--- ray/src/hd/sm_del.c 1998/10/06 18:16:53 3.6 +++ ray/src/hd/sm_del.c 2003/02/22 02:07:25 3.13 @@ -1,9 +1,6 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: sm_del.c,v 3.13 2003/02/22 02:07:25 greg Exp $"; #endif - /* * sm_del.c */ @@ -11,75 +8,33 @@ static char SCCSid[] = "$SunId$ SGI"; #include "sm_flag.h" #include "sm_list.h" #include "sm_geom.h" -#include "sm_qtree.h" -#include "sm_stree.h" #include "sm.h" -static int Max_edges=200; +#define MAX_EDGE_INIT 100 +static int Max_edges= MAX_EDGE_INIT; static EDGE *Edges=NULL; static int Ecnt=0; -#define remove_tri_compress remove_tri -remove_tri(qtptr,fptr,tptr) - QUADTREE *qtptr; - int *fptr; - int *tptr; -{ - int n; - - if(QT_IS_EMPTY(*qtptr)) - return; - if(QT_LEAF_IS_FLAG(*qtptr)) - return; - - n = QT_SET_CNT(qtqueryset(*qtptr))-1; - *qtptr = qtdelelem(*qtptr,*tptr); - if(n == 0) - (*fptr) |= QT_COMPRESS; - if(!QT_FLAG_FILL_TRI(*fptr)) - (*fptr)++; -} - - -smLocator_remove_tri(sm,t_id,v0_id,v1_id,v2_id) +smFree_tri(sm,id,t) SM *sm; -int t_id; -int v0_id,v1_id,v2_id; -{ - STREE *st; - FVECT v0,v1,v2; - - st = SM_LOCATOR(sm); - - VSUB(v0,SM_NTH_WV(sm,v0_id),SM_VIEW_CENTER(sm)); - VSUB(v1,SM_NTH_WV(sm,v1_id),SM_VIEW_CENTER(sm)); - VSUB(v2,SM_NTH_WV(sm,v2_id),SM_VIEW_CENTER(sm)); - - qtClearAllFlags(); - - stApply_to_tri(st,v0,v1,v2,remove_tri,remove_tri_compress,&t_id); - -} - -smFree_tri(sm,id) -SM *sm; int id; +TRI *t; { - TRI *tri; - - tri = SM_NTH_TRI(sm,id); /* Add to the free_list */ - T_NEXT_FREE(tri) = SM_FREE_TRIS(sm); + T_NEXT_FREE(t) = SM_FREE_TRIS(sm); SM_FREE_TRIS(sm) = id; - T_VALID_FLAG(tri) = -1; +#ifdef DEBUG + T_VALID_FLAG(t) = INVALID; +#endif } /* Assumes mesh pointers have been cleaned up appropriately: just deletes from Point location and triangle data structure */ -smDelete_tri(sm,t_id) +smDelete_tri(sm,t_id,t) SM *sm; int t_id; +TRI *t; { /* NOTE: Assumes that a new triangle adjacent to each vertex @@ -88,18 +43,11 @@ int t_id; to id because the vertices can no longer point to tri id as being the first triangle pointer */ - if(!SM_IS_NTH_T_BASE(sm,t_id)) - { - SM_SAMPLE_TRIS(sm)--; - if(SM_IS_NTH_T_NEW(sm,t_id)) - smNew_tri_cnt--; - } - smClear_tri_flags(sm,t_id); + SM_CLR_NTH_T_ACTIVE(sm,t_id); + smFree_tri(sm,t_id,t); - smFree_tri(sm,t_id); } - int eNew_edge() { @@ -109,542 +57,620 @@ eNew_edge() if(Ecnt >= Max_edges) { +#ifdef DEBUG if(Max_edges > 10000) error(CONSISTENCY,"Too many edges in vertex loop\n"); +#endif Max_edges += 100; if(!(Edges = (EDGE *)realloc(Edges,(Max_edges+1)*sizeof(EDGE)))) goto memerr; } +#ifdef DEBUG + SET_E_NTH_TRI(Ecnt+1,0,INVALID); + SET_E_NTH_TRI(Ecnt+1,1,INVALID); +#endif return(++Ecnt); memerr: - error(SYSTEM,"eNew_edge(): Unable to allocate memory"); + error(SYSTEM,"eNew_edge): Unable to allocate memory"); } +/* Return list of edges defining polygon formed by boundary of triangles +adjacent to id. Return set of triangles adjacent to id to delete in delptr +*/ LIST -*smVertex_star_polygon(sm,id,delptr) +*smVertexStar(sm,id) SM *sm; -int id; -QUADTREE *delptr; +S_ID id; { TRI *tri,*t_next; LIST *elist,*end; - int t_id,v_next,t_next_id; - int e; - OBJECT del_set[2]; + int e,t_id,t_next_id,b_id,v_id,t_last_id; + S_ID v_next; elist = end = NULL; + /* Get the first triangle adjacent to vertex id */ t_id = SM_NTH_VERT(sm,id); tri = SM_NTH_TRI(sm,t_id); - if((e = eNew_edge()) == INVALID) - return(NULL); - - v_next = (T_WHICH_V(tri,id)+1)%3; - SET_E_NTH_VERT(e,0,T_NTH_V(tri,v_next)); + e = eNew_edge(); + /* Get the next vertex on the polygon boundary */ + v_id = T_WHICH_V(tri,id); + b_id = (v_id + 1)%3; + /* Create an edge */ + SET_E_NTH_VERT(e,0,T_NTH_V(tri,b_id)); SET_E_NTH_TRI(e,0,INVALID); - SET_E_NTH_TRI(e,1,T_NTH_NBR(tri,v_next)); - v_next = (T_WHICH_V(tri,id)+2)%3; - SET_E_NTH_VERT(e,1,T_NTH_V(tri,v_next)); + SET_E_NTH_TRI(e,1,T_NTH_NBR(tri,v_id)); + v_next = T_NTH_V(tri,(b_id+1)%3); + SET_E_NTH_VERT(e,1,v_next); + elist = add_data_to_circular_list(elist,&end,e); - t_next_id = t_id; t_next = tri; + t_last_id = -1; + + /* Create a set to hold all of the triangles for deletion later */ - del_set[0] =1; del_set[1] = t_id; - *delptr = qtnewleaf(del_set); - - while((t_next_id = T_NTH_NBR(t_next,v_next)) != t_id) - { - if((e = eNew_edge()) == INVALID) - return(NULL); - + while((t_next_id = T_NTH_NBR(t_next,b_id)) != t_id) + { + e = eNew_edge(); + if(t_last_id != -1) + { + smDelete_tri(sm,t_last_id,t_next); + } t_next = SM_NTH_TRI(sm,t_next_id); - v_next = (T_WHICH_V(t_next,id)+1)%3; - - SET_E_NTH_VERT(e,0,T_NTH_V(t_next,v_next)); + t_last_id = t_next_id; + SET_E_NTH_VERT(e,0,v_next); SET_E_NTH_TRI(e,0,INVALID); - SET_E_NTH_TRI(e,1,T_NTH_NBR(t_next,v_next)); - v_next = (T_WHICH_V(t_next,id)+2)%3; - SET_E_NTH_VERT(e,1,T_NTH_V(t_next,v_next)); + v_id = T_WHICH_V(t_next,id); + b_id = (v_id + 1)%3; + SET_E_NTH_TRI(e,1,T_NTH_NBR(t_next,v_id)); + v_next = T_NTH_V(t_next,(b_id+1)%3); + SET_E_NTH_VERT(e,1,v_next); elist = add_data_to_circular_list(elist,&end,e); - - if(qtinset(*delptr,t_next_id)) - { -#ifdef DEBUG - eputs("smVertex_star_polygon(): id already in set\n"); -#endif - free_list(elist); - return(NULL); - } - else - qtaddelem(*delptr,t_next_id); } - return(elist); + smDelete_tri(sm,t_last_id,t_next); + smDelete_tri(sm,t_id,tri); + return(elist); } int -smEdge_intersect_polygon(sm,v0,v1,l) +smTriangulate_add_tri(sm,id0,id1,id2,e0,e1,e2ptr) SM *sm; -FVECT v0,v1; -LIST *l; +S_ID id0,id1,id2; +int e0,e1,*e2ptr; { - FVECT e0,e1; - int e,id_e0,id_e1; - LIST *el,*eptr; - - /* Test the edges in l against v0v1 to see if v0v1 intersects - any other edges - */ - - el = l; + int t_id,e2; + TRI *t; - while(el) - { - e = (int)LIST_DATA(el); - id_e0 = E_NTH_VERT(e,0); - id_e1 = E_NTH_VERT(e,1); - - VSUB(e0,SM_NTH_WV(sm,id_e0),SM_VIEW_CENTER(sm)); - VSUB(e1,SM_NTH_WV(sm,id_e1),SM_VIEW_CENTER(sm)); - if(sedge_intersect(v0,v1,e0,e1)) - return(TRUE); - - el = LIST_NEXT(el); - if(el == l) - break; - } - return(FALSE); -} - -int -smFind_next_convex_vertex(sm,id0,id1,v0,v1,l) - SM *sm; - int id0,id1; - FVECT v0,v1; - LIST *l; -{ - int e,id; - LIST *el; - FVECT v; - - /* starting with the end of edge at head of l, search sequentially for - vertex v such that v0v1v is a convex angle, and the edge v1v does - not intersect any other edges - */ - id = INVALID; - el = l; - while(id != id0) - { - e = (int)LIST_DATA(el); - id = E_NTH_VERT(e,1); - - smDir(sm,v,id); - - if(convex_angle(v0,v1,v) && !smEdge_intersect_polygon(sm,v1,v,l)) - return(id); - - el = LIST_NEXT(el); - if(el == l) - break; - } - return(INVALID); -} - -int -split_edge_list(id0,id_new,l,lnew) -int id0,id_new; -LIST **l,**lnew; -{ - LIST *list,*lptr,*end; - int e,e1,e2,new_e; - - e2 = INVALID; - list = lptr = *l; - - if((new_e = eNew_edge())==INVALID) - { + t_id = smAdd_tri(sm,id0,id1,id2,&t); + if(*e2ptr == 0) + { + e2 = eNew_edge(); + SET_E_NTH_VERT(e2,0,id2); + SET_E_NTH_VERT(e2,1,id0); + } + else + e2 = *e2ptr; + /* set appropriate tri for each edge*/ + SET_E_NTH_TRI(e0,0,t_id); + SET_E_NTH_TRI(e1,0,t_id); + SET_E_NTH_TRI(e2,0,t_id); #ifdef DEBUG - eputs("split_edge_list():Too many edges\n"); +#if DEBUG > 1 + if(E_NTH_TRI(e0,1) == E_NTH_TRI(e0,0) || + E_NTH_TRI(e1,1) == E_NTH_TRI(e1,0) || + E_NTH_TRI(e2,1) == E_NTH_TRI(e2,0)) + error(CONSISTENCY,"Non manifold\n"); #endif - return(FALSE); - } - SET_E_NTH_VERT(new_e,0,id0); - SET_E_NTH_VERT(new_e,1,id_new); - SET_E_NTH_TRI(new_e,0,INVALID); - SET_E_NTH_TRI(new_e,1,INVALID); - - while(e2 != id_new) - { - lptr = LIST_NEXT(lptr); - e = (int)LIST_DATA(lptr); - e2 = E_NTH_VERT(e,1); - if(lptr == list) - { -#ifdef DEBUG - eputs("split_edge_list():cant find vertex\n"); #endif - *lnew = NULL; - return(FALSE); - } + *e2ptr = e2; + return(t_id); - } - end = lptr; - lptr = LIST_NEXT(lptr); - list = add_data_to_circular_list(list,&end,-new_e); - *lnew = list; - - /* now follow other cycle */ - - list = lptr; - e2 = INVALID; - while(e2 != id0) - { - lptr = LIST_NEXT(lptr); - e = (int)LIST_DATA(lptr); - e2 = E_NTH_VERT(e,1); - if(lptr == list) - { -#ifdef DEBUG - eputs("split_edge_list():cant find intial vertex\n"); -#endif - *l = NULL; - return(FALSE); - } - - } - end = lptr; - list = add_data_to_circular_list(list,&end,new_e); - *l = list; - return(TRUE); } - -int -smTriangulate_convex(sm,plist,add_ptr) -SM *sm; -LIST *plist,**add_ptr; +int +smTriangulate_quad(sm,l) + SM *sm; + LIST *l; { - int t_id,e_id0,e_id1,e_id2; - int v_id0,v_id1,v_id2; - LIST *lptr; - int cnt; + int e1,e2,e3,e4,e,t_id; + S_ID id0,id1,id2,id3; + FVECT v0,v1,v2,v3,n; + double dp; + TRI *tri; + LIST *lptr; - lptr = plist; - e_id0 = (int)LIST_DATA(lptr); - v_id0 = E_NTH_VERT(e_id0,0); - lptr = LIST_NEXT(lptr); - while(LIST_NEXT(lptr) != plist) - { - e_id1 = (int)LIST_DATA(lptr); - v_id1 = E_NTH_VERT(e_id1,0); - v_id2 = E_NTH_VERT(e_id1,1); - /* form a triangle for each triple of with v0 as base of star */ - t_id = smAdd_tri(sm,v_id0,v_id1,v_id2); - *add_ptr = push_data(*add_ptr,t_id); +#ifdef DEBUG + if(LIST_NEXT(LIST_NEXT(LIST_NEXT(LIST_NEXT(l)))) != l) + { + eputs("smTriangulate_quad(): not a quadrilateral\n"); + return(FALSE); + } + eputs("smTriangulate_quad():\n"); +#endif + lptr=l; + e1 = (int)LIST_DATA(l); + id0 = E_NTH_VERT(e1,0); + id1 = E_NTH_VERT(e1,1); + VSUB(v0,SM_NTH_WV(sm,id0),SM_VIEW_CENTER(sm)); + VSUB(v1,SM_NTH_WV(sm,id1),SM_VIEW_CENTER(sm)); + /* Get v2 */ + l = LIST_NEXT(l); + e2 = (int)LIST_DATA(l); + id2 = E_NTH_VERT(e2,1); + VSUB(v2,SM_NTH_WV(sm,id2),SM_VIEW_CENTER(sm)); + /* Get v3 */ + l = LIST_NEXT(l); + e3 = (int)LIST_DATA(l); + id3 = E_NTH_VERT(e3,1); + VSUB(v3,SM_NTH_WV(sm,id3),SM_VIEW_CENTER(sm)); + l = LIST_NEXT(l); + e4 = (int)LIST_DATA(l); + free_list(lptr); - /* add which pointer?*/ - - lptr = LIST_NEXT(lptr); - - if(LIST_NEXT(lptr) != plist) - { - e_id2 = eNew_edge(); - SET_E_NTH_VERT(e_id2,0,v_id2); - SET_E_NTH_VERT(e_id2,1,v_id0); - } - else - e_id2 = (int)LIST_DATA(lptr); - - /* set appropriate tri for each edge*/ - SET_E_NTH_TRI(e_id0,0,t_id); - SET_E_NTH_TRI(e_id1,0,t_id); - SET_E_NTH_TRI(e_id2,0,t_id); - - e_id0 = -e_id2; - } - free_list(plist); - return(TRUE); -} -int -smTriangulate_elist(sm,plist,add_ptr) -SM *sm; -LIST *plist,**add_ptr; -{ - LIST *l,*el1; - FVECT v0,v1,v2; - int id0,id1,id2,e,id_next; - char flipped; - int done; - - l = plist; - - while(l) + VCROSS(n,v0,v2); + normalize(n); + normalize(v1); + dp = DOT(n,v1); + e = 0; + if(dp > 0) + { + if(dp >= EV_EPS) { - /* get v0,v1,v2 */ - e = (int)LIST_DATA(l); - id0 = E_NTH_VERT(e,0); - id1 = E_NTH_VERT(e,1); - l = LIST_NEXT(l); - e = (int)LIST_DATA(l); - id2 = E_NTH_VERT(e,1); - - smDir(sm,v0,id0); - smDir(sm,v1,id1); - smDir(sm,v2,id2); - /* determine if convex (left turn), or concave(right turn) angle */ - if(convex_angle(v0,v1,v2)) + normalize(v3); + if(DOT(n,v3) < 0) { - if(l == plist) - break; - else - continue; + t_id = smTriangulate_add_tri(sm,id0,id1,id2,e1,e2,&e); + e *= -1; + t_id = smTriangulate_add_tri(sm,id2,id3,id0,e3,e4,&e); + return(TRUE); } - /* if concave: add edge and recurse on two sub polygons */ - id_next = smFind_next_convex_vertex(sm,id0,id1,v0,v1,LIST_NEXT(l)); - if(id_next == INVALID) - { + } + + } #ifdef DEBUG - eputs("smTriangulate_elist():Unable to find convex vertex\n"); +#if DEBUG > 1 + VCROSS(n,v1,v3); + normalize(n); + normalize(v0); + normalize(v2); + dp = DOT(n,v2); + if((dp < 0) || (dp < EV_EPS) || (DOT(n,v0) >= 0.0)) + error(CONSISTENCY,"smTriangulate_quad: cannot triangulate\n"); #endif - return(FALSE); - } - /* add edge */ - el1 = NULL; - /* Split edge list l into two lists: one from id1-id_next-id1, - and the next from id2-id_next-id2 - */ - split_edge_list(id1,id_next,&l,&el1); - /* Recurse and triangulate the two edge lists */ - done = smTriangulate_elist(sm,l,add_ptr); - if(done) - done = smTriangulate_elist(sm,el1,add_ptr); - return(done); - } - done = smTriangulate_convex(sm,plist,add_ptr); - return(done); +#endif + t_id = smTriangulate_add_tri(sm,id1,id2,id3,e2,e3,&e); + e *= -1; + t_id = smTriangulate_add_tri(sm,id3,id0,id1,e4,e1,&e); + return(TRUE); } -int -smTriangulate_add_tri(sm,id0,id1,id2,e0,e1,e2ptr) -SM *sm; -int id0,id1,id2,e0,e1,*e2ptr; +eIn_tri(e,t) +int e; +TRI *t; { - int t_id; - int e2; - t_id = smAdd_tri(sm,id0,id1,id2); - if(*e2ptr == 0) - { - e2 = eNew_edge(); - SET_E_NTH_VERT(e2,0,id2); - SET_E_NTH_VERT(e2,1,id0); - } + if(T_NTH_V(t,0)==E_NTH_VERT(e,0)) + return(T_NTH_V(t,1)==E_NTH_VERT(e,1)||T_NTH_V(t,2)==E_NTH_VERT(e,1)); else - e2 = *e2ptr; - /* set appropriate tri for each edge*/ - SET_E_NTH_TRI(e0,0,t_id); - SET_E_NTH_TRI(e1,0,t_id); - SET_E_NTH_TRI(e2,0,t_id); + if(T_NTH_V(t,1)==E_NTH_VERT(e,0)) + return(T_NTH_V(t,0)==E_NTH_VERT(e,1)||T_NTH_V(t,2)==E_NTH_VERT(e,1)); + else if(T_NTH_V(t,2)==E_NTH_VERT(e,0)) + return(T_NTH_V(t,0)==E_NTH_VERT(e,1)||T_NTH_V(t,1)==E_NTH_VERT(e,1)); - *e2ptr = e2; - return(t_id); + return(FALSE); } + + +/* Triangulate the polygon defined by plist, and generating vertex p_id. + Return list of added triangles in list add_ptr. Returns TRUE if + successful, FALSE otherwise. This is NOT a general triangulation routine, + assumes polygon star relative to id +*/ + int -smTriangulate_elist_new(sm,id,plist,add_ptr) +smTriangulate(sm,id,plist) SM *sm; -int id; -LIST *plist,**add_ptr; +S_ID id; +LIST *plist; { LIST *l,*prev,*t; FVECT v0,v1,v2,n,p; - int is_tri,loop,t_id,id0,id1,id2,e2,eprev,enext; - double dp; + int is_tri,cut,t_id,e2,e1,enew; + S_ID id0,id1,id2; + double dp1,dp2; - smDir(sm,p,id); - enext=0; - is_tri= loop = FALSE; - l = prev = plist; - /* get v0,v1,v2 */ - eprev = (int)LIST_DATA(l); - id0 = E_NTH_VERT(eprev,0); - id1 = E_NTH_VERT(eprev,1); - smDir(sm,v0,id0); - smDir(sm,v1,id1); + VSUB(p,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm)); + normalize(p); + l = plist; + + enew = 0; + cut = is_tri= FALSE; + prev = l; + /* get v0,v1 */ + e1 = (int)LIST_DATA(l); + id0 = E_NTH_VERT(e1,0); + id1 = E_NTH_VERT(e1,1); + VSUB(v0,SM_NTH_WV(sm,id0),SM_VIEW_CENTER(sm)); + normalize(v0); + VSUB(v1,SM_NTH_WV(sm,id1),SM_VIEW_CENTER(sm)); + normalize(v1); while(l) { l = LIST_NEXT(l); + /* Get v2 */ e2 = (int)LIST_DATA(l); id2 = E_NTH_VERT(e2,1); - /* Check if have a triangle */ + VSUB(v2,SM_NTH_WV(sm,id2),SM_VIEW_CENTER(sm)); + normalize(v2); if(LIST_NEXT(LIST_NEXT(l)) == prev) - { - is_tri = TRUE; - break; + {/* Check if have a triangle */ + is_tri = TRUE; + break; } - if(LIST_NEXT(l) == plist) - { - if(!loop) - loop = 1; - else - loop++; - if(loop > 3) - break; - } - smDir(sm,v2,id2); - /* determine if convex (left turn), or concave(right turn) angle */ - if(!convex_angle(v0,v1,v2)) - { - VCOPY(v0,v1); - VCOPY(v1,v2); - id0 = id1; - id1 = id2; - prev = l; - eprev = e2; - continue; - } + /* determine if v0-v1-v2 is convex:defined clockwise on the sphere- + so switch orientation + */ VCROSS(n,v0,v2); - dp = DOT(n,p); - if(loop <=1 && (!ZERO(dp) && dp < 0.0)) + normalize(n); + dp1 = DOT(n,p); + if(dp1 <= 0.0) { - VCOPY(v0,v1); - VCOPY(v1,v2); - id0 = id1; - id1 = id2; - eprev = e2; - prev = l; - continue; - } - loop = FALSE; - - enext = 0; - t_id = smTriangulate_add_tri(sm,id0,id1,id2,eprev,e2,&enext); - *add_ptr = push_data(*add_ptr,t_id); - - LIST_NEXT(prev) = LIST_NEXT(l); - LIST_DATA(prev) = eprev = -enext; - LIST_NEXT(l)=NULL; - if(l== plist) - plist = prev; - free_list(l); - l = prev; + /* test if safe to cut off v0-v1-v2 by testing if p lies outside of + triangle v0-v1-v2: if so, because plist is the star polygon around p, + the new edge v2-v0 cannot intersect any existing edges + */ + dp1 = DOT(n,v1); + /* Distance from point s to plane is d = |N.p0s|/||N|| */ + /* sp1 = s-p0 for point on plane p0, a.(b+c) = a.b + a.c */ + if(dp1 >= EV_EPS) + { + /* remove edges e1,e2 and add triangle id0,id1,id2 */ + enew = 0; + t_id = smTriangulate_add_tri(sm,id0,id1,id2,e1,e2,&enew); + cut = TRUE; + /* Insert edge enew into the list, reuse prev list element */ + LIST_NEXT(prev) = LIST_NEXT(l); + LIST_DATA(prev) = e1 = -enew; + /* If removing head of list- reset plist pointer */ + if(l== plist) + plist = prev; + /* free list element for e2 */ + LIST_NEXT(l)=NULL; + free_list(l); + l = prev; + VCOPY(v1,v2); + id1 = id2; + continue; + } + } + VCOPY(v0,v1); VCOPY(v1,v2); + id0 = id1; id1 = id2; + e1 = e2; + /* check if gone around circular list without adding any + triangles: prevent infinite loop */ + if(l == plist) + { + if(LIST_NEXT(LIST_NEXT(l)) == prev) + {/* Check if have a triangle */ + is_tri = TRUE; + break; + } + if(!cut) + break; + cut = FALSE; } - if(is_tri) - { + prev = l; + } + if(is_tri) + { l = LIST_NEXT(l); - enext = (int)LIST_DATA(l); - t_id = smTriangulate_add_tri(sm,id0,id1,id2,eprev,e2,&enext); - *add_ptr = push_data(*add_ptr,t_id); + enew = (int)LIST_DATA(l); + t_id = smTriangulate_add_tri(sm,id0,id1,id2,e1,e2,&enew); free_list(l); - } - else - { -#ifdef DEBUG - eputs("smTriangulate_elist()Unable to triangulate\n"); + } + else + if(!smTriangulate_quad(sm,l)) + goto Terror; + /* Set triangle adjacencies based on edge adjacencies */ + FOR_ALL_EDGES(enew) + { + id0 = E_NTH_TRI(enew,0); + id1 = E_NTH_TRI(enew,1); + + e1 = (T_WHICH_V(SM_NTH_TRI(sm,id0),E_NTH_VERT(enew,0))+2)%3; + T_NTH_NBR(SM_NTH_TRI(sm,id0),e1) = id1; + + e2 = (T_WHICH_V(SM_NTH_TRI(sm,id1),E_NTH_VERT(enew,1))+2)%3; + T_NTH_NBR(SM_NTH_TRI(sm,id1),e2) = id0; + } + +#ifdef DEBUG +#if DEBUG > 1 + { + TRI *t0,*t1,*n; + + FOR_ALL_EDGES(enew) + { + id0 = E_NTH_TRI(enew,0); + id1 = E_NTH_TRI(enew,1); + t0 = SM_NTH_TRI(sm,id0); + t1 = SM_NTH_TRI(sm,id1); + if(T_NTH_NBR(t0,0) == T_NTH_NBR(t0,1) || + T_NTH_NBR(t0,1) == T_NTH_NBR(t0,2) || + T_NTH_NBR(t0,0) == T_NTH_NBR(t0,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t0,0)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t0,1)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t0,2)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + + if(T_NTH_NBR(t1,0) == T_NTH_NBR(t1,1) || + T_NTH_NBR(t1,1) == T_NTH_NBR(t1,2) || + T_NTH_NBR(t1,0) == T_NTH_NBR(t1,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t1,0)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t1,1)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t1,2)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + } + + } #endif - return(FALSE); - } +#endif + return(TRUE); + +Terror: + + error(CONSISTENCY,"smTriangulate():Unable to triangulate\n"); + } -int -smTriangulate(sm,p_id,plist,add_ptr) -SM *sm; -int p_id; -LIST *plist,**add_ptr; -{ - int e,id_t0,id_t1,e0,e1; - int test; - test = smTriangulate_elist_new(sm,p_id,plist,add_ptr); +void +smTris_swap_edge(sm,t_id,t1_id,e,e1,tn_id,tn1_id) + SM *sm; + int t_id,t1_id; + int e,e1; + int *tn_id,*tn1_id; +{ + S_ID verts[3]; + int enext,eprev,e1next,e1prev; + TRI *n,*ta,*tb,*t,*t1; + FVECT p1,p2,p3; + int ta_id,tb_id; + /* form new diagonal (e relative to t, and e1 relative to t1) + defined by quadrilateral formed by t,t1- swap for the opposite diagonal + */ + t = SM_NTH_TRI(sm,t_id); + t1 = SM_NTH_TRI(sm,t1_id); + enext = (e+1)%3; + eprev = (e+2)%3; + e1next = (e1+1)%3; + e1prev = (e1+2)%3; + verts[e] = T_NTH_V(t,e); + verts[enext] = T_NTH_V(t,enext); + verts[eprev] = T_NTH_V(t1,e1); + ta_id = smAdd_tri(sm,verts[0],verts[1],verts[2],&ta); #if 0 - test = smTriangulate_elist(sm,plist,add_ptr); + fprintf(stderr,"Added tri %d %d %d %d\n",ta_id,T_NTH_V(ta,0), + T_NTH_V(ta,1), T_NTH_V(ta,2)); #endif + verts[e1] = T_NTH_V(t1,e1); + verts[e1next] = T_NTH_V(t1,e1next); + verts[e1prev] = T_NTH_V(t,e); + tb_id = smAdd_tri(sm,verts[0],verts[1],verts[2],&tb); +#if 0 + fprintf(stderr,"Added tri %d %d %d %d\n",tb_id,T_NTH_V(tb,0), + T_NTH_V(tb,1), T_NTH_V(tb,2)); +#endif + /* set the neighbors */ + T_NTH_NBR(ta,e) = T_NTH_NBR(t1,e1next); + T_NTH_NBR(tb,e1) = T_NTH_NBR(t,enext); + T_NTH_NBR(ta,enext)= tb_id; + T_NTH_NBR(tb,e1next)= ta_id; + T_NTH_NBR(ta,eprev)=T_NTH_NBR(t,eprev); + T_NTH_NBR(tb,e1prev)=T_NTH_NBR(t1,e1prev); - if(!test) - return(test); + /* Reset neighbor pointers of original neighbors */ + n = SM_NTH_TRI(sm,T_NTH_NBR(t,enext)); + T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = tb_id; + n = SM_NTH_TRI(sm,T_NTH_NBR(t,eprev)); + T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = ta_id; + n = SM_NTH_TRI(sm,T_NTH_NBR(t1,e1next)); + T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = ta_id; + n = SM_NTH_TRI(sm,T_NTH_NBR(t1,e1prev)); + T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = tb_id; - FOR_ALL_EDGES(e) - { - id_t0 = E_NTH_TRI(e,0); - id_t1 = E_NTH_TRI(e,1); - if((id_t0==INVALID) || (id_t1==INVALID)) - { + smDelete_tri(sm,t_id,t); + smDelete_tri(sm,t1_id,t1); + #ifdef DEBUG - eputs("smTriangulate(): Unassigned edge neighbor\n"); -#endif - continue; - } - - e0 = T_WHICH_V(SM_NTH_TRI(sm,id_t0),E_NTH_VERT(e,0)); - T_NTH_NBR(SM_NTH_TRI(sm,id_t0),e0) = id_t1; +#if DEBUG > 1 + if(T_NTH_NBR(ta,0) == T_NTH_NBR(ta,1) || + T_NTH_NBR(ta,1) == T_NTH_NBR(ta,2) || + T_NTH_NBR(ta,0) == T_NTH_NBR(ta,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(ta,0)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(ta,1)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(ta,2)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + if(T_NTH_NBR(ta,0) == T_NTH_NBR(ta,1) || + T_NTH_NBR(ta,1) == T_NTH_NBR(ta,2) || + T_NTH_NBR(ta,0) == T_NTH_NBR(ta,2)) + error(CONSISTENCY,"Invalid topology\n"); - e1 = T_WHICH_V(SM_NTH_TRI(sm,id_t1),E_NTH_VERT(e,1)); - T_NTH_NBR(SM_NTH_TRI(sm,id_t1),e1) = id_t0; - } - return(test); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(tb,0)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(tb,1)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(tb,2)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); +#endif +#endif + *tn_id = ta_id; + *tn1_id = tb_id; + + return; } -eIn_tri(e,t) -int e; -TRI *t; -{ - - if(T_NTH_V(t,0)==E_NTH_VERT(e,0)) - return(T_NTH_V(t,1)==E_NTH_VERT(e,1)||T_NTH_V(t,2)==E_NTH_VERT(e,1)); - else - if(T_NTH_V(t,1)==E_NTH_VERT(e,0)) - return(T_NTH_V(t,0)==E_NTH_VERT(e,1)||T_NTH_V(t,2)==E_NTH_VERT(e,1)); - else if(T_NTH_V(t,2)==E_NTH_VERT(e,0)) - return(T_NTH_V(t,0)==E_NTH_VERT(e,1)||T_NTH_V(t,1)==E_NTH_VERT(e,1)); - return(FALSE); -} - -smFix_edges(sm,add_list,delptr) +/* Test the new set of triangles for Delaunay condition. 'Edges' contains + all of the new edges added. The CCW triangle assoc with each edge is + tested against the opposite vertex of the CW triangle. If the vertex + lies inside the circle defined by the CCW triangle- the edge is swapped + for the opposite diagonal +*/ +smFixEdges(sm) SM *sm; - LIST *add_list; - QUADTREE *delptr; - { int e,t0_id,t1_id,e_new,e0,e1,e0_next,e1_next; - int i,v0_id,v1_id,v2_id,p_id,t0_nid,t1_nid; + S_ID v0_id,v1_id,v2_id,p_id; + int i,t0_nid,t1_nid; FVECT v0,v1,v2,p,np,v; + TRI *t0,*t1; FOR_ALL_EDGES(e) { t0_id = E_NTH_TRI(e,0); t1_id = E_NTH_TRI(e,1); - if((t0_id==INVALID) || (t1_id==INVALID)) - { #ifdef DEBUG - eputs("smFix_edges: Unassigned edge nbr\n"); + if((t0_id==INVALID) || (t1_id==INVALID)) + error(CONSISTENCY,"smFix_edges: Unassigned edge nbr\n"); #endif - continue; - } - e0 = T_WHICH_V(SM_NTH_TRI(sm,t0_id),E_NTH_VERT(e,0)); - e1 = T_WHICH_V(SM_NTH_TRI(sm,t1_id),E_NTH_VERT(-e,0)); - e0_next = (e0+2)%3; - e1_next = (e1+2)%3; + t0 = SM_NTH_TRI(sm,t0_id); + t1 = SM_NTH_TRI(sm,t1_id); + e0 = T_NTH_NBR_PTR(t1_id,t0); + e1 = T_NTH_NBR_PTR(t0_id,t1); + v0_id = E_NTH_VERT(e,0); v1_id = E_NTH_VERT(e,1); - v2_id = T_NTH_V(SM_NTH_TRI(sm,t0_id),e0_next); - p_id = T_NTH_V(SM_NTH_TRI(sm,t1_id),e1_next); + v2_id = T_NTH_V(t0,e0); + p_id = T_NTH_V(t1,e1); - smDir_in_cone(sm,v0,v0_id); - smDir_in_cone(sm,v1,v1_id); - smDir_in_cone(sm,v2,v2_id); + smDir(sm,v0,v0_id); + smDir(sm,v1,v1_id); + smDir(sm,v2,v2_id); - VCOPY(p,SM_NTH_WV(sm,p_id)); - VSUB(p,p,SM_VIEW_CENTER(sm)); - if(point_in_cone(p,v0,v1,v2)) + VSUB(p,SM_NTH_WV(sm,p_id),SM_VIEW_CENTER(sm)); + normalize(p); + if(pt_in_cone(p,v2,v1,v0)) { - smTris_swap_edge(sm,t0_id,t1_id,e0,e1,&t0_nid,&t1_nid,&add_list, - delptr); - + smTris_swap_edge(sm,t0_id,t1_id,e0,e1,&t0_nid,&t1_nid); + /* Adjust the triangle pointers of the remaining edges to be + processed + */ FOR_ALL_EDGES_FROM(e,i) { if(E_NTH_TRI(i,0)==t0_id || E_NTH_TRI(i,0)==t1_id) @@ -662,6 +688,10 @@ smFix_edges(sm,add_list,delptr) else SET_E_NTH_TRI(i,1,t1_nid); } +#ifdef DEBUG + if(E_NTH_TRI(i,1) == E_NTH_TRI(i,0) ) + error(CONSISTENCY,"invalid edge\n"); +#endif } t0_id = t0_nid; t1_id = t1_nid; @@ -670,57 +700,70 @@ smFix_edges(sm,add_list,delptr) SET_E_NTH_VERT(e_new,1,v2_id); SET_E_NTH_TRI(e_new,0,t0_id); SET_E_NTH_TRI(e_new,1,t1_id); +#ifdef DEBUG + if(E_NTH_TRI(i,1) == E_NTH_TRI(i,0) ) + error(CONSISTENCY,"invalid edge\n"); +#endif } } - smUpdate_locator(sm,add_list,qtqueryset(*delptr)); } + +smDelete_samp(sm,s_id) +SM *sm; +S_ID s_id; +{ + QUADTREE qt; + S_ID *os; + + /* Mark as free */ + smUnalloc_samp(sm,s_id); + +#ifdef DEBUG + SM_NTH_VERT(sm,s_id) = INVALID; + /* fprintf(stderr,"deleting sample %d\n",s_id); */ +#endif + /* remove from its set */ + qt = SM_S_NTH_QT(sm,s_id); + os = qtqueryset(qt); + deletuelem(os, s_id); /* delete obj from unsorted os, no questions */ +} +/* Remove vertex "id" from the mesh- and retriangulate the resulting + hole: Returns TRUE if successful, FALSE otherwise. + */ int -smMesh_remove_vertex(sm,id) +smRemoveVertex(sm,id) SM *sm; - int id; + S_ID id; { - int t_id; - LIST *elist,*add_list; - int cnt,debug; - QUADTREE delnode; - /* generate list of vertices that form the boundary of the - star polygon formed by vertex id and all of its adjacent - triangles - */ - eClear_edges(); - elist = smVertex_star_polygon(sm,id,&delnode); - - if(!elist) - { -#ifdef DEBUG - eputs("smMesh_remove_vertex(): Unable to remove vertex"); + LIST *b_list; + /* generate list of edges that form the boundary of the + polygon formed by the triangles adjacent to vertex 'id'*/ + b_list = smVertexStar(sm,id); +#if 0 + {int i; + eputs("\n\n"); + for(i=1;i<=Ecnt;i++) + fprintf(stderr,"%d verts %d %d tris %d %d\n", + i,Edges[i].verts[0],Edges[i].verts[1], + Edges[i].tris[0],Edges[i].tris[1]); + } #endif - qtfreeleaf(delnode); - return(FALSE); - } - add_list = NULL; - /* Triangulate spherical polygon */ - if(!smTriangulate(sm,id,elist,&add_list)) - { - while(add_list) - { - t_id = pop_list(&add_list); - smDelete_tri(sm,t_id); - } - qtfreeleaf(delnode); - return(FALSE); - } - /* Fix up new triangles to be Delaunay */ - smFix_edges(sm,add_list,&delnode); - qtfreeleaf(delnode); + /* Triangulate polygonal hole */ + smTriangulate(sm,id,b_list); + + /* Fix up new triangles to be Delaunay*/ + + smFixEdges(sm); + smDelete_samp(sm,id); + eClear_edges(); return(TRUE); } - +
