| 1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */
| 2 |
| 3 |
/* SCCSid "$SunId$ SGI" */
| 4 |
| 5 |
| 6 |
* sm.h
| 7 |
| 8 |
| 9 |
#ifndef _SM_H_
| 10 |
#define _SM_H_
| 11 |
| 12 |
#include "rhd_sample.h"
| 13 |
#include "sm_stree.h"
| 14 |
| 15 |
| 16 |
#ifndef TRUE
| 17 |
#define TRUE 1
| 18 |
#define FALSE 0
| 19 |
#endif
| 20 |
| 21 |
#define P_REPLACE_EPS 0.5
| 22 |
#define SQRT3_2 0.8660254
| 23 |
| 24 |
#define MAX_EDGES 200
| 25 |
| 26 |
#define SM_INVALID -1
| 27 |
#define SM_DEFAULT 0
| 28 |
#define SM_EXTRA_POINTS 5
| 29 |
#define SM_EXTRA_VERTS SM_EXTRA_POINTS
| 30 |
#define SM_POINTSIZ (3*sizeof(float)+ sizeof(int4))
| 31 |
#define SM_POINT_SPACE SM_EXTRA_POINTS * SM_POINTSIZ
| 32 |
| 33 |
#define SM_INC_PERCENT 0.60
| 34 |
#define SM_VIEW_FRAC 0.1
| 35 |
| 36 |
| 37 |
typedef int VERT; /* One triangle that vertex belongs to- the rest
| 38 |
are derived by traversing neighbors */
| 39 |
| 40 |
typedef struct _EDGE {
| 41 |
int verts[2];
| 42 |
int tris[2];
| 43 |
} EDGE;
| 44 |
#define E_NTH_VERT(e,i) ((e>0)?Edges[(e)].verts[(i)]:Edges[-(e)].verts[(1-i)])
| 45 |
#define SET_E_NTH_VERT(e,i,v) if(e>0) Edges[(e)].verts[(i)]=(v); \
| 46 |
else Edges[-(e)].verts[(1-i)]=(v)
| 47 |
#define E_NTH_TRI(e,i) ((e>0)?Edges[(e)].tris[(i)]:Edges[-(e)].tris[(1-i)])
| 48 |
#define SET_E_NTH_TRI(e,i,v) if(e>0) Edges[(e)].tris[(i)]=(v); \
| 49 |
else Edges[-(e)].tris[(1-i)]=(v)
| 50 |
#define eNew_edge() (((Ecnt) < MAX_EDGES)?(++Ecnt):SM_INVALID)
| 51 |
#define eClear_edges() (Ecnt = 0)
| 52 |
| 53 |
#define FOR_ALL_EDGES(i) for((i)=1; (i) <= Ecnt; i++)
| 54 |
#define FOR_ALL_EDGES_FROM(e,i) for((i)=++e; (i) <= Ecnt; i++)
| 55 |
| 56 |
| 57 |
typedef struct _TRI {
| 58 |
int verts[3]; /* Ids into sample and vertex array for each vertex*/
| 59 |
int nbrs[3]; /* Ids for neighboring triangles: -1 if invalid */
| 60 |
}TRI;
| 61 |
| 62 |
| 63 |
#define T_NTH_NBR(t,i) ((t)->nbrs[(i)])
| 64 |
#define T_CLEAR_NBRS(t) (T_NTH_NBR(t,0)=T_NTH_NBR(t,1)=T_NTH_NBR(t,2)=-1)
| 65 |
#define T_NTH_NBR_PTR(t,n) \
| 66 |
(T_NTH_NBR(n,0)==(t)?0:T_NTH_NBR(n,1)==(t)?1:T_NTH_NBR(n,2)==(t)?2:-1)
| 67 |
#define T_NTH_V(t,i) ((t)->verts[(i)])
| 68 |
#define T_WHICH_V(t,i) \
| 69 |
(T_NTH_V(t,0)==(i)?0:T_NTH_V(t,1)==(i)?1:T_NTH_V(t,2)==(i)?2:-1)
| 70 |
#define T_NEXT_FREE(t) ((t)->nbrs[0])
| 71 |
#define T_VALID_FLAG(t) ((t)->nbrs[1])
| 72 |
#define T_IS_VALID(t) (T_VALID_FLAG(t)!=-1)
| 73 |
#define T_FLAGS 4
| 74 |
#define T_FLAG_BYTES T_FLAGS/8.0
| 75 |
#define T_TOTAL_FLAG_BYTES(c) ((((c)+31)>>5)*sizeof(int4))
| 76 |
| 77 |
typedef struct _SM {
| 78 |
FVECT view_center; /* Canonical view center defining unit sphere */
| 79 |
RSAMP *samples; /* Sample point information */
| 80 |
STREE locator; /* spherical quadtree for point/triangle location */
| 81 |
int max_tris; /* Maximum number of triangles */
| 82 |
int tri_cnt; /* Total number of tris ever alloc at one time*/
| 83 |
int num_tris; /* Current number of sample (nonbase)triangles */
| 84 |
int free_tris; /* pointer to free_list */
| 85 |
int max_verts; /* Maximum number of vertices in the mesh */
| 86 |
TRI *tris; /* Pointer to list of triangle structs */
| 87 |
VERT *verts; /* List of vertices */
| 88 |
int4 *flags[T_FLAGS]; /* Bit 0 set if active(in current frustum) */
| 89 |
/* Bit 1 set if not rendered since created */
| 90 |
/* Bit 2 set if base triangle */
| 91 |
/* Bit 3 set used for LRU replacement */
| 92 |
char *base; /* Allocated space */
| 93 |
}SM;
| 94 |
| 95 |
#define T_ACTIVE_FLAG 0
| 96 |
#define T_NEW_FLAG 1
| 97 |
#define T_BASE_FLAG 2
| 98 |
#define T_LRU_FLAG 3
| 99 |
| 100 |
#define SM_VIEW_CENTER(m) ((m)->view_center)
| 101 |
#define SM_SAMP(m) ((m)->samples)
| 102 |
#define SM_LOCATOR(m) (&((m)->locator))
| 103 |
#define SM_MAX_TRIS(m) ((m)->max_tris)
| 104 |
#define SM_TRI_CNT(m) ((m)->tri_cnt)
| 105 |
#define SM_NUM_TRIS(m) ((m)->num_tris)
| 106 |
#define SM_FREE_TRIS(m) ((m)->free_tris)
| 107 |
#define SM_MAX_VERTS(m) ((m)->max_verts)
| 108 |
#define SM_TRIS(m) ((m)->tris)
| 109 |
#define SM_VERTS(m) ((m)->verts)
| 110 |
#define SM_NTH_FLAGS(m,n) ((m)->flags[(n)])
| 111 |
#define SM_BASE(m) ((m)->base)
| 112 |
| 113 |
#define TF_OFFSET(n) ((n) >> 5)
| 114 |
#define TF_BIT(n) ((n) & 0x1f)
| 115 |
#define SM_IS_NTH_T_FLAG(sm,n,f) (SM_NTH_FLAGS(sm,f)[TF_OFFSET(n)] & (0x1 <<TF_BIT(n)))
| 116 |
#define SM_SET_NTH_T_FLAG(sm,n,f) (SM_NTH_FLAGS(sm,f)[TF_OFFSET(n)] |= (0x1<<TF_BIT(n)))
| 117 |
#define SM_CLEAR_NTH_T_FLAG(sm,n,f) (SM_NTH_FLAGS(sm,f)[TF_OFFSET(n)] &= ~(0x1<<TF_BIT(n)))
| 118 |
| 119 |
#define SM_IS_NTH_T_ACTIVE(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG)
| 120 |
#define SM_IS_NTH_T_BASE(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_BASE_FLAG)
| 121 |
#define SM_IS_NTH_T_NEW(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_NEW_FLAG)
| 122 |
#define SM_IS_NTH_T_LRU(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_LRU_FLAG)
| 123 |
| 124 |
#define SM_SET_NTH_T_ACTIVE(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG)
| 125 |
#define SM_SET_NTH_T_BASE(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_BASE_FLAG)
| 126 |
#define SM_SET_NTH_T_NEW(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_NEW_FLAG)
| 127 |
#define SM_SET_NTH_T_LRU(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_LRU_FLAG)
| 128 |
| 129 |
#define SM_CLEAR_NTH_T_ACTIVE(sm,n) SM_CLEAR_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG)
| 130 |
#define SM_CLEAR_NTH_T_BASE(sm,n) SM_CLEAR_NTH_T_FLAG(sm,n,T_BASE_FLAG)
| 131 |
#define SM_CLEAR_NTH_T_NEW(sm,n) SM_CLEAR_NTH_T_FLAG(sm,n,T_NEW_FLAG)
| 132 |
#define SM_CLEAR_NTH_T_LRU(sm,n) SM_CLEAR_NTH_T_FLAG(sm,n,T_LRU_FLAG)
| 133 |
| 134 |
#define SM_NTH_TRI(m,n) (&(SM_TRIS(m)[(n)]))
| 135 |
#define SM_NTH_VERT(m,n) (SM_VERTS(m)[(n)])
| 136 |
#define SM_FREE_TRI_ID(m,n) (n = SM_FREE_TRIS(m)==-1? \
| 137 |
(SM_TRI_CNT(m)<SM_MAX_TRIS(m)?SM_TRI_CNT(m)++:-1):(n=SM_FREE_TRIS(m), \
| 138 |
SM_FREE_TRIS(m)=T_NEXT_FREE(SM_NTH_TRI(m,SM_FREE_TRIS(m))),n))
| 139 |
| 140 |
#define SM_SAMP_BASE(m) RS_BASE(SM_SAMP(m))
| 141 |
#define SM_SAMP_FREE(m) RS_FREE(SM_SAMP(m))
| 142 |
#define SM_SAMP_EOL(m) RS_EOL(SM_SAMP(m))
| 143 |
#define SM_MAX_SAMP(m) RS_MAX_SAMP(SM_SAMP(m))
| 144 |
#define SM_MAX_AUX_PT(m) RS_MAX_AUX_PT(SM_SAMP(m))
| 145 |
#define SM_NTH_WV(m,i) RS_NTH_W_PT(SM_SAMP(m),i)
| 146 |
#define SM_NTH_W_DIR(m,i) RS_NTH_W_DIR(SM_SAMP(m),i)
| 147 |
#define SM_NTH_RGB(m,i) RS_NTH_RGB(SM_SAMP(m),i)
| 148 |
#define SM_RGB(m) RS_RGB(SM_SAMP(m))
| 149 |
#define SM_BRT(m) RS_BRT(SM_SAMP(m))
| 150 |
#define SM_NTH_BRT(m,i) RS_NTH_BRT(SM_SAMP(m),i)
| 151 |
#define SM_CHR(m) RS_CHR(SM_SAMP(m))
| 152 |
#define SM_NTH_CHR(m,i) RS_NTH_CHR(SM_SAMP(m),i)
| 153 |
#define SM_NUM_SAMP(m) RS_NUM_SAMP(SM_SAMP(m))
| 154 |
#define SM_TONE_MAP(m) RS_TONE_MAP(SM_SAMP(m))
| 155 |
| 156 |
#define SM_ALLOWED_VIEW_CHANGE(m) (SM_NUM_SAMP(m)/smDist_sum*SM_VIEW_FRAC)
| 157 |
| 158 |
#define SM_FOR_ALL_FLAGGED_TRIS(m,i,w,b) for(i=smNext_tri_flag_set(m,0,w,b); \
| 159 |
i < SM_TRI_CNT(m); i=smNext_tri_flag_set(m,i+1,w,b))
| 160 |
| 161 |
#define SM_FOR_ALL_ACTIVE_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,0)
| 162 |
#define SM_FOR_ALL_NEW_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_NEW_FLAG,0)
| 163 |
#define SM_FOR_ALL_BASE_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_BASE_FLAG,0)
| 164 |
#define SM_FOR_ALL_VALID_TRIS(m,i) for(i=smNext_valid_tri(m,0); \
| 165 |
i < SM_TRI_CNT(m); i=smNext_valid_tri(m,i+1))
| 166 |
| 167 |
#define SM_FOR_ALL_ACTIVE_FG_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,1)
| 168 |
| 169 |
#define SM_FOR_ALL_ACTIVE_BG_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,2)
| 170 |
| 171 |
| 172 |
#define SM_FOR_ALL_ADJACENT_TRIS(sm,id,t) for(t=smTri_next_ccw_nbr(sm,t,id); \
| 173 |
t!=SM_NTH_TRI(sm,SM_NTH_VERT(sm,id)); t=smTri_next_ccw_nbr(sm,t,id))
| 174 |
| 175 |
#define SM_INVALID_SAMP_ID(sm,id) (((id) < 0) || ((id) >= SM_MAX_SAMP(sm)))
| 176 |
#define SM_INVALID_POINT_ID(sm,id) (((id) < 0) || ((id) >= SM_MAX_AUX_PT(sm)))
| 177 |
#define SM_T_CENTROID(sm,t,c) tri_centroid(SM_NTH_WV(sm,T_NTH_V(t,0)),SM_NTH_WV(sm,T_NTH_V(t,1)),SM_NTH_WV(sm,T_NTH_V(t,2)),c)
| 178 |
#define SM_T_NTH_WV(sm,t,i) (SM_NTH_WV(sm,T_NTH_V(t,i)))
| 179 |
| 180 |
#define SM_BASE_ID(s,i) \
| 181 |
((i) >= RS_MAX_SAMP(SM_SAMP(s)) && (i) < RS_MAX_AUX_PT(SM_SAMP(s)))
| 182 |
| 183 |
#define SM_BG_SAMPLE(sm,i) (SM_NTH_W_DIR(sm,i)==-1)
| 184 |
| 185 |
#define SM_BG_TRI(sm,i) (SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),0)) && \
| 186 |
SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),1)) && \
| 187 |
SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),2)))
| 188 |
#define SM_MIXED_TRI(sm,i) (SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),0)) || \
| 189 |
SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),1)) || \
| 190 |
| 191 |
| 192 |
#define SM_FOR_ALL_SAMPLES(sm,i) for((i)=0;i < SM_NUM_SAMP(sm);(i)++)
| 193 |
| 194 |
typedef struct _T_DEPTH {
| 195 |
int tri;
| 196 |
double depth;
| 197 |
}T_DEPTH;
| 198 |
| 199 |
| 200 |
extern SM *smMesh;
| 201 |
extern int smNew_tri_cnt;
| 202 |
extern double smDist_sum;
| 203 |
| 204 |
#ifdef TEST_DRIVER
| 205 |
extern VIEW View;
| 206 |
extern VIEW Current_View;
| 207 |
extern int Pick_tri,Picking,Pick_samp;
| 208 |
extern FVECT Pick_point[500],Pick_origin,Pick_dir;
| 209 |
extern FVECT Pick_v0[500],Pick_v1[500],Pick_v2[500];
| 210 |
extern FVECT P0,P1,P2;
| 211 |
extern int Pick_cnt;
| 212 |
extern FVECT FrustumNear[4],FrustumFar[4];
| 213 |
#endif
| 214 |
| 215 |
#ifdef DEBUG
| 216 |
extern int Malloc_cnt;
| 217 |
#endif
| 218 |
#endif
| 219 |
| 220 |
| 221 |
| 222 |
| 223 |
| 224 |
| 225 |
| 226 |
