--- ray/src/hd/sm.h 1999/06/10 15:22:22 3.10 +++ ray/src/hd/sm.h 2003/06/20 00:25:49 3.12 @@ -1,7 +1,4 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - -/* SCCSid "$SunId$ SGI" */ - +/* RCSid: $Id: sm.h,v 3.12 2003/06/20 00:25:49 greg Exp $ */ /* * sm.h */ @@ -25,22 +22,16 @@ #define ON_E 3 #define IN_T 4 -#ifndef LOWRES -#define VERT_EPS 5e-4 /* min edge length in radians */ -#define COS_VERT_EPS 0.999999875 /* cos min edge length in radians */ -#define EDGE_EPS 2e-7 /* min distance until considered "on-edge"*/ -#define COLINEAR_EPS 1e-10 /* minimum sine of between edges angle :amount off - 180degrees - */ -#define EQUALITY_EPS 1e-10 -#else +#ifdef SMLFLT #define VERT_EPS 2e-3 /* min edge length in radians */ #define COS_VERT_EPS 0.999998 /* cos min edge length in radians */ #define EDGE_EPS 2e-5 /* min distance until considered "on-edge"*/ -#define COLINEAR_EPS 1e-10 /* minimum sine of between edges angle :amount off - 180degrees - */ -#define EQUALITY_EPS 1e-10 +#define COLINEAR_EPS 1e-10 /* min sine of between edges angle :amount off PI */ +#else +#define VERT_EPS 5e-4 /* min edge length in radians */ +#define COS_VERT_EPS 0.999999875 /* cos min edge length in radians */ +#define EDGE_EPS 2e-7 /* min distance until considered "on-edge"*/ +#define COLINEAR_EPS 1e-10 /* min sine of between edges angle :amount off PI*/ #endif #define EV_EPS EDGE_EPS /* Minimum edge-vertex distance */ @@ -67,7 +58,7 @@ typedef int VERT; /* One triangle that vertex belongs are derived by traversing neighbors */ typedef struct _EDGE { - int verts[2]; + S_ID verts[2]; int tris[2]; } EDGE; @@ -84,7 +75,7 @@ typedef struct _EDGE { typedef struct _TRI { - int verts[3]; /* Ids into sample and vertex array for each vertex*/ + S_ID verts[3]; /* Ids into sample and vertex array for each vertex*/ int nbrs[3]; /* Ids for neighboring triangles: -1 if invalid */ }TRI; @@ -110,7 +101,7 @@ typedef struct _SM { int free_tris; /* pointer to free_list */ int max_verts; /* Maximum number of vertices in the mesh */ TRI *tris; /* Pointer to list of triangle structs */ - int4 *flags[T_FLAGS]; /* Bit 0 set if active(in current frustum) */ + int32 *flags[T_FLAGS]; /* Bit 0 set if active(in current frustum) */ /* Bit 1 set if not rendered since created */ /* Bit 2 set if base triangle */ }SM; @@ -217,17 +208,18 @@ SM_NUM_TRI(m); (i)++,(i)= smNext_valid_tri(m,i)) typedef struct _RT_ARGS_{ FVECT orig,dir; int t_id; - OBJECT *os; + S_ID *os; }RT_ARGS; typedef struct _S_ARGS_{ - int s_id,n_id; + S_ID s_id; + S_ID n_id; }S_ARGS; typedef struct _ADD_ARGS { int t_id; - OBJECT *del_set; + S_ID *del_set; }ADD_ARGS; extern SM *smMesh; @@ -272,23 +264,6 @@ extern FVECT FrustumNear[4],FrustumFar[4]; * * Find the closest sample to the given ray. Return -1 on failure. * - * - * smClean() : display has been wiped clean - * - * Called after display has been effectively cleared, meaning that all - * geometry must be resent down the pipeline in the next call to smUpdate(). - * - * - * smUpdate(vp, qua) : update OpenGL output geometry for view vp - * VIEW *vp; : desired view - * int qua; : quality level (percentage on linear time scale) - * - * Draw new geometric representation using OpenGL calls. Assume that the - * view has already been set up and the correct frame buffer has been - * selected for drawing. The quality level is on a linear scale, where 100% - * is full (final) quality. It is not necessary to redraw geometry that has - * been output since the last call to smClean(). (The last view drawn will - * be vp==&odev.v each time.) */ #endif
