--- ray/src/hd/sm.h 1999/03/05 16:33:17 3.9 +++ ray/src/hd/sm.h 1999/06/10 15:22:22 3.10 @@ -8,8 +8,9 @@ #ifndef _SM_H_ #define _SM_H_ - #include "rhd_sample.h" +#include "sm_qtree.h" +#include "sm_stree.h" #define NEWSETS @@ -24,31 +25,39 @@ #define ON_E 3 #define IN_T 4 -#define S_REPLACE_EPS 0.04 /* if (distance on sphere between sample - and a base point) < S_REPLACE_EPS, - replace base: - */ +#ifndef LOWRES +#define VERT_EPS 5e-4 /* min edge length in radians */ +#define COS_VERT_EPS 0.999999875 /* cos min edge length in radians */ +#define EDGE_EPS 2e-7 /* min distance until considered "on-edge"*/ +#define COLINEAR_EPS 1e-10 /* minimum sine of between edges angle :amount off + 180degrees + */ +#define EQUALITY_EPS 1e-10 +#else +#define VERT_EPS 2e-3 /* min edge length in radians */ +#define COS_VERT_EPS 0.999998 /* cos min edge length in radians */ +#define EDGE_EPS 2e-5 /* min distance until considered "on-edge"*/ +#define COLINEAR_EPS 1e-10 /* minimum sine of between edges angle :amount off + 180degrees + */ +#define EQUALITY_EPS 1e-10 +#endif + +#define EV_EPS EDGE_EPS /* Minimum edge-vertex distance */ + + #define S_REPLACE_SCALE (5.*5.) /* if (distance to new point squared) is - > (triangle edge length squared* - S_REPLACE_SCALE):for all edges/triangle - vertices: new point is puncture - point: dont add - */ -#define S_REPLACE_TRI 2e-8 /* .052 radians to the sixth power */ + > (triangle edge length squared*S_REPLACE_SCALE):for all edges/ + triangle vertices: new point is puncture point: dont add*/ +#define S_REPLACE_TRI 2e-8 /* .052 radians to the sixth power */ -#define SQRT3_2 0.8660254 + #define SM_DEFAULT 0 -#define SM_EXTRA_POINTS 162 +#define SM_BASE_POINTS 162 #define SM_BASE_TRIS 320 -#define SM_EXTRA_VERTS SM_EXTRA_POINTS +#define SM_BASE_VERTS SM_BASE_POINTS -#define SM_INC_PERCENT 0.60 /* If number of new triangles added - since last full redraw is > - (SM_INC_PERCENT * total triangles) - do full redraw instead of incremental - */ - #define SM_VIEW_FRAC 0.1 #define SM_ALL_LEVELS -1 @@ -68,10 +77,10 @@ typedef struct _EDGE { #define E_NTH_TRI(e,i) ((e>0)?Edges[(e)].tris[(i)]:Edges[-(e)].tris[(1-i)]) #define SET_E_NTH_TRI(e,i,v) if(e>0) Edges[(e)].tris[(i)]=(v); \ else Edges[-(e)].tris[(1-i)]=(v) -#define eClear_edges() (Ecnt = 0) +#define eClear_edges() (Ecnt = 0,free(Edges),Edges=NULL) #define FOR_ALL_EDGES(i) for((i)=1; (i) <= Ecnt; i++) -#define FOR_ALL_EDGES_FROM(e,i) for((i)=++e; (i) <= Ecnt; i++) +#define FOR_ALL_EDGES_FROM(e,i) for((i)=e+1; (i) <= Ecnt; i++) typedef struct _TRI { @@ -88,7 +97,6 @@ typedef struct _TRI { #define T_WHICH_V(t,i) \ (T_NTH_V(t,0)==(i)?0:T_NTH_V(t,1)==(i)?1:T_NTH_V(t,2)==(i)?2:-1) #define T_NEXT_FREE(t) ((t)->nbrs[0]) -#define T_NEXT_AVAILABLE(t) ((t)->nbrs[0]) #define T_VALID_FLAG(t) ((t)->nbrs[1]) #define T_IS_VALID(t) (T_VALID_FLAG(t)!=-1) #define T_FLAGS 4 @@ -99,12 +107,9 @@ typedef struct _SM { STREE locator; /* spherical quadtree for point/triangle location */ int max_tris; /* Maximum number of triangles */ int num_tri; /* Current number of triangles */ - int sample_tris; /* Current number of non-base triangles*/ int free_tris; /* pointer to free_list */ - int available_tris; /* pointer to available_list */ int max_verts; /* Maximum number of vertices in the mesh */ TRI *tris; /* Pointer to list of triangle structs */ - VERT *verts; /* List of vertices */ int4 *flags[T_FLAGS]; /* Bit 0 set if active(in current frustum) */ /* Bit 1 set if not rendered since created */ /* Bit 2 set if base triangle */ @@ -120,12 +125,9 @@ typedef struct _SM { #define SM_LOCATOR(m) (&((m)->locator)) #define SM_MAX_TRIS(m) ((m)->max_tris) #define SM_NUM_TRI(m) ((m)->num_tri) -#define SM_SAMPLE_TRIS(m) ((m)->sample_tris) #define SM_FREE_TRIS(m) ((m)->free_tris) -#define SM_AVAILABLE_TRIS(m) ((m)->available_tris) #define SM_MAX_VERTS(m) ((m)->max_verts) #define SM_TRIS(m) ((m)->tris) -#define SM_VERTS(m) ((m)->verts) #define SM_NTH_FLAGS(m,n) ((m)->flags[(n)]) #define SM_FLAGS(m) ((m)->flags) @@ -150,7 +152,7 @@ typedef struct _SM { #define SM_CLR_NTH_T_BG(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_BG_FLAG) #define SM_NTH_TRI(m,n) (&(SM_TRIS(m)[(n)])) -#define SM_NTH_VERT(m,n) (SM_VERTS(m)[(n)]) +#define SM_NTH_VERT(m,n) S_NTH_INFO(SM_SAMP(m),n) #define SM_T_ID_VALID(s,t_id) T_IS_VALID(SM_NTH_TRI(s,t_id)) @@ -194,34 +196,41 @@ t!=SM_NTH_TRI(sm,SM_NTH_VERT(sm,id)); t=smTri_next_ccw #define SM_FOR_ALL_SAMPLES(sm,i) for((i)=0;i < SM_NUM_SAMP(sm);(i)++) -#define smInit_locator(sm,c) (stInit(SM_LOCATOR(sm)), \ - ST_SET_CENTER(SM_LOCATOR(sm),c)) -#define smClear_locator(sm) stClear(SM_LOCATOR(sm)) +#define SM_FOR_ALL_VALID_TRIS(m,i) for((i)=0,(i)=smNext_valid_tri(m,i);(i)< \ +SM_NUM_TRI(m); (i)++,(i)= smNext_valid_tri(m,i)) + +#define SM_FOR_ALL_FLAGGED_TRIS(m,i,w,b) for(i=0,i=smNext_tri_flag_set(m,i,w,b);i < SM_NUM_TRI(m);i++,i=smNext_tri_flag_set(m,i,w,b)) +#define SM_FOR_ALL_ACTIVE_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,0) +#define smInit_locator(sm) stInit(SM_LOCATOR(sm)) #define smAlloc_locator(sm) stAlloc(SM_LOCATOR(sm)) -#define smFree_locator(sm) stClear(SM_LOCATOR(sm)) -#define smPointLocateCell(sm,pt) stPoint_locate(SM_LOCATOR(sm),pt) +#define smFree_locator(sm) stFree(SM_LOCATOR(sm)) #define smUnalloc_samp(sm,id) sUnalloc_samp(SM_SAMP(sm),id) +#define smPoint_locate_cell(sm,pt) stPoint_locate(SM_LOCATOR(sm),pt) #define smFree_samples(sm) sFree(SM_SAMP(sm)) -#define smClear_samples(sm) sClear(SM_SAMP(sm)) #define smInit_samples(sm) sInit(SM_SAMP(sm)) - +#define SM_S_NTH_QT(sm,s_id) S_NTH_INFO1(SM_SAMP(sm),s_id) #define smClear_vert(sm,id) (SM_NTH_VERT(sm,id) = INVALID) +#define freebuf(b) tempbuf(-1) + typedef struct _RT_ARGS_{ FVECT orig,dir; int t_id; OBJECT *os; }RT_ARGS; +typedef struct _S_ARGS_{ + int s_id,n_id; +}S_ARGS; + typedef struct _ADD_ARGS { int t_id; OBJECT *del_set; }ADD_ARGS; extern SM *smMesh; -extern int smNew_tri_cnt; extern double smDist_sum;
