| 1 |
gwlarson |
3.1 |
#ifndef lint
| 2 |
greg |
3.13 |
static const char RCSid[] = "$Id$";
| 3 |
gwlarson |
3.1 |
#endif
| 4 |
| 5 |
* sm_del.c
| 6 |
| 7 |
#include "standard.h"
| 8 |
gwlarson |
3.6 |
#include "sm_flag.h"
| 9 |
gwlarson |
3.1 |
#include "sm_list.h"
| 10 |
#include "sm_geom.h"
| 11 |
#include "sm.h"
| 12 |
| 13 |
gwlarson |
3.12 |
#define MAX_EDGE_INIT 100
| 14 |
static int Max_edges= MAX_EDGE_INIT;
| 15 |
gwlarson |
3.6 |
static EDGE *Edges=NULL;
| 16 |
gwlarson |
3.1 |
static int Ecnt=0;
| 17 |
| 18 |
gwlarson |
3.12 |
smFree_tri(sm,id,t)
| 19 |
gwlarson |
3.1 |
SM *sm;
| 20 |
int id;
| 21 |
gwlarson |
3.12 |
TRI *t;
| 22 |
gwlarson |
3.1 |
| 23 |
/* Add to the free_list */
| 24 |
gwlarson |
3.12 |
T_NEXT_FREE(t) = SM_FREE_TRIS(sm);
| 25 |
gwlarson |
3.1 |
SM_FREE_TRIS(sm) = id;
| 26 |
gwlarson |
3.12 |
#ifdef DEBUG
| 27 |
T_VALID_FLAG(t) = INVALID;
| 28 |
#endif
| 29 |
gwlarson |
3.1 |
| 30 |
| 31 |
/* Assumes mesh pointers have been cleaned up appropriately: just deletes from
| 32 |
Point location and triangle data structure
| 33 |
| 34 |
gwlarson |
3.12 |
smDelete_tri(sm,t_id,t)
| 35 |
gwlarson |
3.1 |
SM *sm;
| 36 |
int t_id;
| 37 |
gwlarson |
3.12 |
TRI *t;
| 38 |
gwlarson |
3.1 |
| 39 |
| 40 |
/* NOTE: Assumes that a new triangle adjacent to each vertex
| 41 |
has been added- before the deletion: replacing
| 42 |
the old tri- and therefore dont need to dereference any pointers
| 43 |
to id because the vertices can no longer
| 44 |
point to tri id as being the first triangle pointer
| 45 |
| 46 |
gwlarson |
3.12 |
SM_CLR_NTH_T_ACTIVE(sm,t_id);
| 47 |
smFree_tri(sm,t_id,t);
| 48 |
gwlarson |
3.9 |
| 49 |
gwlarson |
3.6 |
| 50 |
gwlarson |
3.1 |
| 51 |
gwlarson |
3.6 |
int
| 52 |
eNew_edge()
| 53 |
| 54 |
if(!Edges)
| 55 |
if(!(Edges = (EDGE *)realloc(NULL,(Max_edges+1)*sizeof(EDGE))))
| 56 |
goto memerr;
| 57 |
| 58 |
if(Ecnt >= Max_edges)
| 59 |
| 60 |
gwlarson |
3.12 |
#ifdef DEBUG
| 61 |
gwlarson |
3.6 |
if(Max_edges > 10000)
| 62 |
gwlarson |
3.12 |
error(CONSISTENCY,"Too many edges in vertex loop\n");
| 63 |
#endif
| 64 |
gwlarson |
3.6 |
Max_edges += 100;
| 65 |
greg |
3.14 |
if(!(Edges = (EDGE *)realloc((void *)Edges,(Max_edges+1)*sizeof(EDGE))))
| 66 |
gwlarson |
3.6 |
goto memerr;
| 67 |
| 68 |
gwlarson |
3.12 |
#ifdef DEBUG
| 69 |
SET_E_NTH_TRI(Ecnt+1,0,INVALID);
| 70 |
SET_E_NTH_TRI(Ecnt+1,1,INVALID);
| 71 |
#endif
| 72 |
gwlarson |
3.6 |
return(++Ecnt);
| 73 |
| 74 |
memerr:
| 75 |
gwlarson |
3.12 |
error(SYSTEM,"eNew_edge): Unable to allocate memory");
| 76 |
gwlarson |
3.1 |
| 77 |
| 78 |
gwlarson |
3.7 |
/* Return list of edges defining polygon formed by boundary of triangles
| 79 |
adjacent to id. Return set of triangles adjacent to id to delete in delptr
| 80 |
| 81 |
gwlarson |
3.5 |
LIST
| 82 |
gwlarson |
3.12 |
*smVertexStar(sm,id)
| 83 |
gwlarson |
3.1 |
SM *sm;
| 84 |
greg |
3.13 |
S_ID id;
| 85 |
gwlarson |
3.1 |
| 86 |
TRI *tri,*t_next;
| 87 |
gwlarson |
3.5 |
LIST *elist,*end;
| 88 |
greg |
3.13 |
int e,t_id,t_next_id,b_id,v_id,t_last_id;
| 89 |
S_ID v_next;
| 90 |
gwlarson |
3.1 |
| 91 |
elist = end = NULL;
| 92 |
gwlarson |
3.7 |
| 93 |
gwlarson |
3.1 |
/* Get the first triangle adjacent to vertex id */
| 94 |
t_id = SM_NTH_VERT(sm,id);
| 95 |
tri = SM_NTH_TRI(sm,t_id);
| 96 |
| 97 |
gwlarson |
3.7 |
e = eNew_edge();
| 98 |
/* Get the next vertex on the polygon boundary */
| 99 |
v_id = T_WHICH_V(tri,id);
| 100 |
b_id = (v_id + 1)%3;
| 101 |
/* Create an edge */
| 102 |
SET_E_NTH_VERT(e,0,T_NTH_V(tri,b_id));
| 103 |
gwlarson |
3.6 |
SET_E_NTH_TRI(e,0,INVALID);
| 104 |
gwlarson |
3.7 |
SET_E_NTH_TRI(e,1,T_NTH_NBR(tri,v_id));
| 105 |
gwlarson |
3.12 |
v_next = T_NTH_V(tri,(b_id+1)%3);
| 106 |
gwlarson |
3.7 |
SET_E_NTH_VERT(e,1,v_next);
| 107 |
gwlarson |
3.12 |
| 108 |
gwlarson |
3.6 |
elist = add_data_to_circular_list(elist,&end,e);
| 109 |
gwlarson |
3.1 |
t_next_id = t_id;
| 110 |
t_next = tri;
| 111 |
gwlarson |
3.12 |
t_last_id = -1;
| 112 |
| 113 |
gwlarson |
3.7 |
/* Create a set to hold all of the triangles for deletion later */
| 114 |
gwlarson |
3.1 |
| 115 |
gwlarson |
3.7 |
while((t_next_id = T_NTH_NBR(t_next,b_id)) != t_id)
| 116 |
| 117 |
e = eNew_edge();
| 118 |
gwlarson |
3.12 |
if(t_last_id != -1)
| 119 |
| 120 |
smDelete_tri(sm,t_last_id,t_next);
| 121 |
| 122 |
gwlarson |
3.6 |
t_next = SM_NTH_TRI(sm,t_next_id);
| 123 |
gwlarson |
3.12 |
t_last_id = t_next_id;
| 124 |
gwlarson |
3.7 |
SET_E_NTH_VERT(e,0,v_next);
| 125 |
gwlarson |
3.6 |
| 126 |
gwlarson |
3.7 |
v_id = T_WHICH_V(t_next,id);
| 127 |
| 128 |
SET_E_NTH_TRI(e,1,T_NTH_NBR(t_next,v_id));
| 129 |
v_next = T_NTH_V(t_next,(b_id+1)%3);
| 130 |
| 131 |
gwlarson |
3.6 |
| 132 |
gwlarson |
3.12 |
| 133 |
gwlarson |
3.1 |
| 134 |
gwlarson |
3.12 |
| 135 |
smDelete_tri(sm,t_id,tri);
| 136 |
return(elist);
| 137 |
gwlarson |
3.1 |
| 138 |
| 139 |
int
| 140 |
gwlarson |
3.7 |
smTriangulate_add_tri(sm,id0,id1,id2,e0,e1,e2ptr)
| 141 |
gwlarson |
3.1 |
SM *sm;
| 142 |
greg |
3.13 |
S_ID id0,id1,id2;
| 143 |
int e0,e1,*e2ptr;
| 144 |
gwlarson |
3.1 |
| 145 |
gwlarson |
3.12 |
int t_id,e2;
| 146 |
TRI *t;
| 147 |
gwlarson |
3.1 |
| 148 |
gwlarson |
3.12 |
t_id = smAdd_tri(sm,id0,id1,id2,&t);
| 149 |
gwlarson |
3.7 |
if(*e2ptr == 0)
| 150 |
| 151 |
e2 = eNew_edge();
| 152 |
SET_E_NTH_VERT(e2,0,id2);
| 153 |
SET_E_NTH_VERT(e2,1,id0);
| 154 |
| 155 |
else
| 156 |
e2 = *e2ptr;
| 157 |
/* set appropriate tri for each edge*/
| 158 |
SET_E_NTH_TRI(e0,0,t_id);
| 159 |
SET_E_NTH_TRI(e1,0,t_id);
| 160 |
SET_E_NTH_TRI(e2,0,t_id);
| 161 |
gwlarson |
3.12 |
#ifdef DEBUG
| 162 |
#if DEBUG > 1
| 163 |
if(E_NTH_TRI(e0,1) == E_NTH_TRI(e0,0) ||
| 164 |
E_NTH_TRI(e1,1) == E_NTH_TRI(e1,0) ||
| 165 |
E_NTH_TRI(e2,1) == E_NTH_TRI(e2,0))
| 166 |
error(CONSISTENCY,"Non manifold\n");
| 167 |
#endif
| 168 |
#endif
| 169 |
gwlarson |
3.7 |
*e2ptr = e2;
| 170 |
return(t_id);
| 171 |
gwlarson |
3.12 |
| 172 |
gwlarson |
3.1 |
| 173 |
| 174 |
gwlarson |
3.12 |
int
| 175 |
smTriangulate_quad(sm,l)
| 176 |
SM *sm;
| 177 |
LIST *l;
| 178 |
gwlarson |
3.1 |
| 179 |
greg |
3.13 |
int e1,e2,e3,e4,e,t_id;
| 180 |
S_ID id0,id1,id2,id3;
| 181 |
gwlarson |
3.12 |
FVECT v0,v1,v2,v3,n;
| 182 |
double dp;
| 183 |
TRI *tri;
| 184 |
LIST *lptr;
| 185 |
gwlarson |
3.1 |
| 186 |
gwlarson |
3.12 |
#ifdef DEBUG
| 187 |
if(LIST_NEXT(LIST_NEXT(LIST_NEXT(LIST_NEXT(l)))) != l)
| 188 |
| 189 |
eputs("smTriangulate_quad(): not a quadrilateral\n");
| 190 |
return(FALSE);
| 191 |
| 192 |
eputs("smTriangulate_quad():\n");
| 193 |
#endif
| 194 |
lptr=l;
| 195 |
e1 = (int)LIST_DATA(l);
| 196 |
id0 = E_NTH_VERT(e1,0);
| 197 |
id1 = E_NTH_VERT(e1,1);
| 198 |
VSUB(v0,SM_NTH_WV(sm,id0),SM_VIEW_CENTER(sm));
| 199 |
VSUB(v1,SM_NTH_WV(sm,id1),SM_VIEW_CENTER(sm));
| 200 |
/* Get v2 */
| 201 |
l = LIST_NEXT(l);
| 202 |
e2 = (int)LIST_DATA(l);
| 203 |
id2 = E_NTH_VERT(e2,1);
| 204 |
VSUB(v2,SM_NTH_WV(sm,id2),SM_VIEW_CENTER(sm));
| 205 |
/* Get v3 */
| 206 |
l = LIST_NEXT(l);
| 207 |
e3 = (int)LIST_DATA(l);
| 208 |
id3 = E_NTH_VERT(e3,1);
| 209 |
VSUB(v3,SM_NTH_WV(sm,id3),SM_VIEW_CENTER(sm));
| 210 |
l = LIST_NEXT(l);
| 211 |
e4 = (int)LIST_DATA(l);
| 212 |
free_list(lptr);
| 213 |
| 214 |
VCROSS(n,v0,v2);
| 215 |
normalize(n);
| 216 |
normalize(v1);
| 217 |
dp = DOT(n,v1);
| 218 |
e = 0;
| 219 |
if(dp > 0)
| 220 |
| 221 |
if(dp >= EV_EPS)
| 222 |
gwlarson |
3.1 |
| 223 |
gwlarson |
3.12 |
normalize(v3);
| 224 |
if(DOT(n,v3) < 0)
| 225 |
| 226 |
t_id = smTriangulate_add_tri(sm,id0,id1,id2,e1,e2,&e);
| 227 |
e *= -1;
| 228 |
t_id = smTriangulate_add_tri(sm,id2,id3,id0,e3,e4,&e);
| 229 |
return(TRUE);
| 230 |
| 231 |
| 232 |
gwlarson |
3.1 |
| 233 |
gwlarson |
3.12 |
| 234 |
#ifdef DEBUG
| 235 |
#if DEBUG > 1
| 236 |
VCROSS(n,v1,v3);
| 237 |
normalize(n);
| 238 |
normalize(v0);
| 239 |
normalize(v2);
| 240 |
dp = DOT(n,v2);
| 241 |
if((dp < 0) || (dp < EV_EPS) || (DOT(n,v0) >= 0.0))
| 242 |
error(CONSISTENCY,"smTriangulate_quad: cannot triangulate\n");
| 243 |
#endif
| 244 |
#endif
| 245 |
t_id = smTriangulate_add_tri(sm,id1,id2,id3,e2,e3,&e);
| 246 |
e *= -1;
| 247 |
t_id = smTriangulate_add_tri(sm,id3,id0,id1,e4,e1,&e);
| 248 |
return(TRUE);
| 249 |
gwlarson |
3.1 |
| 250 |
| 251 |
greg |
3.13 |
eIn_tri(e,t)
| 252 |
int e;
| 253 |
TRI *t;
| 254 |
| 255 |
| 256 |
if(T_NTH_V(t,0)==E_NTH_VERT(e,0))
| 257 |
return(T_NTH_V(t,1)==E_NTH_VERT(e,1)||T_NTH_V(t,2)==E_NTH_VERT(e,1));
| 258 |
else
| 259 |
if(T_NTH_V(t,1)==E_NTH_VERT(e,0))
| 260 |
return(T_NTH_V(t,0)==E_NTH_VERT(e,1)||T_NTH_V(t,2)==E_NTH_VERT(e,1));
| 261 |
else if(T_NTH_V(t,2)==E_NTH_VERT(e,0))
| 262 |
return(T_NTH_V(t,0)==E_NTH_VERT(e,1)||T_NTH_V(t,1)==E_NTH_VERT(e,1));
| 263 |
| 264 |
return(FALSE);
| 265 |
| 266 |
| 267 |
| 268 |
gwlarson |
3.7 |
/* Triangulate the polygon defined by plist, and generating vertex p_id.
| 269 |
Return list of added triangles in list add_ptr. Returns TRUE if
| 270 |
successful, FALSE otherwise. This is NOT a general triangulation routine,
| 271 |
assumes polygon star relative to id
| 272 |
| 273 |
gwlarson |
3.6 |
| 274 |
int
| 275 |
gwlarson |
3.12 |
smTriangulate(sm,id,plist)
| 276 |
gwlarson |
3.6 |
SM *sm;
| 277 |
greg |
3.13 |
S_ID id;
| 278 |
gwlarson |
3.12 |
LIST *plist;
| 279 |
gwlarson |
3.1 |
| 280 |
gwlarson |
3.6 |
LIST *l,*prev,*t;
| 281 |
FVECT v0,v1,v2,n,p;
| 282 |
greg |
3.13 |
int is_tri,cut,t_id,e2,e1,enew;
| 283 |
S_ID id0,id1,id2;
| 284 |
gwlarson |
3.12 |
double dp1,dp2;
| 285 |
gwlarson |
3.6 |
| 286 |
gwlarson |
3.7 |
VSUB(p,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm));
| 287 |
gwlarson |
3.12 |
normalize(p);
| 288 |
l = plist;
| 289 |
| 290 |
gwlarson |
3.7 |
enew = 0;
| 291 |
gwlarson |
3.12 |
cut = is_tri= FALSE;
| 292 |
prev = l;
| 293 |
gwlarson |
3.7 |
/* get v0,v1 */
| 294 |
| 295 |
| 296 |
| 297 |
| 298 |
gwlarson |
3.12 |
normalize(v0);
| 299 |
gwlarson |
3.7 |
| 300 |
gwlarson |
3.12 |
normalize(v1);
| 301 |
gwlarson |
3.6 |
while(l)
| 302 |
| 303 |
l = LIST_NEXT(l);
| 304 |
gwlarson |
3.7 |
/* Get v2 */
| 305 |
gwlarson |
3.6 |
| 306 |
| 307 |
gwlarson |
3.7 |
| 308 |
gwlarson |
3.12 |
normalize(v2);
| 309 |
gwlarson |
3.6 |
if(LIST_NEXT(LIST_NEXT(l)) == prev)
| 310 |
gwlarson |
3.7 |
{/* Check if have a triangle */
| 311 |
is_tri = TRUE;
| 312 |
break;
| 313 |
| 314 |
/* determine if v0-v1-v2 is convex:defined clockwise on the sphere-
| 315 |
so switch orientation
| 316 |
| 317 |
gwlarson |
3.12 |
VCROSS(n,v0,v2);
| 318 |
normalize(n);
| 319 |
dp1 = DOT(n,p);
| 320 |
if(dp1 <= 0.0)
| 321 |
gwlarson |
3.6 |
| 322 |
gwlarson |
3.7 |
/* test if safe to cut off v0-v1-v2 by testing if p lies outside of
| 323 |
triangle v0-v1-v2: if so, because plist is the star polygon around p,
| 324 |
the new edge v2-v0 cannot intersect any existing edges
| 325 |
| 326 |
gwlarson |
3.12 |
dp1 = DOT(n,v1);
| 327 |
/* Distance from point s to plane is d = |N.p0s|/||N|| */
| 328 |
/* sp1 = s-p0 for point on plane p0, a.(b+c) = a.b + a.c */
| 329 |
if(dp1 >= EV_EPS)
| 330 |
| 331 |
gwlarson |
3.7 |
/* remove edges e1,e2 and add triangle id0,id1,id2 */
| 332 |
gwlarson |
3.12 |
enew = 0;
| 333 |
t_id = smTriangulate_add_tri(sm,id0,id1,id2,e1,e2,&enew);
| 334 |
cut = TRUE;
| 335 |
/* Insert edge enew into the list, reuse prev list element */
| 336 |
LIST_NEXT(prev) = LIST_NEXT(l);
| 337 |
LIST_DATA(prev) = e1 = -enew;
| 338 |
/* If removing head of list- reset plist pointer */
| 339 |
if(l== plist)
| 340 |
plist = prev;
| 341 |
/* free list element for e2 */
| 342 |
LIST_NEXT(l)=NULL;
| 343 |
free_list(l);
| 344 |
l = prev;
| 345 |
VCOPY(v1,v2);
| 346 |
id1 = id2;
| 347 |
continue;
| 348 |
gwlarson |
3.7 |
| 349 |
greg |
3.13 |
| 350 |
gwlarson |
3.7 |
VCOPY(v0,v1);
| 351 |
VCOPY(v1,v2);
| 352 |
id0 = id1;
| 353 |
id1 = id2;
| 354 |
e1 = e2;
| 355 |
/* check if gone around circular list without adding any
| 356 |
triangles: prevent infinite loop */
| 357 |
if(l == plist)
| 358 |
gwlarson |
3.6 |
| 359 |
gwlarson |
3.7 |
| 360 |
| 361 |
is_tri = TRUE;
| 362 |
break;
| 363 |
| 364 |
gwlarson |
3.12 |
if(!cut)
| 365 |
gwlarson |
3.6 |
break;
| 366 |
gwlarson |
3.7 |
cut = FALSE;
| 367 |
greg |
3.13 |
| 368 |
gwlarson |
3.7 |
prev = l;
| 369 |
greg |
3.13 |
| 370 |
if(is_tri)
| 371 |
| 372 |
gwlarson |
3.6 |
l = LIST_NEXT(l);
| 373 |
gwlarson |
3.7 |
enew = (int)LIST_DATA(l);
| 374 |
| 375 |
gwlarson |
3.6 |
free_list(l);
| 376 |
greg |
3.13 |
| 377 |
else
| 378 |
if(!smTriangulate_quad(sm,l))
| 379 |
gwlarson |
3.12 |
goto Terror;
| 380 |
gwlarson |
3.7 |
/* Set triangle adjacencies based on edge adjacencies */
| 381 |
FOR_ALL_EDGES(enew)
| 382 |
gwlarson |
3.1 |
| 383 |
gwlarson |
3.7 |
id0 = E_NTH_TRI(enew,0);
| 384 |
id1 = E_NTH_TRI(enew,1);
| 385 |
gwlarson |
3.1 |
| 386 |
gwlarson |
3.7 |
e1 = (T_WHICH_V(SM_NTH_TRI(sm,id0),E_NTH_VERT(enew,0))+2)%3;
| 387 |
T_NTH_NBR(SM_NTH_TRI(sm,id0),e1) = id1;
| 388 |
| 389 |
e2 = (T_WHICH_V(SM_NTH_TRI(sm,id1),E_NTH_VERT(enew,1))+2)%3;
| 390 |
T_NTH_NBR(SM_NTH_TRI(sm,id1),e2) = id0;
| 391 |
greg |
3.13 |
| 392 |
gwlarson |
3.12 |
| 393 |
#ifdef DEBUG
| 394 |
#if DEBUG > 1
| 395 |
| 396 |
TRI *t0,*t1,*n;
| 397 |
| 398 |
FOR_ALL_EDGES(enew)
| 399 |
| 400 |
| 401 |
| 402 |
t0 = SM_NTH_TRI(sm,id0);
| 403 |
t1 = SM_NTH_TRI(sm,id1);
| 404 |
if(T_NTH_NBR(t0,0) == T_NTH_NBR(t0,1) ||
| 405 |
T_NTH_NBR(t0,1) == T_NTH_NBR(t0,2) ||
| 406 |
T_NTH_NBR(t0,0) == T_NTH_NBR(t0,2))
| 407 |
error(CONSISTENCY,"Invalid topology\n");
| 408 |
if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,0))) ||
| 409 |
!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,1))) ||
| 410 |
!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,2))))
| 411 |
| 412 |
n = SM_NTH_TRI(sm,T_NTH_NBR(t0,0));
| 413 |
if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
| 414 |
T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
| 415 |
T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
| 416 |
| 417 |
if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
| 418 |
!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
| 419 |
!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
| 420 |
| 421 |
n = SM_NTH_TRI(sm,T_NTH_NBR(t0,1));
| 422 |
| 423 |
| 424 |
| 425 |
| 426 |
| 427 |
| 428 |
| 429 |
| 430 |
n = SM_NTH_TRI(sm,T_NTH_NBR(t0,2));
| 431 |
| 432 |
| 433 |
| 434 |
| 435 |
| 436 |
| 437 |
| 438 |
| 439 |
| 440 |
if(T_NTH_NBR(t1,0) == T_NTH_NBR(t1,1) ||
| 441 |
T_NTH_NBR(t1,1) == T_NTH_NBR(t1,2) ||
| 442 |
T_NTH_NBR(t1,0) == T_NTH_NBR(t1,2))
| 443 |
| 444 |
if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,0))) ||
| 445 |
!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,1))) ||
| 446 |
!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,2))))
| 447 |
| 448 |
n = SM_NTH_TRI(sm,T_NTH_NBR(t1,0));
| 449 |
| 450 |
| 451 |
| 452 |
| 453 |
| 454 |
| 455 |
| 456 |
| 457 |
n = SM_NTH_TRI(sm,T_NTH_NBR(t1,1));
| 458 |
| 459 |
| 460 |
| 461 |
| 462 |
| 463 |
| 464 |
| 465 |
| 466 |
n = SM_NTH_TRI(sm,T_NTH_NBR(t1,2));
| 467 |
| 468 |
| 469 |
| 470 |
| 471 |
| 472 |
| 473 |
| 474 |
| 475 |
greg |
3.13 |
| 476 |
| 477 |
| 478 |
gwlarson |
3.12 |
#endif
| 479 |
greg |
3.13 |
#endif
| 480 |
| 481 |
gwlarson |
3.7 |
return(TRUE);
| 482 |
gwlarson |
3.12 |
| 483 |
Terror:
| 484 |
greg |
3.13 |
| 485 |
gwlarson |
3.12 |
error(CONSISTENCY,"smTriangulate():Unable to triangulate\n");
| 486 |
gwlarson |
3.7 |
| 487 |
gwlarson |
3.1 |
| 488 |
gwlarson |
3.6 |
| 489 |
gwlarson |
3.12 |
| 490 |
void
| 491 |
smTris_swap_edge(sm,t_id,t1_id,e,e1,tn_id,tn1_id)
| 492 |
SM *sm;
| 493 |
int t_id,t1_id;
| 494 |
int e,e1;
| 495 |
int *tn_id,*tn1_id;
| 496 |
| 497 |
greg |
3.13 |
S_ID verts[3];
| 498 |
int enext,eprev,e1next,e1prev;
| 499 |
gwlarson |
3.12 |
TRI *n,*ta,*tb,*t,*t1;
| 500 |
FVECT p1,p2,p3;
| 501 |
int ta_id,tb_id;
| 502 |
/* form new diagonal (e relative to t, and e1 relative to t1)
| 503 |
defined by quadrilateral formed by t,t1- swap for the opposite diagonal
| 504 |
| 505 |
t = SM_NTH_TRI(sm,t_id);
| 506 |
t1 = SM_NTH_TRI(sm,t1_id);
| 507 |
enext = (e+1)%3;
| 508 |
eprev = (e+2)%3;
| 509 |
e1next = (e1+1)%3;
| 510 |
e1prev = (e1+2)%3;
| 511 |
verts[e] = T_NTH_V(t,e);
| 512 |
verts[enext] = T_NTH_V(t,enext);
| 513 |
verts[eprev] = T_NTH_V(t1,e1);
| 514 |
ta_id = smAdd_tri(sm,verts[0],verts[1],verts[2],&ta);
| 515 |
#if 0
| 516 |
fprintf(stderr,"Added tri %d %d %d %d\n",ta_id,T_NTH_V(ta,0),
| 517 |
T_NTH_V(ta,1), T_NTH_V(ta,2));
| 518 |
#endif
| 519 |
verts[e1] = T_NTH_V(t1,e1);
| 520 |
verts[e1next] = T_NTH_V(t1,e1next);
| 521 |
verts[e1prev] = T_NTH_V(t,e);
| 522 |
tb_id = smAdd_tri(sm,verts[0],verts[1],verts[2],&tb);
| 523 |
#if 0
| 524 |
fprintf(stderr,"Added tri %d %d %d %d\n",tb_id,T_NTH_V(tb,0),
| 525 |
T_NTH_V(tb,1), T_NTH_V(tb,2));
| 526 |
#endif
| 527 |
/* set the neighbors */
| 528 |
T_NTH_NBR(ta,e) = T_NTH_NBR(t1,e1next);
| 529 |
T_NTH_NBR(tb,e1) = T_NTH_NBR(t,enext);
| 530 |
T_NTH_NBR(ta,enext)= tb_id;
| 531 |
T_NTH_NBR(tb,e1next)= ta_id;
| 532 |
T_NTH_NBR(ta,eprev)=T_NTH_NBR(t,eprev);
| 533 |
T_NTH_NBR(tb,e1prev)=T_NTH_NBR(t1,e1prev);
| 534 |
| 535 |
/* Reset neighbor pointers of original neighbors */
| 536 |
n = SM_NTH_TRI(sm,T_NTH_NBR(t,enext));
| 537 |
T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = tb_id;
| 538 |
n = SM_NTH_TRI(sm,T_NTH_NBR(t,eprev));
| 539 |
T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = ta_id;
| 540 |
n = SM_NTH_TRI(sm,T_NTH_NBR(t1,e1next));
| 541 |
T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = ta_id;
| 542 |
n = SM_NTH_TRI(sm,T_NTH_NBR(t1,e1prev));
| 543 |
T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = tb_id;
| 544 |
| 545 |
smDelete_tri(sm,t_id,t);
| 546 |
smDelete_tri(sm,t1_id,t1);
| 547 |
| 548 |
#ifdef DEBUG
| 549 |
#if DEBUG > 1
| 550 |
if(T_NTH_NBR(ta,0) == T_NTH_NBR(ta,1) ||
| 551 |
T_NTH_NBR(ta,1) == T_NTH_NBR(ta,2) ||
| 552 |
T_NTH_NBR(ta,0) == T_NTH_NBR(ta,2))
| 553 |
| 554 |
if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,0))) ||
| 555 |
!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,1))) ||
| 556 |
!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,2))))
| 557 |
| 558 |
n = SM_NTH_TRI(sm,T_NTH_NBR(ta,0));
| 559 |
| 560 |
| 561 |
| 562 |
| 563 |
| 564 |
| 565 |
| 566 |
| 567 |
n = SM_NTH_TRI(sm,T_NTH_NBR(ta,1));
| 568 |
| 569 |
| 570 |
| 571 |
| 572 |
| 573 |
| 574 |
| 575 |
| 576 |
n = SM_NTH_TRI(sm,T_NTH_NBR(ta,2));
| 577 |
| 578 |
| 579 |
| 580 |
| 581 |
| 582 |
| 583 |
| 584 |
| 585 |
| 586 |
| 587 |
| 588 |
| 589 |
| 590 |
if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,0))) ||
| 591 |
!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,1))) ||
| 592 |
!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,2))))
| 593 |
| 594 |
n = SM_NTH_TRI(sm,T_NTH_NBR(tb,0));
| 595 |
| 596 |
| 597 |
| 598 |
| 599 |
| 600 |
| 601 |
| 602 |
| 603 |
n = SM_NTH_TRI(sm,T_NTH_NBR(tb,1));
| 604 |
| 605 |
| 606 |
| 607 |
| 608 |
| 609 |
| 610 |
| 611 |
| 612 |
n = SM_NTH_TRI(sm,T_NTH_NBR(tb,2));
| 613 |
| 614 |
| 615 |
| 616 |
| 617 |
| 618 |
| 619 |
| 620 |
| 621 |
#endif
| 622 |
#endif
| 623 |
*tn_id = ta_id;
| 624 |
*tn1_id = tb_id;
| 625 |
| 626 |
return;
| 627 |
| 628 |
| 629 |
gwlarson |
3.7 |
/* Test the new set of triangles for Delaunay condition. 'Edges' contains
| 630 |
all of the new edges added. The CCW triangle assoc with each edge is
| 631 |
tested against the opposite vertex of the CW triangle. If the vertex
| 632 |
lies inside the circle defined by the CCW triangle- the edge is swapped
| 633 |
| 634 |
| 635 |
gwlarson |
3.12 |
smFixEdges(sm)
| 636 |
gwlarson |
3.1 |
SM *sm;
| 637 |
| 638 |
gwlarson |
3.6 |
int e,t0_id,t1_id,e_new,e0,e1,e0_next,e1_next;
| 639 |
greg |
3.13 |
S_ID v0_id,v1_id,v2_id,p_id;
| 640 |
int i,t0_nid,t1_nid;
| 641 |
gwlarson |
3.1 |
FVECT v0,v1,v2,p,np,v;
| 642 |
gwlarson |
3.7 |
TRI *t0,*t1;
| 643 |
gwlarson |
3.5 |
| 644 |
gwlarson |
3.1 |
FOR_ALL_EDGES(e)
| 645 |
| 646 |
gwlarson |
3.6 |
t0_id = E_NTH_TRI(e,0);
| 647 |
t1_id = E_NTH_TRI(e,1);
| 648 |
gwlarson |
3.12 |
#ifdef DEBUG
| 649 |
gwlarson |
3.6 |
if((t0_id==INVALID) || (t1_id==INVALID))
| 650 |
gwlarson |
3.12 |
error(CONSISTENCY,"smFix_edges: Unassigned edge nbr\n");
| 651 |
gwlarson |
3.1 |
#endif
| 652 |
gwlarson |
3.7 |
t0 = SM_NTH_TRI(sm,t0_id);
| 653 |
| 654 |
e0 = T_NTH_NBR_PTR(t1_id,t0);
| 655 |
e1 = T_NTH_NBR_PTR(t0_id,t1);
| 656 |
| 657 |
gwlarson |
3.6 |
v0_id = E_NTH_VERT(e,0);
| 658 |
v1_id = E_NTH_VERT(e,1);
| 659 |
gwlarson |
3.7 |
v2_id = T_NTH_V(t0,e0);
| 660 |
p_id = T_NTH_V(t1,e1);
| 661 |
gwlarson |
3.1 |
| 662 |
gwlarson |
3.11 |
smDir(sm,v0,v0_id);
| 663 |
smDir(sm,v1,v1_id);
| 664 |
smDir(sm,v2,v2_id);
| 665 |
gwlarson |
3.1 |
| 666 |
gwlarson |
3.12 |
VSUB(p,SM_NTH_WV(sm,p_id),SM_VIEW_CENTER(sm));
| 667 |
normalize(p);
| 668 |
if(pt_in_cone(p,v2,v1,v0))
| 669 |
gwlarson |
3.1 |
| 670 |
gwlarson |
3.12 |
smTris_swap_edge(sm,t0_id,t1_id,e0,e1,&t0_nid,&t1_nid);
| 671 |
gwlarson |
3.7 |
/* Adjust the triangle pointers of the remaining edges to be
| 672 |
processed
| 673 |
| 674 |
gwlarson |
3.1 |
FOR_ALL_EDGES_FROM(e,i)
| 675 |
| 676 |
gwlarson |
3.6 |
if(E_NTH_TRI(i,0)==t0_id || E_NTH_TRI(i,0)==t1_id)
| 677 |
gwlarson |
3.1 |
| 678 |
gwlarson |
3.6 |
if(eIn_tri(i,SM_NTH_TRI(sm,t0_nid)))
| 679 |
SET_E_NTH_TRI(i,0,t0_nid);
| 680 |
gwlarson |
3.1 |
else
| 681 |
gwlarson |
3.6 |
SET_E_NTH_TRI(i,0,t1_nid);
| 682 |
gwlarson |
3.1 |
| 683 |
| 684 |
gwlarson |
3.6 |
if(E_NTH_TRI(i,1)==t0_id || E_NTH_TRI(i,1)==t1_id)
| 685 |
gwlarson |
3.1 |
| 686 |
gwlarson |
3.6 |
| 687 |
SET_E_NTH_TRI(i,1,t0_nid);
| 688 |
gwlarson |
3.1 |
else
| 689 |
gwlarson |
3.6 |
SET_E_NTH_TRI(i,1,t1_nid);
| 690 |
gwlarson |
3.1 |
| 691 |
gwlarson |
3.12 |
#ifdef DEBUG
| 692 |
if(E_NTH_TRI(i,1) == E_NTH_TRI(i,0) )
| 693 |
error(CONSISTENCY,"invalid edge\n");
| 694 |
#endif
| 695 |
gwlarson |
3.1 |
| 696 |
gwlarson |
3.6 |
t0_id = t0_nid;
| 697 |
t1_id = t1_nid;
| 698 |
gwlarson |
3.1 |
e_new = eNew_edge();
| 699 |
gwlarson |
3.6 |
SET_E_NTH_VERT(e_new,0,p_id);
| 700 |
SET_E_NTH_VERT(e_new,1,v2_id);
| 701 |
SET_E_NTH_TRI(e_new,0,t0_id);
| 702 |
SET_E_NTH_TRI(e_new,1,t1_id);
| 703 |
gwlarson |
3.12 |
#ifdef DEBUG
| 704 |
| 705 |
| 706 |
#endif
| 707 |
gwlarson |
3.1 |
| 708 |
| 709 |
| 710 |
| 711 |
gwlarson |
3.12 |
| 712 |
smDelete_samp(sm,s_id)
| 713 |
SM *sm;
| 714 |
greg |
3.13 |
S_ID s_id;
| 715 |
gwlarson |
3.12 |
| 716 |
QUADTREE qt;
| 717 |
greg |
3.13 |
S_ID *os;
| 718 |
gwlarson |
3.12 |
| 719 |
/* Mark as free */
| 720 |
smUnalloc_samp(sm,s_id);
| 721 |
| 722 |
#ifdef DEBUG
| 723 |
SM_NTH_VERT(sm,s_id) = INVALID;
| 724 |
/* fprintf(stderr,"deleting sample %d\n",s_id); */
| 725 |
#endif
| 726 |
/* remove from its set */
| 727 |
qt = SM_S_NTH_QT(sm,s_id);
| 728 |
os = qtqueryset(qt);
| 729 |
deletuelem(os, s_id); /* delete obj from unsorted os, no questions */
| 730 |
| 731 |
gwlarson |
3.7 |
/* Remove vertex "id" from the mesh- and retriangulate the resulting
| 732 |
hole: Returns TRUE if successful, FALSE otherwise.
| 733 |
| 734 |
gwlarson |
3.1 |
int
| 735 |
gwlarson |
3.7 |
smRemoveVertex(sm,id)
| 736 |
gwlarson |
3.1 |
SM *sm;
| 737 |
greg |
3.13 |
S_ID id;
| 738 |
gwlarson |
3.1 |
| 739 |
gwlarson |
3.12 |
LIST *b_list;
| 740 |
gwlarson |
3.7 |
/* generate list of edges that form the boundary of the
| 741 |
gwlarson |
3.12 |
polygon formed by the triangles adjacent to vertex 'id'*/
| 742 |
b_list = smVertexStar(sm,id);
| 743 |
#if 0
| 744 |
{int i;
| 745 |
eputs("\n\n");
| 746 |
for(i=1;i<=Ecnt;i++)
| 747 |
fprintf(stderr,"%d verts %d %d tris %d %d\n",
| 748 |
i,Edges[i].verts[0],Edges[i].verts[1],
| 749 |
Edges[i].tris[0],Edges[i].tris[1]);
| 750 |
| 751 |
#endif
| 752 |
| 753 |
gwlarson |
3.7 |
/* Triangulate polygonal hole */
| 754 |
gwlarson |
3.12 |
smTriangulate(sm,id,b_list);
| 755 |
| 756 |
/* Fix up new triangles to be Delaunay*/
| 757 |
gwlarson |
3.7 |
| 758 |
gwlarson |
3.12 |
smFixEdges(sm);
| 759 |
smDelete_samp(sm,id);
| 760 |
eClear_edges();
| 761 |
gwlarson |
3.1 |
return(TRUE);
| 762 |
| 763 |
| 764 |
| 765 |
| 766 |
gwlarson |
3.8 |
| 767 |
gwlarson |
3.1 |
| 768 |
| 769 |
| 770 |
| 771 |
| 772 |
| 773 |
| 774 |
| 775 |
| 776 |
| 777 |
