root/radiance/ray/src/hd/sm_del.c
Revision: 3.4
Committed: Mon Sep 14 10:33:46 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.3: +6 -2 lines
optimized normalizing calls and bug fix in triangle counting
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * sm_del.c
9 */
10 #include "standard.h"
11
12 #include "sm_list.h"
13 #include "sm_geom.h"
14 #include "sm.h"
15
16 static EDGE Edges[MAX_EDGES];
17 static int Ecnt=0;
18
19 int
20 remove_tri(qtptr,fptr,t_id)
21 QUADTREE *qtptr;
22 int *fptr;
23 int t_id;
24 {
25 OBJECT tset[QT_MAXSET+1];
26 int n;
27
28 if(QT_IS_EMPTY(*qtptr))
29 return(FALSE);
30 /* remove id from set */
31 else
32 {
33 if(!qtinset(*qtptr,t_id))
34 return(FALSE);
35 n = QT_SET_CNT(qtqueryset(*qtptr))-1;
36 *qtptr = qtdelelem(*qtptr,t_id);
37 if(n == 0)
38 (*fptr) |= QT_COMPRESS;
39 if(!QT_FLAG_FILL_TRI(*fptr))
40 (*fptr)++;
41 }
42 return(TRUE);
43 }
44
45 int
46 remove_tri_compress(qtptr,q0,q1,q2,t0,t1,t2,n,arg,t_id)
47 QUADTREE *qtptr;
48 FVECT q0,q1,q2;
49 FVECT t0,t1,t2;
50 int n;
51 int *arg;
52 int t_id;
53 {
54 int f = 0;
55 /* NOTE compress */
56 return(remove_tri(qtptr,&f,t_id));
57 }
58
59
60
61 int
62 stDelete_tri(st,t_id,t0,t1,t2)
63 STREE *st;
64 int t_id;
65 FVECT t0,t1,t2;
66 {
67 int f;
68 FVECT dir;
69
70 /* First add all of the leaf cells lying on the triangle perimeter:
71 mark all cells seen on the way
72 */
73 ST_CLEAR_FLAGS(st);
74 f = 0;
75 VSUB(dir,t1,t0);
76 stTrace_edge(st,t0,dir,1.0,remove_tri,&f,t_id);
77 VSUB(dir,t2,t1);
78 stTrace_edge(st,t1,dir,1.0,remove_tri,&f,t_id);
79 VSUB(dir,t0,t2);
80 stTrace_edge(st,t2,dir,1.0,remove_tri,&f,t_id);
81 /* Now visit interior */
82 if(QT_FLAG_FILL_TRI(f) || QT_FLAG_UPDATE(f))
83 stVisit_tri_interior(st,t0,t1,t2,remove_tri_compress,&f,t_id);
84 }
85
86
87 smLocator_remove_tri(sm,t_id)
88 SM *sm;
89 int t_id;
90 {
91 STREE *st;
92 char found;
93 TRI *t;
94 FVECT v0,v1,v2;
95
96 st = SM_LOCATOR(sm);
97
98 t = SM_NTH_TRI(sm,t_id);
99
100 VSUB(v0,SM_T_NTH_WV(sm,t,0),SM_VIEW_CENTER(sm));
101 VSUB(v1,SM_T_NTH_WV(sm,t,1),SM_VIEW_CENTER(sm));
102 VSUB(v2,SM_T_NTH_WV(sm,t,2),SM_VIEW_CENTER(sm));
103 found = stUpdate_tri(st,t_id,v0,v1,v2,remove_tri,remove_tri_compress);
104 return(found);
105 }
106
107 smFree_tri(sm,id)
108 SM *sm;
109 int id;
110 {
111 TRI *tri;
112
113 tri = SM_NTH_TRI(sm,id);
114 /* Add to the free_list */
115 T_NEXT_FREE(tri) = SM_FREE_TRIS(sm);
116 SM_FREE_TRIS(sm) = id;
117 T_VALID_FLAG(tri) = -1;
118 }
119
120 /* Assumes mesh pointers have been cleaned up appropriately: just deletes from
121 Point location and triangle data structure
122 */
123 smDelete_tri(sm,t_id)
124 SM *sm;
125 int t_id;
126 {
127
128
129 /* NOTE: Assumes that a new triangle adjacent to each vertex
130 has been added- before the deletion: replacing
131 the old tri- and therefore dont need to dereference any pointers
132 to id because the vertices can no longer
133 point to tri id as being the first triangle pointer
134 */
135 if(!SM_IS_NTH_T_BASE(sm,t_id))
136 {
137 SM_NUM_TRIS(sm)--;
138 if(SM_IS_NTH_T_NEW(sm,t_id))
139 smNew_tri_cnt--;
140 }
141 smClear_tri_flags(sm,t_id);
142
143 smFree_tri(sm,t_id);
144
145 }
146
147
148
149 LIST
150 *smVertex_star_polygon(sm,id)
151 SM *sm;
152 int id;
153 {
154 TRI *tri,*t_next;
155 LIST *elist,*end,*tlist;
156 int t_id,v_next,t_next_id;
157 int e;
158
159 elist = end = NULL;
160 /* Get the first triangle adjacent to vertex id */
161 t_id = SM_NTH_VERT(sm,id);
162 tri = SM_NTH_TRI(sm,t_id);
163
164
165 if((e = eNew_edge()) == SM_INVALID)
166 {
167 #ifdef DEBUG
168 eputs("smVertex_star_polygon():Too many edges\n");
169 #endif
170 return(NULL);
171 }
172 elist = add_data_to_circular_list(elist,&end,e);
173 v_next = (T_WHICH_V(tri,id)+1)%3;
174 SET_E_NTH_VERT(e,0,T_NTH_V(tri,v_next));
175 SET_E_NTH_TRI(e,0,SM_INVALID);
176 SET_E_NTH_TRI(e,1,T_NTH_NBR(tri,v_next));
177 v_next = (T_WHICH_V(tri,id)+2)%3;
178 SET_E_NTH_VERT(e,1,T_NTH_V(tri,v_next));
179
180
181 t_next_id = t_id;
182 t_next = tri;
183
184 tlist = push_data(NULL,t_id);
185
186 while((t_next_id = smTri_next_ccw_nbr(sm,t_next,id)) != t_id)
187 {
188 if((e = eNew_edge()) == SM_INVALID)
189 {
190 #ifdef DEBUG
191 eputs("smVertex_star_polygon():Too many edges\n");
192 #endif
193 return(NULL);
194 }
195 elist = add_data_to_circular_list(elist,&end,e);
196 t_next = SM_NTH_TRI(sm,t_next_id);
197 v_next = (T_WHICH_V(t_next,id)+1)%3;
198 SET_E_NTH_VERT(e,0,T_NTH_V(t_next,v_next));
199 SET_E_NTH_TRI(e,0,SM_INVALID);
200 SET_E_NTH_TRI(e,1,T_NTH_NBR(t_next,v_next));
201 v_next = (T_WHICH_V(t_next,id)+2)%3;
202 SET_E_NTH_VERT(e,1,T_NTH_V(t_next,v_next));
203 tlist = push_data(tlist,t_next_id);
204 }
205 while(tlist)
206 {
207 t_id = (int)pop_list(&tlist);
208 /* first remove from point location structure */
209 smLocator_remove_tri(sm,t_id);
210 smDelete_tri(sm,t_id);
211 }
212 return(elist);
213 }
214
215 int
216 smEdge_intersect_polygon(sm,v0,v1,l)
217 SM *sm;
218 FVECT v0,v1;
219 LIST *l;
220 {
221 FVECT e0,e1;
222 int e,id_e0,id_e1;
223 LIST *el,*eptr;
224
225 /* Test the edges in l against v0v1 to see if v0v1 intersects
226 any other edges
227 */
228
229 el = l;
230
231 while(el)
232 {
233 e = (int)LIST_DATA(el);
234 id_e0 = E_NTH_VERT(e,0);
235 id_e1 = E_NTH_VERT(e,1);
236 /* NOTE: DO these need to be normalized? Just subtract center? */
237 /*
238 smDir(sm,e0,id_e0);
239 smDir(sm,e1,id_e1);
240 */
241 VSUB(e0,SM_NTH_WV(sm,id_e0),SM_VIEW_CENTER(sm));
242 VSUB(e1,SM_NTH_WV(sm,id_e1),SM_VIEW_CENTER(sm));
243 if(sedge_intersect(v0,v1,e0,e1))
244 return(TRUE);
245
246 el = LIST_NEXT(el);
247 if(el == l)
248 break;
249 }
250 return(FALSE);
251 }
252
253 int
254 smFind_next_convex_vertex(sm,id0,id1,v0,v1,l)
255 SM *sm;
256 int id0,id1;
257 FVECT v0,v1;
258 LIST *l;
259 {
260 int e,id;
261 LIST *el;
262 FVECT v;
263
264 /* starting with the end of edge at head of l, search sequentially for
265 vertex v such that v0v1v is a convex angle, and the edge v1v does
266 not intersect any other edges
267 */
268 id = SM_INVALID;
269 el = l;
270 while(id != id0)
271 {
272 e = (int)LIST_DATA(el);
273 id = E_NTH_VERT(e,1);
274
275 smDir(sm,v,id);
276
277 if(convex_angle(v0,v1,v) && !smEdge_intersect_polygon(sm,v1,v,l))
278 return(id);
279
280 el = LIST_NEXT(el);
281 if(el == l)
282 break;
283 }
284 return(SM_INVALID);
285 }
286
287 int
288 split_edge_list(id0,id_new,l,lnew)
289 int id0,id_new;
290 LIST **l,**lnew;
291 {
292 LIST *list,*lptr,*end;
293 int e,e1,e2,new_e;
294
295 e2 = SM_INVALID;
296 list = lptr = *l;
297
298 if((new_e = eNew_edge())==SM_INVALID)
299 {
300 #ifdef DEBUG
301 eputs("split_edge_list():Too many edges\n");
302 #endif
303 return(FALSE);
304 }
305 SET_E_NTH_VERT(new_e,0,id0);
306 SET_E_NTH_VERT(new_e,1,id_new);
307 SET_E_NTH_TRI(new_e,0,SM_INVALID);
308 SET_E_NTH_TRI(new_e,1,SM_INVALID);
309
310 while(e2 != id_new)
311 {
312 lptr = LIST_NEXT(lptr);
313 e = (int)LIST_DATA(lptr);
314 e2 = E_NTH_VERT(e,1);
315 if(lptr == list)
316 {
317 #ifdef DEBUG
318 eputs("split_edge_list():cant find vertex\n");
319 #endif
320 *lnew = NULL;
321 return(FALSE);
322 }
323
324 }
325 end = lptr;
326 lptr = LIST_NEXT(lptr);
327 list = add_data_to_circular_list(list,&end,-new_e);
328 *lnew = list;
329
330 /* now follow other cycle */
331
332 list = lptr;
333 e2 = SM_INVALID;
334 while(e2 != id0)
335 {
336 lptr = LIST_NEXT(lptr);
337 e = (int)LIST_DATA(lptr);
338 e2 = E_NTH_VERT(e,1);
339 if(lptr == list)
340 {
341 #ifdef DEBUG
342 eputs("split_edge_list():cant find intial vertex\n");
343 #endif
344 *l = NULL;
345 return(FALSE);
346 }
347
348 }
349 end = lptr;
350 list = add_data_to_circular_list(list,&end,new_e);
351 *l = list;
352 return(TRUE);
353 }
354
355
356 int
357 smTriangulate_convex(sm,plist)
358 SM *sm;
359 LIST *plist;
360 {
361 TRI *tri;
362 int t_id,e_id0,e_id1,e_id2;
363 int v_id0,v_id1,v_id2;
364 LIST *lptr;
365 int cnt;
366
367 lptr = plist;
368 e_id0 = (int)LIST_DATA(lptr);
369 v_id0 = E_NTH_VERT(e_id0,0);
370 lptr = LIST_NEXT(lptr);
371 while(LIST_NEXT(lptr) != plist)
372 {
373 e_id1 = (int)LIST_DATA(lptr);
374 v_id1 = E_NTH_VERT(e_id1,0);
375 v_id2 = E_NTH_VERT(e_id1,1);
376 /* form a triangle for each triple of with v0 as base of star */
377 t_id = smAdd_tri(sm,v_id0,v_id1,v_id2,&tri);
378 smLocator_add_tri(sm,t_id,v_id0,v_id1,v_id2);
379 /* add which pointer?*/
380
381 lptr = LIST_NEXT(lptr);
382
383 if(LIST_NEXT(lptr) != plist)
384 {
385 e_id2 = eNew_edge();
386 SET_E_NTH_VERT(e_id2,0,v_id2);
387 SET_E_NTH_VERT(e_id2,1,v_id0);
388 }
389 else
390 e_id2 = (int)LIST_DATA(lptr);
391
392 /* set appropriate tri for each edge*/
393 SET_E_NTH_TRI(e_id0,0,t_id);
394 SET_E_NTH_TRI(e_id1,0,t_id);
395 SET_E_NTH_TRI(e_id2,0,t_id);
396
397 e_id0 = -e_id2;
398 }
399
400 free_list(plist);
401 return(TRUE);
402 }
403 int
404 smTriangulate_elist(sm,plist)
405 SM *sm;
406 LIST *plist;
407 {
408 LIST *l,*el1;
409 FVECT v0,v1,v2;
410 int id0,id1,id2,e,id_next;
411 char flipped;
412 int done;
413
414 l = plist;
415
416 while(l)
417 {
418 /* get v0,v1,v2 */
419 e = (int)LIST_DATA(l);
420 id0 = E_NTH_VERT(e,0);
421 id1 = E_NTH_VERT(e,1);
422 l = LIST_NEXT(l);
423 e = (int)LIST_DATA(l);
424 id2 = E_NTH_VERT(e,1);
425
426 smDir(sm,v0,id0);
427 smDir(sm,v1,id1);
428 smDir(sm,v2,id2);
429 /* determine if convex (left turn), or concave(right turn) angle */
430 if(convex_angle(v0,v1,v2))
431 {
432 if(l == plist)
433 break;
434 else
435 continue;
436 }
437 /* if concave: add edge and recurse on two sub polygons */
438 id_next = smFind_next_convex_vertex(sm,id0,id1,v0,v1,LIST_NEXT(l));
439 if(id_next == SM_INVALID)
440 {
441 #ifdef DEBUG
442 eputs("smTriangulate_elist():Unable to find convex vertex\n");
443 #endif
444 return(FALSE);
445 }
446 /* add edge */
447 el1 = NULL;
448 /* Split edge list l into two lists: one from id1-id_next-id1,
449 and the next from id2-id_next-id2
450 */
451 split_edge_list(id1,id_next,&l,&el1);
452 /* Recurse and triangulate the two edge lists */
453 done = smTriangulate_elist(sm,l);
454 if(done)
455 done = smTriangulate_elist(sm,el1);
456 return(done);
457 }
458 done = smTriangulate_convex(sm,plist);
459 return(done);
460 }
461
462 int
463 smTriangulate(sm,plist)
464 SM *sm;
465 LIST *plist;
466 {
467 int e,id_t0,id_t1,e0,e1;
468 TRI *t0,*t1;
469 int test;
470
471 test = smTriangulate_elist(sm,plist);
472
473 if(!test)
474 return(test);
475 FOR_ALL_EDGES(e)
476 {
477 id_t0 = E_NTH_TRI(e,0);
478 id_t1 = E_NTH_TRI(e,1);
479 if((id_t0==SM_INVALID) || (id_t1==SM_INVALID))
480 {
481 #ifdef DEBUG
482 eputs("smTriangulate(): Unassigned edge neighbor\n");
483 #endif
484 continue;
485 }
486 t0 = SM_NTH_TRI(sm,id_t0);
487 t1 = SM_NTH_TRI(sm,id_t1);
488
489 e0 = T_WHICH_V(t0,E_NTH_VERT(e,0));
490 T_NTH_NBR(t0,e0) = id_t1;
491
492 e1 = T_WHICH_V(t1,E_NTH_VERT(e,1));
493 T_NTH_NBR(t1,e1) = id_t0;
494 }
495 return(test);
496 }
497
498 eIn_tri(e,t)
499 int e;
500 TRI *t;
501 {
502
503 if(T_NTH_V(t,0)==E_NTH_VERT(e,0))
504 return(T_NTH_V(t,1)==E_NTH_VERT(e,1)||T_NTH_V(t,2)==E_NTH_VERT(e,1));
505 else
506 if(T_NTH_V(t,1)==E_NTH_VERT(e,0))
507 return(T_NTH_V(t,0)==E_NTH_VERT(e,1)||T_NTH_V(t,2)==E_NTH_VERT(e,1));
508 else if(T_NTH_V(t,2)==E_NTH_VERT(e,0))
509 return(T_NTH_V(t,0)==E_NTH_VERT(e,1)||T_NTH_V(t,1)==E_NTH_VERT(e,1));
510 return(FALSE);
511 }
512 smFix_edges(sm)
513 SM *sm;
514 {
515 int e,id_t0,id_t1,e_new,e0,e1,e0_next,e1_next;
516 TRI *t0,*t1,*nt0,*nt1;
517 int i,id_v0,id_v1,id_v2,id_p,nid_t0,nid_t1;
518 FVECT v0,v1,v2,p,np,v;
519 LIST *add,*del;
520
521 add = del = NULL;
522 FOR_ALL_EDGES(e)
523 {
524 id_t0 = E_NTH_TRI(e,0);
525 id_t1 = E_NTH_TRI(e,1);
526 if((id_t0==SM_INVALID) || (id_t1==SM_INVALID))
527 {
528 #ifdef DEBUG
529 eputs("smFix_edges: Unassigned edge nbr\n");
530 #endif
531 continue;
532 }
533 t0 = SM_NTH_TRI(sm,id_t0);
534 t1 = SM_NTH_TRI(sm,id_t1);
535
536 e0 = T_WHICH_V(t0,E_NTH_VERT(e,0));
537 e1 = T_WHICH_V(t1,E_NTH_VERT(-e,0));
538 e0_next = (e0+2)%3;
539 e1_next = (e1+2)%3;
540 id_v0 = E_NTH_VERT(e,0);
541 id_v1 = E_NTH_VERT(e,1);
542 id_v2 = T_NTH_V(t0,e0_next);
543 id_p = T_NTH_V(t1,e1_next);
544
545 smDir(sm,v0,id_v0);
546 smDir(sm,v1,id_v1);
547 smDir(sm,v2,id_v2);
548
549 VCOPY(p,SM_NTH_WV(sm,id_p));
550 VSUB(p,p,SM_VIEW_CENTER(sm));
551 if(point_in_cone(p,v0,v1,v2))
552 {
553 smTris_swap_edge(sm,id_t0,id_t1,e0,e1,&nid_t0,&nid_t1,&add,&del);
554
555 nt0 = SM_NTH_TRI(sm,nid_t0);
556 nt1 = SM_NTH_TRI(sm,nid_t1);
557 FOR_ALL_EDGES_FROM(e,i)
558 {
559 if(E_NTH_TRI(i,0)==id_t0 || E_NTH_TRI(i,0)==id_t1)
560 {
561 if(eIn_tri(i,nt0))
562 SET_E_NTH_TRI(i,0,nid_t0);
563 else
564 SET_E_NTH_TRI(i,0,nid_t1);
565 }
566
567 if(E_NTH_TRI(i,1)==id_t0 || E_NTH_TRI(i,1)==id_t1)
568 {
569 if(eIn_tri(i,nt0))
570 SET_E_NTH_TRI(i,1,nid_t0);
571 else
572 SET_E_NTH_TRI(i,1,nid_t1);
573 }
574 }
575 id_t0 = nid_t0;
576 id_t1 = nid_t1;
577 e_new = eNew_edge();
578 SET_E_NTH_VERT(e_new,0,id_p);
579 SET_E_NTH_VERT(e_new,1,id_v2);
580 SET_E_NTH_TRI(e_new,0,id_t0);
581 SET_E_NTH_TRI(e_new,1,id_t1);
582 }
583 }
584 smUpdate_locator(sm,add,del);
585 }
586
587 int
588 smMesh_remove_vertex(sm,id)
589 SM *sm;
590 int id;
591 {
592 int tri;
593 LIST *elist;
594 int cnt,debug;
595 /* generate list of vertices that form the boundary of the
596 star polygon formed by vertex id and all of its adjacent
597 triangles
598 */
599 eClear_edges();
600 elist = smVertex_star_polygon(sm,id);
601 if(!elist)
602 return(FALSE);
603
604 /* Triangulate spherical polygon */
605 smTriangulate(sm,elist);
606
607
608 /* Fix up new triangles to be Delaunay */
609 smFix_edges(sm);
610
611 return(TRUE);
612 }
613
614 /* Remove point from samples, and from mesh. Delete any triangles
615 adjacent to the point and re-triangulate the hole
616 Return TRUE is point found , FALSE otherwise
617 */
618 int
619 smDelete_point(sm,id)
620 SM *sm;
621 int id;
622 {
623
624 /* Remove the corresponding vertex from the mesh */
625 smMesh_remove_vertex(sm,id);
626 /* Free the sample point */
627 smDelete_sample(sm,id);
628 return(TRUE);
629 }
630
631
632
633
634
635
636
637
638
639
640
641
642
643
