--- ray/src/hd/sm_geom.c 1998/09/14 10:33:46 3.5 +++ ray/src/hd/sm_geom.c 1998/10/06 18:16:53 3.7 @@ -33,13 +33,20 @@ int convex_angle(v0,v1,v2) FVECT v0,v1,v2; { - FVECT cp01,cp12,cp; - - /* test sign of (v0Xv1)X(v1Xv2). v1 */ + FVECT cp,cp01,cp12,v10,v02; + double dp; + /* + VSUB(v10,v1,v0); + VSUB(v02,v0,v2); + VCROSS(cp,v10,v02); + */ + /* test sign of (v0Xv1)X(v1Xv2). v1 */ VCROSS(cp01,v0,v1); VCROSS(cp12,v1,v2); VCROSS(cp,cp01,cp12); - if(DOT(cp,v1) < 0.0) + + dp = DOT(cp,v1); + if(ZERO(dp) || dp < 0.0) return(FALSE); return(TRUE); } @@ -64,7 +71,6 @@ int norm; n[1] = (v0[2] - v1[2]) * (v0[0] + v1[0]) + (v1[2] - v2[2]) * (v1[0] + v2[0]) + (v2[2] - v0[2]) * (v2[0] + v0[0]); - n[2] = (v0[1] + v1[1]) * (v0[0] - v1[0]) + (v1[1] + v2[1]) * (v1[0] - v2[0]) + @@ -80,14 +86,14 @@ int norm; } -tri_plane_equation(v0,v1,v2,n,nd,norm) - FVECT v0,v1,v2,n; - double *nd; +tri_plane_equation(v0,v1,v2,peqptr,norm) + FVECT v0,v1,v2; + FPEQ *peqptr; int norm; { - tri_normal(v0,v1,v2,n,norm); + tri_normal(v0,v1,v2,FP_N(*peqptr),norm); - *nd = -(DOT(n,v0)); + FP_D(*peqptr) = -(DOT(FP_N(*peqptr),v0)); } /* From quad_edge-code */ @@ -125,9 +131,9 @@ FVECT ps,p,c; * t, if parallel, returns t=FHUGE */ int -intersect_vector_plane(v,plane_n,plane_d,tptr,r) - FVECT v,plane_n; - double plane_d; +intersect_vector_plane(v,peq,tptr,r) + FVECT v; + FPEQ peq; double *tptr; FVECT r; { @@ -141,7 +147,7 @@ intersect_vector_plane(v,plane_n,plane_d,tptr,r) /* line is l = p1 + (p2-p1)t, p1=origin */ /* Solve for t: */ - d = -(DOT(plane_n,v)); + d = -(DOT(FP_N(peq),v)); if(ZERO(d)) { t = FHUGE; @@ -149,7 +155,7 @@ intersect_vector_plane(v,plane_n,plane_d,tptr,r) } else { - t = plane_d/d; + t = FP_D(peq)/d; if(t < 0 ) hit = 0; else @@ -167,10 +173,9 @@ intersect_vector_plane(v,plane_n,plane_d,tptr,r) } int -intersect_ray_plane(orig,dir,plane_n,plane_d,pd,r) +intersect_ray_plane(orig,dir,peq,pd,r) FVECT orig,dir; - FVECT plane_n; - double plane_d; + FPEQ peq; double *pd; FVECT r; { @@ -185,7 +190,7 @@ intersect_ray_plane(orig,dir,plane_n,plane_d,pd,r) line is l = p1 + (p2-p1)t */ /* Solve for t: */ - t = -(DOT(plane_n,orig) + plane_d)/(DOT(plane_n,dir)); + t = -(DOT(FP_N(peq),orig) + FP_D(peq))/(DOT(FP_N(peq),dir)); if(t < 0) hit = 0; else @@ -201,10 +206,42 @@ intersect_ray_plane(orig,dir,plane_n,plane_d,pd,r) int -intersect_edge_plane(e0,e1,plane_n,plane_d,pd,r) +intersect_ray_oplane(orig,dir,n,pd,r) + FVECT orig,dir; + FVECT n; + double *pd; + FVECT r; +{ + double t; + int hit; + /* + Plane is Ax + By + Cz +D = 0: + plane[0] = A,plane[1] = B,plane[2] = C,plane[3] = D + */ + /* A(orig[0] + dxt) + B(orig[1] + dyt) + C(orig[2] + dzt) + pd = 0 + t = -(DOT(plane_n,orig)+ plane_d)/(DOT(plane_n,d)) + line is l = p1 + (p2-p1)t + */ + /* Solve for t: */ + t = -(DOT(n,orig))/(DOT(n,dir)); + if(t < 0) + hit = 0; + else + hit = 1; + + if(r) + VSUM(r,orig,dir,t); + + if(pd) + *pd = t; + return(hit); +} + + +int +intersect_edge_plane(e0,e1,peq,pd,r) FVECT e0,e1; - FVECT plane_n; - double plane_d; + FPEQ peq; double *pd; FVECT r; { @@ -221,7 +258,7 @@ intersect_edge_plane(e0,e1,plane_n,plane_d,pd,r) */ /* Solve for t: */ VSUB(d,e1,e0); - t = -(DOT(plane_n,e0) + plane_d)/(DOT(plane_n,d)); + t = -(DOT(FP_N(peq),e0) + FP_D(peq))/(DOT(FP_N(peq),d)); if(t < 0) hit = 0; else @@ -240,9 +277,9 @@ point_in_cone(p,p0,p1,p2) FVECT p; FVECT p0,p1,p2; { - FVECT n; FVECT np,x_axis,y_axis; - double d1,d2,d; + double d1,d2; + FPEQ peq; /* Find the equation of the circle defined by the intersection of the cone with the plane defined by p1,p2,p3- project p into @@ -250,7 +287,7 @@ FVECT p0,p1,p2; */ /* find the equation of the plane defined by p1-p3 */ - tri_plane_equation(p0,p1,p2,n,&d,FALSE); + tri_plane_equation(p0,p1,p2,&peq,FALSE); /* define a coordinate system on the plane: the x axis is in the direction of np2-np1, and the y axis is calculated from @@ -258,14 +295,14 @@ FVECT p0,p1,p2; */ /* Project p onto the plane */ /* NOTE: check this: does sideness check?*/ - if(!intersect_vector_plane(p,n,d,NULL,np)) + if(!intersect_vector_plane(p,peq,NULL,np)) return(FALSE); /* create coordinate system on plane: p2-p1 defines the x_axis*/ VSUB(x_axis,p1,p0); normalize(x_axis); /* The y axis is */ - VCROSS(y_axis,n,x_axis); + VCROSS(y_axis,FP_N(peq),x_axis); normalize(y_axis); VSUB(p1,p1,p0); @@ -353,7 +390,7 @@ int sides[3]; - + int point_in_stri(v0,v1,v2,p) FVECT v0,v1,v2,p; @@ -663,8 +700,8 @@ FVECT orig,dir; FVECT v0,v1,v2; FVECT pt; { - FVECT p0,p1,p2,p,n; - double pd; + FVECT p0,p1,p2,p; + FPEQ peq; int type; VSUB(p0,v0,orig); @@ -674,8 +711,8 @@ FVECT pt; if(point_in_stri(p0,p1,p2,dir)) { /* Intersect the ray with the triangle plane */ - tri_plane_equation(v0,v1,v2,n,&pd,FALSE); - return(intersect_ray_plane(orig,dir,n,pd,NULL,pt)); + tri_plane_equation(v0,v1,v2,&peq,FALSE); + return(intersect_ray_plane(orig,dir,peq,NULL,pt)); } return(FALSE); } @@ -736,9 +773,47 @@ FVECT fnear[4],ffar[4]; ffar[3][2] = width*nhv[2] - height*nvv[2] + far*ndv[2] + vp[2] ; } +int +max_index(v,r) +FVECT v; +double *r; +{ + double p[3]; + int i; + p[0] = fabs(v[0]); + p[1] = fabs(v[1]); + p[2] = fabs(v[2]); + i = (p[0]>=p[1])?((p[0]>=p[2])?0:2):((p[1]>=p[2])?1:2); + if(r) + *r = p[i]; + return(i); +} +int +closest_point_in_tri(p0,p1,p2,p,p0id,p1id,p2id) +FVECT p0,p1,p2,p; +int p0id,p1id,p2id; +{ + double d,d1; + int i; + + d = DIST_SQ(p,p0); + d1 = DIST_SQ(p,p1); + if(d < d1) + { + d1 = DIST_SQ(p,p2); + i = (d1 < d)?p2id:p0id; + } + else + { + d = DIST_SQ(p,p2); + i = (d < d1)? p2id:p1id; + } + return(i); +} + int sedge_intersect(a0,a1,b0,b1) FVECT a0,a1,b0,b1; @@ -800,7 +875,7 @@ double coord[3]; a = (x2 - x1) * (y3 - y1) - (x3 - x1) * (y2 - y1); coord[0] = ((x2 - px) * (y3 - py) - (x3 - px) * (y2 - py)) / a; coord[1] = ((x3 - px) * (y1 - py) - (x1 - px) * (y3 - py)) / a; - coord[2] = 1.0 - coord[0] - coord[1]; + coord[2] = ((x1 - px) * (y2 - py) - (x2 - px) * (y1 - py)) / a; } @@ -1013,42 +1088,369 @@ int child,next; } } + +baryi_parent(coord,i) +BCOORD coord[3]; +int i; +{ + + switch(i) { + case 0: + /* update bary for child */ + coord[0] = (coord[0] >> 1) + MAXBCOORD2; + coord[1] >>= 1; + coord[2] >>= 1; + break; + case 1: + coord[0] >>= 1; + coord[1] = (coord[1] >> 1) + MAXBCOORD2; + coord[2] >>= 1; + break; + + case 2: + coord[0] >>= 1; + coord[1] >>= 1; + coord[2] = (coord[2] >> 1) + MAXBCOORD2; + break; + + case 3: + coord[0] = MAXBCOORD2 - (coord[0] >> 1); + coord[1] = MAXBCOORD2 - (coord[1] >> 1); + coord[2] = MAXBCOORD2 - (coord[2] >> 1); + break; +#ifdef DEBUG + default: + eputs("baryi_parent():Invalid child\n"); + break; +#endif + } +} + +baryi_from_child(coord,child,next) +BCOORD coord[3]; +int child,next; +{ +#ifdef DEBUG + if(child <0 || child > 3) + { + eputs("baryi_from_child():Invalid child\n"); + return; + } + if(next <0 || next > 3) + { + eputs("baryi_from_child():Invalid next\n"); + return; + } +#endif + if(next == child) + return; + + switch(child){ + case 0: + coord[0] = 0; + coord[1] = MAXBCOORD - coord[1]; + coord[2] = MAXBCOORD - coord[2]; + break; + case 1: + coord[0] = MAXBCOORD - coord[0]; + coord[1] = 0; + coord[2] = MAXBCOORD - coord[2]; + break; + case 2: + coord[0] = MAXBCOORD - coord[0]; + coord[1] = MAXBCOORD - coord[1]; + coord[2] = 0; + break; + case 3: + switch(next){ + case 0: + coord[0] = 0; + coord[1] = MAXBCOORD - coord[1]; + coord[2] = MAXBCOORD - coord[2]; + break; + case 1: + coord[0] = MAXBCOORD - coord[0]; + coord[1] = 0; + coord[2] = MAXBCOORD - coord[2]; + break; + case 2: + coord[0] = MAXBCOORD - coord[0]; + coord[1] = MAXBCOORD - coord[1]; + coord[2] = 0; + break; + } + break; + } +} + int -max_index(v) -FVECT v; +baryi_child(coord) +BCOORD coord[3]; { - double a,b,c; int i; - a = fabs(v[0]); - b = fabs(v[1]); - c = fabs(v[2]); - i = (a>=b)?((a>=c)?0:2):((b>=c)?1:2); - return(i); + if(coord[0] > MAXBCOORD2) + { + /* update bary for child */ + coord[0] = (coord[0]<< 1) - MAXBCOORD; + coord[1] <<= 1; + coord[2] <<= 1; + return(0); + } + else + if(coord[1] > MAXBCOORD2) + { + coord[0] <<= 1; + coord[1] = (coord[1] << 1) - MAXBCOORD; + coord[2] <<= 1; + return(1); + } + else + if(coord[2] > MAXBCOORD2) + { + coord[0] <<= 1; + coord[1] <<= 1; + coord[2] = (coord[2] << 1) - MAXBCOORD; + return(2); + } + else + { + coord[0] = MAXBCOORD - (coord[0] << 1); + coord[1] = MAXBCOORD - (coord[1] << 1); + coord[2] = MAXBCOORD - (coord[2] << 1); + return(3); + } } int -closest_point_in_tri(p0,p1,p2,p,p0id,p1id,p2id) -FVECT p0,p1,p2,p; -int p0id,p1id,p2id; +baryi_nth_child(coord,i) +BCOORD coord[3]; +int i; { - double d,d1; - int i; + + switch(i){ + case 0: + /* update bary for child */ + coord[0] = (coord[0]<< 1) - MAXBCOORD; + coord[1] <<= 1; + coord[2] <<= 1; + break; + case 1: + coord[0] <<= 1; + coord[1] = (coord[1] << 1) - MAXBCOORD; + coord[2] <<= 1; + break; + case 2: + coord[0] <<= 1; + coord[1] <<= 1; + coord[2] = (coord[2] << 1) - MAXBCOORD; + break; + case 3: + coord[0] = MAXBCOORD - (coord[0] << 1); + coord[1] = MAXBCOORD - (coord[1] << 1); + coord[2] = MAXBCOORD - (coord[2] << 1); + break; + } +} + + +baryi_children(coord,i,in_tri,rcoord,rin_tri) +BCOORD coord[3][3]; +int i; +int in_tri[3]; +BCOORD rcoord[3][3]; +int rin_tri[3]; +{ + int j; + + for(j=0; j< 3; j++) + { + if(!in_tri[j]) + { + rin_tri[j]=0; + continue; + } - d = DIST_SQ(p,p0); - d1 = DIST_SQ(p,p1); - if(d < d1) + if(i != 3) { - d1 = DIST_SQ(p,p2); - i = (d1 < d)?p2id:p0id; + if(coord[j][i] < MAXBCOORD2) + { + rin_tri[j] = 0; + continue; + } } else + if( !(coord[j][0] <= MAXBCOORD2 && coord[j][1] <= MAXBCOORD2 && + coord[j][2] <= MAXBCOORD2)) + { + rin_tri[j] = 0; + continue; + } + + rin_tri[j]=1; + VCOPY(rcoord[j],coord[j]); + baryi_nth_child(rcoord[j],i); + } + +} + +convert_dtol(b,bi) +double b[3]; +BCOORD bi[3]; +{ + int i; + + for(i=0; i < 2;i++) + { + + if(b[i] <= 0.0) { - d = DIST_SQ(p,p2); - i = (d < d1)? p2id:p1id; +#ifdef EXTRA_DEBUG + if(b[i] < 0.0) + printf("under %f\n",b[i]); +#endif + bi[i]= 0; } - return(i); + else + if(b[i] >= 1.0) + { +#ifdef EXTRA_DEBUG + if(b[i] > 1.0) + printf("over %f\n",b[i]); +#endif + bi[i]= MAXBCOORD; + } + else + bi[i] = (BCOORD)(b[i]*MAXBCOORD); + } + bi[2] = bi[0] + bi[1]; + if(bi[2] > MAXBCOORD) + { +#ifdef EXTRA_DEBUG + printf("sum over %f\n",b[0]+b[1]); +#endif + bi[2] = 0; + bi[1] = MAXBCOORD - bi[0]; + } + else + bi[2] = MAXBCOORD - bi[2]; + } + +/* convert barycentric coordinate b in [-eps,1+eps] to [0,MAXLONG], + dir unbounded to [-MAXLONG,MAXLONG] + */ +bary_dtol(b,db,bi,dbi,t,w) +double b[3],db[3][3]; +BCOORD bi[3]; +BDIR dbi[3][3]; +TINT t[3]; +int w; +{ + int i,id,j,k; + double d; + + convert_dtol(b,bi); + + for(j=w; j< 3; j++) + { + if(t[j] == HUGET) + { + max_index(db[j],&d); + for(i=0; i< 3; i++) + dbi[j][i] = (BDIR)(db[j][i]/d*MAXBDIR); + break; + } + else + { + for(i=0; i< 3; i++) + dbi[j][i] = (BDIR)(db[j][i]*MAXBDIR); + } + } +} + + +/* convert barycentric coordinate b in [-eps,1+eps] to [0,MAXLONG], + dir unbounded to [-MAXLONG,MAXLONG] + */ +bary_dtol_new(b,db,bi,boi,dbi,t) +double b[4][3],db[3][3]; +BCOORD bi[3],boi[3][3]; +BDIR dbi[3][3]; +int t[3]; +{ + int i,id,j,k; + double d; + + convert_dtol(b[3],bi); + + for(j=0; j<3;j++) + { + if(t[j] != 1) + continue; + convert_dtol(b[j],boi[j]); + } + for(j=0; j< 3; j++) + { + k = (j+1)%3; + if(t[k]==0) + continue; + if(t[k] == -1) + { + max_index(db[j],&d); + for(i=0; i< 3; i++) + dbi[j][i] = (BDIR)(db[j][i]/d*MAXBDIR); + t[k] = 0; + } + else + if(t[j] != 1) + for(i=0; i< 3; i++) + dbi[j][i] = (BDIR)(db[j][i]*MAXBDIR); + else + for(i=0; i< 3; i++) + dbi[j][i] = boi[k][i] - boi[j][i]; + + } +} + + +bary_dtolb(b,bi,in_tri) +double b[3][3]; +BCOORD bi[3][3]; +int in_tri[3]; +{ + int i,j; + + for(j=0; j<3;j++) + { + if(!in_tri[j]) + continue; + for(i=0; i < 2;i++) + { + if(b[j][i] <= 0.0) + { + bi[j][i]= 0; + } + else + if(b[j][i] >= 1.0) + { + bi[j][i]= MAXBCOORD; + } + else + bi[j][i] = (BCOORD)(b[j][i]*MAXBCOORD); + } + bi[j][2] = MAXBCOORD - bi[j][0] - bi[j][1]; + if(bi[j][2] < 0) + { + bi[j][2] = 0; + bi[j][1] = MAXBCOORD - bi[j][0]; + } + } +} + + + +
