1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
/* SCCSid "$SunId$ SGI" */ |
4 |
5 |
6 |
* sm.h |
7 |
8 |
9 |
#ifndef _SM_H_ |
10 |
#define _SM_H_ |
11 |
12 |
#include "rhd_sample.h" |
13 |
#define NEWSETS |
14 |
15 |
16 |
#ifndef TRUE |
17 |
#define TRUE 1 |
18 |
#define FALSE 0 |
19 |
#endif |
20 |
21 |
22 |
#define ON_V 1 |
23 |
#define ON_P 2 |
24 |
#define ON_E 3 |
25 |
#define IN_T 4 |
26 |
27 |
#define S_REPLACE_EPS 0.04 /* if (distance on sphere between sample |
28 |
and a base point) < S_REPLACE_EPS, |
29 |
replace base: |
30 |
31 |
#define S_REPLACE_SCALE (5.*5.) /* if (distance to new point squared) is |
32 |
> (triangle edge length squared* |
33 |
S_REPLACE_SCALE):for all edges/triangle |
34 |
vertices: new point is puncture |
35 |
point: dont add |
36 |
37 |
#define S_REPLACE_TRI 2e-8 /* .052 radians to the sixth power */ |
38 |
39 |
#define SQRT3_2 0.8660254 |
40 |
41 |
#define SM_DEFAULT 0 |
42 |
#define SM_EXTRA_POINTS 162 |
43 |
#define SM_BASE_TRIS 320 |
44 |
#define SM_EXTRA_VERTS SM_EXTRA_POINTS |
45 |
46 |
#define SM_INC_PERCENT 0.60 /* If number of new triangles added |
47 |
since last full redraw is > |
48 |
(SM_INC_PERCENT * total triangles) |
49 |
do full redraw instead of incremental |
50 |
51 |
52 |
#define SM_VIEW_FRAC 0.1 |
53 |
54 |
55 |
typedef int VERT; /* One triangle that vertex belongs to- the rest |
56 |
are derived by traversing neighbors */ |
57 |
58 |
typedef struct _EDGE { |
59 |
int verts[2]; |
60 |
int tris[2]; |
61 |
} EDGE; |
62 |
63 |
#define E_NTH_VERT(e,i) ((e>0)?Edges[(e)].verts[(i)]:Edges[-(e)].verts[(1-i)]) |
64 |
#define SET_E_NTH_VERT(e,i,v) if(e>0) Edges[(e)].verts[(i)]=(v); \ |
65 |
else Edges[-(e)].verts[(1-i)]=(v) |
66 |
#define E_NTH_TRI(e,i) ((e>0)?Edges[(e)].tris[(i)]:Edges[-(e)].tris[(1-i)]) |
67 |
#define SET_E_NTH_TRI(e,i,v) if(e>0) Edges[(e)].tris[(i)]=(v); \ |
68 |
else Edges[-(e)].tris[(1-i)]=(v) |
69 |
#define eClear_edges() (Ecnt = 0) |
70 |
71 |
#define FOR_ALL_EDGES(i) for((i)=1; (i) <= Ecnt; i++) |
72 |
#define FOR_ALL_EDGES_FROM(e,i) for((i)=++e; (i) <= Ecnt; i++) |
73 |
74 |
75 |
typedef struct _TRI { |
76 |
int verts[3]; /* Ids into sample and vertex array for each vertex*/ |
77 |
int nbrs[3]; /* Ids for neighboring triangles: -1 if invalid */ |
78 |
}TRI; |
79 |
80 |
81 |
#define T_NTH_NBR(t,i) ((t)->nbrs[(i)]) |
82 |
#define T_CLEAR_NBRS(t) (T_NTH_NBR(t,0)=T_NTH_NBR(t,1)=T_NTH_NBR(t,2)=-1) |
83 |
#define T_NTH_NBR_PTR(t,n) \ |
84 |
(T_NTH_NBR(n,0)==(t)?0:T_NTH_NBR(n,1)==(t)?1:T_NTH_NBR(n,2)==(t)?2:-1) |
85 |
#define T_NTH_V(t,i) ((t)->verts[(i)]) |
86 |
#define T_WHICH_V(t,i) \ |
87 |
(T_NTH_V(t,0)==(i)?0:T_NTH_V(t,1)==(i)?1:T_NTH_V(t,2)==(i)?2:-1) |
88 |
#define T_NEXT_FREE(t) ((t)->nbrs[0]) |
89 |
#define T_NEXT_AVAILABLE(t) ((t)->nbrs[0]) |
90 |
#define T_VALID_FLAG(t) ((t)->nbrs[1]) |
91 |
#define T_IS_VALID(t) (T_VALID_FLAG(t)!=-1) |
92 |
#define T_FLAGS 3 |
93 |
94 |
typedef struct _SM { |
95 |
FVECT view_center; /* Canonical view center defining unit sphere */ |
96 |
SAMP *samples; /* Sample point information */ |
97 |
STREE locator; /* spherical quadtree for point/triangle location */ |
98 |
int max_tris; /* Maximum number of triangles */ |
99 |
int num_tri; /* Current number of triangles */ |
100 |
int sample_tris; /* Current number of non-base triangles*/ |
101 |
int free_tris; /* pointer to free_list */ |
102 |
int available_tris; /* pointer to available_list */ |
103 |
int max_verts; /* Maximum number of vertices in the mesh */ |
104 |
TRI *tris; /* Pointer to list of triangle structs */ |
105 |
VERT *verts; /* List of vertices */ |
106 |
int4 *flags[T_FLAGS]; /* Bit 0 set if active(in current frustum) */ |
107 |
/* Bit 1 set if not rendered since created */ |
108 |
/* Bit 2 set if base triangle */ |
109 |
}SM; |
110 |
111 |
#define T_ACTIVE_FLAG 0 |
112 |
#define T_NEW_FLAG 1 |
113 |
#define T_BASE_FLAG 2 |
114 |
115 |
#define SM_VIEW_CENTER(m) ((m)->view_center) |
116 |
#define SM_SAMP(m) ((m)->samples) |
117 |
#define SM_LOCATOR(m) (&((m)->locator)) |
118 |
#define SM_MAX_TRIS(m) ((m)->max_tris) |
119 |
#define SM_NUM_TRI(m) ((m)->num_tri) |
120 |
#define SM_SAMPLE_TRIS(m) ((m)->sample_tris) |
121 |
#define SM_FREE_TRIS(m) ((m)->free_tris) |
122 |
#define SM_AVAILABLE_TRIS(m) ((m)->available_tris) |
123 |
#define SM_MAX_VERTS(m) ((m)->max_verts) |
124 |
#define SM_TRIS(m) ((m)->tris) |
125 |
#define SM_VERTS(m) ((m)->verts) |
126 |
#define SM_NTH_FLAGS(m,n) ((m)->flags[(n)]) |
127 |
#define SM_FLAGS(m) ((m)->flags) |
128 |
129 |
130 |
#define SM_IS_NTH_T_FLAG(sm,n,f) IS_FLAG(SM_NTH_FLAGS(sm,f),n) |
131 |
#define SM_SET_NTH_T_FLAG(sm,n,f) SET_FLAG(SM_NTH_FLAGS(sm,f),n) |
132 |
#define SM_CLR_NTH_T_FLAG(sm,n,f) CLR_FLAG(SM_NTH_FLAGS(sm,f),n) |
133 |
134 |
#define SM_IS_NTH_T_ACTIVE(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG) |
135 |
#define SM_IS_NTH_T_BASE(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_BASE_FLAG) |
136 |
#define SM_IS_NTH_T_NEW(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_NEW_FLAG) |
137 |
138 |
#define SM_SET_NTH_T_ACTIVE(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG) |
139 |
#define SM_SET_NTH_T_BASE(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_BASE_FLAG) |
140 |
#define SM_SET_NTH_T_NEW(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_NEW_FLAG) |
141 |
142 |
#define SM_CLR_NTH_T_ACTIVE(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG) |
143 |
#define SM_CLR_NTH_T_BASE(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_BASE_FLAG) |
144 |
#define SM_CLR_NTH_T_NEW(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_NEW_FLAG) |
145 |
146 |
#define SM_NTH_TRI(m,n) (&(SM_TRIS(m)[(n)])) |
147 |
#define SM_NTH_VERT(m,n) (SM_VERTS(m)[(n)]) |
148 |
149 |
#define SM_T_ID_VALID(s,t_id) T_IS_VALID(SM_NTH_TRI(s,t_id)) |
150 |
151 |
152 |
#define SM_MAX_SAMP(m) S_MAX_SAMP(SM_SAMP(m)) |
153 |
#define SM_MAX_POINTS(m) S_MAX_POINTS(SM_SAMP(m)) |
154 |
#define SM_SAMP_BASE(m) S_BASE(SM_SAMP(m)) |
155 |
#define SM_NTH_WV(m,i) S_NTH_W_PT(SM_SAMP(m),i) |
156 |
#define SM_NTH_W_DIR(m,i) S_NTH_W_DIR(SM_SAMP(m),i) |
157 |
#define SM_DIR_ID(m,i) (!SM_BASE_ID(m,i) && SM_NTH_W_DIR(m,i)==-1) |
158 |
#define SM_NTH_RGB(m,i) S_NTH_RGB(SM_SAMP(m),i) |
159 |
#define SM_RGB(m) S_RGB(SM_SAMP(m)) |
160 |
#define SM_WP(m) S_W_PT(SM_SAMP(m)) |
161 |
#define SM_BRT(m) S_BRT(SM_SAMP(m)) |
162 |
#define SM_NTH_BRT(m,i) S_NTH_BRT(SM_SAMP(m),i) |
163 |
#define SM_CHR(m) S_CHR(SM_SAMP(m)) |
164 |
#define SM_NTH_CHR(m,i) S_NTH_CHR(SM_SAMP(m),i) |
165 |
#define SM_NUM_SAMP(m) S_NUM_SAMP(SM_SAMP(m)) |
166 |
#define SM_TONE_MAP(m) S_TONE_MAP(SM_SAMP(m)) |
167 |
168 |
#define SM_ALLOWED_VIEW_CHANGE(m) (SM_NUM_SAMP(m)/smDist_sum*SM_VIEW_FRAC) |
169 |
170 |
#define SM_FOR_ALL_FLAGGED_TRIS(m,i,w,b) for(i=smNext_tri_flag_set(m,0,w,b); \ |
171 |
i < SM_NUM_TRI(m); i=smNext_tri_flag_set(m,i+1,w,b)) |
172 |
173 |
#define SM_FOR_ALL_ACTIVE_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,0) |
174 |
#if 0 |
175 |
#define SM_FOR_ALL_NEW_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_NEW_FLAG,0) |
176 |
#else |
177 |
#define SM_FOR_ALL_NEW_TRIS(m,i) for(i=0; i < smNew_tri_cnt; i++) |
178 |
#endif |
179 |
#define SM_FOR_ALL_BASE_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_BASE_FLAG,0) |
180 |
#define SM_FOR_ALL_VALID_TRIS(m,i) for(i=smNext_valid_tri(m,0); \ |
181 |
i < SM_NUM_TRI(m); i=smNext_valid_tri(m,i+1)) |
182 |
183 |
#define SM_FOR_ALL_ACTIVE_FG_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,1) |
184 |
185 |
#define SM_FOR_ALL_ACTIVE_BG_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,2) |
186 |
187 |
188 |
#define SM_FOR_ALL_ADJACENT_TRIS(sm,id,t) for(t=smTri_next_ccw_nbr(sm,t,id); \ |
189 |
t!=SM_NTH_TRI(sm,SM_NTH_VERT(sm,id)); t=smTri_next_ccw_nbr(sm,t,id)) |
190 |
191 |
#define SM_INVALID_SAMP_ID(sm,id) (((id) < 0) || ((id) >= SM_MAX_SAMP(sm))) |
192 |
#define SM_INVALID_POINT_ID(sm,id) (((id) < 0) || ((id) >= SM_MAX_POINTS(sm))) |
193 |
#define SM_T_NTH_WV(sm,t,i) (SM_NTH_WV(sm,T_NTH_V(t,i))) |
194 |
195 |
#define SM_BASE_ID(s,i) \ |
196 |
((i) >= S_MAX_SAMP(SM_SAMP(s)) && (i) < S_MAX_BASE_PT(SM_SAMP(s))) |
197 |
198 |
#define SM_BG_SAMPLE(sm,i) (SM_NTH_W_DIR(sm,i)==-1) |
199 |
200 |
#define SM_BG_TRI(sm,i) (SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),0)) && \ |
201 |
SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),1)) && \ |
202 |
SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),2))) |
203 |
#define SM_MIXED_TRI(sm,i) (SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),0)) || \ |
204 |
SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),1)) || \ |
205 |
206 |
207 |
#define SM_FOR_ALL_SAMPLES(sm,i) for((i)=0;i < SM_NUM_SAMP(sm);(i)++) |
208 |
209 |
#define smInit_locator(sm,c) (stInit(SM_LOCATOR(sm)), \ |
210 |
ST_SET_CENTER(SM_LOCATOR(sm),c)) |
211 |
#define smClear_locator(sm) stClear(SM_LOCATOR(sm)) |
212 |
#define smAlloc_locator(sm) stAlloc(SM_LOCATOR(sm)) |
213 |
#define smFree_locator(sm) stClear(SM_LOCATOR(sm)) |
214 |
#define smPointLocateCell(sm,pt) stPoint_locate(SM_LOCATOR(sm),pt) |
215 |
#define smUnalloc_samp(sm,id) sUnalloc_samp(SM_SAMP(sm),id) |
216 |
#define smFree_samples(sm) sFree(SM_SAMP(sm)) |
217 |
#define smClear_samples(sm) sClear(SM_SAMP(sm)) |
218 |
#define smInit_samples(sm) sInit(SM_SAMP(sm)) |
219 |
220 |
221 |
#define smClear_vert(sm,id) (SM_NTH_VERT(sm,id) = INVALID) |
222 |
223 |
#define SQRT3_INV 0.5773502692 |
224 |
225 |
typedef struct _T_DEPTH { |
226 |
int tri; |
227 |
double depth; |
228 |
}T_DEPTH; |
229 |
230 |
typedef struct _RT_ARGS_{ |
231 |
FVECT orig,dir; |
232 |
int t_id; |
233 |
OBJECT *os; |
234 |
}RT_ARGS; |
235 |
236 |
237 |
typedef struct _ADD_ARGS { |
238 |
int t_id; |
239 |
OBJECT *del_set; |
240 |
}ADD_ARGS; |
241 |
242 |
extern SM *smMesh; |
243 |
extern int smNew_tri_cnt; |
244 |
extern int smNew_tri_size; |
245 |
extern T_DEPTH *smNew_tris; |
246 |
247 |
extern double smDist_sum; |
248 |
249 |
250 |
#ifdef TEST_DRIVER |
251 |
extern VIEW View; |
252 |
extern VIEW Current_View; |
253 |
extern int Pick_tri,Picking,Pick_samp; |
254 |
extern FVECT Pick_point[500],Pick_origin,Pick_dir; |
255 |
extern FVECT Pick_v0[500],Pick_v1[500],Pick_v2[500]; |
256 |
extern int Pick_q[500]; |
257 |
extern FVECT P0,P1,P2; |
258 |
extern int Pick_cnt; |
259 |
extern FVECT FrustumNear[4],FrustumFar[4]; |
260 |
#endif |
261 |
262 |
263 |
264 |
* int |
265 |
* smInit(n) : Initialize/clear data structures for n entries |
266 |
* int n; |
267 |
268 |
* Initialize sampL and other data structures for at least n samples. |
269 |
* If n is 0, then free data structures. Return number actually allocated. |
270 |
271 |
272 |
* int |
273 |
* smNewSamp(c, p, v) : register new sample point and return index |
274 |
* COLR c; : pixel color (RGBE) |
275 |
* FVECT p; : world intersection point |
276 |
* FVECT v; : ray direction vector |
277 |
278 |
* Add new sample point to data structures, removing old values as necessary. |
279 |
* New sample representation will be output in next call to smUpdate(). |
280 |
281 |
282 |
* int |
283 |
* smFindSamp(orig, dir): intersect ray with 3D rep. and find closest sample |
284 |
* FVECT orig, dir; |
285 |
286 |
* Find the closest sample to the given ray. Return -1 on failure. |
287 |
288 |
289 |
* smClean() : display has been wiped clean |
290 |
291 |
* Called after display has been effectively cleared, meaning that all |
292 |
* geometry must be resent down the pipeline in the next call to smUpdate(). |
293 |
294 |
295 |
* smUpdate(vp, qua) : update OpenGL output geometry for view vp |
296 |
* VIEW *vp; : desired view |
297 |
* int qua; : quality level (percentage on linear time scale) |
298 |
299 |
* Draw new geometric representation using OpenGL calls. Assume that the |
300 |
* view has already been set up and the correct frame buffer has been |
301 |
* selected for drawing. The quality level is on a linear scale, where 100% |
302 |
* is full (final) quality. It is not necessary to redraw geometry that has |
303 |
* been output since the last call to smClean(). (The last view drawn will |
304 |
* be vp==&odev.v each time.) |
305 |
306 |
#endif |
307 |
308 |
309 |
310 |
311 |
312 |
313 |
314 |
