--- ray/src/hd/sm_geom.c 1998/11/11 12:05:38 3.8 +++ ray/src/hd/sm_geom.c 1998/12/28 18:07:35 3.9 @@ -57,7 +57,7 @@ FVECT v0,v1,v2; /* calculates the normal of a face contour using Newell's formula. e - a = SUMi (yi - yi+1)(zi + zi+1)smMesh->samples->max_samp+4); + a = SUMi (yi - yi+1)(zi + zi+1); b = SUMi (zi - zi+1)(xi + xi+1) c = SUMi (xi - xi+1)(yi + yi+1) */ @@ -74,7 +74,7 @@ int norm; n[1] = (v0[2] - v1[2]) * (v0[0] + v1[0]) + (v1[2] - v2[2]) * (v1[0] + v2[0]) + - (v2[2] - v0[2]) * (v2[0] + v0[0]); + (v2[2] - v0[2]) * (v2[0] + v0[0]); n[2] = (v0[1] + v1[1]) * (v0[0] - v1[0]) + (v1[1] + v2[1]) * (v1[0] - v2[0]) + @@ -119,12 +119,14 @@ FVECT p0,p1; } - +double point_on_sphere(ps,p,c) FVECT ps,p,c; { + double d; VSUB(ps,p,c); - normalize(ps); + d= normalize(ps); + return(d); } @@ -247,7 +249,25 @@ intersect_ray_oplane(orig,dir,n,pd,r) return(hit); } +/* Assumption: know crosses plane:dont need to check for 'on' case */ +intersect_edge_coord_plane(v0,v1,w,r) +FVECT v0,v1; +int w; +FVECT r; +{ + FVECT dv; + int wnext; + double t; + VSUB(dv,v1,v0); + t = -v0[w]/dv[w]; + r[w] = 0.0; + wnext = (w+1)%3; + r[wnext] = v0[wnext] + dv[wnext]*t; + wnext = (w+2)%3; + r[wnext] = v0[wnext] + dv[wnext]*t; +} + int intersect_edge_plane(e0,e1,peq,pd,r) FVECT e0,e1; @@ -319,7 +339,7 @@ FVECT p0,p1,p2; VSUB(p2,p2,p0); VSUB(np,np,p0); - p1[0] = VLEN(p1); + p1[0] = DOT(p1,x_axis); p1[1] = 0; d1 = DOT(p2,x_axis); @@ -647,25 +667,41 @@ FVECT a1,a2,a3,b1,b2,b3; int which,test,n_set[2]; int sides[2][3][3],i,j,inext,jnext; int tests[2][3]; - FVECT n[2][3],p,avg[2]; + FVECT n[2][3],p,avg[2],t1,t2,t3; +#ifdef DEBUG + tri_normal(b1,b2,b3,p,FALSE); + if(DOT(p,b1) > 0) + { + VCOPY(t3,b1); + VCOPY(t2,b2); + VCOPY(t1,b3); + } + else +#endif + { + VCOPY(t1,b1); + VCOPY(t2,b2); + VCOPY(t3,b3); + } + /* Test the vertices of triangle a against the pyramid formed by triangle b and the origin. If any vertex of a is interior to triangle b, or if all 3 vertices of a are ON the edges of b,return TRUE. Remember the results of the edge normal and sidedness tests for later. */ - if(vertices_in_stri(a1,a2,a3,b1,b2,b3,&(n_set[0]),n[0],avg[0],sides[1])) + if(vertices_in_stri(a1,a2,a3,t1,t2,t3,&(n_set[0]),n[0],avg[0],sides[1])) return(TRUE); - if(vertices_in_stri(b1,b2,b3,a1,a2,a3,&(n_set[1]),n[1],avg[1],sides[0])) + if(vertices_in_stri(t1,t2,t3,a1,a2,a3,&(n_set[1]),n[1],avg[1],sides[0])) return(TRUE); - set_sidedness_tests(b1,b2,b3,a1,a2,a3,tests[0],sides[0],n_set[1],n[1]); + set_sidedness_tests(t1,t2,t3,a1,a2,a3,tests[0],sides[0],n_set[1],n[1]); if(tests[0][0]&tests[0][1]&tests[0][2]) return(FALSE); - set_sidedness_tests(a1,a2,a3,b1,b2,b3,tests[1],sides[1],n_set[0],n[0]); + set_sidedness_tests(a1,a2,a3,t1,t2,t3,tests[1],sides[1],n_set[0],n[0]); if(tests[1][0]&tests[1][1]&tests[1][2]) return(FALSE); @@ -871,7 +907,6 @@ FVECT a0,a1,b0,b1; } - /* Find the normalized barycentric coordinates of p relative to * triangle v0,v1,v2. Return result in coord */ @@ -889,266 +924,58 @@ double coord[3]; } -bary_ith_child(coord,i) -double coord[3]; - int i; -{ - - switch(i){ - case 0: - /* update bary for child */ - coord[0] = 2.0*coord[0]- 1.0; - coord[1] *= 2.0; - coord[2] *= 2.0; - break; - case 1: - coord[0] *= 2.0; - coord[1] = 2.0*coord[1]- 1.0; - coord[2] *= 2.0; - break; - case 2: - coord[0] *= 2.0; - coord[1] *= 2.0; - coord[2] = 2.0*coord[2]- 1.0; - break; - case 3: - coord[0] = 1.0 - 2.0*coord[0]; - coord[1] = 1.0 - 2.0*coord[1]; - coord[2] = 1.0 - 2.0*coord[2]; - break; -#ifdef DEBUG - default: - eputs("bary_ith_child():Invalid child\n"); - break; -#endif - } -} -int -bary_child(coord) -double coord[3]; -{ - int i; - if(coord[0] > 0.5) - { - /* update bary for child */ - coord[0] = 2.0*coord[0]- 1.0; - coord[1] *= 2.0; - coord[2] *= 2.0; - return(0); - } - else - if(coord[1] > 0.5) - { - coord[0] *= 2.0; - coord[1] = 2.0*coord[1]- 1.0; - coord[2] *= 2.0; - return(1); - } - else - if(coord[2] > 0.5) - { - coord[0] *= 2.0; - coord[1] *= 2.0; - coord[2] = 2.0*coord[2]- 1.0; - return(2); - } - else - { - coord[0] = 1.0 - 2.0*coord[0]; - coord[1] = 1.0 - 2.0*coord[1]; - coord[2] = 1.0 - 2.0*coord[2]; - return(3); - } -} - -/* Coord was the ith child of the parent: set the coordinate - relative to the parent -*/ bary_parent(coord,i) -double coord[3]; -int i; -{ - - switch(i) { - case 0: - /* update bary for child */ - coord[0] = coord[0]*0.5 + 0.5; - coord[1] *= 0.5; - coord[2] *= 0.5; - break; - case 1: - coord[0] *= 0.5; - coord[1] = coord[1]*0.5 + 0.5; - coord[2] *= 0.5; - break; - - case 2: - coord[0] *= 0.5; - coord[1] *= 0.5; - coord[2] = coord[2]*0.5 + 0.5; - break; - - case 3: - coord[0] = 0.5 - 0.5*coord[0]; - coord[1] = 0.5 - 0.5*coord[1]; - coord[2] = 0.5 - 0.5*coord[2]; - break; -#ifdef DEBUG - default: - eputs("bary_parent():Invalid child\n"); - break; -#endif - } -} - -bary_from_child(coord,child,next) -double coord[3]; -int child,next; -{ -#ifdef DEBUG - if(child <0 || child > 3) - { - eputs("bary_from_child():Invalid child\n"); - return; - } - if(next <0 || next > 3) - { - eputs("bary_from_child():Invalid next\n"); - return; - } -#endif - if(next == child) - return; - - switch(child){ - case 0: - switch(next){ - case 1: - coord[0] += 1.0; - coord[1] -= 1.0; - break; - case 2: - coord[0] += 1.0; - coord[2] -= 1.0; - break; - case 3: - coord[0] *= -1.0; - coord[1] = 1 - coord[1]; - coord[2] = 1 - coord[2]; - break; - - } - break; - case 1: - switch(next){ - case 0: - coord[0] -= 1.0; - coord[1] += 1.0; - break; - case 2: - coord[1] += 1.0; - coord[2] -= 1.0; - break; - case 3: - coord[0] = 1 - coord[0]; - coord[1] *= -1.0; - coord[2] = 1 - coord[2]; - break; - } - break; - case 2: - switch(next){ - case 0: - coord[0] -= 1.0; - coord[2] += 1.0; - break; - case 1: - coord[1] -= 1.0; - coord[2] += 1.0; - break; - case 3: - coord[0] = 1 - coord[0]; - coord[1] = 1 - coord[1]; - coord[2] *= -1.0; - break; - } - break; - case 3: - switch(next){ - case 0: - coord[0] *= -1.0; - coord[1] = 1 - coord[1]; - coord[2] = 1 - coord[2]; - break; - case 1: - coord[0] = 1 - coord[0]; - coord[1] *= -1.0; - coord[2] = 1 - coord[2]; - break; - case 2: - coord[0] = 1 - coord[0]; - coord[1] = 1 - coord[1]; - coord[2] *= -1.0; - break; - } - break; - } -} - - -baryi_parent(coord,i) BCOORD coord[3]; int i; { - switch(i) { case 0: /* update bary for child */ - coord[0] = (coord[0] >> 1) + MAXBCOORD2; + coord[0] = (coord[0] >> 1) + MAXBCOORD4; coord[1] >>= 1; coord[2] >>= 1; break; case 1: coord[0] >>= 1; - coord[1] = (coord[1] >> 1) + MAXBCOORD2; + coord[1] = (coord[1] >> 1) + MAXBCOORD4; coord[2] >>= 1; break; case 2: coord[0] >>= 1; coord[1] >>= 1; - coord[2] = (coord[2] >> 1) + MAXBCOORD2; + coord[2] = (coord[2] >> 1) + MAXBCOORD4; break; case 3: - coord[0] = MAXBCOORD2 - (coord[0] >> 1); - coord[1] = MAXBCOORD2 - (coord[1] >> 1); - coord[2] = MAXBCOORD2 - (coord[2] >> 1); + coord[0] = MAXBCOORD4 - (coord[0] >> 1); + coord[1] = MAXBCOORD4 - (coord[1] >> 1); + coord[2] = MAXBCOORD4 - (coord[2] >> 1); break; #ifdef DEBUG default: - eputs("baryi_parent():Invalid child\n"); + eputs("bary_parent():Invalid child\n"); break; #endif } } -baryi_from_child(coord,child,next) +bary_from_child(coord,child,next) BCOORD coord[3]; int child,next; { #ifdef DEBUG if(child <0 || child > 3) { - eputs("baryi_from_child():Invalid child\n"); + eputs("bary_from_child():Invalid child\n"); return; } if(next <0 || next > 3) { - eputs("baryi_from_child():Invalid next\n"); + eputs("bary_from_child():Invalid next\n"); return; } #endif @@ -1158,34 +985,34 @@ int child,next; switch(child){ case 0: coord[0] = 0; - coord[1] = MAXBCOORD - coord[1]; - coord[2] = MAXBCOORD - coord[2]; + coord[1] = MAXBCOORD2 - coord[1]; + coord[2] = MAXBCOORD2 - coord[2]; break; case 1: - coord[0] = MAXBCOORD - coord[0]; + coord[0] = MAXBCOORD2 - coord[0]; coord[1] = 0; - coord[2] = MAXBCOORD - coord[2]; + coord[2] = MAXBCOORD2 - coord[2]; break; case 2: - coord[0] = MAXBCOORD - coord[0]; - coord[1] = MAXBCOORD - coord[1]; + coord[0] = MAXBCOORD2 - coord[0]; + coord[1] = MAXBCOORD2 - coord[1]; coord[2] = 0; break; case 3: switch(next){ case 0: coord[0] = 0; - coord[1] = MAXBCOORD - coord[1]; - coord[2] = MAXBCOORD - coord[2]; + coord[1] = MAXBCOORD2 - coord[1]; + coord[2] = MAXBCOORD2 - coord[2]; break; case 1: - coord[0] = MAXBCOORD - coord[0]; + coord[0] = MAXBCOORD2 - coord[0]; coord[1] = 0; - coord[2] = MAXBCOORD - coord[2]; + coord[2] = MAXBCOORD2 - coord[2]; break; case 2: - coord[0] = MAXBCOORD - coord[0]; - coord[1] = MAXBCOORD - coord[1]; + coord[0] = MAXBCOORD2 - coord[0]; + coord[1] = MAXBCOORD2 - coord[1]; coord[2] = 0; break; } @@ -1194,46 +1021,46 @@ int child,next; } int -baryi_child(coord) +bary_child(coord) BCOORD coord[3]; { int i; - if(coord[0] > MAXBCOORD2) + if(coord[0] > MAXBCOORD4) { /* update bary for child */ - coord[0] = (coord[0]<< 1) - MAXBCOORD; + coord[0] = (coord[0]<< 1) - MAXBCOORD2; coord[1] <<= 1; coord[2] <<= 1; return(0); } else - if(coord[1] > MAXBCOORD2) + if(coord[1] > MAXBCOORD4) { coord[0] <<= 1; - coord[1] = (coord[1] << 1) - MAXBCOORD; + coord[1] = (coord[1] << 1) - MAXBCOORD2; coord[2] <<= 1; return(1); } else - if(coord[2] > MAXBCOORD2) + if(coord[2] > MAXBCOORD4) { coord[0] <<= 1; coord[1] <<= 1; - coord[2] = (coord[2] << 1) - MAXBCOORD; + coord[2] = (coord[2] << 1) - MAXBCOORD2; return(2); } else { - coord[0] = MAXBCOORD - (coord[0] << 1); - coord[1] = MAXBCOORD - (coord[1] << 1); - coord[2] = MAXBCOORD - (coord[2] << 1); + coord[0] = MAXBCOORD2 - (coord[0] << 1); + coord[1] = MAXBCOORD2 - (coord[1] << 1); + coord[2] = MAXBCOORD2 - (coord[2] << 1); return(3); } } int -baryi_nth_child(coord,i) +bary_nth_child(coord,i) BCOORD coord[3]; int i; { @@ -1241,219 +1068,27 @@ int i; switch(i){ case 0: /* update bary for child */ - coord[0] = (coord[0]<< 1) - MAXBCOORD; + coord[0] = (coord[0]<< 1) - MAXBCOORD2; coord[1] <<= 1; coord[2] <<= 1; break; case 1: coord[0] <<= 1; - coord[1] = (coord[1] << 1) - MAXBCOORD; + coord[1] = (coord[1] << 1) - MAXBCOORD2; coord[2] <<= 1; break; case 2: coord[0] <<= 1; coord[1] <<= 1; - coord[2] = (coord[2] << 1) - MAXBCOORD; + coord[2] = (coord[2] << 1) - MAXBCOORD2; break; case 3: - coord[0] = MAXBCOORD - (coord[0] << 1); - coord[1] = MAXBCOORD - (coord[1] << 1); - coord[2] = MAXBCOORD - (coord[2] << 1); + coord[0] = MAXBCOORD2 - (coord[0] << 1); + coord[1] = MAXBCOORD2 - (coord[1] << 1); + coord[2] = MAXBCOORD2 - (coord[2] << 1); break; } } - - -baryi_children(coord,i,in_tri,rcoord,rin_tri) -BCOORD coord[3][3]; -int i; -int in_tri[3]; -BCOORD rcoord[3][3]; -int rin_tri[3]; -{ - int j; - - for(j=0; j< 3; j++) - { - if(!in_tri[j]) - { - rin_tri[j]=0; - continue; - } - - if(i != 3) - { - if(coord[j][i] < MAXBCOORD2) - { - rin_tri[j] = 0; - continue; - } - } - else - if( !(coord[j][0] <= MAXBCOORD2 && coord[j][1] <= MAXBCOORD2 && - coord[j][2] <= MAXBCOORD2)) - { - rin_tri[j] = 0; - continue; - } - - rin_tri[j]=1; - VCOPY(rcoord[j],coord[j]); - baryi_nth_child(rcoord[j],i); - } - -} - -convert_dtol(b,bi) -double b[3]; -BCOORD bi[3]; -{ - int i; - - for(i=0; i < 2;i++) - { - - if(b[i] <= 0.0) - { - bi[i]= 0; - } - else - if(b[i] >= 1.0) - { - bi[i]= MAXBCOORD; - } - else - bi[i] = (BCOORD)(b[i]*MAXBCOORD); - } - bi[2] = bi[0] + bi[1]; - if(bi[2] > MAXBCOORD) - { - bi[2] = 0; - bi[1] = MAXBCOORD - bi[0]; - } - else - bi[2] = MAXBCOORD - bi[2]; - -} - -/* convert barycentric coordinate b in [-eps,1+eps] to [0,MAXLONG], - dir unbounded to [-MAXLONG,MAXLONG] - */ -bary_dtol(b,db,bi,dbi,t,w) -double b[3],db[3][3]; -BCOORD bi[3]; -BDIR dbi[3][3]; -TINT t[3]; -int w; -{ - int i,id,j,k; - double d; - - convert_dtol(b,bi); - - for(j=w; j< 3; j++) - { - if(t[j] == HUGET) - { - max_index(db[j],&d); - for(i=0; i< 3; i++) - dbi[j][i] = (BDIR)(db[j][i]/d*MAXBDIR); - break; - } - else - { - for(i=0; i< 3; i++) - dbi[j][i] = (BDIR)(db[j][i]*MAXBDIR); - } - } -} - - -/* convert barycentric coordinate b in [-eps,1+eps] to [0,MAXLONG], - dir unbounded to [-MAXLONG,MAXLONG] - */ -bary_dtol_new(b,db,bi,boi,dbi,t) -double b[4][3],db[3][3]; -BCOORD bi[3],boi[3][3]; -BDIR dbi[3][3]; -int t[3]; -{ - int i,id,j,k; - double d; - - convert_dtol(b[3],bi); - - for(j=0; j<3;j++) - { - if(t[j] != 1) - continue; - convert_dtol(b[j],boi[j]); - } - for(j=0; j< 3; j++) - { - k = (j+1)%3; - if(t[k]==0) - continue; - if(t[k] == -1) - { - max_index(db[j],&d); - for(i=0; i< 3; i++) - dbi[j][i] = (BDIR)(db[j][i]/d*MAXBDIR); - t[k] = 0; - } - else - if(t[j] != 1) - for(i=0; i< 3; i++) - dbi[j][i] = (BDIR)(db[j][i]*MAXBDIR); - else - for(i=0; i< 3; i++) - dbi[j][i] = boi[k][i] - boi[j][i]; - - } -} - - -bary_dtolb(b,bi,in_tri) -double b[3][3]; -BCOORD bi[3][3]; -int in_tri[3]; -{ - int i,j; - - for(j=0; j<3;j++) - { - if(!in_tri[j]) - continue; - for(i=0; i < 2;i++) - { - if(b[j][i] <= 0.0) - { - bi[j][i]= 0; - } - else - if(b[j][i] >= 1.0) - { - bi[j][i]= MAXBCOORD; - } - else - bi[j][i] = (BCOORD)(b[j][i]*MAXBCOORD); - } - bi[j][2] = MAXBCOORD - bi[j][0] - bi[j][1]; - if(bi[j][2] < 0) - { - bi[j][2] = 0; - bi[j][1] = MAXBCOORD - bi[j][0]; - } - } -} - - - - - - - -
