root/radiance/ray/src/hd/sm_del.c
Revision: 3.12
Committed: Thu Jun 10 15:22:22 1999 UTC (25 years ago) by gwlarson
Changes since 3.11: +460 -184 lines
Implemented sample quadtree in place of triangle quadtree
Made geometric predicates more robust
Added #define LORES which utilizes a single precision floating point
  sample array, the default is a double sample array
Added topology DEBUG commands (for DEBUG > 1)
Made code optimizations
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * sm_del.c
9 */
10 #include "standard.h"
11 #include "sm_flag.h"
12 #include "sm_list.h"
13 #include "sm_geom.h"
14 #include "sm.h"
15
16 #define MAX_EDGE_INIT 100
17 static int Max_edges= MAX_EDGE_INIT;
18 static EDGE *Edges=NULL;
19 static int Ecnt=0;
20
21 smFree_tri(sm,id,t)
22 SM *sm;
23 int id;
24 TRI *t;
25 {
26 /* Add to the free_list */
27 T_NEXT_FREE(t) = SM_FREE_TRIS(sm);
28 SM_FREE_TRIS(sm) = id;
29 #ifdef DEBUG
30 T_VALID_FLAG(t) = INVALID;
31 #endif
32 }
33
34 /* Assumes mesh pointers have been cleaned up appropriately: just deletes from
35 Point location and triangle data structure
36 */
37 smDelete_tri(sm,t_id,t)
38 SM *sm;
39 int t_id;
40 TRI *t;
41 {
42
43 /* NOTE: Assumes that a new triangle adjacent to each vertex
44 has been added- before the deletion: replacing
45 the old tri- and therefore dont need to dereference any pointers
46 to id because the vertices can no longer
47 point to tri id as being the first triangle pointer
48 */
49 SM_CLR_NTH_T_ACTIVE(sm,t_id);
50 smFree_tri(sm,t_id,t);
51
52 }
53
54 int
55 eNew_edge()
56 {
57 if(!Edges)
58 if(!(Edges = (EDGE *)realloc(NULL,(Max_edges+1)*sizeof(EDGE))))
59 goto memerr;
60
61 if(Ecnt >= Max_edges)
62 {
63 #ifdef DEBUG
64 if(Max_edges > 10000)
65 error(CONSISTENCY,"Too many edges in vertex loop\n");
66 #endif
67 Max_edges += 100;
68 if(!(Edges = (EDGE *)realloc(Edges,(Max_edges+1)*sizeof(EDGE))))
69 goto memerr;
70 }
71 #ifdef DEBUG
72 SET_E_NTH_TRI(Ecnt+1,0,INVALID);
73 SET_E_NTH_TRI(Ecnt+1,1,INVALID);
74 #endif
75 return(++Ecnt);
76
77 memerr:
78 error(SYSTEM,"eNew_edge): Unable to allocate memory");
79 }
80
81 /* Return list of edges defining polygon formed by boundary of triangles
82 adjacent to id. Return set of triangles adjacent to id to delete in delptr
83 */
84 LIST
85 *smVertexStar(sm,id)
86 SM *sm;
87 int id;
88 {
89 TRI *tri,*t_next;
90 LIST *elist,*end;
91 int e,t_id,v_next,t_next_id,b_id,v_id,t_last_id;
92
93 elist = end = NULL;
94
95 /* Get the first triangle adjacent to vertex id */
96 t_id = SM_NTH_VERT(sm,id);
97 tri = SM_NTH_TRI(sm,t_id);
98
99 e = eNew_edge();
100 /* Get the next vertex on the polygon boundary */
101 v_id = T_WHICH_V(tri,id);
102 b_id = (v_id + 1)%3;
103 /* Create an edge */
104 SET_E_NTH_VERT(e,0,T_NTH_V(tri,b_id));
105 SET_E_NTH_TRI(e,0,INVALID);
106 SET_E_NTH_TRI(e,1,T_NTH_NBR(tri,v_id));
107 v_next = T_NTH_V(tri,(b_id+1)%3);
108 SET_E_NTH_VERT(e,1,v_next);
109
110 elist = add_data_to_circular_list(elist,&end,e);
111 t_next_id = t_id;
112 t_next = tri;
113 t_last_id = -1;
114
115 /* Create a set to hold all of the triangles for deletion later */
116
117 while((t_next_id = T_NTH_NBR(t_next,b_id)) != t_id)
118 {
119 e = eNew_edge();
120 if(t_last_id != -1)
121 {
122 smDelete_tri(sm,t_last_id,t_next);
123 }
124 t_next = SM_NTH_TRI(sm,t_next_id);
125 t_last_id = t_next_id;
126 SET_E_NTH_VERT(e,0,v_next);
127 SET_E_NTH_TRI(e,0,INVALID);
128 v_id = T_WHICH_V(t_next,id);
129 b_id = (v_id + 1)%3;
130 SET_E_NTH_TRI(e,1,T_NTH_NBR(t_next,v_id));
131 v_next = T_NTH_V(t_next,(b_id+1)%3);
132 SET_E_NTH_VERT(e,1,v_next);
133 elist = add_data_to_circular_list(elist,&end,e);
134
135 }
136 smDelete_tri(sm,t_last_id,t_next);
137 smDelete_tri(sm,t_id,tri);
138 return(elist);
139 }
140
141 int
142 smTriangulate_add_tri(sm,id0,id1,id2,e0,e1,e2ptr)
143 SM *sm;
144 int id0,id1,id2,e0,e1,*e2ptr;
145 {
146 int t_id,e2;
147 TRI *t;
148
149 t_id = smAdd_tri(sm,id0,id1,id2,&t);
150 if(*e2ptr == 0)
151 {
152 e2 = eNew_edge();
153 SET_E_NTH_VERT(e2,0,id2);
154 SET_E_NTH_VERT(e2,1,id0);
155 }
156 else
157 e2 = *e2ptr;
158 /* set appropriate tri for each edge*/
159 SET_E_NTH_TRI(e0,0,t_id);
160 SET_E_NTH_TRI(e1,0,t_id);
161 SET_E_NTH_TRI(e2,0,t_id);
162 #ifdef DEBUG
163 #if DEBUG > 1
164 if(E_NTH_TRI(e0,1) == E_NTH_TRI(e0,0) ||
165 E_NTH_TRI(e1,1) == E_NTH_TRI(e1,0) ||
166 E_NTH_TRI(e2,1) == E_NTH_TRI(e2,0))
167 error(CONSISTENCY,"Non manifold\n");
168 #endif
169 #endif
170 *e2ptr = e2;
171 return(t_id);
172
173 }
174
175 int
176 smTriangulate_quad(sm,l)
177 SM *sm;
178 LIST *l;
179 {
180 int e1,e2,e3,e4,e,t_id,id0,id1,id2,id3;
181 FVECT v0,v1,v2,v3,n;
182 double dp;
183 TRI *tri;
184 LIST *lptr;
185
186 #ifdef DEBUG
187 if(LIST_NEXT(LIST_NEXT(LIST_NEXT(LIST_NEXT(l)))) != l)
188 {
189 eputs("smTriangulate_quad(): not a quadrilateral\n");
190 return(FALSE);
191 }
192 eputs("smTriangulate_quad():\n");
193 #endif
194 lptr=l;
195 e1 = (int)LIST_DATA(l);
196 id0 = E_NTH_VERT(e1,0);
197 id1 = E_NTH_VERT(e1,1);
198 VSUB(v0,SM_NTH_WV(sm,id0),SM_VIEW_CENTER(sm));
199 VSUB(v1,SM_NTH_WV(sm,id1),SM_VIEW_CENTER(sm));
200 /* Get v2 */
201 l = LIST_NEXT(l);
202 e2 = (int)LIST_DATA(l);
203 id2 = E_NTH_VERT(e2,1);
204 VSUB(v2,SM_NTH_WV(sm,id2),SM_VIEW_CENTER(sm));
205 /* Get v3 */
206 l = LIST_NEXT(l);
207 e3 = (int)LIST_DATA(l);
208 id3 = E_NTH_VERT(e3,1);
209 VSUB(v3,SM_NTH_WV(sm,id3),SM_VIEW_CENTER(sm));
210 l = LIST_NEXT(l);
211 e4 = (int)LIST_DATA(l);
212 free_list(lptr);
213
214 VCROSS(n,v0,v2);
215 normalize(n);
216 normalize(v1);
217 dp = DOT(n,v1);
218 e = 0;
219 if(dp > 0)
220 {
221 if(dp >= EV_EPS)
222 {
223 normalize(v3);
224 if(DOT(n,v3) < 0)
225 {
226 t_id = smTriangulate_add_tri(sm,id0,id1,id2,e1,e2,&e);
227 e *= -1;
228 t_id = smTriangulate_add_tri(sm,id2,id3,id0,e3,e4,&e);
229 return(TRUE);
230 }
231 }
232
233 }
234 #ifdef DEBUG
235 #if DEBUG > 1
236 VCROSS(n,v1,v3);
237 normalize(n);
238 normalize(v0);
239 normalize(v2);
240 dp = DOT(n,v2);
241 if((dp < 0) || (dp < EV_EPS) || (DOT(n,v0) >= 0.0))
242 error(CONSISTENCY,"smTriangulate_quad: cannot triangulate\n");
243 #endif
244 #endif
245 t_id = smTriangulate_add_tri(sm,id1,id2,id3,e2,e3,&e);
246 e *= -1;
247 t_id = smTriangulate_add_tri(sm,id3,id0,id1,e4,e1,&e);
248 return(TRUE);
249 }
250
251 /* Triangulate the polygon defined by plist, and generating vertex p_id.
252 Return list of added triangles in list add_ptr. Returns TRUE if
253 successful, FALSE otherwise. This is NOT a general triangulation routine,
254 assumes polygon star relative to id
255 */
256
257 int
258 smTriangulate(sm,id,plist)
259 SM *sm;
260 int id;
261 LIST *plist;
262 {
263 LIST *l,*prev,*t;
264 FVECT v0,v1,v2,n,p;
265 int is_tri,cut,t_id,id0,id1,id2,e2,e1,enew;
266 double dp1,dp2;
267
268 VSUB(p,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm));
269 normalize(p);
270 l = plist;
271
272 enew = 0;
273 cut = is_tri= FALSE;
274 prev = l;
275 /* get v0,v1 */
276 e1 = (int)LIST_DATA(l);
277 id0 = E_NTH_VERT(e1,0);
278 id1 = E_NTH_VERT(e1,1);
279 VSUB(v0,SM_NTH_WV(sm,id0),SM_VIEW_CENTER(sm));
280 normalize(v0);
281 VSUB(v1,SM_NTH_WV(sm,id1),SM_VIEW_CENTER(sm));
282 normalize(v1);
283 while(l)
284 {
285 l = LIST_NEXT(l);
286 /* Get v2 */
287 e2 = (int)LIST_DATA(l);
288 id2 = E_NTH_VERT(e2,1);
289 VSUB(v2,SM_NTH_WV(sm,id2),SM_VIEW_CENTER(sm));
290 normalize(v2);
291 if(LIST_NEXT(LIST_NEXT(l)) == prev)
292 {/* Check if have a triangle */
293 is_tri = TRUE;
294 break;
295 }
296 /* determine if v0-v1-v2 is convex:defined clockwise on the sphere-
297 so switch orientation
298 */
299 VCROSS(n,v0,v2);
300 normalize(n);
301 dp1 = DOT(n,p);
302 if(dp1 <= 0.0)
303 {
304 /* test if safe to cut off v0-v1-v2 by testing if p lies outside of
305 triangle v0-v1-v2: if so, because plist is the star polygon around p,
306 the new edge v2-v0 cannot intersect any existing edges
307 */
308 dp1 = DOT(n,v1);
309 /* Distance from point s to plane is d = |N.p0s|/||N|| */
310 /* sp1 = s-p0 for point on plane p0, a.(b+c) = a.b + a.c */
311 if(dp1 >= EV_EPS)
312 {
313 /* remove edges e1,e2 and add triangle id0,id1,id2 */
314 enew = 0;
315 t_id = smTriangulate_add_tri(sm,id0,id1,id2,e1,e2,&enew);
316 cut = TRUE;
317 /* Insert edge enew into the list, reuse prev list element */
318 LIST_NEXT(prev) = LIST_NEXT(l);
319 LIST_DATA(prev) = e1 = -enew;
320 /* If removing head of list- reset plist pointer */
321 if(l== plist)
322 plist = prev;
323 /* free list element for e2 */
324 LIST_NEXT(l)=NULL;
325 free_list(l);
326 l = prev;
327 VCOPY(v1,v2);
328 id1 = id2;
329 continue;
330 }
331 }
332 VCOPY(v0,v1);
333 VCOPY(v1,v2);
334 id0 = id1;
335 id1 = id2;
336 e1 = e2;
337 /* check if gone around circular list without adding any
338 triangles: prevent infinite loop */
339 if(l == plist)
340 {
341 if(LIST_NEXT(LIST_NEXT(l)) == prev)
342 {/* Check if have a triangle */
343 is_tri = TRUE;
344 break;
345 }
346 if(!cut)
347 break;
348 cut = FALSE;
349 }
350 prev = l;
351 }
352 if(is_tri)
353 {
354 l = LIST_NEXT(l);
355 enew = (int)LIST_DATA(l);
356 t_id = smTriangulate_add_tri(sm,id0,id1,id2,e1,e2,&enew);
357 free_list(l);
358 }
359 else
360 if(!smTriangulate_quad(sm,l))
361 goto Terror;
362 #if 0
363 {int i;
364 eputs("\n\n");
365 for(i=1;i<=Ecnt;i++)
366 fprintf(stderr,"%d verts %d %d tris %d %d\n",
367 i,Edges[i].verts[0],Edges[i].verts[1],
368 Edges[i].tris[0],Edges[i].tris[1]);
369 }
370 #endif
371
372 /* Set triangle adjacencies based on edge adjacencies */
373 FOR_ALL_EDGES(enew)
374 {
375 id0 = E_NTH_TRI(enew,0);
376 id1 = E_NTH_TRI(enew,1);
377
378 e1 = (T_WHICH_V(SM_NTH_TRI(sm,id0),E_NTH_VERT(enew,0))+2)%3;
379 T_NTH_NBR(SM_NTH_TRI(sm,id0),e1) = id1;
380
381 e2 = (T_WHICH_V(SM_NTH_TRI(sm,id1),E_NTH_VERT(enew,1))+2)%3;
382 T_NTH_NBR(SM_NTH_TRI(sm,id1),e2) = id0;
383 }
384 #if 0
385 {int i;
386 eputs("\n\n");
387 for(i=1;i<=Ecnt;i++)
388 fprintf(stderr,"%d verts %d %d tris %d %d\n",
389 i,Edges[i].verts[0],Edges[i].verts[1],
390 Edges[i].tris[0],Edges[i].tris[1]);
391 }
392 #endif
393
394 #ifdef DEBUG
395 #if DEBUG > 1
396 {
397 TRI *t0,*t1,*n;
398
399 FOR_ALL_EDGES(enew)
400 {
401 id0 = E_NTH_TRI(enew,0);
402 id1 = E_NTH_TRI(enew,1);
403 t0 = SM_NTH_TRI(sm,id0);
404 t1 = SM_NTH_TRI(sm,id1);
405 if(T_NTH_NBR(t0,0) == T_NTH_NBR(t0,1) ||
406 T_NTH_NBR(t0,1) == T_NTH_NBR(t0,2) ||
407 T_NTH_NBR(t0,0) == T_NTH_NBR(t0,2))
408 error(CONSISTENCY,"Invalid topology\n");
409 if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,0))) ||
410 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,1))) ||
411 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,2))))
412 error(CONSISTENCY,"Invalid topology\n");
413 n = SM_NTH_TRI(sm,T_NTH_NBR(t0,0));
414 if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
415 T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
416 T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
417 error(CONSISTENCY,"Invalid topology\n");
418 if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
419 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
420 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
421 error(CONSISTENCY,"Invalid topology\n");
422 n = SM_NTH_TRI(sm,T_NTH_NBR(t0,1));
423 if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
424 T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
425 T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
426 error(CONSISTENCY,"Invalid topology\n");
427 if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
428 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
429 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
430 error(CONSISTENCY,"Invalid topology\n");
431 n = SM_NTH_TRI(sm,T_NTH_NBR(t0,2));
432 if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
433 T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
434 T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
435 error(CONSISTENCY,"Invalid topology\n");
436 if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
437 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
438 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
439 error(CONSISTENCY,"Invalid topology\n");
440
441 if(T_NTH_NBR(t1,0) == T_NTH_NBR(t1,1) ||
442 T_NTH_NBR(t1,1) == T_NTH_NBR(t1,2) ||
443 T_NTH_NBR(t1,0) == T_NTH_NBR(t1,2))
444 error(CONSISTENCY,"Invalid topology\n");
445 if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,0))) ||
446 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,1))) ||
447 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,2))))
448 error(CONSISTENCY,"Invalid topology\n");
449 n = SM_NTH_TRI(sm,T_NTH_NBR(t1,0));
450 if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
451 T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
452 T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
453 error(CONSISTENCY,"Invalid topology\n");
454 if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
455 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
456 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
457 error(CONSISTENCY,"Invalid topology\n");
458 n = SM_NTH_TRI(sm,T_NTH_NBR(t1,1));
459 if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
460 T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
461 T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
462 error(CONSISTENCY,"Invalid topology\n");
463 if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
464 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
465 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
466 error(CONSISTENCY,"Invalid topology\n");
467 n = SM_NTH_TRI(sm,T_NTH_NBR(t1,2));
468 if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
469 T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
470 T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
471 error(CONSISTENCY,"Invalid topology\n");
472 if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
473 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
474 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
475 error(CONSISTENCY,"Invalid topology\n");
476 }
477 }
478 #endif
479 #endif
480 return(TRUE);
481
482 Terror:
483 #ifdef DEBUG
484 error(CONSISTENCY,"smTriangulate():Unable to triangulate\n");
485 #endif
486 }
487
488 eIn_tri(e,t)
489 int e;
490 TRI *t;
491 {
492
493 if(T_NTH_V(t,0)==E_NTH_VERT(e,0))
494 return(T_NTH_V(t,1)==E_NTH_VERT(e,1)||T_NTH_V(t,2)==E_NTH_VERT(e,1));
495 else
496 if(T_NTH_V(t,1)==E_NTH_VERT(e,0))
497 return(T_NTH_V(t,0)==E_NTH_VERT(e,1)||T_NTH_V(t,2)==E_NTH_VERT(e,1));
498 else if(T_NTH_V(t,2)==E_NTH_VERT(e,0))
499 return(T_NTH_V(t,0)==E_NTH_VERT(e,1)||T_NTH_V(t,1)==E_NTH_VERT(e,1));
500
501 return(FALSE);
502 }
503
504
505 void
506 smTris_swap_edge(sm,t_id,t1_id,e,e1,tn_id,tn1_id)
507 SM *sm;
508 int t_id,t1_id;
509 int e,e1;
510 int *tn_id,*tn1_id;
511 {
512 int verts[3],enext,eprev,e1next,e1prev;
513 TRI *n,*ta,*tb,*t,*t1;
514 FVECT p1,p2,p3;
515 int ta_id,tb_id;
516 /* form new diagonal (e relative to t, and e1 relative to t1)
517 defined by quadrilateral formed by t,t1- swap for the opposite diagonal
518 */
519 t = SM_NTH_TRI(sm,t_id);
520 t1 = SM_NTH_TRI(sm,t1_id);
521 enext = (e+1)%3;
522 eprev = (e+2)%3;
523 e1next = (e1+1)%3;
524 e1prev = (e1+2)%3;
525 verts[e] = T_NTH_V(t,e);
526 verts[enext] = T_NTH_V(t,enext);
527 verts[eprev] = T_NTH_V(t1,e1);
528 ta_id = smAdd_tri(sm,verts[0],verts[1],verts[2],&ta);
529 #if 0
530 fprintf(stderr,"Added tri %d %d %d %d\n",ta_id,T_NTH_V(ta,0),
531 T_NTH_V(ta,1), T_NTH_V(ta,2));
532 #endif
533 verts[e1] = T_NTH_V(t1,e1);
534 verts[e1next] = T_NTH_V(t1,e1next);
535 verts[e1prev] = T_NTH_V(t,e);
536 tb_id = smAdd_tri(sm,verts[0],verts[1],verts[2],&tb);
537 #if 0
538 fprintf(stderr,"Added tri %d %d %d %d\n",tb_id,T_NTH_V(tb,0),
539 T_NTH_V(tb,1), T_NTH_V(tb,2));
540 #endif
541 /* set the neighbors */
542 T_NTH_NBR(ta,e) = T_NTH_NBR(t1,e1next);
543 T_NTH_NBR(tb,e1) = T_NTH_NBR(t,enext);
544 T_NTH_NBR(ta,enext)= tb_id;
545 T_NTH_NBR(tb,e1next)= ta_id;
546 T_NTH_NBR(ta,eprev)=T_NTH_NBR(t,eprev);
547 T_NTH_NBR(tb,e1prev)=T_NTH_NBR(t1,e1prev);
548
549 /* Reset neighbor pointers of original neighbors */
550 n = SM_NTH_TRI(sm,T_NTH_NBR(t,enext));
551 T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = tb_id;
552 n = SM_NTH_TRI(sm,T_NTH_NBR(t,eprev));
553 T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = ta_id;
554 n = SM_NTH_TRI(sm,T_NTH_NBR(t1,e1next));
555 T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = ta_id;
556 n = SM_NTH_TRI(sm,T_NTH_NBR(t1,e1prev));
557 T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = tb_id;
558
559 smDelete_tri(sm,t_id,t);
560 smDelete_tri(sm,t1_id,t1);
561
562 #ifdef DEBUG
563 #if DEBUG > 1
564 if(T_NTH_NBR(ta,0) == T_NTH_NBR(ta,1) ||
565 T_NTH_NBR(ta,1) == T_NTH_NBR(ta,2) ||
566 T_NTH_NBR(ta,0) == T_NTH_NBR(ta,2))
567 error(CONSISTENCY,"Invalid topology\n");
568 if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,0))) ||
569 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,1))) ||
570 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,2))))
571 error(CONSISTENCY,"Invalid topology\n");
572 n = SM_NTH_TRI(sm,T_NTH_NBR(ta,0));
573 if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
574 T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
575 T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
576 error(CONSISTENCY,"Invalid topology\n");
577 if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
578 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
579 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
580 error(CONSISTENCY,"Invalid topology\n");
581 n = SM_NTH_TRI(sm,T_NTH_NBR(ta,1));
582 if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
583 T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
584 T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
585 error(CONSISTENCY,"Invalid topology\n");
586 if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
587 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
588 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
589 error(CONSISTENCY,"Invalid topology\n");
590 n = SM_NTH_TRI(sm,T_NTH_NBR(ta,2));
591 if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
592 T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
593 T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
594 error(CONSISTENCY,"Invalid topology\n");
595 if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
596 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
597 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
598 error(CONSISTENCY,"Invalid topology\n");
599 if(T_NTH_NBR(ta,0) == T_NTH_NBR(ta,1) ||
600 T_NTH_NBR(ta,1) == T_NTH_NBR(ta,2) ||
601 T_NTH_NBR(ta,0) == T_NTH_NBR(ta,2))
602 error(CONSISTENCY,"Invalid topology\n");
603
604 if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,0))) ||
605 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,1))) ||
606 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,2))))
607 error(CONSISTENCY,"Invalid topology\n");
608 n = SM_NTH_TRI(sm,T_NTH_NBR(tb,0));
609 if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
610 T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
611 T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
612 error(CONSISTENCY,"Invalid topology\n");
613 if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
614 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
615 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
616 error(CONSISTENCY,"Invalid topology\n");
617 n = SM_NTH_TRI(sm,T_NTH_NBR(tb,1));
618 if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
619 T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
620 T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
621 error(CONSISTENCY,"Invalid topology\n");
622 if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
623 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
624 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
625 error(CONSISTENCY,"Invalid topology\n");
626 n = SM_NTH_TRI(sm,T_NTH_NBR(tb,2));
627 if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
628 T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
629 T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
630 error(CONSISTENCY,"Invalid topology\n");
631 if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
632 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
633 !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
634 error(CONSISTENCY,"Invalid topology\n");
635 #endif
636 #endif
637 *tn_id = ta_id;
638 *tn1_id = tb_id;
639
640 return;
641 }
642
643 /* Test the new set of triangles for Delaunay condition. 'Edges' contains
644 all of the new edges added. The CCW triangle assoc with each edge is
645 tested against the opposite vertex of the CW triangle. If the vertex
646 lies inside the circle defined by the CCW triangle- the edge is swapped
647 for the opposite diagonal
648 */
649 smFixEdges(sm)
650 SM *sm;
651 {
652 int e,t0_id,t1_id,e_new,e0,e1,e0_next,e1_next;
653 int i,v0_id,v1_id,v2_id,p_id,t0_nid,t1_nid;
654 FVECT v0,v1,v2,p,np,v;
655 TRI *t0,*t1;
656
657 FOR_ALL_EDGES(e)
658 {
659 t0_id = E_NTH_TRI(e,0);
660 t1_id = E_NTH_TRI(e,1);
661 #ifdef DEBUG
662 if((t0_id==INVALID) || (t1_id==INVALID))
663 error(CONSISTENCY,"smFix_edges: Unassigned edge nbr\n");
664 #endif
665 t0 = SM_NTH_TRI(sm,t0_id);
666 t1 = SM_NTH_TRI(sm,t1_id);
667 e0 = T_NTH_NBR_PTR(t1_id,t0);
668 e1 = T_NTH_NBR_PTR(t0_id,t1);
669
670 v0_id = E_NTH_VERT(e,0);
671 v1_id = E_NTH_VERT(e,1);
672 v2_id = T_NTH_V(t0,e0);
673 p_id = T_NTH_V(t1,e1);
674
675 smDir(sm,v0,v0_id);
676 smDir(sm,v1,v1_id);
677 smDir(sm,v2,v2_id);
678
679 VSUB(p,SM_NTH_WV(sm,p_id),SM_VIEW_CENTER(sm));
680 normalize(p);
681 if(pt_in_cone(p,v2,v1,v0))
682 {
683 smTris_swap_edge(sm,t0_id,t1_id,e0,e1,&t0_nid,&t1_nid);
684 /* Adjust the triangle pointers of the remaining edges to be
685 processed
686 */
687 FOR_ALL_EDGES_FROM(e,i)
688 {
689 if(E_NTH_TRI(i,0)==t0_id || E_NTH_TRI(i,0)==t1_id)
690 {
691 if(eIn_tri(i,SM_NTH_TRI(sm,t0_nid)))
692 SET_E_NTH_TRI(i,0,t0_nid);
693 else
694 SET_E_NTH_TRI(i,0,t1_nid);
695 }
696
697 if(E_NTH_TRI(i,1)==t0_id || E_NTH_TRI(i,1)==t1_id)
698 {
699 if(eIn_tri(i,SM_NTH_TRI(sm,t0_nid)))
700 SET_E_NTH_TRI(i,1,t0_nid);
701 else
702 SET_E_NTH_TRI(i,1,t1_nid);
703 }
704 #ifdef DEBUG
705 if(E_NTH_TRI(i,1) == E_NTH_TRI(i,0) )
706 error(CONSISTENCY,"invalid edge\n");
707 #endif
708 }
709 t0_id = t0_nid;
710 t1_id = t1_nid;
711 e_new = eNew_edge();
712 SET_E_NTH_VERT(e_new,0,p_id);
713 SET_E_NTH_VERT(e_new,1,v2_id);
714 SET_E_NTH_TRI(e_new,0,t0_id);
715 SET_E_NTH_TRI(e_new,1,t1_id);
716 #ifdef DEBUG
717 if(E_NTH_TRI(i,1) == E_NTH_TRI(i,0) )
718 error(CONSISTENCY,"invalid edge\n");
719 #endif
720 }
721 }
722 }
723
724
725 smDelete_samp(sm,s_id)
726 SM *sm;
727 int s_id;
728 {
729 QUADTREE qt;
730 OBJECT *os;
731
732 /* Mark as free */
733 smUnalloc_samp(sm,s_id);
734
735 #ifdef DEBUG
736 SM_NTH_VERT(sm,s_id) = INVALID;
737 /* fprintf(stderr,"deleting sample %d\n",s_id); */
738 #endif
739 /* remove from its set */
740 qt = SM_S_NTH_QT(sm,s_id);
741 os = qtqueryset(qt);
742 deletuelem(os, s_id); /* delete obj from unsorted os, no questions */
743 }
744 /* Remove vertex "id" from the mesh- and retriangulate the resulting
745 hole: Returns TRUE if successful, FALSE otherwise.
746 */
747 int
748 smRemoveVertex(sm,id)
749 SM *sm;
750 int id;
751 {
752 LIST *b_list;
753 /* generate list of edges that form the boundary of the
754 polygon formed by the triangles adjacent to vertex 'id'*/
755 b_list = smVertexStar(sm,id);
756 #if 0
757 {int i;
758 eputs("\n\n");
759 for(i=1;i<=Ecnt;i++)
760 fprintf(stderr,"%d verts %d %d tris %d %d\n",
761 i,Edges[i].verts[0],Edges[i].verts[1],
762 Edges[i].tris[0],Edges[i].tris[1]);
763 }
764 #endif
765
766 /* Triangulate polygonal hole */
767 smTriangulate(sm,id,b_list);
768
769 /* Fix up new triangles to be Delaunay*/
770
771 smFixEdges(sm);
772 smDelete_samp(sm,id);
773 eClear_edges();
774 return(TRUE);
775 }
776
777
778
779
780
781
782
783
784
785
786
787
788
789
790
