root/radiance/ray/src/hd/sm.h
Revision: 3.2
Committed: Fri Sep 11 11:52:25 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.1: +10 -5 lines
fixed triangle insertion using edge tracing
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * sm.h
7 */
8
9 #ifndef _SM_H_
10 #define _SM_H_
11
12 #include "rhd_sample.h"
13 #include "sm_stree.h"
14
15
16 #ifndef TRUE
17 #define TRUE 1
18 #define FALSE 0
19 #endif
20
21 #define P_REPLACE_EPS 0.5
22 #define SQRT3_2 0.8660254
23
24 #define MAX_EDGES 200
25
26 #define SM_INVALID -1
27 #define SM_DEFAULT 0
28 #define SM_EXTRA_POINTS 5
29 #define SM_EXTRA_VERTS SM_EXTRA_POINTS
30 #define SM_POINTSIZ (3*sizeof(float)+ sizeof(int4))
31 #define SM_POINT_SPACE SM_EXTRA_POINTS * SM_POINTSIZ
32
33 #define SM_INC_PERCENT 0.60
34 #define SM_VIEW_FRAC 0.1
35
36
37 typedef int VERT; /* One triangle that vertex belongs to- the rest
38 are derived by traversing neighbors */
39
40 typedef struct _EDGE {
41 int verts[2];
42 int tris[2];
43 } EDGE;
44 #define E_NTH_VERT(e,i) ((e>0)?Edges[(e)].verts[(i)]:Edges[-(e)].verts[(1-i)])
45 #define SET_E_NTH_VERT(e,i,v) if(e>0) Edges[(e)].verts[(i)]=(v); \
46 else Edges[-(e)].verts[(1-i)]=(v)
47 #define E_NTH_TRI(e,i) ((e>0)?Edges[(e)].tris[(i)]:Edges[-(e)].tris[(1-i)])
48 #define SET_E_NTH_TRI(e,i,v) if(e>0) Edges[(e)].tris[(i)]=(v); \
49 else Edges[-(e)].tris[(1-i)]=(v)
50 #define eNew_edge() (((Ecnt) < MAX_EDGES)?(++Ecnt):SM_INVALID)
51 #define eClear_edges() (Ecnt = 0)
52
53 #define FOR_ALL_EDGES(i) for((i)=1; (i) <= Ecnt; i++)
54 #define FOR_ALL_EDGES_FROM(e,i) for((i)=++e; (i) <= Ecnt; i++)
55
56
57 typedef struct _TRI {
58 int verts[3]; /* Ids into sample and vertex array for each vertex*/
59 int nbrs[3]; /* Ids for neighboring triangles: -1 if invalid */
60 }TRI;
61
62
63 #define T_NTH_NBR(t,i) ((t)->nbrs[(i)])
64 #define T_CLEAR_NBRS(t) (T_NTH_NBR(t,0)=T_NTH_NBR(t,1)=T_NTH_NBR(t,2)=-1)
65 #define T_NTH_NBR_PTR(t,n) \
66 (T_NTH_NBR(n,0)==(t)?0:T_NTH_NBR(n,1)==(t)?1:T_NTH_NBR(n,2)==(t)?2:-1)
67 #define T_NTH_V(t,i) ((t)->verts[(i)])
68 #define T_WHICH_V(t,i) \
69 (T_NTH_V(t,0)==(i)?0:T_NTH_V(t,1)==(i)?1:T_NTH_V(t,2)==(i)?2:-1)
70 #define T_NEXT_FREE(t) ((t)->verts[0])
71 #define T_VALID_FLAG(t) ((t)->verts[1])
72 #define T_IS_VALID(t) (T_VALID_FLAG(t)!=-1)
73 #define T_FLAGS 4
74 #define T_FLAG_BYTES T_FLAGS/8.0
75 #define T_TOTAL_FLAG_BYTES(c) ((((c)+31)>>5)*sizeof(int4))
76
77 typedef struct _SM {
78 FVECT view_center; /* Canonical view center defining unit sphere */
79 RSAMP *samples; /* Sample point information */
80 STREE locator; /* spherical quadtree for point/triangle location */
81 int max_tris; /* Maximum number of triangles */
82 int tri_cnt; /* Total number of tris ever alloc at one time*/
83 int num_tris; /* Current number of sample (nonbase)triangles */
84 int free_tris; /* pointer to free_list */
85 int max_verts; /* Maximum number of vertices in the mesh */
86 TRI *tris; /* Pointer to list of triangle structs */
87 VERT *verts; /* List of vertices */
88 int4 *flags[T_FLAGS]; /* Bit 0 set if active(in current frustum) */
89 /* Bit 1 set if not rendered since created */
90 /* Bit 2 set if base triangle */
91 /* Bit 3 set used for LRU replacement */
92 char *base; /* Allocated space */
93 }SM;
94
95 #define T_ACTIVE_FLAG 0
96 #define T_NEW_FLAG 1
97 #define T_BASE_FLAG 2
98 #define T_LRU_FLAG 3
99
100 #define SM_VIEW_CENTER(m) ((m)->view_center)
101 #define SM_SAMP(m) ((m)->samples)
102 #define SM_LOCATOR(m) (&((m)->locator))
103 #define SM_MAX_TRIS(m) ((m)->max_tris)
104 #define SM_TRI_CNT(m) ((m)->tri_cnt)
105 #define SM_NUM_TRIS(m) ((m)->num_tris)
106 #define SM_FREE_TRIS(m) ((m)->free_tris)
107 #define SM_MAX_VERTS(m) ((m)->max_verts)
108 #define SM_TRIS(m) ((m)->tris)
109 #define SM_VERTS(m) ((m)->verts)
110 #define SM_NTH_FLAGS(m,n) ((m)->flags[(n)])
111 #define SM_BASE(m) ((m)->base)
112
113 #define TF_OFFSET(n) ((n) >> 5)
114 #define TF_BIT(n) ((n) & 0x1f)
115 #define SM_IS_NTH_T_FLAG(sm,n,f) (SM_NTH_FLAGS(sm,f)[TF_OFFSET(n)] & (0x1 <<TF_BIT(n)))
116 #define SM_SET_NTH_T_FLAG(sm,n,f) (SM_NTH_FLAGS(sm,f)[TF_OFFSET(n)] |= (0x1<<TF_BIT(n)))
117 #define SM_CLEAR_NTH_T_FLAG(sm,n,f) (SM_NTH_FLAGS(sm,f)[TF_OFFSET(n)] &= ~(0x1<<TF_BIT(n)))
118
119 #define SM_IS_NTH_T_ACTIVE(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG)
120 #define SM_IS_NTH_T_BASE(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_BASE_FLAG)
121 #define SM_IS_NTH_T_NEW(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_NEW_FLAG)
122 #define SM_IS_NTH_T_LRU(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_LRU_FLAG)
123
124 #define SM_SET_NTH_T_ACTIVE(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG)
125 #define SM_SET_NTH_T_BASE(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_BASE_FLAG)
126 #define SM_SET_NTH_T_NEW(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_NEW_FLAG)
127 #define SM_SET_NTH_T_LRU(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_LRU_FLAG)
128
129 #define SM_CLEAR_NTH_T_ACTIVE(sm,n) SM_CLEAR_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG)
130 #define SM_CLEAR_NTH_T_BASE(sm,n) SM_CLEAR_NTH_T_FLAG(sm,n,T_BASE_FLAG)
131 #define SM_CLEAR_NTH_T_NEW(sm,n) SM_CLEAR_NTH_T_FLAG(sm,n,T_NEW_FLAG)
132 #define SM_CLEAR_NTH_T_LRU(sm,n) SM_CLEAR_NTH_T_FLAG(sm,n,T_LRU_FLAG)
133
134 #define SM_NTH_TRI(m,n) (&(SM_TRIS(m)[(n)]))
135 #define SM_NTH_VERT(m,n) (SM_VERTS(m)[(n)])
136 #define SM_FREE_TRI_ID(m,n) (n = SM_FREE_TRIS(m)==-1? \
137 (SM_TRI_CNT(m)<SM_MAX_TRIS(m)?SM_TRI_CNT(m)++:-1):(n=SM_FREE_TRIS(m), \
138 SM_FREE_TRIS(m)=T_NEXT_FREE(SM_NTH_TRI(m,SM_FREE_TRIS(m))),n))
139
140 #define SM_SAMP_BASE(m) RS_BASE(SM_SAMP(m))
141 #define SM_SAMP_FREE(m) RS_FREE(SM_SAMP(m))
142 #define SM_SAMP_EOL(m) RS_EOL(SM_SAMP(m))
143 #define SM_MAX_SAMP(m) RS_MAX_SAMP(SM_SAMP(m))
144 #define SM_MAX_AUX_PT(m) RS_MAX_AUX_PT(SM_SAMP(m))
145 #define SM_NTH_WV(m,i) RS_NTH_W_PT(SM_SAMP(m),i)
146 #define SM_NTH_W_DIR(m,i) RS_NTH_W_DIR(SM_SAMP(m),i)
147 #define SM_NTH_RGB(m,i) RS_NTH_RGB(SM_SAMP(m),i)
148 #define SM_RGB(m) RS_RGB(SM_SAMP(m))
149 #define SM_BRT(m) RS_BRT(SM_SAMP(m))
150 #define SM_NTH_BRT(m,i) RS_NTH_BRT(SM_SAMP(m),i)
151 #define SM_CHR(m) RS_CHR(SM_SAMP(m))
152 #define SM_NTH_CHR(m,i) RS_NTH_CHR(SM_SAMP(m),i)
153 #define SM_NUM_SAMP(m) RS_NUM_SAMP(SM_SAMP(m))
154 #define SM_TONE_MAP(m) RS_TONE_MAP(SM_SAMP(m))
155
156 #define SM_ALLOWED_VIEW_CHANGE(m) (SM_NUM_SAMP(m)/smDist_sum*SM_VIEW_FRAC)
157
158 #define SM_FOR_ALL_FLAGGED_TRIS(m,i,w,b) for(i=smNext_tri_flag_set(m,0,w,b); \
159 i < SM_TRI_CNT(m); i=smNext_tri_flag_set(m,i+1,w,b))
160
161 #define SM_FOR_ALL_ACTIVE_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,0)
162 #define SM_FOR_ALL_NEW_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_NEW_FLAG,0)
163 #define SM_FOR_ALL_BASE_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_BASE_FLAG,0)
164 #define SM_FOR_ALL_VALID_TRIS(m,i) for(i=smNext_valid_tri(m,0); \
165 i < SM_TRI_CNT(m); i=smNext_valid_tri(m,i+1))
166
167 #define SM_FOR_ALL_ACTIVE_FG_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,1)
168
169 #define SM_FOR_ALL_ACTIVE_BG_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,2)
170
171
172 #define SM_FOR_ALL_ADJACENT_TRIS(sm,id,t) for(t=smTri_next_ccw_nbr(sm,t,id); \
173 t!=SM_NTH_TRI(sm,SM_NTH_VERT(sm,id)); t=smTri_next_ccw_nbr(sm,t,id))
174
175 #define SM_INVALID_SAMP_ID(sm,id) (((id) < 0) || ((id) >= SM_MAX_SAMP(sm)))
176 #define SM_INVALID_POINT_ID(sm,id) (((id) < 0) || ((id) >= SM_MAX_AUX_PT(sm)))
177 #define SM_T_CENTROID(sm,t,c) tri_centroid(SM_NTH_WV(sm,T_NTH_V(t,0)),SM_NTH_WV(sm,T_NTH_V(t,1)),SM_NTH_WV(sm,T_NTH_V(t,2)),c)
178 #define SM_T_NTH_WV(sm,t,i) (SM_NTH_WV(sm,T_NTH_V(t,i)))
179
180 #define SM_BASE_ID(s,i) \
181 ((i) >= RS_MAX_SAMP(SM_SAMP(s)) && (i) < RS_MAX_AUX_PT(SM_SAMP(s)))
182
183 #define SM_BG_SAMPLE(sm,i) (SM_NTH_W_DIR(sm,i)==-1)
184
185 #define SM_BG_TRI(sm,i) (SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),0)) && \
186 SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),1)) && \
187 SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),2)))
188 #define SM_MIXED_TRI(sm,i) (SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),0)) || \
189 SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),1)) || \
190 SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),2)))
191
192 #define SM_FOR_ALL_SAMPLES(sm,i) for((i)=0;i < SM_NUM_SAMP(sm);(i)++)
193
194 typedef struct _T_DEPTH {
195 int tri;
196 double depth;
197 }T_DEPTH;
198
199
200 extern SM *smMesh;
201 extern int smNew_tri_cnt;
202 extern double smDist_sum;
203
204 #ifdef TEST_DRIVER
205 extern VIEW View;
206 extern VIEW Current_View;
207 extern int Pick_tri,Picking,Pick_samp;
208 extern FVECT Pick_point[500],Pick_origin,Pick_dir;
209 extern FVECT Pick_v0[500],Pick_v1[500],Pick_v2[500];
210 extern FVECT P0,P1,P2;
211 extern int Pick_cnt;
212 extern FVECT FrustumNear[4],FrustumFar[4];
213 #endif
214
215 #ifdef DEBUG
216 extern int Malloc_cnt;
217 #endif
218 #endif
219
220
221
222
223
224
225
226
