1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* sm_del.c |
9 |
10 |
#include "standard.h" |
11 |
12 |
#include "sm_list.h" |
13 |
#include "sm_geom.h" |
14 |
#include "sm.h" |
15 |
16 |
static EDGE Edges[MAX_EDGES]; |
17 |
static int Ecnt=0; |
18 |
19 |
int |
20 |
remove_tri(qtptr,fptr,t_id) |
21 |
QUADTREE *qtptr; |
22 |
int *fptr; |
23 |
int t_id; |
24 |
25 |
int n; |
26 |
27 |
if(QT_IS_EMPTY(*qtptr)) |
28 |
return(FALSE); |
29 |
/* remove id from set */ |
30 |
else |
31 |
32 |
if(!qtinset(*qtptr,t_id)) |
33 |
return(FALSE); |
34 |
n = QT_SET_CNT(qtqueryset(*qtptr))-1; |
35 |
*qtptr = qtdelelem(*qtptr,t_id); |
36 |
if(n == 0) |
37 |
(*fptr) |= QT_COMPRESS; |
38 |
if(!QT_FLAG_FILL_TRI(*fptr)) |
39 |
(*fptr)++; |
40 |
41 |
return(TRUE); |
42 |
43 |
44 |
int |
45 |
remove_tri_compress(qtptr,q0,q1,q2,t0,t1,t2,n,arg,t_id) |
46 |
QUADTREE *qtptr; |
47 |
FVECT q0,q1,q2; |
48 |
FVECT t0,t1,t2; |
49 |
int n; |
50 |
int *arg; |
51 |
int t_id; |
52 |
53 |
int f = 0; |
54 |
/* NOTE compress */ |
55 |
return(remove_tri(qtptr,&f,t_id)); |
56 |
57 |
58 |
59 |
smLocator_remove_tri(sm,t_id) |
60 |
SM *sm; |
61 |
int t_id; |
62 |
63 |
STREE *st; |
64 |
TRI *t; |
65 |
FVECT v0,v1,v2; |
66 |
67 |
st = SM_LOCATOR(sm); |
68 |
69 |
t = SM_NTH_TRI(sm,t_id); |
70 |
71 |
VSUB(v0,SM_T_NTH_WV(sm,t,0),SM_VIEW_CENTER(sm)); |
72 |
VSUB(v1,SM_T_NTH_WV(sm,t,1),SM_VIEW_CENTER(sm)); |
73 |
VSUB(v2,SM_T_NTH_WV(sm,t,2),SM_VIEW_CENTER(sm)); |
74 |
stApply_to_tri(st,v0,v1,v2,remove_tri,remove_tri_compress,t_id,NULL); |
75 |
76 |
77 |
smFree_tri(sm,id) |
78 |
SM *sm; |
79 |
int id; |
80 |
81 |
TRI *tri; |
82 |
83 |
tri = SM_NTH_TRI(sm,id); |
84 |
/* Add to the free_list */ |
85 |
T_NEXT_FREE(tri) = SM_FREE_TRIS(sm); |
86 |
SM_FREE_TRIS(sm) = id; |
87 |
T_VALID_FLAG(tri) = -1; |
88 |
89 |
90 |
/* Assumes mesh pointers have been cleaned up appropriately: just deletes from |
91 |
Point location and triangle data structure |
92 |
93 |
smDelete_tri(sm,t_id) |
94 |
SM *sm; |
95 |
int t_id; |
96 |
97 |
98 |
99 |
/* NOTE: Assumes that a new triangle adjacent to each vertex |
100 |
has been added- before the deletion: replacing |
101 |
the old tri- and therefore dont need to dereference any pointers |
102 |
to id because the vertices can no longer |
103 |
point to tri id as being the first triangle pointer |
104 |
105 |
if(!SM_IS_NTH_T_BASE(sm,t_id)) |
106 |
107 |
SM_NUM_TRIS(sm)--; |
108 |
if(SM_IS_NTH_T_NEW(sm,t_id)) |
109 |
smNew_tri_cnt--; |
110 |
111 |
smClear_tri_flags(sm,t_id); |
112 |
113 |
smFree_tri(sm,t_id); |
114 |
115 |
116 |
117 |
118 |
LIST |
119 |
*smVertex_star_polygon(sm,id,del_set) |
120 |
SM *sm; |
121 |
int id; |
122 |
OBJECT *del_set; |
123 |
124 |
TRI *tri,*t_next; |
125 |
LIST *elist,*end; |
126 |
int t_id,v_next,t_next_id; |
127 |
int e; |
128 |
129 |
elist = end = NULL; |
130 |
/* Get the first triangle adjacent to vertex id */ |
131 |
t_id = SM_NTH_VERT(sm,id); |
132 |
tri = SM_NTH_TRI(sm,t_id); |
133 |
134 |
135 |
if((e = eNew_edge()) == SM_INVALID) |
136 |
137 |
#ifdef DEBUG |
138 |
eputs("smVertex_star_polygon():Too many edges\n"); |
139 |
#endif |
140 |
return(NULL); |
141 |
142 |
elist = add_data_to_circular_list(elist,&end,e); |
143 |
v_next = (T_WHICH_V(tri,id)+1)%3; |
144 |
SET_E_NTH_VERT(e,0,T_NTH_V(tri,v_next)); |
145 |
SET_E_NTH_TRI(e,0,SM_INVALID); |
146 |
SET_E_NTH_TRI(e,1,T_NTH_NBR(tri,v_next)); |
147 |
v_next = (T_WHICH_V(tri,id)+2)%3; |
148 |
SET_E_NTH_VERT(e,1,T_NTH_V(tri,v_next)); |
149 |
150 |
151 |
t_next_id = t_id; |
152 |
t_next = tri; |
153 |
154 |
insertelem(del_set,t_id); |
155 |
156 |
while((t_next_id = smTri_next_ccw_nbr(sm,t_next,id)) != t_id) |
157 |
158 |
159 |
160 |
#ifdef DEBUG |
161 |
162 |
#endif |
163 |
return(NULL); |
164 |
165 |
166 |
t_next = SM_NTH_TRI(sm,t_next_id); |
167 |
v_next = (T_WHICH_V(t_next,id)+1)%3; |
168 |
SET_E_NTH_VERT(e,0,T_NTH_V(t_next,v_next)); |
169 |
170 |
SET_E_NTH_TRI(e,1,T_NTH_NBR(t_next,v_next)); |
171 |
v_next = (T_WHICH_V(t_next,id)+2)%3; |
172 |
SET_E_NTH_VERT(e,1,T_NTH_V(t_next,v_next)); |
173 |
insertelem(del_set,t_next_id); |
174 |
175 |
return(elist); |
176 |
177 |
178 |
int |
179 |
smEdge_intersect_polygon(sm,v0,v1,l) |
180 |
SM *sm; |
181 |
FVECT v0,v1; |
182 |
LIST *l; |
183 |
184 |
FVECT e0,e1; |
185 |
int e,id_e0,id_e1; |
186 |
LIST *el,*eptr; |
187 |
188 |
/* Test the edges in l against v0v1 to see if v0v1 intersects |
189 |
any other edges |
190 |
191 |
192 |
el = l; |
193 |
194 |
while(el) |
195 |
196 |
e = (int)LIST_DATA(el); |
197 |
id_e0 = E_NTH_VERT(e,0); |
198 |
id_e1 = E_NTH_VERT(e,1); |
199 |
200 |
VSUB(e0,SM_NTH_WV(sm,id_e0),SM_VIEW_CENTER(sm)); |
201 |
VSUB(e1,SM_NTH_WV(sm,id_e1),SM_VIEW_CENTER(sm)); |
202 |
if(sedge_intersect(v0,v1,e0,e1)) |
203 |
return(TRUE); |
204 |
205 |
el = LIST_NEXT(el); |
206 |
if(el == l) |
207 |
break; |
208 |
209 |
return(FALSE); |
210 |
211 |
212 |
int |
213 |
smFind_next_convex_vertex(sm,id0,id1,v0,v1,l) |
214 |
SM *sm; |
215 |
int id0,id1; |
216 |
FVECT v0,v1; |
217 |
LIST *l; |
218 |
219 |
int e,id; |
220 |
LIST *el; |
221 |
FVECT v; |
222 |
223 |
/* starting with the end of edge at head of l, search sequentially for |
224 |
vertex v such that v0v1v is a convex angle, and the edge v1v does |
225 |
not intersect any other edges |
226 |
227 |
id = SM_INVALID; |
228 |
el = l; |
229 |
while(id != id0) |
230 |
231 |
232 |
id = E_NTH_VERT(e,1); |
233 |
234 |
smDir(sm,v,id); |
235 |
236 |
if(convex_angle(v0,v1,v) && !smEdge_intersect_polygon(sm,v1,v,l)) |
237 |
return(id); |
238 |
239 |
240 |
if(el == l) |
241 |
break; |
242 |
243 |
return(SM_INVALID); |
244 |
245 |
246 |
int |
247 |
split_edge_list(id0,id_new,l,lnew) |
248 |
int id0,id_new; |
249 |
LIST **l,**lnew; |
250 |
251 |
LIST *list,*lptr,*end; |
252 |
int e,e1,e2,new_e; |
253 |
254 |
e2 = SM_INVALID; |
255 |
list = lptr = *l; |
256 |
257 |
if((new_e = eNew_edge())==SM_INVALID) |
258 |
259 |
#ifdef DEBUG |
260 |
eputs("split_edge_list():Too many edges\n"); |
261 |
#endif |
262 |
return(FALSE); |
263 |
264 |
SET_E_NTH_VERT(new_e,0,id0); |
265 |
SET_E_NTH_VERT(new_e,1,id_new); |
266 |
SET_E_NTH_TRI(new_e,0,SM_INVALID); |
267 |
SET_E_NTH_TRI(new_e,1,SM_INVALID); |
268 |
269 |
while(e2 != id_new) |
270 |
271 |
lptr = LIST_NEXT(lptr); |
272 |
e = (int)LIST_DATA(lptr); |
273 |
e2 = E_NTH_VERT(e,1); |
274 |
if(lptr == list) |
275 |
276 |
#ifdef DEBUG |
277 |
eputs("split_edge_list():cant find vertex\n"); |
278 |
#endif |
279 |
*lnew = NULL; |
280 |
return(FALSE); |
281 |
282 |
283 |
284 |
end = lptr; |
285 |
286 |
list = add_data_to_circular_list(list,&end,-new_e); |
287 |
*lnew = list; |
288 |
289 |
/* now follow other cycle */ |
290 |
291 |
list = lptr; |
292 |
e2 = SM_INVALID; |
293 |
while(e2 != id0) |
294 |
295 |
296 |
297 |
298 |
if(lptr == list) |
299 |
300 |
#ifdef DEBUG |
301 |
eputs("split_edge_list():cant find intial vertex\n"); |
302 |
#endif |
303 |
*l = NULL; |
304 |
return(FALSE); |
305 |
306 |
307 |
308 |
end = lptr; |
309 |
list = add_data_to_circular_list(list,&end,new_e); |
310 |
*l = list; |
311 |
return(TRUE); |
312 |
313 |
314 |
315 |
int |
316 |
smTriangulate_convex(sm,plist,add_ptr) |
317 |
SM *sm; |
318 |
LIST *plist,**add_ptr; |
319 |
320 |
TRI *tri; |
321 |
int t_id,e_id0,e_id1,e_id2; |
322 |
int v_id0,v_id1,v_id2; |
323 |
LIST *lptr; |
324 |
int cnt; |
325 |
326 |
lptr = plist; |
327 |
e_id0 = (int)LIST_DATA(lptr); |
328 |
v_id0 = E_NTH_VERT(e_id0,0); |
329 |
330 |
while(LIST_NEXT(lptr) != plist) |
331 |
332 |
e_id1 = (int)LIST_DATA(lptr); |
333 |
v_id1 = E_NTH_VERT(e_id1,0); |
334 |
v_id2 = E_NTH_VERT(e_id1,1); |
335 |
/* form a triangle for each triple of with v0 as base of star */ |
336 |
t_id = smAdd_tri(sm,v_id0,v_id1,v_id2,&tri); |
337 |
*add_ptr = push_data(*add_ptr,t_id); |
338 |
339 |
/* add which pointer?*/ |
340 |
341 |
342 |
343 |
if(LIST_NEXT(lptr) != plist) |
344 |
345 |
e_id2 = eNew_edge(); |
346 |
SET_E_NTH_VERT(e_id2,0,v_id2); |
347 |
SET_E_NTH_VERT(e_id2,1,v_id0); |
348 |
349 |
else |
350 |
e_id2 = (int)LIST_DATA(lptr); |
351 |
352 |
/* set appropriate tri for each edge*/ |
353 |
SET_E_NTH_TRI(e_id0,0,t_id); |
354 |
SET_E_NTH_TRI(e_id1,0,t_id); |
355 |
SET_E_NTH_TRI(e_id2,0,t_id); |
356 |
357 |
e_id0 = -e_id2; |
358 |
359 |
free_list(plist); |
360 |
return(TRUE); |
361 |
362 |
int |
363 |
smTriangulate_elist(sm,plist,add_ptr) |
364 |
SM *sm; |
365 |
366 |
367 |
LIST *l,*el1; |
368 |
FVECT v0,v1,v2; |
369 |
int id0,id1,id2,e,id_next; |
370 |
char flipped; |
371 |
int done; |
372 |
373 |
l = plist; |
374 |
375 |
while(l) |
376 |
377 |
/* get v0,v1,v2 */ |
378 |
e = (int)LIST_DATA(l); |
379 |
id0 = E_NTH_VERT(e,0); |
380 |
id1 = E_NTH_VERT(e,1); |
381 |
l = LIST_NEXT(l); |
382 |
383 |
id2 = E_NTH_VERT(e,1); |
384 |
385 |
smDir(sm,v0,id0); |
386 |
smDir(sm,v1,id1); |
387 |
smDir(sm,v2,id2); |
388 |
/* determine if convex (left turn), or concave(right turn) angle */ |
389 |
if(convex_angle(v0,v1,v2)) |
390 |
391 |
if(l == plist) |
392 |
break; |
393 |
else |
394 |
continue; |
395 |
396 |
/* if concave: add edge and recurse on two sub polygons */ |
397 |
id_next = smFind_next_convex_vertex(sm,id0,id1,v0,v1,LIST_NEXT(l)); |
398 |
if(id_next == SM_INVALID) |
399 |
400 |
#ifdef DEBUG |
401 |
eputs("smTriangulate_elist():Unable to find convex vertex\n"); |
402 |
#endif |
403 |
return(FALSE); |
404 |
405 |
/* add edge */ |
406 |
el1 = NULL; |
407 |
/* Split edge list l into two lists: one from id1-id_next-id1, |
408 |
and the next from id2-id_next-id2 |
409 |
410 |
split_edge_list(id1,id_next,&l,&el1); |
411 |
/* Recurse and triangulate the two edge lists */ |
412 |
done = smTriangulate_elist(sm,l,add_ptr); |
413 |
if(done) |
414 |
done = smTriangulate_elist(sm,el1,add_ptr); |
415 |
return(done); |
416 |
417 |
done = smTriangulate_convex(sm,plist,add_ptr); |
418 |
return(done); |
419 |
420 |
421 |
int |
422 |
smTriangulate(sm,plist,add_ptr) |
423 |
SM *sm; |
424 |
425 |
426 |
int e,id_t0,id_t1,e0,e1; |
427 |
TRI *t0,*t1; |
428 |
int test; |
429 |
430 |
test = smTriangulate_elist(sm,plist,add_ptr); |
431 |
432 |
if(!test) |
433 |
return(test); |
434 |
FOR_ALL_EDGES(e) |
435 |
436 |
id_t0 = E_NTH_TRI(e,0); |
437 |
id_t1 = E_NTH_TRI(e,1); |
438 |
if((id_t0==SM_INVALID) || (id_t1==SM_INVALID)) |
439 |
440 |
#ifdef DEBUG |
441 |
eputs("smTriangulate(): Unassigned edge neighbor\n"); |
442 |
#endif |
443 |
continue; |
444 |
445 |
t0 = SM_NTH_TRI(sm,id_t0); |
446 |
t1 = SM_NTH_TRI(sm,id_t1); |
447 |
448 |
e0 = T_WHICH_V(t0,E_NTH_VERT(e,0)); |
449 |
T_NTH_NBR(t0,e0) = id_t1; |
450 |
451 |
e1 = T_WHICH_V(t1,E_NTH_VERT(e,1)); |
452 |
T_NTH_NBR(t1,e1) = id_t0; |
453 |
454 |
return(test); |
455 |
456 |
457 |
eIn_tri(e,t) |
458 |
int e; |
459 |
TRI *t; |
460 |
461 |
462 |
if(T_NTH_V(t,0)==E_NTH_VERT(e,0)) |
463 |
return(T_NTH_V(t,1)==E_NTH_VERT(e,1)||T_NTH_V(t,2)==E_NTH_VERT(e,1)); |
464 |
else |
465 |
if(T_NTH_V(t,1)==E_NTH_VERT(e,0)) |
466 |
return(T_NTH_V(t,0)==E_NTH_VERT(e,1)||T_NTH_V(t,2)==E_NTH_VERT(e,1)); |
467 |
else if(T_NTH_V(t,2)==E_NTH_VERT(e,0)) |
468 |
return(T_NTH_V(t,0)==E_NTH_VERT(e,1)||T_NTH_V(t,1)==E_NTH_VERT(e,1)); |
469 |
return(FALSE); |
470 |
471 |
smFix_edges(sm,add_list,del_set) |
472 |
SM *sm; |
473 |
LIST *add_list; |
474 |
OBJECT *del_set; |
475 |
476 |
int e,id_t0,id_t1,e_new,e0,e1,e0_next,e1_next; |
477 |
TRI *t0,*t1,*nt0,*nt1; |
478 |
int i,id_v0,id_v1,id_v2,id_p,nid_t0,nid_t1; |
479 |
FVECT v0,v1,v2,p,np,v; |
480 |
481 |
FOR_ALL_EDGES(e) |
482 |
483 |
484 |
485 |
486 |
487 |
#ifdef DEBUG |
488 |
eputs("smFix_edges: Unassigned edge nbr\n"); |
489 |
#endif |
490 |
continue; |
491 |
492 |
493 |
494 |
495 |
496 |
e1 = T_WHICH_V(t1,E_NTH_VERT(-e,0)); |
497 |
e0_next = (e0+2)%3; |
498 |
e1_next = (e1+2)%3; |
499 |
id_v0 = E_NTH_VERT(e,0); |
500 |
id_v1 = E_NTH_VERT(e,1); |
501 |
id_v2 = T_NTH_V(t0,e0_next); |
502 |
id_p = T_NTH_V(t1,e1_next); |
503 |
504 |
smDir_in_cone(sm,v0,id_v0); |
505 |
smDir_in_cone(sm,v1,id_v1); |
506 |
smDir_in_cone(sm,v2,id_v2); |
507 |
508 |
VCOPY(p,SM_NTH_WV(sm,id_p)); |
509 |
VSUB(p,p,SM_VIEW_CENTER(sm)); |
510 |
if(point_in_cone(p,v0,v1,v2)) |
511 |
512 |
smTris_swap_edge(sm,id_t0,id_t1,e0,e1,&nid_t0,&nid_t1,&add_list, |
513 |
del_set); |
514 |
515 |
nt0 = SM_NTH_TRI(sm,nid_t0); |
516 |
nt1 = SM_NTH_TRI(sm,nid_t1); |
517 |
FOR_ALL_EDGES_FROM(e,i) |
518 |
519 |
if(E_NTH_TRI(i,0)==id_t0 || E_NTH_TRI(i,0)==id_t1) |
520 |
521 |
if(eIn_tri(i,nt0)) |
522 |
SET_E_NTH_TRI(i,0,nid_t0); |
523 |
else |
524 |
SET_E_NTH_TRI(i,0,nid_t1); |
525 |
526 |
527 |
if(E_NTH_TRI(i,1)==id_t0 || E_NTH_TRI(i,1)==id_t1) |
528 |
529 |
530 |
SET_E_NTH_TRI(i,1,nid_t0); |
531 |
else |
532 |
SET_E_NTH_TRI(i,1,nid_t1); |
533 |
534 |
535 |
id_t0 = nid_t0; |
536 |
id_t1 = nid_t1; |
537 |
e_new = eNew_edge(); |
538 |
SET_E_NTH_VERT(e_new,0,id_p); |
539 |
SET_E_NTH_VERT(e_new,1,id_v2); |
540 |
SET_E_NTH_TRI(e_new,0,id_t0); |
541 |
SET_E_NTH_TRI(e_new,1,id_t1); |
542 |
543 |
544 |
smUpdate_locator(sm,add_list,del_set); |
545 |
546 |
547 |
int |
548 |
smMesh_remove_vertex(sm,id) |
549 |
SM *sm; |
550 |
int id; |
551 |
552 |
int tri; |
553 |
LIST *elist,*add_list; |
554 |
int cnt,debug; |
555 |
OBJECT del_set[QT_MAXSET +1]; |
556 |
557 |
/* generate list of vertices that form the boundary of the |
558 |
star polygon formed by vertex id and all of its adjacent |
559 |
triangles |
560 |
561 |
eClear_edges(); |
562 |
QT_CLEAR_SET(del_set); |
563 |
elist = smVertex_star_polygon(sm,id,del_set); |
564 |
if(!elist) |
565 |
return(FALSE); |
566 |
567 |
add_list = NULL; |
568 |
/* Triangulate spherical polygon */ |
569 |
smTriangulate(sm,elist,&add_list); |
570 |
571 |
572 |
/* Fix up new triangles to be Delaunay */ |
573 |
smFix_edges(sm,add_list,del_set); |
574 |
575 |
return(TRUE); |
576 |
577 |
578 |
/* Remove point from samples, and from mesh. Delete any triangles |
579 |
adjacent to the point and re-triangulate the hole |
580 |
Return TRUE is point found , FALSE otherwise |
581 |
582 |
int |
583 |
smDelete_point(sm,id) |
584 |
SM *sm; |
585 |
int id; |
586 |
587 |
588 |
/* Remove the corresponding vertex from the mesh */ |
589 |
smMesh_remove_vertex(sm,id); |
590 |
/* Free the sample point */ |
591 |
smDelete_sample(sm,id); |
592 |
return(TRUE); |
593 |
594 |
595 |
596 |
597 |
598 |
599 |
600 |
601 |
602 |
603 |
604 |
605 |
606 |
607 |
