root/radiance/ray/src/hd/sm_geom.c
Revision: 3.4
Committed: Fri Sep 11 11:52:25 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.3: +325 -258 lines
fixed triangle insertion using edge tracing
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * sm_geom.c
9 */
10
11 #include "standard.h"
12 #include "sm_geom.h"
13
14 tri_centroid(v0,v1,v2,c)
15 FVECT v0,v1,v2,c;
16 {
17 /* Average three triangle vertices to give centroid: return in c */
18 c[0] = (v0[0] + v1[0] + v2[0])/3.0;
19 c[1] = (v0[1] + v1[1] + v2[1])/3.0;
20 c[2] = (v0[2] + v1[2] + v2[2])/3.0;
21 }
22
23
24 int
25 vec3_equal(v1,v2)
26 FVECT v1,v2;
27 {
28 return(EQUAL(v1[0],v2[0]) && EQUAL(v1[1],v2[1])&& EQUAL(v1[2],v2[2]));
29 }
30
31
32 int
33 convex_angle(v0,v1,v2)
34 FVECT v0,v1,v2;
35 {
36 FVECT cp01,cp12,cp;
37
38 /* test sign of (v0Xv1)X(v1Xv2). v1 */
39 VCROSS(cp01,v0,v1);
40 VCROSS(cp12,v1,v2);
41 VCROSS(cp,cp01,cp12);
42 if(DOT(cp,v1) < 0.0)
43 return(FALSE);
44 return(TRUE);
45 }
46
47 /* calculates the normal of a face contour using Newell's formula. e
48
49 a = SUMi (yi - yi+1)(zi + zi+1)
50 b = SUMi (zi - zi+1)(xi + xi+1)
51 c = SUMi (xi - xi+1)(yi + yi+1)
52 */
53 double
54 tri_normal(v0,v1,v2,n,norm)
55 FVECT v0,v1,v2,n;
56 int norm;
57 {
58 double mag;
59
60 n[0] = (v0[2] + v1[2]) * (v0[1] - v1[1]) +
61 (v1[2] + v2[2]) * (v1[1] - v2[1]) +
62 (v2[2] + v0[2]) * (v2[1] - v0[1]);
63
64 n[1] = (v0[2] - v1[2]) * (v0[0] + v1[0]) +
65 (v1[2] - v2[2]) * (v1[0] + v2[0]) +
66 (v2[2] - v0[2]) * (v2[0] + v0[0]);
67
68
69 n[2] = (v0[1] + v1[1]) * (v0[0] - v1[0]) +
70 (v1[1] + v2[1]) * (v1[0] - v2[0]) +
71 (v2[1] + v0[1]) * (v2[0] - v0[0]);
72
73 if(!norm)
74 return(0);
75
76
77 mag = normalize(n);
78
79 return(mag);
80 }
81
82
83 tri_plane_equation(v0,v1,v2,n,nd,norm)
84 FVECT v0,v1,v2,n;
85 double *nd;
86 int norm;
87 {
88 tri_normal(v0,v1,v2,n,norm);
89
90 *nd = -(DOT(n,v0));
91 }
92
93 /* From quad_edge-code */
94 int
95 point_in_circle_thru_origin(p,p0,p1)
96 FVECT p;
97 FVECT p0,p1;
98 {
99
100 double dp0,dp1;
101 double dp,det;
102
103 dp0 = DOT_VEC2(p0,p0);
104 dp1 = DOT_VEC2(p1,p1);
105 dp = DOT_VEC2(p,p);
106
107 det = -dp0*CROSS_VEC2(p1,p) + dp1*CROSS_VEC2(p0,p) - dp*CROSS_VEC2(p0,p1);
108
109 return (det > 0);
110 }
111
112
113
114 point_on_sphere(ps,p,c)
115 FVECT ps,p,c;
116 {
117 VSUB(ps,p,c);
118 normalize(ps);
119 }
120
121
122 /* returns TRUE if ray from origin in direction v intersects plane defined
123 * by normal plane_n, and plane_d. If plane is not parallel- returns
124 * intersection point if r != NULL. If tptr!= NULL returns value of
125 * t, if parallel, returns t=FHUGE
126 */
127 int
128 intersect_vector_plane(v,plane_n,plane_d,tptr,r)
129 FVECT v,plane_n;
130 double plane_d;
131 double *tptr;
132 FVECT r;
133 {
134 double t,d;
135 int hit;
136 /*
137 Plane is Ax + By + Cz +D = 0:
138 plane[0] = A,plane[1] = B,plane[2] = C,plane[3] = D
139 */
140
141 /* line is l = p1 + (p2-p1)t, p1=origin */
142
143 /* Solve for t: */
144 d = -(DOT(plane_n,v));
145 if(ZERO(d))
146 {
147 t = FHUGE;
148 hit = 0;
149 }
150 else
151 {
152 t = plane_d/d;
153 if(t < 0 )
154 hit = 0;
155 else
156 hit = 1;
157 if(r)
158 {
159 r[0] = v[0]*t;
160 r[1] = v[1]*t;
161 r[2] = v[2]*t;
162 }
163 }
164 if(tptr)
165 *tptr = t;
166 return(hit);
167 }
168
169 int
170 intersect_ray_plane(orig,dir,plane_n,plane_d,pd,r)
171 FVECT orig,dir;
172 FVECT plane_n;
173 double plane_d;
174 double *pd;
175 FVECT r;
176 {
177 double t;
178 int hit;
179 /*
180 Plane is Ax + By + Cz +D = 0:
181 plane[0] = A,plane[1] = B,plane[2] = C,plane[3] = D
182 */
183 /* A(orig[0] + dxt) + B(orig[1] + dyt) + C(orig[2] + dzt) + pd = 0
184 t = -(DOT(plane_n,orig)+ plane_d)/(DOT(plane_n,d))
185 line is l = p1 + (p2-p1)t
186 */
187 /* Solve for t: */
188 t = -(DOT(plane_n,orig) + plane_d)/(DOT(plane_n,dir));
189 if(t < 0)
190 hit = 0;
191 else
192 hit = 1;
193
194 if(r)
195 VSUM(r,orig,dir,t);
196
197 if(pd)
198 *pd = t;
199 return(hit);
200 }
201
202
203 int
204 intersect_edge_plane(e0,e1,plane_n,plane_d,pd,r)
205 FVECT e0,e1;
206 FVECT plane_n;
207 double plane_d;
208 double *pd;
209 FVECT r;
210 {
211 double t;
212 int hit;
213 FVECT d;
214 /*
215 Plane is Ax + By + Cz +D = 0:
216 plane[0] = A,plane[1] = B,plane[2] = C,plane[3] = D
217 */
218 /* A(orig[0] + dxt) + B(orig[1] + dyt) + C(orig[2] + dzt) + pd = 0
219 t = -(DOT(plane_n,orig)+ plane_d)/(DOT(plane_n,d))
220 line is l = p1 + (p2-p1)t
221 */
222 /* Solve for t: */
223 VSUB(d,e1,e0);
224 t = -(DOT(plane_n,e0) + plane_d)/(DOT(plane_n,d));
225 if(t < 0)
226 hit = 0;
227 else
228 hit = 1;
229
230 VSUM(r,e0,d,t);
231
232 if(pd)
233 *pd = t;
234 return(hit);
235 }
236
237
238 int
239 point_in_cone(p,p0,p1,p2)
240 FVECT p;
241 FVECT p0,p1,p2;
242 {
243 FVECT n;
244 FVECT np,x_axis,y_axis;
245 double d1,d2,d;
246
247 /* Find the equation of the circle defined by the intersection
248 of the cone with the plane defined by p1,p2,p3- project p into
249 that plane and do an in-circle test in the plane
250 */
251
252 /* find the equation of the plane defined by p1-p3 */
253 tri_plane_equation(p0,p1,p2,n,&d,FALSE);
254
255 /* define a coordinate system on the plane: the x axis is in
256 the direction of np2-np1, and the y axis is calculated from
257 n cross x-axis
258 */
259 /* Project p onto the plane */
260 /* NOTE: check this: does sideness check?*/
261 if(!intersect_vector_plane(p,n,d,NULL,np))
262 return(FALSE);
263
264 /* create coordinate system on plane: p2-p1 defines the x_axis*/
265 VSUB(x_axis,p1,p0);
266 normalize(x_axis);
267 /* The y axis is */
268 VCROSS(y_axis,n,x_axis);
269 normalize(y_axis);
270
271 VSUB(p1,p1,p0);
272 VSUB(p2,p2,p0);
273 VSUB(np,np,p0);
274
275 p1[0] = VLEN(p1);
276 p1[1] = 0;
277
278 d1 = DOT(p2,x_axis);
279 d2 = DOT(p2,y_axis);
280 p2[0] = d1;
281 p2[1] = d2;
282
283 d1 = DOT(np,x_axis);
284 d2 = DOT(np,y_axis);
285 np[0] = d1;
286 np[1] = d2;
287
288 /* perform the in-circle test in the new coordinate system */
289 return(point_in_circle_thru_origin(np,p1,p2));
290 }
291
292 int
293 point_set_in_stri(v0,v1,v2,p,n,nset,sides)
294 FVECT v0,v1,v2,p;
295 FVECT n[3];
296 int *nset;
297 int sides[3];
298
299 {
300 double d;
301 /* Find the normal to the triangle ORIGIN:v0:v1 */
302 if(!NTH_BIT(*nset,0))
303 {
304 VCROSS(n[0],v1,v0);
305 SET_NTH_BIT(*nset,0);
306 }
307 /* Test the point for sidedness */
308 d = DOT(n[0],p);
309
310 if(d > 0.0)
311 {
312 sides[0] = GT_OUT;
313 sides[1] = sides[2] = GT_INVALID;
314 return(FALSE);
315 }
316 else
317 sides[0] = GT_INTERIOR;
318
319 /* Test next edge */
320 if(!NTH_BIT(*nset,1))
321 {
322 VCROSS(n[1],v2,v1);
323 SET_NTH_BIT(*nset,1);
324 }
325 /* Test the point for sidedness */
326 d = DOT(n[1],p);
327 if(d > 0.0)
328 {
329 sides[1] = GT_OUT;
330 sides[2] = GT_INVALID;
331 return(FALSE);
332 }
333 else
334 sides[1] = GT_INTERIOR;
335 /* Test next edge */
336 if(!NTH_BIT(*nset,2))
337 {
338 VCROSS(n[2],v0,v2);
339 SET_NTH_BIT(*nset,2);
340 }
341 /* Test the point for sidedness */
342 d = DOT(n[2],p);
343 if(d > 0.0)
344 {
345 sides[2] = GT_OUT;
346 return(FALSE);
347 }
348 else
349 sides[2] = GT_INTERIOR;
350 /* Must be interior to the pyramid */
351 return(GT_INTERIOR);
352 }
353
354
355
356
357 int
358 point_in_stri(v0,v1,v2,p)
359 FVECT v0,v1,v2,p;
360 {
361 double d;
362 FVECT n;
363
364 VCROSS(n,v1,v0);
365 /* Test the point for sidedness */
366 d = DOT(n,p);
367 if(d > 0.0)
368 return(FALSE);
369
370 /* Test next edge */
371 VCROSS(n,v2,v1);
372 /* Test the point for sidedness */
373 d = DOT(n,p);
374 if(d > 0.0)
375 return(FALSE);
376
377 /* Test next edge */
378 VCROSS(n,v0,v2);
379 /* Test the point for sidedness */
380 d = DOT(n,p);
381 if(d > 0.0)
382 return(FALSE);
383 /* Must be interior to the pyramid */
384 return(GT_INTERIOR);
385 }
386
387 int
388 vertices_in_stri(t0,t1,t2,p0,p1,p2,nset,n,avg,pt_sides)
389 FVECT t0,t1,t2,p0,p1,p2;
390 int *nset;
391 FVECT n[3];
392 FVECT avg;
393 int pt_sides[3][3];
394
395 {
396 int below_plane[3],test;
397
398 SUM_3VEC3(avg,t0,t1,t2);
399 *nset = 0;
400 /* Test vertex v[i] against triangle j*/
401 /* Check if v[i] lies below plane defined by avg of 3 vectors
402 defining triangle
403 */
404
405 /* test point 0 */
406 if(DOT(avg,p0) < 0.0)
407 below_plane[0] = 1;
408 else
409 below_plane[0] = 0;
410 /* Test if b[i] lies in or on triangle a */
411 test = point_set_in_stri(t0,t1,t2,p0,n,nset,pt_sides[0]);
412 /* If pts[i] is interior: done */
413 if(!below_plane[0])
414 {
415 if(test == GT_INTERIOR)
416 return(TRUE);
417 }
418 /* Now test point 1*/
419
420 if(DOT(avg,p1) < 0.0)
421 below_plane[1] = 1;
422 else
423 below_plane[1]=0;
424 /* Test if b[i] lies in or on triangle a */
425 test = point_set_in_stri(t0,t1,t2,p1,n,nset,pt_sides[1]);
426 /* If pts[i] is interior: done */
427 if(!below_plane[1])
428 {
429 if(test == GT_INTERIOR)
430 return(TRUE);
431 }
432
433 /* Now test point 2 */
434 if(DOT(avg,p2) < 0.0)
435 below_plane[2] = 1;
436 else
437 below_plane[2] = 0;
438 /* Test if b[i] lies in or on triangle a */
439 test = point_set_in_stri(t0,t1,t2,p2,n,nset,pt_sides[2]);
440
441 /* If pts[i] is interior: done */
442 if(!below_plane[2])
443 {
444 if(test == GT_INTERIOR)
445 return(TRUE);
446 }
447
448 /* If all three points below separating plane: trivial reject */
449 if(below_plane[0] && below_plane[1] && below_plane[2])
450 return(FALSE);
451 /* Now check vertices in a against triangle b */
452 return(FALSE);
453 }
454
455
456 set_sidedness_tests(t0,t1,t2,p0,p1,p2,test,sides,nset,n)
457 FVECT t0,t1,t2,p0,p1,p2;
458 int test[3];
459 int sides[3][3];
460 int nset;
461 FVECT n[3];
462 {
463 int t;
464 double d;
465
466
467 /* p=0 */
468 test[0] = 0;
469 if(sides[0][0] == GT_INVALID)
470 {
471 if(!NTH_BIT(nset,0))
472 VCROSS(n[0],t1,t0);
473 /* Test the point for sidedness */
474 d = DOT(n[0],p0);
475 if(d >= 0.0)
476 SET_NTH_BIT(test[0],0);
477 }
478 else
479 if(sides[0][0] != GT_INTERIOR)
480 SET_NTH_BIT(test[0],0);
481
482 if(sides[0][1] == GT_INVALID)
483 {
484 if(!NTH_BIT(nset,1))
485 VCROSS(n[1],t2,t1);
486 /* Test the point for sidedness */
487 d = DOT(n[1],p0);
488 if(d >= 0.0)
489 SET_NTH_BIT(test[0],1);
490 }
491 else
492 if(sides[0][1] != GT_INTERIOR)
493 SET_NTH_BIT(test[0],1);
494
495 if(sides[0][2] == GT_INVALID)
496 {
497 if(!NTH_BIT(nset,2))
498 VCROSS(n[2],t0,t2);
499 /* Test the point for sidedness */
500 d = DOT(n[2],p0);
501 if(d >= 0.0)
502 SET_NTH_BIT(test[0],2);
503 }
504 else
505 if(sides[0][2] != GT_INTERIOR)
506 SET_NTH_BIT(test[0],2);
507
508 /* p=1 */
509 test[1] = 0;
510 /* t=0*/
511 if(sides[1][0] == GT_INVALID)
512 {
513 if(!NTH_BIT(nset,0))
514 VCROSS(n[0],t1,t0);
515 /* Test the point for sidedness */
516 d = DOT(n[0],p1);
517 if(d >= 0.0)
518 SET_NTH_BIT(test[1],0);
519 }
520 else
521 if(sides[1][0] != GT_INTERIOR)
522 SET_NTH_BIT(test[1],0);
523
524 /* t=1 */
525 if(sides[1][1] == GT_INVALID)
526 {
527 if(!NTH_BIT(nset,1))
528 VCROSS(n[1],t2,t1);
529 /* Test the point for sidedness */
530 d = DOT(n[1],p1);
531 if(d >= 0.0)
532 SET_NTH_BIT(test[1],1);
533 }
534 else
535 if(sides[1][1] != GT_INTERIOR)
536 SET_NTH_BIT(test[1],1);
537
538 /* t=2 */
539 if(sides[1][2] == GT_INVALID)
540 {
541 if(!NTH_BIT(nset,2))
542 VCROSS(n[2],t0,t2);
543 /* Test the point for sidedness */
544 d = DOT(n[2],p1);
545 if(d >= 0.0)
546 SET_NTH_BIT(test[1],2);
547 }
548 else
549 if(sides[1][2] != GT_INTERIOR)
550 SET_NTH_BIT(test[1],2);
551
552 /* p=2 */
553 test[2] = 0;
554 /* t = 0 */
555 if(sides[2][0] == GT_INVALID)
556 {
557 if(!NTH_BIT(nset,0))
558 VCROSS(n[0],t1,t0);
559 /* Test the point for sidedness */
560 d = DOT(n[0],p2);
561 if(d >= 0.0)
562 SET_NTH_BIT(test[2],0);
563 }
564 else
565 if(sides[2][0] != GT_INTERIOR)
566 SET_NTH_BIT(test[2],0);
567 /* t=1 */
568 if(sides[2][1] == GT_INVALID)
569 {
570 if(!NTH_BIT(nset,1))
571 VCROSS(n[1],t2,t1);
572 /* Test the point for sidedness */
573 d = DOT(n[1],p2);
574 if(d >= 0.0)
575 SET_NTH_BIT(test[2],1);
576 }
577 else
578 if(sides[2][1] != GT_INTERIOR)
579 SET_NTH_BIT(test[2],1);
580 /* t=2 */
581 if(sides[2][2] == GT_INVALID)
582 {
583 if(!NTH_BIT(nset,2))
584 VCROSS(n[2],t0,t2);
585 /* Test the point for sidedness */
586 d = DOT(n[2],p2);
587 if(d >= 0.0)
588 SET_NTH_BIT(test[2],2);
589 }
590 else
591 if(sides[2][2] != GT_INTERIOR)
592 SET_NTH_BIT(test[2],2);
593 }
594
595
596 int
597 stri_intersect(a1,a2,a3,b1,b2,b3)
598 FVECT a1,a2,a3,b1,b2,b3;
599 {
600 int which,test,n_set[2];
601 int sides[2][3][3],i,j,inext,jnext;
602 int tests[2][3];
603 FVECT n[2][3],p,avg[2];
604
605 /* Test the vertices of triangle a against the pyramid formed by triangle
606 b and the origin. If any vertex of a is interior to triangle b, or
607 if all 3 vertices of a are ON the edges of b,return TRUE. Remember
608 the results of the edge normal and sidedness tests for later.
609 */
610 if(vertices_in_stri(a1,a2,a3,b1,b2,b3,&(n_set[0]),n[0],avg[0],sides[1]))
611 return(TRUE);
612
613 if(vertices_in_stri(b1,b2,b3,a1,a2,a3,&(n_set[1]),n[1],avg[1],sides[0]))
614 return(TRUE);
615
616
617 set_sidedness_tests(b1,b2,b3,a1,a2,a3,tests[0],sides[0],n_set[1],n[1]);
618 if(tests[0][0]&tests[0][1]&tests[0][2])
619 return(FALSE);
620
621 set_sidedness_tests(a1,a2,a3,b1,b2,b3,tests[1],sides[1],n_set[0],n[0]);
622 if(tests[1][0]&tests[1][1]&tests[1][2])
623 return(FALSE);
624
625 for(j=0; j < 3;j++)
626 {
627 jnext = (j+1)%3;
628 /* IF edge b doesnt cross any great circles of a, punt */
629 if(tests[1][j] & tests[1][jnext])
630 continue;
631 for(i=0;i<3;i++)
632 {
633 inext = (i+1)%3;
634 /* IF edge a doesnt cross any great circles of b, punt */
635 if(tests[0][i] & tests[0][inext])
636 continue;
637 /* Now find the great circles that cross and test */
638 if((NTH_BIT(tests[0][i],j)^(NTH_BIT(tests[0][inext],j)))
639 && (NTH_BIT(tests[1][j],i)^NTH_BIT(tests[1][jnext],i)))
640 {
641 VCROSS(p,n[0][i],n[1][j]);
642
643 /* If zero cp= done */
644 if(ZERO_VEC3(p))
645 continue;
646 /* check above both planes */
647 if(DOT(avg[0],p) < 0 || DOT(avg[1],p) < 0)
648 {
649 NEGATE_VEC3(p);
650 if(DOT(avg[0],p) < 0 || DOT(avg[1],p) < 0)
651 continue;
652 }
653 return(TRUE);
654 }
655 }
656 }
657 return(FALSE);
658 }
659
660 int
661 ray_intersect_tri(orig,dir,v0,v1,v2,pt)
662 FVECT orig,dir;
663 FVECT v0,v1,v2;
664 FVECT pt;
665 {
666 FVECT p0,p1,p2,p,n;
667 double pd;
668 int type;
669
670 point_on_sphere(p0,v0,orig);
671 point_on_sphere(p1,v1,orig);
672 point_on_sphere(p2,v2,orig);
673
674 if(point_in_stri(p0,p1,p2,dir))
675 {
676 /* Intersect the ray with the triangle plane */
677 tri_plane_equation(v0,v1,v2,n,&pd,FALSE);
678 return(intersect_ray_plane(orig,dir,n,pd,NULL,pt));
679 }
680 return(FALSE);
681 }
682
683
684 calculate_view_frustum(vp,hv,vv,horiz,vert,near,far,fnear,ffar)
685 FVECT vp,hv,vv;
686 double horiz,vert,near,far;
687 FVECT fnear[4],ffar[4];
688 {
689 double height,width;
690 FVECT t,nhv,nvv,ndv;
691 double w2,h2;
692 /* Calculate the x and y dimensions of the near face */
693 /* hv and vv are the horizontal and vertical vectors in the
694 view frame-the magnitude is the dimension of the front frustum
695 face at z =1
696 */
697 VCOPY(nhv,hv);
698 VCOPY(nvv,vv);
699 w2 = normalize(nhv);
700 h2 = normalize(nvv);
701 /* Use similar triangles to calculate the dimensions at z=near */
702 width = near*0.5*w2;
703 height = near*0.5*h2;
704
705 VCROSS(ndv,nvv,nhv);
706 /* Calculate the world space points corresponding to the 4 corners
707 of the front face of the view frustum
708 */
709 fnear[0][0] = width*nhv[0] + height*nvv[0] + near*ndv[0] + vp[0] ;
710 fnear[0][1] = width*nhv[1] + height*nvv[1] + near*ndv[1] + vp[1];
711 fnear[0][2] = width*nhv[2] + height*nvv[2] + near*ndv[2] + vp[2];
712 fnear[1][0] = -width*nhv[0] + height*nvv[0] + near*ndv[0] + vp[0];
713 fnear[1][1] = -width*nhv[1] + height*nvv[1] + near*ndv[1] + vp[1];
714 fnear[1][2] = -width*nhv[2] + height*nvv[2] + near*ndv[2] + vp[2];
715 fnear[2][0] = -width*nhv[0] - height*nvv[0] + near*ndv[0] + vp[0];
716 fnear[2][1] = -width*nhv[1] - height*nvv[1] + near*ndv[1] + vp[1];
717 fnear[2][2] = -width*nhv[2] - height*nvv[2] + near*ndv[2] + vp[2];
718 fnear[3][0] = width*nhv[0] - height*nvv[0] + near*ndv[0] + vp[0];
719 fnear[3][1] = width*nhv[1] - height*nvv[1] + near*ndv[1] + vp[1];
720 fnear[3][2] = width*nhv[2] - height*nvv[2] + near*ndv[2] + vp[2];
721
722 /* Now do the far face */
723 width = far*0.5*w2;
724 height = far*0.5*h2;
725 ffar[0][0] = width*nhv[0] + height*nvv[0] + far*ndv[0] + vp[0] ;
726 ffar[0][1] = width*nhv[1] + height*nvv[1] + far*ndv[1] + vp[1] ;
727 ffar[0][2] = width*nhv[2] + height*nvv[2] + far*ndv[2] + vp[2] ;
728 ffar[1][0] = -width*nhv[0] + height*nvv[0] + far*ndv[0] + vp[0] ;
729 ffar[1][1] = -width*nhv[1] + height*nvv[1] + far*ndv[1] + vp[1] ;
730 ffar[1][2] = -width*nhv[2] + height*nvv[2] + far*ndv[2] + vp[2] ;
731 ffar[2][0] = -width*nhv[0] - height*nvv[0] + far*ndv[0] + vp[0] ;
732 ffar[2][1] = -width*nhv[1] - height*nvv[1] + far*ndv[1] + vp[1] ;
733 ffar[2][2] = -width*nhv[2] - height*nvv[2] + far*ndv[2] + vp[2] ;
734 ffar[3][0] = width*nhv[0] - height*nvv[0] + far*ndv[0] + vp[0] ;
735 ffar[3][1] = width*nhv[1] - height*nvv[1] + far*ndv[1] + vp[1] ;
736 ffar[3][2] = width*nhv[2] - height*nvv[2] + far*ndv[2] + vp[2] ;
737 }
738
739
740
741
742 int
743 sedge_intersect(a0,a1,b0,b1)
744 FVECT a0,a1,b0,b1;
745 {
746 FVECT na,nb,avga,avgb,p;
747 double d;
748 int sb0,sb1,sa0,sa1;
749
750 /* First test if edge b straddles great circle of a */
751 VCROSS(na,a0,a1);
752 d = DOT(na,b0);
753 sb0 = ZERO(d)?0:(d<0)? -1: 1;
754 d = DOT(na,b1);
755 sb1 = ZERO(d)?0:(d<0)? -1: 1;
756 /* edge b entirely on one side of great circle a: edges cannot intersect*/
757 if(sb0*sb1 > 0)
758 return(FALSE);
759 /* test if edge a straddles great circle of b */
760 VCROSS(nb,b0,b1);
761 d = DOT(nb,a0);
762 sa0 = ZERO(d)?0:(d<0)? -1: 1;
763 d = DOT(nb,a1);
764 sa1 = ZERO(d)?0:(d<0)? -1: 1;
765 /* edge a entirely on one side of great circle b: edges cannot intersect*/
766 if(sa0*sa1 > 0)
767 return(FALSE);
768
769 /* Find one of intersection points of the great circles */
770 VCROSS(p,na,nb);
771 /* If they lie on same great circle: call an intersection */
772 if(ZERO_VEC3(p))
773 return(TRUE);
774
775 VADD(avga,a0,a1);
776 VADD(avgb,b0,b1);
777 if(DOT(avga,p) < 0 || DOT(avgb,p) < 0)
778 {
779 NEGATE_VEC3(p);
780 if(DOT(avga,p) < 0 || DOT(avgb,p) < 0)
781 return(FALSE);
782 }
783 if((!sb0 || !sb1) && (!sa0 || !sa1))
784 return(FALSE);
785 return(TRUE);
786 }
787
788
789
790 /* Find the normalized barycentric coordinates of p relative to
791 * triangle v0,v1,v2. Return result in coord
792 */
793 bary2d(x1,y1,x2,y2,x3,y3,px,py,coord)
794 double x1,y1,x2,y2,x3,y3;
795 double px,py;
796 double coord[3];
797 {
798 double a;
799
800 a = (x2 - x1) * (y3 - y1) - (x3 - x1) * (y2 - y1);
801 coord[0] = ((x2 - px) * (y3 - py) - (x3 - px) * (y2 - py)) / a;
802 coord[1] = ((x3 - px) * (y1 - py) - (x1 - px) * (y3 - py)) / a;
803 coord[2] = 1.0 - coord[0] - coord[1];
804
805 }
806
807 bary_ith_child(coord,i)
808 double coord[3];
809 int i;
810 {
811
812 switch(i){
813 case 0:
814 /* update bary for child */
815 coord[0] = 2.0*coord[0]- 1.0;
816 coord[1] *= 2.0;
817 coord[2] *= 2.0;
818 break;
819 case 1:
820 coord[0] *= 2.0;
821 coord[1] = 2.0*coord[1]- 1.0;
822 coord[2] *= 2.0;
823 break;
824 case 2:
825 coord[0] *= 2.0;
826 coord[1] *= 2.0;
827 coord[2] = 2.0*coord[2]- 1.0;
828 break;
829 case 3:
830 coord[0] = 1.0 - 2.0*coord[0];
831 coord[1] = 1.0 - 2.0*coord[1];
832 coord[2] = 1.0 - 2.0*coord[2];
833 break;
834 #ifdef DEBUG
835 default:
836 eputs("bary_ith_child():Invalid child\n");
837 break;
838 #endif
839 }
840 }
841
842
843 int
844 bary_child(coord)
845 double coord[3];
846 {
847 int i;
848
849 if(coord[0] > 0.5)
850 {
851 /* update bary for child */
852 coord[0] = 2.0*coord[0]- 1.0;
853 coord[1] *= 2.0;
854 coord[2] *= 2.0;
855 return(0);
856 }
857 else
858 if(coord[1] > 0.5)
859 {
860 coord[0] *= 2.0;
861 coord[1] = 2.0*coord[1]- 1.0;
862 coord[2] *= 2.0;
863 return(1);
864 }
865 else
866 if(coord[2] > 0.5)
867 {
868 coord[0] *= 2.0;
869 coord[1] *= 2.0;
870 coord[2] = 2.0*coord[2]- 1.0;
871 return(2);
872 }
873 else
874 {
875 coord[0] = 1.0 - 2.0*coord[0];
876 coord[1] = 1.0 - 2.0*coord[1];
877 coord[2] = 1.0 - 2.0*coord[2];
878 return(3);
879 }
880 }
881
882 /* Coord was the ith child of the parent: set the coordinate
883 relative to the parent
884 */
885 bary_parent(coord,i)
886 double coord[3];
887 int i;
888 {
889
890 switch(i) {
891 case 0:
892 /* update bary for child */
893 coord[0] = coord[0]*0.5 + 0.5;
894 coord[1] *= 0.5;
895 coord[2] *= 0.5;
896 break;
897 case 1:
898 coord[0] *= 0.5;
899 coord[1] = coord[1]*0.5 + 0.5;
900 coord[2] *= 0.5;
901 break;
902
903 case 2:
904 coord[0] *= 0.5;
905 coord[1] *= 0.5;
906 coord[2] = coord[2]*0.5 + 0.5;
907 break;
908
909 case 3:
910 coord[0] = 0.5 - 0.5*coord[0];
911 coord[1] = 0.5 - 0.5*coord[1];
912 coord[2] = 0.5 - 0.5*coord[2];
913 break;
914 #ifdef DEBUG
915 default:
916 eputs("bary_parent():Invalid child\n");
917 break;
918 #endif
919 }
920 }
921
922 bary_from_child(coord,child,next)
923 double coord[3];
924 int child,next;
925 {
926 #ifdef DEBUG
927 if(child <0 || child > 3)
928 {
929 eputs("bary_from_child():Invalid child\n");
930 return;
931 }
932 if(next <0 || next > 3)
933 {
934 eputs("bary_from_child():Invalid next\n");
935 return;
936 }
937 #endif
938 if(next == child)
939 return;
940
941 switch(child){
942 case 0:
943 switch(next){
944 case 1:
945 coord[0] += 1.0;
946 coord[1] -= 1.0;
947 break;
948 case 2:
949 coord[0] += 1.0;
950 coord[2] -= 1.0;
951 break;
952 case 3:
953 coord[0] *= -1.0;
954 coord[1] = 1 - coord[1];
955 coord[2] = 1 - coord[2];
956 break;
957
958 }
959 break;
960 case 1:
961 switch(next){
962 case 0:
963 coord[0] -= 1.0;
964 coord[1] += 1.0;
965 break;
966 case 2:
967 coord[1] += 1.0;
968 coord[2] -= 1.0;
969 break;
970 case 3:
971 coord[0] = 1 - coord[0];
972 coord[1] *= -1.0;
973 coord[2] = 1 - coord[2];
974 break;
975 }
976 break;
977 case 2:
978 switch(next){
979 case 0:
980 coord[0] -= 1.0;
981 coord[2] += 1.0;
982 break;
983 case 1:
984 coord[1] -= 1.0;
985 coord[2] += 1.0;
986 break;
987 case 3:
988 coord[0] = 1 - coord[0];
989 coord[1] = 1 - coord[1];
990 coord[2] *= -1.0;
991 break;
992 }
993 break;
994 case 3:
995 switch(next){
996 case 0:
997 coord[0] *= -1.0;
998 coord[1] = 1 - coord[1];
999 coord[2] = 1 - coord[2];
1000 break;
1001 case 1:
1002 coord[0] = 1 - coord[0];
1003 coord[1] *= -1.0;
1004 coord[2] = 1 - coord[2];
1005 break;
1006 case 2:
1007 coord[0] = 1 - coord[0];
1008 coord[1] = 1 - coord[1];
1009 coord[2] *= -1.0;
1010 break;
1011 }
1012 break;
1013 }
1014 }
1015
1016 int
1017 max_index(v)
1018 FVECT v;
1019 {
1020 double a,b,c;
1021 int i;
1022
1023 a = fabs(v[0]);
1024 b = fabs(v[1]);
1025 c = fabs(v[2]);
1026 i = (a>=b)?((a>=c)?0:2):((b>=c)?1:2);
1027 return(i);
1028 }
1029
1030
1031
1032 /*
1033 * int
1034 * traceRay(FVECT orig, FVECT dir,FVECT v0,FVECT v1,FVECT v2,FVECT r)
1035 *
1036 * Intersect the ray with triangle v0v1v2, return intersection point in r
1037 *
1038 * Assumes orig,v0,v1,v2 are in spherical coordinates, and orig is
1039 * unit
1040 */
1041 int
1042 traceRay(orig,dir,v0,v1,v2,r)
1043 FVECT orig,dir;
1044 FVECT v0,v1,v2;
1045 FVECT r;
1046 {
1047 FVECT n,p[3],d;
1048 double pt[3],r_eps;
1049 int i;
1050 int which;
1051
1052 /* Find the plane equation for the triangle defined by the edge v0v1 and
1053 the view center*/
1054 VCROSS(n,v0,v1);
1055 /* Intersect the ray with this plane */
1056 i = intersect_ray_plane(orig,dir,n,0.0,&(pt[0]),p[0]);
1057 if(i)
1058 which = 0;
1059 else
1060 which = -1;
1061
1062 VCROSS(n,v1,v2);
1063 i = intersect_ray_plane(orig,dir,n,0.0,&(pt[1]),p[1]);
1064 if(i)
1065 if((which==-1) || pt[1] < pt[0])
1066 which = 1;
1067
1068 VCROSS(n,v2,v0);
1069 i = intersect_ray_plane(orig,dir,n,0.0,&(pt[2]),p[2]);
1070 if(i)
1071 if((which==-1) || pt[2] < pt[which])
1072 which = 2;
1073
1074 if(which != -1)
1075 {
1076 /* Return point that is K*eps along projection of the ray on
1077 the sphere to push intersection point p[which] into next cell
1078 */
1079 normalize(p[which]);
1080 /* Calculate the ray perpendicular to the intersection point: approx
1081 the direction moved along the sphere a distance of K*epsilon*/
1082 r_eps = -DOT(p[which],dir);
1083 VSUM(n,dir,p[which],r_eps);
1084 /* Calculate the length along ray p[which]-dir needed to move to
1085 cause a move along the sphere of k*epsilon
1086 */
1087 r_eps = DOT(n,dir);
1088 VSUM(r,p[which],dir,(20*FTINY)/r_eps);
1089 normalize(r);
1090 return(TRUE);
1091 }
1092 else
1093 {
1094 /* Unable to find intersection: move along ray and try again */
1095 r_eps = -DOT(orig,dir);
1096 VSUM(n,dir,orig,r_eps);
1097 r_eps = DOT(n,dir);
1098 VSUM(r,orig,dir,(20*FTINY)/r_eps);
1099 normalize(r);
1100 #ifdef DEBUG
1101 eputs("traceRay:Ray does not intersect triangle\n");
1102 #endif
1103 return(FALSE);
1104 }
1105 }
1106
1107
1108 int
1109 closest_point_in_tri(p0,p1,p2,p,p0id,p1id,p2id)
1110 FVECT p0,p1,p2,p;
1111 int p0id,p1id,p2id;
1112 {
1113 double d,d1;
1114 int i;
1115
1116 d = DIST_SQ(p,p0);
1117 d1 = DIST_SQ(p,p1);
1118 if(d < d1)
1119 {
1120 d1 = DIST_SQ(p,p2);
1121 i = (d1 < d)?p2id:p0id;
1122 }
1123 else
1124 {
1125 d = DIST_SQ(p,p2);
1126 i = (d < d1)? p2id:p1id;
1127 }
1128 return(i);
1129 }
1130
1131
1132
1133
1134
1135
1136
