root/radiance/ray/src/hd/sm_geom.c
Revision: 3.11
Committed: Sun Jan 10 10:27:47 1999 UTC (25 years, 3 months ago) by gwlarson
Changes since 3.10: +0 -0 lines
sm.c, sm_del.c sm_ogl.c sm.h
Fixed failure to tone-map on start up
added code for temporary buffer allocation
added bg flag, and fast flag checking routines for drawing
provided graceful backout if deletion triangulation fails
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * sm_geom.c
9 */
10
11 #include "standard.h"
12 #include "sm_geom.h"
13
14 tri_centroid(v0,v1,v2,c)
15 FVECT v0,v1,v2,c;
16 {
17 /* Average three triangle vertices to give centroid: return in c */
18 c[0] = (v0[0] + v1[0] + v2[0])/3.0;
19 c[1] = (v0[1] + v1[1] + v2[1])/3.0;
20 c[2] = (v0[2] + v1[2] + v2[2])/3.0;
21 }
22
23
24 int
25 vec3_equal(v1,v2)
26 FVECT v1,v2;
27 {
28 return(EQUAL(v1[0],v2[0]) && EQUAL(v1[1],v2[1])&& EQUAL(v1[2],v2[2]));
29 }
30 #if 0
31 extern FVECT Norm[500];
32 extern int Ncnt;
33 #endif
34
35 int
36 convex_angle(v0,v1,v2)
37 FVECT v0,v1,v2;
38 {
39 FVECT cp,cp01,cp12,v10,v02;
40 double dp;
41
42 /* test sign of (v0Xv1)X(v1Xv2). v1 */
43 VCROSS(cp01,v0,v1);
44 VCROSS(cp12,v1,v2);
45 VCROSS(cp,cp01,cp12);
46
47 dp = DOT(cp,v1);
48 #if 0
49 VCOPY(Norm[Ncnt++],cp01);
50 VCOPY(Norm[Ncnt++],cp12);
51 VCOPY(Norm[Ncnt++],cp);
52 #endif
53 if(ZERO(dp) || dp < 0.0)
54 return(FALSE);
55 return(TRUE);
56 }
57
58 /* calculates the normal of a face contour using Newell's formula. e
59
60 a = SUMi (yi - yi+1)(zi + zi+1);
61 b = SUMi (zi - zi+1)(xi + xi+1)
62 c = SUMi (xi - xi+1)(yi + yi+1)
63 */
64 double
65 tri_normal(v0,v1,v2,n,norm)
66 FVECT v0,v1,v2,n;
67 int norm;
68 {
69 double mag;
70
71 n[0] = (v0[2] + v1[2]) * (v0[1] - v1[1]) +
72 (v1[2] + v2[2]) * (v1[1] - v2[1]) +
73 (v2[2] + v0[2]) * (v2[1] - v0[1]);
74
75 n[1] = (v0[2] - v1[2]) * (v0[0] + v1[0]) +
76 (v1[2] - v2[2]) * (v1[0] + v2[0]) +
77 (v2[2] - v0[2]) * (v2[0] + v0[0]);
78
79 n[2] = (v0[1] + v1[1]) * (v0[0] - v1[0]) +
80 (v1[1] + v2[1]) * (v1[0] - v2[0]) +
81 (v2[1] + v0[1]) * (v2[0] - v0[0]);
82
83 if(!norm)
84 return(0);
85
86 mag = normalize(n);
87
88 return(mag);
89 }
90
91
92 tri_plane_equation(v0,v1,v2,peqptr,norm)
93 FVECT v0,v1,v2;
94 FPEQ *peqptr;
95 int norm;
96 {
97 tri_normal(v0,v1,v2,FP_N(*peqptr),norm);
98
99 FP_D(*peqptr) = -(DOT(FP_N(*peqptr),v0));
100 }
101
102 /* From quad_edge-code */
103 int
104 point_in_circle_thru_origin(p,p0,p1)
105 FVECT p;
106 FVECT p0,p1;
107 {
108
109 double dp0,dp1;
110 double dp,det;
111
112 dp0 = DOT_VEC2(p0,p0);
113 dp1 = DOT_VEC2(p1,p1);
114 dp = DOT_VEC2(p,p);
115
116 det = -dp0*CROSS_VEC2(p1,p) + dp1*CROSS_VEC2(p0,p) - dp*CROSS_VEC2(p0,p1);
117
118 return (det > (1e-10));
119 }
120
121
122 double
123 point_on_sphere(ps,p,c)
124 FVECT ps,p,c;
125 {
126 double d;
127 VSUB(ps,p,c);
128 d= normalize(ps);
129 return(d);
130 }
131
132
133 /* returns TRUE if ray from origin in direction v intersects plane defined
134 * by normal plane_n, and plane_d. If plane is not parallel- returns
135 * intersection point if r != NULL. If tptr!= NULL returns value of
136 * t, if parallel, returns t=FHUGE
137 */
138 int
139 intersect_vector_plane(v,peq,tptr,r)
140 FVECT v;
141 FPEQ peq;
142 double *tptr;
143 FVECT r;
144 {
145 double t,d;
146 int hit;
147 /*
148 Plane is Ax + By + Cz +D = 0:
149 plane[0] = A,plane[1] = B,plane[2] = C,plane[3] = D
150 */
151
152 /* line is l = p1 + (p2-p1)t, p1=origin */
153
154 /* Solve for t: */
155 d = -(DOT(FP_N(peq),v));
156 if(ZERO(d))
157 {
158 t = FHUGE;
159 hit = 0;
160 }
161 else
162 {
163 t = FP_D(peq)/d;
164 if(t < 0 )
165 hit = 0;
166 else
167 hit = 1;
168 if(r)
169 {
170 r[0] = v[0]*t;
171 r[1] = v[1]*t;
172 r[2] = v[2]*t;
173 }
174 }
175 if(tptr)
176 *tptr = t;
177 return(hit);
178 }
179
180 int
181 intersect_ray_plane(orig,dir,peq,pd,r)
182 FVECT orig,dir;
183 FPEQ peq;
184 double *pd;
185 FVECT r;
186 {
187 double t,d;
188 int hit;
189 /*
190 Plane is Ax + By + Cz +D = 0:
191 plane[0] = A,plane[1] = B,plane[2] = C,plane[3] = D
192 */
193 /* A(orig[0] + dxt) + B(orig[1] + dyt) + C(orig[2] + dzt) + pd = 0
194 t = -(DOT(plane_n,orig)+ plane_d)/(DOT(plane_n,d))
195 line is l = p1 + (p2-p1)t
196 */
197 /* Solve for t: */
198 d = DOT(FP_N(peq),dir);
199 if(ZERO(d))
200 return(0);
201 t = -(DOT(FP_N(peq),orig) + FP_D(peq))/d;
202
203 if(t < 0)
204 hit = 0;
205 else
206 hit = 1;
207
208 if(r)
209 VSUM(r,orig,dir,t);
210
211 if(pd)
212 *pd = t;
213 return(hit);
214 }
215
216
217 int
218 intersect_ray_oplane(orig,dir,n,pd,r)
219 FVECT orig,dir;
220 FVECT n;
221 double *pd;
222 FVECT r;
223 {
224 double t,d;
225 int hit;
226 /*
227 Plane is Ax + By + Cz +D = 0:
228 plane[0] = A,plane[1] = B,plane[2] = C,plane[3] = D
229 */
230 /* A(orig[0] + dxt) + B(orig[1] + dyt) + C(orig[2] + dzt) + pd = 0
231 t = -(DOT(plane_n,orig)+ plane_d)/(DOT(plane_n,d))
232 line is l = p1 + (p2-p1)t
233 */
234 /* Solve for t: */
235 d= DOT(n,dir);
236 if(ZERO(d))
237 return(0);
238 t = -(DOT(n,orig))/d;
239 if(t < 0)
240 hit = 0;
241 else
242 hit = 1;
243
244 if(r)
245 VSUM(r,orig,dir,t);
246
247 if(pd)
248 *pd = t;
249 return(hit);
250 }
251
252 /* Assumption: know crosses plane:dont need to check for 'on' case */
253 intersect_edge_coord_plane(v0,v1,w,r)
254 FVECT v0,v1;
255 int w;
256 FVECT r;
257 {
258 FVECT dv;
259 int wnext;
260 double t;
261
262 VSUB(dv,v1,v0);
263 t = -v0[w]/dv[w];
264 r[w] = 0.0;
265 wnext = (w+1)%3;
266 r[wnext] = v0[wnext] + dv[wnext]*t;
267 wnext = (w+2)%3;
268 r[wnext] = v0[wnext] + dv[wnext]*t;
269 }
270
271 int
272 intersect_edge_plane(e0,e1,peq,pd,r)
273 FVECT e0,e1;
274 FPEQ peq;
275 double *pd;
276 FVECT r;
277 {
278 double t;
279 int hit;
280 FVECT d;
281 /*
282 Plane is Ax + By + Cz +D = 0:
283 plane[0] = A,plane[1] = B,plane[2] = C,plane[3] = D
284 */
285 /* A(orig[0] + dxt) + B(orig[1] + dyt) + C(orig[2] + dzt) + pd = 0
286 t = -(DOT(plane_n,orig)+ plane_d)/(DOT(plane_n,d))
287 line is l = p1 + (p2-p1)t
288 */
289 /* Solve for t: */
290 VSUB(d,e1,e0);
291 t = -(DOT(FP_N(peq),e0) + FP_D(peq))/(DOT(FP_N(peq),d));
292 if(t < 0)
293 hit = 0;
294 else
295 hit = 1;
296
297 VSUM(r,e0,d,t);
298
299 if(pd)
300 *pd = t;
301 return(hit);
302 }
303
304
305 int
306 point_in_cone(p,p0,p1,p2)
307 FVECT p;
308 FVECT p0,p1,p2;
309 {
310 FVECT np,x_axis,y_axis;
311 double d1,d2;
312 FPEQ peq;
313
314 /* Find the equation of the circle defined by the intersection
315 of the cone with the plane defined by p1,p2,p3- project p into
316 that plane and do an in-circle test in the plane
317 */
318
319 /* find the equation of the plane defined by p0-p2 */
320 tri_plane_equation(p0,p1,p2,&peq,FALSE);
321
322 /* define a coordinate system on the plane: the x axis is in
323 the direction of np2-np1, and the y axis is calculated from
324 n cross x-axis
325 */
326 /* Project p onto the plane */
327 /* NOTE: check this: does sideness check?*/
328 if(!intersect_vector_plane(p,peq,NULL,np))
329 return(FALSE);
330
331 /* create coordinate system on plane: p1-p0 defines the x_axis*/
332 VSUB(x_axis,p1,p0);
333 normalize(x_axis);
334 /* The y axis is */
335 VCROSS(y_axis,FP_N(peq),x_axis);
336 normalize(y_axis);
337
338 VSUB(p1,p1,p0);
339 VSUB(p2,p2,p0);
340 VSUB(np,np,p0);
341
342 p1[0] = DOT(p1,x_axis);
343 p1[1] = 0;
344
345 d1 = DOT(p2,x_axis);
346 d2 = DOT(p2,y_axis);
347 p2[0] = d1;
348 p2[1] = d2;
349
350 d1 = DOT(np,x_axis);
351 d2 = DOT(np,y_axis);
352 np[0] = d1;
353 np[1] = d2;
354
355 /* perform the in-circle test in the new coordinate system */
356 return(point_in_circle_thru_origin(np,p1,p2));
357 }
358
359 int
360 point_set_in_stri(v0,v1,v2,p,n,nset,sides)
361 FVECT v0,v1,v2,p;
362 FVECT n[3];
363 int *nset;
364 int sides[3];
365
366 {
367 double d;
368 /* Find the normal to the triangle ORIGIN:v0:v1 */
369 if(!NTH_BIT(*nset,0))
370 {
371 VCROSS(n[0],v0,v1);
372 SET_NTH_BIT(*nset,0);
373 }
374 /* Test the point for sidedness */
375 d = DOT(n[0],p);
376
377 if(d > 0.0)
378 {
379 sides[0] = GT_OUT;
380 sides[1] = sides[2] = GT_INVALID;
381 return(FALSE);
382 }
383 else
384 sides[0] = GT_INTERIOR;
385
386 /* Test next edge */
387 if(!NTH_BIT(*nset,1))
388 {
389 VCROSS(n[1],v1,v2);
390 SET_NTH_BIT(*nset,1);
391 }
392 /* Test the point for sidedness */
393 d = DOT(n[1],p);
394 if(d > 0.0)
395 {
396 sides[1] = GT_OUT;
397 sides[2] = GT_INVALID;
398 return(FALSE);
399 }
400 else
401 sides[1] = GT_INTERIOR;
402 /* Test next edge */
403 if(!NTH_BIT(*nset,2))
404 {
405 VCROSS(n[2],v2,v0);
406 SET_NTH_BIT(*nset,2);
407 }
408 /* Test the point for sidedness */
409 d = DOT(n[2],p);
410 if(d > 0.0)
411 {
412 sides[2] = GT_OUT;
413 return(FALSE);
414 }
415 else
416 sides[2] = GT_INTERIOR;
417 /* Must be interior to the pyramid */
418 return(GT_INTERIOR);
419 }
420
421
422
423
424 int
425 point_in_stri(v0,v1,v2,p)
426 FVECT v0,v1,v2,p;
427 {
428 double d;
429 FVECT n;
430
431 VCROSS(n,v0,v1);
432 /* Test the point for sidedness */
433 d = DOT(n,p);
434 if(d > 0.0)
435 return(FALSE);
436
437 /* Test next edge */
438 VCROSS(n,v1,v2);
439 /* Test the point for sidedness */
440 d = DOT(n,p);
441 if(d > 0.0)
442 return(FALSE);
443
444 /* Test next edge */
445 VCROSS(n,v2,v0);
446 /* Test the point for sidedness */
447 d = DOT(n,p);
448 if(d > 0.0)
449 return(FALSE);
450 /* Must be interior to the pyramid */
451 return(GT_INTERIOR);
452 }
453
454 int
455 vertices_in_stri(t0,t1,t2,p0,p1,p2,nset,n,avg,pt_sides)
456 FVECT t0,t1,t2,p0,p1,p2;
457 int *nset;
458 FVECT n[3];
459 FVECT avg;
460 int pt_sides[3][3];
461
462 {
463 int below_plane[3],test;
464
465 SUM_3VEC3(avg,t0,t1,t2);
466 *nset = 0;
467 /* Test vertex v[i] against triangle j*/
468 /* Check if v[i] lies below plane defined by avg of 3 vectors
469 defining triangle
470 */
471
472 /* test point 0 */
473 if(DOT(avg,p0) < 0.0)
474 below_plane[0] = 1;
475 else
476 below_plane[0] = 0;
477 /* Test if b[i] lies in or on triangle a */
478 test = point_set_in_stri(t0,t1,t2,p0,n,nset,pt_sides[0]);
479 /* If pts[i] is interior: done */
480 if(!below_plane[0])
481 {
482 if(test == GT_INTERIOR)
483 return(TRUE);
484 }
485 /* Now test point 1*/
486
487 if(DOT(avg,p1) < 0.0)
488 below_plane[1] = 1;
489 else
490 below_plane[1]=0;
491 /* Test if b[i] lies in or on triangle a */
492 test = point_set_in_stri(t0,t1,t2,p1,n,nset,pt_sides[1]);
493 /* If pts[i] is interior: done */
494 if(!below_plane[1])
495 {
496 if(test == GT_INTERIOR)
497 return(TRUE);
498 }
499
500 /* Now test point 2 */
501 if(DOT(avg,p2) < 0.0)
502 below_plane[2] = 1;
503 else
504 below_plane[2] = 0;
505 /* Test if b[i] lies in or on triangle a */
506 test = point_set_in_stri(t0,t1,t2,p2,n,nset,pt_sides[2]);
507
508 /* If pts[i] is interior: done */
509 if(!below_plane[2])
510 {
511 if(test == GT_INTERIOR)
512 return(TRUE);
513 }
514
515 /* If all three points below separating plane: trivial reject */
516 if(below_plane[0] && below_plane[1] && below_plane[2])
517 return(FALSE);
518 /* Now check vertices in a against triangle b */
519 return(FALSE);
520 }
521
522
523 set_sidedness_tests(t0,t1,t2,p0,p1,p2,test,sides,nset,n)
524 FVECT t0,t1,t2,p0,p1,p2;
525 int test[3];
526 int sides[3][3];
527 int nset;
528 FVECT n[3];
529 {
530 int t;
531 double d;
532
533
534 /* p=0 */
535 test[0] = 0;
536 if(sides[0][0] == GT_INVALID)
537 {
538 if(!NTH_BIT(nset,0))
539 VCROSS(n[0],t0,t1);
540 /* Test the point for sidedness */
541 d = DOT(n[0],p0);
542 if(d >= 0.0)
543 SET_NTH_BIT(test[0],0);
544 }
545 else
546 if(sides[0][0] != GT_INTERIOR)
547 SET_NTH_BIT(test[0],0);
548
549 if(sides[0][1] == GT_INVALID)
550 {
551 if(!NTH_BIT(nset,1))
552 VCROSS(n[1],t1,t2);
553 /* Test the point for sidedness */
554 d = DOT(n[1],p0);
555 if(d >= 0.0)
556 SET_NTH_BIT(test[0],1);
557 }
558 else
559 if(sides[0][1] != GT_INTERIOR)
560 SET_NTH_BIT(test[0],1);
561
562 if(sides[0][2] == GT_INVALID)
563 {
564 if(!NTH_BIT(nset,2))
565 VCROSS(n[2],t2,t0);
566 /* Test the point for sidedness */
567 d = DOT(n[2],p0);
568 if(d >= 0.0)
569 SET_NTH_BIT(test[0],2);
570 }
571 else
572 if(sides[0][2] != GT_INTERIOR)
573 SET_NTH_BIT(test[0],2);
574
575 /* p=1 */
576 test[1] = 0;
577 /* t=0*/
578 if(sides[1][0] == GT_INVALID)
579 {
580 if(!NTH_BIT(nset,0))
581 VCROSS(n[0],t0,t1);
582 /* Test the point for sidedness */
583 d = DOT(n[0],p1);
584 if(d >= 0.0)
585 SET_NTH_BIT(test[1],0);
586 }
587 else
588 if(sides[1][0] != GT_INTERIOR)
589 SET_NTH_BIT(test[1],0);
590
591 /* t=1 */
592 if(sides[1][1] == GT_INVALID)
593 {
594 if(!NTH_BIT(nset,1))
595 VCROSS(n[1],t1,t2);
596 /* Test the point for sidedness */
597 d = DOT(n[1],p1);
598 if(d >= 0.0)
599 SET_NTH_BIT(test[1],1);
600 }
601 else
602 if(sides[1][1] != GT_INTERIOR)
603 SET_NTH_BIT(test[1],1);
604
605 /* t=2 */
606 if(sides[1][2] == GT_INVALID)
607 {
608 if(!NTH_BIT(nset,2))
609 VCROSS(n[2],t2,t0);
610 /* Test the point for sidedness */
611 d = DOT(n[2],p1);
612 if(d >= 0.0)
613 SET_NTH_BIT(test[1],2);
614 }
615 else
616 if(sides[1][2] != GT_INTERIOR)
617 SET_NTH_BIT(test[1],2);
618
619 /* p=2 */
620 test[2] = 0;
621 /* t = 0 */
622 if(sides[2][0] == GT_INVALID)
623 {
624 if(!NTH_BIT(nset,0))
625 VCROSS(n[0],t0,t1);
626 /* Test the point for sidedness */
627 d = DOT(n[0],p2);
628 if(d >= 0.0)
629 SET_NTH_BIT(test[2],0);
630 }
631 else
632 if(sides[2][0] != GT_INTERIOR)
633 SET_NTH_BIT(test[2],0);
634 /* t=1 */
635 if(sides[2][1] == GT_INVALID)
636 {
637 if(!NTH_BIT(nset,1))
638 VCROSS(n[1],t1,t2);
639 /* Test the point for sidedness */
640 d = DOT(n[1],p2);
641 if(d >= 0.0)
642 SET_NTH_BIT(test[2],1);
643 }
644 else
645 if(sides[2][1] != GT_INTERIOR)
646 SET_NTH_BIT(test[2],1);
647 /* t=2 */
648 if(sides[2][2] == GT_INVALID)
649 {
650 if(!NTH_BIT(nset,2))
651 VCROSS(n[2],t2,t0);
652 /* Test the point for sidedness */
653 d = DOT(n[2],p2);
654 if(d >= 0.0)
655 SET_NTH_BIT(test[2],2);
656 }
657 else
658 if(sides[2][2] != GT_INTERIOR)
659 SET_NTH_BIT(test[2],2);
660 }
661
662
663 int
664 stri_intersect(a1,a2,a3,b1,b2,b3)
665 FVECT a1,a2,a3,b1,b2,b3;
666 {
667 int which,test,n_set[2];
668 int sides[2][3][3],i,j,inext,jnext;
669 int tests[2][3];
670 FVECT n[2][3],p,avg[2],t1,t2,t3;
671
672 #ifdef DEBUG
673 tri_normal(b1,b2,b3,p,FALSE);
674 if(DOT(p,b1) > 0)
675 {
676 VCOPY(t3,b1);
677 VCOPY(t2,b2);
678 VCOPY(t1,b3);
679 }
680 else
681 #endif
682 {
683 VCOPY(t1,b1);
684 VCOPY(t2,b2);
685 VCOPY(t3,b3);
686 }
687
688 /* Test the vertices of triangle a against the pyramid formed by triangle
689 b and the origin. If any vertex of a is interior to triangle b, or
690 if all 3 vertices of a are ON the edges of b,return TRUE. Remember
691 the results of the edge normal and sidedness tests for later.
692 */
693 if(vertices_in_stri(a1,a2,a3,t1,t2,t3,&(n_set[0]),n[0],avg[0],sides[1]))
694 return(TRUE);
695
696 if(vertices_in_stri(t1,t2,t3,a1,a2,a3,&(n_set[1]),n[1],avg[1],sides[0]))
697 return(TRUE);
698
699
700 set_sidedness_tests(t1,t2,t3,a1,a2,a3,tests[0],sides[0],n_set[1],n[1]);
701 if(tests[0][0]&tests[0][1]&tests[0][2])
702 return(FALSE);
703
704 set_sidedness_tests(a1,a2,a3,t1,t2,t3,tests[1],sides[1],n_set[0],n[0]);
705 if(tests[1][0]&tests[1][1]&tests[1][2])
706 return(FALSE);
707
708 for(j=0; j < 3;j++)
709 {
710 jnext = (j+1)%3;
711 /* IF edge b doesnt cross any great circles of a, punt */
712 if(tests[1][j] & tests[1][jnext])
713 continue;
714 for(i=0;i<3;i++)
715 {
716 inext = (i+1)%3;
717 /* IF edge a doesnt cross any great circles of b, punt */
718 if(tests[0][i] & tests[0][inext])
719 continue;
720 /* Now find the great circles that cross and test */
721 if((NTH_BIT(tests[0][i],j)^(NTH_BIT(tests[0][inext],j)))
722 && (NTH_BIT(tests[1][j],i)^NTH_BIT(tests[1][jnext],i)))
723 {
724 VCROSS(p,n[0][i],n[1][j]);
725
726 /* If zero cp= done */
727 if(ZERO_VEC3(p))
728 continue;
729 /* check above both planes */
730 if(DOT(avg[0],p) < 0 || DOT(avg[1],p) < 0)
731 {
732 NEGATE_VEC3(p);
733 if(DOT(avg[0],p) < 0 || DOT(avg[1],p) < 0)
734 continue;
735 }
736 return(TRUE);
737 }
738 }
739 }
740 return(FALSE);
741 }
742
743 int
744 ray_intersect_tri(orig,dir,v0,v1,v2,pt)
745 FVECT orig,dir;
746 FVECT v0,v1,v2;
747 FVECT pt;
748 {
749 FVECT p0,p1,p2,p;
750 FPEQ peq;
751 int type;
752
753 VSUB(p0,v0,orig);
754 VSUB(p1,v1,orig);
755 VSUB(p2,v2,orig);
756
757 if(point_in_stri(p0,p1,p2,dir))
758 {
759 /* Intersect the ray with the triangle plane */
760 tri_plane_equation(v0,v1,v2,&peq,FALSE);
761 return(intersect_ray_plane(orig,dir,peq,NULL,pt));
762 }
763 return(FALSE);
764 }
765
766
767 calculate_view_frustum(vp,hv,vv,horiz,vert,near,far,fnear,ffar)
768 FVECT vp,hv,vv;
769 double horiz,vert,near,far;
770 FVECT fnear[4],ffar[4];
771 {
772 double height,width;
773 FVECT t,nhv,nvv,ndv;
774 double w2,h2;
775 /* Calculate the x and y dimensions of the near face */
776 /* hv and vv are the horizontal and vertical vectors in the
777 view frame-the magnitude is the dimension of the front frustum
778 face at z =1
779 */
780 VCOPY(nhv,hv);
781 VCOPY(nvv,vv);
782 w2 = normalize(nhv);
783 h2 = normalize(nvv);
784 /* Use similar triangles to calculate the dimensions at z=near */
785 width = near*0.5*w2;
786 height = near*0.5*h2;
787
788 VCROSS(ndv,nvv,nhv);
789 /* Calculate the world space points corresponding to the 4 corners
790 of the front face of the view frustum
791 */
792 fnear[0][0] = width*nhv[0] + height*nvv[0] + near*ndv[0] + vp[0] ;
793 fnear[0][1] = width*nhv[1] + height*nvv[1] + near*ndv[1] + vp[1];
794 fnear[0][2] = width*nhv[2] + height*nvv[2] + near*ndv[2] + vp[2];
795 fnear[1][0] = -width*nhv[0] + height*nvv[0] + near*ndv[0] + vp[0];
796 fnear[1][1] = -width*nhv[1] + height*nvv[1] + near*ndv[1] + vp[1];
797 fnear[1][2] = -width*nhv[2] + height*nvv[2] + near*ndv[2] + vp[2];
798 fnear[2][0] = -width*nhv[0] - height*nvv[0] + near*ndv[0] + vp[0];
799 fnear[2][1] = -width*nhv[1] - height*nvv[1] + near*ndv[1] + vp[1];
800 fnear[2][2] = -width*nhv[2] - height*nvv[2] + near*ndv[2] + vp[2];
801 fnear[3][0] = width*nhv[0] - height*nvv[0] + near*ndv[0] + vp[0];
802 fnear[3][1] = width*nhv[1] - height*nvv[1] + near*ndv[1] + vp[1];
803 fnear[3][2] = width*nhv[2] - height*nvv[2] + near*ndv[2] + vp[2];
804
805 /* Now do the far face */
806 width = far*0.5*w2;
807 height = far*0.5*h2;
808 ffar[0][0] = width*nhv[0] + height*nvv[0] + far*ndv[0] + vp[0] ;
809 ffar[0][1] = width*nhv[1] + height*nvv[1] + far*ndv[1] + vp[1] ;
810 ffar[0][2] = width*nhv[2] + height*nvv[2] + far*ndv[2] + vp[2] ;
811 ffar[1][0] = -width*nhv[0] + height*nvv[0] + far*ndv[0] + vp[0] ;
812 ffar[1][1] = -width*nhv[1] + height*nvv[1] + far*ndv[1] + vp[1] ;
813 ffar[1][2] = -width*nhv[2] + height*nvv[2] + far*ndv[2] + vp[2] ;
814 ffar[2][0] = -width*nhv[0] - height*nvv[0] + far*ndv[0] + vp[0] ;
815 ffar[2][1] = -width*nhv[1] - height*nvv[1] + far*ndv[1] + vp[1] ;
816 ffar[2][2] = -width*nhv[2] - height*nvv[2] + far*ndv[2] + vp[2] ;
817 ffar[3][0] = width*nhv[0] - height*nvv[0] + far*ndv[0] + vp[0] ;
818 ffar[3][1] = width*nhv[1] - height*nvv[1] + far*ndv[1] + vp[1] ;
819 ffar[3][2] = width*nhv[2] - height*nvv[2] + far*ndv[2] + vp[2] ;
820 }
821
822 int
823 max_index(v,r)
824 FVECT v;
825 double *r;
826 {
827 double p[3];
828 int i;
829
830 p[0] = fabs(v[0]);
831 p[1] = fabs(v[1]);
832 p[2] = fabs(v[2]);
833 i = (p[0]>=p[1])?((p[0]>=p[2])?0:2):((p[1]>=p[2])?1:2);
834 if(r)
835 *r = p[i];
836 return(i);
837 }
838
839 int
840 closest_point_in_tri(p0,p1,p2,p,p0id,p1id,p2id)
841 FVECT p0,p1,p2,p;
842 int p0id,p1id,p2id;
843 {
844 double d,d1;
845 int i;
846
847 d = DIST_SQ(p,p0);
848 d1 = DIST_SQ(p,p1);
849 if(d < d1)
850 {
851 d1 = DIST_SQ(p,p2);
852 i = (d1 < d)?p2id:p0id;
853 }
854 else
855 {
856 d = DIST_SQ(p,p2);
857 i = (d < d1)? p2id:p1id;
858 }
859 return(i);
860 }
861
862
863 int
864 sedge_intersect(a0,a1,b0,b1)
865 FVECT a0,a1,b0,b1;
866 {
867 FVECT na,nb,avga,avgb,p;
868 double d;
869 int sb0,sb1,sa0,sa1;
870
871 /* First test if edge b straddles great circle of a */
872 VCROSS(na,a0,a1);
873 d = DOT(na,b0);
874 sb0 = ZERO(d)?0:(d<0)? -1: 1;
875 d = DOT(na,b1);
876 sb1 = ZERO(d)?0:(d<0)? -1: 1;
877 /* edge b entirely on one side of great circle a: edges cannot intersect*/
878 if(sb0*sb1 > 0)
879 return(FALSE);
880 /* test if edge a straddles great circle of b */
881 VCROSS(nb,b0,b1);
882 d = DOT(nb,a0);
883 sa0 = ZERO(d)?0:(d<0)? -1: 1;
884 d = DOT(nb,a1);
885 sa1 = ZERO(d)?0:(d<0)? -1: 1;
886 /* edge a entirely on one side of great circle b: edges cannot intersect*/
887 if(sa0*sa1 > 0)
888 return(FALSE);
889
890 /* Find one of intersection points of the great circles */
891 VCROSS(p,na,nb);
892 /* If they lie on same great circle: call an intersection */
893 if(ZERO_VEC3(p))
894 return(TRUE);
895
896 VADD(avga,a0,a1);
897 VADD(avgb,b0,b1);
898 if(DOT(avga,p) < 0 || DOT(avgb,p) < 0)
899 {
900 NEGATE_VEC3(p);
901 if(DOT(avga,p) < 0 || DOT(avgb,p) < 0)
902 return(FALSE);
903 }
904 if((!sb0 || !sb1) && (!sa0 || !sa1))
905 return(FALSE);
906 return(TRUE);
907 }
908
909
910 /* Find the normalized barycentric coordinates of p relative to
911 * triangle v0,v1,v2. Return result in coord
912 */
913 bary2d(x1,y1,x2,y2,x3,y3,px,py,coord)
914 double x1,y1,x2,y2,x3,y3;
915 double px,py;
916 double coord[3];
917 {
918 double a;
919
920 a = (x2 - x1) * (y3 - y1) - (x3 - x1) * (y2 - y1);
921 coord[0] = ((x2 - px) * (y3 - py) - (x3 - px) * (y2 - py)) / a;
922 coord[1] = ((x3 - px) * (y1 - py) - (x1 - px) * (y3 - py)) / a;
923 coord[2] = ((x1 - px) * (y2 - py) - (x2 - px) * (y1 - py)) / a;
924
925 }
926
927
928
929
930 bary_parent(coord,i)
931 BCOORD coord[3];
932 int i;
933 {
934 switch(i) {
935 case 0:
936 /* update bary for child */
937 coord[0] = (coord[0] >> 1) + MAXBCOORD4;
938 coord[1] >>= 1;
939 coord[2] >>= 1;
940 break;
941 case 1:
942 coord[0] >>= 1;
943 coord[1] = (coord[1] >> 1) + MAXBCOORD4;
944 coord[2] >>= 1;
945 break;
946
947 case 2:
948 coord[0] >>= 1;
949 coord[1] >>= 1;
950 coord[2] = (coord[2] >> 1) + MAXBCOORD4;
951 break;
952
953 case 3:
954 coord[0] = MAXBCOORD4 - (coord[0] >> 1);
955 coord[1] = MAXBCOORD4 - (coord[1] >> 1);
956 coord[2] = MAXBCOORD4 - (coord[2] >> 1);
957 break;
958 #ifdef DEBUG
959 default:
960 eputs("bary_parent():Invalid child\n");
961 break;
962 #endif
963 }
964 }
965
966 bary_from_child(coord,child,next)
967 BCOORD coord[3];
968 int child,next;
969 {
970 #ifdef DEBUG
971 if(child <0 || child > 3)
972 {
973 eputs("bary_from_child():Invalid child\n");
974 return;
975 }
976 if(next <0 || next > 3)
977 {
978 eputs("bary_from_child():Invalid next\n");
979 return;
980 }
981 #endif
982 if(next == child)
983 return;
984
985 switch(child){
986 case 0:
987 coord[0] = 0;
988 coord[1] = MAXBCOORD2 - coord[1];
989 coord[2] = MAXBCOORD2 - coord[2];
990 break;
991 case 1:
992 coord[0] = MAXBCOORD2 - coord[0];
993 coord[1] = 0;
994 coord[2] = MAXBCOORD2 - coord[2];
995 break;
996 case 2:
997 coord[0] = MAXBCOORD2 - coord[0];
998 coord[1] = MAXBCOORD2 - coord[1];
999 coord[2] = 0;
1000 break;
1001 case 3:
1002 switch(next){
1003 case 0:
1004 coord[0] = 0;
1005 coord[1] = MAXBCOORD2 - coord[1];
1006 coord[2] = MAXBCOORD2 - coord[2];
1007 break;
1008 case 1:
1009 coord[0] = MAXBCOORD2 - coord[0];
1010 coord[1] = 0;
1011 coord[2] = MAXBCOORD2 - coord[2];
1012 break;
1013 case 2:
1014 coord[0] = MAXBCOORD2 - coord[0];
1015 coord[1] = MAXBCOORD2 - coord[1];
1016 coord[2] = 0;
1017 break;
1018 }
1019 break;
1020 }
1021 }
1022
1023 int
1024 bary_child(coord)
1025 BCOORD coord[3];
1026 {
1027 int i;
1028
1029 if(coord[0] > MAXBCOORD4)
1030 {
1031 /* update bary for child */
1032 coord[0] = (coord[0]<< 1) - MAXBCOORD2;
1033 coord[1] <<= 1;
1034 coord[2] <<= 1;
1035 return(0);
1036 }
1037 else
1038 if(coord[1] > MAXBCOORD4)
1039 {
1040 coord[0] <<= 1;
1041 coord[1] = (coord[1] << 1) - MAXBCOORD2;
1042 coord[2] <<= 1;
1043 return(1);
1044 }
1045 else
1046 if(coord[2] > MAXBCOORD4)
1047 {
1048 coord[0] <<= 1;
1049 coord[1] <<= 1;
1050 coord[2] = (coord[2] << 1) - MAXBCOORD2;
1051 return(2);
1052 }
1053 else
1054 {
1055 coord[0] = MAXBCOORD2 - (coord[0] << 1);
1056 coord[1] = MAXBCOORD2 - (coord[1] << 1);
1057 coord[2] = MAXBCOORD2 - (coord[2] << 1);
1058 return(3);
1059 }
1060 }
1061
1062 int
1063 bary_nth_child(coord,i)
1064 BCOORD coord[3];
1065 int i;
1066 {
1067
1068 switch(i){
1069 case 0:
1070 /* update bary for child */
1071 coord[0] = (coord[0]<< 1) - MAXBCOORD2;
1072 coord[1] <<= 1;
1073 coord[2] <<= 1;
1074 break;
1075 case 1:
1076 coord[0] <<= 1;
1077 coord[1] = (coord[1] << 1) - MAXBCOORD2;
1078 coord[2] <<= 1;
1079 break;
1080 case 2:
1081 coord[0] <<= 1;
1082 coord[1] <<= 1;
1083 coord[2] = (coord[2] << 1) - MAXBCOORD2;
1084 break;
1085 case 3:
1086 coord[0] = MAXBCOORD2 - (coord[0] << 1);
1087 coord[1] = MAXBCOORD2 - (coord[1] << 1);
1088 coord[2] = MAXBCOORD2 - (coord[2] << 1);
1089 break;
1090 }
1091 }
1092
1093
1094
