root/radiance/ray/src/hd/sm.c
Revision: 3.6
Committed: Mon Sep 14 10:33:46 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.5: +38 -113 lines
optimized normalizing calls and bug fix in triangle counting
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * sm.c
9 */
10 #include "standard.h"
11 #include "sm_list.h"
12 #include "sm_geom.h"
13 #include "sm.h"
14
15
16 SM *smMesh = NULL;
17 double smDist_sum=0;
18 int smNew_tri_cnt=0;
19
20 static int smBase_nbrs[4][3] = { {3,2,1},{3,0,2},{3,1,0},{1,2,0}};
21
22 #ifdef TEST_DRIVER
23 VIEW Current_View = {0,{0,0,0},{0,0,-1},{0,1,0},60,60,0};
24 int Pick_cnt =0;
25 int Pick_tri = -1,Picking = FALSE,Pick_samp=-1;
26 FVECT Pick_point[500],Pick_origin,Pick_dir;
27 FVECT Pick_v0[500], Pick_v1[500], Pick_v2[500];
28 FVECT P0,P1,P2;
29 FVECT FrustumNear[4],FrustumFar[4];
30 double dev_zmin=.01,dev_zmax=1000;
31 #endif
32
33 smDir(sm,ps,id)
34 SM *sm;
35 FVECT ps;
36 int id;
37 {
38 FVECT p;
39
40 VCOPY(p,SM_NTH_WV(sm,id));
41 point_on_sphere(ps,p,SM_VIEW_CENTER(sm));
42 }
43
44 smClear_mesh(sm)
45 SM *sm;
46 {
47 /* Reset the triangle counters */
48 SM_TRI_CNT(sm) = 0;
49 SM_NUM_TRIS(sm) = 0;
50 SM_FREE_TRIS(sm) = -1;
51 }
52
53 smClear_flags(sm,which)
54 SM *sm;
55 int which;
56 {
57 int i;
58
59 if(which== -1)
60 for(i=0; i < T_FLAGS;i++)
61 bzero(SM_NTH_FLAGS(sm,i),T_TOTAL_FLAG_BYTES(SM_MAX_TRIS(sm)));
62 else
63 bzero(SM_NTH_FLAGS(sm,which),T_TOTAL_FLAG_BYTES(SM_MAX_TRIS(sm)));
64 }
65
66 smClear_locator(sm)
67 SM *sm;
68 {
69 STREE *st;
70
71 st = SM_LOCATOR(sm);
72
73 stClear(st);
74 }
75
76 smInit_locator(sm,center,base)
77 SM *sm;
78 FVECT center,base[4];
79 {
80 STREE *st;
81
82 st = SM_LOCATOR(sm);
83
84 stInit(st,center,base);
85
86 }
87
88 smClear(sm)
89 SM *sm;
90 {
91 smClear_samples(sm);
92 smClear_mesh(sm);
93 smClear_locator(sm);
94 }
95
96 int
97 smAlloc_tris(sm,max_verts,max_tris)
98 SM *sm;
99 int max_verts,max_tris;
100 {
101 int i,nbytes,vbytes,fbytes;
102
103 vbytes = max_verts*sizeof(VERT);
104 fbytes = T_TOTAL_FLAG_BYTES(max_tris);
105 nbytes = vbytes + max_tris*sizeof(TRI) +T_FLAGS*fbytes + 8;
106 for(i = 1024; nbytes > i; i <<= 1)
107 ;
108 /* check if casting works correctly */
109 max_tris = (i-vbytes-8)/(sizeof(TRI) + T_FLAG_BYTES);
110 fbytes = T_TOTAL_FLAG_BYTES(max_tris);
111
112 SM_BASE(sm)=(char *)malloc(vbytes+max_tris*sizeof(TRI)+T_FLAGS*fbytes);
113
114 if (SM_BASE(sm) == NULL)
115 return(0);
116
117 SM_TRIS(sm) = (TRI *)SM_BASE(sm);
118 SM_VERTS(sm) = (VERT *)(SM_TRIS(sm) + max_tris);
119
120 SM_NTH_FLAGS(sm,0) = (int4 *)(SM_VERTS(sm) + max_verts);
121 for(i=1; i < T_FLAGS; i++)
122 SM_NTH_FLAGS(sm,i) = (int4 *)(SM_NTH_FLAGS(sm,i-1)+fbytes/sizeof(int4));
123
124 SM_MAX_VERTS(sm) = max_verts;
125 SM_MAX_TRIS(sm) = max_tris;
126
127 smClear_mesh(sm);
128
129 return(max_tris);
130 }
131
132
133
134 int
135 smAlloc_locator(sm)
136 SM *sm;
137 {
138 STREE *st;
139
140 st = SM_LOCATOR(sm);
141
142 st = stAlloc(st);
143
144 if(st)
145 return(TRUE);
146 else
147 return(FALSE);
148 }
149
150 /* Initialize/clear global smL sample list for at least n samples */
151 smAlloc(max_samples)
152 register int max_samples;
153 {
154 unsigned nbytes;
155 register unsigned i;
156 int total_points;
157 int max_tris;
158
159 /* If this is the first call, allocate sample,vertex and triangle lists */
160 if(!smMesh)
161 {
162 if(!(smMesh = (SM *)malloc(sizeof(SM))))
163 error(SYSTEM,"smAlloc():Unable to allocate memory");
164 bzero(smMesh,sizeof(SM));
165 }
166 else
167 { /* If existing structure: first deallocate */
168 if(SM_BASE(smMesh))
169 free(SM_BASE(smMesh));
170 if(SM_SAMP_BASE(smMesh))
171 free(SM_SAMP_BASE(smMesh));
172 }
173
174 /* First allocate at least n samples + extra points:at least enough
175 necessary to form the BASE MESH- Default = 4;
176 */
177 max_samples = smAlloc_samples(smMesh, max_samples,SM_EXTRA_POINTS);
178
179 total_points = max_samples + SM_EXTRA_POINTS;
180 max_tris = total_points*2;
181
182 /* Now allocate space for mesh vertices and triangles */
183 max_tris = smAlloc_tris(smMesh, total_points, max_tris);
184
185 /* Initialize the structure for point,triangle location.
186 */
187 smAlloc_locator(smMesh);
188
189 }
190
191
192
193 smInit_mesh(sm,vp)
194 SM *sm;
195 FVECT vp;
196 {
197
198 /* NOTE: Should be elsewhere?*/
199 smDist_sum = 0;
200 smNew_tri_cnt = 0;
201
202 VCOPY(SM_VIEW_CENTER(smMesh),vp);
203 smClear_locator(sm);
204 smInit_locator(sm,vp,0);
205 smClear_aux_samples(sm);
206 smClear_mesh(sm);
207 smCreate_base_mesh(sm,SM_DEFAULT);
208 }
209
210 /*
211 * int
212 * smInit(n) : Initialize/clear data structures for n entries
213 * int n;
214 *
215 * This routine allocates/initializes the sample, mesh, and point-location
216 * structures for at least n samples.
217 * If n is <= 0, then clear data structures. Returns number samples
218 * actually allocated.
219 */
220
221 int
222 smInit(n)
223 register int n;
224 {
225 int max_vertices;
226
227 /* If n <=0, Just clear the existing structures */
228 if(n <= 0)
229 {
230 smClear(smMesh);
231 return(0);
232 }
233
234 /* Total mesh vertices includes the sample points and the extra vertices
235 to form the base mesh
236 */
237 max_vertices = n + SM_EXTRA_POINTS;
238
239 /* If the current mesh contains enough room, clear and return */
240 if(smMesh && max_vertices <= SM_MAX_VERTS(smMesh))
241 {
242 smClear(smMesh);
243 return(SM_MAX_SAMP(smMesh));
244 }
245 /* Otherwise- mesh must be allocated with the appropriate number of
246 samples
247 */
248 smAlloc(n);
249
250 return(SM_MAX_SAMP(smMesh));
251 }
252
253
254 int
255 smLocator_apply_func(sm,v0,v1,v2,func,arg)
256 SM *sm;
257 FVECT v0,v1,v2;
258 int (*func)();
259 int *arg;
260 {
261 STREE *st;
262 int found;
263 FVECT p0,p1,p2;
264
265 st = SM_LOCATOR(sm);
266
267 VSUB(p0,v0,SM_VIEW_CENTER(sm));
268 VSUB(p1,v1,SM_VIEW_CENTER(sm));
269 VSUB(p2,v2,SM_VIEW_CENTER(sm));
270
271 found = stApply_to_tri_cells(st,p0,p1,p2,func,arg);
272
273 return(found);
274 }
275
276
277 int
278 add_tri_expand(qtptr,q0,q1,q2,t0,t1,t2,n,arg,t_id)
279 QUADTREE *qtptr;
280 FVECT q0,q1,q2;
281 FVECT t0,t1,t2;
282 int n;
283 int *arg;
284 int t_id;
285 {
286 OBJECT tset[QT_MAXSET+1],*optr;
287 int i,id,found;
288 FVECT v0,v1,v2;
289 TRI *tri;
290 #ifdef DEBUG_TEST_DRIVER
291 Pick_tri = t_id;
292 Picking = TRUE;
293 #endif
294
295 if(QT_IS_EMPTY(*qtptr))
296 {
297 *qtptr = qtaddelem(*qtptr,t_id);
298 return(TRUE);
299 }
300
301 optr = qtqueryset(*qtptr);
302 if(!inset(optr,t_id))
303 {
304 if(QT_SET_CNT(optr) < QT_MAXSET)
305 *qtptr = qtaddelem(*qtptr,t_id);
306 else
307 {
308 #ifdef DEBUG
309 eputs("add_tri_expand():no room in set\n");
310 #endif
311 return(FALSE);
312 }
313 }
314 optr = qtqueryset(*qtptr);
315 if(QT_SET_CNT(optr) >= QT_SET_THRESHOLD)
316 if (n < QT_MAX_LEVELS)
317 {
318 qtgetset(tset,*qtptr);
319 /* If set size exceeds threshold: subdivide cell and reinsert tris*/
320 qtfreeleaf(*qtptr);
321 qtSubdivide(qtptr);
322
323 for(optr = QT_SET_PTR(tset),i=QT_SET_CNT(tset); i > 0; i--)
324 {
325 id = QT_SET_NEXT_ELEM(optr);
326 tri = SM_NTH_TRI(smMesh,id);
327 VSUB(v0,SM_T_NTH_WV(smMesh,tri,0),SM_VIEW_CENTER(smMesh));
328 VSUB(v1,SM_T_NTH_WV(smMesh,tri,1),SM_VIEW_CENTER(smMesh));
329 VSUB(v2,SM_T_NTH_WV(smMesh,tri,2),SM_VIEW_CENTER(smMesh));
330 found = qtAdd_tri(qtptr,q0,q1,q2,v0,v1,v2,id,n);
331 #ifdef DEBUG
332 if(!found)
333 eputs("add_tri_expand():Reinsert\n");
334 #endif
335 }
336 return(QT_MODIFIED);
337 }
338 else
339 if(QT_SET_CNT(optr) < QT_MAXSET)
340 {
341 #ifdef DEBUG_TEST_DRIVER
342 eputs("add_tri_expand():too many levels:can't expand\n");
343 #endif
344 return(TRUE);
345 }
346 else
347 {
348 #ifdef DEBUG
349 eputs("add_tri_expand():too many tris inset:can't add\n");
350 #endif
351 return(FALSE);
352 }
353 }
354
355
356 int
357 add_tri(qtptr,fptr,t_id)
358 QUADTREE *qtptr;
359 int *fptr;
360 int t_id;
361 {
362
363 OBJECT *optr;
364
365 #ifdef DEBUG_TEST_DRIVER
366 Pick_tri = t_id;
367 Picking = TRUE;
368 #endif
369 if(QT_IS_EMPTY(*qtptr))
370 {
371 *qtptr = qtaddelem(*qtptr,t_id);
372 if(!QT_FLAG_FILL_TRI(*fptr))
373 (*fptr)++;
374 }
375 else
376 {
377 optr = qtqueryset(*qtptr);
378 if(!inset(optr,t_id))
379 {
380 if(QT_SET_CNT(optr) < QT_MAXSET)
381 {
382 if(QT_SET_CNT(optr) >= QT_SET_THRESHOLD)
383 (*fptr) |= QT_EXPAND;
384 if(!QT_FLAG_FILL_TRI(*fptr))
385 (*fptr)++;
386 *qtptr = qtaddelem(*qtptr,t_id);
387 }
388 else
389 {
390 #ifdef DEBUG_TESTDRIVER
391 eputs("add_tri():exceeded set size\n");
392 #endif
393 return(FALSE);
394 }
395 }
396 }
397 return(TRUE);
398 }
399
400
401 int
402 stInsert_tri(st,t_id,t0,t1,t2)
403 STREE *st;
404 int t_id;
405 FVECT t0,t1,t2;
406 {
407 int f;
408 FVECT dir;
409
410 /* First add all of the leaf cells lying on the triangle perimeter:
411 mark all cells seen on the way
412 */
413 ST_CLEAR_FLAGS(st);
414 f = 0;
415 VSUB(dir,t1,t0);
416 stTrace_edge(st,t0,dir,1.0,add_tri,&f,t_id);
417 VSUB(dir,t2,t1);
418 stTrace_edge(st,t1,dir,1.0,add_tri,&f,t_id);
419 VSUB(dir,t0,t2);
420 stTrace_edge(st,t2,dir,1.0,add_tri,&f,t_id);
421 /* Now visit interior */
422 if(QT_FLAG_FILL_TRI(f) || QT_FLAG_UPDATE(f))
423 stVisit_tri_interior(st,t0,t1,t2,add_tri_expand,&f,t_id);
424 }
425
426 smLocator_add_tri(sm,t_id,v0_id,v1_id,v2_id)
427 SM *sm;
428 int t_id;
429 int v0_id,v1_id,v2_id;
430 {
431 STREE *st;
432 FVECT v0,v1,v2;
433
434 st = SM_LOCATOR(sm);
435
436 VSUB(v0,SM_NTH_WV(sm,v0_id),SM_VIEW_CENTER(sm));
437 VSUB(v1,SM_NTH_WV(sm,v1_id),SM_VIEW_CENTER(sm));
438 VSUB(v2,SM_NTH_WV(sm,v2_id),SM_VIEW_CENTER(sm));
439
440 stUpdate_tri(st,t_id,v0,v1,v2,add_tri,add_tri_expand);
441
442 }
443
444 /* Add a triangle to the base array with vertices v1-v2-v3 */
445 int
446 smAdd_tri(sm, v0_id,v1_id,v2_id,tptr)
447 SM *sm;
448 int v0_id,v1_id,v2_id;
449 TRI **tptr;
450 {
451 int t_id;
452 TRI *t;
453
454
455 if(SM_TRI_CNT(sm)+1 > SM_MAX_TRIS(sm))
456 error(SYSTEM,"smAdd_tri():Too many triangles");
457
458 /* Get the id for the next available triangle */
459 SM_FREE_TRI_ID(sm,t_id);
460 if(t_id == -1)
461 return(t_id);
462
463 t = SM_NTH_TRI(sm,t_id);
464 T_CLEAR_NBRS(t);
465
466 if(SM_BASE_ID(sm,v0_id) || SM_BASE_ID(sm,v1_id) || SM_BASE_ID(sm,v2_id))
467 {
468 smClear_tri_flags(sm,t_id);
469 SM_SET_NTH_T_BASE(sm,t_id);
470 }
471 else
472 {
473 SM_CLEAR_NTH_T_BASE(sm,t_id);
474 SM_SET_NTH_T_ACTIVE(sm,t_id);
475 SM_SET_NTH_T_LRU(sm,t_id);
476 SM_SET_NTH_T_NEW(sm,t_id);
477 SM_NUM_TRIS(sm)++;
478 smNew_tri_cnt++;
479 }
480 /* set the triangle vertex ids */
481 T_NTH_V(t,0) = v0_id;
482 T_NTH_V(t,1) = v1_id;
483 T_NTH_V(t,2) = v2_id;
484
485 SM_NTH_VERT(sm,v0_id) = t_id;
486 SM_NTH_VERT(sm,v1_id) = t_id;
487 SM_NTH_VERT(sm,v2_id) = t_id;
488
489 if(t)
490 *tptr = t;
491 /* return initialized triangle */
492 return(t_id);
493 }
494
495 int
496 smClosest_vertex_in_tri(sm,v0_id,v1_id,v2_id,p,eps)
497 SM *sm;
498 int v0_id,v1_id,v2_id;
499 FVECT p;
500 double eps;
501 {
502 FVECT v;
503 double d,d0,d1,d2;
504 int closest = -1;
505
506 if(v0_id != -1)
507 {
508 smDir(sm,v,v0_id);
509 d0 = DIST(p,v);
510 if(eps < 0 || d0 < eps)
511 {
512 closest = v0_id;
513 d = d0;
514 }
515 }
516 if(v1_id != -1)
517 {
518 smDir(sm,v,v1_id);
519 d1 = DIST(p,v);
520 if(closest== -1)
521 {
522 if(eps < 0 || d1 < eps)
523 {
524 closest = v1_id;
525 d = d1;
526 }
527 }
528 else
529 if(d1 < d0)
530 {
531 if((eps < 0) || d1 < eps)
532 {
533 closest = v1_id;
534 d = d1;
535 }
536 }
537 }
538 if(v2_id != -1)
539 {
540 smDir(sm,v,v2_id);
541 d2 = DIST(p,v);
542 if((eps < 0) || d2 < eps)
543 if(closest == -1 ||(d2 < d))
544 return(v2_id);
545 }
546 return(closest);
547 }
548
549
550 int
551 smClosest_vertex_in_w_tri(sm,v0_id,v1_id,v2_id,p)
552 SM *sm;
553 int v0_id,v1_id,v2_id;
554 FVECT p;
555 {
556 FVECT v;
557 double d,d0,d1,d2;
558 int closest;
559
560 VCOPY(v,SM_NTH_WV(sm,v0_id));
561 d = d0 = DIST(p,v);
562 closest = v0_id;
563
564 VCOPY(v,SM_NTH_WV(sm,v1_id));
565 d1 = DIST(p,v);
566 if(d1 < d0)
567 {
568 closest = v1_id;
569 d = d1;
570 }
571 VCOPY(v,SM_NTH_WV(sm,v2_id));
572 d2 = DIST(p,v);
573 if(d2 < d)
574 return(v2_id);
575 else
576 return(closest);
577 }
578
579 void
580 smTris_swap_edge(sm,t_id,t1_id,e,e1,tn_id,tn1_id,add,del)
581 SM *sm;
582 int t_id,t1_id;
583 int e,e1;
584 int *tn_id,*tn1_id;
585 LIST **add,**del;
586
587 {
588 TRI *t,*t1;
589 TRI *ta,*tb;
590 int verts[3],enext,eprev,e1next,e1prev;
591 TRI *n;
592 FVECT p1,p2,p3;
593 int ta_id,tb_id;
594 /* swap diagonal (e relative to t, and e1 relative to t1)
595 defined by quadrilateral
596 formed by t,t1- swap for the opposite diagonal
597 */
598 t = SM_NTH_TRI(sm,t_id);
599 t1 = SM_NTH_TRI(sm,t1_id);
600 enext = (e+1)%3;
601 eprev = (e+2)%3;
602 e1next = (e1+1)%3;
603 e1prev = (e1+2)%3;
604 verts[e] = T_NTH_V(t,e);
605 verts[enext] = T_NTH_V(t1,e1prev);
606 verts[eprev] = T_NTH_V(t,eprev);
607 ta_id = smAdd_tri(sm,verts[0],verts[1],verts[2],&ta);
608 *add = push_data(*add,ta_id);
609 verts[e1] = T_NTH_V(t1,e1);
610 verts[e1next] = T_NTH_V(t,eprev);
611 verts[e1prev] = T_NTH_V(t1,e1prev);
612 tb_id = smAdd_tri(sm,verts[0],verts[1],verts[2],&tb);
613 *add = push_data(*add,tb_id);
614
615 /* set the neighbors */
616 T_NTH_NBR(ta,e) = T_NTH_NBR(t1,e1next);
617 T_NTH_NBR(tb,e1) = T_NTH_NBR(t,enext);
618 T_NTH_NBR(ta,enext) = tb_id;
619 T_NTH_NBR(tb,e1next) = ta_id;
620 T_NTH_NBR(ta,eprev) = T_NTH_NBR(t,eprev);
621 T_NTH_NBR(tb,e1prev) = T_NTH_NBR(t1,e1prev);
622
623 /* Reset neighbor pointers of original neighbors */
624 n = SM_NTH_TRI(sm,T_NTH_NBR(t,enext));
625 T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = tb_id;
626 n = SM_NTH_TRI(sm,T_NTH_NBR(t,eprev));
627 T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = ta_id;
628
629 n = SM_NTH_TRI(sm,T_NTH_NBR(t1,e1next));
630 T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = ta_id;
631 n = SM_NTH_TRI(sm,T_NTH_NBR(t1,e1prev));
632 T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = tb_id;
633
634 /* Delete two parent triangles */
635
636 *del = push_data(*del,t_id);
637 T_VALID_FLAG(t) = -1;
638 *del = push_data(*del,t1_id);
639 T_VALID_FLAG(t1) = -1;
640 *tn_id = ta_id;
641 *tn1_id = tb_id;
642 }
643
644 smUpdate_locator(sm,add_list,del_list)
645 SM *sm;
646 LIST *add_list,*del_list;
647 {
648 int t_id;
649 TRI *t;
650 while(add_list)
651 {
652 t_id = pop_list(&add_list);
653 t = SM_NTH_TRI(sm,t_id);
654 if(!T_IS_VALID(t))
655 {
656 T_VALID_FLAG(t) = 1;
657 continue;
658 }
659 smLocator_add_tri(sm,t_id,T_NTH_V(t,0),T_NTH_V(t,1),T_NTH_V(t,2));
660 }
661
662 while(del_list)
663 {
664 t_id = pop_list(&del_list);
665 t = SM_NTH_TRI(sm,t_id);
666 if(!T_IS_VALID(t))
667 {
668 smLocator_remove_tri(sm,t_id);
669 }
670 smDelete_tri(sm,t_id);
671 }
672 }
673 /* MUST add check for constrained edges */
674 int
675 smFix_tris(sm,id,tlist,add_list,del_list)
676 SM *sm;
677 int id;
678 LIST *tlist;
679 LIST *add_list,*del_list;
680 {
681 TRI *t,*t_opp;
682 FVECT p,p1,p2,p3;
683 int e,e1,swapped = 0;
684 int t_id,t_opp_id;
685
686
687 VSUB(p,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm));
688 while(tlist)
689 {
690 t_id = pop_list(&tlist);
691 t = SM_NTH_TRI(sm,t_id);
692 e = (T_WHICH_V(t,id)+1)%3;
693 t_opp_id = T_NTH_NBR(t,e);
694 t_opp = SM_NTH_TRI(sm,t_opp_id);
695 /*
696 VSUB(p1,SM_T_NTH_WV(sm,t_opp,0),SM_VIEW_CENTER(sm));
697 VSUB(p2,SM_T_NTH_WV(sm,t_opp,1),SM_VIEW_CENTER(sm));
698 VSUB(p3,SM_T_NTH_WV(sm,t_opp,2),SM_VIEW_CENTER(sm));
699 */
700 smDir(sm,p1,T_NTH_V(t_opp,0));
701 smDir(sm,p2,T_NTH_V(t_opp,1));
702 smDir(sm,p3,T_NTH_V(t_opp,2));
703 if(point_in_cone(p,p1,p2,p3))
704 {
705 swapped = 1;
706 e1 = T_NTH_NBR_PTR(t_id,t_opp);
707 /* check list for t_opp and Remove if there */
708 remove_from_list(t_opp_id,&tlist);
709 smTris_swap_edge(sm,t_id,t_opp_id,e,e1,&t_id,&t_opp_id,
710 &add_list,&del_list);
711 tlist = push_data(tlist,t_id);
712 tlist = push_data(tlist,t_opp_id);
713 }
714 }
715 smUpdate_locator(sm,add_list,del_list);
716 return(swapped);
717 }
718
719 /* Give the vertex "id" and a triangle "t" that it belongs to- return the
720 next nbr in a counter clockwise order about vertex "id"
721 */
722 int
723 smTri_next_ccw_nbr(sm,t,id)
724 SM *sm;
725 TRI *t;
726 int id;
727 {
728 int t_id;
729 int tri;
730
731 /* Want the edge for which "id" is the destination */
732 t_id = (T_WHICH_V(t,id)+ 2)% 3;
733 tri = T_NTH_NBR(t,t_id);
734 return(tri);
735 }
736
737 void
738 smReplace_point(sm,tri,id,nid)
739 SM *sm;
740 TRI *tri;
741 int id,nid;
742 {
743 TRI *t;
744 int t_id;
745
746 T_NTH_V(tri,T_WHICH_V(tri,id)) = nid;
747
748 t_id = smTri_next_ccw_nbr(sm,tri,nid);
749 while((t = SM_NTH_TRI(sm,t_id)) != tri)
750 {
751 T_NTH_V(t,T_WHICH_V(t,id)) = nid;
752 t_id = smTri_next_ccw_nbr(sm,t,nid);
753 }
754 }
755
756
757 smClear_tri_flags(sm,id)
758 SM *sm;
759 int id;
760 {
761 int i;
762
763 for(i=0; i < T_FLAGS; i++)
764 SM_CLEAR_NTH_T_FLAG(sm,id,i);
765
766 }
767
768 /* Locate the point-id in the point location structure: */
769 int
770 smReplace_vertex(sm,c,dir,p,tri_id,snew_id,type,which)
771 SM *sm;
772 COLR c;
773 FVECT dir,p;
774 int tri_id,snew_id;
775 int type,which;
776 {
777 int n_id,s_id;
778 TRI *tri;
779
780 tri = SM_NTH_TRI(sm,tri_id);
781 /* Get the sample that corresponds to the "which" vertex of "tri" */
782 /* NEED: have re-init that sets clock flag */
783 /* If this is a base-sample: create a new sample and replace
784 all references to the base sample with references to the
785 new sample
786 */
787 s_id = T_NTH_V(tri,which);
788 if(SM_BASE_ID(sm,s_id))
789 {
790 if(snew_id != -1)
791 n_id = smAdd_sample_point(sm,c,dir,p);
792 else
793 n_id = snew_id;
794 smReplace_point(sm,tri,s_id,n_id);
795 s_id = n_id;
796 }
797 else /* If the sample exists, reset the values */
798 /* NOTE: This test was based on the SPHERICAL coordinates
799 of the point: If we are doing a multiple-sample-per
800 SPHERICAL pixel: we will want to test for equality-
801 and do other processing: for now: SINGLE SAMPLE PER
802 PIXEL
803 */
804 /* NOTE: snew_id needs to be marked as invalid?*/
805 if(snew_id == -1)
806 smInit_sample(sm,s_id,c,dir,p);
807 else
808 smReset_sample(sm,s_id,snew_id);
809 return(s_id);
810 }
811
812
813 /* Locate the point-id in the point location structure: */
814 int
815 smInsert_point_in_tri(sm,c,dir,p,s_id,tri_id)
816 SM *sm;
817 COLR c;
818 FVECT dir,p;
819 int s_id,tri_id;
820 {
821 TRI *tri,*t0,*t1,*t2,*nbr;
822 int v0_id,v1_id,v2_id,n_id;
823 int t0_id,t1_id,t2_id;
824 LIST *tlist,*add_list,*del_list;
825 FVECT npt;
826
827 add_list = del_list = NULL;
828 if(s_id == SM_INVALID)
829 s_id = smAdd_sample_point(sm,c,dir,p);
830
831 tri = SM_NTH_TRI(sm,tri_id);
832 v0_id = T_NTH_V(tri,0);
833 v1_id = T_NTH_V(tri,1);
834 v2_id = T_NTH_V(tri,2);
835
836 n_id = -1;
837 if(SM_BASE_ID(sm,v0_id)||SM_BASE_ID(sm,v1_id)||SM_BASE_ID(sm,v2_id))
838 {
839 smDir(sm,npt,s_id);
840 /* Change to an add and delete */
841 t0_id = (SM_BASE_ID(sm,v0_id))?v0_id:-1;
842 t1_id = (SM_BASE_ID(sm,v1_id))?v1_id:-1;
843 t2_id = (SM_BASE_ID(sm,v2_id))?v2_id:-1;
844 n_id = smClosest_vertex_in_tri(sm,t0_id,t1_id,t2_id,npt,P_REPLACE_EPS);
845 }
846 t0_id = smAdd_tri(sm,s_id,v0_id,v1_id,&t0);
847 /* Add triangle to the locator */
848
849 add_list = push_data(add_list,t0_id);
850
851 t1_id = smAdd_tri(sm,s_id,v1_id,v2_id,&t1);
852 add_list = push_data(add_list,t1_id);
853
854 t2_id = smAdd_tri(sm,s_id,v2_id,v0_id,&t2);
855 add_list = push_data(add_list,t2_id);
856
857 /* Set the neighbor pointers for the new tris */
858 T_NTH_NBR(t0,0) = t2_id;
859 T_NTH_NBR(t0,1) = T_NTH_NBR(tri,0);
860 T_NTH_NBR(t0,2) = t1_id;
861 T_NTH_NBR(t1,0) = t0_id;
862 T_NTH_NBR(t1,1) = T_NTH_NBR(tri,1);
863 T_NTH_NBR(t1,2) = t2_id;
864 T_NTH_NBR(t2,0) = t1_id;
865 T_NTH_NBR(t2,1) = T_NTH_NBR(tri,2);
866 T_NTH_NBR(t2,2) = t0_id;
867
868 /* Reset the neigbor pointers for the neighbors of the original */
869 nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,0));
870 T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t0_id;
871 nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,1));
872 T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t1_id;
873 nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,2));
874 T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t2_id;
875
876 del_list = push_data(del_list,tri_id);
877 T_VALID_FLAG(tri) = -1;
878
879 /* Fix up the new triangles*/
880 tlist = push_data(NULL,t0_id);
881 tlist = push_data(tlist,t1_id);
882 tlist = push_data(tlist,t2_id);
883
884 smFix_tris(sm,s_id,tlist,add_list,del_list);
885
886 if(n_id != -1)
887 smDelete_point(sm,n_id);
888
889 return(s_id);
890 }
891
892
893 int
894 smPointLocate(sm,pt,norm)
895 SM *sm;
896 FVECT pt;
897 int norm;
898 {
899 STREE *st;
900 int tri;
901 FVECT npt;
902
903 st = SM_LOCATOR(sm);
904 if(norm)
905 {
906 VSUB(npt,pt,SM_VIEW_CENTER(sm));
907 tri = stPoint_locate(st,npt);
908 }
909 else
910 tri = stPoint_locate(st,pt);
911 return(tri);
912 }
913
914 QUADTREE
915 smPointLocateCell(sm,pt,norm,v0,v1,v2)
916 SM *sm;
917 FVECT pt;
918 int norm;
919 FVECT v0,v1,v2;
920 {
921 STREE *st;
922 QUADTREE *qtptr;
923 FVECT npt;
924
925 st = SM_LOCATOR(sm);
926 if(norm)
927 {
928 VSUB(npt,pt,SM_VIEW_CENTER(sm));
929
930 qtptr = stPoint_locate_cell(st,npt,v0,v1,v2);
931 }
932 else
933 qtptr = stPoint_locate_cell(st,pt,v0,v1,v2);
934
935 if(qtptr)
936 return(*qtptr);
937 else
938 return(EMPTY);
939 }
940
941 int
942 smAdd_sample_to_mesh(sm,c,dir,pt,s_id)
943 SM *sm;
944 COLR c;
945 FVECT dir,pt;
946 int s_id;
947 {
948 int t_id;
949 double d;
950 FVECT p;
951
952 /* If new, foreground pt */
953 if(pt)
954 {
955 /* NOTE: This should be elsewhere! */
956 d = DIST(pt,SM_VIEW_CENTER(smMesh));
957 smDist_sum += 1.0/d;
958 /************************************/
959 t_id = smPointLocate(smMesh,pt,TRUE);
960 if(t_id >= 0)
961 s_id = smInsert_point_in_tri(smMesh,c,dir,pt,s_id,t_id);
962 #ifdef DEBUG
963 else
964 {
965 c[0] = 255;c[1]=0;c[2]=0;
966 s_id = smAdd_sample_point(sm,c,dir,pt);
967 eputs("smAdd_sample_to_mesh(): not found fg\n");
968 }
969 #endif
970 }
971 else if(s_id != -1)
972 {
973 VCOPY(p,SM_NTH_WV(sm,s_id));
974 if(SM_NTH_W_DIR(sm,s_id) != -1)
975 {
976 /* NOTE: This should be elsewhere! */
977 d = DIST(p,SM_VIEW_CENTER(smMesh));
978 smDist_sum += 1.0/d;
979 /************************************/
980 }
981 t_id = smPointLocate(smMesh,p,TRUE);
982 if(t_id != -1)
983 s_id = smInsert_point_in_tri(smMesh,c,dir,p,s_id,t_id);
984 #ifdef DEBUG
985 else
986 eputs("smAdd_sample_to_mesh():not found reinsert\n");
987 #endif
988 }
989 /* Is a BG(sky point) */
990 else
991 {
992 t_id = smPointLocate(smMesh,dir,FALSE);
993 if(t_id != -1)
994 s_id = smInsert_point_in_tri(smMesh,c,dir,NULL,s_id,t_id);
995
996 #ifdef DEBUG
997 else
998 eputs("smAdd_sample_to_mesh(): not found bg\n");
999 #endif
1000 }
1001 return(s_id);
1002 }
1003
1004 /*
1005 * int
1006 * smNewSamp(c, dir, p) : register new sample point and return index
1007 * COLR c; : pixel color (RGBE)
1008 * FVECT dir; : ray direction vector
1009 * FVECT p; : world intersection point
1010 *
1011 * Add new sample point to data structures, removing old values as necessary.
1012 * New sample representation will be output in next call to smUpdate().
1013 * If the point is a sky point: then v=NULL
1014 */
1015 int
1016 smNewSamp(c,dir,p)
1017 COLR c;
1018 FVECT dir;
1019 FVECT p;
1020
1021 {
1022 int s_id;
1023 int debug=0;
1024
1025 /* First check if this the first sample: if so initialize mesh */
1026 if(SM_NUM_SAMP(smMesh) == 0)
1027 smInit_mesh(smMesh,odev.v.vp);
1028 if(!debug)
1029 s_id = smAdd_sample_to_mesh(smMesh,c,dir,p,-1);
1030 return(s_id);
1031
1032 }
1033 /*
1034 * int
1035 * smFindsamp(orig, dir): intersect ray with 3D rep. and find closest sample
1036 * FVECT orig, dir;
1037 *
1038 * Find the closest sample to the given ray. Return -1 on failure.
1039 */
1040
1041 /*
1042 * smClean() : display has been wiped clean
1043 *
1044 * Called after display has been effectively cleared, meaning that all
1045 * geometry must be resent down the pipeline in the next call to smUpdate().
1046 */
1047
1048
1049 /*
1050 * smUpdate(vp, qua) : update OpenGL output geometry for view vp
1051 * VIEW *vp; : desired view
1052 * int qua; : quality level (percentage on linear time scale)
1053 *
1054 * Draw new geometric representation using OpenGL calls. Assume that the
1055 * view has already been set up and the correct frame buffer has been
1056 * selected for drawing. The quality level is on a linear scale, where 100%
1057 * is full (final) quality. It is not necessary to redraw geometry that has
1058 * been output since the last call to smClean().
1059 */
1060
1061
1062 int
1063 smClear_vert(sm,id)
1064 SM *sm;
1065 int id;
1066 {
1067 if(SM_INVALID_POINT_ID(sm,id))
1068 return(FALSE);
1069
1070 SM_NTH_VERT(sm,id) = SM_INVALID;
1071
1072 return(TRUE);
1073 }
1074
1075 int
1076 smAdd_base_vertex(sm,v,d)
1077 SM *sm;
1078 FVECT v,d;
1079 {
1080 int id;
1081
1082 /* First add coordinate to the sample array */
1083 id = smAdd_aux_point(sm,v,d);
1084 if(id == -1)
1085 return(SM_INVALID);
1086 /* Initialize triangle pointer to -1 */
1087 smClear_vert(sm,id);
1088 return(id);
1089 }
1090
1091
1092
1093 /* Initialize a the point location DAG based on a 6 triangle tesselation
1094 of the unit sphere centered on the view center. The DAG structure
1095 contains 6 roots: one for each initial base triangle
1096 */
1097
1098 int
1099 smCreate_base_mesh(sm,type)
1100 SM *sm;
1101 int type;
1102 {
1103 int i,id,tri_id,nbr_id;
1104 int p[4],ids[4];
1105 int v0_id,v1_id,v2_id;
1106 TRI *tris[4];
1107 FVECT d,pt,cntr;
1108
1109 /* First insert the base vertices into the sample point array */
1110
1111 for(i=0; i < 4; i++)
1112 {
1113 VCOPY(cntr,stDefault_base[i]);
1114 cntr[0] += .01;
1115 cntr[1] += .02;
1116 cntr[2] += .03;
1117 VADD(cntr,cntr,SM_VIEW_CENTER(sm));
1118 /* WONT use dir */
1119 point_on_sphere(d,cntr,SM_VIEW_CENTER(sm));
1120 id = smAdd_base_vertex(sm,cntr,d);
1121 /* test to make sure vertex allocated */
1122 if(id != -1)
1123 p[i] = id;
1124 else
1125 return(0);
1126 }
1127 /* Create the base triangles */
1128 for(i=0;i < 4; i++)
1129 {
1130 v0_id = p[stTri_verts[i][0]];
1131 v1_id = p[stTri_verts[i][1]];
1132 v2_id = p[stTri_verts[i][2]];
1133 if((ids[i] = smAdd_tri(sm, v0_id,v1_id,v2_id,&(tris[i])))== -1)
1134 return(0);
1135 smLocator_add_tri(sm,ids[i],v0_id,v1_id,v2_id);
1136 }
1137 /* Set neighbors */
1138
1139 for(tri_id=0;tri_id < 4; tri_id++)
1140 for(nbr_id=0; nbr_id < 3; nbr_id++)
1141 T_NTH_NBR(tris[tri_id],nbr_id) = smBase_nbrs[tri_id][nbr_id];
1142
1143 return(1);
1144
1145 }
1146
1147
1148 int
1149 smNext_tri_flag_set(sm,i,which,b)
1150 SM *sm;
1151 int i,which;
1152 int b;
1153 {
1154
1155 for(; i < SM_TRI_CNT(sm);i++)
1156 {
1157
1158 if(!SM_IS_NTH_T_FLAG(sm,i,which))
1159 continue;
1160 if(!b)
1161 break;
1162 if((b==1) && !SM_BG_TRI(sm,i))
1163 break;
1164 if((b==2) && SM_BG_TRI(sm,i))
1165 break;
1166 }
1167
1168 return(i);
1169 }
1170
1171
1172 int
1173 smNext_valid_tri(sm,i)
1174 SM *sm;
1175 int i;
1176 {
1177
1178 while( i < SM_TRI_CNT(sm) && !T_IS_VALID(SM_NTH_TRI(sm,i)))
1179 i++;
1180
1181 return(i);
1182 }
1183
1184
1185
1186 qtTri_from_id(t_id,v0,v1,v2,n0,n1,n2,v0_idp,v1_idp,v2_idp)
1187 int t_id;
1188 FVECT v0,v1,v2;
1189 FVECT n0,n1,n2;
1190 int *v0_idp,*v1_idp,*v2_idp;
1191 {
1192 TRI *t;
1193 int v0_id,v1_id,v2_id;
1194
1195 t = SM_NTH_TRI(smMesh,t_id);
1196 v0_id = T_NTH_V(t,0);
1197 v1_id = T_NTH_V(t,1);
1198 v2_id = T_NTH_V(t,2);
1199
1200 if(v0)
1201 {
1202 VCOPY(v0,SM_NTH_WV(smMesh,v0_id));
1203 VCOPY(v1,SM_NTH_WV(smMesh,v1_id));
1204 VCOPY(v2,SM_NTH_WV(smMesh,v2_id));
1205 }
1206 if(n0)
1207 {
1208 smDir(smMesh,n0,v0_id);
1209 smDir(smMesh,n1,v1_id);
1210 smDir(smMesh,n2,v2_id);
1211
1212 }
1213 if(v0_idp)
1214 {
1215 *v0_idp = v0_id;
1216 *v1_idp = v1_id;
1217 *v2_idp = v2_id;
1218 }
1219 }
1220
1221
1222 /*
1223 * int
1224 * smFindSamp(FVECT orig, FVECT dir)
1225 *
1226 * Find the closest sample to the given ray. Returns sample id, -1 on failure.
1227 * "dir" is assumed to be normalized
1228 */
1229
1230
1231
1232 smRebuild_mesh(sm,vp)
1233 SM *sm;
1234 FVECT vp;
1235 {
1236 int i;
1237 FVECT dir;
1238 COLR c;
1239 FVECT p,ov;
1240
1241 /* Clear the mesh- and rebuild using the current sample array */
1242
1243 VSUB(ov,vp,SM_VIEW_CENTER(sm));
1244 smInit_mesh(sm,vp);
1245
1246 SM_FOR_ALL_SAMPLES(sm,i)
1247 {
1248 if(SM_NTH_W_DIR(sm,i)==-1)
1249 VADD(SM_NTH_WV(sm,i),SM_NTH_WV(sm,i),ov);
1250 smAdd_sample_to_mesh(sm,NULL,NULL,NULL,i);
1251 }
1252 }
1253
1254 int
1255 intersect_tri_set(t_set,orig,dir,pt)
1256 OBJECT *t_set;
1257 FVECT orig,dir,pt;
1258 {
1259 OBJECT *optr;
1260 int i,t_id,id;
1261 int pid0,pid1,pid2;
1262 FVECT p0,p1,p2,p;
1263 TRI *t;
1264
1265 optr = QT_SET_PTR(t_set);
1266 for(i = QT_SET_CNT(t_set); i > 0; i--)
1267 {
1268 t_id = QT_SET_NEXT_ELEM(optr);
1269
1270 t = SM_NTH_TRI(smMesh,t_id);
1271 pid0 = T_NTH_V(t,0);
1272 pid1 = T_NTH_V(t,1);
1273 pid2 = T_NTH_V(t,2);
1274 VCOPY(p0,SM_NTH_WV(smMesh,pid0));
1275 VCOPY(p1,SM_NTH_WV(smMesh,pid1));
1276 VCOPY(p2,SM_NTH_WV(smMesh,pid2));
1277 if(ray_intersect_tri(orig,dir,p0,p1,p2,p))
1278 {
1279 id = closest_point_in_tri(p0,p1,p2,p,pid0,pid1,pid2);
1280
1281 if(pt)
1282 VCOPY(pt,p);
1283 #ifdef DEBUG_TEST_DRIVER
1284 Pick_tri = t_id;
1285 Pick_samp = id;
1286 VCOPY(Pick_point[0],p);
1287 #endif
1288 return(id);
1289 }
1290 }
1291 return(-1);
1292 }
1293
1294 int
1295 ray_trace_check_set(qtptr,orig,dir,tptr,os)
1296 QUADTREE *qtptr;
1297 FVECT orig,dir;
1298 int *tptr;
1299 OBJECT *os;
1300 {
1301 OBJECT tset[QT_MAXSET+1];
1302 double dt,t;
1303 int found;
1304 FVECT o;
1305
1306
1307 if(!QT_IS_EMPTY(*qtptr))
1308 {
1309 VADD(o,orig,SM_VIEW_CENTER(smMesh));
1310 qtgetset(tset,*qtptr);
1311 /* Check triangles in set against those seen so far(os):only
1312 check new triangles for intersection (t_set')
1313 */
1314 check_set(tset,os);
1315 if((found = intersect_tri_set(tset,o,dir,NULL))!= -1)
1316 {
1317 *tptr = found;
1318 return(QT_DONE);
1319 }
1320 }
1321 return(FALSE);
1322 }
1323
1324 int
1325 smFindSamp(orig,dir)
1326 FVECT orig,dir;
1327 {
1328 FVECT b,p,o;
1329 OBJECT *ts;
1330 QUADTREE qt;
1331 int s_id;
1332 double d;
1333
1334 /* r is the normalized vector from the view center to the current
1335 * ray point ( starting with "orig"). Find the cell that r falls in,
1336 * and test the ray against all triangles stored in the cell. If
1337 * the test fails, trace the projection of the ray across to the
1338 * next cell it intersects: iterate until either an intersection
1339 * is found, or the projection ray is // to the direction. The sample
1340 * corresponding to the triangle vertex closest to the intersection
1341 * point is returned.
1342 */
1343
1344 /* First test if "orig" coincides with the View_center or if "dir" is
1345 parallel to r formed by projecting "orig" on the sphere. In
1346 either case, do a single test against the cell containing the
1347 intersection of "dir" and the sphere
1348 */
1349 /* orig will be updated-so preserve original value */
1350 if(!smMesh)
1351 return;
1352 point_on_sphere(b,orig,SM_VIEW_CENTER(smMesh));
1353 d = -DOT(b,dir);
1354 if(EQUAL_VEC3(orig,SM_VIEW_CENTER(smMesh)) || EQUAL(fabs(d),1.0))
1355 {
1356 qt = smPointLocateCell(smMesh,dir,FALSE,NULL,NULL,NULL);
1357 /* Test triangles in the set for intersection with Ray:returns
1358 first found
1359 */
1360 ts = qtqueryset(qt);
1361 s_id = intersect_tri_set(ts,orig,dir,p);
1362 #ifdef DEBUG_TEST_DRIVER
1363 VCOPY(Pick_point[0],p);
1364 #endif
1365 }
1366 else
1367 {
1368 OBJECT t_set[QT_MAXCSET+1];
1369 /* Test each of the root triangles against point id */
1370 QT_CLEAR_SET(t_set);
1371 VSUB(o,orig,SM_VIEW_CENTER(smMesh));
1372 ST_CLEAR_FLAGS(SM_LOCATOR(smMesh));
1373 s_id=stTrace_ray(SM_LOCATOR(smMesh),o,dir,ray_trace_check_set,&s_id,t_set);
1374 }
1375 return(s_id);
1376 }
1377
1378
1379
1380
1381
1382
1383
1384
1385
1386
1387
1388
