root/radiance/ray/src/hd/sm.h
Revision: 3.13
Committed: Mon Jul 14 22:24:00 2003 UTC (20 years, 11 months ago) by schorsch
CVS Tags: rad3R6P1, rad3R6
Changes since 3.12: +13 -10 lines
1 /* RCSid: $Id: sm.h,v 3.12 2003/06/20 00:25:49 greg Exp $ */
2 /*
3 * sm.h
4 */
5
6 #ifndef _RAD_SM_H_
7 #define _RAD_SM_H_
8
9 #include "rhd_sample.h"
10 #include "sm_qtree.h"
11 #include "sm_stree.h"
12
13 #ifdef __cplusplus
14 extern "C" {
15 #endif
16
17 #define NEWSETS
18
19
20 #ifndef TRUE
21 #define TRUE 1
22 #define FALSE 0
23 #endif
24
25
26 #define ON_V 1
27 #define ON_P 2
28 #define ON_E 3
29 #define IN_T 4
30
31 #ifdef SMLFLT
32 #define VERT_EPS 2e-3 /* min edge length in radians */
33 #define COS_VERT_EPS 0.999998 /* cos min edge length in radians */
34 #define EDGE_EPS 2e-5 /* min distance until considered "on-edge"*/
35 #define COLINEAR_EPS 1e-10 /* min sine of between edges angle :amount off PI */
36 #else
37 #define VERT_EPS 5e-4 /* min edge length in radians */
38 #define COS_VERT_EPS 0.999999875 /* cos min edge length in radians */
39 #define EDGE_EPS 2e-7 /* min distance until considered "on-edge"*/
40 #define COLINEAR_EPS 1e-10 /* min sine of between edges angle :amount off PI*/
41 #endif
42
43 #define EV_EPS EDGE_EPS /* Minimum edge-vertex distance */
44
45
46 #define S_REPLACE_SCALE (5.*5.) /* if (distance to new point squared) is
47 > (triangle edge length squared*S_REPLACE_SCALE):for all edges/
48 triangle vertices: new point is puncture point: dont add*/
49 #define S_REPLACE_TRI 2e-8 /* .052 radians to the sixth power */
50
51
52
53 #define SM_DEFAULT 0
54 #define SM_BASE_POINTS 162
55 #define SM_BASE_TRIS 320
56 #define SM_BASE_VERTS SM_BASE_POINTS
57
58 #define SM_VIEW_FRAC 0.1
59
60 #define SM_ALL_LEVELS -1
61
62
63 typedef int VERT; /* One triangle that vertex belongs to- the rest
64 are derived by traversing neighbors */
65
66 typedef struct _EDGE {
67 S_ID verts[2];
68 int tris[2];
69 } EDGE;
70
71 #define E_NTH_VERT(e,i) ((e>0)?Edges[(e)].verts[(i)]:Edges[-(e)].verts[(1-i)])
72 #define SET_E_NTH_VERT(e,i,v) if(e>0) Edges[(e)].verts[(i)]=(v); \
73 else Edges[-(e)].verts[(1-i)]=(v)
74 #define E_NTH_TRI(e,i) ((e>0)?Edges[(e)].tris[(i)]:Edges[-(e)].tris[(1-i)])
75 #define SET_E_NTH_TRI(e,i,v) if(e>0) Edges[(e)].tris[(i)]=(v); \
76 else Edges[-(e)].tris[(1-i)]=(v)
77 #define eClear_edges() (Ecnt = 0,free(Edges),Edges=NULL)
78
79 #define FOR_ALL_EDGES(i) for((i)=1; (i) <= Ecnt; i++)
80 #define FOR_ALL_EDGES_FROM(e,i) for((i)=e+1; (i) <= Ecnt; i++)
81
82
83 typedef struct _TRI {
84 S_ID verts[3]; /* Ids into sample and vertex array for each vertex*/
85 int nbrs[3]; /* Ids for neighboring triangles: -1 if invalid */
86 }TRI;
87
88
89 #define T_NTH_NBR(t,i) ((t)->nbrs[(i)])
90 #define T_CLEAR_NBRS(t) (T_NTH_NBR(t,0)=T_NTH_NBR(t,1)=T_NTH_NBR(t,2)=-1)
91 #define T_NTH_NBR_PTR(t,n) \
92 (T_NTH_NBR(n,0)==(t)?0:T_NTH_NBR(n,1)==(t)?1:T_NTH_NBR(n,2)==(t)?2:-1)
93 #define T_NTH_V(t,i) ((t)->verts[(i)])
94 #define T_WHICH_V(t,i) \
95 (T_NTH_V(t,0)==(i)?0:T_NTH_V(t,1)==(i)?1:T_NTH_V(t,2)==(i)?2:-1)
96 #define T_NEXT_FREE(t) ((t)->nbrs[0])
97 #define T_VALID_FLAG(t) ((t)->nbrs[1])
98 #define T_IS_VALID(t) (T_VALID_FLAG(t)!=-1)
99 #define T_FLAGS 4
100
101 typedef struct _SM {
102 FVECT view_center; /* Canonical view center defining unit sphere */
103 SAMP *samples; /* Sample point information */
104 STREE locator; /* spherical quadtree for point/triangle location */
105 int max_tris; /* Maximum number of triangles */
106 int num_tri; /* Current number of triangles */
107 int free_tris; /* pointer to free_list */
108 int max_verts; /* Maximum number of vertices in the mesh */
109 TRI *tris; /* Pointer to list of triangle structs */
110 int32 *flags[T_FLAGS]; /* Bit 0 set if active(in current frustum) */
111 /* Bit 1 set if not rendered since created */
112 /* Bit 2 set if base triangle */
113 }SM;
114
115 #define T_ACTIVE_FLAG 0
116 #define T_NEW_FLAG 1
117 #define T_BASE_FLAG 2
118 #define T_BG_FLAG 3
119
120 #define SM_VIEW_CENTER(m) ((m)->view_center)
121 #define SM_SAMP(m) ((m)->samples)
122 #define SM_LOCATOR(m) (&((m)->locator))
123 #define SM_MAX_TRIS(m) ((m)->max_tris)
124 #define SM_NUM_TRI(m) ((m)->num_tri)
125 #define SM_FREE_TRIS(m) ((m)->free_tris)
126 #define SM_MAX_VERTS(m) ((m)->max_verts)
127 #define SM_TRIS(m) ((m)->tris)
128 #define SM_NTH_FLAGS(m,n) ((m)->flags[(n)])
129 #define SM_FLAGS(m) ((m)->flags)
130
131
132 #define SM_IS_NTH_T_FLAG(sm,n,f) IS_FLAG(SM_NTH_FLAGS(sm,f),n)
133 #define SM_SET_NTH_T_FLAG(sm,n,f) SET_FLAG(SM_NTH_FLAGS(sm,f),n)
134 #define SM_CLR_NTH_T_FLAG(sm,n,f) CLR_FLAG(SM_NTH_FLAGS(sm,f),n)
135
136 #define SM_IS_NTH_T_ACTIVE(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG)
137 #define SM_IS_NTH_T_BASE(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_BASE_FLAG)
138 #define SM_IS_NTH_T_NEW(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_NEW_FLAG)
139 #define SM_IS_NTH_T_BG(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_BG_FLAG)
140
141 #define SM_SET_NTH_T_ACTIVE(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG)
142 #define SM_SET_NTH_T_BASE(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_BASE_FLAG)
143 #define SM_SET_NTH_T_NEW(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_NEW_FLAG)
144 #define SM_SET_NTH_T_BG(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_BG_FLAG)
145
146 #define SM_CLR_NTH_T_ACTIVE(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG)
147 #define SM_CLR_NTH_T_BASE(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_BASE_FLAG)
148 #define SM_CLR_NTH_T_NEW(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_NEW_FLAG)
149 #define SM_CLR_NTH_T_BG(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_BG_FLAG)
150
151 #define SM_NTH_TRI(m,n) (&(SM_TRIS(m)[(n)]))
152 #define SM_NTH_VERT(m,n) S_NTH_INFO(SM_SAMP(m),n)
153
154 #define SM_T_ID_VALID(s,t_id) T_IS_VALID(SM_NTH_TRI(s,t_id))
155
156
157 #define SM_MAX_SAMP(m) S_MAX_SAMP(SM_SAMP(m))
158 #define SM_MAX_POINTS(m) S_MAX_POINTS(SM_SAMP(m))
159 #define SM_SAMP_BASE(m) S_BASE(SM_SAMP(m))
160 #define SM_NTH_WV(m,i) S_NTH_W_PT(SM_SAMP(m),i)
161 #define SM_NTH_W_DIR(m,i) S_NTH_W_DIR(SM_SAMP(m),i)
162 #define SM_DIR_ID(m,i) (!SM_BASE_ID(m,i) && SM_NTH_W_DIR(m,i)==-1)
163 #define SM_NTH_RGB(m,i) S_NTH_RGB(SM_SAMP(m),i)
164 #define SM_RGB(m) S_RGB(SM_SAMP(m))
165 #define SM_WP(m) S_W_PT(SM_SAMP(m))
166 #define SM_BRT(m) S_BRT(SM_SAMP(m))
167 #define SM_NTH_BRT(m,i) S_NTH_BRT(SM_SAMP(m),i)
168 #define SM_CHR(m) S_CHR(SM_SAMP(m))
169 #define SM_NTH_CHR(m,i) S_NTH_CHR(SM_SAMP(m),i)
170 #define SM_NUM_SAMP(m) S_NUM_SAMP(SM_SAMP(m))
171 #define SM_TONE_MAP(m) S_TONE_MAP(SM_SAMP(m))
172
173 #define SM_ALLOWED_VIEW_CHANGE(m) (SM_NUM_SAMP(m)/smDist_sum*SM_VIEW_FRAC)
174
175 #define SM_FOR_ALL_ADJACENT_TRIS(sm,id,t) for(t=smTri_next_ccw_nbr(sm,t,id); \
176 t!=SM_NTH_TRI(sm,SM_NTH_VERT(sm,id)); t=smTri_next_ccw_nbr(sm,t,id))
177
178 #define SM_INVALID_SAMP_ID(sm,id) (((id) < 0) || ((id) >= SM_MAX_SAMP(sm)))
179 #define SM_INVALID_POINT_ID(sm,id) (((id) < 0) || ((id) >= SM_MAX_POINTS(sm)))
180 #define SM_T_NTH_WV(sm,t,i) (SM_NTH_WV(sm,T_NTH_V(t,i)))
181
182 #define SM_BASE_ID(s,i) \
183 ((i) >= S_MAX_SAMP(SM_SAMP(s)) && (i) < S_MAX_BASE_PT(SM_SAMP(s)))
184
185 #define SM_BG_SAMPLE(sm,i) (SM_NTH_W_DIR(sm,i)==-1)
186
187 #define SM_BG_TRI(sm,i) (SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),0)) && \
188 SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),1)) && \
189 SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),2)))
190 #define SM_MIXED_TRI(sm,i) (SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),0)) || \
191 SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),1)) || \
192 SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),2)))
193
194 #define SM_FOR_ALL_SAMPLES(sm,i) for((i)=0;i < SM_NUM_SAMP(sm);(i)++)
195
196 #define SM_FOR_ALL_VALID_TRIS(m,i) for((i)=0,(i)=smNext_valid_tri(m,i);(i)< \
197 SM_NUM_TRI(m); (i)++,(i)= smNext_valid_tri(m,i))
198
199 #define SM_FOR_ALL_FLAGGED_TRIS(m,i,w,b) for(i=0,i=smNext_tri_flag_set(m,i,w,b);i < SM_NUM_TRI(m);i++,i=smNext_tri_flag_set(m,i,w,b))
200 #define SM_FOR_ALL_ACTIVE_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,0)
201 #define smInit_locator(sm) stInit(SM_LOCATOR(sm))
202 #define smAlloc_locator(sm) stAlloc(SM_LOCATOR(sm))
203 #define smFree_locator(sm) stFree(SM_LOCATOR(sm))
204 #define smUnalloc_samp(sm,id) sUnalloc_samp(SM_SAMP(sm),id)
205 #define smPoint_locate_cell(sm,pt) stPoint_locate(SM_LOCATOR(sm),pt)
206 #define smFree_samples(sm) sFree(SM_SAMP(sm))
207 #define smInit_samples(sm) sInit(SM_SAMP(sm))
208
209 #define SM_S_NTH_QT(sm,s_id) S_NTH_INFO1(SM_SAMP(sm),s_id)
210 #define smClear_vert(sm,id) (SM_NTH_VERT(sm,id) = INVALID)
211
212 #define freebuf(b) tempbuf(-1)
213
214 typedef struct _RT_ARGS_{
215 FVECT orig,dir;
216 int t_id;
217 S_ID *os;
218 }RT_ARGS;
219
220 typedef struct _S_ARGS_{
221 S_ID s_id;
222 S_ID n_id;
223 }S_ARGS;
224
225
226 typedef struct _ADD_ARGS {
227 int t_id;
228 S_ID *del_set;
229 }ADD_ARGS;
230
231 extern SM *smMesh;
232 extern double smDist_sum;
233
234
235 #ifdef TEST_DRIVER
236 extern VIEW View;
237 extern VIEW Current_View;
238 extern int Pick_tri,Picking,Pick_samp;
239 extern FVECT Pick_point[500],Pick_origin,Pick_dir;
240 extern FVECT Pick_v0[500],Pick_v1[500],Pick_v2[500];
241 extern int Pick_q[500];
242 extern FVECT P0,P1,P2;
243 extern int Pick_cnt;
244 extern FVECT FrustumNear[4],FrustumFar[4];
245 #endif
246
247
248 /*
249 * int
250 * smInit(n) : Initialize/clear data structures for n entries
251 * int n;
252 *
253 * Initialize sampL and other data structures for at least n samples.
254 * If n is 0, then free data structures. Return number actually allocated.
255 *
256 *
257 * int
258 * smNewSamp(c, p, v) : register new sample point and return index
259 * COLR c; : pixel color (RGBE)
260 * FVECT p; : world intersection point
261 * FVECT v; : ray direction vector
262 *
263 * Add new sample point to data structures, removing old values as necessary.
264 * New sample representation will be output in next call to smUpdate().
265 *
266 *
267 * int
268 * smFindSamp(orig, dir): intersect ray with 3D rep. and find closest sample
269 * FVECT orig, dir;
270 *
271 * Find the closest sample to the given ray. Return -1 on failure.
272 *
273 */
274
275 #ifdef __cplusplus
276 }
277 #endif
278 #endif /* define _RAD_SM_H_ */
279
