--- ray/src/hd/sm_del.c 1998/10/06 18:16:53 3.6 +++ ray/src/hd/sm_del.c 1999/01/10 10:27:46 3.10 @@ -19,56 +19,15 @@ static int Max_edges=200; static EDGE *Edges=NULL; static int Ecnt=0; -#define remove_tri_compress remove_tri -remove_tri(qtptr,fptr,tptr) - QUADTREE *qtptr; - int *fptr; - int *tptr; -{ - int n; - - if(QT_IS_EMPTY(*qtptr)) - return; - if(QT_LEAF_IS_FLAG(*qtptr)) - return; - - n = QT_SET_CNT(qtqueryset(*qtptr))-1; - *qtptr = qtdelelem(*qtptr,*tptr); - if(n == 0) - (*fptr) |= QT_COMPRESS; - if(!QT_FLAG_FILL_TRI(*fptr)) - (*fptr)++; -} - - -smLocator_remove_tri(sm,t_id,v0_id,v1_id,v2_id) -SM *sm; -int t_id; -int v0_id,v1_id,v2_id; -{ - STREE *st; - FVECT v0,v1,v2; - - st = SM_LOCATOR(sm); - - VSUB(v0,SM_NTH_WV(sm,v0_id),SM_VIEW_CENTER(sm)); - VSUB(v1,SM_NTH_WV(sm,v1_id),SM_VIEW_CENTER(sm)); - VSUB(v2,SM_NTH_WV(sm,v2_id),SM_VIEW_CENTER(sm)); - - qtClearAllFlags(); - - stApply_to_tri(st,v0,v1,v2,remove_tri,remove_tri_compress,&t_id); - -} - smFree_tri(sm,id) SM *sm; int id; { - TRI *tri; + TRI *tri,*t; tri = SM_NTH_TRI(sm,id); /* Add to the free_list */ + smClear_tri_flags(sm,id); T_NEXT_FREE(tri) = SM_FREE_TRIS(sm); SM_FREE_TRIS(sm) = id; T_VALID_FLAG(tri) = -1; @@ -88,12 +47,10 @@ int t_id; to id because the vertices can no longer point to tri id as being the first triangle pointer */ - if(!SM_IS_NTH_T_BASE(sm,t_id)) - { - SM_SAMPLE_TRIS(sm)--; - if(SM_IS_NTH_T_NEW(sm,t_id)) - smNew_tri_cnt--; - } + SM_SAMPLE_TRIS(sm)--; + if(SM_IS_NTH_T_NEW(sm,t_id)) + smNew_tri_cnt--; + smClear_tri_flags(sm,t_id); smFree_tri(sm,t_id); @@ -110,7 +67,10 @@ eNew_edge() if(Ecnt >= Max_edges) { if(Max_edges > 10000) - error(CONSISTENCY,"Too many edges in vertex loop\n"); + { + eputs("Too many edges in vertex loop\n"); + return(-1); + } Max_edges += 100; if(!(Edges = (EDGE *)realloc(Edges,(Max_edges+1)*sizeof(EDGE)))) goto memerr; @@ -121,216 +81,102 @@ memerr: error(SYSTEM,"eNew_edge(): Unable to allocate memory"); } +/* Return list of edges defining polygon formed by boundary of triangles +adjacent to id. Return set of triangles adjacent to id to delete in delptr +*/ LIST -*smVertex_star_polygon(sm,id,delptr) +*smVertexPolygon(sm,id,del_ptr) SM *sm; int id; -QUADTREE *delptr; +LIST **del_ptr; { TRI *tri,*t_next; LIST *elist,*end; - int t_id,v_next,t_next_id; - int e; - OBJECT del_set[2]; + int e,t_id,v_next,t_next_id,b_id,v_id; + eClear_edges(); elist = end = NULL; + /* Get the first triangle adjacent to vertex id */ t_id = SM_NTH_VERT(sm,id); tri = SM_NTH_TRI(sm,t_id); - if((e = eNew_edge()) == INVALID) - return(NULL); + e = eNew_edge(); - v_next = (T_WHICH_V(tri,id)+1)%3; - SET_E_NTH_VERT(e,0,T_NTH_V(tri,v_next)); + /* Get the next vertex on the polygon boundary */ + v_id = T_WHICH_V(tri,id); + b_id = (v_id + 1)%3; + /* Create an edge */ + SET_E_NTH_VERT(e,0,T_NTH_V(tri,b_id)); SET_E_NTH_TRI(e,0,INVALID); - SET_E_NTH_TRI(e,1,T_NTH_NBR(tri,v_next)); - v_next = (T_WHICH_V(tri,id)+2)%3; - SET_E_NTH_VERT(e,1,T_NTH_V(tri,v_next)); + SET_E_NTH_TRI(e,1,T_NTH_NBR(tri,v_id)); + v_next = T_NTH_V(tri,(b_id+1)%3); + SET_E_NTH_VERT(e,1,v_next); elist = add_data_to_circular_list(elist,&end,e); - t_next_id = t_id; t_next = tri; - del_set[0] =1; del_set[1] = t_id; - *delptr = qtnewleaf(del_set); + *del_ptr = push_data(*del_ptr,t_id); + /* Create a set to hold all of the triangles for deletion later */ - while((t_next_id = T_NTH_NBR(t_next,v_next)) != t_id) - { - if((e = eNew_edge()) == INVALID) + while((t_next_id = T_NTH_NBR(t_next,b_id)) != t_id) + { + e = eNew_edge(); + if(e== INVALID) return(NULL); - t_next = SM_NTH_TRI(sm,t_next_id); - v_next = (T_WHICH_V(t_next,id)+1)%3; - - SET_E_NTH_VERT(e,0,T_NTH_V(t_next,v_next)); + SET_E_NTH_VERT(e,0,v_next); SET_E_NTH_TRI(e,0,INVALID); - SET_E_NTH_TRI(e,1,T_NTH_NBR(t_next,v_next)); - v_next = (T_WHICH_V(t_next,id)+2)%3; - SET_E_NTH_VERT(e,1,T_NTH_V(t_next,v_next)); + v_id = T_WHICH_V(t_next,id); + b_id = (v_id + 1)%3; + SET_E_NTH_TRI(e,1,T_NTH_NBR(t_next,v_id)); + v_next = T_NTH_V(t_next,(b_id+1)%3); + SET_E_NTH_VERT(e,1,v_next); elist = add_data_to_circular_list(elist,&end,e); - - - if(qtinset(*delptr,t_next_id)) - { -#ifdef DEBUG - eputs("smVertex_star_polygon(): id already in set\n"); -#endif - free_list(elist); - return(NULL); - } - else - qtaddelem(*delptr,t_next_id); + *del_ptr = push_data(*del_ptr,t_next_id); } return(elist); } + int -smEdge_intersect_polygon(sm,v0,v1,l) +smTriangulate_add_tri(sm,id0,id1,id2,e0,e1,e2ptr) SM *sm; -FVECT v0,v1; -LIST *l; +int id0,id1,id2,e0,e1,*e2ptr; { - FVECT e0,e1; - int e,id_e0,id_e1; - LIST *el,*eptr; - - /* Test the edges in l against v0v1 to see if v0v1 intersects - any other edges - */ - - el = l; + int t_id; + int e2; - while(el) - { - e = (int)LIST_DATA(el); - id_e0 = E_NTH_VERT(e,0); - id_e1 = E_NTH_VERT(e,1); - - VSUB(e0,SM_NTH_WV(sm,id_e0),SM_VIEW_CENTER(sm)); - VSUB(e1,SM_NTH_WV(sm,id_e1),SM_VIEW_CENTER(sm)); - if(sedge_intersect(v0,v1,e0,e1)) - return(TRUE); - - el = LIST_NEXT(el); - if(el == l) - break; - } - return(FALSE); -} - -int -smFind_next_convex_vertex(sm,id0,id1,v0,v1,l) - SM *sm; - int id0,id1; - FVECT v0,v1; - LIST *l; -{ - int e,id; - LIST *el; - FVECT v; - - /* starting with the end of edge at head of l, search sequentially for - vertex v such that v0v1v is a convex angle, and the edge v1v does - not intersect any other edges - */ - id = INVALID; - el = l; - while(id != id0) - { - e = (int)LIST_DATA(el); - id = E_NTH_VERT(e,1); - - smDir(sm,v,id); - - if(convex_angle(v0,v1,v) && !smEdge_intersect_polygon(sm,v1,v,l)) - return(id); - - el = LIST_NEXT(el); - if(el == l) - break; - } - return(INVALID); -} - -int -split_edge_list(id0,id_new,l,lnew) -int id0,id_new; -LIST **l,**lnew; -{ - LIST *list,*lptr,*end; - int e,e1,e2,new_e; - - e2 = INVALID; - list = lptr = *l; - - if((new_e = eNew_edge())==INVALID) - { -#ifdef DEBUG - eputs("split_edge_list():Too many edges\n"); +#ifdef DEBUG + if(id0 == INVALID || id1==INVALID || id2==INVALID) + error(CONSISTENCY,"bad id- smTriangulate_add_tri()\n"); #endif - return(FALSE); - } - SET_E_NTH_VERT(new_e,0,id0); - SET_E_NTH_VERT(new_e,1,id_new); - SET_E_NTH_TRI(new_e,0,INVALID); - SET_E_NTH_TRI(new_e,1,INVALID); - - while(e2 != id_new) - { - lptr = LIST_NEXT(lptr); - e = (int)LIST_DATA(lptr); - e2 = E_NTH_VERT(e,1); - if(lptr == list) - { -#ifdef DEBUG - eputs("split_edge_list():cant find vertex\n"); -#endif - *lnew = NULL; - return(FALSE); - } + t_id = smAdd_tri(sm,id0,id1,id2); + if(*e2ptr == 0) + { + e2 = eNew_edge(); + SET_E_NTH_VERT(e2,0,id2); + SET_E_NTH_VERT(e2,1,id0); + } + else + e2 = *e2ptr; + /* set appropriate tri for each edge*/ + SET_E_NTH_TRI(e0,0,t_id); + SET_E_NTH_TRI(e1,0,t_id); + SET_E_NTH_TRI(e2,0,t_id); - } - end = lptr; - lptr = LIST_NEXT(lptr); - list = add_data_to_circular_list(list,&end,-new_e); - *lnew = list; - - /* now follow other cycle */ - - list = lptr; - e2 = INVALID; - while(e2 != id0) - { - lptr = LIST_NEXT(lptr); - e = (int)LIST_DATA(lptr); - e2 = E_NTH_VERT(e,1); - if(lptr == list) - { -#ifdef DEBUG - eputs("split_edge_list():cant find intial vertex\n"); -#endif - *l = NULL; - return(FALSE); - } - - } - end = lptr; - list = add_data_to_circular_list(list,&end,new_e); - *l = list; - return(TRUE); + *e2ptr = e2; + return(t_id); } - int -smTriangulate_convex(sm,plist,add_ptr) +smTriangulateConvex(sm,plist,add_ptr) SM *sm; LIST *plist,**add_ptr; { int t_id,e_id0,e_id1,e_id2; int v_id0,v_id1,v_id2; LIST *lptr; - int cnt; lptr = plist; e_id0 = (int)LIST_DATA(lptr); @@ -341,252 +187,174 @@ LIST *plist,**add_ptr; e_id1 = (int)LIST_DATA(lptr); v_id1 = E_NTH_VERT(e_id1,0); v_id2 = E_NTH_VERT(e_id1,1); - /* form a triangle for each triple of with v0 as base of star */ - t_id = smAdd_tri(sm,v_id0,v_id1,v_id2); - *add_ptr = push_data(*add_ptr,t_id); - - /* add which pointer?*/ - lptr = LIST_NEXT(lptr); - if(LIST_NEXT(lptr) != plist) - { - e_id2 = eNew_edge(); - SET_E_NTH_VERT(e_id2,0,v_id2); - SET_E_NTH_VERT(e_id2,1,v_id0); - } + if(LIST_NEXT(lptr) != plist) + e_id2 = 0; else e_id2 = (int)LIST_DATA(lptr); - - /* set appropriate tri for each edge*/ - SET_E_NTH_TRI(e_id0,0,t_id); - SET_E_NTH_TRI(e_id1,0,t_id); - SET_E_NTH_TRI(e_id2,0,t_id); - + t_id = smTriangulate_add_tri(sm,v_id0,v_id1,v_id2,e_id0,e_id1,&e_id2); + *add_ptr = push_data(*add_ptr,t_id); e_id0 = -e_id2; } free_list(plist); return(TRUE); } -int -smTriangulate_elist(sm,plist,add_ptr) -SM *sm; -LIST *plist,**add_ptr; -{ - LIST *l,*el1; - FVECT v0,v1,v2; - int id0,id1,id2,e,id_next; - char flipped; - int done; - - l = plist; - - while(l) - { - /* get v0,v1,v2 */ - e = (int)LIST_DATA(l); - id0 = E_NTH_VERT(e,0); - id1 = E_NTH_VERT(e,1); - l = LIST_NEXT(l); - e = (int)LIST_DATA(l); - id2 = E_NTH_VERT(e,1); - - smDir(sm,v0,id0); - smDir(sm,v1,id1); - smDir(sm,v2,id2); - /* determine if convex (left turn), or concave(right turn) angle */ - if(convex_angle(v0,v1,v2)) - { - if(l == plist) - break; - else - continue; - } - /* if concave: add edge and recurse on two sub polygons */ - id_next = smFind_next_convex_vertex(sm,id0,id1,v0,v1,LIST_NEXT(l)); - if(id_next == INVALID) - { -#ifdef DEBUG - eputs("smTriangulate_elist():Unable to find convex vertex\n"); +#ifdef TEST_DRIVER +FVECT Norm[500],B_V[500]; +int Ncnt,Bcnt,Del=0; #endif - return(FALSE); - } - /* add edge */ - el1 = NULL; - /* Split edge list l into two lists: one from id1-id_next-id1, - and the next from id2-id_next-id2 - */ - split_edge_list(id1,id_next,&l,&el1); - /* Recurse and triangulate the two edge lists */ - done = smTriangulate_elist(sm,l,add_ptr); - if(done) - done = smTriangulate_elist(sm,el1,add_ptr); - return(done); - } - done = smTriangulate_convex(sm,plist,add_ptr); - return(done); -} -int -smTriangulate_add_tri(sm,id0,id1,id2,e0,e1,e2ptr) -SM *sm; -int id0,id1,id2,e0,e1,*e2ptr; -{ - int t_id; - int e2; - t_id = smAdd_tri(sm,id0,id1,id2); - if(*e2ptr == 0) - { - e2 = eNew_edge(); - SET_E_NTH_VERT(e2,0,id2); - SET_E_NTH_VERT(e2,1,id0); - } - else - e2 = *e2ptr; - /* set appropriate tri for each edge*/ - SET_E_NTH_TRI(e0,0,t_id); - SET_E_NTH_TRI(e1,0,t_id); - SET_E_NTH_TRI(e2,0,t_id); +/* Triangulate the polygon defined by plist, and generating vertex p_id. + Return list of added triangles in list add_ptr. Returns TRUE if + successful, FALSE otherwise. This is NOT a general triangulation routine, + assumes polygon star relative to id +*/ - *e2ptr = e2; - return(t_id); -} int -smTriangulate_elist_new(sm,id,plist,add_ptr) +smTriangulate(sm,id,plist,add_ptr) SM *sm; int id; LIST *plist,**add_ptr; { LIST *l,*prev,*t; FVECT v0,v1,v2,n,p; - int is_tri,loop,t_id,id0,id1,id2,e2,eprev,enext; + int is_tri,is_convex,cut,t_id,id0,id1,id2,e2,e1,enew; double dp; + static int debug=0; - smDir(sm,p,id); - enext=0; - is_tri= loop = FALSE; + VSUB(p,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm)); + enew = 0; + is_convex = TRUE; + cut = is_tri= FALSE; l = prev = plist; - /* get v0,v1,v2 */ - eprev = (int)LIST_DATA(l); - id0 = E_NTH_VERT(eprev,0); - id1 = E_NTH_VERT(eprev,1); - smDir(sm,v0,id0); - smDir(sm,v1,id1); + + /* get v0,v1 */ + e1 = (int)LIST_DATA(l); + id0 = E_NTH_VERT(e1,0); + id1 = E_NTH_VERT(e1,1); + VSUB(v0,SM_NTH_WV(sm,id0),SM_VIEW_CENTER(sm)); + VSUB(v1,SM_NTH_WV(sm,id1),SM_VIEW_CENTER(sm)); +#ifdef TEST_DRIVER + Del = TRUE; + VCOPY(B_V[0],v0); + VCOPY(B_V[1],v1); + Bcnt = 2; + Ncnt = 0; +#endif while(l) { l = LIST_NEXT(l); + /* Get v2 */ e2 = (int)LIST_DATA(l); id2 = E_NTH_VERT(e2,1); - /* Check if have a triangle */ + VSUB(v2,SM_NTH_WV(sm,id2),SM_VIEW_CENTER(sm)); +#ifdef TEST_DRIVER + VCOPY(B_V[Bcnt++],v2); +#endif if(LIST_NEXT(LIST_NEXT(l)) == prev) - { - is_tri = TRUE; - break; + {/* Check if have a triangle */ + is_tri = TRUE; + break; } - if(LIST_NEXT(l) == plist) + + /* determine if v0-v1-v2 is convex:defined clockwise on the sphere- + so switch orientation + */ + if(convex_angle(v2,v1,v0)) { - if(!loop) - loop = 1; - else - loop++; - if(loop > 3) - break; + /* test if safe to cut off v0-v1-v2 by testing if p lies outside of + triangle v0-v1-v2: if so, because plist is the star polygon around p, + the new edge v2-v0 cannot intersect any existing edges + */ + VCROSS(n,v0,v2); + dp = DOT(n,p); + if(dp <= 0.0) + { + /* remove edges e1,e2 and add triangle id0,id1,id2 */ + enew = 0; + t_id = smTriangulate_add_tri(sm,id0,id1,id2,e1,e2,&enew); + cut = TRUE; + *add_ptr = push_data(*add_ptr,t_id); + /* Insert edge enew into the list, reuse prev list element */ + LIST_NEXT(prev) = LIST_NEXT(l); + LIST_DATA(prev) = e1 = -enew; + /* If removing head of list- reset plist pointer */ + if(l== plist) + plist = prev; + /* free list element for e2 */ + LIST_NEXT(l)=NULL; + free_list(l); + l = prev; + VCOPY(v1,v2); + id1 = id2; + continue; + } } - smDir(sm,v2,id2); - /* determine if convex (left turn), or concave(right turn) angle */ - if(!convex_angle(v0,v1,v2)) - { - VCOPY(v0,v1); - VCOPY(v1,v2); - id0 = id1; - id1 = id2; - prev = l; - eprev = e2; - continue; - } - VCROSS(n,v0,v2); - dp = DOT(n,p); - if(loop <=1 && (!ZERO(dp) && dp < 0.0)) - { - VCOPY(v0,v1); - VCOPY(v1,v2); - id0 = id1; - id1 = id2; - eprev = e2; - prev = l; - continue; - } - loop = FALSE; - - enext = 0; - t_id = smTriangulate_add_tri(sm,id0,id1,id2,eprev,e2,&enext); - *add_ptr = push_data(*add_ptr,t_id); - - LIST_NEXT(prev) = LIST_NEXT(l); - LIST_DATA(prev) = eprev = -enext; - LIST_NEXT(l)=NULL; - if(l== plist) - plist = prev; - free_list(l); - l = prev; + else + is_convex = FALSE; + VCOPY(v0,v1); VCOPY(v1,v2); + id0 = id1; id1 = id2; + e1 = e2; + /* check if gone around circular list without adding any + triangles: prevent infinite loop */ + if(l == plist) + { + if(LIST_NEXT(LIST_NEXT(l)) == prev) + {/* Check if have a triangle */ + is_tri = TRUE; + break; + } + + if(is_convex) + break; + if(!cut) + { +#ifdef DEBUG + eputs("smTriangulate():Unable to triangulate\n"); +#endif + free_list(l); + while(*add_ptr) + { + t_id = pop_list(add_ptr); + smDelete_tri(sm,t_id); + } + return(FALSE); + } + + cut = FALSE; + is_convex = TRUE; + } + prev = l; } if(is_tri) { l = LIST_NEXT(l); - enext = (int)LIST_DATA(l); - t_id = smTriangulate_add_tri(sm,id0,id1,id2,eprev,e2,&enext); + enew = (int)LIST_DATA(l); + t_id = smTriangulate_add_tri(sm,id0,id1,id2,e1,e2,&enew); *add_ptr = push_data(*add_ptr,t_id); free_list(l); - } + } else - { -#ifdef DEBUG - eputs("smTriangulate_elist()Unable to triangulate\n"); -#endif + if(!smTriangulateConvex(sm,l,add_ptr)) return(FALSE); - } - return(TRUE); -} -int -smTriangulate(sm,p_id,plist,add_ptr) -SM *sm; -int p_id; -LIST *plist,**add_ptr; -{ - int e,id_t0,id_t1,e0,e1; - int test; - - test = smTriangulate_elist_new(sm,p_id,plist,add_ptr); -#if 0 - test = smTriangulate_elist(sm,plist,add_ptr); -#endif - - if(!test) - return(test); - - FOR_ALL_EDGES(e) + /* Set triangle adjacencies based on edge adjacencies */ + FOR_ALL_EDGES(enew) { - id_t0 = E_NTH_TRI(e,0); - id_t1 = E_NTH_TRI(e,1); - if((id_t0==INVALID) || (id_t1==INVALID)) - { -#ifdef DEBUG - eputs("smTriangulate(): Unassigned edge neighbor\n"); -#endif - continue; - } + id0 = E_NTH_TRI(enew,0); + id1 = E_NTH_TRI(enew,1); - e0 = T_WHICH_V(SM_NTH_TRI(sm,id_t0),E_NTH_VERT(e,0)); - T_NTH_NBR(SM_NTH_TRI(sm,id_t0),e0) = id_t1; - - e1 = T_WHICH_V(SM_NTH_TRI(sm,id_t1),E_NTH_VERT(e,1)); - T_NTH_NBR(SM_NTH_TRI(sm,id_t1),e1) = id_t0; + e1 = (T_WHICH_V(SM_NTH_TRI(sm,id0),E_NTH_VERT(enew,0))+2)%3; + T_NTH_NBR(SM_NTH_TRI(sm,id0),e1) = id1; + + e2 = (T_WHICH_V(SM_NTH_TRI(sm,id1),E_NTH_VERT(enew,1))+2)%3; + T_NTH_NBR(SM_NTH_TRI(sm,id1),e2) = id0; } - return(test); + return(TRUE); } eIn_tri(e,t) @@ -601,18 +369,24 @@ TRI *t; return(T_NTH_V(t,0)==E_NTH_VERT(e,1)||T_NTH_V(t,2)==E_NTH_VERT(e,1)); else if(T_NTH_V(t,2)==E_NTH_VERT(e,0)) return(T_NTH_V(t,0)==E_NTH_VERT(e,1)||T_NTH_V(t,1)==E_NTH_VERT(e,1)); + return(FALSE); } -smFix_edges(sm,add_list,delptr) +/* Test the new set of triangles for Delaunay condition. 'Edges' contains + all of the new edges added. The CCW triangle assoc with each edge is + tested against the opposite vertex of the CW triangle. If the vertex + lies inside the circle defined by the CCW triangle- the edge is swapped + for the opposite diagonal +*/ +smFixEdges(sm,add_list) SM *sm; LIST *add_list; - QUADTREE *delptr; - { int e,t0_id,t1_id,e_new,e0,e1,e0_next,e1_next; int i,v0_id,v1_id,v2_id,p_id,t0_nid,t1_nid; FVECT v0,v1,v2,p,np,v; + TRI *t0,*t1; FOR_ALL_EDGES(e) { @@ -621,18 +395,18 @@ smFix_edges(sm,add_list,delptr) if((t0_id==INVALID) || (t1_id==INVALID)) { #ifdef DEBUG - eputs("smFix_edges: Unassigned edge nbr\n"); + error(CONSISTENCY,"smFix_edges: Unassigned edge nbr\n"); #endif - continue; } - e0 = T_WHICH_V(SM_NTH_TRI(sm,t0_id),E_NTH_VERT(e,0)); - e1 = T_WHICH_V(SM_NTH_TRI(sm,t1_id),E_NTH_VERT(-e,0)); - e0_next = (e0+2)%3; - e1_next = (e1+2)%3; + t0 = SM_NTH_TRI(sm,t0_id); + t1 = SM_NTH_TRI(sm,t1_id); + e0 = T_NTH_NBR_PTR(t1_id,t0); + e1 = T_NTH_NBR_PTR(t0_id,t1); + v0_id = E_NTH_VERT(e,0); v1_id = E_NTH_VERT(e,1); - v2_id = T_NTH_V(SM_NTH_TRI(sm,t0_id),e0_next); - p_id = T_NTH_V(SM_NTH_TRI(sm,t1_id),e1_next); + v2_id = T_NTH_V(t0,e0); + p_id = T_NTH_V(t1,e1); smDir_in_cone(sm,v0,v0_id); smDir_in_cone(sm,v1,v1_id); @@ -642,9 +416,11 @@ smFix_edges(sm,add_list,delptr) VSUB(p,p,SM_VIEW_CENTER(sm)); if(point_in_cone(p,v0,v1,v2)) { - smTris_swap_edge(sm,t0_id,t1_id,e0,e1,&t0_nid,&t1_nid,&add_list, - delptr); + smTris_swap_edge(sm,t0_id,t1_id,e0,e1,&t0_nid,&t1_nid,&add_list); + /* Adjust the triangle pointers of the remaining edges to be + processed + */ FOR_ALL_EDGES_FROM(e,i) { if(E_NTH_TRI(i,0)==t0_id || E_NTH_TRI(i,0)==t1_id) @@ -672,55 +448,59 @@ smFix_edges(sm,add_list,delptr) SET_E_NTH_TRI(e_new,1,t1_id); } } - smUpdate_locator(sm,add_list,qtqueryset(*delptr)); + /* Add/Delete the appropriate triangles from the stree */ + smUpdate_locator(sm,add_list); } +/* Remove vertex "id" from the mesh- and retriangulate the resulting + hole: Returns TRUE if successful, FALSE otherwise. + */ int -smMesh_remove_vertex(sm,id) +smRemoveVertex(sm,id) SM *sm; int id; { - int t_id; - LIST *elist,*add_list; - int cnt,debug; - QUADTREE delnode; - /* generate list of vertices that form the boundary of the - star polygon formed by vertex id and all of its adjacent - triangles + LIST *b_list,*add_list,*del_list; + int t_id,i; + static int cnt=0; + OBJECT *optr,*os; + /* generate list of edges that form the boundary of the + polygon formed by the triangles adjacent to vertex 'id' */ - eClear_edges(); - elist = smVertex_star_polygon(sm,id,&delnode); - - if(!elist) + del_list = NULL; + b_list = smVertexPolygon(sm,id,&del_list); + if(!b_list) { -#ifdef DEBUG - eputs("smMesh_remove_vertex(): Unable to remove vertex"); -#endif - qtfreeleaf(delnode); + if(del_list) + free_list(del_list); return(FALSE); } add_list = NULL; - /* Triangulate spherical polygon */ - if(!smTriangulate(sm,id,elist,&add_list)) + /* Triangulate polygonal hole */ + if(!smTriangulate(sm,id,b_list,&add_list)) { - while(add_list) - { - t_id = pop_list(&add_list); - smDelete_tri(sm,t_id); - } - qtfreeleaf(delnode); + free_list(del_list); return(FALSE); } - /* Fix up new triangles to be Delaunay */ - smFix_edges(sm,add_list,&delnode); + else + { + while(del_list) + { + t_id = pop_list(&del_list); + smDelete_tri(sm,t_id); + } + } + /* Fix up new triangles to be Delaunay-delnode contains set of + triangles to delete,add_list is the set of new triangles to add + */ + smFixEdges(sm,add_list); - qtfreeleaf(delnode); return(TRUE); } - +
