--- ray/src/hd/sm.h 1998/12/28 18:07:34 3.6 +++ ray/src/hd/sm.h 1999/01/05 16:52:38 3.7 @@ -148,14 +148,16 @@ typedef struct _SM { #define SM_T_ID_VALID(s,t_id) T_IS_VALID(SM_NTH_TRI(s,t_id)) + #define SM_MAX_SAMP(m) S_MAX_SAMP(SM_SAMP(m)) #define SM_MAX_POINTS(m) S_MAX_POINTS(SM_SAMP(m)) #define SM_SAMP_BASE(m) S_BASE(SM_SAMP(m)) #define SM_NTH_WV(m,i) S_NTH_W_PT(SM_SAMP(m),i) #define SM_NTH_W_DIR(m,i) S_NTH_W_DIR(SM_SAMP(m),i) -#define SM_DIR_ID(m,i) (SM_NTH_W_DIR(m,i)==-1) +#define SM_DIR_ID(m,i) (!SM_BASE_ID(m,i) && SM_NTH_W_DIR(m,i)==-1) #define SM_NTH_RGB(m,i) S_NTH_RGB(SM_SAMP(m),i) #define SM_RGB(m) S_RGB(SM_SAMP(m)) +#define SM_WP(m) S_W_PT(SM_SAMP(m)) #define SM_BRT(m) S_BRT(SM_SAMP(m)) #define SM_NTH_BRT(m,i) S_NTH_BRT(SM_SAMP(m),i) #define SM_CHR(m) S_CHR(SM_SAMP(m)) @@ -169,7 +171,11 @@ typedef struct _SM { i < SM_NUM_TRI(m); i=smNext_tri_flag_set(m,i+1,w,b)) #define SM_FOR_ALL_ACTIVE_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,0) +#if 0 #define SM_FOR_ALL_NEW_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_NEW_FLAG,0) +#else +#define SM_FOR_ALL_NEW_TRIS(m,i) for(i=0; i < smNew_tri_cnt; i++) +#endif #define SM_FOR_ALL_BASE_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_BASE_FLAG,0) #define SM_FOR_ALL_VALID_TRIS(m,i) for(i=smNext_valid_tri(m,0); \ i < SM_NUM_TRI(m); i=smNext_valid_tri(m,i+1)) @@ -235,6 +241,9 @@ typedef struct _ADD_ARGS { extern SM *smMesh; extern int smNew_tri_cnt; +extern int smNew_tri_size; +extern T_DEPTH *smNew_tris; + extern double smDist_sum;
