1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* sm_geom.c |
9 |
10 |
11 |
#include "standard.h" |
12 |
#include "sm_geom.h" |
13 |
14 |
tri_centroid(v0,v1,v2,c) |
15 |
FVECT v0,v1,v2,c; |
16 |
17 |
/* Average three triangle vertices to give centroid: return in c */ |
18 |
c[0] = (v0[0] + v1[0] + v2[0])/3.0; |
19 |
c[1] = (v0[1] + v1[1] + v2[1])/3.0; |
20 |
c[2] = (v0[2] + v1[2] + v2[2])/3.0; |
21 |
22 |
23 |
24 |
int |
25 |
vec3_equal(v1,v2) |
26 |
FVECT v1,v2; |
27 |
28 |
return(EQUAL(v1[0],v2[0]) && EQUAL(v1[1],v2[1])&& EQUAL(v1[2],v2[2])); |
29 |
30 |
31 |
32 |
int |
33 |
convex_angle(v0,v1,v2) |
34 |
FVECT v0,v1,v2; |
35 |
36 |
FVECT cp01,cp12,cp; |
37 |
38 |
/* test sign of (v0Xv1)X(v1Xv2). v1 */ |
39 |
VCROSS(cp01,v0,v1); |
40 |
VCROSS(cp12,v1,v2); |
41 |
VCROSS(cp,cp01,cp12); |
42 |
if(DOT(cp,v1) < 0) |
43 |
return(FALSE); |
44 |
return(TRUE); |
45 |
46 |
47 |
/* calculates the normal of a face contour using Newell's formula. e |
48 |
49 |
a = SUMi (yi - yi+1)(zi + zi+1) |
50 |
b = SUMi (zi - zi+1)(xi + xi+1) |
51 |
c = SUMi (xi - xi+1)(yi + yi+1) |
52 |
53 |
double |
54 |
tri_normal(v0,v1,v2,n,norm) |
55 |
FVECT v0,v1,v2,n; |
56 |
char norm; |
57 |
58 |
double mag; |
59 |
60 |
n[0] = (v0[2] + v1[2]) * (v0[1] - v1[1]) + |
61 |
(v1[2] + v2[2]) * (v1[1] - v2[1]) + |
62 |
(v2[2] + v0[2]) * (v2[1] - v0[1]); |
63 |
64 |
n[1] = (v0[2] - v1[2]) * (v0[0] + v1[0]) + |
65 |
(v1[2] - v2[2]) * (v1[0] + v2[0]) + |
66 |
(v2[2] - v0[2]) * (v2[0] + v0[0]); |
67 |
68 |
69 |
n[2] = (v0[1] + v1[1]) * (v0[0] - v1[0]) + |
70 |
(v1[1] + v2[1]) * (v1[0] - v2[0]) + |
71 |
(v2[1] + v0[1]) * (v2[0] - v0[0]); |
72 |
73 |
if(!norm) |
74 |
return(0); |
75 |
76 |
77 |
mag = normalize(n); |
78 |
79 |
return(mag); |
80 |
81 |
82 |
83 |
tri_plane_equation(v0,v1,v2,n,nd,norm) |
84 |
FVECT v0,v1,v2,n; |
85 |
double *nd; |
86 |
char norm; |
87 |
88 |
tri_normal(v0,v1,v2,n,norm); |
89 |
90 |
*nd = -(DOT(n,v0)); |
91 |
92 |
93 |
int |
94 |
point_relative_to_plane(p,n,nd) |
95 |
FVECT p,n; |
96 |
double nd; |
97 |
98 |
double d; |
99 |
100 |
d = p[0]*n[0] + p[1]*n[1] + p[2]*n[2] + nd; |
101 |
if(d < 0) |
102 |
return(-1); |
103 |
if(ZERO(d)) |
104 |
return(0); |
105 |
else |
106 |
return(1); |
107 |
108 |
109 |
/* From quad_edge-code */ |
110 |
int |
111 |
point_in_circle_thru_origin(p,p0,p1) |
112 |
FVECT p; |
113 |
FVECT p0,p1; |
114 |
115 |
116 |
double dp0,dp1; |
117 |
double dp,det; |
118 |
119 |
dp0 = DOT_VEC2(p0,p0); |
120 |
dp1 = DOT_VEC2(p1,p1); |
121 |
dp = DOT_VEC2(p,p); |
122 |
123 |
det = -dp0*CROSS_VEC2(p1,p) + dp1*CROSS_VEC2(p0,p) - dp*CROSS_VEC2(p0,p1); |
124 |
125 |
return (det > 0); |
126 |
127 |
128 |
129 |
130 |
point_on_sphere(ps,p,c) |
131 |
FVECT ps,p,c; |
132 |
133 |
VSUB(ps,p,c); |
134 |
normalize(ps); |
135 |
136 |
137 |
138 |
int |
139 |
intersect_vector_plane(v,plane_n,plane_d,tptr,r) |
140 |
FVECT v,plane_n; |
141 |
double plane_d; |
142 |
double *tptr; |
143 |
FVECT r; |
144 |
145 |
double t; |
146 |
int hit; |
147 |
148 |
Plane is Ax + By + Cz +D = 0: |
149 |
plane[0] = A,plane[1] = B,plane[2] = C,plane[3] = D |
150 |
151 |
152 |
/* line is l = p1 + (p2-p1)t, p1=origin */ |
153 |
154 |
/* Solve for t: */ |
155 |
t = plane_d/-(DOT(plane_n,v)); |
156 |
if(t >0 || ZERO(t)) |
157 |
hit = 1; |
158 |
else |
159 |
hit = 0; |
160 |
r[0] = v[0]*t; |
161 |
r[1] = v[1]*t; |
162 |
r[2] = v[2]*t; |
163 |
if(tptr) |
164 |
*tptr = t; |
165 |
return(hit); |
166 |
167 |
168 |
int |
169 |
intersect_ray_plane(orig,dir,plane_n,plane_d,pd,r) |
170 |
FVECT orig,dir; |
171 |
FVECT plane_n; |
172 |
double plane_d; |
173 |
double *pd; |
174 |
FVECT r; |
175 |
176 |
double t; |
177 |
int hit; |
178 |
179 |
180 |
181 |
182 |
/* A(orig[0] + dxt) + B(orig[1] + dyt) + C(orig[2] + dzt) + pd = 0 |
183 |
t = -(DOT(plane_n,orig)+ plane_d)/(DOT(plane_n,d)) |
184 |
line is l = p1 + (p2-p1)t |
185 |
186 |
187 |
t = -(DOT(plane_n,orig) + plane_d)/(DOT(plane_n,dir)); |
188 |
if(ZERO(t) || t >0) |
189 |
hit = 1; |
190 |
else |
191 |
hit = 0; |
192 |
193 |
VSUM(r,orig,dir,t); |
194 |
195 |
if(pd) |
196 |
*pd = t; |
197 |
return(hit); |
198 |
199 |
200 |
201 |
int |
202 |
point_in_cone(p,p0,p1,p2) |
203 |
FVECT p; |
204 |
FVECT p0,p1,p2; |
205 |
206 |
FVECT n; |
207 |
FVECT np,x_axis,y_axis; |
208 |
double d1,d2,d; |
209 |
210 |
/* Find the equation of the circle defined by the intersection |
211 |
of the cone with the plane defined by p1,p2,p3- project p into |
212 |
that plane and do an in-circle test in the plane |
213 |
214 |
215 |
/* find the equation of the plane defined by p1-p3 */ |
216 |
tri_plane_equation(p0,p1,p2,n,&d,FALSE); |
217 |
218 |
/* define a coordinate system on the plane: the x axis is in |
219 |
the direction of np2-np1, and the y axis is calculated from |
220 |
n cross x-axis |
221 |
222 |
/* Project p onto the plane */ |
223 |
if(!intersect_vector_plane(p,n,d,NULL,np)) |
224 |
return(FALSE); |
225 |
226 |
/* create coordinate system on plane: p2-p1 defines the x_axis*/ |
227 |
VSUB(x_axis,p1,p0); |
228 |
normalize(x_axis); |
229 |
/* The y axis is */ |
230 |
VCROSS(y_axis,n,x_axis); |
231 |
normalize(y_axis); |
232 |
233 |
VSUB(p1,p1,p0); |
234 |
VSUB(p2,p2,p0); |
235 |
VSUB(np,np,p0); |
236 |
237 |
p1[0] = VLEN(p1); |
238 |
p1[1] = 0; |
239 |
240 |
d1 = DOT(p2,x_axis); |
241 |
d2 = DOT(p2,y_axis); |
242 |
p2[0] = d1; |
243 |
p2[1] = d2; |
244 |
245 |
d1 = DOT(np,x_axis); |
246 |
d2 = DOT(np,y_axis); |
247 |
np[0] = d1; |
248 |
np[1] = d2; |
249 |
250 |
/* perform the in-circle test in the new coordinate system */ |
251 |
return(point_in_circle_thru_origin(np,p1,p2)); |
252 |
253 |
254 |
int |
255 |
test_point_against_spherical_tri(v0,v1,v2,p,n,nset,which,sides) |
256 |
FVECT v0,v1,v2,p; |
257 |
FVECT n[3]; |
258 |
char *nset; |
259 |
char *which; |
260 |
char sides[3]; |
261 |
262 |
263 |
float d; |
264 |
265 |
/* Find the normal to the triangle ORIGIN:v0:v1 */ |
266 |
if(!NTH_BIT(*nset,0)) |
267 |
268 |
VCROSS(n[0],v1,v0); |
269 |
SET_NTH_BIT(*nset,0); |
270 |
271 |
/* Test the point for sidedness */ |
272 |
d = DOT(n[0],p); |
273 |
274 |
if(ZERO(d)) |
275 |
sides[0] = GT_EDGE; |
276 |
else |
277 |
if(d > 0) |
278 |
279 |
sides[0] = GT_OUT; |
280 |
sides[1] = sides[2] = GT_INVALID; |
281 |
return(FALSE); |
282 |
283 |
else |
284 |
sides[0] = GT_INTERIOR; |
285 |
286 |
/* Test next edge */ |
287 |
if(!NTH_BIT(*nset,1)) |
288 |
289 |
VCROSS(n[1],v2,v1); |
290 |
SET_NTH_BIT(*nset,1); |
291 |
292 |
293 |
d = DOT(n[1],p); |
294 |
if(ZERO(d)) |
295 |
296 |
sides[1] = GT_EDGE; |
297 |
/* If on plane 0-and on plane 1: lies on edge */ |
298 |
if(sides[0] == GT_EDGE) |
299 |
300 |
*which = 1; |
301 |
302 |
return(GT_EDGE); |
303 |
304 |
305 |
else if(d > 0) |
306 |
307 |
sides[1] = GT_OUT; |
308 |
309 |
return(FALSE); |
310 |
311 |
else |
312 |
sides[1] = GT_INTERIOR; |
313 |
314 |
if(!NTH_BIT(*nset,2)) |
315 |
316 |
317 |
VCROSS(n[2],v0,v2); |
318 |
SET_NTH_BIT(*nset,2); |
319 |
320 |
321 |
d = DOT(n[2],p); |
322 |
if(ZERO(d)) |
323 |
324 |
sides[2] = GT_EDGE; |
325 |
326 |
/* If on plane 0 and 2: lies on edge 0*/ |
327 |
328 |
329 |
*which = 0; |
330 |
return(GT_EDGE); |
331 |
332 |
/* If on plane 1 and 2: lies on edge 2*/ |
333 |
if(sides[1] == GT_EDGE) |
334 |
335 |
*which = 2; |
336 |
return(GT_EDGE); |
337 |
338 |
/* otherwise: on face 2 */ |
339 |
else |
340 |
341 |
*which = 2; |
342 |
return(GT_FACE); |
343 |
344 |
345 |
else if(d > 0) |
346 |
347 |
sides[2] = GT_OUT; |
348 |
return(FALSE); |
349 |
350 |
/* If on edge */ |
351 |
else |
352 |
sides[2] = GT_INTERIOR; |
353 |
354 |
/* If on plane 0 only: on face 0 */ |
355 |
356 |
357 |
*which = 0; |
358 |
return(GT_FACE); |
359 |
360 |
/* If on plane 1 only: on face 1 */ |
361 |
362 |
363 |
*which = 1; |
364 |
return(GT_FACE); |
365 |
366 |
/* Must be interior to the pyramid */ |
367 |
return(GT_INTERIOR); |
368 |
369 |
370 |
371 |
372 |
373 |
int |
374 |
test_single_point_against_spherical_tri(v0,v1,v2,p,which) |
375 |
FVECT v0,v1,v2,p; |
376 |
char *which; |
377 |
378 |
float d; |
379 |
FVECT n; |
380 |
char sides[3]; |
381 |
382 |
/* First test if point coincides with any of the vertices */ |
383 |
if(EQUAL_VEC3(p,v0)) |
384 |
385 |
*which = 0; |
386 |
return(GT_VERTEX); |
387 |
388 |
if(EQUAL_VEC3(p,v1)) |
389 |
390 |
*which = 1; |
391 |
392 |
393 |
if(EQUAL_VEC3(p,v2)) |
394 |
395 |
*which = 2; |
396 |
397 |
398 |
VCROSS(n,v1,v0); |
399 |
400 |
d = DOT(n,p); |
401 |
if(ZERO(d)) |
402 |
403 |
else |
404 |
if(d > 0) |
405 |
return(FALSE); |
406 |
else |
407 |
408 |
409 |
VCROSS(n,v2,v1); |
410 |
411 |
d = DOT(n,p); |
412 |
if(ZERO(d)) |
413 |
414 |
415 |
416 |
417 |
418 |
*which = 1; |
419 |
420 |
421 |
422 |
else if(d > 0) |
423 |
return(FALSE); |
424 |
else |
425 |
426 |
427 |
428 |
VCROSS(n,v0,v2); |
429 |
430 |
d = DOT(n,p); |
431 |
if(ZERO(d)) |
432 |
433 |
434 |
435 |
436 |
437 |
438 |
*which = 0; |
439 |
440 |
441 |
442 |
443 |
444 |
*which = 2; |
445 |
446 |
447 |
448 |
else |
449 |
450 |
return(GT_FACE); |
451 |
452 |
453 |
else if(d > 0) |
454 |
return(FALSE); |
455 |
456 |
return(GT_FACE); |
457 |
458 |
459 |
int |
460 |
test_vertices_for_tri_inclusion(t0,t1,t2,p0,p1,p2,nset,n,avg,pt_sides) |
461 |
FVECT t0,t1,t2,p0,p1,p2; |
462 |
char *nset; |
463 |
FVECT n[3]; |
464 |
FVECT avg; |
465 |
char pt_sides[3][3]; |
466 |
467 |
468 |
char below_plane[3],on_edge,test; |
469 |
char which; |
470 |
471 |
SUM_3VEC3(avg,t0,t1,t2); |
472 |
on_edge = 0; |
473 |
*nset = 0; |
474 |
/* Test vertex v[i] against triangle j*/ |
475 |
/* Check if v[i] lies below plane defined by avg of 3 vectors |
476 |
defining triangle |
477 |
478 |
479 |
/* test point 0 */ |
480 |
if(DOT(avg,p0) < 0) |
481 |
below_plane[0] = 1; |
482 |
else |
483 |
below_plane[0]=0; |
484 |
/* Test if b[i] lies in or on triangle a */ |
485 |
test = test_point_against_spherical_tri(t0,t1,t2,p0, |
486 |
n,nset,&which,pt_sides[0]); |
487 |
/* If pts[i] is interior: done */ |
488 |
if(!below_plane[0]) |
489 |
490 |
if(test == GT_INTERIOR) |
491 |
return(TRUE); |
492 |
/* Remember if b[i] fell on one of the 3 defining planes */ |
493 |
if(test) |
494 |
on_edge++; |
495 |
496 |
/* Now test point 1*/ |
497 |
498 |
if(DOT(avg,p1) < 0) |
499 |
below_plane[1] = 1; |
500 |
else |
501 |
below_plane[1]=0; |
502 |
503 |
test = test_point_against_spherical_tri(t0,t1,t2,p1, |
504 |
n,nset,&which,pt_sides[1]); |
505 |
506 |
if(!below_plane[1]) |
507 |
508 |
509 |
return(TRUE); |
510 |
511 |
if(test) |
512 |
on_edge++; |
513 |
514 |
515 |
/* Now test point 2 */ |
516 |
if(DOT(avg,p2) < 0) |
517 |
below_plane[2] = 1; |
518 |
else |
519 |
below_plane[2]=0; |
520 |
521 |
test = test_point_against_spherical_tri(t0,t1,t2,p2, |
522 |
n,nset,&which,pt_sides[2]); |
523 |
524 |
525 |
if(!below_plane[2]) |
526 |
527 |
528 |
return(TRUE); |
529 |
530 |
if(test) |
531 |
on_edge++; |
532 |
533 |
534 |
/* If all three points below separating plane: trivial reject */ |
535 |
if(below_plane[0] && below_plane[1] && below_plane[2]) |
536 |
return(FALSE); |
537 |
/* Accept if all points lie on a triangle vertex/edge edge- accept*/ |
538 |
if(on_edge == 3) |
539 |
return(TRUE); |
540 |
/* Now check vertices in a against triangle b */ |
541 |
return(FALSE); |
542 |
543 |
544 |
545 |
set_sidedness_tests(t0,t1,t2,p0,p1,p2,test,sides,nset,n) |
546 |
547 |
char test[3]; |
548 |
char sides[3][3]; |
549 |
char nset; |
550 |
FVECT n[3]; |
551 |
552 |
char t; |
553 |
double d; |
554 |
555 |
556 |
/* p=0 */ |
557 |
test[0] = 0; |
558 |
if(sides[0][0] == GT_INVALID) |
559 |
560 |
if(!NTH_BIT(nset,0)) |
561 |
VCROSS(n[0],t1,t0); |
562 |
563 |
d = DOT(n[0],p0); |
564 |
if(d >= 0) |
565 |
SET_NTH_BIT(test[0],0); |
566 |
567 |
else |
568 |
if(sides[0][0] != GT_INTERIOR) |
569 |
570 |
571 |
if(sides[0][1] == GT_INVALID) |
572 |
573 |
if(!NTH_BIT(nset,1)) |
574 |
VCROSS(n[1],t2,t1); |
575 |
576 |
d = DOT(n[1],p0); |
577 |
if(d >= 0) |
578 |
SET_NTH_BIT(test[0],1); |
579 |
580 |
else |
581 |
if(sides[0][1] != GT_INTERIOR) |
582 |
583 |
584 |
if(sides[0][2] == GT_INVALID) |
585 |
586 |
if(!NTH_BIT(nset,2)) |
587 |
VCROSS(n[2],t0,t2); |
588 |
589 |
d = DOT(n[2],p0); |
590 |
if(d >= 0) |
591 |
SET_NTH_BIT(test[0],2); |
592 |
593 |
else |
594 |
if(sides[0][2] != GT_INTERIOR) |
595 |
596 |
597 |
/* p=1 */ |
598 |
test[1] = 0; |
599 |
/* t=0*/ |
600 |
if(sides[1][0] == GT_INVALID) |
601 |
602 |
603 |
604 |
605 |
d = DOT(n[0],p1); |
606 |
if(d >= 0) |
607 |
SET_NTH_BIT(test[1],0); |
608 |
609 |
else |
610 |
if(sides[1][0] != GT_INTERIOR) |
611 |
612 |
613 |
/* t=1 */ |
614 |
if(sides[1][1] == GT_INVALID) |
615 |
616 |
617 |
618 |
619 |
d = DOT(n[1],p1); |
620 |
if(d >= 0) |
621 |
SET_NTH_BIT(test[1],1); |
622 |
623 |
else |
624 |
if(sides[1][1] != GT_INTERIOR) |
625 |
626 |
627 |
/* t=2 */ |
628 |
if(sides[1][2] == GT_INVALID) |
629 |
630 |
631 |
632 |
633 |
d = DOT(n[2],p1); |
634 |
if(d >= 0) |
635 |
SET_NTH_BIT(test[1],2); |
636 |
637 |
else |
638 |
if(sides[1][2] != GT_INTERIOR) |
639 |
640 |
641 |
/* p=2 */ |
642 |
test[2] = 0; |
643 |
/* t = 0 */ |
644 |
if(sides[2][0] == GT_INVALID) |
645 |
646 |
647 |
648 |
649 |
d = DOT(n[0],p2); |
650 |
if(d >= 0) |
651 |
SET_NTH_BIT(test[2],0); |
652 |
653 |
else |
654 |
if(sides[2][0] != GT_INTERIOR) |
655 |
656 |
/* t=1 */ |
657 |
if(sides[2][1] == GT_INVALID) |
658 |
659 |
660 |
661 |
662 |
d = DOT(n[1],p2); |
663 |
if(d >= 0) |
664 |
SET_NTH_BIT(test[2],1); |
665 |
666 |
else |
667 |
if(sides[2][1] != GT_INTERIOR) |
668 |
669 |
/* t=2 */ |
670 |
if(sides[2][2] == GT_INVALID) |
671 |
672 |
673 |
674 |
675 |
d = DOT(n[2],p2); |
676 |
if(d >= 0) |
677 |
SET_NTH_BIT(test[2],2); |
678 |
679 |
else |
680 |
if(sides[2][2] != GT_INTERIOR) |
681 |
682 |
683 |
684 |
685 |
int |
686 |
spherical_tri_intersect(a1,a2,a3,b1,b2,b3) |
687 |
FVECT a1,a2,a3,b1,b2,b3; |
688 |
689 |
char which,test,n_set[2]; |
690 |
char sides[2][3][3],i,j,inext,jnext; |
691 |
char tests[2][3]; |
692 |
FVECT n[2][3],p,avg[2]; |
693 |
694 |
/* Test the vertices of triangle a against the pyramid formed by triangle |
695 |
b and the origin. If any vertex of a is interior to triangle b, or |
696 |
if all 3 vertices of a are ON the edges of b,return TRUE. Remember |
697 |
the results of the edge normal and sidedness tests for later. |
698 |
699 |
if(test_vertices_for_tri_inclusion(a1,a2,a3,b1,b2,b3, |
700 |
&(n_set[0]),n[0],avg[0],sides[1])) |
701 |
return(TRUE); |
702 |
703 |
if(test_vertices_for_tri_inclusion(b1,b2,b3,a1,a2,a3, |
704 |
&(n_set[1]),n[1],avg[1],sides[0])) |
705 |
return(TRUE); |
706 |
707 |
708 |
set_sidedness_tests(b1,b2,b3,a1,a2,a3,tests[0],sides[0],n_set[1],n[1]); |
709 |
if(tests[0][0]&tests[0][1]&tests[0][2]) |
710 |
return(FALSE); |
711 |
712 |
set_sidedness_tests(a1,a2,a3,b1,b2,b3,tests[1],sides[1],n_set[0],n[0]); |
713 |
if(tests[1][0]&tests[1][1]&tests[1][2]) |
714 |
return(FALSE); |
715 |
716 |
for(j=0; j < 3;j++) |
717 |
718 |
jnext = (j+1)%3; |
719 |
/* IF edge b doesnt cross any great circles of a, punt */ |
720 |
if(tests[1][j] & tests[1][jnext]) |
721 |
continue; |
722 |
for(i=0;i<3;i++) |
723 |
724 |
inext = (i+1)%3; |
725 |
/* IF edge a doesnt cross any great circles of b, punt */ |
726 |
if(tests[0][i] & tests[0][inext]) |
727 |
continue; |
728 |
/* Now find the great circles that cross and test */ |
729 |
if((NTH_BIT(tests[0][i],j)^(NTH_BIT(tests[0][inext],j))) |
730 |
&& (NTH_BIT(tests[1][j],i)^NTH_BIT(tests[1][jnext],i))) |
731 |
732 |
VCROSS(p,n[0][i],n[1][j]); |
733 |
734 |
/* If zero cp= done */ |
735 |
if(ZERO_VEC3(p)) |
736 |
continue; |
737 |
/* check above both planes */ |
738 |
if(DOT(avg[0],p) < 0 || DOT(avg[1],p) < 0) |
739 |
740 |
NEGATE_VEC3(p); |
741 |
742 |
continue; |
743 |
744 |
return(TRUE); |
745 |
746 |
747 |
748 |
return(FALSE); |
749 |
750 |
751 |
int |
752 |
ray_intersect_tri(orig,dir,v0,v1,v2,pt,wptr) |
753 |
FVECT orig,dir; |
754 |
FVECT v0,v1,v2; |
755 |
FVECT pt; |
756 |
char *wptr; |
757 |
758 |
FVECT p0,p1,p2,p,n; |
759 |
char type,which; |
760 |
double pd; |
761 |
762 |
point_on_sphere(p0,v0,orig); |
763 |
point_on_sphere(p1,v1,orig); |
764 |
point_on_sphere(p2,v2,orig); |
765 |
type = test_single_point_against_spherical_tri(p0,p1,p2,dir,&which); |
766 |
767 |
if(type) |
768 |
769 |
/* Intersect the ray with the triangle plane */ |
770 |
tri_plane_equation(v0,v1,v2,n,&pd,FALSE); |
771 |
intersect_ray_plane(orig,dir,n,pd,NULL,pt); |
772 |
773 |
if(wptr) |
774 |
*wptr = which; |
775 |
776 |
return(type); |
777 |
778 |
779 |
780 |
calculate_view_frustum(vp,hv,vv,horiz,vert,near,far,fnear,ffar) |
781 |
FVECT vp,hv,vv; |
782 |
double horiz,vert,near,far; |
783 |
FVECT fnear[4],ffar[4]; |
784 |
785 |
double height,width; |
786 |
FVECT t,nhv,nvv,ndv; |
787 |
double w2,h2; |
788 |
/* Calculate the x and y dimensions of the near face */ |
789 |
/* hv and vv are the horizontal and vertical vectors in the |
790 |
view frame-the magnitude is the dimension of the front frustum |
791 |
face at z =1 |
792 |
793 |
VCOPY(nhv,hv); |
794 |
VCOPY(nvv,vv); |
795 |
w2 = normalize(nhv); |
796 |
h2 = normalize(nvv); |
797 |
/* Use similar triangles to calculate the dimensions at z=near */ |
798 |
width = near*0.5*w2; |
799 |
height = near*0.5*h2; |
800 |
801 |
VCROSS(ndv,nvv,nhv); |
802 |
/* Calculate the world space points corresponding to the 4 corners |
803 |
of the front face of the view frustum |
804 |
805 |
fnear[0][0] = width*nhv[0] + height*nvv[0] + near*ndv[0] + vp[0] ; |
806 |
fnear[0][1] = width*nhv[1] + height*nvv[1] + near*ndv[1] + vp[1]; |
807 |
fnear[0][2] = width*nhv[2] + height*nvv[2] + near*ndv[2] + vp[2]; |
808 |
fnear[1][0] = -width*nhv[0] + height*nvv[0] + near*ndv[0] + vp[0]; |
809 |
fnear[1][1] = -width*nhv[1] + height*nvv[1] + near*ndv[1] + vp[1]; |
810 |
fnear[1][2] = -width*nhv[2] + height*nvv[2] + near*ndv[2] + vp[2]; |
811 |
fnear[2][0] = -width*nhv[0] - height*nvv[0] + near*ndv[0] + vp[0]; |
812 |
fnear[2][1] = -width*nhv[1] - height*nvv[1] + near*ndv[1] + vp[1]; |
813 |
fnear[2][2] = -width*nhv[2] - height*nvv[2] + near*ndv[2] + vp[2]; |
814 |
fnear[3][0] = width*nhv[0] - height*nvv[0] + near*ndv[0] + vp[0]; |
815 |
fnear[3][1] = width*nhv[1] - height*nvv[1] + near*ndv[1] + vp[1]; |
816 |
fnear[3][2] = width*nhv[2] - height*nvv[2] + near*ndv[2] + vp[2]; |
817 |
818 |
/* Now do the far face */ |
819 |
width = far*0.5*w2; |
820 |
height = far*0.5*h2; |
821 |
ffar[0][0] = width*nhv[0] + height*nvv[0] + far*ndv[0] + vp[0] ; |
822 |
ffar[0][1] = width*nhv[1] + height*nvv[1] + far*ndv[1] + vp[1] ; |
823 |
ffar[0][2] = width*nhv[2] + height*nvv[2] + far*ndv[2] + vp[2] ; |
824 |
ffar[1][0] = -width*nhv[0] + height*nvv[0] + far*ndv[0] + vp[0] ; |
825 |
ffar[1][1] = -width*nhv[1] + height*nvv[1] + far*ndv[1] + vp[1] ; |
826 |
ffar[1][2] = -width*nhv[2] + height*nvv[2] + far*ndv[2] + vp[2] ; |
827 |
ffar[2][0] = -width*nhv[0] - height*nvv[0] + far*ndv[0] + vp[0] ; |
828 |
ffar[2][1] = -width*nhv[1] - height*nvv[1] + far*ndv[1] + vp[1] ; |
829 |
ffar[2][2] = -width*nhv[2] - height*nvv[2] + far*ndv[2] + vp[2] ; |
830 |
ffar[3][0] = width*nhv[0] - height*nvv[0] + far*ndv[0] + vp[0] ; |
831 |
ffar[3][1] = width*nhv[1] - height*nvv[1] + far*ndv[1] + vp[1] ; |
832 |
ffar[3][2] = width*nhv[2] - height*nvv[2] + far*ndv[2] + vp[2] ; |
833 |
834 |
835 |
836 |
837 |
838 |
int |
839 |
spherical_polygon_edge_intersect(a0,a1,b0,b1) |
840 |
FVECT a0,a1,b0,b1; |
841 |
842 |
FVECT na,nb,avga,avgb,p; |
843 |
double d; |
844 |
int sb0,sb1,sa0,sa1; |
845 |
846 |
/* First test if edge b straddles great circle of a */ |
847 |
VCROSS(na,a0,a1); |
848 |
d = DOT(na,b0); |
849 |
sb0 = ZERO(d)?0:(d<0)? -1: 1; |
850 |
d = DOT(na,b1); |
851 |
sb1 = ZERO(d)?0:(d<0)? -1: 1; |
852 |
/* edge b entirely on one side of great circle a: edges cannot intersect*/ |
853 |
if(sb0*sb1 > 0) |
854 |
return(FALSE); |
855 |
/* test if edge a straddles great circle of b */ |
856 |
VCROSS(nb,b0,b1); |
857 |
d = DOT(nb,a0); |
858 |
sa0 = ZERO(d)?0:(d<0)? -1: 1; |
859 |
d = DOT(nb,a1); |
860 |
sa1 = ZERO(d)?0:(d<0)? -1: 1; |
861 |
/* edge a entirely on one side of great circle b: edges cannot intersect*/ |
862 |
if(sa0*sa1 > 0) |
863 |
return(FALSE); |
864 |
865 |
/* Find one of intersection points of the great circles */ |
866 |
VCROSS(p,na,nb); |
867 |
/* If they lie on same great circle: call an intersection */ |
868 |
if(ZERO_VEC3(p)) |
869 |
return(TRUE); |
870 |
871 |
VADD(avga,a0,a1); |
872 |
VADD(avgb,b0,b1); |
873 |
if(DOT(avga,p) < 0 || DOT(avgb,p) < 0) |
874 |
875 |
NEGATE_VEC3(p); |
876 |
877 |
return(FALSE); |
878 |
879 |
if((!sb0 || !sb1) && (!sa0 || !sa1)) |
880 |
return(FALSE); |
881 |
return(TRUE); |
882 |
883 |
884 |
885 |
886 |
/* Find the normalized barycentric coordinates of p relative to |
887 |
* triangle v0,v1,v2. Return result in coord |
888 |
889 |
bary2d(x1,y1,x2,y2,x3,y3,px,py,coord) |
890 |
double x1,y1,x2,y2,x3,y3; |
891 |
double px,py; |
892 |
double coord[3]; |
893 |
894 |
double a; |
895 |
896 |
a = (x2 - x1) * (y3 - y1) - (x3 - x1) * (y2 - y1); |
897 |
coord[0] = ((x2 - px) * (y3 - py) - (x3 - px) * (y2 - py)) / a; |
898 |
coord[1] = ((x3 - px) * (y1 - py) - (x1 - px) * (y3 - py)) / a; |
899 |
coord[2] = 1.0 - coord[0] - coord[1]; |
900 |
901 |
902 |
903 |
int |
904 |
bary2d_child(coord) |
905 |
double coord[3]; |
906 |
907 |
int i; |
908 |
909 |
/* First check if one of the original vertices */ |
910 |
for(i=0;i<3;i++) |
911 |
if(EQUAL(coord[i],1.0)) |
912 |
return(i); |
913 |
914 |
/* Check if one of the new vertices: for all return center child */ |
915 |
if(ZERO(coord[0]) && EQUAL(coord[1],0.5)) |
916 |
917 |
coord[0] = 1.0f; |
918 |
coord[1] = 0.0f; |
919 |
coord[2] = 0.0f; |
920 |
return(3); |
921 |
922 |
if(ZERO(coord[1]) && EQUAL(coord[0],0.5)) |
923 |
924 |
coord[0] = 0.0f; |
925 |
coord[1] = 1.0f; |
926 |
coord[2] = 0.0f; |
927 |
return(3); |
928 |
929 |
if(ZERO(coord[2]) && EQUAL(coord[0],0.5)) |
930 |
931 |
coord[0] = 0.0f; |
932 |
coord[1] = 0.0f; |
933 |
coord[2] = 1.0f; |
934 |
return(3); |
935 |
936 |
937 |
/* Otherwise return child */ |
938 |
if(coord[0] > 0.5) |
939 |
940 |
/* update bary for child */ |
941 |
coord[0] = 2.0*coord[0]- 1.0; |
942 |
coord[1] *= 2.0; |
943 |
coord[2] *= 2.0; |
944 |
return(0); |
945 |
946 |
else |
947 |
if(coord[1] > 0.5) |
948 |
949 |
coord[0] *= 2.0; |
950 |
coord[1] = 2.0*coord[1]- 1.0; |
951 |
coord[2] *= 2.0; |
952 |
return(1); |
953 |
954 |
else |
955 |
if(coord[2] > 0.5) |
956 |
957 |
coord[0] *= 2.0; |
958 |
coord[1] *= 2.0; |
959 |
coord[2] = 2.0*coord[2]- 1.0; |
960 |
return(2); |
961 |
962 |
else |
963 |
964 |
coord[0] = 1.0 - 2.0*coord[0]; |
965 |
coord[1] = 1.0 - 2.0*coord[1]; |
966 |
coord[2] = 1.0 - 2.0*coord[2]; |
967 |
return(3); |
968 |
969 |
970 |
971 |
int |
972 |
max_index(v) |
973 |
FVECT v; |
974 |
975 |
double a,b,c; |
976 |
int i; |
977 |
978 |
a = fabs(v[0]); |
979 |
b = fabs(v[1]); |
980 |
c = fabs(v[2]); |
981 |
i = (a>=b)?((a>=c)?0:2):((b>=c)?1:2); |
982 |
return(i); |
983 |
984 |
985 |
986 |
987 |
988 |
* int |
989 |
* smRay(FVECT orig, FVECT dir,FVECT v0,FVECT v1,FVECT v2,FVECT r) |
990 |
991 |
* Intersect the ray with triangle v0v1v2, return intersection point in r |
992 |
993 |
* Assumes orig,v0,v1,v2 are in spherical coordinates, and orig is |
994 |
* unit |
995 |
996 |
int |
997 |
traceRay(orig,dir,v0,v1,v2,r) |
998 |
FVECT orig,dir; |
999 |
FVECT v0,v1,v2; |
1000 |
FVECT r; |
1001 |
1002 |
FVECT n,p[3],d; |
1003 |
double pt[3],r_eps; |
1004 |
char i; |
1005 |
int which; |
1006 |
1007 |
/* Find the plane equation for the triangle defined by the edge v0v1 and |
1008 |
the view center*/ |
1009 |
VCROSS(n,v0,v1); |
1010 |
/* Intersect the ray with this plane */ |
1011 |
i = intersect_ray_plane(orig,dir,n,0.0,&(pt[0]),p[0]); |
1012 |
if(i) |
1013 |
which = 0; |
1014 |
else |
1015 |
which = -1; |
1016 |
1017 |
VCROSS(n,v1,v2); |
1018 |
i = intersect_ray_plane(orig,dir,n,0.0,&(pt[1]),p[1]); |
1019 |
if(i) |
1020 |
if((which==-1) || pt[1] < pt[0]) |
1021 |
which = 1; |
1022 |
1023 |
VCROSS(n,v2,v0); |
1024 |
i = intersect_ray_plane(orig,dir,n,0.0,&(pt[2]),p[2]); |
1025 |
if(i) |
1026 |
if((which==-1) || pt[2] < pt[which]) |
1027 |
which = 2; |
1028 |
1029 |
if(which != -1) |
1030 |
1031 |
/* Return point that is K*eps along projection of the ray on |
1032 |
the sphere to push intersection point p[which] into next cell |
1033 |
1034 |
normalize(p[which]); |
1035 |
/* Calculate the ray perpendicular to the intersection point: approx |
1036 |
the direction moved along the sphere a distance of K*epsilon*/ |
1037 |
r_eps = -DOT(p[which],dir); |
1038 |
VSUM(n,dir,p[which],r_eps); |
1039 |
/* Calculate the length along ray p[which]-dir needed to move to |
1040 |
cause a move along the sphere of k*epsilon |
1041 |
1042 |
r_eps = DOT(n,dir); |
1043 |
VSUM(r,p[which],dir,(20*FTINY)/r_eps); |
1044 |
normalize(r); |
1045 |
return(TRUE); |
1046 |
1047 |
else |
1048 |
1049 |
/* Unable to find intersection: move along ray and try again */ |
1050 |
r_eps = -DOT(orig,dir); |
1051 |
VSUM(n,dir,orig,r_eps); |
1052 |
1053 |
VSUM(r,orig,dir,(20*FTINY)/r_eps); |
1054 |
normalize(r); |
1055 |
#ifdef DEBUG |
1056 |
eputs("traceRay:Ray does not intersect triangle"); |
1057 |
#endif |
1058 |
return(FALSE); |
1059 |
1060 |
1061 |
1062 |
1063 |
1064 |
1065 |
1066 |
1067 |
1068 |
1069 |
