root/radiance/ray/src/hd/sm.c
Revision: 3.8
Committed: Tue Oct 6 18:16:54 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 3.7: +841 -718 lines
new triangulate routine
added smTestSample to check for occlusion
added frustum culling before rebuild
changed base quadtree to use octahedron and created new point locate
added "sample active" flags and implemented LRU replacement
started handling case of too many triangles
set sizes are now unbounded
changed all quadtree pointers to quadtrees
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * sm.c
9 */
10 #include "standard.h"
11 #include "sm_flag.h"
12 #include "sm_list.h"
13 #include "sm_geom.h"
14 #include "sm_qtree.h"
15 #include "sm_stree.h"
16 #include "sm.h"
17
18
19 SM *smMesh = NULL;
20 double smDist_sum=0;
21 int smNew_tri_cnt=0;
22 double smMinSampDiff = 1e-4;
23
24 static FVECT smDefault_base[4] = { {SQRT3_INV, SQRT3_INV, SQRT3_INV},
25 {-SQRT3_INV, -SQRT3_INV, SQRT3_INV},
26 {-SQRT3_INV, SQRT3_INV, -SQRT3_INV},
27 {SQRT3_INV, -SQRT3_INV, -SQRT3_INV}};
28 static int smTri_verts[4][3] = { {2,1,0},{3,2,0},{1,3,0},{2,3,1}};
29
30 static int smBase_nbrs[4][3] = { {3,2,1},{3,0,2},{3,1,0},{1,2,0}};
31
32 #ifdef TEST_DRIVER
33 VIEW Current_View = {0,{0,0,0},{0,0,-1},{0,1,0},60,60,0};
34 int Pick_cnt =0;
35 int Pick_tri = -1,Picking = FALSE,Pick_samp=-1;
36 FVECT Pick_point[500],Pick_origin,Pick_dir;
37 FVECT Pick_v0[500], Pick_v1[500], Pick_v2[500];
38 FVECT P0,P1,P2;
39 FVECT FrustumNear[4],FrustumFar[4];
40 double dev_zmin=.01,dev_zmax=1000;
41 #endif
42
43 smDir(sm,ps,id)
44 SM *sm;
45 FVECT ps;
46 int id;
47 {
48 VSUB(ps,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm));
49 normalize(ps);
50 }
51
52 smDir_in_cone(sm,ps,id)
53 SM *sm;
54 FVECT ps;
55 int id;
56 {
57
58 VSUB(ps,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm));
59 normalize(ps);
60 }
61
62 smClear_flags(sm,which)
63 SM *sm;
64 int which;
65 {
66 int i;
67
68 if(which== -1)
69 for(i=0; i < T_FLAGS;i++)
70 bzero(SM_NTH_FLAGS(sm,i),FLAG_BYTES(SM_MAX_TRIS(sm)));
71 else
72 bzero(SM_NTH_FLAGS(sm,which),FLAG_BYTES(SM_MAX_TRIS(sm)));
73 }
74
75 /* Given an allocated mesh- initialize */
76 smInit_mesh(sm)
77 SM *sm;
78 {
79 /* Reset the triangle counters */
80 SM_NUM_TRI(sm) = 0;
81 SM_SAMPLE_TRIS(sm) = 0;
82 SM_FREE_TRIS(sm) = -1;
83 smClear_flags(sm,-1);
84 }
85
86
87 /* Clear the SM for reuse: free any extra allocated memory:does initialization
88 as well
89 */
90 smClear(sm)
91 SM *sm;
92 {
93 smClear_samples(sm);
94 smClear_locator(sm);
95 smInit_mesh(sm);
96 }
97
98 static int realloc_cnt=0;
99
100 int
101 smRealloc_mesh(sm)
102 SM *sm;
103 {
104 int fbytes,i,max_tris,max_verts;
105
106 if(realloc_cnt <=0)
107 realloc_cnt = SM_MAX_TRIS(sm);
108
109 max_tris = SM_MAX_TRIS(sm) + realloc_cnt;
110 fbytes = FLAG_BYTES(max_tris);
111
112 if(!(SM_TRIS(sm) = (TRI *)realloc(SM_TRIS(sm),max_tris*sizeof(TRI))))
113 goto memerr;
114
115 for(i=0; i< T_FLAGS; i++)
116 if(!(SM_NTH_FLAGS(sm,i)=(int4 *)realloc((char *)SM_NTH_FLAGS(sm,i),fbytes)))
117 goto memerr;
118
119 SM_MAX_TRIS(sm) = max_tris;
120 return(max_tris);
121
122 memerr:
123 error(SYSTEM, "out of memory in smRealloc_mesh()");
124 }
125
126 /* Allocate and initialize a new mesh with max_verts and max_tris */
127 int
128 smAlloc_mesh(sm,max_verts,max_tris)
129 SM *sm;
130 int max_verts,max_tris;
131 {
132 int fbytes,i;
133
134 fbytes = FLAG_BYTES(max_tris);
135
136 if(!(SM_TRIS(sm) = (TRI *)realloc(NULL,max_tris*sizeof(TRI))))
137 goto memerr;
138
139 if(!(SM_VERTS(sm) = (VERT *)realloc(NULL,max_verts*sizeof(VERT))))
140 goto memerr;
141
142 for(i=0; i< T_FLAGS; i++)
143 if(!(SM_NTH_FLAGS(sm,i)=(int4 *)realloc(NULL,fbytes)))
144 goto memerr;
145
146 SM_MAX_VERTS(sm) = max_verts;
147 SM_MAX_TRIS(sm) = max_tris;
148
149 realloc_cnt = max_verts >> 1;
150
151 smInit_mesh(sm);
152
153 return(max_tris);
154 memerr:
155 error(SYSTEM, "out of memory in smAlloc_mesh()");
156 }
157
158
159 int
160 smAlloc_tri(sm)
161 SM *sm;
162 {
163 int id;
164
165 /* First check if there are any tris on the free list */
166 /* Otherwise, have we reached the end of the list yet?*/
167 if(SM_NUM_TRI(sm) < SM_MAX_TRIS(sm))
168 return(SM_NUM_TRI(sm)++);
169
170 if((id = SM_FREE_TRIS(sm)) != -1)
171 {
172 SM_FREE_TRIS(sm) = T_NEXT_FREE(SM_NTH_TRI(sm,id));
173 return(id);
174 }
175
176 /*Else: realloc */
177 smRealloc_mesh(sm);
178 return(SM_NUM_TRI(sm)++);
179 }
180
181 smFree_mesh(sm)
182 SM *sm;
183 {
184 int i;
185
186 if(SM_TRIS(sm))
187 free(SM_TRIS(sm));
188 if(SM_VERTS(sm))
189 free(SM_VERTS(sm));
190 for(i=0; i< T_FLAGS; i++)
191 if(SM_NTH_FLAGS(sm,i))
192 free(SM_NTH_FLAGS(sm,i));
193 }
194
195
196 /* Initialize/clear global smL sample list for at least n samples */
197 smAlloc(max_samples)
198 register int max_samples;
199 {
200 unsigned nbytes;
201 register unsigned i;
202 int total_points;
203 int max_tris,n;
204
205 n = max_samples;
206 /* If this is the first call, allocate sample,vertex and triangle lists */
207 if(!smMesh)
208 {
209 if(!(smMesh = (SM *)malloc(sizeof(SM))))
210 error(SYSTEM,"smAlloc():Unable to allocate memory\n");
211 bzero(smMesh,sizeof(SM));
212 }
213 else
214 { /* If existing structure: first deallocate */
215 smFree_mesh(smMesh);
216 smFree_samples(smMesh);
217 smFree_locator(smMesh);
218 }
219
220 /* First allocate at least n samples + extra points:at least enough
221 necessary to form the BASE MESH- Default = 4;
222 */
223 SM_SAMP(smMesh) = sAlloc(&n,SM_EXTRA_POINTS);
224
225 total_points = n + SM_EXTRA_POINTS;
226
227 max_tris = total_points*4;
228 /* Now allocate space for mesh vertices and triangles */
229 max_tris = smAlloc_mesh(smMesh, total_points, max_tris);
230
231 /* Initialize the structure for point,triangle location.
232 */
233 smAlloc_locator(smMesh);
234 }
235
236
237
238 smInit_sm(sm,vp)
239 SM *sm;
240 FVECT vp;
241 {
242
243 smDist_sum = 0;
244 smNew_tri_cnt = 0;
245
246 VCOPY(SM_VIEW_CENTER(sm),vp);
247 smInit_locator(sm,vp);
248 smInit_samples(sm);
249 smInit_mesh(sm);
250 smCreate_base_mesh(sm,SM_DEFAULT);
251 }
252
253 /*
254 * int
255 * smInit(n) : Initialize/clear data structures for n entries
256 * int n;
257 *
258 * This routine allocates/initializes the sample, mesh, and point-location
259 * structures for at least n samples.
260 * If n is <= 0, then clear data structures. Returns number samples
261 * actually allocated.
262 */
263
264 int
265 smInit(n)
266 register int n;
267 {
268 int max_vertices;
269
270
271 /* If n <=0, Just clear the existing structures */
272 if(n <= 0)
273 {
274 smClear(smMesh);
275 return(0);
276 }
277
278 /* Total mesh vertices includes the sample points and the extra vertices
279 to form the base mesh
280 */
281 max_vertices = n + SM_EXTRA_POINTS;
282
283 /* If the current mesh contains enough room, clear and return */
284 if(smMesh && (max_vertices <= SM_MAX_VERTS(smMesh)) && SM_MAX_SAMP(smMesh) <=
285 n && SM_MAX_POINTS(smMesh) <= max_vertices)
286 {
287 smClear(smMesh);
288 return(SM_MAX_SAMP(smMesh));
289 }
290 /* Otherwise- mesh must be allocated with the appropriate number of
291 samples
292 */
293 smAlloc(n);
294
295 return(SM_MAX_SAMP(smMesh));
296 }
297
298
299 smLocator_apply_func(sm,v0,v1,v2,edge_func,tri_func,argptr)
300 SM *sm;
301 FVECT v0,v1,v2;
302 int (*edge_func)();
303 int (*tri_func)();
304 int *argptr;
305 {
306 STREE *st;
307 FVECT p0,p1,p2;
308
309 st = SM_LOCATOR(sm);
310
311 VSUB(p0,v0,SM_VIEW_CENTER(sm));
312 VSUB(p1,v1,SM_VIEW_CENTER(sm));
313 VSUB(p2,v2,SM_VIEW_CENTER(sm));
314
315 stApply_to_tri(st,p0,p1,p2,edge_func,tri_func,argptr);
316
317 }
318
319 QUADTREE
320 delete_tri_set(qt,optr,del_set)
321 QUADTREE qt;
322 OBJECT *optr,*del_set;
323 {
324
325 int set_size,i,t_id;
326 OBJECT *rptr,r_set[QT_MAXSET+1];
327 OBJECT *tptr,t_set[QT_MAXSET+1],*sptr;
328
329 /* First need to check if set size larger than QT_MAXSET: if so
330 need to allocate larger array
331 */
332 if((set_size = MAX(QT_SET_CNT(optr),QT_SET_CNT(del_set))) >QT_MAXSET)
333 rptr = (OBJECT *)malloc((set_size+1)*sizeof(OBJECT));
334 else
335 rptr = r_set;
336 if(!rptr)
337 goto memerr;
338 setintersect(rptr,del_set,optr);
339
340 if(QT_SET_CNT(rptr) > 0)
341 {
342 /* First need to check if set size larger than QT_MAXSET: if so
343 need to allocate larger array
344 */
345 sptr = QT_SET_PTR(rptr);
346 for(i = QT_SET_CNT(rptr); i > 0; i--)
347 {
348 t_id = QT_SET_NEXT_ELEM(sptr);
349 qt = qtdelelem(qt,t_id);
350 }
351 }
352 /* If we allocated memory: free it */
353 if(rptr != r_set)
354 free(rptr);
355
356 return(qt);
357 memerr:
358 error(SYSTEM,"delete_tri_set():Unable to allocate memory");
359 }
360
361 QUADTREE
362 expand_node(qt,q0,q1,q2,optr,n)
363 QUADTREE qt;
364 FVECT q0,q1,q2;
365 OBJECT *optr;
366 int n;
367 {
368 OBJECT *tptr,t_set[QT_MAXSET+1];
369 int i,t_id,found;
370 TRI *t;
371 FVECT v0,v1,v2;
372
373 if(QT_SET_CNT(optr) > QT_MAXSET)
374 tptr = (OBJECT *)malloc((QT_SET_CNT(optr)+1)*sizeof(OBJECT));
375 else
376 tptr = t_set;
377 if(!tptr)
378 goto memerr;
379
380 qtgetset(tptr,qt);
381 /* If set size exceeds threshold: subdivide cell and reinsert tris*/
382 qtfreeleaf(qt);
383 qtSubdivide(qt);
384
385 for(optr = QT_SET_PTR(tptr),i=QT_SET_CNT(tptr); i > 0; i--)
386 {
387 t_id = QT_SET_NEXT_ELEM(optr);
388 t = SM_NTH_TRI(smMesh,t_id);
389 if(!T_IS_VALID(t))
390 continue;
391 VSUB(v0,SM_T_NTH_WV(smMesh,t,0),SM_VIEW_CENTER(smMesh));
392 VSUB(v1,SM_T_NTH_WV(smMesh,t,1),SM_VIEW_CENTER(smMesh));
393 VSUB(v2,SM_T_NTH_WV(smMesh,t,2),SM_VIEW_CENTER(smMesh));
394 qt = qtAdd_tri(qt,q0,q1,q2,v0,v1,v2,t_id,n);
395 }
396 /* If we allocated memory: free it */
397 if( tptr != t_set)
398 free(tptr);
399
400 return(qt);
401 memerr:
402 error(SYSTEM,"expand_node():Unable to allocate memory");
403 }
404
405 add_tri_expand(qtptr,f,argptr,q0,q1,q2,t0,t1,t2,n)
406 QUADTREE *qtptr;
407 int *f;
408 ADD_ARGS *argptr;
409 FVECT q0,q1,q2;
410 FVECT t0,t1,t2;
411 int n;
412 {
413 int t_id;
414 OBJECT *optr,*del_set;
415
416 t_id = argptr->t_id;
417
418 if(QT_IS_EMPTY(*qtptr))
419 {
420 *qtptr = qtaddelem(*qtptr,t_id);
421 return;
422 }
423 if(!QT_LEAF_IS_FLAG(*qtptr))
424 {
425 optr = qtqueryset(*qtptr);
426
427 if(del_set=argptr->del_set)
428 *qtptr = delete_tri_set(*qtptr,optr,del_set);
429 *qtptr = qtaddelem(*qtptr,t_id);
430 }
431 if (n >= QT_MAX_LEVELS)
432 return;
433 optr = qtqueryset(*qtptr);
434 if(QT_SET_CNT(optr) < QT_SET_THRESHOLD)
435 return;
436 *qtptr = expand_node(*qtptr,q0,q1,q2,optr,n);
437 }
438
439
440
441 add_tri(qtptr,fptr,argptr)
442 QUADTREE *qtptr;
443 int *fptr;
444 ADD_ARGS *argptr;
445 {
446
447 OBJECT *optr,*del_set;
448 int t_id;
449
450 t_id = argptr->t_id;
451
452
453 if(QT_IS_EMPTY(*qtptr))
454 {
455 *qtptr = qtaddelem(*qtptr,t_id);
456 if(!QT_FLAG_FILL_TRI(*fptr))
457 (*fptr)++;
458 return;
459 }
460 if(QT_LEAF_IS_FLAG(*qtptr))
461 return;
462
463 optr = qtqueryset(*qtptr);
464
465 if(del_set = argptr->del_set)
466 *qtptr = delete_tri_set(*qtptr,optr,del_set);
467
468 if(!QT_IS_EMPTY(*qtptr))
469 {
470 optr = qtqueryset(*qtptr);
471 if(QT_SET_CNT(optr) >= QT_SET_THRESHOLD)
472 (*fptr) |= QT_EXPAND;
473 }
474 if(!QT_FLAG_FILL_TRI(*fptr))
475 (*fptr)++;
476 *qtptr = qtaddelem(*qtptr,t_id);
477
478 }
479
480
481 smLocator_add_tri(sm,t_id,v0_id,v1_id,v2_id,del_set)
482 SM *sm;
483 int t_id;
484 int v0_id,v1_id,v2_id;
485 OBJECT *del_set;
486 {
487 STREE *st;
488 FVECT v0,v1,v2;
489 ADD_ARGS args;
490
491 st = SM_LOCATOR(sm);
492
493
494 VSUB(v0,SM_NTH_WV(sm,v0_id),SM_VIEW_CENTER(sm));
495 VSUB(v1,SM_NTH_WV(sm,v1_id),SM_VIEW_CENTER(sm));
496 VSUB(v2,SM_NTH_WV(sm,v2_id),SM_VIEW_CENTER(sm));
497
498 qtClearAllFlags();
499 args.t_id = t_id;
500 args.del_set = del_set;
501
502 stApply_to_tri(st,v0,v1,v2,add_tri,add_tri_expand,&args);
503
504 }
505
506 /* Add a triangle to the base array with vertices v1-v2-v3 */
507 int
508 smAdd_tri(sm, v0_id,v1_id,v2_id)
509 SM *sm;
510 int v0_id,v1_id,v2_id;
511 {
512 int t_id;
513 TRI *t;
514
515 t_id = smAlloc_tri(sm);
516
517 if(t_id == -1)
518 return(t_id);
519
520 t = SM_NTH_TRI(sm,t_id);
521
522 T_CLEAR_NBRS(t);
523 /* set the triangle vertex ids */
524 T_NTH_V(t,0) = v0_id;
525 T_NTH_V(t,1) = v1_id;
526 T_NTH_V(t,2) = v2_id;
527
528 SM_NTH_VERT(sm,v0_id) = t_id;
529 SM_NTH_VERT(sm,v1_id) = t_id;
530 SM_NTH_VERT(sm,v2_id) = t_id;
531
532 if(SM_BASE_ID(sm,v0_id) || SM_BASE_ID(sm,v1_id) || SM_BASE_ID(sm,v2_id))
533 {
534 smClear_tri_flags(sm,t_id);
535 SM_SET_NTH_T_BASE(sm,t_id);
536 }
537 else
538 {
539 SM_CLR_NTH_T_BASE(sm,t_id);
540 SM_SET_NTH_T_ACTIVE(sm,t_id);
541 SM_SET_NTH_T_NEW(sm,t_id);
542 S_SET_FLAG(T_NTH_V(t,0));
543 S_SET_FLAG(T_NTH_V(t,1));
544 S_SET_FLAG(T_NTH_V(t,2));
545 SM_SAMPLE_TRIS(sm)++;
546 smNew_tri_cnt++;
547 }
548
549 /* return initialized triangle */
550 return(t_id);
551 }
552
553
554 void
555 smTris_swap_edge(sm,t_id,t1_id,e,e1,tn_id,tn1_id,add_ptr,delptr)
556 SM *sm;
557 int t_id,t1_id;
558 int e,e1;
559 int *tn_id,*tn1_id;
560 LIST **add_ptr;
561 QUADTREE *delptr;
562
563 {
564 int verts[3],enext,eprev,e1next,e1prev;
565 TRI *n;
566 FVECT p1,p2,p3;
567 int ta_id,tb_id;
568 /* swap diagonal (e relative to t, and e1 relative to t1)
569 defined by quadrilateral
570 formed by t,t1- swap for the opposite diagonal
571 */
572 enext = (e+1)%3;
573 eprev = (e+2)%3;
574 e1next = (e1+1)%3;
575 e1prev = (e1+2)%3;
576 verts[e] = T_NTH_V(SM_NTH_TRI(sm,t_id),e);
577 verts[enext] = T_NTH_V(SM_NTH_TRI(sm,t1_id),e1prev);
578 verts[eprev] = T_NTH_V(SM_NTH_TRI(sm,t_id),eprev);
579 ta_id = smAdd_tri(sm,verts[0],verts[1],verts[2]);
580 *add_ptr = push_data(*add_ptr,ta_id);
581 verts[e1] = T_NTH_V(SM_NTH_TRI(sm,t1_id),e1);
582 verts[e1next] = T_NTH_V(SM_NTH_TRI(sm,t_id),eprev);
583 verts[e1prev] = T_NTH_V(SM_NTH_TRI(sm,t1_id),e1prev);
584 tb_id = smAdd_tri(sm,verts[0],verts[1],verts[2]);
585 *add_ptr = push_data(*add_ptr,tb_id);
586
587 /* set the neighbors */
588 T_NTH_NBR(SM_NTH_TRI(sm,ta_id),e) = T_NTH_NBR(SM_NTH_TRI(sm,t1_id),e1next);
589 T_NTH_NBR(SM_NTH_TRI(sm,tb_id),e1) = T_NTH_NBR(SM_NTH_TRI(sm,t_id),enext);
590 T_NTH_NBR(SM_NTH_TRI(sm,ta_id),enext) =tb_id;
591 T_NTH_NBR(SM_NTH_TRI(sm,tb_id),e1next) = ta_id;
592 T_NTH_NBR(SM_NTH_TRI(sm,ta_id),eprev)=T_NTH_NBR(SM_NTH_TRI(sm,t_id),eprev);
593 T_NTH_NBR(SM_NTH_TRI(sm,tb_id),e1prev)=
594 T_NTH_NBR(SM_NTH_TRI(sm,t1_id),e1prev);
595
596 /* Reset neighbor pointers of original neighbors */
597 n = SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,t_id),enext));
598 T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = tb_id;
599 n = SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,t_id),eprev));
600 T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = ta_id;
601
602 n = SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,t1_id),e1next));
603 T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = ta_id;
604 n = SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,t1_id),e1prev));
605 T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = tb_id;
606
607 /* Delete two parent triangles */
608 if(remove_from_list(t_id,add_ptr))
609 smDelete_tri(sm,t_id);
610 else
611 *delptr = qtaddelem(*delptr,t_id);
612
613 if(remove_from_list(t1_id,add_ptr))
614 smDelete_tri(sm,t1_id);
615 else
616 *delptr = qtaddelem(*delptr,t1_id);
617
618 *tn_id = ta_id;
619 *tn1_id = tb_id;
620 }
621
622 smUpdate_locator(sm,add_list,del_set)
623 SM *sm;
624 LIST *add_list;
625 OBJECT *del_set;
626 {
627 int t_id,i;
628 TRI *t;
629 OBJECT *optr;
630
631 while(add_list)
632 {
633 t_id = pop_list(&add_list);
634 t = SM_NTH_TRI(sm,t_id);
635 smLocator_add_tri(sm,t_id,T_NTH_V(t,0),T_NTH_V(t,1),T_NTH_V(t,2),del_set);
636 }
637
638 optr = QT_SET_PTR(del_set);
639 for(i = QT_SET_CNT(del_set); i > 0; i--)
640 {
641 t_id = QT_SET_NEXT_ELEM(optr);
642 #if 0
643 t = SM_NTH_TRI(sm,t_id);
644 smLocator_remove_tri(sm,t_id,T_NTH_V(t,0),T_NTH_V(t,1),T_NTH_V(t,2));
645 #endif
646 smDelete_tri(sm,t_id);
647 }
648 }
649 /* MUST add check for constrained edges */
650 int
651 smFix_tris(sm,id,tlist,add_list,delptr)
652 SM *sm;
653 int id;
654 LIST *tlist,*add_list;
655 QUADTREE *delptr;
656 {
657 TRI *t,*t_opp;
658 FVECT p,p1,p2,p3;
659 int e,e1,swapped = 0;
660 int t_id,t_opp_id;
661
662 VSUB(p,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm));
663 while(tlist)
664 {
665 t_id = pop_list(&tlist);
666 t = SM_NTH_TRI(sm,t_id);
667 e = (T_WHICH_V(t,id)+1)%3;
668 t_opp_id = T_NTH_NBR(t,e);
669 t_opp = SM_NTH_TRI(sm,t_opp_id);
670
671 smDir_in_cone(sm,p1,T_NTH_V(t_opp,0));
672 smDir_in_cone(sm,p2,T_NTH_V(t_opp,1));
673 smDir_in_cone(sm,p3,T_NTH_V(t_opp,2));
674 if(point_in_cone(p,p1,p2,p3))
675 {
676 swapped = 1;
677 e1 = T_NTH_NBR_PTR(t_id,t_opp);
678 /* check list for t_opp and Remove if there */
679 remove_from_list(t_opp_id,&tlist);
680 smTris_swap_edge(sm,t_id,t_opp_id,e,e1,&t_id,&t_opp_id,
681 &add_list,delptr);
682 tlist = push_data(tlist,t_id);
683 tlist = push_data(tlist,t_opp_id);
684 }
685 }
686 smUpdate_locator(sm,add_list,qtqueryset(*delptr));
687 return(swapped);
688 }
689
690 /* Give the vertex "id" and a triangle "t" that it belongs to- return the
691 next nbr in a counter clockwise order about vertex "id"
692 */
693 int
694 smTri_next_ccw_nbr(sm,t,id)
695 SM *sm;
696 TRI *t;
697 int id;
698 {
699 int t_id;
700 int nbr_id;
701
702 /* Want the edge for which "id" is the destination */
703 t_id = (T_WHICH_V(t,id)+ 2)% 3;
704 nbr_id = T_NTH_NBR(t,t_id);
705 return(nbr_id);
706 }
707
708 smClear_tri_flags(sm,id)
709 SM *sm;
710 int id;
711 {
712 int i;
713
714 for(i=0; i < T_FLAGS; i++)
715 SM_CLR_NTH_T_FLAG(sm,id,i);
716
717 }
718
719 /* Locate the point-id in the point location structure: */
720 int
721 smInsert_samp(sm,s_id,tri_id)
722 SM *sm;
723 int s_id,tri_id;
724 {
725 int v0_id,v1_id,v2_id;
726 int t0_id,t1_id,t2_id,replaced;
727 LIST *tlist,*add_list;
728 OBJECT del_set[2];
729 QUADTREE delnode;
730 FVECT npt;
731 TRI *tri,*nbr;
732
733 add_list = NULL;
734
735 v0_id = T_NTH_V(SM_NTH_TRI(sm,tri_id),0);
736 v1_id = T_NTH_V(SM_NTH_TRI(sm,tri_id),1);
737 v2_id = T_NTH_V(SM_NTH_TRI(sm,tri_id),2);
738
739 t0_id = smAdd_tri(sm,s_id,v0_id,v1_id);
740 /* Add triangle to the locator */
741
742 add_list = push_data(add_list,t0_id);
743
744 t1_id = smAdd_tri(sm,s_id,v1_id,v2_id);
745 add_list = push_data(add_list,t1_id);
746
747 t2_id = smAdd_tri(sm,s_id,v2_id,v0_id);
748 add_list = push_data(add_list,t2_id);
749
750 /* CAUTION: tri must be assigned after Add_tri: pointers may change*/
751 tri = SM_NTH_TRI(sm,tri_id);
752
753 /* Set the neighbor pointers for the new tris */
754 T_NTH_NBR(SM_NTH_TRI(sm,t0_id),0) = t2_id;
755 T_NTH_NBR(SM_NTH_TRI(sm,t0_id),1) = T_NTH_NBR(tri,0);
756 T_NTH_NBR(SM_NTH_TRI(sm,t0_id),2) = t1_id;
757 T_NTH_NBR(SM_NTH_TRI(sm,t1_id),0) = t0_id;
758 T_NTH_NBR(SM_NTH_TRI(sm,t1_id),1) = T_NTH_NBR(tri,1);
759 T_NTH_NBR(SM_NTH_TRI(sm,t1_id),2) = t2_id;
760 T_NTH_NBR(SM_NTH_TRI(sm,t2_id),0) = t1_id;
761 T_NTH_NBR(SM_NTH_TRI(sm,t2_id),1) = T_NTH_NBR(tri,2);
762 T_NTH_NBR(SM_NTH_TRI(sm,t2_id),2) = t0_id;
763
764 /* Reset the neigbor pointers for the neighbors of the original */
765 nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,0));
766 T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t0_id;
767 nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,1));
768 T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t1_id;
769 nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,2));
770 T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t2_id;
771
772 del_set[0] = 1; del_set[1] = tri_id;
773 delnode = qtnewleaf(del_set);
774
775 /* Fix up the new triangles*/
776 tlist = push_data(NULL,t0_id);
777 tlist = push_data(tlist,t1_id);
778 tlist = push_data(tlist,t2_id);
779
780 smFix_tris(sm,s_id,tlist,add_list,&delnode);
781
782 qtfreeleaf(delnode);
783
784 return(TRUE);
785 }
786
787
788 int
789 smTri_in_set(sm,p,optr)
790 SM *sm;
791 FVECT p;
792 OBJECT *optr;
793 {
794 int i,t_id;
795 FVECT n,v0,v1,v2;
796 TRI *t;
797
798 for (i = QT_SET_CNT(optr),optr = QT_SET_PTR(optr);i > 0; i--)
799 {
800 /* Find the first triangle that pt falls */
801 t_id = QT_SET_NEXT_ELEM(optr);
802 t = SM_NTH_TRI(sm,t_id);
803 if(!T_IS_VALID(t))
804 continue;
805 VSUB(v0,SM_T_NTH_WV(sm,t,0),SM_VIEW_CENTER(sm));
806 VSUB(v1,SM_T_NTH_WV(sm,t,1),SM_VIEW_CENTER(sm));
807 VSUB(v2,SM_T_NTH_WV(sm,t,2),SM_VIEW_CENTER(sm));
808
809 if(EQUAL_VEC3(v0,p) || EQUAL_VEC3(v1,p) || EQUAL_VEC3(v2,p))
810 return(t_id);
811
812 VCROSS(n,v1,v0);
813 if(DOT(n,p) >0.0)
814 continue;
815 VCROSS(n,v2,v1);
816 if(DOT(n,p) > 0.0)
817 continue;
818
819 VCROSS(n,v0,v2);
820 if(DOT(n,p) > 0.0)
821 continue;
822
823 return(t_id);
824 }
825 return(INVALID);
826 }
827
828 int
829 smPointLocateTri(sm,id)
830 SM *sm;
831 int id;
832 {
833 FVECT tpt;
834 QUADTREE qt,*optr;
835
836 VSUB(tpt,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm));
837 qt = smPointLocateCell(sm,tpt);
838 if(QT_IS_EMPTY(qt))
839 return(INVALID);
840
841 optr = qtqueryset(qt);
842 return(smTri_in_set(sm,tpt,optr));
843 }
844
845
846 /*
847 Determine whether this sample should:
848 a) be added to the mesh by subdividing the triangle
849 b) ignored
850 c) replace values of an existing mesh vertex
851
852 In case a, the routine will return TRUE, for b,c will return FALSE
853 In case a, also determine if this sample should cause the deletion of
854 an existing vertex. If so *rptr will contain the id of the sample to delete
855 after the new sample has been added.
856
857 ASSUMPTION: this will not be called with a new sample that is
858 a BASE point.
859
860 The following tests are performed (in order) to determine the fate
861 of the sample:
862
863 1) If the world space point of the sample coincides with one of the
864 triangle vertex samples: The values of the triangle sample are
865 replaced with the new values and FALSE is returned
866 2) If the new sample is close in ws, and close in the spherical projection
867 to one of the triangle vertex samples:
868 pick the point with dir closest to that of the canonical view
869 If it is the new point: mark existing point for deletion,and return
870 TRUE,else return FALSE
871 3) If the spherical projection of new is < REPLACE_EPS from a base point:
872 add new and mark the base for deletion: return TRUE
873 4) If the addition of the new sample point would introduce a "puncture"
874 or cause new triangles with large depth differences:return FALSE
875 This attempts to throw out points that should be occluded
876 */
877 int
878 smTest_sample(sm,tri_id,s_id,dir,rptr)
879 SM *sm;
880 int tri_id,s_id;
881 FVECT dir;
882 int *rptr;
883 {
884 TRI *tri;
885 double d,d2,dnear,dspt,d01,d12,d20,s0,s1,s2,ds,dv;
886 int vid[3],i,nearid,norm,dcnt,bcnt;
887 FVECT diff[3],spt,npt;
888 FVECT p;
889
890 VCOPY(p,SM_NTH_WV(sm,s_id));
891 *rptr = INVALID;
892 bcnt = dcnt = 0;
893 tri = SM_NTH_TRI(sm,tri_id);
894 vid[0] = T_NTH_V(tri,0);
895 vid[1] = T_NTH_V(tri,1);
896 vid[2] = T_NTH_V(tri,2);
897
898 /* TEST 1: Test if the new point has the same world space point as
899 one of the existing triangle vertices
900 */
901 for(i=0; i<3; i++)
902 {
903 if(SM_BASE_ID(sm,vid[i]))
904 {
905 bcnt++;
906 continue;
907 }
908 if(SM_DIR_ID(sm,vid[i]))
909 dcnt++;
910 VSUB(diff[i],SM_NTH_WV(sm,vid[i]),p);
911 /* If same world point: replace */
912 if(ZERO_VEC3(diff[i]))
913 {
914 sReset_samp(SM_SAMP(sm),vid[i],s_id);
915 SM_TONE_MAP(sm) = 0;
916 return(FALSE);
917 }
918 }
919 if(SM_DIR_ID(sm,s_id))
920 return(TRUE);
921 /* TEST 2: If the new sample is close in ws, and close in the spherical
922 projection to one of the triangle vertex samples
923 */
924 norm = FALSE;
925 if(bcnt + dcnt != 3)
926 {
927 VSUB(spt,p,SM_VIEW_CENTER(sm));
928 ds = DOT(spt,spt);
929 dnear = FHUGE;
930 for(i=0; i<3; i++)
931 {
932 if(SM_BASE_ID(sm,vid[i]) || SM_DIR_ID(sm,vid[i]))
933 continue;
934 d = DOT(diff[i],diff[i])/ds;
935 if(d < dnear)
936 {
937 dnear = d;
938 nearid=vid[i];
939 }
940 }
941
942 if(dnear <= smMinSampDiff*smMinSampDiff)
943 {
944 /* Pick the point with dir closest to that of the canonical view
945 if it is the new sample: mark existing point for deletion
946 */
947 normalize(spt);
948 norm = TRUE;
949 VSUB(npt,SM_NTH_WV(sm,nearid),SM_VIEW_CENTER(sm));
950 normalize(npt);
951 d = fdir2diff(SM_NTH_W_DIR(sm,nearid), npt);
952 if(dir)
953 d2 = 2. - 2.*DOT(dir,spt);
954 else
955 d2 = fdir2diff(SM_NTH_W_DIR(sm,s_id), spt);
956 /* The existing sample is a better sample:punt */
957 if(d2 > d)
958 return(FALSE);
959 else
960 {
961 /* The new sample is better: mark the existing one
962 for deletion after the new one is added*/
963 *rptr = nearid;
964 return(TRUE);
965 }
966 }
967 }
968 /* TEST 3: If the spherical projection of new is < S_REPLACE_EPS
969 from a base point
970 */
971 if(bcnt)
972 {
973 dnear = FHUGE;
974 if(bcnt + dcnt ==3)
975 VSUB(spt,p,SM_VIEW_CENTER(sm));
976 if(!norm)
977 normalize(spt);
978
979 for(i=0; i<3; i++)
980 {
981 if(!SM_BASE_ID(sm,vid[i]))
982 continue;
983 VSUB(npt,SM_NTH_WV(sm,vid[i]),SM_VIEW_CENTER(sm));
984 d = DIST_SQ(npt,spt);
985 if(d < S_REPLACE_EPS && d < dnear)
986 {
987 dnear = d;
988 nearid = vid[i];
989 }
990 }
991 if(dnear != FHUGE)
992 {
993 /* add new and mark the base for deletion */
994 *rptr = nearid;
995 return(TRUE);
996 }
997 }
998
999 /* TEST 4:
1000 If the addition of the new sample point would introduce a "puncture"
1001 or cause new triangles with large depth differences:dont add:
1002 */
1003 if(bcnt || dcnt)
1004 return(TRUE);
1005 /* If the new point is in front of the existing points- add */
1006 dv = DIST_SQ(SM_NTH_WV(sm,vid[0]),SM_VIEW_CENTER(sm));
1007 if(ds < dv)
1008 return(TRUE);
1009
1010 d01 = DIST_SQ(SM_NTH_WV(sm,vid[1]),SM_NTH_WV(sm,vid[0]));
1011 s0 = DOT(diff[0],diff[0]);
1012 if(s0 < S_REPLACE_SCALE*d01)
1013 return(TRUE);
1014 d12 = DIST_SQ(SM_NTH_WV(sm,vid[2]),SM_NTH_WV(sm,vid[1]));
1015 if(s0 < S_REPLACE_SCALE*d12)
1016 return(TRUE);
1017 d20 = DIST_SQ(SM_NTH_WV(sm,vid[0]),SM_NTH_WV(sm,vid[2]));
1018 if(s0 < S_REPLACE_SCALE*d20)
1019 return(TRUE);
1020 d = MIN3(d01,d12,d20);
1021 s1 = DOT(diff[1],diff[1]);
1022 if(s1 < S_REPLACE_SCALE*d)
1023 return(TRUE);
1024 s2 = DOT(diff[2],diff[2]);
1025 if(s2 < S_REPLACE_SCALE*d)
1026 return(TRUE);
1027
1028
1029 return(FALSE);
1030 }
1031
1032
1033 int
1034 smAlloc_samp(sm,c,dir,pt)
1035 SM *sm;
1036 COLR c;
1037 FVECT dir,pt;
1038 {
1039 int s_id,replaced,cnt;
1040 SAMP *s;
1041 FVECT p;
1042
1043 s = SM_SAMP(sm);
1044 s_id = sAlloc_samp(s,&replaced);
1045
1046 cnt=0;
1047 while(replaced)
1048 {
1049 if(smMesh_remove_vertex(sm,s_id))
1050 break;
1051 s_id = sAlloc_samp(s,&replaced);
1052 cnt++;
1053 if(cnt > S_MAX_SAMP(s))
1054 error(CONSISTENCY,"smAlloc_samp():unable to find free samp\n");
1055 }
1056
1057 if(pt)
1058 sInit_samp(s,s_id,c,dir,pt);
1059 else
1060 {
1061 VADD(p,dir,SM_VIEW_CENTER(sm));
1062 sInit_samp(s,s_id,c,NULL,p);
1063 }
1064 return(s_id);
1065 }
1066
1067 int
1068 smAdd_samp(sm,s_id,p,dir)
1069 SM *sm;
1070 int s_id;
1071 FVECT p,dir;
1072 {
1073 int t_id,r_id,test;
1074 double d;
1075
1076 r_id = INVALID;
1077 t_id = smPointLocateTri(sm,s_id);
1078 if(t_id == INVALID)
1079 {
1080 #ifdef DEBUG
1081 eputs("smAdd_samp(): tri not found \n");
1082 #endif
1083 return(FALSE);
1084 }
1085 if(!SM_BASE_ID(sm,s_id))
1086 {
1087 if(!smTest_sample(sm,t_id,s_id,dir,&r_id))
1088 return(FALSE);
1089 /* If not a sky point, add distance from the viewcenter to average*/
1090 if( !SM_DIR_ID(sm,s_id))
1091 {
1092 d = DIST(p,SM_VIEW_CENTER(smMesh));
1093 smDist_sum += 1.0/d;
1094 }
1095 }
1096 test = smInsert_samp(smMesh,s_id,t_id);
1097
1098 if(test && r_id != INVALID)
1099 smMesh_remove_vertex(sm,r_id);
1100
1101 return(test);
1102 }
1103
1104 /*
1105 * int
1106 * smNewSamp(c, dir, p) : register new sample point and return index
1107 * COLR c; : pixel color (RGBE)
1108 * FVECT dir; : ray direction vector
1109 * FVECT p; : world intersection point
1110 *
1111 * Add new sample point to data structures, removing old values as necessary.
1112 * New sample representation will be output in next call to smUpdate().
1113 * If the point is a sky point: then v=NULL
1114 */
1115 int
1116 smNewSamp(c,dir,p)
1117 COLR c;
1118 FVECT dir;
1119 FVECT p;
1120
1121 {
1122 int s_id;
1123 int debug=0;
1124 static FILE *fp;
1125 static int cnt=0,n=3010;
1126 /* First check if this the first sample: if so initialize mesh */
1127 if(SM_NUM_SAMP(smMesh) == 0)
1128 {
1129 smInit_sm(smMesh,odev.v.vp);
1130 #if 0
1131 fp = fopen("Debug_data.view","w");
1132 fprintf(fp,"%d %d %f %f %f ",1280,1024,odev.v.vp[0],odev.v.vp[1],
1133 odev.v.vp[2]);
1134 fprintf(fp,"%f %f %f ",odev.v.vdir[0],odev.v.vdir[1],
1135 odev.v.vdir[2]);
1136 fprintf(fp,"%f %f %f ",odev.v.vup[0],odev.v.vup[1],odev.v.vup[2]);
1137 fprintf(fp,"%f %f ",odev.v.horiz,odev.v.vert);
1138 fclose(fp);
1139 fp = fopen("Debug_data","w");
1140 #endif
1141 }
1142 #if 0
1143 fprintf(fp,"%f %f %f %f %f %f ",p[0],p[1],p[2],(float)c[0]/255.0,(float)c[1]/255.0,
1144 (float)c[2]/255.0);
1145 #endif
1146
1147 /* Allocate space for a sample */
1148 s_id = smAlloc_samp(smMesh,c,dir,p);
1149 #if 0
1150 if(cnt==n)
1151 return(-1);
1152 cnt++;
1153 #endif
1154 /* Add the sample to the mesh */
1155 if(!smAdd_samp(smMesh,s_id,p,dir))
1156 {
1157 /* If the sample space was not used: return */
1158 smUnalloc_samp(smMesh,s_id);
1159 s_id = INVALID;
1160 }
1161 return(s_id);
1162
1163 }
1164 int
1165 smAdd_base_vertex(sm,v)
1166 SM *sm;
1167 FVECT v;
1168 {
1169 int id;
1170
1171 /* First add coordinate to the sample array */
1172 id = sAdd_base_point(SM_SAMP(sm),v);
1173 if(id == INVALID)
1174 return(INVALID);
1175 /* Initialize triangle pointer to -1 */
1176 smClear_vert(sm,id);
1177 return(id);
1178 }
1179
1180
1181
1182 /* Initialize a the point location DAG based on a 6 triangle tesselation
1183 of the unit sphere centered on the view center. The DAG structure
1184 contains 6 roots: one for each initial base triangle
1185 */
1186
1187 int
1188 smCreate_base_mesh(sm,type)
1189 SM *sm;
1190 int type;
1191 {
1192 int i,s_id,tri_id,nbr_id;
1193 int p[4],ids[4];
1194 int v0_id,v1_id,v2_id;
1195 FVECT d,pt,cntr,v0,v1,v2;
1196
1197 /* First insert the base vertices into the sample point array */
1198
1199 for(i=0; i < 4; i++)
1200 {
1201 VCOPY(cntr,smDefault_base[i]);
1202 cntr[0] += .01;
1203 cntr[1] += .02;
1204 cntr[2] += .03;
1205 VADD(cntr,cntr,SM_VIEW_CENTER(sm));
1206 p[i] = smAdd_base_vertex(sm,cntr);
1207 }
1208 /* Create the base triangles */
1209 for(i=0;i < 4; i++)
1210 {
1211 v0_id = p[smTri_verts[i][0]];
1212 v1_id = p[smTri_verts[i][1]];
1213 v2_id = p[smTri_verts[i][2]];
1214 ids[i] = smAdd_tri(sm, v0_id,v1_id,v2_id);
1215 smLocator_add_tri(sm,ids[i],v0_id,v1_id,v2_id,NULL);
1216 }
1217
1218 /* Set neighbors */
1219
1220 for(tri_id=0;tri_id < 4; tri_id++)
1221 for(nbr_id=0; nbr_id < 3; nbr_id++)
1222 T_NTH_NBR(SM_NTH_TRI(sm,ids[tri_id]),nbr_id) = smBase_nbrs[tri_id][nbr_id];
1223
1224
1225 /* Now add the centroids of the faces */
1226 for(tri_id=0;tri_id < 4; tri_id++)
1227 {
1228 VCOPY(v0,SM_T_NTH_WV(sm,SM_NTH_TRI(sm,ids[tri_id]),0));
1229 VCOPY(v1,SM_T_NTH_WV(sm,SM_NTH_TRI(sm,ids[tri_id]),1));
1230 VCOPY(v2,SM_T_NTH_WV(sm,SM_NTH_TRI(sm,ids[tri_id]),2));
1231 tri_centroid(v0,v1,v2,cntr);
1232 VSUB(cntr,cntr,SM_VIEW_CENTER(sm));
1233 normalize(cntr);
1234 VADD(cntr,cntr,SM_VIEW_CENTER(sm));
1235 s_id = smAdd_base_vertex(sm,cntr);
1236 smAdd_samp(sm,s_id,NULL,NULL);
1237 }
1238 return(1);
1239
1240 }
1241
1242
1243 int
1244 smNext_tri_flag_set(sm,i,which,b)
1245 SM *sm;
1246 int i,which;
1247 int b;
1248 {
1249
1250 for(; i < SM_NUM_TRI(sm);i++)
1251 {
1252
1253 if(!T_IS_VALID(SM_NTH_TRI(sm,i)))
1254 continue;
1255 if(!SM_IS_NTH_T_FLAG(sm,i,which))
1256 continue;
1257 if(!b)
1258 break;
1259 if((b==1) && !SM_BG_TRI(sm,i))
1260 break;
1261 if((b==2) && SM_BG_TRI(sm,i))
1262 break;
1263 }
1264
1265 return(i);
1266 }
1267
1268
1269 int
1270 smNext_valid_tri(sm,i)
1271 SM *sm;
1272 int i;
1273 {
1274
1275 while( i < SM_NUM_TRI(sm) && !T_IS_VALID(SM_NTH_TRI(sm,i)))
1276 i++;
1277
1278 return(i);
1279 }
1280
1281
1282
1283 qtTri_from_id(t_id,v0,v1,v2)
1284 int t_id;
1285 FVECT v0,v1,v2;
1286 {
1287 TRI *t;
1288
1289 t = SM_NTH_TRI(smMesh,t_id);
1290 if(!T_IS_VALID(t))
1291 return(0);
1292 VSUB(v0,SM_T_NTH_WV(smMesh,t,0),SM_VIEW_CENTER(smMesh));
1293 VSUB(v1,SM_T_NTH_WV(smMesh,t,1),SM_VIEW_CENTER(smMesh));
1294 VSUB(v2,SM_T_NTH_WV(smMesh,t,2),SM_VIEW_CENTER(smMesh));
1295 return(1);
1296 }
1297
1298
1299 smRebuild_mesh(sm,v)
1300 SM *sm;
1301 VIEW *v;
1302 {
1303 int i,j,cnt;
1304 FVECT p,ov,dir;
1305 double d;
1306
1307 #ifdef DEBUG
1308 eputs("smRebuild_mesh(): rebuilding....");
1309 #endif
1310 /* Clear the mesh- and rebuild using the current sample array */
1311 /* Remember the current number of samples */
1312 cnt = SM_NUM_SAMP(sm);
1313 /* Calculate the difference between the current and new viewpoint*/
1314 /* Will need to subtract this off of sky points */
1315 VSUB(ov,v->vp,SM_VIEW_CENTER(sm));
1316 /* Initialize the mesh to 0 samples and the base triangles */
1317
1318 /* Go through all samples and add in if in the new view frustum, and
1319 the dir is <= 30 degrees from new view
1320 */
1321 j=0;
1322 for(i=0; i < cnt; i++)
1323 {
1324 /* First check if sample visible(conservative approx: if one of tris
1325 attached to sample is in frustum) */
1326 if(!S_IS_FLAG(i))
1327 continue;
1328
1329 /* Next test if direction > 30 from current direction */
1330 if(SM_NTH_W_DIR(sm,i)!=-1)
1331 {
1332 VSUB(p,SM_NTH_WV(sm,i),v->vp);
1333 normalize(p);
1334 d = fdir2diff(SM_NTH_W_DIR(sm,i), p);
1335 if (d > MAXDIFF2)
1336 continue;
1337 }
1338 sReset_samp(SM_SAMP(sm),j,i);
1339 j++;
1340 }
1341 smInit_sm(sm,v->vp);
1342 for(i=0; i< j; i++)
1343 {
1344 S_SET_FLAG(i);
1345 VCOPY(p,SM_NTH_WV(sm,i));
1346 smAdd_samp(sm,i,p,NULL);
1347 }
1348 SM_NUM_SAMP(sm) = j;
1349 smNew_tri_cnt = SM_SAMPLE_TRIS(sm);
1350 #ifdef DEBUG
1351 eputs("smRebuild_mesh():done\n");
1352 #endif
1353 }
1354
1355 int
1356 intersect_tri_set(t_set,orig,dir,pt)
1357 OBJECT *t_set;
1358 FVECT orig,dir,pt;
1359 {
1360 OBJECT *optr;
1361 int i,t_id,id;
1362 int pid0,pid1,pid2;
1363 FVECT p0,p1,p2,p;
1364 TRI *t;
1365
1366 optr = QT_SET_PTR(t_set);
1367 for(i = QT_SET_CNT(t_set); i > 0; i--)
1368 {
1369 t_id = QT_SET_NEXT_ELEM(optr);
1370
1371 t = SM_NTH_TRI(smMesh,t_id);
1372 if(!T_IS_VALID(t))
1373 continue;
1374
1375 pid0 = T_NTH_V(t,0);
1376 pid1 = T_NTH_V(t,1);
1377 pid2 = T_NTH_V(t,2);
1378 VCOPY(p0,SM_NTH_WV(smMesh,pid0));
1379 VCOPY(p1,SM_NTH_WV(smMesh,pid1));
1380 VCOPY(p2,SM_NTH_WV(smMesh,pid2));
1381 if(ray_intersect_tri(orig,dir,p0,p1,p2,p))
1382 {
1383 id = closest_point_in_tri(p0,p1,p2,p,pid0,pid1,pid2);
1384
1385 if(pt)
1386 VCOPY(pt,p);
1387 #ifdef DEBUG_TEST_DRIVER
1388 Pick_tri = t_id;
1389 Pick_samp = id;
1390 VCOPY(Pick_point[0],p);
1391 #endif
1392 return(id);
1393 }
1394 }
1395 return(-1);
1396 }
1397
1398 /* OS is constrained to be <= QT_MAXCSET : if the set exceeds this, the
1399 results of check_set are conservative
1400 */
1401
1402 ray_trace_check_set(qtptr,fptr,argptr)
1403 QUADTREE *qtptr;
1404 int *fptr;
1405 RT_ARGS *argptr;
1406 {
1407 OBJECT tset[QT_MAXSET+1],*tptr;
1408 double dt,t;
1409 int found;
1410
1411 if(QT_LEAF_IS_FLAG(*qtptr))
1412 {
1413 QT_FLAG_SET_DONE(*fptr);
1414 #if DEBUG
1415 eputs("ray_trace_check_set():Already visited this node:aborting\n");
1416 #endif
1417 return;
1418 }
1419 if(!QT_IS_EMPTY(*qtptr))
1420 {
1421 tptr = qtqueryset(*qtptr);
1422 if(QT_SET_CNT(tptr) > QT_MAXSET)
1423 tptr = (OBJECT *)malloc((QT_SET_CNT(tptr)+1)*sizeof(OBJECT));
1424 else
1425 tptr = tset;
1426 if(!tptr)
1427 goto memerr;
1428
1429 qtgetset(tptr,*qtptr);
1430 /* Check triangles in set against those seen so far(os):only
1431 check new triangles for intersection (t_set')
1432 */
1433 check_set_large(tptr,argptr->os);
1434 if((found = intersect_tri_set(tptr,argptr->orig,argptr->dir,NULL))!= -1)
1435 {
1436 argptr->t_id = found;
1437 if(tptr != tset)
1438 free(tptr);
1439 QT_FLAG_SET_DONE(*fptr);
1440 return;
1441 }
1442 if(tptr != tset)
1443 free(tptr);
1444 }
1445 return;
1446 memerr:
1447 error(SYSTEM,"ray_trace_check_set():Unable to allocate memory");
1448 }
1449
1450
1451 /*
1452 * int
1453 * smFindSamp(FVECT orig, FVECT dir)
1454 *
1455 * Find the closest sample to the given ray. Returns sample id, -1 on failure.
1456 * "dir" is assumed to be normalized
1457 */
1458
1459 int
1460 smFindSamp(orig,dir)
1461 FVECT orig,dir;
1462 {
1463 FVECT b,p,o;
1464 OBJECT *ts;
1465 QUADTREE qt;
1466 int s_id;
1467 double d;
1468
1469 /* r is the normalized vector from the view center to the current
1470 * ray point ( starting with "orig"). Find the cell that r falls in,
1471 * and test the ray against all triangles stored in the cell. If
1472 * the test fails, trace the projection of the ray across to the
1473 * next cell it intersects: iterate until either an intersection
1474 * is found, or the projection ray is // to the direction. The sample
1475 * corresponding to the triangle vertex closest to the intersection
1476 * point is returned.
1477 */
1478
1479 /* First test if "orig" coincides with the View_center or if "dir" is
1480 parallel to r formed by projecting "orig" on the sphere. In
1481 either case, do a single test against the cell containing the
1482 intersection of "dir" and the sphere
1483 */
1484 /* orig will be updated-so preserve original value */
1485 if(!smMesh)
1486 return;
1487 point_on_sphere(b,orig,SM_VIEW_CENTER(smMesh));
1488 d = -DOT(b,dir);
1489 if(EQUAL_VEC3(orig,SM_VIEW_CENTER(smMesh)) || EQUAL(fabs(d),1.0))
1490 {
1491 qt = smPointLocateCell(smMesh,dir);
1492 /* Test triangles in the set for intersection with Ray:returns
1493 first found
1494 */
1495 #ifdef DEBUG
1496 if(QT_IS_EMPTY(qt))
1497 {
1498 eputs("smFindSamp(): point not found");
1499 return;
1500 }
1501 #endif
1502 ts = qtqueryset(qt);
1503 s_id = intersect_tri_set(ts,orig,dir,p);
1504 #ifdef DEBUG_TEST_DRIVER
1505 VCOPY(Pick_point[0],p);
1506 #endif
1507 }
1508 else
1509 {
1510 OBJECT t_set[QT_MAXCSET + 1];
1511 RT_ARGS rt;
1512
1513 /* Test each of the root triangles against point id */
1514 QT_CLEAR_SET(t_set);
1515 VSUB(o,orig,SM_VIEW_CENTER(smMesh));
1516 ST_CLEAR_FLAGS(SM_LOCATOR(smMesh));
1517 rt.t_id = -1;
1518 rt.os = t_set;
1519 VCOPY(rt.orig,orig);
1520 VCOPY(rt.dir,dir);
1521 stTrace_ray(SM_LOCATOR(smMesh),o,dir,ray_trace_check_set,&rt);
1522 s_id = rt.t_id;
1523 }
1524 return(s_id);
1525 }
1526
1527
1528
1529
1530
1531
1532
1533
1534
1535
1536
