--- ray/src/hd/sm.h 1998/10/06 18:16:54 3.4 +++ ray/src/hd/sm.h 2003/06/20 00:25:49 3.12 @@ -1,15 +1,14 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - -/* SCCSid "$SunId$ SGI" */ - +/* RCSid: $Id: sm.h,v 3.12 2003/06/20 00:25:49 greg Exp $ */ /* * sm.h */ #ifndef _SM_H_ #define _SM_H_ - #include "rhd_sample.h" +#include "sm_qtree.h" +#include "sm_stree.h" +#define NEWSETS #ifndef TRUE @@ -17,24 +16,49 @@ #define FALSE 0 #endif -#define S_REPLACE_EPS 0.06 -#define S_REPLACE_SCALE 10.0 -#define SQRT3_2 0.8660254 +#define ON_V 1 +#define ON_P 2 +#define ON_E 3 +#define IN_T 4 +#ifdef SMLFLT +#define VERT_EPS 2e-3 /* min edge length in radians */ +#define COS_VERT_EPS 0.999998 /* cos min edge length in radians */ +#define EDGE_EPS 2e-5 /* min distance until considered "on-edge"*/ +#define COLINEAR_EPS 1e-10 /* min sine of between edges angle :amount off PI */ +#else +#define VERT_EPS 5e-4 /* min edge length in radians */ +#define COS_VERT_EPS 0.999999875 /* cos min edge length in radians */ +#define EDGE_EPS 2e-7 /* min distance until considered "on-edge"*/ +#define COLINEAR_EPS 1e-10 /* min sine of between edges angle :amount off PI*/ +#endif + +#define EV_EPS EDGE_EPS /* Minimum edge-vertex distance */ + + +#define S_REPLACE_SCALE (5.*5.) /* if (distance to new point squared) is + > (triangle edge length squared*S_REPLACE_SCALE):for all edges/ + triangle vertices: new point is puncture point: dont add*/ +#define S_REPLACE_TRI 2e-8 /* .052 radians to the sixth power */ + + + #define SM_DEFAULT 0 -#define SM_EXTRA_POINTS 8 -#define SM_EXTRA_VERTS SM_EXTRA_POINTS +#define SM_BASE_POINTS 162 +#define SM_BASE_TRIS 320 +#define SM_BASE_VERTS SM_BASE_POINTS -#define SM_INC_PERCENT 0.60 #define SM_VIEW_FRAC 0.1 +#define SM_ALL_LEVELS -1 + typedef int VERT; /* One triangle that vertex belongs to- the rest are derived by traversing neighbors */ typedef struct _EDGE { - int verts[2]; + S_ID verts[2]; int tris[2]; } EDGE; @@ -44,14 +68,14 @@ typedef struct _EDGE { #define E_NTH_TRI(e,i) ((e>0)?Edges[(e)].tris[(i)]:Edges[-(e)].tris[(1-i)]) #define SET_E_NTH_TRI(e,i,v) if(e>0) Edges[(e)].tris[(i)]=(v); \ else Edges[-(e)].tris[(1-i)]=(v) -#define eClear_edges() (Ecnt = 0) +#define eClear_edges() (Ecnt = 0,free(Edges),Edges=NULL) #define FOR_ALL_EDGES(i) for((i)=1; (i) <= Ecnt; i++) -#define FOR_ALL_EDGES_FROM(e,i) for((i)=++e; (i) <= Ecnt; i++) +#define FOR_ALL_EDGES_FROM(e,i) for((i)=e+1; (i) <= Ecnt; i++) typedef struct _TRI { - int verts[3]; /* Ids into sample and vertex array for each vertex*/ + S_ID verts[3]; /* Ids into sample and vertex array for each vertex*/ int nbrs[3]; /* Ids for neighboring triangles: -1 if invalid */ }TRI; @@ -66,7 +90,7 @@ typedef struct _TRI { #define T_NEXT_FREE(t) ((t)->nbrs[0]) #define T_VALID_FLAG(t) ((t)->nbrs[1]) #define T_IS_VALID(t) (T_VALID_FLAG(t)!=-1) -#define T_FLAGS 3 +#define T_FLAGS 4 typedef struct _SM { FVECT view_center; /* Canonical view center defining unit sphere */ @@ -74,12 +98,10 @@ typedef struct _SM { STREE locator; /* spherical quadtree for point/triangle location */ int max_tris; /* Maximum number of triangles */ int num_tri; /* Current number of triangles */ - int sample_tris; /* Current number of non-base triangles*/ int free_tris; /* pointer to free_list */ int max_verts; /* Maximum number of vertices in the mesh */ TRI *tris; /* Pointer to list of triangle structs */ - VERT *verts; /* List of vertices */ - int4 *flags[T_FLAGS]; /* Bit 0 set if active(in current frustum) */ + int32 *flags[T_FLAGS]; /* Bit 0 set if active(in current frustum) */ /* Bit 1 set if not rendered since created */ /* Bit 2 set if base triangle */ }SM; @@ -87,17 +109,16 @@ typedef struct _SM { #define T_ACTIVE_FLAG 0 #define T_NEW_FLAG 1 #define T_BASE_FLAG 2 +#define T_BG_FLAG 3 #define SM_VIEW_CENTER(m) ((m)->view_center) #define SM_SAMP(m) ((m)->samples) #define SM_LOCATOR(m) (&((m)->locator)) #define SM_MAX_TRIS(m) ((m)->max_tris) #define SM_NUM_TRI(m) ((m)->num_tri) -#define SM_SAMPLE_TRIS(m) ((m)->sample_tris) #define SM_FREE_TRIS(m) ((m)->free_tris) #define SM_MAX_VERTS(m) ((m)->max_verts) #define SM_TRIS(m) ((m)->tris) -#define SM_VERTS(m) ((m)->verts) #define SM_NTH_FLAGS(m,n) ((m)->flags[(n)]) #define SM_FLAGS(m) ((m)->flags) @@ -109,26 +130,33 @@ typedef struct _SM { #define SM_IS_NTH_T_ACTIVE(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG) #define SM_IS_NTH_T_BASE(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_BASE_FLAG) #define SM_IS_NTH_T_NEW(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_NEW_FLAG) +#define SM_IS_NTH_T_BG(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_BG_FLAG) #define SM_SET_NTH_T_ACTIVE(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG) #define SM_SET_NTH_T_BASE(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_BASE_FLAG) #define SM_SET_NTH_T_NEW(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_NEW_FLAG) +#define SM_SET_NTH_T_BG(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_BG_FLAG) #define SM_CLR_NTH_T_ACTIVE(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG) #define SM_CLR_NTH_T_BASE(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_BASE_FLAG) #define SM_CLR_NTH_T_NEW(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_NEW_FLAG) +#define SM_CLR_NTH_T_BG(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_BG_FLAG) #define SM_NTH_TRI(m,n) (&(SM_TRIS(m)[(n)])) -#define SM_NTH_VERT(m,n) (SM_VERTS(m)[(n)]) +#define SM_NTH_VERT(m,n) S_NTH_INFO(SM_SAMP(m),n) + +#define SM_T_ID_VALID(s,t_id) T_IS_VALID(SM_NTH_TRI(s,t_id)) + #define SM_MAX_SAMP(m) S_MAX_SAMP(SM_SAMP(m)) #define SM_MAX_POINTS(m) S_MAX_POINTS(SM_SAMP(m)) #define SM_SAMP_BASE(m) S_BASE(SM_SAMP(m)) #define SM_NTH_WV(m,i) S_NTH_W_PT(SM_SAMP(m),i) #define SM_NTH_W_DIR(m,i) S_NTH_W_DIR(SM_SAMP(m),i) -#define SM_DIR_ID(m,i) (SM_NTH_W_DIR(m,i)==-1) +#define SM_DIR_ID(m,i) (!SM_BASE_ID(m,i) && SM_NTH_W_DIR(m,i)==-1) #define SM_NTH_RGB(m,i) S_NTH_RGB(SM_SAMP(m),i) #define SM_RGB(m) S_RGB(SM_SAMP(m)) +#define SM_WP(m) S_W_PT(SM_SAMP(m)) #define SM_BRT(m) S_BRT(SM_SAMP(m)) #define SM_NTH_BRT(m,i) S_NTH_BRT(SM_SAMP(m),i) #define SM_CHR(m) S_CHR(SM_SAMP(m)) @@ -138,20 +166,6 @@ typedef struct _SM { #define SM_ALLOWED_VIEW_CHANGE(m) (SM_NUM_SAMP(m)/smDist_sum*SM_VIEW_FRAC) -#define SM_FOR_ALL_FLAGGED_TRIS(m,i,w,b) for(i=smNext_tri_flag_set(m,0,w,b); \ -i < SM_NUM_TRI(m); i=smNext_tri_flag_set(m,i+1,w,b)) - -#define SM_FOR_ALL_ACTIVE_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,0) -#define SM_FOR_ALL_NEW_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_NEW_FLAG,0) -#define SM_FOR_ALL_BASE_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_BASE_FLAG,0) -#define SM_FOR_ALL_VALID_TRIS(m,i) for(i=smNext_valid_tri(m,0); \ -i < SM_NUM_TRI(m); i=smNext_valid_tri(m,i+1)) - -#define SM_FOR_ALL_ACTIVE_FG_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,1) - -#define SM_FOR_ALL_ACTIVE_BG_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,2) - - #define SM_FOR_ALL_ADJACENT_TRIS(sm,id,t) for(t=smTri_next_ccw_nbr(sm,t,id); \ t!=SM_NTH_TRI(sm,SM_NTH_VERT(sm,id)); t=smTri_next_ccw_nbr(sm,t,id)) @@ -173,41 +187,42 @@ t!=SM_NTH_TRI(sm,SM_NTH_VERT(sm,id)); t=smTri_next_ccw #define SM_FOR_ALL_SAMPLES(sm,i) for((i)=0;i < SM_NUM_SAMP(sm);(i)++) -#define smInit_locator(sm,c) (stInit(SM_LOCATOR(sm)), \ - ST_SET_CENTER(SM_LOCATOR(sm),c)) -#define smClear_locator(sm) stClear(SM_LOCATOR(sm)) +#define SM_FOR_ALL_VALID_TRIS(m,i) for((i)=0,(i)=smNext_valid_tri(m,i);(i)< \ +SM_NUM_TRI(m); (i)++,(i)= smNext_valid_tri(m,i)) + +#define SM_FOR_ALL_FLAGGED_TRIS(m,i,w,b) for(i=0,i=smNext_tri_flag_set(m,i,w,b);i < SM_NUM_TRI(m);i++,i=smNext_tri_flag_set(m,i,w,b)) +#define SM_FOR_ALL_ACTIVE_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,0) +#define smInit_locator(sm) stInit(SM_LOCATOR(sm)) #define smAlloc_locator(sm) stAlloc(SM_LOCATOR(sm)) -#define smFree_locator(sm) stClear(SM_LOCATOR(sm)) -#define smPointLocateCell(sm,pt) stPoint_locate(SM_LOCATOR(sm),pt) +#define smFree_locator(sm) stFree(SM_LOCATOR(sm)) #define smUnalloc_samp(sm,id) sUnalloc_samp(SM_SAMP(sm),id) +#define smPoint_locate_cell(sm,pt) stPoint_locate(SM_LOCATOR(sm),pt) #define smFree_samples(sm) sFree(SM_SAMP(sm)) -#define smClear_samples(sm) sClear(SM_SAMP(sm)) #define smInit_samples(sm) sInit(SM_SAMP(sm)) - +#define SM_S_NTH_QT(sm,s_id) S_NTH_INFO1(SM_SAMP(sm),s_id) #define smClear_vert(sm,id) (SM_NTH_VERT(sm,id) = INVALID) -#define SQRT3_INV 0.5773502692 +#define freebuf(b) tempbuf(-1) -typedef struct _T_DEPTH { - int tri; - double depth; -}T_DEPTH; - typedef struct _RT_ARGS_{ FVECT orig,dir; int t_id; - OBJECT *os; + S_ID *os; }RT_ARGS; +typedef struct _S_ARGS_{ + S_ID s_id; + S_ID n_id; +}S_ARGS; + typedef struct _ADD_ARGS { int t_id; - OBJECT *del_set; + S_ID *del_set; }ADD_ARGS; extern SM *smMesh; -extern int smNew_tri_cnt; extern double smDist_sum; @@ -217,6 +232,7 @@ extern VIEW Current_View; extern int Pick_tri,Picking,Pick_samp; extern FVECT Pick_point[500],Pick_origin,Pick_dir; extern FVECT Pick_v0[500],Pick_v1[500],Pick_v2[500]; +extern int Pick_q[500]; extern FVECT P0,P1,P2; extern int Pick_cnt; extern FVECT FrustumNear[4],FrustumFar[4]; @@ -248,25 +264,7 @@ extern FVECT FrustumNear[4],FrustumFar[4]; * * Find the closest sample to the given ray. Return -1 on failure. * - * - * smClean() : display has been wiped clean - * - * Called after display has been effectively cleared, meaning that all - * geometry must be resent down the pipeline in the next call to smUpdate(). - * - * - * smUpdate(vp, qua) : update OpenGL output geometry for view vp - * VIEW *vp; : desired view - * int qua; : quality level (percentage on linear time scale) - * - * Draw new geometric representation using OpenGL calls. Assume that the - * view has already been set up and the correct frame buffer has been - * selected for drawing. The quality level is on a linear scale, where 100% - * is full (final) quality. It is not necessary to redraw geometry that has - * been output since the last call to smClean(). (The last view drawn will - * be vp==&odev.v each time.) */ - #endif
