--- ray/src/hd/sm_geom.c 1998/08/19 17:45:24 3.1 +++ ray/src/hd/sm_geom.c 1998/08/25 11:03:28 3.3 @@ -136,10 +136,10 @@ FVECT ps,p,c; int -intersect_vector_plane(v,plane_n,plane_d,pd,r) +intersect_vector_plane(v,plane_n,plane_d,tptr,r) FVECT v,plane_n; double plane_d; - double *pd; + double *tptr; FVECT r; { double t; @@ -160,8 +160,8 @@ intersect_vector_plane(v,plane_n,plane_d,pd,r) r[0] = v[0]*t; r[1] = v[1]*t; r[2] = v[2]*t; - if(pd) - *pd = t; + if(tptr) + *tptr = t; return(hit); } @@ -179,9 +179,10 @@ intersect_ray_plane(orig,dir,plane_n,plane_d,pd,r) Plane is Ax + By + Cz +D = 0: plane[0] = A,plane[1] = B,plane[2] = C,plane[3] = D */ - /* A(orig[0] + dxt) + B(orig[1] + dyt) + C(orig[2] + dzt) + pd = 0 */ - /* t = -(DOT(plane_n,orig)+ plane_d)/(DOT(plane_n,d)) - /* line is l = p1 + (p2-p1)t */ + /* A(orig[0] + dxt) + B(orig[1] + dyt) + C(orig[2] + dzt) + pd = 0 + t = -(DOT(plane_n,orig)+ plane_d)/(DOT(plane_n,d)) + line is l = p1 + (p2-p1)t + */ /* Solve for t: */ t = -(DOT(plane_n,orig) + plane_d)/(DOT(plane_n,dir)); if(ZERO(t) || t >0) @@ -879,4 +880,190 @@ FVECT a0,a1,b0,b1; return(FALSE); return(TRUE); } + + + +/* Find the normalized barycentric coordinates of p relative to + * triangle v0,v1,v2. Return result in coord + */ +bary2d(x1,y1,x2,y2,x3,y3,px,py,coord) +double x1,y1,x2,y2,x3,y3; +double px,py; +double coord[3]; +{ + double a; + + a = (x2 - x1) * (y3 - y1) - (x3 - x1) * (y2 - y1); + coord[0] = ((x2 - px) * (y3 - py) - (x3 - px) * (y2 - py)) / a; + coord[1] = ((x3 - px) * (y1 - py) - (x1 - px) * (y3 - py)) / a; + coord[2] = 1.0 - coord[0] - coord[1]; + +} + +int +bary2d_child(coord) +double coord[3]; +{ + int i; + + /* First check if one of the original vertices */ + for(i=0;i<3;i++) + if(EQUAL(coord[i],1.0)) + return(i); + + /* Check if one of the new vertices: for all return center child */ + if(ZERO(coord[0]) && EQUAL(coord[1],0.5)) + { + coord[0] = 1.0f; + coord[1] = 0.0f; + coord[2] = 0.0f; + return(3); + } + if(ZERO(coord[1]) && EQUAL(coord[0],0.5)) + { + coord[0] = 0.0f; + coord[1] = 1.0f; + coord[2] = 0.0f; + return(3); + } + if(ZERO(coord[2]) && EQUAL(coord[0],0.5)) + { + coord[0] = 0.0f; + coord[1] = 0.0f; + coord[2] = 1.0f; + return(3); + } + + /* Otherwise return child */ + if(coord[0] > 0.5) + { + /* update bary for child */ + coord[0] = 2.0*coord[0]- 1.0; + coord[1] *= 2.0; + coord[2] *= 2.0; + return(0); + } + else + if(coord[1] > 0.5) + { + coord[0] *= 2.0; + coord[1] = 2.0*coord[1]- 1.0; + coord[2] *= 2.0; + return(1); + } + else + if(coord[2] > 0.5) + { + coord[0] *= 2.0; + coord[1] *= 2.0; + coord[2] = 2.0*coord[2]- 1.0; + return(2); + } + else + { + coord[0] = 1.0 - 2.0*coord[0]; + coord[1] = 1.0 - 2.0*coord[1]; + coord[2] = 1.0 - 2.0*coord[2]; + return(3); + } +} + +int +max_index(v) +FVECT v; +{ + double a,b,c; + int i; + + a = fabs(v[0]); + b = fabs(v[1]); + c = fabs(v[2]); + i = (a>=b)?((a>=c)?0:2):((b>=c)?1:2); + return(i); +} + + + +/* + * int + * smRay(FVECT orig, FVECT dir,FVECT v0,FVECT v1,FVECT v2,FVECT r) + * + * Intersect the ray with triangle v0v1v2, return intersection point in r + * + * Assumes orig,v0,v1,v2 are in spherical coordinates, and orig is + * unit + */ +int +traceRay(orig,dir,v0,v1,v2,r) + FVECT orig,dir; + FVECT v0,v1,v2; + FVECT r; +{ + FVECT n,p[3],d; + double pt[3],r_eps; + char i; + int which; + + /* Find the plane equation for the triangle defined by the edge v0v1 and + the view center*/ + VCROSS(n,v0,v1); + /* Intersect the ray with this plane */ + i = intersect_ray_plane(orig,dir,n,0.0,&(pt[0]),p[0]); + if(i) + which = 0; + else + which = -1; + + VCROSS(n,v1,v2); + i = intersect_ray_plane(orig,dir,n,0.0,&(pt[1]),p[1]); + if(i) + if((which==-1) || pt[1] < pt[0]) + which = 1; + + VCROSS(n,v2,v0); + i = intersect_ray_plane(orig,dir,n,0.0,&(pt[2]),p[2]); + if(i) + if((which==-1) || pt[2] < pt[which]) + which = 2; + + if(which != -1) + { + /* Return point that is K*eps along projection of the ray on + the sphere to push intersection point p[which] into next cell + */ + normalize(p[which]); + /* Calculate the ray perpendicular to the intersection point: approx + the direction moved along the sphere a distance of K*epsilon*/ + r_eps = -DOT(p[which],dir); + VSUM(n,dir,p[which],r_eps); + /* Calculate the length along ray p[which]-dir needed to move to + cause a move along the sphere of k*epsilon + */ + r_eps = DOT(n,dir); + VSUM(r,p[which],dir,(20*FTINY)/r_eps); + normalize(r); + return(TRUE); + } + else + { + /* Unable to find intersection: move along ray and try again */ + r_eps = -DOT(orig,dir); + VSUM(n,dir,orig,r_eps); + r_eps = DOT(n,dir); + VSUM(r,orig,dir,(20*FTINY)/r_eps); + normalize(r); +#ifdef DEBUG + eputs("traceRay:Ray does not intersect triangle"); +#endif + return(FALSE); + } +} + + + + + + + +
