root/radiance/ray/src/hd/sm_del.c
Revision: 3.15
Committed: Fri Nov 5 03:31:37 2004 UTC (20 years, 6 months ago) by greg
Changes since 3.14: +1 -1 lines
State: FILE REMOVED
# User Rev Content
1 gwlarson 3.1 #ifndef lint
2 greg 3.15 static const char RCSid[] = "$Id: sm_del.c,v 3.14 2003/04/23 00:52:34 greg Exp $";
3 gwlarson 3.1 #endif
4     /*
5     * sm_del.c
6     */
7     #include "standard.h"
8 gwlarson 3.6 #include "sm_flag.h"
9 gwlarson 3.1 #include "sm_list.h"
10     #include "sm_geom.h"
11     #include "sm.h"
12
13 gwlarson 3.12 #define MAX_EDGE_INIT 100
14     static int Max_edges= MAX_EDGE_INIT;
15 gwlarson 3.6 static EDGE *Edges=NULL;
16 gwlarson 3.1 static int Ecnt=0;
17
18 gwlarson 3.12 smFree_tri(sm,id,t)
19 gwlarson 3.1 SM *sm;
20     int id;
21 gwlarson 3.12 TRI *t;
22 gwlarson 3.1 {
23     /* Add to the free_list */
24 gwlarson 3.12 T_NEXT_FREE(t) = SM_FREE_TRIS(sm);
25 gwlarson 3.1 SM_FREE_TRIS(sm) = id;
26 gwlarson 3.12 #ifdef DEBUG
27     T_VALID_FLAG(t) = INVALID;
28     #endif
29 gwlarson 3.1 }
30
31     /* Assumes mesh pointers have been cleaned up appropriately: just deletes from
32     Point location and triangle data structure
33     */
34 gwlarson 3.12 smDelete_tri(sm,t_id,t)
35 gwlarson 3.1 SM *sm;
36     int t_id;
37 gwlarson 3.12 TRI *t;
38 gwlarson 3.1 {
39
40     /* NOTE: Assumes that a new triangle adjacent to each vertex
41     has been added- before the deletion: replacing
42     the old tri- and therefore dont need to dereference any pointers
43     to id because the vertices can no longer
44     point to tri id as being the first triangle pointer
45     */
46 gwlarson 3.12 SM_CLR_NTH_T_ACTIVE(sm,t_id);
47     smFree_tri(sm,t_id,t);
48 gwlarson 3.9
49 gwlarson 3.6 }
50 gwlarson 3.1
51 gwlarson 3.6 int
52     eNew_edge()
53     {
54     if(!Edges)
55     if(!(Edges = (EDGE *)realloc(NULL,(Max_edges+1)*sizeof(EDGE))))
56     goto memerr;
57
58     if(Ecnt >= Max_edges)
59     {
60 gwlarson 3.12 #ifdef DEBUG
61 gwlarson 3.6 if(Max_edges > 10000)
62 gwlarson 3.12 error(CONSISTENCY,"Too many edges in vertex loop\n");
63     #endif
64 gwlarson 3.6 Max_edges += 100;
65 greg 3.14 if(!(Edges = (EDGE *)realloc((void *)Edges,(Max_edges+1)*sizeof(EDGE))))
66 gwlarson 3.6 goto memerr;
67     }
68 gwlarson 3.12 #ifdef DEBUG
69     SET_E_NTH_TRI(Ecnt+1,0,INVALID);
70     SET_E_NTH_TRI(Ecnt+1,1,INVALID);
71     #endif
72 gwlarson 3.6 return(++Ecnt);
73
74     memerr:
75 gwlarson 3.12 error(SYSTEM,"eNew_edge): Unable to allocate memory");
76 gwlarson 3.1 }
77
78 gwlarson 3.7 /* Return list of edges defining polygon formed by boundary of triangles
79     adjacent to id. Return set of triangles adjacent to id to delete in delptr
80     */
81 gwlarson 3.5 LIST
82 gwlarson 3.12 *smVertexStar(sm,id)
83 gwlarson 3.1 SM *sm;
84 greg 3.13 S_ID id;
85 gwlarson 3.1 {
86     TRI *tri,*t_next;
87 gwlarson 3.5 LIST *elist,*end;
88 greg 3.13 int e,t_id,t_next_id,b_id,v_id,t_last_id;
89     S_ID v_next;
90 gwlarson 3.1
91     elist = end = NULL;
92 gwlarson 3.7
93 gwlarson 3.1 /* Get the first triangle adjacent to vertex id */
94     t_id = SM_NTH_VERT(sm,id);
95     tri = SM_NTH_TRI(sm,t_id);
96
97 gwlarson 3.7 e = eNew_edge();
98     /* Get the next vertex on the polygon boundary */
99     v_id = T_WHICH_V(tri,id);
100     b_id = (v_id + 1)%3;
101     /* Create an edge */
102     SET_E_NTH_VERT(e,0,T_NTH_V(tri,b_id));
103 gwlarson 3.6 SET_E_NTH_TRI(e,0,INVALID);
104 gwlarson 3.7 SET_E_NTH_TRI(e,1,T_NTH_NBR(tri,v_id));
105 gwlarson 3.12 v_next = T_NTH_V(tri,(b_id+1)%3);
106 gwlarson 3.7 SET_E_NTH_VERT(e,1,v_next);
107 gwlarson 3.12
108 gwlarson 3.6 elist = add_data_to_circular_list(elist,&end,e);
109 gwlarson 3.1 t_next_id = t_id;
110     t_next = tri;
111 gwlarson 3.12 t_last_id = -1;
112
113 gwlarson 3.7 /* Create a set to hold all of the triangles for deletion later */
114 gwlarson 3.1
115 gwlarson 3.7 while((t_next_id = T_NTH_NBR(t_next,b_id)) != t_id)
116     {
117     e = eNew_edge();
118 gwlarson 3.12 if(t_last_id != -1)
119     {
120     smDelete_tri(sm,t_last_id,t_next);
121     }
122 gwlarson 3.6 t_next = SM_NTH_TRI(sm,t_next_id);
123 gwlarson 3.12 t_last_id = t_next_id;
124 gwlarson 3.7 SET_E_NTH_VERT(e,0,v_next);
125 gwlarson 3.6 SET_E_NTH_TRI(e,0,INVALID);
126 gwlarson 3.7 v_id = T_WHICH_V(t_next,id);
127     b_id = (v_id + 1)%3;
128     SET_E_NTH_TRI(e,1,T_NTH_NBR(t_next,v_id));
129     v_next = T_NTH_V(t_next,(b_id+1)%3);
130     SET_E_NTH_VERT(e,1,v_next);
131 gwlarson 3.6 elist = add_data_to_circular_list(elist,&end,e);
132 gwlarson 3.12
133 gwlarson 3.1 }
134 gwlarson 3.12 smDelete_tri(sm,t_last_id,t_next);
135     smDelete_tri(sm,t_id,tri);
136     return(elist);
137 gwlarson 3.1 }
138
139     int
140 gwlarson 3.7 smTriangulate_add_tri(sm,id0,id1,id2,e0,e1,e2ptr)
141 gwlarson 3.1 SM *sm;
142 greg 3.13 S_ID id0,id1,id2;
143     int e0,e1,*e2ptr;
144 gwlarson 3.1 {
145 gwlarson 3.12 int t_id,e2;
146     TRI *t;
147 gwlarson 3.1
148 gwlarson 3.12 t_id = smAdd_tri(sm,id0,id1,id2,&t);
149 gwlarson 3.7 if(*e2ptr == 0)
150     {
151     e2 = eNew_edge();
152     SET_E_NTH_VERT(e2,0,id2);
153     SET_E_NTH_VERT(e2,1,id0);
154     }
155     else
156     e2 = *e2ptr;
157     /* set appropriate tri for each edge*/
158     SET_E_NTH_TRI(e0,0,t_id);
159     SET_E_NTH_TRI(e1,0,t_id);
160     SET_E_NTH_TRI(e2,0,t_id);
161 gwlarson 3.12 #ifdef DEBUG
162     #if DEBUG > 1
163     if(E_NTH_TRI(e0,1) == E_NTH_TRI(e0,0) ||
164     E_NTH_TRI(e1,1) == E_NTH_TRI(e1,0) ||
165     E_NTH_TRI(e2,1) == E_NTH_TRI(e2,0))
166     error(CONSISTENCY,"Non manifold\n");
167     #endif
168     #endif
169 gwlarson 3.7 *e2ptr = e2;
170     return(t_id);
171 gwlarson 3.12
172 gwlarson 3.1 }
173
174 gwlarson 3.12 int
175     smTriangulate_quad(sm,l)
176     SM *sm;
177     LIST *l;
178 gwlarson 3.1 {
179 greg 3.13 int e1,e2,e3,e4,e,t_id;
180     S_ID id0,id1,id2,id3;
181 gwlarson 3.12 FVECT v0,v1,v2,v3,n;
182     double dp;
183     TRI *tri;
184     LIST *lptr;
185 gwlarson 3.1
186 gwlarson 3.12 #ifdef DEBUG
187     if(LIST_NEXT(LIST_NEXT(LIST_NEXT(LIST_NEXT(l)))) != l)
188     {
189     eputs("smTriangulate_quad(): not a quadrilateral\n");
190     return(FALSE);
191     }
192     eputs("smTriangulate_quad():\n");
193     #endif
194     lptr=l;
195     e1 = (int)LIST_DATA(l);
196     id0 = E_NTH_VERT(e1,0);
197     id1 = E_NTH_VERT(e1,1);
198     VSUB(v0,SM_NTH_WV(sm,id0),SM_VIEW_CENTER(sm));
199     VSUB(v1,SM_NTH_WV(sm,id1),SM_VIEW_CENTER(sm));
200     /* Get v2 */
201     l = LIST_NEXT(l);
202     e2 = (int)LIST_DATA(l);
203     id2 = E_NTH_VERT(e2,1);
204     VSUB(v2,SM_NTH_WV(sm,id2),SM_VIEW_CENTER(sm));
205     /* Get v3 */
206     l = LIST_NEXT(l);
207     e3 = (int)LIST_DATA(l);
208     id3 = E_NTH_VERT(e3,1);
209     VSUB(v3,SM_NTH_WV(sm,id3),SM_VIEW_CENTER(sm));
210     l = LIST_NEXT(l);
211     e4 = (int)LIST_DATA(l);
212     free_list(lptr);
213
214     VCROSS(n,v0,v2);
215     normalize(n);
216     normalize(v1);
217     dp = DOT(n,v1);
218     e = 0;
219     if(dp > 0)
220     {
221     if(dp >= EV_EPS)
222 gwlarson 3.1 {
223 gwlarson 3.12 normalize(v3);
224     if(DOT(n,v3) < 0)
225     {
226     t_id = smTriangulate_add_tri(sm,id0,id1,id2,e1,e2,&e);
227     e *= -1;
228     t_id = smTriangulate_add_tri(sm,id2,id3,id0,e3,e4,&e);
229     return(TRUE);
230     }
231     }
232 gwlarson 3.1
233 gwlarson 3.12 }
234     #ifdef DEBUG
235     #if DEBUG > 1
236     VCROSS(n,v1,v3);
237     normalize(n);
238     normalize(v0);
239     normalize(v2);
240     dp = DOT(n,v2);
241     if((dp < 0) || (dp < EV_EPS) || (DOT(n,v0) >= 0.0))
242     error(CONSISTENCY,"smTriangulate_quad: cannot triangulate\n");
243     #endif
244     #endif
245     t_id = smTriangulate_add_tri(sm,id1,id2,id3,e2,e3,&e);
246     e *= -1;
247     t_id = smTriangulate_add_tri(sm,id3,id0,id1,e4,e1,&e);
248     return(TRUE);
249 gwlarson 3.1 }
250
251 greg 3.13 eIn_tri(e,t)
252     int e;
253     TRI *t;
254     {
255
256     if(T_NTH_V(t,0)==E_NTH_VERT(e,0))
257     return(T_NTH_V(t,1)==E_NTH_VERT(e,1)||T_NTH_V(t,2)==E_NTH_VERT(e,1));
258     else
259     if(T_NTH_V(t,1)==E_NTH_VERT(e,0))
260     return(T_NTH_V(t,0)==E_NTH_VERT(e,1)||T_NTH_V(t,2)==E_NTH_VERT(e,1));
261     else if(T_NTH_V(t,2)==E_NTH_VERT(e,0))
262     return(T_NTH_V(t,0)==E_NTH_VERT(e,1)||T_NTH_V(t,1)==E_NTH_VERT(e,1));
263
264     return(FALSE);
265     }
266
267
268 gwlarson 3.7 /* Triangulate the polygon defined by plist, and generating vertex p_id.
269     Return list of added triangles in list add_ptr. Returns TRUE if
270     successful, FALSE otherwise. This is NOT a general triangulation routine,
271     assumes polygon star relative to id
272     */
273 gwlarson 3.6
274     int
275 gwlarson 3.12 smTriangulate(sm,id,plist)
276 gwlarson 3.6 SM *sm;
277 greg 3.13 S_ID id;
278 gwlarson 3.12 LIST *plist;
279 gwlarson 3.1 {
280 gwlarson 3.6 LIST *l,*prev,*t;
281     FVECT v0,v1,v2,n,p;
282 greg 3.13 int is_tri,cut,t_id,e2,e1,enew;
283     S_ID id0,id1,id2;
284 gwlarson 3.12 double dp1,dp2;
285 gwlarson 3.6
286 gwlarson 3.7 VSUB(p,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm));
287 gwlarson 3.12 normalize(p);
288     l = plist;
289
290 gwlarson 3.7 enew = 0;
291 gwlarson 3.12 cut = is_tri= FALSE;
292     prev = l;
293 gwlarson 3.7 /* get v0,v1 */
294     e1 = (int)LIST_DATA(l);
295     id0 = E_NTH_VERT(e1,0);
296     id1 = E_NTH_VERT(e1,1);
297     VSUB(v0,SM_NTH_WV(sm,id0),SM_VIEW_CENTER(sm));
298 gwlarson 3.12 normalize(v0);
299 gwlarson 3.7 VSUB(v1,SM_NTH_WV(sm,id1),SM_VIEW_CENTER(sm));
300 gwlarson 3.12 normalize(v1);
301 gwlarson 3.6 while(l)
302     {
303     l = LIST_NEXT(l);
304 gwlarson 3.7 /* Get v2 */
305 gwlarson 3.6 e2 = (int)LIST_DATA(l);
306     id2 = E_NTH_VERT(e2,1);
307 gwlarson 3.7 VSUB(v2,SM_NTH_WV(sm,id2),SM_VIEW_CENTER(sm));
308 gwlarson 3.12 normalize(v2);
309 gwlarson 3.6 if(LIST_NEXT(LIST_NEXT(l)) == prev)
310 gwlarson 3.7 {/* Check if have a triangle */
311     is_tri = TRUE;
312     break;
313     }
314     /* determine if v0-v1-v2 is convex:defined clockwise on the sphere-
315     so switch orientation
316     */
317 gwlarson 3.12 VCROSS(n,v0,v2);
318     normalize(n);
319     dp1 = DOT(n,p);
320     if(dp1 <= 0.0)
321 gwlarson 3.6 {
322 gwlarson 3.7 /* test if safe to cut off v0-v1-v2 by testing if p lies outside of
323     triangle v0-v1-v2: if so, because plist is the star polygon around p,
324     the new edge v2-v0 cannot intersect any existing edges
325     */
326 gwlarson 3.12 dp1 = DOT(n,v1);
327     /* Distance from point s to plane is d = |N.p0s|/||N|| */
328     /* sp1 = s-p0 for point on plane p0, a.(b+c) = a.b + a.c */
329     if(dp1 >= EV_EPS)
330     {
331 gwlarson 3.7 /* remove edges e1,e2 and add triangle id0,id1,id2 */
332 gwlarson 3.12 enew = 0;
333     t_id = smTriangulate_add_tri(sm,id0,id1,id2,e1,e2,&enew);
334     cut = TRUE;
335     /* Insert edge enew into the list, reuse prev list element */
336     LIST_NEXT(prev) = LIST_NEXT(l);
337     LIST_DATA(prev) = e1 = -enew;
338     /* If removing head of list- reset plist pointer */
339     if(l== plist)
340     plist = prev;
341     /* free list element for e2 */
342     LIST_NEXT(l)=NULL;
343     free_list(l);
344     l = prev;
345     VCOPY(v1,v2);
346     id1 = id2;
347     continue;
348 gwlarson 3.7 }
349 greg 3.13 }
350 gwlarson 3.7 VCOPY(v0,v1);
351     VCOPY(v1,v2);
352     id0 = id1;
353     id1 = id2;
354     e1 = e2;
355     /* check if gone around circular list without adding any
356     triangles: prevent infinite loop */
357     if(l == plist)
358 gwlarson 3.6 {
359 gwlarson 3.7 if(LIST_NEXT(LIST_NEXT(l)) == prev)
360     {/* Check if have a triangle */
361     is_tri = TRUE;
362     break;
363     }
364 gwlarson 3.12 if(!cut)
365 gwlarson 3.6 break;
366 gwlarson 3.7 cut = FALSE;
367 greg 3.13 }
368 gwlarson 3.7 prev = l;
369 greg 3.13 }
370     if(is_tri)
371     {
372 gwlarson 3.6 l = LIST_NEXT(l);
373 gwlarson 3.7 enew = (int)LIST_DATA(l);
374     t_id = smTriangulate_add_tri(sm,id0,id1,id2,e1,e2,&enew);
375 gwlarson 3.6 free_list(l);
376 greg 3.13 }
377     else
378     if(!smTriangulate_quad(sm,l))
379 gwlarson 3.12 goto Terror;
380 gwlarson 3.7 /* Set triangle adjacencies based on edge adjacencies */
381     FOR_ALL_EDGES(enew)
382 gwlarson 3.1 {
383 gwlarson 3.7 id0 = E_NTH_TRI(enew,0);
384     id1 = E_NTH_TRI(enew,1);
385 gwlarson 3.1
386 gwlarson 3.7 e1 = (T_WHICH_V(SM_NTH_TRI(sm,id0),E_NTH_VERT(enew,0))+2)%3;
387     T_NTH_NBR(SM_NTH_TRI(sm,id0),e1) = id1;
388
389     e2 = (T_WHICH_V(SM_NTH_TRI(sm,id1),E_NTH_VERT(enew,1))+2)%3;
390     T_NTH_NBR(SM_NTH_TRI(sm,id1),e2) = id0;
391 greg 3.13 }
392 gwlarson 3.12
393     #ifdef DEBUG
394     #if DEBUG > 1
395     {
396     TRI *t0,*t1,*n;
397
398     FOR_ALL_EDGES(enew)
399     {
400     id0 = E_NTH_TRI(enew,0);
401     id1 = E_NTH_TRI(enew,1);
402     t0 = SM_NTH_TRI(sm,id0);
403     t1 = SM_NTH_TRI(sm,id1);
404     if(T_NTH_NBR(t0,0) == T_NTH_NBR(t0,1) ||
405     T_NTH_NBR(t0,1) == T_NTH_NBR(t0,2) ||
406     T_NTH_NBR(t0,0) == T_NTH_NBR(t0,2))
407     error(CONSISTENCY,"Invalid topology\n");
408     if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,0))) ||
409     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,1))) ||
410     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,2))))
411     error(CONSISTENCY,"Invalid topology\n");
412     n = SM_NTH_TRI(sm,T_NTH_NBR(t0,0));
413     if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
414     T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
415     T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
416     error(CONSISTENCY,"Invalid topology\n");
417     if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
418     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
419     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
420     error(CONSISTENCY,"Invalid topology\n");
421     n = SM_NTH_TRI(sm,T_NTH_NBR(t0,1));
422     if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
423     T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
424     T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
425     error(CONSISTENCY,"Invalid topology\n");
426     if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
427     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
428     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
429     error(CONSISTENCY,"Invalid topology\n");
430     n = SM_NTH_TRI(sm,T_NTH_NBR(t0,2));
431     if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
432     T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
433     T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
434     error(CONSISTENCY,"Invalid topology\n");
435     if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
436     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
437     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
438     error(CONSISTENCY,"Invalid topology\n");
439
440     if(T_NTH_NBR(t1,0) == T_NTH_NBR(t1,1) ||
441     T_NTH_NBR(t1,1) == T_NTH_NBR(t1,2) ||
442     T_NTH_NBR(t1,0) == T_NTH_NBR(t1,2))
443     error(CONSISTENCY,"Invalid topology\n");
444     if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,0))) ||
445     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,1))) ||
446     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,2))))
447     error(CONSISTENCY,"Invalid topology\n");
448     n = SM_NTH_TRI(sm,T_NTH_NBR(t1,0));
449     if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
450     T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
451     T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
452     error(CONSISTENCY,"Invalid topology\n");
453     if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
454     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
455     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
456     error(CONSISTENCY,"Invalid topology\n");
457     n = SM_NTH_TRI(sm,T_NTH_NBR(t1,1));
458     if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
459     T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
460     T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
461     error(CONSISTENCY,"Invalid topology\n");
462     if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
463     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
464     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
465     error(CONSISTENCY,"Invalid topology\n");
466     n = SM_NTH_TRI(sm,T_NTH_NBR(t1,2));
467     if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
468     T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
469     T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
470     error(CONSISTENCY,"Invalid topology\n");
471     if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
472     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
473     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
474     error(CONSISTENCY,"Invalid topology\n");
475 greg 3.13 }
476
477     }
478 gwlarson 3.12 #endif
479 greg 3.13 #endif
480
481 gwlarson 3.7 return(TRUE);
482 gwlarson 3.12
483     Terror:
484 greg 3.13
485 gwlarson 3.12 error(CONSISTENCY,"smTriangulate():Unable to triangulate\n");
486 gwlarson 3.7
487 gwlarson 3.1 }
488 gwlarson 3.6
489 gwlarson 3.12
490     void
491     smTris_swap_edge(sm,t_id,t1_id,e,e1,tn_id,tn1_id)
492     SM *sm;
493     int t_id,t1_id;
494     int e,e1;
495     int *tn_id,*tn1_id;
496     {
497 greg 3.13 S_ID verts[3];
498     int enext,eprev,e1next,e1prev;
499 gwlarson 3.12 TRI *n,*ta,*tb,*t,*t1;
500     FVECT p1,p2,p3;
501     int ta_id,tb_id;
502     /* form new diagonal (e relative to t, and e1 relative to t1)
503     defined by quadrilateral formed by t,t1- swap for the opposite diagonal
504     */
505     t = SM_NTH_TRI(sm,t_id);
506     t1 = SM_NTH_TRI(sm,t1_id);
507     enext = (e+1)%3;
508     eprev = (e+2)%3;
509     e1next = (e1+1)%3;
510     e1prev = (e1+2)%3;
511     verts[e] = T_NTH_V(t,e);
512     verts[enext] = T_NTH_V(t,enext);
513     verts[eprev] = T_NTH_V(t1,e1);
514     ta_id = smAdd_tri(sm,verts[0],verts[1],verts[2],&ta);
515     #if 0
516     fprintf(stderr,"Added tri %d %d %d %d\n",ta_id,T_NTH_V(ta,0),
517     T_NTH_V(ta,1), T_NTH_V(ta,2));
518     #endif
519     verts[e1] = T_NTH_V(t1,e1);
520     verts[e1next] = T_NTH_V(t1,e1next);
521     verts[e1prev] = T_NTH_V(t,e);
522     tb_id = smAdd_tri(sm,verts[0],verts[1],verts[2],&tb);
523     #if 0
524     fprintf(stderr,"Added tri %d %d %d %d\n",tb_id,T_NTH_V(tb,0),
525     T_NTH_V(tb,1), T_NTH_V(tb,2));
526     #endif
527     /* set the neighbors */
528     T_NTH_NBR(ta,e) = T_NTH_NBR(t1,e1next);
529     T_NTH_NBR(tb,e1) = T_NTH_NBR(t,enext);
530     T_NTH_NBR(ta,enext)= tb_id;
531     T_NTH_NBR(tb,e1next)= ta_id;
532     T_NTH_NBR(ta,eprev)=T_NTH_NBR(t,eprev);
533     T_NTH_NBR(tb,e1prev)=T_NTH_NBR(t1,e1prev);
534
535     /* Reset neighbor pointers of original neighbors */
536     n = SM_NTH_TRI(sm,T_NTH_NBR(t,enext));
537     T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = tb_id;
538     n = SM_NTH_TRI(sm,T_NTH_NBR(t,eprev));
539     T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = ta_id;
540     n = SM_NTH_TRI(sm,T_NTH_NBR(t1,e1next));
541     T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = ta_id;
542     n = SM_NTH_TRI(sm,T_NTH_NBR(t1,e1prev));
543     T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = tb_id;
544
545     smDelete_tri(sm,t_id,t);
546     smDelete_tri(sm,t1_id,t1);
547
548     #ifdef DEBUG
549     #if DEBUG > 1
550     if(T_NTH_NBR(ta,0) == T_NTH_NBR(ta,1) ||
551     T_NTH_NBR(ta,1) == T_NTH_NBR(ta,2) ||
552     T_NTH_NBR(ta,0) == T_NTH_NBR(ta,2))
553     error(CONSISTENCY,"Invalid topology\n");
554     if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,0))) ||
555     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,1))) ||
556     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,2))))
557     error(CONSISTENCY,"Invalid topology\n");
558     n = SM_NTH_TRI(sm,T_NTH_NBR(ta,0));
559     if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
560     T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
561     T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
562     error(CONSISTENCY,"Invalid topology\n");
563     if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
564     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
565     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
566     error(CONSISTENCY,"Invalid topology\n");
567     n = SM_NTH_TRI(sm,T_NTH_NBR(ta,1));
568     if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
569     T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
570     T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
571     error(CONSISTENCY,"Invalid topology\n");
572     if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
573     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
574     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
575     error(CONSISTENCY,"Invalid topology\n");
576     n = SM_NTH_TRI(sm,T_NTH_NBR(ta,2));
577     if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
578     T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
579     T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
580     error(CONSISTENCY,"Invalid topology\n");
581     if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
582     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
583     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
584     error(CONSISTENCY,"Invalid topology\n");
585     if(T_NTH_NBR(ta,0) == T_NTH_NBR(ta,1) ||
586     T_NTH_NBR(ta,1) == T_NTH_NBR(ta,2) ||
587     T_NTH_NBR(ta,0) == T_NTH_NBR(ta,2))
588     error(CONSISTENCY,"Invalid topology\n");
589
590     if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,0))) ||
591     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,1))) ||
592     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,2))))
593     error(CONSISTENCY,"Invalid topology\n");
594     n = SM_NTH_TRI(sm,T_NTH_NBR(tb,0));
595     if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
596     T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
597     T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
598     error(CONSISTENCY,"Invalid topology\n");
599     if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
600     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
601     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
602     error(CONSISTENCY,"Invalid topology\n");
603     n = SM_NTH_TRI(sm,T_NTH_NBR(tb,1));
604     if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
605     T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
606     T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
607     error(CONSISTENCY,"Invalid topology\n");
608     if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
609     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
610     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
611     error(CONSISTENCY,"Invalid topology\n");
612     n = SM_NTH_TRI(sm,T_NTH_NBR(tb,2));
613     if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) ||
614     T_NTH_NBR(n,1) == T_NTH_NBR(n,2) ||
615     T_NTH_NBR(n,0) == T_NTH_NBR(n,2))
616     error(CONSISTENCY,"Invalid topology\n");
617     if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) ||
618     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) ||
619     !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2))))
620     error(CONSISTENCY,"Invalid topology\n");
621     #endif
622     #endif
623     *tn_id = ta_id;
624     *tn1_id = tb_id;
625
626     return;
627     }
628
629 gwlarson 3.7 /* Test the new set of triangles for Delaunay condition. 'Edges' contains
630     all of the new edges added. The CCW triangle assoc with each edge is
631     tested against the opposite vertex of the CW triangle. If the vertex
632     lies inside the circle defined by the CCW triangle- the edge is swapped
633     for the opposite diagonal
634     */
635 gwlarson 3.12 smFixEdges(sm)
636 gwlarson 3.1 SM *sm;
637     {
638 gwlarson 3.6 int e,t0_id,t1_id,e_new,e0,e1,e0_next,e1_next;
639 greg 3.13 S_ID v0_id,v1_id,v2_id,p_id;
640     int i,t0_nid,t1_nid;
641 gwlarson 3.1 FVECT v0,v1,v2,p,np,v;
642 gwlarson 3.7 TRI *t0,*t1;
643 gwlarson 3.5
644 gwlarson 3.1 FOR_ALL_EDGES(e)
645     {
646 gwlarson 3.6 t0_id = E_NTH_TRI(e,0);
647     t1_id = E_NTH_TRI(e,1);
648 gwlarson 3.12 #ifdef DEBUG
649 gwlarson 3.6 if((t0_id==INVALID) || (t1_id==INVALID))
650 gwlarson 3.12 error(CONSISTENCY,"smFix_edges: Unassigned edge nbr\n");
651 gwlarson 3.1 #endif
652 gwlarson 3.7 t0 = SM_NTH_TRI(sm,t0_id);
653     t1 = SM_NTH_TRI(sm,t1_id);
654     e0 = T_NTH_NBR_PTR(t1_id,t0);
655     e1 = T_NTH_NBR_PTR(t0_id,t1);
656
657 gwlarson 3.6 v0_id = E_NTH_VERT(e,0);
658     v1_id = E_NTH_VERT(e,1);
659 gwlarson 3.7 v2_id = T_NTH_V(t0,e0);
660     p_id = T_NTH_V(t1,e1);
661 gwlarson 3.1
662 gwlarson 3.11 smDir(sm,v0,v0_id);
663     smDir(sm,v1,v1_id);
664     smDir(sm,v2,v2_id);
665 gwlarson 3.1
666 gwlarson 3.12 VSUB(p,SM_NTH_WV(sm,p_id),SM_VIEW_CENTER(sm));
667     normalize(p);
668     if(pt_in_cone(p,v2,v1,v0))
669 gwlarson 3.1 {
670 gwlarson 3.12 smTris_swap_edge(sm,t0_id,t1_id,e0,e1,&t0_nid,&t1_nid);
671 gwlarson 3.7 /* Adjust the triangle pointers of the remaining edges to be
672     processed
673     */
674 gwlarson 3.1 FOR_ALL_EDGES_FROM(e,i)
675     {
676 gwlarson 3.6 if(E_NTH_TRI(i,0)==t0_id || E_NTH_TRI(i,0)==t1_id)
677 gwlarson 3.1 {
678 gwlarson 3.6 if(eIn_tri(i,SM_NTH_TRI(sm,t0_nid)))
679     SET_E_NTH_TRI(i,0,t0_nid);
680 gwlarson 3.1 else
681 gwlarson 3.6 SET_E_NTH_TRI(i,0,t1_nid);
682 gwlarson 3.1 }
683
684 gwlarson 3.6 if(E_NTH_TRI(i,1)==t0_id || E_NTH_TRI(i,1)==t1_id)
685 gwlarson 3.1 {
686 gwlarson 3.6 if(eIn_tri(i,SM_NTH_TRI(sm,t0_nid)))
687     SET_E_NTH_TRI(i,1,t0_nid);
688 gwlarson 3.1 else
689 gwlarson 3.6 SET_E_NTH_TRI(i,1,t1_nid);
690 gwlarson 3.1 }
691 gwlarson 3.12 #ifdef DEBUG
692     if(E_NTH_TRI(i,1) == E_NTH_TRI(i,0) )
693     error(CONSISTENCY,"invalid edge\n");
694     #endif
695 gwlarson 3.1 }
696 gwlarson 3.6 t0_id = t0_nid;
697     t1_id = t1_nid;
698 gwlarson 3.1 e_new = eNew_edge();
699 gwlarson 3.6 SET_E_NTH_VERT(e_new,0,p_id);
700     SET_E_NTH_VERT(e_new,1,v2_id);
701     SET_E_NTH_TRI(e_new,0,t0_id);
702     SET_E_NTH_TRI(e_new,1,t1_id);
703 gwlarson 3.12 #ifdef DEBUG
704     if(E_NTH_TRI(i,1) == E_NTH_TRI(i,0) )
705     error(CONSISTENCY,"invalid edge\n");
706     #endif
707 gwlarson 3.1 }
708     }
709     }
710
711 gwlarson 3.12
712     smDelete_samp(sm,s_id)
713     SM *sm;
714 greg 3.13 S_ID s_id;
715 gwlarson 3.12 {
716     QUADTREE qt;
717 greg 3.13 S_ID *os;
718 gwlarson 3.12
719     /* Mark as free */
720     smUnalloc_samp(sm,s_id);
721
722     #ifdef DEBUG
723     SM_NTH_VERT(sm,s_id) = INVALID;
724     /* fprintf(stderr,"deleting sample %d\n",s_id); */
725     #endif
726     /* remove from its set */
727     qt = SM_S_NTH_QT(sm,s_id);
728     os = qtqueryset(qt);
729     deletuelem(os, s_id); /* delete obj from unsorted os, no questions */
730     }
731 gwlarson 3.7 /* Remove vertex "id" from the mesh- and retriangulate the resulting
732     hole: Returns TRUE if successful, FALSE otherwise.
733     */
734 gwlarson 3.1 int
735 gwlarson 3.7 smRemoveVertex(sm,id)
736 gwlarson 3.1 SM *sm;
737 greg 3.13 S_ID id;
738 gwlarson 3.1 {
739 gwlarson 3.12 LIST *b_list;
740 gwlarson 3.7 /* generate list of edges that form the boundary of the
741 gwlarson 3.12 polygon formed by the triangles adjacent to vertex 'id'*/
742     b_list = smVertexStar(sm,id);
743     #if 0
744     {int i;
745     eputs("\n\n");
746     for(i=1;i<=Ecnt;i++)
747     fprintf(stderr,"%d verts %d %d tris %d %d\n",
748     i,Edges[i].verts[0],Edges[i].verts[1],
749     Edges[i].tris[0],Edges[i].tris[1]);
750     }
751     #endif
752
753 gwlarson 3.7 /* Triangulate polygonal hole */
754 gwlarson 3.12 smTriangulate(sm,id,b_list);
755
756     /* Fix up new triangles to be Delaunay*/
757 gwlarson 3.7
758 gwlarson 3.12 smFixEdges(sm);
759     smDelete_samp(sm,id);
760     eClear_edges();
761 gwlarson 3.1 return(TRUE);
762     }
763
764
765
766 gwlarson 3.8
767 gwlarson 3.1
768
769
770
771
772
773
774
775
776
777
