root/radiance/ray/src/hd/sm.h
Revision: 3.14
Committed: Fri Nov 5 03:31:37 2004 UTC (20 years, 7 months ago) by greg
Changes since 3.13: +1 -1 lines
State: FILE REMOVED
# User Rev Content
1 greg 3.14 /* RCSid: $Id: sm.h,v 3.13 2003/07/14 22:24:00 schorsch Exp $ */
2 gwlarson 3.1 /*
3     * sm.h
4     */
5
6 schorsch 3.13 #ifndef _RAD_SM_H_
7     #define _RAD_SM_H_
8
9 gwlarson 3.1 #include "rhd_sample.h"
10 gwlarson 3.10 #include "sm_qtree.h"
11     #include "sm_stree.h"
12 schorsch 3.13
13     #ifdef __cplusplus
14     extern "C" {
15     #endif
16
17 gwlarson 3.6 #define NEWSETS
18 gwlarson 3.1
19 gwlarson 3.2
20 gwlarson 3.1 #ifndef TRUE
21     #define TRUE 1
22     #define FALSE 0
23     #endif
24
25 gwlarson 3.6
26     #define ON_V 1
27     #define ON_P 2
28     #define ON_E 3
29     #define IN_T 4
30
31 greg 3.11 #ifdef SMLFLT
32     #define VERT_EPS 2e-3 /* min edge length in radians */
33     #define COS_VERT_EPS 0.999998 /* cos min edge length in radians */
34     #define EDGE_EPS 2e-5 /* min distance until considered "on-edge"*/
35     #define COLINEAR_EPS 1e-10 /* min sine of between edges angle :amount off PI */
36     #else
37 gwlarson 3.10 #define VERT_EPS 5e-4 /* min edge length in radians */
38     #define COS_VERT_EPS 0.999999875 /* cos min edge length in radians */
39     #define EDGE_EPS 2e-7 /* min distance until considered "on-edge"*/
40 greg 3.11 #define COLINEAR_EPS 1e-10 /* min sine of between edges angle :amount off PI*/
41 gwlarson 3.10 #endif
42
43     #define EV_EPS EDGE_EPS /* Minimum edge-vertex distance */
44
45
46 gwlarson 3.5 #define S_REPLACE_SCALE (5.*5.) /* if (distance to new point squared) is
47 gwlarson 3.10 > (triangle edge length squared*S_REPLACE_SCALE):for all edges/
48     triangle vertices: new point is puncture point: dont add*/
49     #define S_REPLACE_TRI 2e-8 /* .052 radians to the sixth power */
50 gwlarson 3.4
51 gwlarson 3.1
52 gwlarson 3.10
53 gwlarson 3.4 #define SM_DEFAULT 0
54 gwlarson 3.10 #define SM_BASE_POINTS 162
55 gwlarson 3.6 #define SM_BASE_TRIS 320
56 gwlarson 3.10 #define SM_BASE_VERTS SM_BASE_POINTS
57 gwlarson 3.1
58     #define SM_VIEW_FRAC 0.1
59
60 gwlarson 3.9 #define SM_ALL_LEVELS -1
61
62 gwlarson 3.1
63     typedef int VERT; /* One triangle that vertex belongs to- the rest
64     are derived by traversing neighbors */
65
66     typedef struct _EDGE {
67 greg 3.11 S_ID verts[2];
68 gwlarson 3.1 int tris[2];
69     } EDGE;
70 gwlarson 3.4
71 gwlarson 3.1 #define E_NTH_VERT(e,i) ((e>0)?Edges[(e)].verts[(i)]:Edges[-(e)].verts[(1-i)])
72     #define SET_E_NTH_VERT(e,i,v) if(e>0) Edges[(e)].verts[(i)]=(v); \
73     else Edges[-(e)].verts[(1-i)]=(v)
74     #define E_NTH_TRI(e,i) ((e>0)?Edges[(e)].tris[(i)]:Edges[-(e)].tris[(1-i)])
75     #define SET_E_NTH_TRI(e,i,v) if(e>0) Edges[(e)].tris[(i)]=(v); \
76     else Edges[-(e)].tris[(1-i)]=(v)
77 gwlarson 3.10 #define eClear_edges() (Ecnt = 0,free(Edges),Edges=NULL)
78 gwlarson 3.1
79     #define FOR_ALL_EDGES(i) for((i)=1; (i) <= Ecnt; i++)
80 gwlarson 3.10 #define FOR_ALL_EDGES_FROM(e,i) for((i)=e+1; (i) <= Ecnt; i++)
81 gwlarson 3.1
82
83     typedef struct _TRI {
84 greg 3.11 S_ID verts[3]; /* Ids into sample and vertex array for each vertex*/
85 gwlarson 3.1 int nbrs[3]; /* Ids for neighboring triangles: -1 if invalid */
86     }TRI;
87
88
89     #define T_NTH_NBR(t,i) ((t)->nbrs[(i)])
90     #define T_CLEAR_NBRS(t) (T_NTH_NBR(t,0)=T_NTH_NBR(t,1)=T_NTH_NBR(t,2)=-1)
91     #define T_NTH_NBR_PTR(t,n) \
92     (T_NTH_NBR(n,0)==(t)?0:T_NTH_NBR(n,1)==(t)?1:T_NTH_NBR(n,2)==(t)?2:-1)
93     #define T_NTH_V(t,i) ((t)->verts[(i)])
94     #define T_WHICH_V(t,i) \
95     (T_NTH_V(t,0)==(i)?0:T_NTH_V(t,1)==(i)?1:T_NTH_V(t,2)==(i)?2:-1)
96 gwlarson 3.3 #define T_NEXT_FREE(t) ((t)->nbrs[0])
97     #define T_VALID_FLAG(t) ((t)->nbrs[1])
98 gwlarson 3.1 #define T_IS_VALID(t) (T_VALID_FLAG(t)!=-1)
99 gwlarson 3.8 #define T_FLAGS 4
100 gwlarson 3.1
101     typedef struct _SM {
102     FVECT view_center; /* Canonical view center defining unit sphere */
103 gwlarson 3.4 SAMP *samples; /* Sample point information */
104     STREE locator; /* spherical quadtree for point/triangle location */
105 gwlarson 3.1 int max_tris; /* Maximum number of triangles */
106 gwlarson 3.4 int num_tri; /* Current number of triangles */
107 gwlarson 3.1 int free_tris; /* pointer to free_list */
108     int max_verts; /* Maximum number of vertices in the mesh */
109     TRI *tris; /* Pointer to list of triangle structs */
110 greg 3.12 int32 *flags[T_FLAGS]; /* Bit 0 set if active(in current frustum) */
111 gwlarson 3.4 /* Bit 1 set if not rendered since created */
112     /* Bit 2 set if base triangle */
113 gwlarson 3.1 }SM;
114
115     #define T_ACTIVE_FLAG 0
116     #define T_NEW_FLAG 1
117     #define T_BASE_FLAG 2
118 gwlarson 3.8 #define T_BG_FLAG 3
119 gwlarson 3.1
120     #define SM_VIEW_CENTER(m) ((m)->view_center)
121     #define SM_SAMP(m) ((m)->samples)
122     #define SM_LOCATOR(m) (&((m)->locator))
123     #define SM_MAX_TRIS(m) ((m)->max_tris)
124 gwlarson 3.4 #define SM_NUM_TRI(m) ((m)->num_tri)
125 gwlarson 3.1 #define SM_FREE_TRIS(m) ((m)->free_tris)
126     #define SM_MAX_VERTS(m) ((m)->max_verts)
127     #define SM_TRIS(m) ((m)->tris)
128     #define SM_NTH_FLAGS(m,n) ((m)->flags[(n)])
129 gwlarson 3.4 #define SM_FLAGS(m) ((m)->flags)
130 gwlarson 3.1
131
132 gwlarson 3.4 #define SM_IS_NTH_T_FLAG(sm,n,f) IS_FLAG(SM_NTH_FLAGS(sm,f),n)
133     #define SM_SET_NTH_T_FLAG(sm,n,f) SET_FLAG(SM_NTH_FLAGS(sm,f),n)
134     #define SM_CLR_NTH_T_FLAG(sm,n,f) CLR_FLAG(SM_NTH_FLAGS(sm,f),n)
135
136 gwlarson 3.1 #define SM_IS_NTH_T_ACTIVE(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG)
137     #define SM_IS_NTH_T_BASE(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_BASE_FLAG)
138     #define SM_IS_NTH_T_NEW(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_NEW_FLAG)
139 gwlarson 3.8 #define SM_IS_NTH_T_BG(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_BG_FLAG)
140 gwlarson 3.1
141     #define SM_SET_NTH_T_ACTIVE(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG)
142     #define SM_SET_NTH_T_BASE(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_BASE_FLAG)
143 gwlarson 3.4 #define SM_SET_NTH_T_NEW(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_NEW_FLAG)
144 gwlarson 3.8 #define SM_SET_NTH_T_BG(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_BG_FLAG)
145 gwlarson 3.1
146 gwlarson 3.4 #define SM_CLR_NTH_T_ACTIVE(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG)
147     #define SM_CLR_NTH_T_BASE(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_BASE_FLAG)
148     #define SM_CLR_NTH_T_NEW(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_NEW_FLAG)
149 gwlarson 3.8 #define SM_CLR_NTH_T_BG(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_BG_FLAG)
150 gwlarson 3.1
151     #define SM_NTH_TRI(m,n) (&(SM_TRIS(m)[(n)]))
152 gwlarson 3.10 #define SM_NTH_VERT(m,n) S_NTH_INFO(SM_SAMP(m),n)
153 gwlarson 3.6
154     #define SM_T_ID_VALID(s,t_id) T_IS_VALID(SM_NTH_TRI(s,t_id))
155 gwlarson 3.1
156 gwlarson 3.7
157 gwlarson 3.4 #define SM_MAX_SAMP(m) S_MAX_SAMP(SM_SAMP(m))
158     #define SM_MAX_POINTS(m) S_MAX_POINTS(SM_SAMP(m))
159     #define SM_SAMP_BASE(m) S_BASE(SM_SAMP(m))
160     #define SM_NTH_WV(m,i) S_NTH_W_PT(SM_SAMP(m),i)
161     #define SM_NTH_W_DIR(m,i) S_NTH_W_DIR(SM_SAMP(m),i)
162 gwlarson 3.7 #define SM_DIR_ID(m,i) (!SM_BASE_ID(m,i) && SM_NTH_W_DIR(m,i)==-1)
163 gwlarson 3.4 #define SM_NTH_RGB(m,i) S_NTH_RGB(SM_SAMP(m),i)
164     #define SM_RGB(m) S_RGB(SM_SAMP(m))
165 gwlarson 3.7 #define SM_WP(m) S_W_PT(SM_SAMP(m))
166 gwlarson 3.4 #define SM_BRT(m) S_BRT(SM_SAMP(m))
167     #define SM_NTH_BRT(m,i) S_NTH_BRT(SM_SAMP(m),i)
168     #define SM_CHR(m) S_CHR(SM_SAMP(m))
169     #define SM_NTH_CHR(m,i) S_NTH_CHR(SM_SAMP(m),i)
170     #define SM_NUM_SAMP(m) S_NUM_SAMP(SM_SAMP(m))
171     #define SM_TONE_MAP(m) S_TONE_MAP(SM_SAMP(m))
172 gwlarson 3.1
173     #define SM_ALLOWED_VIEW_CHANGE(m) (SM_NUM_SAMP(m)/smDist_sum*SM_VIEW_FRAC)
174
175     #define SM_FOR_ALL_ADJACENT_TRIS(sm,id,t) for(t=smTri_next_ccw_nbr(sm,t,id); \
176     t!=SM_NTH_TRI(sm,SM_NTH_VERT(sm,id)); t=smTri_next_ccw_nbr(sm,t,id))
177
178     #define SM_INVALID_SAMP_ID(sm,id) (((id) < 0) || ((id) >= SM_MAX_SAMP(sm)))
179 gwlarson 3.4 #define SM_INVALID_POINT_ID(sm,id) (((id) < 0) || ((id) >= SM_MAX_POINTS(sm)))
180 gwlarson 3.1 #define SM_T_NTH_WV(sm,t,i) (SM_NTH_WV(sm,T_NTH_V(t,i)))
181
182     #define SM_BASE_ID(s,i) \
183 gwlarson 3.4 ((i) >= S_MAX_SAMP(SM_SAMP(s)) && (i) < S_MAX_BASE_PT(SM_SAMP(s)))
184 gwlarson 3.1
185     #define SM_BG_SAMPLE(sm,i) (SM_NTH_W_DIR(sm,i)==-1)
186
187 gwlarson 3.2 #define SM_BG_TRI(sm,i) (SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),0)) && \
188     SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),1)) && \
189     SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),2)))
190     #define SM_MIXED_TRI(sm,i) (SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),0)) || \
191 gwlarson 3.1 SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),1)) || \
192     SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),2)))
193
194     #define SM_FOR_ALL_SAMPLES(sm,i) for((i)=0;i < SM_NUM_SAMP(sm);(i)++)
195
196 gwlarson 3.10 #define SM_FOR_ALL_VALID_TRIS(m,i) for((i)=0,(i)=smNext_valid_tri(m,i);(i)< \
197     SM_NUM_TRI(m); (i)++,(i)= smNext_valid_tri(m,i))
198
199     #define SM_FOR_ALL_FLAGGED_TRIS(m,i,w,b) for(i=0,i=smNext_tri_flag_set(m,i,w,b);i < SM_NUM_TRI(m);i++,i=smNext_tri_flag_set(m,i,w,b))
200     #define SM_FOR_ALL_ACTIVE_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,0)
201     #define smInit_locator(sm) stInit(SM_LOCATOR(sm))
202 gwlarson 3.4 #define smAlloc_locator(sm) stAlloc(SM_LOCATOR(sm))
203 gwlarson 3.10 #define smFree_locator(sm) stFree(SM_LOCATOR(sm))
204 gwlarson 3.4 #define smUnalloc_samp(sm,id) sUnalloc_samp(SM_SAMP(sm),id)
205 gwlarson 3.10 #define smPoint_locate_cell(sm,pt) stPoint_locate(SM_LOCATOR(sm),pt)
206 gwlarson 3.4 #define smFree_samples(sm) sFree(SM_SAMP(sm))
207     #define smInit_samples(sm) sInit(SM_SAMP(sm))
208
209 gwlarson 3.10 #define SM_S_NTH_QT(sm,s_id) S_NTH_INFO1(SM_SAMP(sm),s_id)
210 gwlarson 3.4 #define smClear_vert(sm,id) (SM_NTH_VERT(sm,id) = INVALID)
211
212 gwlarson 3.10 #define freebuf(b) tempbuf(-1)
213
214 gwlarson 3.4 typedef struct _RT_ARGS_{
215     FVECT orig,dir;
216     int t_id;
217 greg 3.11 S_ID *os;
218 gwlarson 3.4 }RT_ARGS;
219 gwlarson 3.1
220 gwlarson 3.10 typedef struct _S_ARGS_{
221 greg 3.11 S_ID s_id;
222     S_ID n_id;
223 gwlarson 3.10 }S_ARGS;
224 gwlarson 3.4
225 gwlarson 3.10
226 gwlarson 3.4 typedef struct _ADD_ARGS {
227     int t_id;
228 greg 3.11 S_ID *del_set;
229 gwlarson 3.4 }ADD_ARGS;
230
231 gwlarson 3.1 extern SM *smMesh;
232     extern double smDist_sum;
233
234 gwlarson 3.4
235 gwlarson 3.1 #ifdef TEST_DRIVER
236     extern VIEW View;
237     extern VIEW Current_View;
238 gwlarson 3.2 extern int Pick_tri,Picking,Pick_samp;
239 gwlarson 3.1 extern FVECT Pick_point[500],Pick_origin,Pick_dir;
240     extern FVECT Pick_v0[500],Pick_v1[500],Pick_v2[500];
241 gwlarson 3.5 extern int Pick_q[500];
242 gwlarson 3.1 extern FVECT P0,P1,P2;
243     extern int Pick_cnt;
244     extern FVECT FrustumNear[4],FrustumFar[4];
245     #endif
246
247 gwlarson 3.4
248     /*
249     * int
250     * smInit(n) : Initialize/clear data structures for n entries
251     * int n;
252     *
253     * Initialize sampL and other data structures for at least n samples.
254     * If n is 0, then free data structures. Return number actually allocated.
255     *
256     *
257     * int
258     * smNewSamp(c, p, v) : register new sample point and return index
259     * COLR c; : pixel color (RGBE)
260     * FVECT p; : world intersection point
261     * FVECT v; : ray direction vector
262     *
263     * Add new sample point to data structures, removing old values as necessary.
264     * New sample representation will be output in next call to smUpdate().
265     *
266     *
267     * int
268     * smFindSamp(orig, dir): intersect ray with 3D rep. and find closest sample
269     * FVECT orig, dir;
270     *
271     * Find the closest sample to the given ray. Return -1 on failure.
272     *
273     */
274 schorsch 3.13
275     #ifdef __cplusplus
276     }
277 gwlarson 3.1 #endif
278 schorsch 3.13 #endif /* define _RAD_SM_H_ */
279 gwlarson 3.1
