--- ray/src/hd/sm.c 1999/06/10 15:22:21 3.15 +++ ray/src/hd/sm.c 2003/06/20 00:25:49 3.18 @@ -1,9 +1,6 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: sm.c,v 3.18 2003/06/20 00:25:49 greg Exp $"; #endif - /* * sm.c */ @@ -13,8 +10,6 @@ static char SCCSid[] = "$SunId$ SGI"; #include "sm_geom.h" #include "sm.h" - - SM *smMesh = NULL; double smDist_sum=0; @@ -243,7 +238,6 @@ tempbuf(len,resize) /* get a temporary buffer */ unsigned len; int resize; { - extern char *malloc(), *realloc(); static char *tempbuf = NULL; static unsigned tempbuflen = 0; @@ -263,7 +257,7 @@ int resize; #endif if (len > tempbuflen) { if (tempbuflen > 0) - tempbuf = realloc(tempbuf, len); + tempbuf = realloc((void *)tempbuf, len); else tempbuf = malloc(len); tempbuflen = tempbuf==NULL ? 0 : len; @@ -277,7 +271,7 @@ int resize; smDir(sm,ps,id) SM *sm; FVECT ps; - int id; + S_ID id; { VSUB(ps,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm)); normalize(ps); @@ -333,7 +327,7 @@ int max_verts,max_tris; goto memerr; for(i=0; i< T_FLAGS; i++) - if(!(SM_NTH_FLAGS(sm,i)=(int4 *)malloc(fbytes))) + if(!(SM_NTH_FLAGS(sm,i)=(int32 *)malloc(fbytes))) goto memerr; SM_MAX_VERTS(sm) = max_verts; @@ -347,6 +341,12 @@ memerr: } +/* + * smAlloc_tri(sm) : Allocate a new mesh triangle + * SM *sm; : mesh + * + * Returns ptr to next available tri + */ int smAlloc_tri(sm) SM *sm; @@ -367,6 +367,7 @@ SM *sm; return(INVALID); } + smFree_mesh(sm) SM *sm; { @@ -379,8 +380,13 @@ SM *sm; free(SM_NTH_FLAGS(sm,i)); } - -/* Initialize/clear global smL sample list for at least n samples */ + +/* + * smAlloc(max_samples) : Initialize/clear global sample list for at least + * max_samples + * int max_samples; + * + */ smAlloc(max_samples) register int max_samples; { @@ -429,7 +435,6 @@ smInit_sm(sm,vp) SM *sm; FVECT vp; { - VCOPY(SM_VIEW_CENTER(sm),vp); smClear(sm); smCreate_base_mesh(sm,SM_DEFAULT); @@ -445,13 +450,12 @@ FVECT vp; * If n is <= 0, then clear data structures. Returns number samples * actually allocated. */ - int smInit(n) register int n; { int max_vertices; - + sleep(5); /* If n <=0, Just clear the existing structures */ if(n <= 0) { @@ -505,6 +509,22 @@ smLocator_apply(sm,v0,v1,v2,func,n) } +/* + * QUADTREE + * insert_samp(argptr,root,qt,parent,q0,q1,q2,bc,scale,rev,f,n,doneptr) + * Callback function called from quadtree traversal when leaf is reached + * int *argptr; :ptr to sample id number + * int root; :quadtree root from which traversal started + * QUADTREE qt,parent; :current quadtree node and its parent + * BCOORD q0[3],q1[3],q2[3],bc[3]; :barycentric coordinates of the current + * quadtree node (q0,q1,q2) and sample (bc) + * unsigned int scale,rev; :scale factor relative to which level at in + * tree, rev indicates if traversed of child 3 + * FUNC f; :function structure so can recurse + * int n,*doneptr; :n indicates which level at in quadtree, and + * doneptr can be set to indicate whether nbr + * sample has been found + */ QUADTREE insert_samp(argptr,root,qt,parent,q0,q1,q2,bc,scale,rev,f,n,doneptr) int *argptr; @@ -515,12 +535,8 @@ insert_samp(argptr,root,qt,parent,q0,q1,q2,bc,scale,re FUNC f; int n,*doneptr; { - OBJECT *optr,*sptr,s_set[QT_MAXSET+1]; - int i,s_id; - FVECT p; - BCOORD bp[3]; - FUNC sfunc; - S_ARGS args; + S_ID s_id; + S_ID *optr; s_id = ((S_ARGS *)argptr)->s_id; /* If the set is empty - just add */ @@ -557,77 +573,85 @@ insert_samp(argptr,root,qt,parent,q0,q1,q2,bc,scale,re /* otherwise: expand node- and insert sample, and reinsert existing samples in set to children of new node */ - if(QT_SET_CNT(optr) > QT_MAXSET) - { - if(!(sptr = (OBJECT *)malloc((QT_SET_CNT(optr)+1)*sizeof(OBJECT)))) - goto memerr; - } - else - sptr = s_set; - qtgetset(sptr,qt); - - /* subdivide node */ - qtfreeleaf(qt); - qtSubdivide(qt); - - /* Now add in all of the rest; */ - F_FUNC(sfunc) = F_FUNC(f); - F_ARGS(sfunc) = (int *) (&args); - args.n_id = 0; - for(optr = sptr,i=QT_SET_CNT(sptr); i > 0; i--) { - s_id = QT_SET_NEXT_ELEM(optr); - args.s_id = s_id; - VSUB(p,SM_NTH_WV(smMesh,s_id),SM_VIEW_CENTER(smMesh)); - normalize(p); - vert_to_qt_frame(i,p,bp); - if(rev) - qt= qtInsert_point_rev(root,qt,parent,q0,q1,q2,bp,scale,sfunc,n,doneptr); - else - qt= qtInsert_point(root,qt,parent,q0,q1,q2,bp,scale,sfunc,n,doneptr); - } - /* Add current sample: have all of the information */ - if(rev) - qt =qtInsert_point_rev(root,qt,parent,q0,q1,q2,bc,scale,f,n,doneptr); - else - qt = qtInsert_point(root,qt,parent,q0,q1,q2,bc,scale,f,n,doneptr); - - /* If we allocated memory: free it */ + OBJECT *sptr,s_set[QT_MAXSET+1]; + FUNC sfunc; + S_ARGS args; + FVECT p; + BCOORD bp[3]; + int i; + + if(QT_SET_CNT(optr) > QT_MAXSET) + { + if(!(sptr = (OBJECT *)malloc((QT_SET_CNT(optr)+1)*sizeof(OBJECT)))) + goto memerr; + } + else + sptr = s_set; - if( sptr != s_set) - free(sptr); + qtgetset(sptr,qt); + + /* subdivide node */ + qtfreeleaf(qt); + qtSubdivide(qt); + + /* Now add in all of the rest; */ + F_FUNC(sfunc) = F_FUNC(f); + F_ARGS(sfunc) = (int *) (&args); + args.n_id = 0; + for(optr = sptr,i=QT_SET_CNT(sptr); i > 0; i--) + { + s_id = QT_SET_NEXT_ELEM(optr); + args.s_id = s_id; + VSUB(p,SM_NTH_WV(smMesh,s_id),SM_VIEW_CENTER(smMesh)); + normalize(p); + vert_to_qt_frame(i,p,bp); + if(rev) + qt= qtInsert_point_rev(root,qt,parent,q0,q1,q2,bp, + scale,sfunc,n,doneptr); + else + qt= qtInsert_point(root,qt,parent,q0,q1,q2,bp, + scale,sfunc,n,doneptr); + } + /* Add current sample: have all of the information */ + if(rev) + qt =qtInsert_point_rev(root,qt,parent,q0,q1,q2,bc,scale,f,n,doneptr); + else + qt = qtInsert_point(root,qt,parent,q0,q1,q2,bc,scale,f,n,doneptr); + + /* If we allocated memory: free it */ - return(qt); + if( sptr != s_set) + free(sptr); + + return(qt); + } memerr: error(SYSTEM,"expand_node():Unable to allocate memory"); } -double -triangle_normal(n,a,b,c) -double n[3]; -double a[3],b[3],c[3]; -{ - double ab[3],ac[3]; - - VSUB(ab,b,a); - normalize(ab); - VSUB(ac,c,a); - normalize(ac); - VCROSS(n,ab,ac); - return(normalize(n)); -} -double on0,on1,on2; -/* Add a triangle to the base array with vertices v1-v2-v3 */ +/* + * int + * smAdd_tri(sm,v0_id,v1_id,v2_id,tptr) + * : Add a triangle to the base array with vertices v0-v1-v2, + * returns ptr to triangle in tptr + * SM *sm; : mesh + * S_ID v0_id,v1_id,v2_id; : sample ids of triangle vertices + * TRI **tptr; : ptr to set to triangle + * + * Allocates and initializes mesh triangle with vertices specified. + */ int smAdd_tri(sm, v0_id,v1_id,v2_id,tptr) SM *sm; -int v0_id,v1_id,v2_id; +S_ID v0_id,v1_id,v2_id; TRI **tptr; { int t_id; TRI *t; + #ifdef DEBUG if(v0_id==v1_id || v0_id==v2_id || v1_id==v2_id) error(CONSISTENCY,"smAdd_tri: invalid vertex ids\n"); @@ -639,28 +663,32 @@ TRI **tptr; { double v0[3],v1[3],v2[3],n[3]; double area,dp; - + double ab[3],ac[3]; VSUB(v0,SM_NTH_WV(sm,v0_id),SM_VIEW_CENTER(sm)); VSUB(v1,SM_NTH_WV(sm,v1_id),SM_VIEW_CENTER(sm)); VSUB(v2,SM_NTH_WV(sm,v2_id),SM_VIEW_CENTER(sm)); normalize(v0); normalize(v1); normalize(v2); - area = triangle_normal(n,v2,v1,v0); + + VSUB(ab,v1,v2); + normalize(ab); + VSUB(ac,v0,v2); + normalize(ac); + VCROSS(n,ab,ac); + area = normalize(n); if((dp=DOT(v0,n)) < 0.0) { - fprintf(stderr,"dp = %.10f on0=%.10f on1=%.10f on2=%.10f\n", dp, - on0,on1,on2); eputs("backwards tri\n"); } } #endif #endif - t = SM_NTH_TRI(sm,t_id); - +#ifdef DEBUG T_CLEAR_NBRS(t); +#endif /* set the triangle vertex ids */ T_NTH_V(t,0) = v0_id; T_NTH_V(t,1) = v1_id; @@ -685,61 +713,21 @@ TRI **tptr; SM_SET_NTH_T_ACTIVE(sm,t_id); SM_SET_NTH_T_NEW(sm,t_id); - *tptr = t; /* return initialized triangle */ return(t_id); } -/* pt_in_cone: assumed apex at origin, a,b,c are unit vectors defining the - triangle which the cone circumscribes. Assumed p is not normalized - */ -int -pt_in_cone(p,a,b,c) -double p[3],a[3],b[3],c[3]; -{ - double r[3]; - double pr,ar; - double ab[3],ac[3]; - /* r = (B-A)X(C-A) */ - /* in = (p.r) > (a.r) */ -#ifdef DEBUG -#if DEBUG > 1 -{ - double l; - l = triangle_normal(r,a,b,c); - /* l = sin@ between ab,ac - if 0 vectors are colinear */ - if( l <= COLINEAR_EPS) - { - eputs("pt in cone: null triangle:returning FALSE\n"); - return(FALSE); - } -} -#endif -#endif - - VSUB(ab,b,a); - VSUB(ac,c,a); - VCROSS(r,ab,ac); - - pr = DOT(p,r); - ar = DOT(a,r); - /* Need to check for equality for degeneracy of 4 points on circle */ - if( pr > ar *( 1.0 + EQUALITY_EPS)) - return(TRUE); - else - return(FALSE); -} - smRestore_Delaunay(sm,a,b,c,t,t_id,a_id,b_id,c_id) SM *sm; FVECT a,b,c; TRI *t; int t_id,a_id,b_id,c_id; { - int e1,topp_id,p_id; + int e1,topp_id; + S_ID p_id; TRI *topp; FVECT p; @@ -883,7 +871,7 @@ int smTri_next_ccw_nbr(sm,t,id) SM *sm; TRI *t; -int id; +S_ID id; { int which; int nbr_id; @@ -912,13 +900,15 @@ int id; int smInsert_samp_mesh(sm,s_id,tri_id,a,b,c,d,on,which) SM *sm; - int s_id,tri_id; + S_ID s_id; + int tri_id; FVECT a,b,c,d; int on,which; { - int v_id[3],topp_id,i; + S_ID v_id[3],opp_id; + int topp_id,i; int t0_id,t1_id,t2_id,t3_id; - int e0,e1,e2,opp_id,opp0,opp1,opp2; + int e0,e1,e2,opp0,opp1,opp2; TRI *tri,*nbr,*topp,*t0,*t1,*t2,*t3; FVECT e; @@ -1331,7 +1321,7 @@ FVECT a,b; { FVECT n,v0,v1,v2; TRI *tn; - + double on0,on1,on2; int tn_id; #ifdef DEBUG @@ -1712,15 +1702,16 @@ FVECT a,b; if(EQUAL_VEC3(v2,p)){ *o = ON_V; *w = 2; return(t_id);} -int + find_neighbor(argptr,qt,f,doneptr) int *argptr; QUADTREE qt; FUNC f; int *doneptr; { - int s_id,i; - OBJECT *optr; + S_ID s_id; + int i; + S_ID *optr; if(QT_IS_EMPTY(qt)) return; @@ -1752,9 +1743,9 @@ int *doneptr; smInsert_samp(sm,s_id,p,nptr) SM *sm; -int s_id; +S_ID s_id; FVECT p; -int *nptr; +S_ID *nptr; { FVECT tpt; FUNC f; @@ -1781,8 +1772,9 @@ int smSample_locate_tri(sm,p,s_id,onptr,whichptr,nptr) SM *sm; FVECT p; -int s_id; -int *onptr,*whichptr,*nptr; +S_ID s_id; +int *onptr,*whichptr; +S_ID *nptr; { int tri_id; FVECT tpt; @@ -1853,7 +1845,7 @@ smTest_samp(sm,tri_id,dir,p,rptr,ns,n0,n1,n2,ds,d0,on, SM *sm; int tri_id; FVECT dir,p; - int *rptr; + S_ID *rptr; FVECT ns,n0,n1,n2; double ds,d0; int on,which; @@ -1861,7 +1853,8 @@ smTest_samp(sm,tri_id,dir,p,rptr,ns,n0,n1,n2,ds,d0,on, TRI *tri; double d,d2,dnear,dspt,d01,d12,d20,s0,s1,s2; double dp,dp1; - int vid[3],i,nearid,norm,dcnt,bcnt; + S_ID vid[3]; + int i,norm,dcnt,bcnt; FVECT diff[3],spt,npt,n; FVECT nearpt; @@ -1880,44 +1873,26 @@ smTest_samp(sm,tri_id,dir,p,rptr,ns,n0,n1,n2,ds,d0,on, if(SM_DIR_ID(sm,vid[i])) dcnt++; } - if( on == IN_T) - { - d = DIST_SQ(n0,ns); - dnear = d; - nearid = 0; - d = DIST_SQ(n1,ns); - if(d < dnear) - { - dnear = d; nearid = 1; - } - d = DIST_SQ(n2,ns); - if(d < dnear) - { - dnear = d; nearid = 2; - } - } if(on == ON_P) - nearid = which; - if(on == ON_P || dnear < VERT_EPS*VERT_EPS) { FVECT edir; - /* Pick the point with dir closest to that of the canonical view - if it is the new sample: mark existing point for deletion - */ - if(SM_BASE_ID(sm,vid[nearid])) - return(FALSE); + /* Pick the point with dir closest to that of the canonical view + if it is the new sample: mark existing point for deletion + */ if(!dir) - return(FALSE); - if(SM_DIR_ID(sm,vid[nearid])) + return(FALSE); + if(SM_BASE_ID(sm,vid[which])) + return(FALSE); + if(SM_DIR_ID(sm,vid[which])) { - *rptr = vid[nearid]; - return(TRUE); + *rptr = vid[which]; + return(TRUE); } - decodedir(edir,SM_NTH_W_DIR(sm,vid[nearid])); - if(nearid == 0) + decodedir(edir,SM_NTH_W_DIR(sm,vid[which])); + if(which == 0) d = DOT(edir,n0); else - if(nearid == 1) + if(which == 1) d = DOT(edir,n1); else d = DOT(edir,n2); @@ -1928,7 +1903,7 @@ smTest_samp(sm,tri_id,dir,p,rptr,ns,n0,n1,n2,ds,d0,on, else { /* The new sample is better: mark existing one for deletion*/ - *rptr = vid[nearid]; + *rptr = vid[which]; return(TRUE); } } @@ -2026,14 +2001,18 @@ smTest_samp(sm,tri_id,dir,p,rptr,ns,n0,n1,n2,ds,d0,on, return(FALSE); } -int +S_ID smReplace_samp(sm,c,dir,p,np,s_id,t_id,o_id,on,which) SM *sm; COLR c; FVECT dir,p,np; - int s_id,t_id,o_id,on,which; + S_ID s_id; + int t_id; + S_ID o_id; + int on,which; { - int v_id,tri_id; + S_ID v_id; + int tri_id; TRI *t,*tri; tri = SM_NTH_TRI(sm,t_id); @@ -2082,11 +2061,12 @@ smReplace_samp(sm,c,dir,p,np,s_id,t_id,o_id,on,which) } -int +S_ID smAlloc_samp(sm) SM *sm; { - int s_id,replaced,cnt; + S_ID s_id; + int replaced,cnt; SAMP *s; FVECT p; @@ -2114,14 +2094,15 @@ SM *sm; b) coincide with existing edge c) Fall in existing triangle */ -int +S_ID smAdd_samp(sm,c,dir,p,o_id) SM *sm; COLR c; FVECT dir,p; - int o_id; + S_ID o_id; { - int t_id,s_id,r_id,on,which,n_id,nbr_id; + int t_id,on,which,n_id; + S_ID s_id,r_id,nbr_id; double ds,d0; FVECT wpt,ns,n0,n1,n2; QUADTREE qt,parent; @@ -2131,7 +2112,6 @@ smAdd_samp(sm,c,dir,p,o_id) nbr_id = INVALID; /* Must do this first-as may change mesh */ s_id = smAlloc_samp(sm); - SM_S_NTH_QT(sm,s_id)= EMPTY; /* If sample is a world space point */ if(p) @@ -2196,16 +2176,17 @@ smAdd_samp(sm,c,dir,p,o_id) /* If sample is being added in the middle of the sample array: tone map individually */ - /* Initialize sample */ - sInit_samp(SM_SAMP(sm),s_id,c,dir,p,o_id); /* If not base or sky point, add distance from center to average*/ smDist_sum += 1.0/ds; + /* Initialize sample */ + sInit_samp(SM_SAMP(sm),s_id,c,dir,p,o_id); smInsert_samp_mesh(sm,s_id,t_id,ns,n0,n1,n2,on,which); } /* If sample is a direction vector */ else { VADD(wpt,dir,SM_VIEW_CENTER(sm)); + /* Allocate space for a sample and initialize */ while(1) { t_id = smSample_locate_tri(sm,dir,s_id,&on,&which,&nbr_id); @@ -2250,7 +2231,6 @@ smAdd_samp(sm,c,dir,p,o_id) else break; } - /* Allocate space for a sample and initialize */ sInit_samp(SM_SAMP(sm),s_id,c,NULL,wpt,o_id); smInsert_samp_mesh(sm,s_id,t_id,dir,n0,n1,n2,on,which); } @@ -2268,48 +2248,36 @@ smAdd_samp(sm,c,dir,p,o_id) * New sample representation will be output in next call to smUpdate(). * If the point is a sky point: then v=NULL */ +#define FVECT_TO_SFLOAT(p) \ + (p[0]=(SFLOAT)p[0],p[1]=(SFLOAT)p[1],p[2]=(SFLOAT)p[2]) int smNewSamp(c,dir,p) COLR c; FVECT dir; FVECT p; { - int s_id; + S_ID s_id; + /* First check if this the first sample: if so initialize mesh */ if(SM_NUM_SAMP(smMesh) == 0) { smInit_sm(smMesh,odev.v.vp); sClear_all_flags(SM_SAMP(smMesh)); } + FVECT_TO_SFLOAT(p); + FVECT_TO_SFLOAT(dir); /* Add the sample to the mesh */ s_id = smAdd_samp(smMesh,c,dir,p,INVALID); -#if 0 - { - int i; - FILE *fp; - if(s_id == 10000) - { - fp = fopen("test.xyz","w"); - for(i=0; i < s_id; i++) - if(!SM_DIR_ID(smMesh,i)) - fprintf(fp,"%f %f %f %d %d %d \n",SM_NTH_WV(smMesh,i)[0], - SM_NTH_WV(smMesh,i)[1],SM_NTH_WV(smMesh,i)[2], - SM_NTH_RGB(smMesh,i)[0],SM_NTH_RGB(smMesh,i)[1], - SM_NTH_RGB(smMesh,i)[2]); - fclose(fp); - } - } -#endif - return(s_id); + return((int)s_id); } -int +S_ID smAdd_base_vertex(sm,v) SM *sm; FVECT v; { - int id; + S_ID id; /* First add coordinate to the sample array */ id = sAdd_base_point(SM_SAMP(sm),v); @@ -2333,13 +2301,13 @@ SM *sm; int type; { int i,s_id,tri_id,nbr_id; - int p[SM_BASE_POINTS],ids[SM_BASE_TRIS]; - int v0_id,v1_id,v2_id; + S_ID p[SM_BASE_POINTS]; + int ids[SM_BASE_TRIS]; + S_ID v0_id,v1_id,v2_id; FVECT d,pt,cntr,v0,v1,v2; TRI *t; /* First insert the base vertices into the sample point array */ - for(i=0; i < SM_BASE_POINTS; i++) { VADD(cntr,icosa_verts[i],SM_VIEW_CENTER(sm)); @@ -2366,7 +2334,8 @@ smRebuild(sm,v) SM *sm; VIEW *v; { - int i,j,cnt; + S_ID s_id; + int j,cnt; FVECT p,ov,dir; double d; @@ -2386,35 +2355,35 @@ smRebuild(sm,v) /* Go through all samples and add in if in the new view frustum, and the dir is <= 30 degrees from new view */ - for(i=0; i < cnt; i++) + for(s_id=0; s_id < cnt; s_id++) { /* First check if sample visible(conservative approx: if one of tris attached to sample is in frustum) */ - if(!S_IS_FLAG(i)) + if(!S_IS_FLAG(s_id)) continue; /* Next test if direction > 30 degrees from current direction */ - if(SM_NTH_W_DIR(sm,i)!=-1) + if(SM_NTH_W_DIR(sm,s_id)!=-1) { - VSUB(p,SM_NTH_WV(sm,i),v->vp); - decodedir(dir,SM_NTH_W_DIR(sm,i)); + VSUB(p,SM_NTH_WV(sm,s_id),v->vp); + decodedir(dir,SM_NTH_W_DIR(sm,s_id)); d = DOT(dir,p); if (d*d < MAXDIFF2*DOT(p,p)) continue; - VCOPY(p,SM_NTH_WV(sm,i)); - smAdd_samp(sm,NULL,dir,p,i); + VCOPY(p,SM_NTH_WV(sm,s_id)); + smAdd_samp(sm,NULL,dir,p,s_id); } else { /* If the direction is > 45 degrees from current view direction: throw out */ - VSUB(dir,SM_NTH_WV(sm,i),ov); + VSUB(dir,SM_NTH_WV(sm,s_id),ov); if(DOT(dir,v->vdir) < MAXDIR) continue; - VADD(SM_NTH_WV(sm,i),dir,SM_VIEW_CENTER(sm)); - smAdd_samp(sm,NULL,dir,NULL,i); + VADD(SM_NTH_WV(sm,s_id),dir,SM_VIEW_CENTER(sm)); + smAdd_samp(sm,NULL,dir,NULL,s_id); } } @@ -2423,65 +2392,12 @@ smRebuild(sm,v) #endif } -int -intersect_tri_set(t_set,orig,dir,pt) - OBJECT *t_set; - FVECT orig,dir,pt; -{ - OBJECT *optr; - int i,t_id,id,base; - int pid0,pid1,pid2; - FVECT p0,p1,p2,p; - TRI *t; - double d,d1; - - optr = t_set; - for(i = QT_SET_CNT(t_set); i > 0; i--) - { - t_id = QT_SET_NEXT_ELEM(optr); - t = SM_NTH_TRI(smMesh,t_id); - if(!T_IS_VALID(t) || SM_IS_NTH_T_BASE(smMesh,t_id)|| - SM_IS_NTH_T_BG(smMesh,t_id)) - continue; - pid0 = T_NTH_V(t,0); - pid1 = T_NTH_V(t,1); - pid2 = T_NTH_V(t,2); - VCOPY(p0,SM_NTH_WV(smMesh,pid0)); - VCOPY(p1,SM_NTH_WV(smMesh,pid1)); - VCOPY(p2,SM_NTH_WV(smMesh,pid2)); - if(ray_intersect_tri(orig,dir,p0,p1,p2,p)) - { - d = DIST_SQ(p,p0); - d1 = DIST_SQ(p,p1); - if(d < d1) - { - d1 = DIST_SQ(p,p2); - id = (d1 < d)?pid2:pid0; - } - else - { - d = DIST_SQ(p,p2); - id = (d < d1)? pid2:pid1; - } - if(pt) - VCOPY(pt,p); -#ifdef TEST_DRIVER - Pick_tri = t_id; - Pick_samp = id; - VCOPY(Pick_point[0],p); -#endif - return(id); - } - } - return(-1); -} - /* OS is constrained to be <= QT_MAXCSET : if the set exceeds this, the results of check_set are conservative */ int compare_ids(id1,id2) -OBJECT *id1,*id2; +S_ID *id1,*id2; { int d; @@ -2495,168 +2411,7 @@ OBJECT *id1,*id2; return(0); } -ray_trace_check_set(qt,argptr,fptr) - QUADTREE qt; - RT_ARGS *argptr; - int *fptr; -{ - OBJECT tset[QT_MAXSET+1],*tptr; - double dt,t; - int found; - if(QT_IS_EMPTY(qt)) - return; - if(QT_LEAF_IS_FLAG(qt)) - { - QT_FLAG_SET_DONE(*fptr); -#if DEBUG - eputs("ray_trace_check_set():Already visited this node:aborting\n"); -#endif - return; - } - else - QT_LEAF_SET_FLAG(qt); - tptr = qtqueryset(qt); - if(QT_SET_CNT(tptr) > QT_MAXSET) - tptr = (OBJECT *)malloc((QT_SET_CNT(tptr)+1)*sizeof(OBJECT)); - else - tptr = tset; - if(!tptr) - goto memerr; - - qtgetset(tptr,qt); - /* Must sort */ - qsort((void *)(&(tptr[1])),tptr[0],sizeof(OBJECT),compare_ids); - /* Check triangles in set against those seen so far(os):only - check new triangles for intersection (t_set') - */ - check_set_large(tptr,argptr->os); - - if(!QT_SET_CNT(tptr)) - return; - found = intersect_tri_set(tptr,argptr->orig,argptr->dir,NULL); - if(tptr != tset) - free(tptr); - if(found != INVALID) - { - argptr->t_id = found; - QT_FLAG_SET_DONE(*fptr); - } - return; -memerr: - error(SYSTEM,"ray_trace_check_set():Unable to allocate memory"); -} - - -/* - * int - * smFindSamp(FVECT orig, FVECT dir) - * - * Find the closest sample to the given ray. Returns sample id, -1 on failure. - * "dir" is assumed to be normalized - */ - -int -smFindSamp(orig,dir) -FVECT orig,dir; -{ - FVECT b,p,o; - OBJECT *ts; - QUADTREE qt; - int s_id,test; - double d; - - /* r is the normalized vector from the view center to the current - * ray point ( starting with "orig"). Find the cell that r falls in, - * and test the ray against all triangles stored in the cell. If - * the test fails, trace the projection of the ray across to the - * next cell it intersects: iterate until either an intersection - * is found, or the projection ray is // to the direction. The sample - * corresponding to the triangle vertex closest to the intersection - * point is returned. - */ - - /* First test if "orig" coincides with the View_center or if "dir" is - parallel to r formed by projecting "orig" on the sphere. In - either case, do a single test against the cell containing the - intersection of "dir" and the sphere - */ - /* orig will be updated-so preserve original value */ - if(!smMesh) - return; - - if(EQUAL_VEC3(orig,SM_VIEW_CENTER(smMesh))) - { - qt = smPoint_locate_cell(smMesh,dir); - if(QT_IS_EMPTY(qt)) - goto Lerror; - ts = qtqueryset(qt); - s_id = intersect_tri_set(ts,orig,dir,p); - return(s_id); - } - d = point_on_sphere(b,orig,SM_VIEW_CENTER(smMesh)); - if(EQUAL_VEC3(b,dir)) - { - qt = smPoint_locate_cell(smMesh,dir); - if(QT_IS_EMPTY(qt)) - goto Lerror; - ts = qtqueryset(qt); - s_id = intersect_tri_set(ts,orig,dir,p); - return(s_id); - } - if(OPP_EQUAL_VEC3(b,dir)) - { - qt = smPoint_locate_cell(smMesh,orig); - if(QT_IS_EMPTY(qt)) - goto Lerror; - ts = qtqueryset(qt); - s_id = intersect_tri_set(ts,orig,dir,p); - if(s_id != INVALID) - { -#ifdef DEBUG - fprintf(stderr,"Front pick returning %d\n",s_id); -#endif - return(s_id); - } - qt = smPoint_locate_cell(smMesh,dir); - if(QT_IS_EMPTY(qt)) - goto Lerror; - ts = qtqueryset(qt); - s_id = intersect_tri_set(ts,orig,dir,p); -#ifdef DEBUG - fprintf(stderr,"Back pick returning %d\n",s_id); -#endif - return(s_id); - } - { - OBJECT t_set[QT_MAXCSET + 1]; - RT_ARGS rt; - FUNC func; - - /* Test each of the root triangles against point id */ - QT_CLEAR_SET(t_set); - VSUB(o,orig,SM_VIEW_CENTER(smMesh)); - ST_CLEAR_FLAGS(SM_LOCATOR(smMesh)); - rt.t_id = -1; - rt.os = t_set; - VCOPY(rt.orig,orig); - VCOPY(rt.dir,dir); - F_FUNC(func) = ray_trace_check_set; - F_ARGS(func) = (int *)(&rt); - stTrace_ray(SM_LOCATOR(smMesh),o,dir,func); - s_id = rt.t_id; - - } - return(s_id); - -Lerror: -#ifdef DEBUG - eputs("smFindSamp(): point not found"); -#endif - return(INVALID); - -} - null_func(argptr,root,qt,n) int *argptr; int root; @@ -2672,8 +2427,8 @@ mark_active_samples(argptr,root,qt,n) QUADTREE qt; int n; { - OBJECT *os; - register int i,s_id,t_id,tri_id; + S_ID *os,s_id; + register int i,t_id,tri_id; TRI *tri; if(QT_IS_EMPTY(qt) || QT_LEAF_IS_FLAG(qt))
