99,23 @@ typedef long TINT; #define NTH_BIT(n,i) ((n) & (1<<(i))) #define SET_NTH_BIT(n,i) ((n) |= (1<<(i))) +#define PT_ON_PLANE(p,peq) (DOT(FP_N(peq),p)+FP_D(peq)) -/* int convex_angle(FVECT v0,FVECT v1,FVECT v2) */ -/* void triangle_centroid(FVECT v0,FVECT v1,FVECT v2,FVECT c) */ -/* void triangle_plane_equation(FVECT v0,FVECT v1,FVECT v2,FVECT n,double *nd, - char norm) */ -/* int vec3_equal(FVECT v1,v2) */ -/* int point_relative_to_plane(FVECT p,FVECT n, double nd) */ -/* int point_in_circle(FVECT p,FVECT p0,FVECT p1) */ -/* int intersect_line_plane(FVECT r,FVECT p1,FVECT p2,float *plane) */ -/* int point_in_cone(FVECT p,FVECT p1,FVECT p2,FVECT p3,FVECT p4) */ -/* void point_on_sphere(FVECT ps,FVECT p,FVECT c) */ -/* int test_point_against_spherical_tri(FVECT v0,FVECT v1,FVECT v2,FVECT p, - FVECT n,char *nset,char *which,char sides[3]) */ -/* int test_single_point_against_spherical_tri(FVECT v0,FVECT v1,FVECT v2, - FVECT p,char *which )*/ -/* int test_vertices_for_tri_inclusion(FVECT tri[3],FVECT pts[3],char *nset, - FVECT n[3],FVECT avg,char pt_sides[3][3]); */ -/* void set_sidedness_tests(FVECT tri[3],FVECT pts[3],char test[3], - char sides[3][3],char nset,FVECT n[3]) - */ -/* int cs_spherical_edge_edge_test(FVECT n[2][3],int i,int j,FVECT avg[2]) */ -/* int spherical_tri_tri_intersect(FVECT a1,FVECT a2,FVECT a3, - FVECT b1,FVECT b2,FVECT b3) */ - -/* void calculate_view_frustum(FVECT vp,hv,vv,double horiz,vert,near,far, - FVECT fnear[4],FVECT ffar[4]) - */ -/* double triangle_normal_Newell(FVECT v0,FVECT v1,FVECT v2,FVECT n,char n)*/ +/* FUNCTIONS: + int point_in_cone(FVECT p,a,b,c) + void triangle_centroid(FVECT v0,v1,v2,c) + double tri_normal(FVECT v0,v1,v2,n,int norm) + void tri_plane_equation(FVECT v0,v1,v2,FPEQ *peqptr,int norm) + int intersect_ray_plane(FVECT orig,dir,FPEQ peq,double *pd,FVECT r) + double point_on_sphere(FVECT ps,p,c) + int point_in_stri(FVECT v0,v1,v2,p) + int ray_intersect_tri(FVECT orig,dir,v0,v1,v2,pt) + void calculate_view_frustum(FVECT vp,hv,vv,double horiz,vert,near,far, + FVECT fnear[4],ffar[4]) + void bary2d(double x1,y1,x2,y2,x3,y3,px,py,coord) +*/ double tri_normal(); -/* double spherical_edge_normal(FVECT v0,FVECT v1,FVECT n,char norm) */ -double spherical_edge_normal(); double point_on_sphere(); -#define point_in_stri_n(n0,n1,n2,p) \ - ((DOT(n0,p)<=FTINY)&&(DOT(n1,p)<=FTINY)&&(DOT(n2,p)<=FTINY)) -#define PT_ON_PLANE(p,peq) (DOT(FP_N(peq),p)+FP_D(peq))
