| 1 |
/* RCSid: $Id: sm.h,v 3.13 2003/07/14 22:24:00 schorsch Exp $ */
| 2 |
| 3 |
* sm.h
| 4 |
| 5 |
| 6 |
#ifndef _RAD_SM_H_
| 7 |
#define _RAD_SM_H_
| 8 |
| 9 |
#include "rhd_sample.h"
| 10 |
#include "sm_qtree.h"
| 11 |
#include "sm_stree.h"
| 12 |
| 13 |
#ifdef __cplusplus
| 14 |
extern "C" {
| 15 |
#endif
| 16 |
| 17 |
#define NEWSETS
| 18 |
| 19 |
| 20 |
#ifndef TRUE
| 21 |
#define TRUE 1
| 22 |
#define FALSE 0
| 23 |
#endif
| 24 |
| 25 |
| 26 |
#define ON_V 1
| 27 |
#define ON_P 2
| 28 |
#define ON_E 3
| 29 |
#define IN_T 4
| 30 |
| 31 |
#ifdef SMLFLT
| 32 |
#define VERT_EPS 2e-3 /* min edge length in radians */
| 33 |
#define COS_VERT_EPS 0.999998 /* cos min edge length in radians */
| 34 |
#define EDGE_EPS 2e-5 /* min distance until considered "on-edge"*/
| 35 |
#define COLINEAR_EPS 1e-10 /* min sine of between edges angle :amount off PI */
| 36 |
#else
| 37 |
#define VERT_EPS 5e-4 /* min edge length in radians */
| 38 |
#define COS_VERT_EPS 0.999999875 /* cos min edge length in radians */
| 39 |
#define EDGE_EPS 2e-7 /* min distance until considered "on-edge"*/
| 40 |
#define COLINEAR_EPS 1e-10 /* min sine of between edges angle :amount off PI*/
| 41 |
#endif
| 42 |
| 43 |
#define EV_EPS EDGE_EPS /* Minimum edge-vertex distance */
| 44 |
| 45 |
| 46 |
#define S_REPLACE_SCALE (5.*5.) /* if (distance to new point squared) is
| 47 |
> (triangle edge length squared*S_REPLACE_SCALE):for all edges/
| 48 |
triangle vertices: new point is puncture point: dont add*/
| 49 |
#define S_REPLACE_TRI 2e-8 /* .052 radians to the sixth power */
| 50 |
| 51 |
| 52 |
| 53 |
#define SM_DEFAULT 0
| 54 |
#define SM_BASE_POINTS 162
| 55 |
#define SM_BASE_TRIS 320
| 56 |
#define SM_BASE_VERTS SM_BASE_POINTS
| 57 |
| 58 |
#define SM_VIEW_FRAC 0.1
| 59 |
| 60 |
#define SM_ALL_LEVELS -1
| 61 |
| 62 |
| 63 |
typedef int VERT; /* One triangle that vertex belongs to- the rest
| 64 |
are derived by traversing neighbors */
| 65 |
| 66 |
typedef struct _EDGE {
| 67 |
S_ID verts[2];
| 68 |
int tris[2];
| 69 |
} EDGE;
| 70 |
| 71 |
#define E_NTH_VERT(e,i) ((e>0)?Edges[(e)].verts[(i)]:Edges[-(e)].verts[(1-i)])
| 72 |
#define SET_E_NTH_VERT(e,i,v) if(e>0) Edges[(e)].verts[(i)]=(v); \
| 73 |
else Edges[-(e)].verts[(1-i)]=(v)
| 74 |
#define E_NTH_TRI(e,i) ((e>0)?Edges[(e)].tris[(i)]:Edges[-(e)].tris[(1-i)])
| 75 |
#define SET_E_NTH_TRI(e,i,v) if(e>0) Edges[(e)].tris[(i)]=(v); \
| 76 |
else Edges[-(e)].tris[(1-i)]=(v)
| 77 |
#define eClear_edges() (Ecnt = 0,free(Edges),Edges=NULL)
| 78 |
| 79 |
#define FOR_ALL_EDGES(i) for((i)=1; (i) <= Ecnt; i++)
| 80 |
#define FOR_ALL_EDGES_FROM(e,i) for((i)=e+1; (i) <= Ecnt; i++)
| 81 |
| 82 |
| 83 |
typedef struct _TRI {
| 84 |
S_ID verts[3]; /* Ids into sample and vertex array for each vertex*/
| 85 |
int nbrs[3]; /* Ids for neighboring triangles: -1 if invalid */
| 86 |
}TRI;
| 87 |
| 88 |
| 89 |
#define T_NTH_NBR(t,i) ((t)->nbrs[(i)])
| 90 |
#define T_CLEAR_NBRS(t) (T_NTH_NBR(t,0)=T_NTH_NBR(t,1)=T_NTH_NBR(t,2)=-1)
| 91 |
#define T_NTH_NBR_PTR(t,n) \
| 92 |
(T_NTH_NBR(n,0)==(t)?0:T_NTH_NBR(n,1)==(t)?1:T_NTH_NBR(n,2)==(t)?2:-1)
| 93 |
#define T_NTH_V(t,i) ((t)->verts[(i)])
| 94 |
#define T_WHICH_V(t,i) \
| 95 |
(T_NTH_V(t,0)==(i)?0:T_NTH_V(t,1)==(i)?1:T_NTH_V(t,2)==(i)?2:-1)
| 96 |
#define T_NEXT_FREE(t) ((t)->nbrs[0])
| 97 |
#define T_VALID_FLAG(t) ((t)->nbrs[1])
| 98 |
#define T_IS_VALID(t) (T_VALID_FLAG(t)!=-1)
| 99 |
#define T_FLAGS 4
| 100 |
| 101 |
typedef struct _SM {
| 102 |
FVECT view_center; /* Canonical view center defining unit sphere */
| 103 |
SAMP *samples; /* Sample point information */
| 104 |
STREE locator; /* spherical quadtree for point/triangle location */
| 105 |
int max_tris; /* Maximum number of triangles */
| 106 |
int num_tri; /* Current number of triangles */
| 107 |
int free_tris; /* pointer to free_list */
| 108 |
int max_verts; /* Maximum number of vertices in the mesh */
| 109 |
TRI *tris; /* Pointer to list of triangle structs */
| 110 |
int32 *flags[T_FLAGS]; /* Bit 0 set if active(in current frustum) */
| 111 |
/* Bit 1 set if not rendered since created */
| 112 |
/* Bit 2 set if base triangle */
| 113 |
}SM;
| 114 |
| 115 |
#define T_ACTIVE_FLAG 0
| 116 |
#define T_NEW_FLAG 1
| 117 |
#define T_BASE_FLAG 2
| 118 |
#define T_BG_FLAG 3
| 119 |
| 120 |
#define SM_VIEW_CENTER(m) ((m)->view_center)
| 121 |
#define SM_SAMP(m) ((m)->samples)
| 122 |
#define SM_LOCATOR(m) (&((m)->locator))
| 123 |
#define SM_MAX_TRIS(m) ((m)->max_tris)
| 124 |
#define SM_NUM_TRI(m) ((m)->num_tri)
| 125 |
#define SM_FREE_TRIS(m) ((m)->free_tris)
| 126 |
#define SM_MAX_VERTS(m) ((m)->max_verts)
| 127 |
#define SM_TRIS(m) ((m)->tris)
| 128 |
#define SM_NTH_FLAGS(m,n) ((m)->flags[(n)])
| 129 |
#define SM_FLAGS(m) ((m)->flags)
| 130 |
| 131 |
| 132 |
#define SM_IS_NTH_T_FLAG(sm,n,f) IS_FLAG(SM_NTH_FLAGS(sm,f),n)
| 133 |
#define SM_SET_NTH_T_FLAG(sm,n,f) SET_FLAG(SM_NTH_FLAGS(sm,f),n)
| 134 |
#define SM_CLR_NTH_T_FLAG(sm,n,f) CLR_FLAG(SM_NTH_FLAGS(sm,f),n)
| 135 |
| 136 |
#define SM_IS_NTH_T_ACTIVE(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG)
| 137 |
#define SM_IS_NTH_T_BASE(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_BASE_FLAG)
| 138 |
#define SM_IS_NTH_T_NEW(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_NEW_FLAG)
| 139 |
#define SM_IS_NTH_T_BG(sm,n) SM_IS_NTH_T_FLAG(sm,n,T_BG_FLAG)
| 140 |
| 141 |
#define SM_SET_NTH_T_ACTIVE(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG)
| 142 |
#define SM_SET_NTH_T_BASE(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_BASE_FLAG)
| 143 |
#define SM_SET_NTH_T_NEW(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_NEW_FLAG)
| 144 |
#define SM_SET_NTH_T_BG(sm,n) SM_SET_NTH_T_FLAG(sm,n,T_BG_FLAG)
| 145 |
| 146 |
#define SM_CLR_NTH_T_ACTIVE(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_ACTIVE_FLAG)
| 147 |
#define SM_CLR_NTH_T_BASE(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_BASE_FLAG)
| 148 |
#define SM_CLR_NTH_T_NEW(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_NEW_FLAG)
| 149 |
#define SM_CLR_NTH_T_BG(sm,n) SM_CLR_NTH_T_FLAG(sm,n,T_BG_FLAG)
| 150 |
| 151 |
#define SM_NTH_TRI(m,n) (&(SM_TRIS(m)[(n)]))
| 152 |
#define SM_NTH_VERT(m,n) S_NTH_INFO(SM_SAMP(m),n)
| 153 |
| 154 |
#define SM_T_ID_VALID(s,t_id) T_IS_VALID(SM_NTH_TRI(s,t_id))
| 155 |
| 156 |
| 157 |
#define SM_MAX_SAMP(m) S_MAX_SAMP(SM_SAMP(m))
| 158 |
#define SM_MAX_POINTS(m) S_MAX_POINTS(SM_SAMP(m))
| 159 |
#define SM_SAMP_BASE(m) S_BASE(SM_SAMP(m))
| 160 |
#define SM_NTH_WV(m,i) S_NTH_W_PT(SM_SAMP(m),i)
| 161 |
#define SM_NTH_W_DIR(m,i) S_NTH_W_DIR(SM_SAMP(m),i)
| 162 |
#define SM_DIR_ID(m,i) (!SM_BASE_ID(m,i) && SM_NTH_W_DIR(m,i)==-1)
| 163 |
#define SM_NTH_RGB(m,i) S_NTH_RGB(SM_SAMP(m),i)
| 164 |
#define SM_RGB(m) S_RGB(SM_SAMP(m))
| 165 |
#define SM_WP(m) S_W_PT(SM_SAMP(m))
| 166 |
#define SM_BRT(m) S_BRT(SM_SAMP(m))
| 167 |
#define SM_NTH_BRT(m,i) S_NTH_BRT(SM_SAMP(m),i)
| 168 |
#define SM_CHR(m) S_CHR(SM_SAMP(m))
| 169 |
#define SM_NTH_CHR(m,i) S_NTH_CHR(SM_SAMP(m),i)
| 170 |
#define SM_NUM_SAMP(m) S_NUM_SAMP(SM_SAMP(m))
| 171 |
#define SM_TONE_MAP(m) S_TONE_MAP(SM_SAMP(m))
| 172 |
| 173 |
#define SM_ALLOWED_VIEW_CHANGE(m) (SM_NUM_SAMP(m)/smDist_sum*SM_VIEW_FRAC)
| 174 |
| 175 |
#define SM_FOR_ALL_ADJACENT_TRIS(sm,id,t) for(t=smTri_next_ccw_nbr(sm,t,id); \
| 176 |
t!=SM_NTH_TRI(sm,SM_NTH_VERT(sm,id)); t=smTri_next_ccw_nbr(sm,t,id))
| 177 |
| 178 |
#define SM_INVALID_SAMP_ID(sm,id) (((id) < 0) || ((id) >= SM_MAX_SAMP(sm)))
| 179 |
#define SM_INVALID_POINT_ID(sm,id) (((id) < 0) || ((id) >= SM_MAX_POINTS(sm)))
| 180 |
#define SM_T_NTH_WV(sm,t,i) (SM_NTH_WV(sm,T_NTH_V(t,i)))
| 181 |
| 182 |
#define SM_BASE_ID(s,i) \
| 183 |
((i) >= S_MAX_SAMP(SM_SAMP(s)) && (i) < S_MAX_BASE_PT(SM_SAMP(s)))
| 184 |
| 185 |
#define SM_BG_SAMPLE(sm,i) (SM_NTH_W_DIR(sm,i)==-1)
| 186 |
| 187 |
#define SM_BG_TRI(sm,i) (SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),0)) && \
| 188 |
SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),1)) && \
| 189 |
SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),2)))
| 190 |
#define SM_MIXED_TRI(sm,i) (SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),0)) || \
| 191 |
SM_BG_SAMPLE(sm,T_NTH_V(SM_NTH_TRI(sm,i),1)) || \
| 192 |
| 193 |
| 194 |
#define SM_FOR_ALL_SAMPLES(sm,i) for((i)=0;i < SM_NUM_SAMP(sm);(i)++)
| 195 |
| 196 |
#define SM_FOR_ALL_VALID_TRIS(m,i) for((i)=0,(i)=smNext_valid_tri(m,i);(i)< \
| 197 |
SM_NUM_TRI(m); (i)++,(i)= smNext_valid_tri(m,i))
| 198 |
| 199 |
#define SM_FOR_ALL_FLAGGED_TRIS(m,i,w,b) for(i=0,i=smNext_tri_flag_set(m,i,w,b);i < SM_NUM_TRI(m);i++,i=smNext_tri_flag_set(m,i,w,b))
| 200 |
#define SM_FOR_ALL_ACTIVE_TRIS(m,i) SM_FOR_ALL_FLAGGED_TRIS(m,i,T_ACTIVE_FLAG,0)
| 201 |
#define smInit_locator(sm) stInit(SM_LOCATOR(sm))
| 202 |
#define smAlloc_locator(sm) stAlloc(SM_LOCATOR(sm))
| 203 |
#define smFree_locator(sm) stFree(SM_LOCATOR(sm))
| 204 |
#define smUnalloc_samp(sm,id) sUnalloc_samp(SM_SAMP(sm),id)
| 205 |
#define smPoint_locate_cell(sm,pt) stPoint_locate(SM_LOCATOR(sm),pt)
| 206 |
#define smFree_samples(sm) sFree(SM_SAMP(sm))
| 207 |
#define smInit_samples(sm) sInit(SM_SAMP(sm))
| 208 |
| 209 |
#define SM_S_NTH_QT(sm,s_id) S_NTH_INFO1(SM_SAMP(sm),s_id)
| 210 |
#define smClear_vert(sm,id) (SM_NTH_VERT(sm,id) = INVALID)
| 211 |
| 212 |
#define freebuf(b) tempbuf(-1)
| 213 |
| 214 |
typedef struct _RT_ARGS_{
| 215 |
FVECT orig,dir;
| 216 |
int t_id;
| 217 |
S_ID *os;
| 218 |
}RT_ARGS;
| 219 |
| 220 |
typedef struct _S_ARGS_{
| 221 |
S_ID s_id;
| 222 |
S_ID n_id;
| 223 |
}S_ARGS;
| 224 |
| 225 |
| 226 |
typedef struct _ADD_ARGS {
| 227 |
int t_id;
| 228 |
S_ID *del_set;
| 229 |
}ADD_ARGS;
| 230 |
| 231 |
extern SM *smMesh;
| 232 |
extern double smDist_sum;
| 233 |
| 234 |
| 235 |
#ifdef TEST_DRIVER
| 236 |
extern VIEW View;
| 237 |
extern VIEW Current_View;
| 238 |
extern int Pick_tri,Picking,Pick_samp;
| 239 |
extern FVECT Pick_point[500],Pick_origin,Pick_dir;
| 240 |
extern FVECT Pick_v0[500],Pick_v1[500],Pick_v2[500];
| 241 |
extern int Pick_q[500];
| 242 |
extern FVECT P0,P1,P2;
| 243 |
extern int Pick_cnt;
| 244 |
extern FVECT FrustumNear[4],FrustumFar[4];
| 245 |
#endif
| 246 |
| 247 |
| 248 |
| 249 |
* int
| 250 |
* smInit(n) : Initialize/clear data structures for n entries
| 251 |
* int n;
| 252 |
| 253 |
* Initialize sampL and other data structures for at least n samples.
| 254 |
* If n is 0, then free data structures. Return number actually allocated.
| 255 |
| 256 |
| 257 |
* int
| 258 |
* smNewSamp(c, p, v) : register new sample point and return index
| 259 |
* COLR c; : pixel color (RGBE)
| 260 |
* FVECT p; : world intersection point
| 261 |
* FVECT v; : ray direction vector
| 262 |
| 263 |
* Add new sample point to data structures, removing old values as necessary.
| 264 |
* New sample representation will be output in next call to smUpdate().
| 265 |
| 266 |
| 267 |
* int
| 268 |
* smFindSamp(orig, dir): intersect ray with 3D rep. and find closest sample
| 269 |
* FVECT orig, dir;
| 270 |
| 271 |
* Find the closest sample to the given ray. Return -1 on failure.
| 272 |
| 273 |
| 274 |
| 275 |
#ifdef __cplusplus
| 276 |
| 277 |
#endif
| 278 |
#endif /* define _RAD_SM_H_ */
| 279 |
