--- ray/src/hd/sm_del.c 1998/12/28 18:07:34 3.8 +++ ray/src/hd/sm_del.c 1999/01/05 16:52:37 3.9 @@ -47,30 +47,18 @@ int t_id; to id because the vertices can no longer point to tri id as being the first triangle pointer */ + SM_SAMPLE_TRIS(sm)--; if(!SM_IS_NTH_T_BASE(sm,t_id)) { - SM_SAMPLE_TRIS(sm)--; + +#if 0 if(SM_IS_NTH_T_NEW(sm,t_id)) smNew_tri_cnt--; +#endif } smClear_tri_flags(sm,t_id); smFree_tri(sm,t_id); - -#if 0 - { - int i; - TRI *t; - for(i=0; i < SM_NUM_TRI(sm);i++) - { - t = SM_NTH_TRI(sm,i); - if(!T_IS_VALID(t)) - continue; - if(T_NTH_NBR(t,0)==t_id || T_NTH_NBR(t,1)==t_id || T_NTH_NBR(t,2)==t_id) - eputs("Stale pointer: smDelete_tri()\n"); - } - } -#endif }
