--- ray/src/hd/sm.c 1998/09/14 10:33:46 3.6 +++ ray/src/hd/sm.c 1998/11/11 12:05:37 3.9 @@ -8,23 +8,34 @@ static char SCCSid[] = "$SunId$ SGI"; * sm.c */ #include "standard.h" +#include "sm_flag.h" #include "sm_list.h" #include "sm_geom.h" +#include "sm_qtree.h" +#include "sm_stree.h" #include "sm.h" SM *smMesh = NULL; double smDist_sum=0; int smNew_tri_cnt=0; +double smMinSampDiff = 1.7e-3; /* min edge length in radians */ -static int smBase_nbrs[4][3] = { {3,2,1},{3,0,2},{3,1,0},{1,2,0}}; +static FVECT smDefault_base[4] = { {SQRT3_INV, SQRT3_INV, SQRT3_INV}, + {-SQRT3_INV, -SQRT3_INV, SQRT3_INV}, + {-SQRT3_INV, SQRT3_INV, -SQRT3_INV}, + {SQRT3_INV, -SQRT3_INV, -SQRT3_INV}}; +static int smTri_verts[4][3] = { {0,1,2},{0,2,3},{0,3,1},{1,3,2}}; +static int smBase_nbrs[4][3] = { {3,1,2},{3,2,0},{3,0,1},{1,0,2}}; + #ifdef TEST_DRIVER VIEW Current_View = {0,{0,0,0},{0,0,-1},{0,1,0},60,60,0}; int Pick_cnt =0; int Pick_tri = -1,Picking = FALSE,Pick_samp=-1; FVECT Pick_point[500],Pick_origin,Pick_dir; FVECT Pick_v0[500], Pick_v1[500], Pick_v2[500]; +int Pick_q[500]; FVECT P0,P1,P2; FVECT FrustumNear[4],FrustumFar[4]; double dev_zmin=.01,dev_zmax=1000; @@ -35,19 +46,18 @@ smDir(sm,ps,id) FVECT ps; int id; { - FVECT p; - - VCOPY(p,SM_NTH_WV(sm,id)); - point_on_sphere(ps,p,SM_VIEW_CENTER(sm)); + VSUB(ps,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm)); + normalize(ps); } -smClear_mesh(sm) - SM *sm; +smDir_in_cone(sm,ps,id) + SM *sm; + FVECT ps; + int id; { - /* Reset the triangle counters */ - SM_TRI_CNT(sm) = 0; - SM_NUM_TRIS(sm) = 0; - SM_FREE_TRIS(sm) = -1; + + VSUB(ps,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm)); + normalize(ps); } smClear_flags(sm,which) @@ -58,95 +68,132 @@ int which; if(which== -1) for(i=0; i < T_FLAGS;i++) - bzero(SM_NTH_FLAGS(sm,i),T_TOTAL_FLAG_BYTES(SM_MAX_TRIS(sm))); + bzero(SM_NTH_FLAGS(sm,i),FLAG_BYTES(SM_MAX_TRIS(sm))); else - bzero(SM_NTH_FLAGS(sm,which),T_TOTAL_FLAG_BYTES(SM_MAX_TRIS(sm))); + bzero(SM_NTH_FLAGS(sm,which),FLAG_BYTES(SM_MAX_TRIS(sm))); } -smClear_locator(sm) -SM *sm; +/* Given an allocated mesh- initialize */ +smInit_mesh(sm) + SM *sm; { - STREE *st; - - st = SM_LOCATOR(sm); - - stClear(st); + /* Reset the triangle counters */ + SM_NUM_TRI(sm) = 0; + SM_SAMPLE_TRIS(sm) = 0; + SM_FREE_TRIS(sm) = -1; + smClear_flags(sm,-1); } -smInit_locator(sm,center,base) -SM *sm; -FVECT center,base[4]; -{ - STREE *st; - - st = SM_LOCATOR(sm); - - stInit(st,center,base); -} - +/* Clear the SM for reuse: free any extra allocated memory:does initialization + as well +*/ smClear(sm) SM *sm; { smClear_samples(sm); - smClear_mesh(sm); smClear_locator(sm); + smInit_mesh(sm); } +static int realloc_cnt=0; + int -smAlloc_tris(sm,max_verts,max_tris) +smRealloc_mesh(sm) SM *sm; +{ + int fbytes,i,max_tris,max_verts; + + if(realloc_cnt <=0) + realloc_cnt = SM_MAX_TRIS(sm); + + max_tris = SM_MAX_TRIS(sm) + realloc_cnt; + fbytes = FLAG_BYTES(max_tris); + + if(!(SM_TRIS(sm) = (TRI *)realloc(SM_TRIS(sm),max_tris*sizeof(TRI)))) + goto memerr; + + for(i=0; i< T_FLAGS; i++) + if(!(SM_NTH_FLAGS(sm,i)=(int4 *)realloc((char *)SM_NTH_FLAGS(sm,i),fbytes))) + goto memerr; + + SM_MAX_TRIS(sm) = max_tris; + return(max_tris); + +memerr: + error(SYSTEM, "out of memory in smRealloc_mesh()"); +} + +/* Allocate and initialize a new mesh with max_verts and max_tris */ +int +smAlloc_mesh(sm,max_verts,max_tris) +SM *sm; int max_verts,max_tris; { - int i,nbytes,vbytes,fbytes; + int fbytes,i; - vbytes = max_verts*sizeof(VERT); - fbytes = T_TOTAL_FLAG_BYTES(max_tris); - nbytes = vbytes + max_tris*sizeof(TRI) +T_FLAGS*fbytes + 8; - for(i = 1024; nbytes > i; i <<= 1) - ; - /* check if casting works correctly */ - max_tris = (i-vbytes-8)/(sizeof(TRI) + T_FLAG_BYTES); - fbytes = T_TOTAL_FLAG_BYTES(max_tris); - - SM_BASE(sm)=(char *)malloc(vbytes+max_tris*sizeof(TRI)+T_FLAGS*fbytes); + fbytes = FLAG_BYTES(max_tris); - if (SM_BASE(sm) == NULL) - return(0); + if(!(SM_TRIS(sm) = (TRI *)realloc(NULL,max_tris*sizeof(TRI)))) + goto memerr; - SM_TRIS(sm) = (TRI *)SM_BASE(sm); - SM_VERTS(sm) = (VERT *)(SM_TRIS(sm) + max_tris); + if(!(SM_VERTS(sm) = (VERT *)realloc(NULL,max_verts*sizeof(VERT)))) + goto memerr; - SM_NTH_FLAGS(sm,0) = (int4 *)(SM_VERTS(sm) + max_verts); - for(i=1; i < T_FLAGS; i++) - SM_NTH_FLAGS(sm,i) = (int4 *)(SM_NTH_FLAGS(sm,i-1)+fbytes/sizeof(int4)); - + for(i=0; i< T_FLAGS; i++) + if(!(SM_NTH_FLAGS(sm,i)=(int4 *)realloc(NULL,fbytes))) + goto memerr; + SM_MAX_VERTS(sm) = max_verts; SM_MAX_TRIS(sm) = max_tris; - smClear_mesh(sm); + realloc_cnt = max_verts >> 1; + smInit_mesh(sm); + return(max_tris); +memerr: + error(SYSTEM, "out of memory in smAlloc_mesh()"); } - int -smAlloc_locator(sm) +smAlloc_tri(sm) SM *sm; { - STREE *st; - - st = SM_LOCATOR(sm); - - st = stAlloc(st); - - if(st) - return(TRUE); - else - return(FALSE); + int id; + + /* First check if there are any tris on the free list */ + /* Otherwise, have we reached the end of the list yet?*/ + if(SM_NUM_TRI(sm) < SM_MAX_TRIS(sm)) + return(SM_NUM_TRI(sm)++); + + if((id = SM_FREE_TRIS(sm)) != -1) + { + SM_FREE_TRIS(sm) = T_NEXT_FREE(SM_NTH_TRI(sm,id)); + return(id); + } + + /*Else: realloc */ + smRealloc_mesh(sm); + return(SM_NUM_TRI(sm)++); } +smFree_mesh(sm) +SM *sm; +{ + int i; + + if(SM_TRIS(sm)) + free(SM_TRIS(sm)); + if(SM_VERTS(sm)) + free(SM_VERTS(sm)); + for(i=0; i< T_FLAGS; i++) + if(SM_NTH_FLAGS(sm,i)) + free(SM_NTH_FLAGS(sm,i)); +} + + /* Initialize/clear global smL sample list for at least n samples */ smAlloc(max_samples) register int max_samples; @@ -154,56 +201,53 @@ smAlloc(max_samples) unsigned nbytes; register unsigned i; int total_points; - int max_tris; + int max_tris,n; + n = max_samples; /* If this is the first call, allocate sample,vertex and triangle lists */ if(!smMesh) { if(!(smMesh = (SM *)malloc(sizeof(SM)))) - error(SYSTEM,"smAlloc():Unable to allocate memory"); + error(SYSTEM,"smAlloc():Unable to allocate memory\n"); bzero(smMesh,sizeof(SM)); } else { /* If existing structure: first deallocate */ - if(SM_BASE(smMesh)) - free(SM_BASE(smMesh)); - if(SM_SAMP_BASE(smMesh)) - free(SM_SAMP_BASE(smMesh)); - } + smFree_mesh(smMesh); + smFree_samples(smMesh); + smFree_locator(smMesh); + } /* First allocate at least n samples + extra points:at least enough necessary to form the BASE MESH- Default = 4; */ - max_samples = smAlloc_samples(smMesh, max_samples,SM_EXTRA_POINTS); + SM_SAMP(smMesh) = sAlloc(&n,SM_EXTRA_POINTS); - total_points = max_samples + SM_EXTRA_POINTS; - max_tris = total_points*2; + total_points = n + SM_EXTRA_POINTS; + max_tris = total_points*4; /* Now allocate space for mesh vertices and triangles */ - max_tris = smAlloc_tris(smMesh, total_points, max_tris); + max_tris = smAlloc_mesh(smMesh, total_points, max_tris); /* Initialize the structure for point,triangle location. */ smAlloc_locator(smMesh); - } -smInit_mesh(sm,vp) +smInit_sm(sm,vp) SM *sm; FVECT vp; { - /* NOTE: Should be elsewhere?*/ smDist_sum = 0; smNew_tri_cnt = 0; - VCOPY(SM_VIEW_CENTER(smMesh),vp); - smClear_locator(sm); - smInit_locator(sm,vp,0); - smClear_aux_samples(sm); - smClear_mesh(sm); + VCOPY(SM_VIEW_CENTER(sm),vp); + smInit_locator(sm,vp); + smInit_samples(sm); + smInit_mesh(sm); smCreate_base_mesh(sm,SM_DEFAULT); } @@ -224,6 +268,7 @@ smInit(n) { int max_vertices; + /* If n <=0, Just clear the existing structures */ if(n <= 0) { @@ -237,7 +282,8 @@ smInit(n) max_vertices = n + SM_EXTRA_POINTS; /* If the current mesh contains enough room, clear and return */ - if(smMesh && max_vertices <= SM_MAX_VERTS(smMesh)) + if(smMesh && (max_vertices <= SM_MAX_VERTS(smMesh)) && SM_MAX_SAMP(smMesh) <= + n && SM_MAX_POINTS(smMesh) <= max_vertices) { smClear(smMesh); return(SM_MAX_SAMP(smMesh)); @@ -251,15 +297,14 @@ smInit(n) } -int -smLocator_apply_func(sm,v0,v1,v2,func,arg) -SM *sm; -FVECT v0,v1,v2; -int (*func)(); -int *arg; +smLocator_apply_func(sm,v0,v1,v2,edge_func,tri_func,argptr) + SM *sm; + FVECT v0,v1,v2; + int (*edge_func)(); + int (*tri_func)(); + int *argptr; { STREE *st; - int found; FVECT p0,p1,p2; st = SM_LOCATOR(sm); @@ -268,201 +313,233 @@ int *arg; VSUB(p1,v1,SM_VIEW_CENTER(sm)); VSUB(p2,v2,SM_VIEW_CENTER(sm)); - found = stApply_to_tri_cells(st,p0,p1,p2,func,arg); + stApply_to_tri(st,p0,p1,p2,edge_func,tri_func,argptr); - return(found); } +QUADTREE +delete_tri_set(qt,optr,del_set) +QUADTREE qt; +OBJECT *optr,*del_set; +{ -int -add_tri_expand(qtptr,q0,q1,q2,t0,t1,t2,n,arg,t_id) + int set_size,i,t_id; + OBJECT *rptr,r_set[QT_MAXSET+1]; + OBJECT *tptr,t_set[QT_MAXSET+1],*sptr; + + /* First need to check if set size larger than QT_MAXSET: if so + need to allocate larger array + */ + if((set_size = MAX(QT_SET_CNT(optr),QT_SET_CNT(del_set))) >QT_MAXSET) + rptr = (OBJECT *)malloc((set_size+1)*sizeof(OBJECT)); + else + rptr = r_set; + if(!rptr) + goto memerr; + setintersect(rptr,del_set,optr); + + if(QT_SET_CNT(rptr) > 0) + { + /* First need to check if set size larger than QT_MAXSET: if so + need to allocate larger array + */ + sptr = QT_SET_PTR(rptr); + for(i = QT_SET_CNT(rptr); i > 0; i--) + { + t_id = QT_SET_NEXT_ELEM(sptr); + qt = qtdelelem(qt,t_id); + } + } + /* If we allocated memory: free it */ + if(rptr != r_set) + free(rptr); + + return(qt); +memerr: + error(SYSTEM,"delete_tri_set():Unable to allocate memory"); +} + +QUADTREE +expand_node(qt,q0,q1,q2,optr,n) +QUADTREE qt; +FVECT q0,q1,q2; +OBJECT *optr; +int n; +{ + OBJECT *tptr,t_set[QT_MAXSET+1]; + int i,t_id,found; + TRI *t; + FVECT v0,v1,v2; + + if(QT_SET_CNT(optr) > QT_MAXSET) + tptr = (OBJECT *)malloc((QT_SET_CNT(optr)+1)*sizeof(OBJECT)); + else + tptr = t_set; + if(!tptr) + goto memerr; + + qtgetset(tptr,qt); + /* If set size exceeds threshold: subdivide cell and reinsert tris*/ + qtfreeleaf(qt); + qtSubdivide(qt); + + for(optr = QT_SET_PTR(tptr),i=QT_SET_CNT(tptr); i > 0; i--) + { + t_id = QT_SET_NEXT_ELEM(optr); + t = SM_NTH_TRI(smMesh,t_id); + if(!T_IS_VALID(t)) + continue; + VSUB(v0,SM_T_NTH_WV(smMesh,t,0),SM_VIEW_CENTER(smMesh)); + VSUB(v1,SM_T_NTH_WV(smMesh,t,1),SM_VIEW_CENTER(smMesh)); + VSUB(v2,SM_T_NTH_WV(smMesh,t,2),SM_VIEW_CENTER(smMesh)); + qt = qtAdd_tri(qt,q0,q1,q2,v0,v1,v2,t_id,n); + } + /* If we allocated memory: free it */ + if( tptr != t_set) + free(tptr); + + return(qt); +memerr: + error(SYSTEM,"expand_node():Unable to allocate memory"); +} + +add_tri_expand(qtptr,f,argptr,q0,q1,q2,t0,t1,t2,n) QUADTREE *qtptr; +int *f; +ADD_ARGS *argptr; FVECT q0,q1,q2; FVECT t0,t1,t2; int n; -int *arg; -int t_id; { - OBJECT tset[QT_MAXSET+1],*optr; - int i,id,found; - FVECT v0,v1,v2; - TRI *tri; -#ifdef DEBUG_TEST_DRIVER - Pick_tri = t_id; - Picking = TRUE; -#endif - - if(QT_IS_EMPTY(*qtptr)) - { - *qtptr = qtaddelem(*qtptr,t_id); - return(TRUE); - } - + int t_id; + OBJECT *optr,*del_set; + + t_id = argptr->t_id; + + if(QT_IS_EMPTY(*qtptr)) + { + *qtptr = qtaddelem(*qtptr,t_id); + return; + } + if(!QT_LEAF_IS_FLAG(*qtptr)) + { optr = qtqueryset(*qtptr); - if(!inset(optr,t_id)) - { - if(QT_SET_CNT(optr) < QT_MAXSET) - *qtptr = qtaddelem(*qtptr,t_id); - else - { -#ifdef DEBUG - eputs("add_tri_expand():no room in set\n"); -#endif - return(FALSE); - } - } - optr = qtqueryset(*qtptr); - if(QT_SET_CNT(optr) >= QT_SET_THRESHOLD) - if (n < QT_MAX_LEVELS) - { - qtgetset(tset,*qtptr); - /* If set size exceeds threshold: subdivide cell and reinsert tris*/ - qtfreeleaf(*qtptr); - qtSubdivide(qtptr); - for(optr = QT_SET_PTR(tset),i=QT_SET_CNT(tset); i > 0; i--) - { - id = QT_SET_NEXT_ELEM(optr); - tri = SM_NTH_TRI(smMesh,id); - VSUB(v0,SM_T_NTH_WV(smMesh,tri,0),SM_VIEW_CENTER(smMesh)); - VSUB(v1,SM_T_NTH_WV(smMesh,tri,1),SM_VIEW_CENTER(smMesh)); - VSUB(v2,SM_T_NTH_WV(smMesh,tri,2),SM_VIEW_CENTER(smMesh)); - found = qtAdd_tri(qtptr,q0,q1,q2,v0,v1,v2,id,n); -#ifdef DEBUG - if(!found) - eputs("add_tri_expand():Reinsert\n"); -#endif - } - return(QT_MODIFIED); - } - else - if(QT_SET_CNT(optr) < QT_MAXSET) - { -#ifdef DEBUG_TEST_DRIVER - eputs("add_tri_expand():too many levels:can't expand\n"); -#endif - return(TRUE); - } - else - { -#ifdef DEBUG - eputs("add_tri_expand():too many tris inset:can't add\n"); -#endif - return(FALSE); - } + if(del_set=argptr->del_set) + *qtptr = delete_tri_set(*qtptr,optr,del_set); + *qtptr = qtaddelem(*qtptr,t_id); + } + if (n >= QT_MAX_LEVELS) + return; + optr = qtqueryset(*qtptr); + if(QT_SET_CNT(optr) < QT_SET_THRESHOLD) + return; + *qtptr = expand_node(*qtptr,q0,q1,q2,optr,n); } -int -add_tri(qtptr,fptr,t_id) + +add_tri(qtptr,fptr,argptr) QUADTREE *qtptr; int *fptr; - int t_id; + ADD_ARGS *argptr; { - OBJECT *optr; + OBJECT *optr,*del_set; + int t_id; -#ifdef DEBUG_TEST_DRIVER - Pick_tri = t_id; - Picking = TRUE; -#endif - if(QT_IS_EMPTY(*qtptr)) + t_id = argptr->t_id; + + + if(QT_IS_EMPTY(*qtptr)) + { + *qtptr = qtaddelem(*qtptr,t_id); + if(!QT_FLAG_FILL_TRI(*fptr)) + (*fptr)++; + return; + } + if(QT_LEAF_IS_FLAG(*qtptr)) + return; + + optr = qtqueryset(*qtptr); + + if(del_set = argptr->del_set) + *qtptr = delete_tri_set(*qtptr,optr,del_set); + + if(!QT_IS_EMPTY(*qtptr)) { - *qtptr = qtaddelem(*qtptr,t_id); - if(!QT_FLAG_FILL_TRI(*fptr)) - (*fptr)++; + optr = qtqueryset(*qtptr); + if(QT_SET_CNT(optr) >= QT_SET_THRESHOLD) + (*fptr) |= QT_EXPAND; } - else - { - optr = qtqueryset(*qtptr); - if(!inset(optr,t_id)) - { - if(QT_SET_CNT(optr) < QT_MAXSET) - { - if(QT_SET_CNT(optr) >= QT_SET_THRESHOLD) - (*fptr) |= QT_EXPAND; - if(!QT_FLAG_FILL_TRI(*fptr)) - (*fptr)++; - *qtptr = qtaddelem(*qtptr,t_id); - } - else - { -#ifdef DEBUG_TESTDRIVER - eputs("add_tri():exceeded set size\n"); -#endif - return(FALSE); - } - } - } - return(TRUE); + if(!QT_FLAG_FILL_TRI(*fptr)) + (*fptr)++; + *qtptr = qtaddelem(*qtptr,t_id); + } -int -stInsert_tri(st,t_id,t0,t1,t2) - STREE *st; - int t_id; - FVECT t0,t1,t2; -{ - int f; - FVECT dir; - - /* First add all of the leaf cells lying on the triangle perimeter: - mark all cells seen on the way - */ - ST_CLEAR_FLAGS(st); - f = 0; - VSUB(dir,t1,t0); - stTrace_edge(st,t0,dir,1.0,add_tri,&f,t_id); - VSUB(dir,t2,t1); - stTrace_edge(st,t1,dir,1.0,add_tri,&f,t_id); - VSUB(dir,t0,t2); - stTrace_edge(st,t2,dir,1.0,add_tri,&f,t_id); - /* Now visit interior */ - if(QT_FLAG_FILL_TRI(f) || QT_FLAG_UPDATE(f)) - stVisit_tri_interior(st,t0,t1,t2,add_tri_expand,&f,t_id); -} - -smLocator_add_tri(sm,t_id,v0_id,v1_id,v2_id) +smLocator_add_tri(sm,t_id,v0_id,v1_id,v2_id,del_set) SM *sm; int t_id; -int v0_id,v1_id,v2_id; +int v0_id,v1_id,v2_id; +OBJECT *del_set; { STREE *st; FVECT v0,v1,v2; - + ADD_ARGS args; + st = SM_LOCATOR(sm); +#ifdef DEBUG + if((v0_id == INVALID) || (v1_id == INVALID) || (v2_id == INVALID)) + error(CONSISTENCY,"Invalid ids 1\n"); +#endif + VSUB(v0,SM_NTH_WV(sm,v0_id),SM_VIEW_CENTER(sm)); VSUB(v1,SM_NTH_WV(sm,v1_id),SM_VIEW_CENTER(sm)); VSUB(v2,SM_NTH_WV(sm,v2_id),SM_VIEW_CENTER(sm)); - stUpdate_tri(st,t_id,v0,v1,v2,add_tri,add_tri_expand); + qtClearAllFlags(); + args.t_id = t_id; + args.del_set = del_set; + stApply_to_tri(st,v0,v1,v2,add_tri,add_tri_expand,&args); + } /* Add a triangle to the base array with vertices v1-v2-v3 */ int -smAdd_tri(sm, v0_id,v1_id,v2_id,tptr) +smAdd_tri(sm, v0_id,v1_id,v2_id) SM *sm; int v0_id,v1_id,v2_id; -TRI **tptr; { int t_id; TRI *t; +#ifdef DEBUG + if(v0_id==v1_id || v0_id==v2_id || v1_id==v2_id) + { + eputs("smAdd_tri: invalid vertex ids\n"); + return(INVALID); + } +#endif + t_id = smAlloc_tri(sm); - - if(SM_TRI_CNT(sm)+1 > SM_MAX_TRIS(sm)) - error(SYSTEM,"smAdd_tri():Too many triangles"); - - /* Get the id for the next available triangle */ - SM_FREE_TRI_ID(sm,t_id); if(t_id == -1) return(t_id); t = SM_NTH_TRI(sm,t_id); + T_CLEAR_NBRS(t); + /* set the triangle vertex ids */ + T_NTH_V(t,0) = v0_id; + T_NTH_V(t,1) = v1_id; + T_NTH_V(t,2) = v2_id; + SM_NTH_VERT(sm,v0_id) = t_id; + SM_NTH_VERT(sm,v1_id) = t_id; + SM_NTH_VERT(sm,v2_id) = t_id; + if(SM_BASE_ID(sm,v0_id) || SM_BASE_ID(sm,v1_id) || SM_BASE_ID(sm,v2_id)) { smClear_tri_flags(sm,t_id); @@ -470,155 +547,64 @@ TRI **tptr; } else { - SM_CLEAR_NTH_T_BASE(sm,t_id); + SM_CLR_NTH_T_BASE(sm,t_id); SM_SET_NTH_T_ACTIVE(sm,t_id); - SM_SET_NTH_T_LRU(sm,t_id); SM_SET_NTH_T_NEW(sm,t_id); - SM_NUM_TRIS(sm)++; + S_SET_FLAG(T_NTH_V(t,0)); + S_SET_FLAG(T_NTH_V(t,1)); + S_SET_FLAG(T_NTH_V(t,2)); + SM_SAMPLE_TRIS(sm)++; smNew_tri_cnt++; } - /* set the triangle vertex ids */ - T_NTH_V(t,0) = v0_id; - T_NTH_V(t,1) = v1_id; - T_NTH_V(t,2) = v2_id; - SM_NTH_VERT(sm,v0_id) = t_id; - SM_NTH_VERT(sm,v1_id) = t_id; - SM_NTH_VERT(sm,v2_id) = t_id; - - if(t) - *tptr = t; /* return initialized triangle */ return(t_id); } -int -smClosest_vertex_in_tri(sm,v0_id,v1_id,v2_id,p,eps) -SM *sm; -int v0_id,v1_id,v2_id; -FVECT p; -double eps; -{ - FVECT v; - double d,d0,d1,d2; - int closest = -1; - if(v0_id != -1) - { - smDir(sm,v,v0_id); - d0 = DIST(p,v); - if(eps < 0 || d0 < eps) - { - closest = v0_id; - d = d0; - } - } - if(v1_id != -1) - { - smDir(sm,v,v1_id); - d1 = DIST(p,v); - if(closest== -1) - { - if(eps < 0 || d1 < eps) - { - closest = v1_id; - d = d1; - } - } - else - if(d1 < d0) - { - if((eps < 0) || d1 < eps) - { - closest = v1_id; - d = d1; - } - } - } - if(v2_id != -1) - { - smDir(sm,v,v2_id); - d2 = DIST(p,v); - if((eps < 0) || d2 < eps) - if(closest == -1 ||(d2 < d)) - return(v2_id); - } - return(closest); -} - - -int -smClosest_vertex_in_w_tri(sm,v0_id,v1_id,v2_id,p) -SM *sm; -int v0_id,v1_id,v2_id; -FVECT p; -{ - FVECT v; - double d,d0,d1,d2; - int closest; - - VCOPY(v,SM_NTH_WV(sm,v0_id)); - d = d0 = DIST(p,v); - closest = v0_id; - - VCOPY(v,SM_NTH_WV(sm,v1_id)); - d1 = DIST(p,v); - if(d1 < d0) - { - closest = v1_id; - d = d1; - } - VCOPY(v,SM_NTH_WV(sm,v2_id)); - d2 = DIST(p,v); - if(d2 < d) - return(v2_id); - else - return(closest); -} - void -smTris_swap_edge(sm,t_id,t1_id,e,e1,tn_id,tn1_id,add,del) +smTris_swap_edge(sm,t_id,t1_id,e,e1,tn_id,tn1_id,add_ptr,delptr) SM *sm; int t_id,t1_id; int e,e1; int *tn_id,*tn1_id; - LIST **add,**del; + LIST **add_ptr; + QUADTREE *delptr; { - TRI *t,*t1; - TRI *ta,*tb; int verts[3],enext,eprev,e1next,e1prev; - TRI *n; + TRI *n,*ta,*tb,*t,*t1; FVECT p1,p2,p3; int ta_id,tb_id; - /* swap diagonal (e relative to t, and e1 relative to t1) - defined by quadrilateral - formed by t,t1- swap for the opposite diagonal + /* form new diagonal (e relative to t, and e1 relative to t1) + defined by quadrilateral formed by t,t1- swap for the opposite diagonal */ - t = SM_NTH_TRI(sm,t_id); - t1 = SM_NTH_TRI(sm,t1_id); enext = (e+1)%3; eprev = (e+2)%3; e1next = (e1+1)%3; e1prev = (e1+2)%3; - verts[e] = T_NTH_V(t,e); - verts[enext] = T_NTH_V(t1,e1prev); - verts[eprev] = T_NTH_V(t,eprev); - ta_id = smAdd_tri(sm,verts[0],verts[1],verts[2],&ta); - *add = push_data(*add,ta_id); - verts[e1] = T_NTH_V(t1,e1); - verts[e1next] = T_NTH_V(t,eprev); - verts[e1prev] = T_NTH_V(t1,e1prev); - tb_id = smAdd_tri(sm,verts[0],verts[1],verts[2],&tb); - *add = push_data(*add,tb_id); + verts[e] = T_NTH_V(SM_NTH_TRI(sm,t_id),e); + verts[enext] = T_NTH_V(SM_NTH_TRI(sm,t_id),enext); + verts[eprev] = T_NTH_V(SM_NTH_TRI(sm,t1_id),e1); + ta_id = smAdd_tri(sm,verts[0],verts[1],verts[2]); + *add_ptr = push_data(*add_ptr,ta_id); + verts[e1] = T_NTH_V(SM_NTH_TRI(sm,t1_id),e1); + verts[e1next] = T_NTH_V(SM_NTH_TRI(sm,t1_id),e1next); + verts[e1prev] = T_NTH_V(SM_NTH_TRI(sm,t_id),e); + tb_id = smAdd_tri(sm,verts[0],verts[1],verts[2]); + *add_ptr = push_data(*add_ptr,tb_id); + ta = SM_NTH_TRI(sm,ta_id); + tb = SM_NTH_TRI(sm,tb_id); + t = SM_NTH_TRI(sm,t_id); + t1 = SM_NTH_TRI(sm,t1_id); /* set the neighbors */ T_NTH_NBR(ta,e) = T_NTH_NBR(t1,e1next); T_NTH_NBR(tb,e1) = T_NTH_NBR(t,enext); - T_NTH_NBR(ta,enext) = tb_id; - T_NTH_NBR(tb,e1next) = ta_id; - T_NTH_NBR(ta,eprev) = T_NTH_NBR(t,eprev); - T_NTH_NBR(tb,e1prev) = T_NTH_NBR(t1,e1prev); + T_NTH_NBR(ta,enext)= tb_id; + T_NTH_NBR(tb,e1next)= ta_id; + T_NTH_NBR(ta,eprev)=T_NTH_NBR(t,eprev); + T_NTH_NBR(tb,e1prev)=T_NTH_NBR(t1,e1prev); /* Reset neighbor pointers of original neighbors */ n = SM_NTH_TRI(sm,T_NTH_NBR(t,enext)); @@ -632,87 +618,93 @@ smTris_swap_edge(sm,t_id,t1_id,e,e1,tn_id,tn1_id,add,d T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = tb_id; /* Delete two parent triangles */ + if(remove_from_list(t_id,add_ptr)) + smDelete_tri(sm,t_id); + else + *delptr = qtaddelem(*delptr,t_id); - *del = push_data(*del,t_id); - T_VALID_FLAG(t) = -1; - *del = push_data(*del,t1_id); - T_VALID_FLAG(t1) = -1; + if(remove_from_list(t1_id,add_ptr)) + smDelete_tri(sm,t1_id); + else + *delptr = qtaddelem(*delptr,t1_id); + *tn_id = ta_id; *tn1_id = tb_id; } -smUpdate_locator(sm,add_list,del_list) +smUpdate_locator(sm,add_list,del_set) SM *sm; -LIST *add_list,*del_list; +LIST *add_list; +OBJECT *del_set; { - int t_id; + int t_id,i; TRI *t; + OBJECT *optr; + while(add_list) { t_id = pop_list(&add_list); t = SM_NTH_TRI(sm,t_id); - if(!T_IS_VALID(t)) - { - T_VALID_FLAG(t) = 1; - continue; - } - smLocator_add_tri(sm,t_id,T_NTH_V(t,0),T_NTH_V(t,1),T_NTH_V(t,2)); + smLocator_add_tri(sm,t_id,T_NTH_V(t,0),T_NTH_V(t,1),T_NTH_V(t,2),del_set); } - - while(del_list) + + optr = QT_SET_PTR(del_set); + for(i = QT_SET_CNT(del_set); i > 0; i--) { - t_id = pop_list(&del_list); - t = SM_NTH_TRI(sm,t_id); - if(!T_IS_VALID(t)) - { - smLocator_remove_tri(sm,t_id); - } - smDelete_tri(sm,t_id); + t_id = QT_SET_NEXT_ELEM(optr); +#if 0 + t = SM_NTH_TRI(sm,t_id); + smLocator_remove_tri(sm,t_id,T_NTH_V(t,0),T_NTH_V(t,1),T_NTH_V(t,2)); +#endif + smDelete_tri(sm,t_id); } } /* MUST add check for constrained edges */ int -smFix_tris(sm,id,tlist,add_list,del_list) +smFix_tris(sm,id,tlist,add_list,delptr) SM *sm; int id; -LIST *tlist; -LIST *add_list,*del_list; +LIST *tlist,*add_list; +QUADTREE *delptr; { TRI *t,*t_opp; - FVECT p,p1,p2,p3; + FVECT p,p0,p1,p2; int e,e1,swapped = 0; int t_id,t_opp_id; - VSUB(p,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm)); while(tlist) { t_id = pop_list(&tlist); +#ifdef DEBUG + if(t_id==INVALID || t_id > smMesh->num_tri) + error(CONSISTENCY,"Invalid tri id smFix_tris()\n"); +#endif t = SM_NTH_TRI(sm,t_id); - e = (T_WHICH_V(t,id)+1)%3; + e = T_WHICH_V(t,id); t_opp_id = T_NTH_NBR(t,e); - t_opp = SM_NTH_TRI(sm,t_opp_id); - /* - VSUB(p1,SM_T_NTH_WV(sm,t_opp,0),SM_VIEW_CENTER(sm)); - VSUB(p2,SM_T_NTH_WV(sm,t_opp,1),SM_VIEW_CENTER(sm)); - VSUB(p3,SM_T_NTH_WV(sm,t_opp,2),SM_VIEW_CENTER(sm)); - */ - smDir(sm,p1,T_NTH_V(t_opp,0)); - smDir(sm,p2,T_NTH_V(t_opp,1)); - smDir(sm,p3,T_NTH_V(t_opp,2)); - if(point_in_cone(p,p1,p2,p3)) +#ifdef DEBUG + if(t_opp_id==INVALID || t_opp_id > smMesh->num_tri) + error(CONSISTENCY,"Invalid tri id smFix_tris()\n"); +#endif + t_opp = SM_NTH_TRI(sm,t_opp_id); + + smDir_in_cone(sm,p0,T_NTH_V(t_opp,0)); + smDir_in_cone(sm,p1,T_NTH_V(t_opp,1)); + smDir_in_cone(sm,p2,T_NTH_V(t_opp,2)); + if(point_in_cone(p,p0,p1,p2)) { swapped = 1; e1 = T_NTH_NBR_PTR(t_id,t_opp); /* check list for t_opp and Remove if there */ remove_from_list(t_opp_id,&tlist); smTris_swap_edge(sm,t_id,t_opp_id,e,e1,&t_id,&t_opp_id, - &add_list,&del_list); + &add_list,delptr); tlist = push_data(tlist,t_id); tlist = push_data(tlist,t_opp_id); } } - smUpdate_locator(sm,add_list,del_list); + smUpdate_locator(sm,add_list,qtqueryset(*delptr)); return(swapped); } @@ -726,34 +718,14 @@ TRI *t; int id; { int t_id; - int tri; + int nbr_id; /* Want the edge for which "id" is the destination */ - t_id = (T_WHICH_V(t,id)+ 2)% 3; - tri = T_NTH_NBR(t,t_id); - return(tri); + t_id = (T_WHICH_V(t,id)+ 1)% 3; + nbr_id = T_NTH_NBR(t,t_id); + return(nbr_id); } -void -smReplace_point(sm,tri,id,nid) -SM *sm; -TRI *tri; -int id,nid; -{ - TRI *t; - int t_id; - - T_NTH_V(tri,T_WHICH_V(tri,id)) = nid; - - t_id = smTri_next_ccw_nbr(sm,tri,nid); - while((t = SM_NTH_TRI(sm,t_id)) != tri) - { - T_NTH_V(t,T_WHICH_V(t,id)) = nid; - t_id = smTri_next_ccw_nbr(sm,t,nid); - } -} - - smClear_tri_flags(sm,id) SM *sm; int id; @@ -761,243 +733,431 @@ int id; int i; for(i=0; i < T_FLAGS; i++) - SM_CLEAR_NTH_T_FLAG(sm,id,i); + SM_CLR_NTH_T_FLAG(sm,id,i); } /* Locate the point-id in the point location structure: */ int -smReplace_vertex(sm,c,dir,p,tri_id,snew_id,type,which) +smInsert_samp(sm,s_id,tri_id) SM *sm; - COLR c; - FVECT dir,p; - int tri_id,snew_id; - int type,which; -{ - int n_id,s_id; - TRI *tri; - - tri = SM_NTH_TRI(sm,tri_id); - /* Get the sample that corresponds to the "which" vertex of "tri" */ - /* NEED: have re-init that sets clock flag */ - /* If this is a base-sample: create a new sample and replace - all references to the base sample with references to the - new sample - */ - s_id = T_NTH_V(tri,which); - if(SM_BASE_ID(sm,s_id)) - { - if(snew_id != -1) - n_id = smAdd_sample_point(sm,c,dir,p); - else - n_id = snew_id; - smReplace_point(sm,tri,s_id,n_id); - s_id = n_id; - } - else /* If the sample exists, reset the values */ - /* NOTE: This test was based on the SPHERICAL coordinates - of the point: If we are doing a multiple-sample-per - SPHERICAL pixel: we will want to test for equality- - and do other processing: for now: SINGLE SAMPLE PER - PIXEL - */ - /* NOTE: snew_id needs to be marked as invalid?*/ - if(snew_id == -1) - smInit_sample(sm,s_id,c,dir,p); - else - smReset_sample(sm,s_id,snew_id); - return(s_id); -} - - -/* Locate the point-id in the point location structure: */ -int -smInsert_point_in_tri(sm,c,dir,p,s_id,tri_id) - SM *sm; - COLR c; - FVECT dir,p; int s_id,tri_id; { - TRI *tri,*t0,*t1,*t2,*nbr; - int v0_id,v1_id,v2_id,n_id; - int t0_id,t1_id,t2_id; - LIST *tlist,*add_list,*del_list; + int v0_id,v1_id,v2_id; + int t0_id,t1_id,t2_id,replaced; + LIST *tlist,*add_list; + OBJECT del_set[2]; + QUADTREE delnode; FVECT npt; + TRI *tri,*nbr; - add_list = del_list = NULL; - if(s_id == SM_INVALID) - s_id = smAdd_sample_point(sm,c,dir,p); - - tri = SM_NTH_TRI(sm,tri_id); - v0_id = T_NTH_V(tri,0); - v1_id = T_NTH_V(tri,1); - v2_id = T_NTH_V(tri,2); + add_list = NULL; - n_id = -1; - if(SM_BASE_ID(sm,v0_id)||SM_BASE_ID(sm,v1_id)||SM_BASE_ID(sm,v2_id)) - { - smDir(sm,npt,s_id); - /* Change to an add and delete */ - t0_id = (SM_BASE_ID(sm,v0_id))?v0_id:-1; - t1_id = (SM_BASE_ID(sm,v1_id))?v1_id:-1; - t2_id = (SM_BASE_ID(sm,v2_id))?v2_id:-1; - n_id = smClosest_vertex_in_tri(sm,t0_id,t1_id,t2_id,npt,P_REPLACE_EPS); - } - t0_id = smAdd_tri(sm,s_id,v0_id,v1_id,&t0); + v0_id = T_NTH_V(SM_NTH_TRI(sm,tri_id),0); + v1_id = T_NTH_V(SM_NTH_TRI(sm,tri_id),1); + v2_id = T_NTH_V(SM_NTH_TRI(sm,tri_id),2); + + t0_id = smAdd_tri(sm,s_id,v0_id,v1_id); /* Add triangle to the locator */ add_list = push_data(add_list,t0_id); - t1_id = smAdd_tri(sm,s_id,v1_id,v2_id,&t1); + t1_id = smAdd_tri(sm,s_id,v1_id,v2_id); add_list = push_data(add_list,t1_id); - t2_id = smAdd_tri(sm,s_id,v2_id,v0_id,&t2); + t2_id = smAdd_tri(sm,s_id,v2_id,v0_id); add_list = push_data(add_list,t2_id); + /* CAUTION: tri must be assigned after Add_tri: pointers may change*/ + tri = SM_NTH_TRI(sm,tri_id); + /* Set the neighbor pointers for the new tris */ - T_NTH_NBR(t0,0) = t2_id; - T_NTH_NBR(t0,1) = T_NTH_NBR(tri,0); - T_NTH_NBR(t0,2) = t1_id; - T_NTH_NBR(t1,0) = t0_id; - T_NTH_NBR(t1,1) = T_NTH_NBR(tri,1); - T_NTH_NBR(t1,2) = t2_id; - T_NTH_NBR(t2,0) = t1_id; - T_NTH_NBR(t2,1) = T_NTH_NBR(tri,2); - T_NTH_NBR(t2,2) = t0_id; + T_NTH_NBR(SM_NTH_TRI(sm,t0_id),0) = T_NTH_NBR(tri,2); + T_NTH_NBR(SM_NTH_TRI(sm,t0_id),1) = t1_id; + T_NTH_NBR(SM_NTH_TRI(sm,t0_id),2) = t2_id; + T_NTH_NBR(SM_NTH_TRI(sm,t1_id),0) = T_NTH_NBR(tri,0); + T_NTH_NBR(SM_NTH_TRI(sm,t1_id),1) = t2_id; + T_NTH_NBR(SM_NTH_TRI(sm,t1_id),2) = t0_id; + T_NTH_NBR(SM_NTH_TRI(sm,t2_id),0) = T_NTH_NBR(tri,1); + T_NTH_NBR(SM_NTH_TRI(sm,t2_id),1) = t0_id; + T_NTH_NBR(SM_NTH_TRI(sm,t2_id),2) = t1_id; /* Reset the neigbor pointers for the neighbors of the original */ nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,0)); - T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t0_id; - nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,1)); T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t1_id; - nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,2)); + nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,1)); T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t2_id; + nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,2)); + T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t0_id; - del_list = push_data(del_list,tri_id); - T_VALID_FLAG(tri) = -1; + del_set[0] = 1; del_set[1] = tri_id; + delnode = qtnewleaf(del_set); /* Fix up the new triangles*/ tlist = push_data(NULL,t0_id); tlist = push_data(tlist,t1_id); tlist = push_data(tlist,t2_id); - smFix_tris(sm,s_id,tlist,add_list,del_list); + smFix_tris(sm,s_id,tlist,add_list,&delnode); - if(n_id != -1) - smDelete_point(sm,n_id); + qtfreeleaf(delnode); - return(s_id); + return(TRUE); } int -smPointLocate(sm,pt,norm) +smTri_in_set(sm,p,optr) SM *sm; -FVECT pt; -int norm; +FVECT p; +OBJECT *optr; { - STREE *st; - int tri; - FVECT npt; + int i,t_id; + FVECT n,v0,v1,v2; + TRI *t; - st = SM_LOCATOR(sm); - if(norm) + for (i = QT_SET_CNT(optr),optr = QT_SET_PTR(optr);i > 0; i--) { - VSUB(npt,pt,SM_VIEW_CENTER(sm)); - tri = stPoint_locate(st,npt); + /* Find the first triangle that pt falls */ + t_id = QT_SET_NEXT_ELEM(optr); + t = SM_NTH_TRI(sm,t_id); + if(!T_IS_VALID(t)) + continue; + VSUB(v0,SM_T_NTH_WV(sm,t,0),SM_VIEW_CENTER(sm)); + VSUB(v1,SM_T_NTH_WV(sm,t,1),SM_VIEW_CENTER(sm)); + VSUB(v2,SM_T_NTH_WV(sm,t,2),SM_VIEW_CENTER(sm)); + + if(EQUAL_VEC3(v0,p) || EQUAL_VEC3(v1,p) || EQUAL_VEC3(v2,p)) + return(t_id); + + VCROSS(n,v0,v1); + if(DOT(n,p) >0.0) + continue; + VCROSS(n,v1,v2); + if(DOT(n,p) > 0.0) + continue; + + VCROSS(n,v2,v0); + if(DOT(n,p) > 0.0) + continue; + + return(t_id); } - else - tri = stPoint_locate(st,pt); - return(tri); + return(INVALID); } -QUADTREE -smPointLocateCell(sm,pt,norm,v0,v1,v2) +int +smPointLocateTri(sm,p) SM *sm; -FVECT pt; -int norm; -FVECT v0,v1,v2; +FVECT p; { - STREE *st; - QUADTREE *qtptr; - FVECT npt; + QUADTREE qt,*optr; + FVECT tpt; - st = SM_LOCATOR(sm); - if(norm) - { - VSUB(npt,pt,SM_VIEW_CENTER(sm)); - - qtptr = stPoint_locate_cell(st,npt,v0,v1,v2); - } - else - qtptr = stPoint_locate_cell(st,pt,v0,v1,v2); - - if(qtptr) - return(*qtptr); - else - return(EMPTY); + VSUB(tpt,p,SM_VIEW_CENTER(sm)); + qt = smPointLocateCell(sm,tpt); + if(QT_IS_EMPTY(qt)) + return(INVALID); + + optr = qtqueryset(qt); + return(smTri_in_set(sm,tpt,optr)); } + +/* + Determine whether this sample should: + a) be added to the mesh by subdividing the triangle + b) ignored + c) replace values of an existing mesh vertex + + In case a, the routine will return TRUE, for b,c will return FALSE + In case a, also determine if this sample should cause the deletion of + an existing vertex. If so *rptr will contain the id of the sample to delete + after the new sample has been added. + + ASSUMPTION: this will not be called with a new sample that is + a BASE point. + + The following tests are performed (in order) to determine the fate + of the sample: + + 1) If the world space point of the sample coincides with one of the + triangle vertex samples: The values of the triangle sample are + replaced with the new values and FALSE is returned + 2) If the new sample is close in ws, and close in the spherical projection + to one of the triangle vertex samples: + pick the point with dir closest to that of the canonical view + If it is the new point: mark existing point for deletion,and return + TRUE,else return FALSE + 3) If the spherical projection of new is < REPLACE_EPS from a base point: + add new and mark the base for deletion: return TRUE + 4) If the addition of the new sample point would introduce a "puncture" + or cause new triangles with large depth differences:return FALSE + This attempts to throw out points that should be occluded +*/ int -smAdd_sample_to_mesh(sm,c,dir,pt,s_id) +smTest_sample(sm,tri_id,c,dir,p,o_id,rptr) SM *sm; + int tri_id; COLR c; - FVECT dir,pt; - int s_id; + FVECT dir,p; + int o_id; + int *rptr; { - int t_id; - double d; - FVECT p; - - /* If new, foreground pt */ - if(pt) + TRI *tri; + double d,d2,dnear,dspt,d01,d12,d20,s0,s1,s2,ds,dv; + int vid[3],i,nearid,norm,dcnt,bcnt; + FVECT diff[3],spt,npt; + int tonemap; + + *rptr = INVALID; + bcnt = dcnt = 0; + tri = SM_NTH_TRI(sm,tri_id); + vid[0] = T_NTH_V(tri,0); + vid[1] = T_NTH_V(tri,1); + vid[2] = T_NTH_V(tri,2); + + /* TEST 1: Test if the new point has the same world space point as + one of the existing triangle vertices + */ + for(i=0; i<3; i++) { - /* NOTE: This should be elsewhere! */ - d = DIST(pt,SM_VIEW_CENTER(smMesh)); - smDist_sum += 1.0/d; - /************************************/ - t_id = smPointLocate(smMesh,pt,TRUE); - if(t_id >= 0) - s_id = smInsert_point_in_tri(smMesh,c,dir,pt,s_id,t_id); -#ifdef DEBUG - else - { - c[0] = 255;c[1]=0;c[2]=0; - s_id = smAdd_sample_point(sm,c,dir,pt); - eputs("smAdd_sample_to_mesh(): not found fg\n"); - } -#endif + if(SM_BASE_ID(sm,vid[i])) + { + bcnt++; + continue; + } + if(SM_DIR_ID(sm,vid[i])) + dcnt++; + VSUB(diff[i],SM_NTH_WV(sm,vid[i]),p); + /* If same world point: replace */ + if(FZERO_VEC3(diff[i])) + { + tonemap = (SM_TONE_MAP(sm) > vid[i]); + sInit_samp(SM_SAMP(sm),vid[i],c,dir,p,o_id,tonemap); + return(FALSE); + } } - else if(s_id != -1) + if(!dir) + return(TRUE); + /* TEST 2: If the new sample is close in ws, and close in the spherical + projection to one of the triangle vertex samples + */ + norm = FALSE; + if(bcnt + dcnt != 3) { - VCOPY(p,SM_NTH_WV(sm,s_id)); - if(SM_NTH_W_DIR(sm,s_id) != -1) + VSUB(spt,p,SM_VIEW_CENTER(sm)); + ds = DOT(spt,spt); + dnear = FHUGE; + for(i=0; i<3; i++) { - /* NOTE: This should be elsewhere! */ - d = DIST(p,SM_VIEW_CENTER(smMesh)); - smDist_sum += 1.0/d; - /************************************/ + if(SM_BASE_ID(sm,vid[i]) || SM_DIR_ID(sm,vid[i])) + continue; + d = DOT(diff[i],diff[i])/ds; + if(d < dnear) + { + dnear = d; + nearid=vid[i]; + } } - t_id = smPointLocate(smMesh,p,TRUE); - if(t_id != -1) - s_id = smInsert_point_in_tri(smMesh,c,dir,p,s_id,t_id); + + if(dnear <= smMinSampDiff*smMinSampDiff) + { + /* Pick the point with dir closest to that of the canonical view + if it is the new sample: mark existing point for deletion + */ + normalize(spt); + norm = TRUE; + VSUB(npt,SM_NTH_WV(sm,nearid),SM_VIEW_CENTER(sm)); + normalize(npt); + d = fdir2diff(SM_NTH_W_DIR(sm,nearid), npt); + d2 = 2. - 2.*DOT(dir,spt); + /* The existing sample is a better sample:punt */ + if(d2 > d) + return(FALSE); + else + { + /* The new sample is better: mark the existing one + for deletion after the new one is added*/ + *rptr = nearid; + return(TRUE); + } + } + } + /* TEST 3: If the spherical projection of new is < S_REPLACE_EPS + from a base point + */ + if(bcnt) + { + dnear = FHUGE; + if(bcnt + dcnt ==3) + VSUB(spt,p,SM_VIEW_CENTER(sm)); + if(!norm) + normalize(spt); + + for(i=0; i<3; i++) + { + if(!SM_BASE_ID(sm,vid[i])) + continue; + VSUB(npt,SM_NTH_WV(sm,vid[i]),SM_VIEW_CENTER(sm)); + d = DIST_SQ(npt,spt); + if(d < S_REPLACE_EPS && d < dnear) + { + dnear = d; + nearid = vid[i]; + } + } + if(dnear != FHUGE) + { + /* add new and mark the base for deletion */ + *rptr = nearid; + return(TRUE); + } + } + + /* TEST 4: + If the addition of the new sample point would introduce a "puncture" + or cause new triangles with large depth differences:dont add: + */ + if(bcnt || dcnt) + return(TRUE); + /* If the new point is in front of the existing points- add */ + dv = DIST_SQ(SM_NTH_WV(sm,vid[0]),SM_VIEW_CENTER(sm)); + if(ds < dv) + return(TRUE); + + d01 = DIST_SQ(SM_NTH_WV(sm,vid[1]),SM_NTH_WV(sm,vid[0])); + s0 = DOT(diff[0],diff[0]); + if(s0 < S_REPLACE_SCALE*d01) + return(TRUE); + d12 = DIST_SQ(SM_NTH_WV(sm,vid[2]),SM_NTH_WV(sm,vid[1])); + if(s0 < S_REPLACE_SCALE*d12) + return(TRUE); + d20 = DIST_SQ(SM_NTH_WV(sm,vid[0]),SM_NTH_WV(sm,vid[2])); + if(s0 < S_REPLACE_SCALE*d20) + return(TRUE); + d = MIN3(d01,d12,d20); + s1 = DOT(diff[1],diff[1]); + if(s1 < S_REPLACE_SCALE*d) + return(TRUE); + s2 = DOT(diff[2],diff[2]); + if(s2 < S_REPLACE_SCALE*d) + return(TRUE); + + /* TEST 5: + Check to see if triangle is relatively large and should therefore + be subdivided anyway. + */ + dv *= DIST_SQ(SM_NTH_WV(sm,vid[1]),SM_VIEW_CENTER(sm)); + dv *= DIST_SQ(SM_NTH_WV(sm,vid[2]),SM_VIEW_CENTER(sm)); + if (d01*d12*d20/dv > S_REPLACE_TRI) + return(TRUE); + + return(FALSE); +} + + +int +smAlloc_samp(sm,c,dir,pt,o_id) +SM *sm; +COLR c; +FVECT dir,pt; +int o_id; +{ + int s_id,replaced,cnt; + SAMP *s; + FVECT p; + + s = SM_SAMP(sm); + s_id = sAlloc_samp(s,&replaced); + + cnt=0; + while(replaced) + { + if(smRemoveVertex(sm,s_id)) + break; + s_id = sAlloc_samp(s,&replaced); + cnt++; + if(cnt > S_MAX_SAMP(s)) + error(CONSISTENCY,"smAlloc_samp():unable to find free samp\n"); + } + + /* If sample is being added in the middle of the sample array: tone + map individually + */ + /* Initialize sample */ + sInit_samp(s,s_id,c,dir,pt,o_id,(SM_TONE_MAP(sm)>s_id)); + + return(s_id); +} + +int +smAdd_samp(sm,c,dir,p,o_id) + SM *sm; + COLR c; + FVECT dir,p; + int o_id; +{ + int t_id,s_id,r_id; + double d; + FVECT wpt; + + r_id = INVALID; + /* If sample is a world space point */ + if(p) + { + t_id = smPointLocateTri(sm,p); + if(t_id == INVALID) + { #ifdef DEBUG - else - eputs("smAdd_sample_to_mesh():not found reinsert\n"); + eputs("smAddSamp(): unable to locate tri containing sample \n"); #endif + return(INVALID); + } + /* if not a base id, Test to see if this sample should be added */ + if(!SM_BASE_ID(sm,o_id)) + { + if(!smTest_sample(sm,t_id,c,dir,p,o_id,&r_id)) + return(INVALID); + /* Allocate space for a sample and initialize */ + s_id = smAlloc_samp(smMesh,c,dir,p,o_id); } - /* Is a BG(sky point) */ else - { - t_id = smPointLocate(smMesh,dir,FALSE); - if(t_id != -1) - s_id = smInsert_point_in_tri(smMesh,c,dir,NULL,s_id,t_id); - + s_id = o_id; + } + /* If sample is a direction vector */ + else + { + VADD(wpt,dir,SM_VIEW_CENTER(smMesh)); + t_id = smPointLocateTri(sm,wpt); + if(t_id == INVALID) + { #ifdef DEBUG - else - eputs("smAdd_sample_to_mesh(): not found bg\n"); + eputs("smAddSamp(): unable to locate tri containing sample \n"); #endif - } + return(INVALID); + } + /* Test to see if this sample should be added */ + if(!smTest_sample(sm,t_id,c,NULL,wpt,o_id,&r_id)) + return(INVALID); + /* Allocate space for a sample and initialize */ + s_id = smAlloc_samp(smMesh,c,NULL,wpt,o_id); + } + if(!SM_BASE_ID(sm,s_id) && !SM_DIR_ID(sm,s_id)) + { + /* If not a base or sky point, add distance from the + viewcenter to average*/ + d = DIST(SM_NTH_WV(sm,s_id),SM_VIEW_CENTER(smMesh)); + smDist_sum += 1.0/d; + } + smInsert_samp(smMesh,s_id,t_id); + + /* If new sample replaces existing one- remove that vertex now */ + if(r_id != INVALID) + { + smRemoveVertex(sm,r_id); + sDelete_samp(SM_SAMP(sm),r_id); + } return(s_id); } @@ -1017,72 +1177,32 @@ smNewSamp(c,dir,p) COLR c; FVECT dir; FVECT p; - { int s_id; - int debug=0; - + /* First check if this the first sample: if so initialize mesh */ if(SM_NUM_SAMP(smMesh) == 0) - smInit_mesh(smMesh,odev.v.vp); - if(!debug) - s_id = smAdd_sample_to_mesh(smMesh,c,dir,p,-1); + { + smInit_sm(smMesh,odev.v.vp); + sClear_all_flags(SM_SAMP(smMesh)); + } + /* Add the sample to the mesh */ + s_id = smAdd_samp(smMesh,c,dir,p,INVALID); + return(s_id); } -/* - * int - * smFindsamp(orig, dir): intersect ray with 3D rep. and find closest sample - * FVECT orig, dir; - * - * Find the closest sample to the given ray. Return -1 on failure. - */ - -/* - * smClean() : display has been wiped clean - * - * Called after display has been effectively cleared, meaning that all - * geometry must be resent down the pipeline in the next call to smUpdate(). - */ - - -/* - * smUpdate(vp, qua) : update OpenGL output geometry for view vp - * VIEW *vp; : desired view - * int qua; : quality level (percentage on linear time scale) - * - * Draw new geometric representation using OpenGL calls. Assume that the - * view has already been set up and the correct frame buffer has been - * selected for drawing. The quality level is on a linear scale, where 100% - * is full (final) quality. It is not necessary to redraw geometry that has - * been output since the last call to smClean(). - */ - - int -smClear_vert(sm,id) -SM *sm; -int id; -{ - if(SM_INVALID_POINT_ID(sm,id)) - return(FALSE); - - SM_NTH_VERT(sm,id) = SM_INVALID; - - return(TRUE); -} - -int -smAdd_base_vertex(sm,v,d) +smAdd_base_vertex(sm,v) SM *sm; - FVECT v,d; + FVECT v; { int id; /* First add coordinate to the sample array */ - id = smAdd_aux_point(sm,v,d); - if(id == -1) - return(SM_INVALID); + id = sAdd_base_point(SM_SAMP(sm),v); + if(id == INVALID) + return(INVALID); /* Initialize triangle pointer to -1 */ smClear_vert(sm,id); return(id); @@ -1100,47 +1220,52 @@ smCreate_base_mesh(sm,type) SM *sm; int type; { - int i,id,tri_id,nbr_id; + int i,s_id,tri_id,nbr_id; int p[4],ids[4]; int v0_id,v1_id,v2_id; - TRI *tris[4]; - FVECT d,pt,cntr; + FVECT d,pt,cntr,v0,v1,v2; /* First insert the base vertices into the sample point array */ for(i=0; i < 4; i++) { - VCOPY(cntr,stDefault_base[i]); + VCOPY(cntr,smDefault_base[i]); cntr[0] += .01; cntr[1] += .02; cntr[2] += .03; VADD(cntr,cntr,SM_VIEW_CENTER(sm)); - /* WONT use dir */ - point_on_sphere(d,cntr,SM_VIEW_CENTER(sm)); - id = smAdd_base_vertex(sm,cntr,d); - /* test to make sure vertex allocated */ - if(id != -1) - p[i] = id; - else - return(0); + p[i] = smAdd_base_vertex(sm,cntr); } /* Create the base triangles */ for(i=0;i < 4; i++) { - v0_id = p[stTri_verts[i][0]]; - v1_id = p[stTri_verts[i][1]]; - v2_id = p[stTri_verts[i][2]]; - if((ids[i] = smAdd_tri(sm, v0_id,v1_id,v2_id,&(tris[i])))== -1) - return(0); - smLocator_add_tri(sm,ids[i],v0_id,v1_id,v2_id); + v0_id = p[smTri_verts[i][0]]; + v1_id = p[smTri_verts[i][1]]; + v2_id = p[smTri_verts[i][2]]; + ids[i] = smAdd_tri(sm, v0_id,v1_id,v2_id); + smLocator_add_tri(sm,ids[i],v0_id,v1_id,v2_id,NULL); } + /* Set neighbors */ for(tri_id=0;tri_id < 4; tri_id++) - for(nbr_id=0; nbr_id < 3; nbr_id++) - T_NTH_NBR(tris[tri_id],nbr_id) = smBase_nbrs[tri_id][nbr_id]; + for(nbr_id=0; nbr_id < 3; nbr_id++) + T_NTH_NBR(SM_NTH_TRI(sm,ids[tri_id]),nbr_id) = smBase_nbrs[tri_id][nbr_id]; - return(1); + /* Now add the centroids of the faces */ + for(tri_id=0;tri_id < 4; tri_id++) + { + VCOPY(v0,SM_T_NTH_WV(sm,SM_NTH_TRI(sm,ids[tri_id]),0)); + VCOPY(v1,SM_T_NTH_WV(sm,SM_NTH_TRI(sm,ids[tri_id]),1)); + VCOPY(v2,SM_T_NTH_WV(sm,SM_NTH_TRI(sm,ids[tri_id]),2)); + tri_centroid(v0,v1,v2,cntr); + VSUB(cntr,cntr,SM_VIEW_CENTER(sm)); + normalize(cntr); + VADD(cntr,cntr,SM_VIEW_CENTER(sm)); + s_id = smAdd_base_vertex(sm,cntr); + smAdd_samp(sm,NULL,NULL,cntr,s_id); + } + return(1); } @@ -1152,11 +1277,13 @@ smNext_tri_flag_set(sm,i,which,b) int b; { - for(; i < SM_TRI_CNT(sm);i++) + for(; i < SM_NUM_TRI(sm);i++) { - if(!SM_IS_NTH_T_FLAG(sm,i,which)) + if(!T_IS_VALID(SM_NTH_TRI(sm,i))) continue; + if(!SM_IS_NTH_T_FLAG(sm,i,which)) + continue; if(!b) break; if((b==1) && !SM_BG_TRI(sm,i)) @@ -1175,7 +1302,7 @@ smNext_valid_tri(sm,i) int i; { - while( i < SM_TRI_CNT(sm) && !T_IS_VALID(SM_NTH_TRI(sm,i))) + while( i < SM_NUM_TRI(sm) && !T_IS_VALID(SM_NTH_TRI(sm,i))) i++; return(i); @@ -1183,72 +1310,75 @@ smNext_valid_tri(sm,i) -qtTri_from_id(t_id,v0,v1,v2,n0,n1,n2,v0_idp,v1_idp,v2_idp) +qtTri_from_id(t_id,v0,v1,v2) int t_id; FVECT v0,v1,v2; -FVECT n0,n1,n2; -int *v0_idp,*v1_idp,*v2_idp; { TRI *t; - int v0_id,v1_id,v2_id; t = SM_NTH_TRI(smMesh,t_id); - v0_id = T_NTH_V(t,0); - v1_id = T_NTH_V(t,1); - v2_id = T_NTH_V(t,2); - - if(v0) - { - VCOPY(v0,SM_NTH_WV(smMesh,v0_id)); - VCOPY(v1,SM_NTH_WV(smMesh,v1_id)); - VCOPY(v2,SM_NTH_WV(smMesh,v2_id)); - } - if(n0) - { - smDir(smMesh,n0,v0_id); - smDir(smMesh,n1,v1_id); - smDir(smMesh,n2,v2_id); - - } - if(v0_idp) - { - *v0_idp = v0_id; - *v1_idp = v1_id; - *v2_idp = v2_id; - } + if(!T_IS_VALID(t)) + return(0); + VSUB(v0,SM_T_NTH_WV(smMesh,t,0),SM_VIEW_CENTER(smMesh)); + VSUB(v1,SM_T_NTH_WV(smMesh,t,1),SM_VIEW_CENTER(smMesh)); + VSUB(v2,SM_T_NTH_WV(smMesh,t,2),SM_VIEW_CENTER(smMesh)); + return(1); } -/* - * int - * smFindSamp(FVECT orig, FVECT dir) - * - * Find the closest sample to the given ray. Returns sample id, -1 on failure. - * "dir" is assumed to be normalized - */ - - - -smRebuild_mesh(sm,vp) +smRebuild_mesh(sm,v) SM *sm; - FVECT vp; + VIEW *v; { - int i; - FVECT dir; - COLR c; - FVECT p,ov; + int i,j,cnt; + FVECT p,ov,dir; + double d; +#ifdef DEBUG + eputs("smRebuild_mesh(): rebuilding...."); +#endif /* Clear the mesh- and rebuild using the current sample array */ + /* Remember the current number of samples */ + cnt = SM_NUM_SAMP(sm); + /* Calculate the difference between the current and new viewpoint*/ + /* Will need to subtract this off of sky points */ + VCOPY(ov,SM_VIEW_CENTER(sm)); + /* Initialize the mesh to 0 samples and the base triangles */ - VSUB(ov,vp,SM_VIEW_CENTER(sm)); - smInit_mesh(sm,vp); - - SM_FOR_ALL_SAMPLES(sm,i) + /* Go through all samples and add in if in the new view frustum, and + the dir is <= 30 degrees from new view + */ + smInit_sm(sm,v->vp); + for(i=0; i < cnt; i++) { - if(SM_NTH_W_DIR(sm,i)==-1) - VADD(SM_NTH_WV(sm,i),SM_NTH_WV(sm,i),ov); - smAdd_sample_to_mesh(sm,NULL,NULL,NULL,i); + /* First check if sample visible(conservative approx: if one of tris + attached to sample is in frustum) */ + if(!S_IS_FLAG(i)) + continue; + + /* Next test if direction > 30 from current direction */ + if(SM_NTH_W_DIR(sm,i)!=-1) + { + VSUB(p,SM_NTH_WV(sm,i),v->vp); + normalize(p); + decodedir(dir,SM_NTH_W_DIR(sm,i)); + d = 2. - 2.*DOT(dir,p); + if (d > MAXDIFF2) + continue; + VCOPY(p,SM_NTH_WV(sm,i)); + smAdd_samp(sm,NULL,dir,p,i); + } + else + { + VSUB(dir,SM_NTH_WV(sm,i),ov); + smAdd_samp(sm,NULL,dir,NULL,i); + } + } + smNew_tri_cnt = SM_SAMPLE_TRIS(sm); +#ifdef DEBUG + eputs("smRebuild_mesh():done\n"); +#endif } int @@ -1266,8 +1396,11 @@ intersect_tri_set(t_set,orig,dir,pt) for(i = QT_SET_CNT(t_set); i > 0; i--) { t_id = QT_SET_NEXT_ELEM(optr); - + if(SM_IS_NTH_T_BASE(smMesh,t_id)) + continue; t = SM_NTH_TRI(smMesh,t_id); + if(!T_IS_VALID(t)) + continue; pid0 = T_NTH_V(t,0); pid1 = T_NTH_V(t,1); pid2 = T_NTH_V(t,2); @@ -1291,36 +1424,67 @@ intersect_tri_set(t_set,orig,dir,pt) return(-1); } -int -ray_trace_check_set(qtptr,orig,dir,tptr,os) +/* OS is constrained to be <= QT_MAXCSET : if the set exceeds this, the + results of check_set are conservative +*/ + +ray_trace_check_set(qtptr,fptr,argptr) QUADTREE *qtptr; - FVECT orig,dir; - int *tptr; - OBJECT *os; + int *fptr; + RT_ARGS *argptr; { - OBJECT tset[QT_MAXSET+1]; + OBJECT tset[QT_MAXSET+1],*tptr; double dt,t; int found; - FVECT o; - + if(QT_LEAF_IS_FLAG(*qtptr)) + { + QT_FLAG_SET_DONE(*fptr); +#if DEBUG + eputs("ray_trace_check_set():Already visited this node:aborting\n"); +#endif + return; + } if(!QT_IS_EMPTY(*qtptr)) - { - VADD(o,orig,SM_VIEW_CENTER(smMesh)); - qtgetset(tset,*qtptr); + { + tptr = qtqueryset(*qtptr); + if(QT_SET_CNT(tptr) > QT_MAXSET) + tptr = (OBJECT *)malloc((QT_SET_CNT(tptr)+1)*sizeof(OBJECT)); + else + tptr = tset; + if(!tptr) + goto memerr; + + qtgetset(tptr,*qtptr); /* Check triangles in set against those seen so far(os):only check new triangles for intersection (t_set') */ - check_set(tset,os); - if((found = intersect_tri_set(tset,o,dir,NULL))!= -1) - { - *tptr = found; - return(QT_DONE); - } + check_set_large(tptr,argptr->os); + if((found = intersect_tri_set(tptr,argptr->orig,argptr->dir,NULL))!= -1) + { + argptr->t_id = found; + if(tptr != tset) + free(tptr); + QT_FLAG_SET_DONE(*fptr); + return; } - return(FALSE); + if(tptr != tset) + free(tptr); + } + return; +memerr: + error(SYSTEM,"ray_trace_check_set():Unable to allocate memory"); } + +/* + * int + * smFindSamp(FVECT orig, FVECT dir) + * + * Find the closest sample to the given ray. Returns sample id, -1 on failure. + * "dir" is assumed to be normalized + */ + int smFindSamp(orig,dir) FVECT orig,dir; @@ -1349,14 +1513,24 @@ FVECT orig,dir; /* orig will be updated-so preserve original value */ if(!smMesh) return; +#ifdef TEST_DRIVER + Picking= TRUE; +#endif point_on_sphere(b,orig,SM_VIEW_CENTER(smMesh)); d = -DOT(b,dir); if(EQUAL_VEC3(orig,SM_VIEW_CENTER(smMesh)) || EQUAL(fabs(d),1.0)) { - qt = smPointLocateCell(smMesh,dir,FALSE,NULL,NULL,NULL); + qt = smPointLocateCell(smMesh,dir); /* Test triangles in the set for intersection with Ray:returns first found */ +#ifdef DEBUG + if(QT_IS_EMPTY(qt)) + { + eputs("smFindSamp(): point not found"); + return; + } +#endif ts = qtqueryset(qt); s_id = intersect_tri_set(ts,orig,dir,p); #ifdef DEBUG_TEST_DRIVER @@ -1365,16 +1539,22 @@ FVECT orig,dir; } else { - OBJECT t_set[QT_MAXCSET+1]; + OBJECT t_set[QT_MAXCSET + 1]; + RT_ARGS rt; + /* Test each of the root triangles against point id */ QT_CLEAR_SET(t_set); VSUB(o,orig,SM_VIEW_CENTER(smMesh)); ST_CLEAR_FLAGS(SM_LOCATOR(smMesh)); - s_id=stTrace_ray(SM_LOCATOR(smMesh),o,dir,ray_trace_check_set,&s_id,t_set); + rt.t_id = -1; + rt.os = t_set; + VCOPY(rt.orig,orig); + VCOPY(rt.dir,dir); + stTrace_ray(SM_LOCATOR(smMesh),o,dir,ray_trace_check_set,&rt); + s_id = rt.t_id; } return(s_id); } -
