--- ray/src/hd/sm.c 1998/10/06 18:16:54 3.8 +++ ray/src/hd/sm.c 1998/11/11 12:05:37 3.9 @@ -19,15 +19,15 @@ static char SCCSid[] = "$SunId$ SGI"; SM *smMesh = NULL; double smDist_sum=0; int smNew_tri_cnt=0; -double smMinSampDiff = 1e-4; +double smMinSampDiff = 1.7e-3; /* min edge length in radians */ static FVECT smDefault_base[4] = { {SQRT3_INV, SQRT3_INV, SQRT3_INV}, {-SQRT3_INV, -SQRT3_INV, SQRT3_INV}, {-SQRT3_INV, SQRT3_INV, -SQRT3_INV}, {SQRT3_INV, -SQRT3_INV, -SQRT3_INV}}; -static int smTri_verts[4][3] = { {2,1,0},{3,2,0},{1,3,0},{2,3,1}}; +static int smTri_verts[4][3] = { {0,1,2},{0,2,3},{0,3,1},{1,3,2}}; -static int smBase_nbrs[4][3] = { {3,2,1},{3,0,2},{3,1,0},{1,2,0}}; +static int smBase_nbrs[4][3] = { {3,1,2},{3,2,0},{3,0,1},{1,0,2}}; #ifdef TEST_DRIVER VIEW Current_View = {0,{0,0,0},{0,0,-1},{0,1,0},60,60,0}; @@ -35,6 +35,7 @@ int Pick_cnt =0; int Pick_tri = -1,Picking = FALSE,Pick_samp=-1; FVECT Pick_point[500],Pick_origin,Pick_dir; FVECT Pick_v0[500], Pick_v1[500], Pick_v2[500]; +int Pick_q[500]; FVECT P0,P1,P2; FVECT FrustumNear[4],FrustumFar[4]; double dev_zmin=.01,dev_zmax=1000; @@ -490,6 +491,10 @@ OBJECT *del_set; st = SM_LOCATOR(sm); +#ifdef DEBUG + if((v0_id == INVALID) || (v1_id == INVALID) || (v2_id == INVALID)) + error(CONSISTENCY,"Invalid ids 1\n"); +#endif VSUB(v0,SM_NTH_WV(sm,v0_id),SM_VIEW_CENTER(sm)); VSUB(v1,SM_NTH_WV(sm,v1_id),SM_VIEW_CENTER(sm)); @@ -511,7 +516,13 @@ int v0_id,v1_id,v2_id; { int t_id; TRI *t; - +#ifdef DEBUG + if(v0_id==v1_id || v0_id==v2_id || v1_id==v2_id) + { + eputs("smAdd_tri: invalid vertex ids\n"); + return(INVALID); + } +#endif t_id = smAlloc_tri(sm); if(t_id == -1) @@ -562,46 +573,48 @@ smTris_swap_edge(sm,t_id,t1_id,e,e1,tn_id,tn1_id,add_p { int verts[3],enext,eprev,e1next,e1prev; - TRI *n; + TRI *n,*ta,*tb,*t,*t1; FVECT p1,p2,p3; int ta_id,tb_id; - /* swap diagonal (e relative to t, and e1 relative to t1) - defined by quadrilateral - formed by t,t1- swap for the opposite diagonal + /* form new diagonal (e relative to t, and e1 relative to t1) + defined by quadrilateral formed by t,t1- swap for the opposite diagonal */ enext = (e+1)%3; eprev = (e+2)%3; e1next = (e1+1)%3; e1prev = (e1+2)%3; verts[e] = T_NTH_V(SM_NTH_TRI(sm,t_id),e); - verts[enext] = T_NTH_V(SM_NTH_TRI(sm,t1_id),e1prev); - verts[eprev] = T_NTH_V(SM_NTH_TRI(sm,t_id),eprev); + verts[enext] = T_NTH_V(SM_NTH_TRI(sm,t_id),enext); + verts[eprev] = T_NTH_V(SM_NTH_TRI(sm,t1_id),e1); ta_id = smAdd_tri(sm,verts[0],verts[1],verts[2]); *add_ptr = push_data(*add_ptr,ta_id); verts[e1] = T_NTH_V(SM_NTH_TRI(sm,t1_id),e1); - verts[e1next] = T_NTH_V(SM_NTH_TRI(sm,t_id),eprev); - verts[e1prev] = T_NTH_V(SM_NTH_TRI(sm,t1_id),e1prev); + verts[e1next] = T_NTH_V(SM_NTH_TRI(sm,t1_id),e1next); + verts[e1prev] = T_NTH_V(SM_NTH_TRI(sm,t_id),e); tb_id = smAdd_tri(sm,verts[0],verts[1],verts[2]); *add_ptr = push_data(*add_ptr,tb_id); + ta = SM_NTH_TRI(sm,ta_id); + tb = SM_NTH_TRI(sm,tb_id); + t = SM_NTH_TRI(sm,t_id); + t1 = SM_NTH_TRI(sm,t1_id); /* set the neighbors */ - T_NTH_NBR(SM_NTH_TRI(sm,ta_id),e) = T_NTH_NBR(SM_NTH_TRI(sm,t1_id),e1next); - T_NTH_NBR(SM_NTH_TRI(sm,tb_id),e1) = T_NTH_NBR(SM_NTH_TRI(sm,t_id),enext); - T_NTH_NBR(SM_NTH_TRI(sm,ta_id),enext) =tb_id; - T_NTH_NBR(SM_NTH_TRI(sm,tb_id),e1next) = ta_id; - T_NTH_NBR(SM_NTH_TRI(sm,ta_id),eprev)=T_NTH_NBR(SM_NTH_TRI(sm,t_id),eprev); - T_NTH_NBR(SM_NTH_TRI(sm,tb_id),e1prev)= - T_NTH_NBR(SM_NTH_TRI(sm,t1_id),e1prev); + T_NTH_NBR(ta,e) = T_NTH_NBR(t1,e1next); + T_NTH_NBR(tb,e1) = T_NTH_NBR(t,enext); + T_NTH_NBR(ta,enext)= tb_id; + T_NTH_NBR(tb,e1next)= ta_id; + T_NTH_NBR(ta,eprev)=T_NTH_NBR(t,eprev); + T_NTH_NBR(tb,e1prev)=T_NTH_NBR(t1,e1prev); /* Reset neighbor pointers of original neighbors */ - n = SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,t_id),enext)); + n = SM_NTH_TRI(sm,T_NTH_NBR(t,enext)); T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = tb_id; - n = SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,t_id),eprev)); + n = SM_NTH_TRI(sm,T_NTH_NBR(t,eprev)); T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = ta_id; - n = SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,t1_id),e1next)); + n = SM_NTH_TRI(sm,T_NTH_NBR(t1,e1next)); T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = ta_id; - n = SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,t1_id),e1prev)); + n = SM_NTH_TRI(sm,T_NTH_NBR(t1,e1prev)); T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = tb_id; /* Delete two parent triangles */ @@ -655,7 +668,7 @@ LIST *tlist,*add_list; QUADTREE *delptr; { TRI *t,*t_opp; - FVECT p,p1,p2,p3; + FVECT p,p0,p1,p2; int e,e1,swapped = 0; int t_id,t_opp_id; @@ -663,15 +676,23 @@ QUADTREE *delptr; while(tlist) { t_id = pop_list(&tlist); +#ifdef DEBUG + if(t_id==INVALID || t_id > smMesh->num_tri) + error(CONSISTENCY,"Invalid tri id smFix_tris()\n"); +#endif t = SM_NTH_TRI(sm,t_id); - e = (T_WHICH_V(t,id)+1)%3; + e = T_WHICH_V(t,id); t_opp_id = T_NTH_NBR(t,e); - t_opp = SM_NTH_TRI(sm,t_opp_id); - - smDir_in_cone(sm,p1,T_NTH_V(t_opp,0)); - smDir_in_cone(sm,p2,T_NTH_V(t_opp,1)); - smDir_in_cone(sm,p3,T_NTH_V(t_opp,2)); - if(point_in_cone(p,p1,p2,p3)) +#ifdef DEBUG + if(t_opp_id==INVALID || t_opp_id > smMesh->num_tri) + error(CONSISTENCY,"Invalid tri id smFix_tris()\n"); +#endif + t_opp = SM_NTH_TRI(sm,t_opp_id); + + smDir_in_cone(sm,p0,T_NTH_V(t_opp,0)); + smDir_in_cone(sm,p1,T_NTH_V(t_opp,1)); + smDir_in_cone(sm,p2,T_NTH_V(t_opp,2)); + if(point_in_cone(p,p0,p1,p2)) { swapped = 1; e1 = T_NTH_NBR_PTR(t_id,t_opp); @@ -700,7 +721,7 @@ int id; int nbr_id; /* Want the edge for which "id" is the destination */ - t_id = (T_WHICH_V(t,id)+ 2)% 3; + t_id = (T_WHICH_V(t,id)+ 1)% 3; nbr_id = T_NTH_NBR(t,t_id); return(nbr_id); } @@ -751,23 +772,23 @@ smInsert_samp(sm,s_id,tri_id) tri = SM_NTH_TRI(sm,tri_id); /* Set the neighbor pointers for the new tris */ - T_NTH_NBR(SM_NTH_TRI(sm,t0_id),0) = t2_id; - T_NTH_NBR(SM_NTH_TRI(sm,t0_id),1) = T_NTH_NBR(tri,0); - T_NTH_NBR(SM_NTH_TRI(sm,t0_id),2) = t1_id; - T_NTH_NBR(SM_NTH_TRI(sm,t1_id),0) = t0_id; - T_NTH_NBR(SM_NTH_TRI(sm,t1_id),1) = T_NTH_NBR(tri,1); - T_NTH_NBR(SM_NTH_TRI(sm,t1_id),2) = t2_id; - T_NTH_NBR(SM_NTH_TRI(sm,t2_id),0) = t1_id; - T_NTH_NBR(SM_NTH_TRI(sm,t2_id),1) = T_NTH_NBR(tri,2); - T_NTH_NBR(SM_NTH_TRI(sm,t2_id),2) = t0_id; + T_NTH_NBR(SM_NTH_TRI(sm,t0_id),0) = T_NTH_NBR(tri,2); + T_NTH_NBR(SM_NTH_TRI(sm,t0_id),1) = t1_id; + T_NTH_NBR(SM_NTH_TRI(sm,t0_id),2) = t2_id; + T_NTH_NBR(SM_NTH_TRI(sm,t1_id),0) = T_NTH_NBR(tri,0); + T_NTH_NBR(SM_NTH_TRI(sm,t1_id),1) = t2_id; + T_NTH_NBR(SM_NTH_TRI(sm,t1_id),2) = t0_id; + T_NTH_NBR(SM_NTH_TRI(sm,t2_id),0) = T_NTH_NBR(tri,1); + T_NTH_NBR(SM_NTH_TRI(sm,t2_id),1) = t0_id; + T_NTH_NBR(SM_NTH_TRI(sm,t2_id),2) = t1_id; /* Reset the neigbor pointers for the neighbors of the original */ nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,0)); - T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t0_id; - nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,1)); T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t1_id; - nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,2)); + nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,1)); T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t2_id; + nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,2)); + T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t0_id; del_set[0] = 1; del_set[1] = tri_id; delnode = qtnewleaf(del_set); @@ -809,14 +830,14 @@ OBJECT *optr; if(EQUAL_VEC3(v0,p) || EQUAL_VEC3(v1,p) || EQUAL_VEC3(v2,p)) return(t_id); - VCROSS(n,v1,v0); + VCROSS(n,v0,v1); if(DOT(n,p) >0.0) continue; - VCROSS(n,v2,v1); + VCROSS(n,v1,v2); if(DOT(n,p) > 0.0) continue; - VCROSS(n,v0,v2); + VCROSS(n,v2,v0); if(DOT(n,p) > 0.0) continue; @@ -826,14 +847,14 @@ OBJECT *optr; } int -smPointLocateTri(sm,id) +smPointLocateTri(sm,p) SM *sm; -int id; +FVECT p; { - FVECT tpt; QUADTREE qt,*optr; - - VSUB(tpt,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm)); + FVECT tpt; + + VSUB(tpt,p,SM_VIEW_CENTER(sm)); qt = smPointLocateCell(sm,tpt); if(QT_IS_EMPTY(qt)) return(INVALID); @@ -875,19 +896,20 @@ int id; This attempts to throw out points that should be occluded */ int -smTest_sample(sm,tri_id,s_id,dir,rptr) +smTest_sample(sm,tri_id,c,dir,p,o_id,rptr) SM *sm; - int tri_id,s_id; - FVECT dir; + int tri_id; + COLR c; + FVECT dir,p; + int o_id; int *rptr; { TRI *tri; double d,d2,dnear,dspt,d01,d12,d20,s0,s1,s2,ds,dv; int vid[3],i,nearid,norm,dcnt,bcnt; FVECT diff[3],spt,npt; - FVECT p; + int tonemap; - VCOPY(p,SM_NTH_WV(sm,s_id)); *rptr = INVALID; bcnt = dcnt = 0; tri = SM_NTH_TRI(sm,tri_id); @@ -909,15 +931,15 @@ smTest_sample(sm,tri_id,s_id,dir,rptr) dcnt++; VSUB(diff[i],SM_NTH_WV(sm,vid[i]),p); /* If same world point: replace */ - if(ZERO_VEC3(diff[i])) + if(FZERO_VEC3(diff[i])) { - sReset_samp(SM_SAMP(sm),vid[i],s_id); - SM_TONE_MAP(sm) = 0; - return(FALSE); + tonemap = (SM_TONE_MAP(sm) > vid[i]); + sInit_samp(SM_SAMP(sm),vid[i],c,dir,p,o_id,tonemap); + return(FALSE); } } - if(SM_DIR_ID(sm,s_id)) - return(TRUE); + if(!dir) + return(TRUE); /* TEST 2: If the new sample is close in ws, and close in the spherical projection to one of the triangle vertex samples */ @@ -949,10 +971,7 @@ smTest_sample(sm,tri_id,s_id,dir,rptr) VSUB(npt,SM_NTH_WV(sm,nearid),SM_VIEW_CENTER(sm)); normalize(npt); d = fdir2diff(SM_NTH_W_DIR(sm,nearid), npt); - if(dir) - d2 = 2. - 2.*DOT(dir,spt); - else - d2 = fdir2diff(SM_NTH_W_DIR(sm,s_id), spt); + d2 = 2. - 2.*DOT(dir,spt); /* The existing sample is a better sample:punt */ if(d2 > d) return(FALSE); @@ -1025,16 +1044,25 @@ smTest_sample(sm,tri_id,s_id,dir,rptr) if(s2 < S_REPLACE_SCALE*d) return(TRUE); + /* TEST 5: + Check to see if triangle is relatively large and should therefore + be subdivided anyway. + */ + dv *= DIST_SQ(SM_NTH_WV(sm,vid[1]),SM_VIEW_CENTER(sm)); + dv *= DIST_SQ(SM_NTH_WV(sm,vid[2]),SM_VIEW_CENTER(sm)); + if (d01*d12*d20/dv > S_REPLACE_TRI) + return(TRUE); return(FALSE); } int -smAlloc_samp(sm,c,dir,pt) +smAlloc_samp(sm,c,dir,pt,o_id) SM *sm; COLR c; FVECT dir,pt; +int o_id; { int s_id,replaced,cnt; SAMP *s; @@ -1046,7 +1074,7 @@ FVECT dir,pt; cnt=0; while(replaced) { - if(smMesh_remove_vertex(sm,s_id)) + if(smRemoveVertex(sm,s_id)) break; s_id = sAlloc_samp(s,&replaced); cnt++; @@ -1054,51 +1082,83 @@ FVECT dir,pt; error(CONSISTENCY,"smAlloc_samp():unable to find free samp\n"); } - if(pt) - sInit_samp(s,s_id,c,dir,pt); - else - { - VADD(p,dir,SM_VIEW_CENTER(sm)); - sInit_samp(s,s_id,c,NULL,p); - } + /* If sample is being added in the middle of the sample array: tone + map individually + */ + /* Initialize sample */ + sInit_samp(s,s_id,c,dir,pt,o_id,(SM_TONE_MAP(sm)>s_id)); + return(s_id); } int -smAdd_samp(sm,s_id,p,dir) +smAdd_samp(sm,c,dir,p,o_id) SM *sm; - int s_id; - FVECT p,dir; + COLR c; + FVECT dir,p; + int o_id; { - int t_id,r_id,test; - double d; + int t_id,s_id,r_id; + double d; + FVECT wpt; - r_id = INVALID; - t_id = smPointLocateTri(sm,s_id); + r_id = INVALID; + /* If sample is a world space point */ + if(p) + { + t_id = smPointLocateTri(sm,p); if(t_id == INVALID) + { +#ifdef DEBUG + eputs("smAddSamp(): unable to locate tri containing sample \n"); +#endif + return(INVALID); + } + /* if not a base id, Test to see if this sample should be added */ + if(!SM_BASE_ID(sm,o_id)) { + if(!smTest_sample(sm,t_id,c,dir,p,o_id,&r_id)) + return(INVALID); + /* Allocate space for a sample and initialize */ + s_id = smAlloc_samp(smMesh,c,dir,p,o_id); + } + else + s_id = o_id; + } + /* If sample is a direction vector */ + else + { + VADD(wpt,dir,SM_VIEW_CENTER(smMesh)); + t_id = smPointLocateTri(sm,wpt); + if(t_id == INVALID) + { #ifdef DEBUG - eputs("smAdd_samp(): tri not found \n"); + eputs("smAddSamp(): unable to locate tri containing sample \n"); #endif - return(FALSE); + return(INVALID); + } + /* Test to see if this sample should be added */ + if(!smTest_sample(sm,t_id,c,NULL,wpt,o_id,&r_id)) + return(INVALID); + /* Allocate space for a sample and initialize */ + s_id = smAlloc_samp(smMesh,c,NULL,wpt,o_id); } - if(!SM_BASE_ID(sm,s_id)) + if(!SM_BASE_ID(sm,s_id) && !SM_DIR_ID(sm,s_id)) { - if(!smTest_sample(sm,t_id,s_id,dir,&r_id)) - return(FALSE); - /* If not a sky point, add distance from the viewcenter to average*/ - if( !SM_DIR_ID(sm,s_id)) - { - d = DIST(p,SM_VIEW_CENTER(smMesh)); - smDist_sum += 1.0/d; - } + /* If not a base or sky point, add distance from the + viewcenter to average*/ + d = DIST(SM_NTH_WV(sm,s_id),SM_VIEW_CENTER(smMesh)); + smDist_sum += 1.0/d; } - test = smInsert_samp(smMesh,s_id,t_id); + smInsert_samp(smMesh,s_id,t_id); - if(test && r_id != INVALID) - smMesh_remove_vertex(sm,r_id); - - return(test); + /* If new sample replaces existing one- remove that vertex now */ + if(r_id != INVALID) + { + smRemoveVertex(sm,r_id); + sDelete_samp(SM_SAMP(sm),r_id); + } + return(s_id); } /* @@ -1117,47 +1177,18 @@ smNewSamp(c,dir,p) COLR c; FVECT dir; FVECT p; - { int s_id; - int debug=0; - static FILE *fp; - static int cnt=0,n=3010; + /* First check if this the first sample: if so initialize mesh */ if(SM_NUM_SAMP(smMesh) == 0) - { - smInit_sm(smMesh,odev.v.vp); -#if 0 - fp = fopen("Debug_data.view","w"); - fprintf(fp,"%d %d %f %f %f ",1280,1024,odev.v.vp[0],odev.v.vp[1], - odev.v.vp[2]); - fprintf(fp,"%f %f %f ",odev.v.vdir[0],odev.v.vdir[1], - odev.v.vdir[2]); - fprintf(fp,"%f %f %f ",odev.v.vup[0],odev.v.vup[1],odev.v.vup[2]); - fprintf(fp,"%f %f ",odev.v.horiz,odev.v.vert); - fclose(fp); - fp = fopen("Debug_data","w"); -#endif - } -#if 0 - fprintf(fp,"%f %f %f %f %f %f ",p[0],p[1],p[2],(float)c[0]/255.0,(float)c[1]/255.0, - (float)c[2]/255.0); -#endif - - /* Allocate space for a sample */ - s_id = smAlloc_samp(smMesh,c,dir,p); -#if 0 - if(cnt==n) - return(-1); - cnt++; -#endif - /* Add the sample to the mesh */ - if(!smAdd_samp(smMesh,s_id,p,dir)) - { - /* If the sample space was not used: return */ - smUnalloc_samp(smMesh,s_id); - s_id = INVALID; + { + smInit_sm(smMesh,odev.v.vp); + sClear_all_flags(SM_SAMP(smMesh)); } + /* Add the sample to the mesh */ + s_id = smAdd_samp(smMesh,c,dir,p,INVALID); + return(s_id); } @@ -1221,7 +1252,6 @@ int type; for(nbr_id=0; nbr_id < 3; nbr_id++) T_NTH_NBR(SM_NTH_TRI(sm,ids[tri_id]),nbr_id) = smBase_nbrs[tri_id][nbr_id]; - /* Now add the centroids of the faces */ for(tri_id=0;tri_id < 4; tri_id++) { @@ -1233,7 +1263,7 @@ int type; normalize(cntr); VADD(cntr,cntr,SM_VIEW_CENTER(sm)); s_id = smAdd_base_vertex(sm,cntr); - smAdd_samp(sm,s_id,NULL,NULL); + smAdd_samp(sm,NULL,NULL,cntr,s_id); } return(1); @@ -1312,13 +1342,13 @@ smRebuild_mesh(sm,v) cnt = SM_NUM_SAMP(sm); /* Calculate the difference between the current and new viewpoint*/ /* Will need to subtract this off of sky points */ - VSUB(ov,v->vp,SM_VIEW_CENTER(sm)); + VCOPY(ov,SM_VIEW_CENTER(sm)); /* Initialize the mesh to 0 samples and the base triangles */ /* Go through all samples and add in if in the new view frustum, and the dir is <= 30 degrees from new view */ - j=0; + smInit_sm(sm,v->vp); for(i=0; i < cnt; i++) { /* First check if sample visible(conservative approx: if one of tris @@ -1331,22 +1361,21 @@ smRebuild_mesh(sm,v) { VSUB(p,SM_NTH_WV(sm,i),v->vp); normalize(p); - d = fdir2diff(SM_NTH_W_DIR(sm,i), p); + decodedir(dir,SM_NTH_W_DIR(sm,i)); + d = 2. - 2.*DOT(dir,p); if (d > MAXDIFF2) continue; + VCOPY(p,SM_NTH_WV(sm,i)); + smAdd_samp(sm,NULL,dir,p,i); } - sReset_samp(SM_SAMP(sm),j,i); - j++; + else + { + VSUB(dir,SM_NTH_WV(sm,i),ov); + smAdd_samp(sm,NULL,dir,NULL,i); + } + } - smInit_sm(sm,v->vp); - for(i=0; i< j; i++) - { - S_SET_FLAG(i); - VCOPY(p,SM_NTH_WV(sm,i)); - smAdd_samp(sm,i,p,NULL); - } - SM_NUM_SAMP(sm) = j; - smNew_tri_cnt = SM_SAMPLE_TRIS(sm); + smNew_tri_cnt = SM_SAMPLE_TRIS(sm); #ifdef DEBUG eputs("smRebuild_mesh():done\n"); #endif @@ -1367,11 +1396,11 @@ intersect_tri_set(t_set,orig,dir,pt) for(i = QT_SET_CNT(t_set); i > 0; i--) { t_id = QT_SET_NEXT_ELEM(optr); - + if(SM_IS_NTH_T_BASE(smMesh,t_id)) + continue; t = SM_NTH_TRI(smMesh,t_id); if(!T_IS_VALID(t)) continue; - pid0 = T_NTH_V(t,0); pid1 = T_NTH_V(t,1); pid2 = T_NTH_V(t,2); @@ -1484,6 +1513,9 @@ FVECT orig,dir; /* orig will be updated-so preserve original value */ if(!smMesh) return; +#ifdef TEST_DRIVER + Picking= TRUE; +#endif point_on_sphere(b,orig,SM_VIEW_CENTER(smMesh)); d = -DOT(b,dir); if(EQUAL_VEC3(orig,SM_VIEW_CENTER(smMesh)) || EQUAL(fabs(d),1.0))
