--- ray/src/hd/sm.c 1999/01/05 16:52:37 3.12 +++ ray/src/hd/sm.c 1999/06/10 15:22:21 3.15 @@ -11,21 +11,17 @@ static char SCCSid[] = "$SunId$ SGI"; #include "sm_flag.h" #include "sm_list.h" #include "sm_geom.h" -#include "sm_qtree.h" -#include "sm_stree.h" #include "sm.h" + SM *smMesh = NULL; double smDist_sum=0; -#define S_INC 1000 -int smNew_tri_cnt=0; -int smNew_tri_size=0; -T_DEPTH *smNew_tris= NULL; -#define SM_MIN_SAMP_DIFF 1e-3 /* min edge length in radians */ - -/* Each edge extends .5536 radians - 31.72 degrees */ +#ifdef DEBUG +int Tcnt=0,Wcnt=0; +#endif +/* Each edge extends .372 radians */ static FVECT icosa_verts[162] = {{-0.018096,0.495400,0.868477},{0.018614,-0.554780,0.831789}, {0.850436,0.011329,0.525956},{0.850116,0.048016,-0.524402}, @@ -132,15 +128,18 @@ static int icosa_tris[320][3] = {34,112,114},{112,33,113},{114,113,1},{112,113,114},{32,111,107},{111,33,112}, {107,112,34},{111,112,107},{9,109,116},{109,32,115},{116,115,36},{109,115,116}, {32,106,118},{106,8,117},{118,117,35},{106,117,118},{36,119,121},{119,35,120}, -{121,120,11},{119,120,121},{32,118,115},{118,35,119},{115,119,36},{118,119,115}, -{10,122,124},{122,37,123},{124,123,39},{122,123,124},{37,125,127},{125,11,126}, -{127,126,38},{125,126,127},{39,128,130},{128,38,129},{130,129,3},{128,129,130}, +{121,120,11},{119,120,121},{32,118,115},{118,35,119},{115,119,36}, +{118,119,115},{10,122,124},{122,37,123},{124,123,39},{122,123,124}, +{37,125,127},{125,11,126},{127,126,38},{125,126,127},{39,128,130}, +{128,38,129},{130,129,3},{128,129,130}, {37,127,123},{127,38,128},{123,128,39},{127,128,123},{11,125,132},{125,37,131}, -{132,131,41},{125,131,132},{37,122,134},{122,10,133},{134,133,40},{122,133,134}, -{41,135,137},{135,40,136},{137,136,5},{135,136,137},{37,134,131},{134,40,135}, +{132,131,41},{125,131,132},{37,122,134},{122,10,133},{134,133,40}, +{122,133,134},{41,135,137},{135,40,136},{137,136,5},{135,136,137}, +{37,134,131},{134,40,135}, {131,135,41},{134,135,131},{6,65,94},{65,18,138},{94,138,28},{65,138,94}, -{18,62,139},{62,2,49},{139,49,13},{62,49,139},{28,140,97},{140,13,46},{97,46,0}, -{140,46,97},{18,139,138},{139,13,140},{138,140,28},{139,140,138},{1,44,114}, +{18,62,139},{62,2,49},{139,49,13},{62,49,139},{28,140,97},{140,13,46}, +{97,46,0},{140,46,97},{18,139,138},{139,13,140},{138,140,28},{139,140,138}, +{1,44,114}, {44,14,141},{114,141,34},{44,141,114},{14,50,142},{50,2,68},{142,68,21}, {50,68,142},{34,143,108},{143,21,73},{108,73,8},{143,73,108},{14,142,141}, {142,21,143},{141,143,34},{142,143,141},{0,52,98},{52,16,144},{98,144,29}, @@ -156,7 +155,8 @@ static int icosa_tris[320][3] = {155,38,126},{120,126,11},{155,126,120},{20,154,153},{154,38,155},{153,155,35}, {154,155,153},{7,81,101},{81,23,156},{101,156,30},{81,156,101},{23,78,157}, {78,5,136},{157,136,40},{78,136,157},{30,158,104},{158,40,133},{104,133,10}, -{158,133,104},{23,157,156},{157,40,158},{156,158,30},{157,158,156},{11,132,121}, +{158,133,104},{23,157,156},{157,40,158},{156,158,30},{157,158,156},{ +11,132,121}, {132,41,159},{121,159,36},{132,159,121},{41,137,160},{137,5,84},{160,84,26}, {137,84,160},{36,161,116},{161,26,89},{116,89,9},{161,89,116},{41,160,159}, {160,26,161},{159,161,36},{160,161,159}}; @@ -196,15 +196,18 @@ static int icosa_nbrs[320][3] = {182,180,181},{187,308,190},{294,187,189},{293,309,187},{186,184,185}, {191,177,180},{185,191,182},{184,178,191},{190,188,189},{195,101,42}, {204,195,41},{206,102,195},{194,192,193},{199,204,38},{10,199,37},{9,205,199}, -{198,196,197},{203,105,206},{6,203,205},{5,106,203},{202,200,201},{207,193,196}, -{201,207,198},{200,194,207},{206,204,205},{211,138,0},{220,211,2},{222,136,211}, -{210,208,209},{215,220,8},{48,215,10},{50,221,215},{214,212,213},{219,130,222}, +{198,196,197},{203,105,206},{6,203,205},{5,106,203},{202,200,201}, +{207,193,196},{201,207,198},{200,194,207},{206,204,205},{211,138,0}, +{220,211,2}, {222,136,211},{210,208,209},{215,220,8},{48,215,10},{50,221,215}, +{214,212,213},{219,130,222}, {56,219,221},{58,128,219},{218,216,217},{223,209,212},{217,223,214}, {216,210,223},{222,220,221},{227,106,16},{236,227,18},{238,104,227}, -{226,224,225},{231,236,24},{64,231,26},{66,237,231},{230,228,229},{235,98,238}, +{226,224,225},{231,236,24},{64,231,26},{66,237,231},{230,228,229}, +{235,98,238}, {72,235,237},{74,96,235},{234,232,233},{239,225,228},{233,239,230}, {232,226,239},{238,236,237},{243,133,90},{252,243,89},{254,134,243}, -{242,240,241},{247,252,86},{26,247,85},{25,253,247},{246,244,245},{251,137,254}, +{242,240,241},{247,252,86},{26,247,85},{25,253,247},{246,244,245}, +{251,137,254}, {22,251,253},{21,138,251},{250,248,249},{255,241,244},{249,255,246}, {248,242,255},{254,252,253},{259,122,160},{268,259,162},{270,120,259}, {258,256,257},{263,268,168},{32,263,170},{34,269,263},{262,260,261}, @@ -234,21 +237,48 @@ FVECT FrustumNear[4],FrustumFar[4]; double dev_zmin=.01,dev_zmax=1000; #endif -smDir(sm,ps,id) - SM *sm; - FVECT ps; - int id; + +char * +tempbuf(len,resize) /* get a temporary buffer */ +unsigned len; +int resize; { - VSUB(ps,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm)); - normalize(ps); + extern char *malloc(), *realloc(); + static char *tempbuf = NULL; + static unsigned tempbuflen = 0; + +#ifdef DEBUG + static int in_use=FALSE; + + if(len == -1) + { + in_use = FALSE; + return(NULL); + } + if(!resize && in_use) + { + eputs("Buffer in use:cannot allocate:tempbuf()\n"); + return(NULL); + } +#endif + if (len > tempbuflen) { + if (tempbuflen > 0) + tempbuf = realloc(tempbuf, len); + else + tempbuf = malloc(len); + tempbuflen = tempbuf==NULL ? 0 : len; + } +#ifdef DEBUG + in_use = TRUE; +#endif + return(tempbuf); } -smDir_in_cone(sm,ps,id) +smDir(sm,ps,id) SM *sm; FVECT ps; int id; { - VSUB(ps,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm)); normalize(ps); } @@ -272,9 +302,7 @@ smInit_mesh(sm) { /* Reset the triangle counters */ SM_NUM_TRI(sm) = 0; - SM_SAMPLE_TRIS(sm) = 0; SM_FREE_TRIS(sm) = -1; - SM_AVAILABLE_TRIS(sm) = -1; smClear_flags(sm,-1); } @@ -285,39 +313,12 @@ smInit_mesh(sm) smClear(sm) SM *sm; { - smClear_samples(sm); - smClear_locator(sm); + smDist_sum = 0; + smInit_samples(sm); + smInit_locator(sm); smInit_mesh(sm); } -static int realloc_cnt=0; - -int -smRealloc_mesh(sm) -SM *sm; -{ - int fbytes,i,max_tris,max_verts; - - if(realloc_cnt <=0) - realloc_cnt = SM_MAX_TRIS(sm); - - max_tris = SM_MAX_TRIS(sm) + realloc_cnt; - fbytes = FLAG_BYTES(max_tris); - - if(!(SM_TRIS(sm) = (TRI *)realloc(SM_TRIS(sm),max_tris*sizeof(TRI)))) - goto memerr; - - for(i=0; i< T_FLAGS; i++) - if(!(SM_NTH_FLAGS(sm,i)=(int4 *)realloc((char *)SM_NTH_FLAGS(sm,i),fbytes))) - goto memerr; - - SM_MAX_TRIS(sm) = max_tris; - return(max_tris); - -memerr: - error(SYSTEM, "out of memory in smRealloc_mesh()"); -} - /* Allocate and initialize a new mesh with max_verts and max_tris */ int smAlloc_mesh(sm,max_verts,max_tris) @@ -328,21 +329,16 @@ int max_verts,max_tris; fbytes = FLAG_BYTES(max_tris); - if(!(SM_TRIS(sm) = (TRI *)realloc(NULL,max_tris*sizeof(TRI)))) + if(!(SM_TRIS(sm) = (TRI *)malloc(max_tris*sizeof(TRI)))) goto memerr; - if(!(SM_VERTS(sm) = (VERT *)realloc(NULL,max_verts*sizeof(VERT)))) - goto memerr; - for(i=0; i< T_FLAGS; i++) - if(!(SM_NTH_FLAGS(sm,i)=(int4 *)realloc(NULL,fbytes))) + if(!(SM_NTH_FLAGS(sm,i)=(int4 *)malloc(fbytes))) goto memerr; SM_MAX_VERTS(sm) = max_verts; SM_MAX_TRIS(sm) = max_tris; - realloc_cnt = max_verts >> 1; - smInit_mesh(sm); return(max_tris); @@ -351,31 +347,6 @@ memerr: } -int -compress_set(os) -OBJECT *os; -{ - int i,j; - - for (i = 1, j = os[0]; i <= j; i++) - { - if(SM_T_ID_VALID(smMesh,os[i])) - continue; - if(i==j) - break; - while(!SM_T_ID_VALID(smMesh,os[j]) && (i < j)) - j--; - if(i==j) - break; - os[i] = os[j--]; - } - i--; - - os[0] = i; - return(i); - -} - int smAlloc_tri(sm) SM *sm; @@ -386,21 +357,14 @@ SM *sm; /* Otherwise, have we reached the end of the list yet?*/ if(SM_NUM_TRI(sm) < SM_MAX_TRIS(sm)) return(SM_NUM_TRI(sm)++); - if((id = SM_AVAILABLE_TRIS(sm)) != -1) - { - SM_AVAILABLE_TRIS(sm) = T_NEXT_AVAILABLE(SM_NTH_TRI(sm,id)); - return(id); - } if((id = SM_FREE_TRIS(sm)) != -1) { - dosets(compress_set); - SM_AVAILABLE_TRIS(sm) = T_NEXT_FREE(SM_NTH_TRI(sm,id)); - SM_FREE_TRIS(sm) = -1; + SM_FREE_TRIS(sm) = T_NEXT_FREE(SM_NTH_TRI(sm,id)); return(id); } - /*Else: realloc */ - smRealloc_mesh(sm); - return(SM_NUM_TRI(sm)++); + + error(CONSISTENCY,"smAlloc_tri: no more available triangles\n"); + return(INVALID); } smFree_mesh(sm) @@ -410,8 +374,6 @@ SM *sm; if(SM_TRIS(sm)) free(SM_TRIS(sm)); - if(SM_VERTS(sm)) - free(SM_VERTS(sm)); for(i=0; i< T_FLAGS; i++) if(SM_NTH_FLAGS(sm,i)) free(SM_NTH_FLAGS(sm,i)); @@ -445,11 +407,14 @@ smAlloc(max_samples) /* First allocate at least n samples + extra points:at least enough necessary to form the BASE MESH- Default = 4; */ - SM_SAMP(smMesh) = sAlloc(&n,SM_EXTRA_POINTS); + SM_SAMP(smMesh) = sAlloc(&n,SM_BASE_POINTS); - total_points = n + SM_EXTRA_POINTS; + total_points = n + SM_BASE_POINTS; - max_tris = total_points*4; + /* Need enough tris for base mesh, + 2 for each sample, plus extra + since triangles are not deleted until added and edge flips (max 4) + */ + max_tris = n*2 + SM_BASE_TRIS + 10; /* Now allocate space for mesh vertices and triangles */ max_tris = smAlloc_mesh(smMesh, total_points, max_tris); @@ -465,13 +430,8 @@ SM *sm; FVECT vp; { - smDist_sum = 0; - smNew_tri_cnt = 0; - VCOPY(SM_VIEW_CENTER(sm),vp); - smInit_locator(sm,vp); - smInit_samples(sm); - smInit_mesh(sm); + smClear(sm); smCreate_base_mesh(sm,SM_DEFAULT); } @@ -492,10 +452,12 @@ smInit(n) { int max_vertices; - /* If n <=0, Just clear the existing structures */ if(n <= 0) { +#ifdef DEBUG + fprintf(stderr,"Tcnt=%d Wcnt = %d, avg = %f\n",Tcnt,Wcnt,(float)Wcnt/Tcnt); +#endif smClear(smMesh); return(0); } @@ -503,7 +465,7 @@ smInit(n) /* Total mesh vertices includes the sample points and the extra vertices to form the base mesh */ - max_vertices = n + SM_EXTRA_POINTS; + max_vertices = n + SM_BASE_POINTS; /* If the current mesh contains enough room, clear and return */ if(smMesh && (max_vertices <= SM_MAX_VERTS(smMesh)) && SM_MAX_SAMP(smMesh) <= @@ -517,14 +479,19 @@ smInit(n) */ smAlloc(n); +#ifdef DEBUG + fprintf(stderr,"smInit: allocating room for %d samples\n", + SM_MAX_SAMP(smMesh)); +#endif return(SM_MAX_SAMP(smMesh)); } -smLocator_apply(sm,v0,v1,v2,func) +smLocator_apply(sm,v0,v1,v2,func,n) SM *sm; FVECT v0,v1,v2; FUNC func; + int n; { STREE *st; FVECT tri[3]; @@ -534,106 +501,102 @@ smLocator_apply(sm,v0,v1,v2,func) VSUB(tri[0],v0,SM_VIEW_CENTER(sm)); VSUB(tri[1],v1,SM_VIEW_CENTER(sm)); VSUB(tri[2],v2,SM_VIEW_CENTER(sm)); - stVisit(st,tri,func); + stVisit(st,tri,func,n); } - -/* NEW INSERTION!!! ******************************************************/ QUADTREE -insert_tri(argptr,root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, - s0,s1,s2,sq0,sq1,sq2,rev,f,n) +insert_samp(argptr,root,qt,parent,q0,q1,q2,bc,scale,rev,f,n,doneptr) int *argptr; int root; - QUADTREE qt; - BCOORD q0[3],q1[3],q2[3]; - BCOORD t0[3],t1[3],t2[3]; - BCOORD dt10[3],dt21[3],dt02[3]; - unsigned int scale,s0,s1,s2,sq0,sq1,sq2,rev; + QUADTREE qt,parent; + BCOORD q0[3],q1[3],q2[3],bc[3]; + unsigned int scale,rev; FUNC f; - int n; + int n,*doneptr; { - OBJECT *optr,*tptr,t_set[QT_MAXSET+1]; - int i,t_id; - TRI *t; - FVECT tri[3]; - BCOORD b0[3],b1[3],b2[3]; - BCOORD tb0[3],tb1[3],tb2[3]; - BCOORD db10[3],db21[3],db02[3]; - BCOORD a,b,c,qa,qb,qc; - FUNC tfunc; + OBJECT *optr,*sptr,s_set[QT_MAXSET+1]; + int i,s_id; + FVECT p; + BCOORD bp[3]; + FUNC sfunc; + S_ARGS args; - t_id = *argptr; - + s_id = ((S_ARGS *)argptr)->s_id; /* If the set is empty - just add */ if(QT_IS_EMPTY(qt)) - return(qtadduelem(qt,t_id)); - + { + qt = qtadduelem(qt,s_id); + SM_S_NTH_QT(smMesh,s_id) = qt; + if(((S_ARGS *)argptr)->n_id) + *doneptr = FALSE; + else + *doneptr = TRUE; + return(qt); + } /* If the set size is below expansion threshold,or at maximum number of quadtree levels : just add */ optr = qtqueryset(qt); if(QT_SET_CNT(optr) < QT_SET_THRESHOLD || (n > (QT_MAX_LEVELS-2))) - return(qtadduelem(qt,t_id)); - /* otherwise: expand node- and insert tri, and reinsert existing tris + { + qt = qtadduelem(qt,s_id); + + SM_S_NTH_QT(smMesh,s_id) = qt; + if(((S_ARGS *)argptr)->n_id) + if(QT_SET_CNT(qtqueryset(qt)) > 1) + { + ((S_ARGS *)argptr)->n_id = qtqueryset(qt)[1]; + *doneptr = TRUE; + } + else + *doneptr = FALSE; + else + *doneptr = TRUE; + return(qt); + } + /* otherwise: expand node- and insert sample, and reinsert existing samples in set to children of new node */ - /* First tri compressing set */ -#ifdef NEWSETS0 - if(qtcompressuelem(qt,compress_set) < QT_SET_THRESHOLD) - /* Get set: If greater than standard size: allocate memory to hold */ - return(qtadduelem(qt,t_id)); -#endif - if(QT_SET_CNT(optr) > QT_MAXSET) - { - if(!(tptr = (OBJECT *)malloc((QT_SET_CNT(optr)+1)*sizeof(OBJECT)))) - goto memerr; - } - else - tptr = t_set; - qtgetset(tptr,qt); + if(QT_SET_CNT(optr) > QT_MAXSET) + { + if(!(sptr = (OBJECT *)malloc((QT_SET_CNT(optr)+1)*sizeof(OBJECT)))) + goto memerr; + } + else + sptr = s_set; + qtgetset(sptr,qt); /* subdivide node */ qtfreeleaf(qt); qtSubdivide(qt); - a = q1[0]; b = q0[1]; c = q0[2]; - qa = q0[0]; qb = q1[1]; qc = q2[2]; - /* First add current tri: have all of the information */ - if(rev) - qt = qtInsert_tri_rev(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, - s0,s1,s2,sq0,sq1,sq2,f,n); - else - qt = qtInsert_tri(root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, - s0,s1,s2,sq0,sq1,sq2,f,n); - /* Now add in all of the rest; */ - F_FUNC(tfunc) = F_FUNC(f); - for(optr = QT_SET_PTR(tptr),i=QT_SET_CNT(tptr); i > 0; i--) + F_FUNC(sfunc) = F_FUNC(f); + F_ARGS(sfunc) = (int *) (&args); + args.n_id = 0; + for(optr = sptr,i=QT_SET_CNT(sptr); i > 0; i--) { - t_id = QT_SET_NEXT_ELEM(optr); - t = SM_NTH_TRI(smMesh,t_id); - if(!T_IS_VALID(t)) - continue; - F_ARGS(tfunc) = &t_id; - VSUB(tri[0],SM_T_NTH_WV(smMesh,t,0),SM_VIEW_CENTER(smMesh)); - VSUB(tri[1],SM_T_NTH_WV(smMesh,t,1),SM_VIEW_CENTER(smMesh)); - VSUB(tri[2],SM_T_NTH_WV(smMesh,t,2),SM_VIEW_CENTER(smMesh)); - convert_tri_to_frame(root,tri,b0,b1,b2,db10,db21,db02); - - /* Calculate appropriate sidedness values */ - SIDES_GTR(b0,b1,b2,s0,s1,s2,a,b,c); - SIDES_GTR(b0,b1,b2,sq0,sq1,sq2,qa,qb,qc); + s_id = QT_SET_NEXT_ELEM(optr); + args.s_id = s_id; + VSUB(p,SM_NTH_WV(smMesh,s_id),SM_VIEW_CENTER(smMesh)); + normalize(p); + vert_to_qt_frame(i,p,bp); if(rev) - qt = qtInsert_tri_rev(root,qt,q0,q1,q2,b0,b1,b2,db10,db21,db02,scale, - s0,s1,s2,sq0,sq1,sq2,tfunc,n); + qt= qtInsert_point_rev(root,qt,parent,q0,q1,q2,bp,scale,sfunc,n,doneptr); else - qt = qtInsert_tri(root,qt,q0,q1,q2,b0,b1,b2,db10,db21,db02,scale, - s0,s1,s2,sq0,sq1,sq2,tfunc,n); + qt= qtInsert_point(root,qt,parent,q0,q1,q2,bp,scale,sfunc,n,doneptr); } + /* Add current sample: have all of the information */ + if(rev) + qt =qtInsert_point_rev(root,qt,parent,q0,q1,q2,bc,scale,f,n,doneptr); + else + qt = qtInsert_point(root,qt,parent,q0,q1,q2,bc,scale,f,n,doneptr); + /* If we allocated memory: free it */ - if( tptr != t_set) - free(tptr); + if( sptr != s_set) + free(sptr); + return(qt); memerr: error(SYSTEM,"expand_node():Unable to allocate memory"); @@ -641,53 +604,60 @@ memerr: } - -smLocator_add_tri(sm,t_id,v0_id,v1_id,v2_id) -SM *sm; -int t_id; -int v0_id,v1_id,v2_id; +double +triangle_normal(n,a,b,c) +double n[3]; +double a[3],b[3],c[3]; { - FVECT tri[3]; - FUNC f; + double ab[3],ac[3]; -#ifdef DEBUG -if(T_NTH_NBR(SM_NTH_TRI(sm,t_id),0)== -1 || - T_NTH_NBR(SM_NTH_TRI(sm,t_id),1)== -1 || - T_NTH_NBR(SM_NTH_TRI(sm,t_id),2)== -1) - error("Invalid tri: smLocator_add_tri()\n"); - -if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,t_id),0))) || - !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,t_id),1))) || - !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,t_id),2)))) - error("Invalid tri: smLocator_add_tri()\n"); -#endif - - VSUB(tri[0],SM_NTH_WV(sm,v0_id),SM_VIEW_CENTER(sm)); - VSUB(tri[1],SM_NTH_WV(sm,v1_id),SM_VIEW_CENTER(sm)); - VSUB(tri[2],SM_NTH_WV(sm,v2_id),SM_VIEW_CENTER(sm)); - - F_FUNC(f) = insert_tri; - F_ARGS(f) = &t_id; - stInsert_tri(SM_LOCATOR(sm),tri,f); + VSUB(ab,b,a); + normalize(ab); + VSUB(ac,c,a); + normalize(ac); + VCROSS(n,ab,ac); + return(normalize(n)); } - +double on0,on1,on2; /* Add a triangle to the base array with vertices v1-v2-v3 */ int -smAdd_tri(sm, v0_id,v1_id,v2_id) +smAdd_tri(sm, v0_id,v1_id,v2_id,tptr) SM *sm; int v0_id,v1_id,v2_id; +TRI **tptr; { int t_id; TRI *t; #ifdef DEBUG if(v0_id==v1_id || v0_id==v2_id || v1_id==v2_id) error(CONSISTENCY,"smAdd_tri: invalid vertex ids\n"); -#endif - t_id = smAlloc_tri(sm); - if(t_id == -1) - return(t_id); +#endif + t_id = smAlloc_tri(sm); +#ifdef DEBUG +#if DEBUG > 1 + { + double v0[3],v1[3],v2[3],n[3]; + double area,dp; + VSUB(v0,SM_NTH_WV(sm,v0_id),SM_VIEW_CENTER(sm)); + VSUB(v1,SM_NTH_WV(sm,v1_id),SM_VIEW_CENTER(sm)); + VSUB(v2,SM_NTH_WV(sm,v2_id),SM_VIEW_CENTER(sm)); + normalize(v0); + normalize(v1); + normalize(v2); + area = triangle_normal(n,v2,v1,v0); + if((dp=DOT(v0,n)) < 0.0) + { + fprintf(stderr,"dp = %.10f on0=%.10f on1=%.10f on2=%.10f\n", dp, + on0,on1,on2); + eputs("backwards tri\n"); + } + } +#endif +#endif + + t = SM_NTH_TRI(sm,t_id); T_CLEAR_NBRS(t); @@ -700,241 +670,212 @@ int v0_id,v1_id,v2_id; SM_NTH_VERT(sm,v1_id) = t_id; SM_NTH_VERT(sm,v2_id) = t_id; - smClear_tri_flags(sm,t_id); if(SM_BASE_ID(sm,v0_id) || SM_BASE_ID(sm,v1_id) || SM_BASE_ID(sm,v2_id)) - { SM_SET_NTH_T_BASE(sm,t_id); - } else - { - S_SET_FLAG(T_NTH_V(t,0)); - S_SET_FLAG(T_NTH_V(t,1)); - S_SET_FLAG(T_NTH_V(t,2)); - } + SM_CLR_NTH_T_BASE(sm,t_id); + if(SM_DIR_ID(sm,v0_id) || SM_DIR_ID(sm,v1_id) || SM_DIR_ID(sm,v2_id)) + SM_SET_NTH_T_BG(sm,t_id); + else + SM_CLR_NTH_T_BG(sm,t_id); + S_SET_FLAG(T_NTH_V(t,0)); + S_SET_FLAG(T_NTH_V(t,1)); + S_SET_FLAG(T_NTH_V(t,2)); + SM_SET_NTH_T_ACTIVE(sm,t_id); + SM_SET_NTH_T_NEW(sm,t_id); - SM_SAMPLE_TRIS(sm)++; + *tptr = t; /* return initialized triangle */ return(t_id); } -void -smTris_swap_edge(sm,t_id,t1_id,e,e1,tn_id,tn1_id,add_ptr) - SM *sm; - int t_id,t1_id; - int e,e1; - int *tn_id,*tn1_id; - LIST **add_ptr; +/* pt_in_cone: assumed apex at origin, a,b,c are unit vectors defining the + triangle which the cone circumscribes. Assumed p is not normalized + */ +int +pt_in_cone(p,a,b,c) +double p[3],a[3],b[3],c[3]; { - int verts[3],enext,eprev,e1next,e1prev; - TRI *n,*ta,*tb,*t,*t1; - FVECT p1,p2,p3; - int ta_id,tb_id; - /* form new diagonal (e relative to t, and e1 relative to t1) - defined by quadrilateral formed by t,t1- swap for the opposite diagonal - */ - enext = (e+1)%3; - eprev = (e+2)%3; - e1next = (e1+1)%3; - e1prev = (e1+2)%3; - verts[e] = T_NTH_V(SM_NTH_TRI(sm,t_id),e); - verts[enext] = T_NTH_V(SM_NTH_TRI(sm,t_id),enext); - verts[eprev] = T_NTH_V(SM_NTH_TRI(sm,t1_id),e1); - ta_id = smAdd_tri(sm,verts[0],verts[1],verts[2]); - *add_ptr = push_data(*add_ptr,ta_id); - verts[e1] = T_NTH_V(SM_NTH_TRI(sm,t1_id),e1); - verts[e1next] = T_NTH_V(SM_NTH_TRI(sm,t1_id),e1next); - verts[e1prev] = T_NTH_V(SM_NTH_TRI(sm,t_id),e); - tb_id = smAdd_tri(sm,verts[0],verts[1],verts[2]); + double r[3]; + double pr,ar; + double ab[3],ac[3]; + /* r = (B-A)X(C-A) */ + /* in = (p.r) > (a.r) */ - *add_ptr = push_data(*add_ptr,tb_id); - ta = SM_NTH_TRI(sm,ta_id); - tb = SM_NTH_TRI(sm,tb_id); - t = SM_NTH_TRI(sm,t_id); - t1 = SM_NTH_TRI(sm,t1_id); - /* set the neighbors */ - T_NTH_NBR(ta,e) = T_NTH_NBR(t1,e1next); - T_NTH_NBR(tb,e1) = T_NTH_NBR(t,enext); - T_NTH_NBR(ta,enext)= tb_id; - T_NTH_NBR(tb,e1next)= ta_id; - T_NTH_NBR(ta,eprev)=T_NTH_NBR(t,eprev); - T_NTH_NBR(tb,e1prev)=T_NTH_NBR(t1,e1prev); - - #ifdef DEBUG - if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,0))) || - !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,1))) || - !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,2))) || - !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,0))) || - !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,1))) || - !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,2)))) - goto Ltri_error; - /* - if(SM_NTH_TRI(sm,T_NTH_NBR(ta,0))==SM_NTH_TRI(sm,T_NTH_NBR(ta,1)) || - SM_NTH_TRI(sm,T_NTH_NBR(ta,0))==SM_NTH_TRI(sm,T_NTH_NBR(ta,2)) || - SM_NTH_TRI(sm,T_NTH_NBR(ta,1))==SM_NTH_TRI(sm,T_NTH_NBR(ta,2)) || - SM_NTH_TRI(sm,T_NTH_NBR(tb,0))==SM_NTH_TRI(sm,T_NTH_NBR(tb,1)) || - SM_NTH_TRI(sm,T_NTH_NBR(tb,0))==SM_NTH_TRI(sm,T_NTH_NBR(tb,2)) || - SM_NTH_TRI(sm,T_NTH_NBR(tb,1))==SM_NTH_TRI(sm,T_NTH_NBR(tb,2)) ) - goto Ltri_error; - */ +#if DEBUG > 1 +{ + double l; + l = triangle_normal(r,a,b,c); + /* l = sin@ between ab,ac - if 0 vectors are colinear */ + if( l <= COLINEAR_EPS) + { + eputs("pt in cone: null triangle:returning FALSE\n"); + return(FALSE); + } +} #endif - /* Reset neighbor pointers of original neighbors */ - n = SM_NTH_TRI(sm,T_NTH_NBR(t,enext)); -#ifdef DEBUG - if(!T_IS_VALID(n)) - goto Ltri_error; #endif - T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = tb_id; - n = SM_NTH_TRI(sm,T_NTH_NBR(t,eprev)); -#ifdef DEBUG - if(!T_IS_VALID(n)) - goto Ltri_error; -#endif - T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = ta_id; - n = SM_NTH_TRI(sm,T_NTH_NBR(t1,e1next)); -#ifdef DEBUG - if(!T_IS_VALID(n)) - goto Ltri_error; -#endif - T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = ta_id; - n = SM_NTH_TRI(sm,T_NTH_NBR(t1,e1prev)); -#ifdef DEBUG - if(!T_IS_VALID(n)) - goto Ltri_error; -#endif - T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = tb_id; + VSUB(ab,b,a); + VSUB(ac,c,a); + VCROSS(r,ab,ac); -#ifdef DEBUG - T_VALID_FLAG(SM_NTH_TRI(sm,t_id))=-1; - T_VALID_FLAG(SM_NTH_TRI(sm,t1_id))=-1; -#endif - - remove_from_list(t_id,add_ptr); - remove_from_list(t1_id,add_ptr); - - smDelete_tri(sm,t_id); - smDelete_tri(sm,t1_id); - - *tn_id = ta_id; - *tn1_id = tb_id; - -#ifdef DEBUG - if(T_NTH_NBR(SM_NTH_TRI(sm,ta_id),0)== -1 || - T_NTH_NBR(SM_NTH_TRI(sm,ta_id),1)== -1 || - T_NTH_NBR(SM_NTH_TRI(sm,ta_id),2)== -1 || - T_NTH_NBR(SM_NTH_TRI(sm,tb_id),0)== -1 || - T_NTH_NBR(SM_NTH_TRI(sm,tb_id),1)== -1 || - T_NTH_NBR(SM_NTH_TRI(sm,tb_id),2)== -1) - goto Ltri_error; - if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,ta_id),0))) || - !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,ta_id),1))) || - !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,ta_id),2)))) - goto Ltri_error; - if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,tb_id),0))) || - !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,tb_id),1))) || - !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,tb_id),2)))) - goto Ltri_error; -#endif - return; -Ltri_error: - error(CONSISTENCY,"Invalid tri: smTris_swap_edge()\n"); + pr = DOT(p,r); + ar = DOT(a,r); + /* Need to check for equality for degeneracy of 4 points on circle */ + if( pr > ar *( 1.0 + EQUALITY_EPS)) + return(TRUE); + else + return(FALSE); } -add_new_tri(id) -int id; -{ - if(smNew_tri_cnt == smNew_tri_size) - { - smNew_tri_size += S_INC; - smNew_tris=(T_DEPTH *)realloc(smNew_tris,sizeof(T_DEPTH)*smNew_tri_size); - if(!smNew_tris) - error(SYSTEM,"Out of memory in add_new_tris()\n"); - } - smNew_tris[smNew_tri_cnt++].tri = id; -} - -smUpdate_locator(sm,add_list) +smRestore_Delaunay(sm,a,b,c,t,t_id,a_id,b_id,c_id) SM *sm; -LIST *add_list; +FVECT a,b,c; +TRI *t; +int t_id,a_id,b_id,c_id; { - int t_id,i; - TRI *t; - OBJECT *optr; - LIST *list; + int e1,topp_id,p_id; + TRI *topp; + FVECT p; - list = add_list; - while(list) + topp_id = T_NTH_NBR(t,0); +#ifdef DEBUG + if(topp_id==INVALID) { - t_id = LIST_DATA(list); - add_new_tri(t_id); - list = LIST_NEXT(list); + eputs("Invalid tri id smRestore_delaunay()\n"); + return; } - - while(add_list) +#endif + topp = SM_NTH_TRI(sm,topp_id); +#ifdef DEBUG + if(!T_IS_VALID(topp)) { - t_id = pop_list(&add_list); - t = SM_NTH_TRI(sm,t_id); - smLocator_add_tri(sm,t_id,T_NTH_V(t,0),T_NTH_V(t,1),T_NTH_V(t,2)); + eputs("Invalid tri smRestore_delaunay()\n"); + return; } -} +#endif + e1 = T_NTH_NBR_PTR(t_id,topp); + p_id = T_NTH_V(topp,e1); -int -smFix_tris(sm,id,tlist,add_list) -SM *sm; -int id; -LIST *tlist,*add_list; -{ - TRI *t,*t_opp; - FVECT p,p0,p1,p2; - int e,e1,swapped = 0; - int t_id,t_opp_id; - LIST *del_list=NULL,*lptr; + VSUB(p,SM_NTH_WV(sm,p_id),SM_VIEW_CENTER(sm)); + normalize(p); + if(pt_in_cone(p,c,b,a)) + { + int e1next,e1prev; + int ta_id,tb_id; + TRI *ta,*tb,*n; + e1next = (e1 + 1)%3; + e1prev = (e1 + 2)%3; + ta_id = smAdd_tri(sm,a_id,b_id,p_id,&ta); + tb_id = smAdd_tri(sm,a_id,p_id,c_id,&tb); - VSUB(p,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm)); - while(tlist) - { - t_id = pop_list(&tlist); + T_NTH_NBR(ta,0) = T_NTH_NBR(topp,e1next); + T_NTH_NBR(ta,1) = tb_id; + T_NTH_NBR(ta,2) = T_NTH_NBR(t,2); + + T_NTH_NBR(tb,0) = T_NTH_NBR(topp,e1prev); + T_NTH_NBR(tb,1) = T_NTH_NBR(t,1); + T_NTH_NBR(tb,2) = ta_id; + + n = SM_NTH_TRI(sm,T_NTH_NBR(t,1)); + T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = tb_id; + n = SM_NTH_TRI(sm,T_NTH_NBR(t,2)); + T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = ta_id; + n = SM_NTH_TRI(sm,T_NTH_NBR(topp,e1next)); + T_NTH_NBR(n,T_NTH_NBR_PTR(topp_id,n)) = ta_id; + n = SM_NTH_TRI(sm,T_NTH_NBR(topp,e1prev)); + T_NTH_NBR(n,T_NTH_NBR_PTR(topp_id,n)) = tb_id; + + smDelete_tri(sm,t_id,t); + smDelete_tri(sm,topp_id,topp); + #ifdef DEBUG - if(t_id==INVALID || t_id > smMesh->num_tri) - error(CONSISTENCY,"Invalid tri id smFix_tris()\n"); -#endif - t = SM_NTH_TRI(sm,t_id); - e = T_WHICH_V(t,id); - t_opp_id = T_NTH_NBR(t,e); -#ifdef DEBUG - if(t_opp_id==INVALID || t_opp_id > smMesh->num_tri) - error(CONSISTENCY,"Invalid tri id smFix_tris()\n"); -#endif - t_opp = SM_NTH_TRI(sm,t_opp_id); -#ifdef DEBUG - if(!T_IS_VALID(t_opp)) - error(CONSISTENCY,"Invalid trismFix_tris()\n"); -#endif - smDir_in_cone(sm,p0,T_NTH_V(t_opp,0)); - smDir_in_cone(sm,p1,T_NTH_V(t_opp,1)); - smDir_in_cone(sm,p2,T_NTH_V(t_opp,2)); - if(point_in_cone(p,p0,p1,p2)) - { - swapped = 1; - e1 = T_NTH_NBR_PTR(t_id,t_opp); - /* check list for t_opp and Remove if there */ - remove_from_list(t_opp_id,&tlist); - smTris_swap_edge(sm,t_id,t_opp_id,e,e1,&t_id,&t_opp_id, - &add_list); - tlist = push_data(tlist,t_id); - tlist = push_data(tlist,t_opp_id); - } - } +#if DEBUG > 1 + if(T_NTH_NBR(ta,0) == T_NTH_NBR(ta,1) || + T_NTH_NBR(ta,1) == T_NTH_NBR(ta,2) || + T_NTH_NBR(ta,0) == T_NTH_NBR(ta,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(ta,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(ta,0)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(ta,1)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(ta,2)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(tb,0)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(tb,1)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(tb,2)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); - smUpdate_locator(sm,add_list); + if(T_NTH_NBR(tb,0) == T_NTH_NBR(tb,1) || + T_NTH_NBR(tb,1) == T_NTH_NBR(tb,2) || + T_NTH_NBR(tb,0) == T_NTH_NBR(tb,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(tb,2)))) + error(CONSISTENCY,"Invalid topology\n"); - return(swapped); +#endif +#endif + smRestore_Delaunay(sm,a,b,p,ta,ta_id,a_id,b_id,p_id); + smRestore_Delaunay(sm,a,p,c,tb,tb_id,a_id,p_id,c_id); + } } + /* Give the vertex "id" and a triangle "t" that it belongs to- return the next nbr in a counter clockwise order about vertex "id" */ @@ -969,29 +910,27 @@ int id; /* Locate the point-id in the point location structure: */ int -smInsert_samp(sm,s_id,tri_id,on,which) +smInsert_samp_mesh(sm,s_id,tri_id,a,b,c,d,on,which) SM *sm; int s_id,tri_id; + FVECT a,b,c,d; int on,which; { int v_id[3],topp_id,i; - int t0_id,t1_id,t2_id,t3_id,replaced; - int e0,e1,e2,opp0,opp1,opp2,opp_id; - LIST *tlist,*add_list; - FVECT npt; - TRI *tri,*nbr,*topp; + int t0_id,t1_id,t2_id,t3_id; + int e0,e1,e2,opp_id,opp0,opp1,opp2; + TRI *tri,*nbr,*topp,*t0,*t1,*t2,*t3; + FVECT e; - if(tri_id==18611 && s_id == 2243) - sleep(1); - if(s_id == 2649 && tri_id == 13302) - sleep(1); - add_list = NULL; for(i=0; i<3;i++) v_id[i] = T_NTH_V(SM_NTH_TRI(sm,tri_id),i); /* If falls on existing edge */ if(on == ON_E) { + FVECT n,vopp; + double dp; + tri = SM_NTH_TRI(sm,tri_id); topp_id = T_NTH_NBR(tri,which); e0 = which; @@ -999,9 +938,10 @@ smInsert_samp(sm,s_id,tri_id,on,which) e2 = (which+2)%3; topp = SM_NTH_TRI(sm,topp_id); opp0 = T_NTH_NBR_PTR(tri_id,topp); - opp_id = T_NTH_V(topp,opp0); opp1 = (opp0+1)%3; opp2 = (opp0+2)%3; + + opp_id = T_NTH_V(topp,opp0); /* Create 4 triangles */ /* /|\ /|\ @@ -1011,31 +951,24 @@ smInsert_samp(sm,s_id,tri_id,on,which) \ | / \ | / \|/ \|/ */ - t0_id = smAdd_tri(sm,s_id,v_id[e0],v_id[e1]); - add_list = push_data(add_list,t0_id); - t1_id = smAdd_tri(sm,s_id,v_id[e2],v_id[e0]); - add_list = push_data(add_list,t1_id); - t2_id = smAdd_tri(sm,s_id,v_id[e1],opp_id); - add_list = push_data(add_list,t2_id); - t3_id = smAdd_tri(sm,s_id,opp_id,v_id[e2]); - add_list = push_data(add_list,t3_id); - /* CAUTION: tri must be assigned after Add_tri: pointers may change*/ - tri = SM_NTH_TRI(sm,tri_id); - topp =SM_NTH_TRI(sm,topp_id); + t0_id = smAdd_tri(sm,s_id,v_id[e0],v_id[e1],&t0); + t1_id = smAdd_tri(sm,s_id,v_id[e2],v_id[e0],&t1); + t2_id = smAdd_tri(sm,s_id,v_id[e1],opp_id,&t2); + t3_id = smAdd_tri(sm,s_id,opp_id,v_id[e2],&t3); - /* Set the neighbor pointers for the new tris */ - T_NTH_NBR(SM_NTH_TRI(sm,t0_id),0) = T_NTH_NBR(tri,e2); - T_NTH_NBR(SM_NTH_TRI(sm,t0_id),1) = t2_id; - T_NTH_NBR(SM_NTH_TRI(sm,t0_id),2) = t1_id; - T_NTH_NBR(SM_NTH_TRI(sm,t1_id),0) = T_NTH_NBR(tri,e1); - T_NTH_NBR(SM_NTH_TRI(sm,t1_id),1) = t0_id; - T_NTH_NBR(SM_NTH_TRI(sm,t1_id),2) = t3_id; - T_NTH_NBR(SM_NTH_TRI(sm,t2_id),0) = T_NTH_NBR(topp,opp1); - T_NTH_NBR(SM_NTH_TRI(sm,t2_id),1) = t3_id; - T_NTH_NBR(SM_NTH_TRI(sm,t2_id),2) = t0_id; - T_NTH_NBR(SM_NTH_TRI(sm,t3_id),0) = T_NTH_NBR(topp,opp2); - T_NTH_NBR(SM_NTH_TRI(sm,t3_id),1) = t1_id; - T_NTH_NBR(SM_NTH_TRI(sm,t3_id),2) = t2_id; + /* Set the neighbor pointers for the new tris */ + T_NTH_NBR(t0,0) = T_NTH_NBR(tri,e2); + T_NTH_NBR(t0,1) = t2_id; + T_NTH_NBR(t0,2) = t1_id; + T_NTH_NBR(t1,0) = T_NTH_NBR(tri,e1); + T_NTH_NBR(t1,1) = t0_id; + T_NTH_NBR(t1,2) = t3_id; + T_NTH_NBR(t2,0) = T_NTH_NBR(topp,opp1); + T_NTH_NBR(t2,1) = t3_id; + T_NTH_NBR(t2,2) = t0_id; + T_NTH_NBR(t3,0) = T_NTH_NBR(topp,opp2); + T_NTH_NBR(t3,1) = t1_id; + T_NTH_NBR(t3,2) = t2_id; /* Reset the neigbor pointers for the neighbors of the original */ nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,e1)); @@ -1046,207 +979,847 @@ smInsert_samp(sm,s_id,tri_id,on,which) T_NTH_NBR(nbr,T_NTH_NBR_PTR(topp_id,nbr)) = t2_id; nbr = SM_NTH_TRI(sm,T_NTH_NBR(topp,opp2)); T_NTH_NBR(nbr,T_NTH_NBR_PTR(topp_id,nbr)) = t3_id; + #ifdef DEBUG - T_VALID_FLAG(SM_NTH_TRI(sm,tri_id))=-1; - T_VALID_FLAG(SM_NTH_TRI(sm,topp_id))=-1; -#endif - tlist = push_data(NULL,t0_id); - tlist = push_data(tlist,t1_id); - tlist = push_data(tlist,t2_id); - tlist = push_data(tlist,t3_id); +#if DEBUG > 1 +{ + TRI *n; + + if(T_NTH_NBR(t0,0) == T_NTH_NBR(t0,1) || + T_NTH_NBR(t0,1) == T_NTH_NBR(t0,2) || + T_NTH_NBR(t0,0) == T_NTH_NBR(t0,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t0,0)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t0,1)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t0,2)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t1,0)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t1,1)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t1,2)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + + if(T_NTH_NBR(t1,0) == T_NTH_NBR(t1,1) || + T_NTH_NBR(t1,1) == T_NTH_NBR(t1,2) || + T_NTH_NBR(t1,0) == T_NTH_NBR(t1,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,2)))) + error(CONSISTENCY,"Invalid topology\n"); + + if(T_NTH_NBR(t2,0) == T_NTH_NBR(t2,1) || + T_NTH_NBR(t2,1) == T_NTH_NBR(t2,2) || + T_NTH_NBR(t2,0) == T_NTH_NBR(t2,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t2,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t2,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t2,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t2,0)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t2,1)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t2,2)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + + if(T_NTH_NBR(t3,0) == T_NTH_NBR(t3,1) || + T_NTH_NBR(t3,1) == T_NTH_NBR(t3,2) || + T_NTH_NBR(t3,0) == T_NTH_NBR(t3,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t3,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t3,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t3,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t3,0)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t3,1)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t3,2)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); +} +#endif +#endif + smDir(sm,e,opp_id); + if(which == 0) + { + smRestore_Delaunay(sm,a,b,c,t0,t0_id,s_id,v_id[e0],v_id[e1]); + smRestore_Delaunay(sm,a,d,b,t1,t1_id,s_id,v_id[e2],v_id[e0]); + smRestore_Delaunay(sm,a,c,e,t2,t2_id,s_id,v_id[e1],opp_id); + smRestore_Delaunay(sm,a,e,d,t3,t3_id,s_id,opp_id,v_id[e2]); + } + else + if( which==1 ) + { + smRestore_Delaunay(sm,a,c,d,t0,t0_id,s_id,v_id[e0],v_id[e1]); + smRestore_Delaunay(sm,a,b,c,t1,t1_id,s_id,v_id[e2],v_id[e0]); + smRestore_Delaunay(sm,a,d,e,t2,t2_id,s_id,v_id[e1],opp_id); + smRestore_Delaunay(sm,a,e,b,t3,t3_id,s_id,opp_id,v_id[e2]); + } + else + { + smRestore_Delaunay(sm,a,d,b,t0,t0_id,s_id,v_id[e0],v_id[e1]); + smRestore_Delaunay(sm,a,c,d,t1,t1_id,s_id,v_id[e2],v_id[e0]); + smRestore_Delaunay(sm,a,b,e,t2,t2_id,s_id,v_id[e1],opp_id); + smRestore_Delaunay(sm,a,e,c,t3,t3_id,s_id,opp_id,v_id[e2]); + } + smDelete_tri(sm,tri_id,tri); + smDelete_tri(sm,topp_id,topp); + return(TRUE); } - else - { - /* Create 3 triangles */ - /* / \ /|\ - / \ / | \ - / * \ ----> / | \ - / \ / / \ \ - / \ / / \ \ - /___________\ //_________\\ - */ +Linsert_in_tri: + /* Create 3 triangles */ + /* / \ /|\ + / \ / | \ + / * \ ----> / | \ + / \ / / \ \ + / \ / / \ \ + ___________\ //_________\\ + */ + tri = SM_NTH_TRI(sm,tri_id); - t0_id = smAdd_tri(sm,s_id,v_id[0],v_id[1]); - add_list = push_data(add_list,t0_id); - t1_id = smAdd_tri(sm,s_id,v_id[1],v_id[2]); - add_list = push_data(add_list,t1_id); - t2_id = smAdd_tri(sm,s_id,v_id[2],v_id[0]); - add_list = push_data(add_list,t2_id); + t0_id = smAdd_tri(sm,s_id,v_id[0],v_id[1],&t0); + t1_id = smAdd_tri(sm,s_id,v_id[1],v_id[2],&t1); + t2_id = smAdd_tri(sm,s_id,v_id[2],v_id[0],&t2); - /* CAUTION: tri must be assigned after Add_tri: pointers may change*/ - tri = SM_NTH_TRI(sm,tri_id); - /* Set the neighbor pointers for the new tris */ - T_NTH_NBR(SM_NTH_TRI(sm,t0_id),0) = T_NTH_NBR(tri,2); - T_NTH_NBR(SM_NTH_TRI(sm,t0_id),1) = t1_id; - T_NTH_NBR(SM_NTH_TRI(sm,t0_id),2) = t2_id; - T_NTH_NBR(SM_NTH_TRI(sm,t1_id),0) = T_NTH_NBR(tri,0); - T_NTH_NBR(SM_NTH_TRI(sm,t1_id),1) = t2_id; - T_NTH_NBR(SM_NTH_TRI(sm,t1_id),2) = t0_id; - T_NTH_NBR(SM_NTH_TRI(sm,t2_id),0) = T_NTH_NBR(tri,1); - T_NTH_NBR(SM_NTH_TRI(sm,t2_id),1) = t0_id; - T_NTH_NBR(SM_NTH_TRI(sm,t2_id),2) = t1_id; + /* Set the neighbor pointers for the new tris */ + T_NTH_NBR(t0,0) = T_NTH_NBR(tri,2); + T_NTH_NBR(t0,1) = t1_id; + T_NTH_NBR(t0,2) = t2_id; + T_NTH_NBR(t1,0) = T_NTH_NBR(tri,0); + T_NTH_NBR(t1,1) = t2_id; + T_NTH_NBR(t1,2) = t0_id; + T_NTH_NBR(t2,0) = T_NTH_NBR(tri,1); + T_NTH_NBR(t2,1) = t0_id; + T_NTH_NBR(t2,2) = t1_id; - /* Reset the neigbor pointers for the neighbors of the original */ - nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,0)); - T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t1_id; - nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,1)); - T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t2_id; - nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,2)); - T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t0_id; + /* Reset the neigbor pointers for the neighbors of the original */ + nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,0)); + T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t1_id; + nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,1)); + T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t2_id; + nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,2)); + T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t0_id; +#ifdef DEBUG +#if DEBUG > 1 +{ + TRI *n; + if(T_NTH_NBR(t0,0) == T_NTH_NBR(t0,1) || + T_NTH_NBR(t0,1) == T_NTH_NBR(t0,2) || + T_NTH_NBR(t0,0) == T_NTH_NBR(t0,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t0,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t0,0)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t0,1)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t0,2)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t1,0)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t1,1)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t1,2)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); - tlist = push_data(NULL,t0_id); - tlist = push_data(tlist,t1_id); - tlist = push_data(tlist,t2_id); - } - /* Fix up the new triangles*/ - smFix_tris(sm,s_id,tlist,add_list); + if(T_NTH_NBR(t1,0) == T_NTH_NBR(t1,1) || + T_NTH_NBR(t1,1) == T_NTH_NBR(t1,2) || + T_NTH_NBR(t1,0) == T_NTH_NBR(t1,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t1,2)))) + error(CONSISTENCY,"Invalid topology\n"); - smDelete_tri(sm,tri_id); - if(on==ON_E) - smDelete_tri(sm,topp_id); + if(T_NTH_NBR(t2,0) == T_NTH_NBR(t2,1) || + T_NTH_NBR(t2,1) == T_NTH_NBR(t2,2) || + T_NTH_NBR(t2,0) == T_NTH_NBR(t2,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t2,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t2,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(t2,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t2,0)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t2,1)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); + n = SM_NTH_TRI(sm,T_NTH_NBR(t2,2)); + if(T_NTH_NBR(n,0) == T_NTH_NBR(n,1) || + T_NTH_NBR(n,1) == T_NTH_NBR(n,2) || + T_NTH_NBR(n,0) == T_NTH_NBR(n,2)) + error(CONSISTENCY,"Invalid topology\n"); + if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,0))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,1))) || + !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(n,2)))) + error(CONSISTENCY,"Invalid topology\n"); +} +#endif +#endif + smRestore_Delaunay(sm,a,b,c,t0,t0_id,s_id,v_id[0],v_id[1]); + smRestore_Delaunay(sm,a,c,d,t1,t1_id,s_id,v_id[1],v_id[2]); + smRestore_Delaunay(sm,a,d,b,t2,t2_id,s_id,v_id[2],v_id[0]); + smDelete_tri(sm,tri_id,tri); + return(TRUE); - return(TRUE); - #ifdef DEBUG Ladderror: - error(CONSISTENCY,"Invalid tri: smInsert_samp()\n"); + error(CONSISTENCY,"Invalid tri: smInsert_samp_mesh()\n"); #endif } + int -smTri_in_set(sm,p,optr,onptr,whichptr) +smWalk(sm,p,t_id,t,onptr,wptr,from,on_edge,a,b) SM *sm; FVECT p; -OBJECT *optr; -int *onptr,*whichptr; +int t_id; +TRI *t; +int *onptr,*wptr; +int from; +double on_edge; +FVECT a,b; { - int i,t_id,on0,on1,on2; FVECT n,v0,v1,v2; - TRI *t; - double side; + TRI *tn; - for (i = QT_SET_CNT(optr),optr = QT_SET_PTR(optr);i > 0; i--) - { - /* Find the first triangle that pt falls */ - t_id = QT_SET_NEXT_ELEM(optr); - t = SM_NTH_TRI(sm,t_id); - if(!T_IS_VALID(t)) - continue; + int tn_id; + +#ifdef DEBUG + Wcnt++; + on0 = on1 = on2 = 10; +#endif + switch(from){ + case 0: + on0 = on_edge; + /* Havnt calculate v0 yet: check for equality first */ VSUB(v0,SM_T_NTH_WV(sm,t,0),SM_VIEW_CENTER(sm)); - VSUB(v1,SM_T_NTH_WV(sm,t,1),SM_VIEW_CENTER(sm)); - VSUB(v2,SM_T_NTH_WV(sm,t,2),SM_VIEW_CENTER(sm)); + normalize(v0); + if(EQUAL_VEC3(v0,p)){ *onptr = ON_V; *wptr = 0; return(t_id); } + /* determine what side of edge v0v1 (v0a) point is on*/ + VCROSS(n,v0,a); + normalize(n); + on2 = DOT(n,p); + if(on2 > 0.0) + { + tn_id = T_NTH_NBR(t,2); + tn = SM_NTH_TRI(sm,tn_id); + return(smWalk(sm,p,tn_id,tn,onptr,wptr,T_NTH_NBR_PTR(t_id,tn), + -on2,a,v0)); + } + else + if(on2 >= -EDGE_EPS) + { + if(on0 >= -EDGE_EPS) + { + /* Could either be epsilon of vertex 1*/ + /* dot(p,a) == cos angle between them. Want length of chord x to + be <= EDGE_EPS for test. if the perpendicular bisector of pa + is d, cos@/2 = d/1, with right triangle d^2 + (x/2)^2 = 1 + or x^2 = 4(1-cos^2@/2) = 4(1- (1 + cos@)/2) = 2 -2cos@, + so test is if x^2 <= VERT_EPS*VERT_EPS, + 2 - 2cos@ <= VERT_EPS*VERT_EPS, or... */ + if(DOT(p,a) >= 1.0-VERT_EPS*VERT_EPS/2.0) + {*onptr = ON_P; *wptr = 1;} + else + if(on2 > on0) + {*onptr = ON_E; *wptr = 2;} + else + {*onptr = ON_E; *wptr = 0;} + return(t_id); + } + } - if(EQUAL_VEC3(v0,p)) + VCROSS(n,b,v0); + normalize(n); + on1 = DOT(n,p); + if(on1 > 0.0) { - *onptr = ON_V; - *whichptr = 0; - return(t_id); + tn_id = T_NTH_NBR(t,1); + tn = SM_NTH_TRI(sm,tn_id); + return(smWalk(sm,p,tn_id,tn,onptr,wptr,T_NTH_NBR_PTR(t_id,tn), + -on1,v0,b)); } - if(EQUAL_VEC3(v1,p)) + else + if(on1 >= -EDGE_EPS) + { /* Either on v0 or on edge 1 */ + if(on0 >= -EDGE_EPS) + { + if(DOT(p,b) >= 1.0-VERT_EPS*VERT_EPS/2.0) + {*onptr = ON_P; *wptr = 2;} + else + if(on1 > on0) + {*onptr = ON_E; *wptr = 1;} + else + {*onptr = ON_E; *wptr = 0;} + return(t_id); + } + if(on2 >= -EDGE_EPS) + { + if(DOT(p,v0) >= 1.0-VERT_EPS*VERT_EPS/2.0) + {*onptr = ON_P; *wptr = 0;} + else + if( on1 > on2) + {*onptr = ON_E; *wptr = 1;} + else + {*onptr = ON_E; *wptr = 2;} + return(t_id); + } + *onptr = ON_E; *wptr = 1; + return(t_id); + } + else + if(on2 >= -EDGE_EPS) + { + *onptr = ON_E; *wptr = 2; + return(t_id); + } + if(on0 >= -EDGE_EPS) + { + *onptr = ON_E; *wptr = 0; + return(t_id); + } + *onptr = IN_T; + return(t_id); + case 1: + on1 = on_edge; + /* Havnt calculate v1 yet: check for equality first */ + VSUB(v1,SM_T_NTH_WV(sm,t,1),SM_VIEW_CENTER(sm)); + normalize(v1); + if(EQUAL_VEC3(v1,p)){ *onptr = ON_V; *wptr = 1; return(t_id); } + /* determine what side of edge v0v1 (v0a) point is on*/ + VCROSS(n,b,v1); + normalize(n); + on2 = DOT(n,p); + if(on2 > 0.0) { - *onptr = ON_V; - *whichptr = 1; - return(t_id); + tn_id = T_NTH_NBR(t,2); + tn = SM_NTH_TRI(sm,tn_id); + return(smWalk(sm,p,tn_id,tn,onptr,wptr,T_NTH_NBR_PTR(t_id,tn), + -on2,v1,b)); } - if(EQUAL_VEC3(v2,p)) + if(on2 >= -EDGE_EPS) { - *onptr = ON_V; - *whichptr = 2; - return(t_id); + if(on1 >= -EDGE_EPS) + { + if(DOT(p,b) >= 1.0-VERT_EPS*VERT_EPS/2.0) + { *onptr = ON_P; *wptr = 0;} + else + if(on2 > on1) + { *onptr = ON_E; *wptr = 2;} + else + { *onptr = ON_E; *wptr = 1;} + return(t_id); + } } - - on0 = on1 =on2 = 0; - VCROSS(n,v0,v1); - side = DOT(n,p); - if(ZERO(side)) - on2 = TRUE; - else - if(side >0.0) - continue; - VCROSS(n,v1,v2); - side = DOT(n,p); - if(ZERO(side)) - on0 = TRUE; + VCROSS(n,v1,a); + normalize(n); + on0 = DOT(n,p); + if(on0 >0.0) + { + tn_id = T_NTH_NBR(t,0); + tn = SM_NTH_TRI(sm,tn_id); + return(smWalk(sm,p,tn_id,tn,onptr,wptr,T_NTH_NBR_PTR(t_id,tn), + -on0,a,v1)); + } + else + if(on0 >= -EDGE_EPS) + { /* Either on v0 or on edge 1 */ + if(on1 >= -EDGE_EPS) + { + if(DOT(p,a) >= 1.0-VERT_EPS*VERT_EPS/2.0) + {*onptr = ON_P; *wptr = 2;} + else + if(on0 > on1) + { *onptr = ON_E; *wptr = 0;} + else + { *onptr = ON_E; *wptr = 1;} + return(t_id); + } + if(on2 >= -EDGE_EPS) + { + if(DOT(p,v1) >= 1.0-VERT_EPS*VERT_EPS/2.0) + {*onptr = ON_P; *wptr = 1;} + else + if(on0 > on2) + { *onptr = ON_E; *wptr = 0;} + else + { *onptr = ON_E; *wptr = 2;} + return(t_id); + } + *onptr = ON_E; *wptr = 0; + return(t_id); + } else - if(side >0.0) - continue; + if(on2 >= -EDGE_EPS) + { + *onptr = ON_E; *wptr = 2; + return(t_id); + } + if(on1 >= -EDGE_EPS) + { + *onptr = ON_E; *wptr = 1; + return(t_id); + } + *onptr = IN_T; + return(t_id); + case 2: + on2 = on_edge; + VSUB(v2,SM_T_NTH_WV(sm,t,2),SM_VIEW_CENTER(sm)); + normalize(v2); + if(EQUAL_VEC3(v2,p)){ *onptr = ON_V; *wptr = 2; return(t_id); } - VCROSS(n,v2,v0); - side = DOT(n,p); - if(ZERO(side)) - on1 = TRUE; - else - if(side >0.0) - continue; - if(on0) + /* determine what side of edge v0v1 (v0a) point is on*/ + VCROSS(n,b,v2); + normalize(n); + on0 = DOT(n,p); + if(on0 > 0.0) { - if(on1) + tn_id = T_NTH_NBR(t,0); + tn = SM_NTH_TRI(sm,tn_id); + return(smWalk(sm,p,tn_id,tn,onptr,wptr,T_NTH_NBR_PTR(t_id,tn), + -on0,v2,b)); + } + else + if(on0 >= -EDGE_EPS) { - *onptr = ON_P; - *whichptr = 2; + if(on2 >= - EDGE_EPS) + { + if(DOT(p,b) >= 1.0-VERT_EPS*VERT_EPS/2.0) + {*onptr = ON_P; *wptr = 1;} + else + if(on0 > on2) + {*onptr = ON_E; *wptr = 0;} + else + {*onptr = ON_E; *wptr = 2;} + return(t_id); + } } - else - if(on2) + VCROSS(n,v2,a); + normalize(n); + on1 = DOT(n,p); + if(on1 >0.0) + { + tn_id = T_NTH_NBR(t,1); + tn = SM_NTH_TRI(sm,tn_id); + return(smWalk(sm,p,tn_id,tn,onptr,wptr,T_NTH_NBR_PTR(t_id,tn), + -on1,a,v2)); + } + else + if(on1 >= -EDGE_EPS) + { /* Either on v0 or on edge 1 */ + if(on0 >= - EDGE_EPS) { - *onptr = ON_P; - *whichptr = 1; + if(DOT(p,v2) >= 1.0-VERT_EPS*VERT_EPS/2.0) + {*onptr = ON_P;*wptr = 2;} + else + if(on1 > on0) + {*onptr = ON_E;*wptr = 1;} + else + {*onptr = ON_E;*wptr = 0;} + return(t_id); } + if(on2 >= -EDGE_EPS) + { + if(DOT(p,a) >= 1.0-VERT_EPS*VERT_EPS/2.0) + {*onptr = ON_P;*wptr = 0;} else - { - *onptr = ON_E; - *whichptr = 0; - } - return(t_id); - } - if(on1) - { - if(on2) + if(on1 > on2) + {*onptr = ON_E;*wptr = 1;} + else + {*onptr = ON_E;*wptr = 2;} + return(t_id); + } + *onptr = ON_E;*wptr = 1; + return(t_id); + } + else + if(on0 >= -EDGE_EPS) { - *onptr = ON_P; - *whichptr = 0; + *onptr = ON_E;*wptr = 0; + return(t_id); } - else + if(on2 >= -EDGE_EPS) { - *onptr = ON_E; - *whichptr = 1; + *onptr = ON_E;*wptr = 2; + return(t_id); } - return(t_id); + *onptr = IN_T; + return(t_id); + default: + /* First time called: havnt tested anything */ + /* Check against vertices */ + VSUB(v0,SM_T_NTH_WV(sm,t,0),SM_VIEW_CENTER(sm)); + normalize(v0); + if(EQUAL_VEC3(v0,p)){ *onptr = ON_V; *wptr = 0; return(t_id); } + VSUB(v1,SM_T_NTH_WV(sm,t,1),SM_VIEW_CENTER(sm)); + normalize(v1); + if(EQUAL_VEC3(v1,p)){ *onptr = ON_V; *wptr = 1; return(t_id); } + VSUB(v2,SM_T_NTH_WV(sm,t,2),SM_VIEW_CENTER(sm)); + normalize(v2); + if(EQUAL_VEC3(v2,p)){ *onptr = ON_V; *wptr = 2; return(t_id); } + + VCROSS(n,v0,v1); /* Check against v0v1, or edge 2 */ + normalize(n); + on2 = DOT(n,p); + if(on2 > 0.0) + { /* Outside edge: traverse to nbr 2 */ + tn_id = T_NTH_NBR(t,2); + tn = SM_NTH_TRI(sm,tn_id); + return(smWalk(sm,p,tn_id,tn,onptr,wptr,T_NTH_NBR_PTR(t_id,tn), + -on2,v1,v0)); } - if(on2) - { - *onptr = ON_E; - *whichptr = 2; + else + VCROSS(n,v1,v2); /* Check against v1v2 or edge 0 */ + normalize(n); + on0 = DOT(n,p); + if(on0 > 0.0) + { /* Outside edge: traverse to nbr 0 */ + tn_id = T_NTH_NBR(t,0); + tn = SM_NTH_TRI(sm,tn_id); + return(smWalk(sm,p,tn_id,tn,onptr,wptr,T_NTH_NBR_PTR(t_id,tn), + -on0,v2,v1)); + } + else + if(on0 >= -EDGE_EPS) + { /* On the line defining edge 0 */ + if(on2 >= -EDGE_EPS) + { + if(DOT(p,v1) >= 1.0-VERT_EPS*VERT_EPS/2.0) + {*onptr = ON_P;*wptr = 1;} + else + if(on0 > on2) + {*onptr = ON_E;*wptr = 0;} + else + {*onptr = ON_E;*wptr = 2;} + return(t_id); + } + } + VCROSS(n,v2,v0); /* Check against v2v0 or edge 1 */ + normalize(n); + on1 = DOT(n,p); + if(on1 >0.0) + { /* Outside edge: traverse to nbr 1 */ + tn_id = T_NTH_NBR(t,1); + tn = SM_NTH_TRI(sm,tn_id); + return(smWalk(sm,p,tn_id,tn,onptr,wptr,T_NTH_NBR_PTR(t_id,tn), + -on1,v0,v2)); + } + else + if(on1 >= -EDGE_EPS) + { /* On the line defining edge 1 */ + if(on2 >= -EDGE_EPS) + { + if(DOT(p,v0) >= 1.0-VERT_EPS*VERT_EPS/2.0) + {*onptr = ON_P;*wptr = 0;} + else + if(on1 > on2) + {*onptr = ON_E;*wptr = 1;} + else + {*onptr = ON_E;*wptr = 2;} + return(t_id); + } + if(on0 >= -EDGE_EPS) + { + if(DOT(p,v2) >= 1.0-VERT_EPS*VERT_EPS/2.0) + {*onptr = ON_P;*wptr = 2;} + else + if(on1 > on0) + {*onptr = ON_E;*wptr = 1;} + else + {*onptr = ON_E;*wptr = 0;} + return(t_id); + } + *onptr = ON_E; /* Only on edge 1 */ + *wptr = 1; + return(t_id); + } + else + if(on2 >= -EDGE_EPS) /* Is on edge 2 ? */ + { + *onptr = ON_E; *wptr = 2; + return(t_id); + } + if(on0 >= -EDGE_EPS) /* Is on edge 0 ? */ + { + *onptr = ON_E; *wptr = 0; return(t_id); - } - *onptr = IN_T; + } + *onptr = IN_T; /* Must be interior to t */ return(t_id); } - return(INVALID); } +#define check_edges(on0,on1,on2,o,w,t_id) \ + if(on0){if(on1){*o = ON_P;*w = 2;} else if(on2){*o = ON_P;*w = 1;} \ + else {*o = ON_E; *w = 0; } return(t_id); } \ + if(on1){if(on2){*o = ON_P;*w = 0;} else {*o = ON_E;*w = 1;}return(t_id);}\ + if(on2){*o = ON_E;*w = 2;return(t_id);} + +#define check_verts(p,v0,v1,v2,o,w,t_id) \ + if(EQUAL_VEC3(v0,p)){ *o = ON_V; *w = 0; return(t_id); } \ + if(EQUAL_VEC3(v1,p)){ *o = ON_V; *w = 1; return(t_id); } \ + if(EQUAL_VEC3(v2,p)){ *o = ON_V; *w = 2; return(t_id);} + + int -smPointLocateTri(sm,p,onptr,whichptr) +find_neighbor(argptr,qt,f,doneptr) +int *argptr; +QUADTREE qt; +FUNC f; +int *doneptr; +{ + int s_id,i; + OBJECT *optr; + + if(QT_IS_EMPTY(qt)) + return; + else + if(QT_IS_TREE(qt)) + { + for(i=0;i < 4; i++) + { + find_neighbor(argptr,QT_NTH_CHILD(qt,i),f,doneptr); + if(*doneptr) + return; + } + } + else + { + optr = qtqueryset(qt); + for(i = QT_SET_CNT(optr); i > 0; i--) + { + s_id = QT_SET_NEXT_ELEM(optr); + if(s_id != ((S_ARGS *)argptr)->s_id) + { + *doneptr = TRUE; + ((S_ARGS *)argptr)->n_id = s_id; + return; + } + } + } +} + +smInsert_samp(sm,s_id,p,nptr) SM *sm; +int s_id; FVECT p; -int *onptr,*whichptr; +int *nptr; { - QUADTREE qt,*optr; FVECT tpt; - int tri_id; + FUNC f; + S_ARGS args; - VSUB(tpt,p,SM_VIEW_CENTER(sm)); - qt = smPointLocateCell(sm,tpt); - if(QT_IS_EMPTY(qt)) - return(INVALID); - - optr = qtqueryset(qt); - tri_id = smTri_in_set(sm,tpt,optr,onptr,whichptr); + F_FUNC(f) = insert_samp; + args.s_id = s_id; + if(nptr) + { + args.n_id = 1; + F_FUNC2(f) = find_neighbor; + } + else + args.n_id = 0; + F_ARGS(f) = (int *)(&args); + stInsert_samp(SM_LOCATOR(sm),p,f); - return(tri_id); + if(nptr) + *nptr = args.n_id; } +/* Assumed p is normalized to view sphere */ +int +smSample_locate_tri(sm,p,s_id,onptr,whichptr,nptr) +SM *sm; +FVECT p; +int s_id; +int *onptr,*whichptr,*nptr; +{ + int tri_id; + FVECT tpt; + TRI *tri; + if(SM_S_NTH_QT(sm,s_id) == EMPTY) + smInsert_samp(sm,s_id,p,nptr); +#ifdef DEBUG + if(*nptr == INVALID) + error(CONSISTENCY,"smSample_locate_tri: unable to find sample\n"); +#endif + + /* Get the triangle adjacent to a sample in qt, or if there are no other + samples in qt than the one just inserted, look at siblings-from parent + node + */ + + tri_id = SM_NTH_VERT(sm,*nptr); +#ifdef DEBUG + if(tri_id == INVALID) + error(CONSISTENCY,"smSample_locate_tri: Invalid tri_id\n"); +#endif + + tri = SM_NTH_TRI(sm,tri_id); +#ifdef DEBUG + Tcnt++; + if(!T_IS_VALID(tri)) + error(CONSISTENCY,"smSample_locate_tri: Invalid tri\n"); +#endif + tri_id = smWalk(sm,p,tri_id,tri,onptr,whichptr,-1,0.0,NULL,NULL); +#ifdef DEBUG + if(tri_id == INVALID) + error(CONSISTENCY,"smSample_locate_tri: unable to find tri on walk\n"); +#endif + return(tri_id); +} + /* Determine whether this sample should: a) be added to the mesh by subdividing the triangle @@ -1276,16 +1849,21 @@ int *onptr,*whichptr; This attempts to throw out points that should be occluded */ int -smTest_sample(sm,tri_id,dir,p,rptr) +smTest_samp(sm,tri_id,dir,p,rptr,ns,n0,n1,n2,ds,d0,on,which) SM *sm; int tri_id; FVECT dir,p; int *rptr; + FVECT ns,n0,n1,n2; + double ds,d0; + int on,which; { TRI *tri; - double d,d2,dnear,dspt,d01,d12,d20,s0,s1,s2,ds,dv; + double d,d2,dnear,dspt,d01,d12,d20,s0,s1,s2; + double dp,dp1; int vid[3],i,nearid,norm,dcnt,bcnt; - FVECT diff[3],spt,npt; + FVECT diff[3],spt,npt,n; + FVECT nearpt; *rptr = INVALID; bcnt = dcnt = 0; @@ -1298,151 +1876,113 @@ smTest_sample(sm,tri_id,dir,p,rptr) { if(SM_BASE_ID(sm,vid[i])) bcnt++; - if(SM_DIR_ID(sm,vid[i])) - dcnt++; - + else + if(SM_DIR_ID(sm,vid[i])) + dcnt++; } - /* TEST 1: If the new sample is close in ws, and close in the spherical - projection to one of the triangle vertex samples - */ -#if 0 - norm = FALSE; - VSUB(spt,p,SM_VIEW_CENTER(sm)); - ds = DOT(spt,spt); - dnear = FHUGE; - for(i=0; i<3; i++) - { - d = DOT(diff[i],diff[i])/ds; - if(d < dnear) - { - dnear = d; - nearid=vid[i]; - } - } - - if(dnear <= SM_MIN_SAMP_DIFF*SM_MIN_SAMP_DIFF) - { - /* Pick the point with dir closest to that of the canonical view - if it is the new sample: mark existing point for deletion - */ - if(SM_BASE_ID(sm,nearid)) - { - *rptr = nearid; - return(TRUE); - } - if(SM_DIR_ID(sm,nearid)) - return(FALSE); - if(!dir) - { - *rptr = nearid; - return(TRUE); - } - normalize(spt); - norm = TRUE; - VSUB(npt,SM_NTH_WV(sm,nearid),SM_VIEW_CENTER(sm)); - normalize(npt); - d = fdir2diff(SM_NTH_W_DIR(sm,nearid), npt); - d2 = 2. - 2.*DOT(dir,spt); - /* The existing sample is a better sample:punt */ - if(d2 > d) - return(FALSE); - else - { - /* The new sample is better: mark the existing one - for deletion after the new one is added*/ - *rptr = nearid; - return(TRUE); - } - } - - /* TEST 3: If the spherical projection of new is < S_REPLACE_EPS - from a base point: Edge length is constrained to subtend <45 degrees: - original base mesh edges are approx 32 degrees- so have about 13 degrees - to work in: S_REPLACE_EPS is the square of the radian value - */ - - if(bcnt) - { - dnear = FHUGE; - if(!norm) - normalize(spt); - - for(i=0; i<3; i++) - { - if(!SM_BASE_ID(sm,vid[i])) - continue; - VSUB(npt,SM_NTH_WV(sm,vid[i]),SM_VIEW_CENTER(sm)); - d = DIST_SQ(npt,spt); - if(dnear <= SM_MIN_SAMP_DIFF*SM_MIN_SAMP_DIFF && d< near) - { - dnear = d; - nearid = vid[i]; - } - } - if(dnear != FHUGE) - { - /* add new and mark the base for deletion */ - *rptr = nearid; - return(TRUE); - } + if( on == IN_T) + { + d = DIST_SQ(n0,ns); + dnear = d; + nearid = 0; + d = DIST_SQ(n1,ns); + if(d < dnear) + { + dnear = d; nearid = 1; + } + d = DIST_SQ(n2,ns); + if(d < dnear) + { + dnear = d; nearid = 2; + } } -#else + if(on == ON_P) + nearid = which; + if(on == ON_P || dnear < VERT_EPS*VERT_EPS) { - FVECT nearpt; - dnear = FHUGE; - VSUB(spt,p,SM_VIEW_CENTER(sm)); - ds = DOT(spt,spt); - normalize(spt); + FVECT edir; + /* Pick the point with dir closest to that of the canonical view + if it is the new sample: mark existing point for deletion + */ + if(SM_BASE_ID(sm,vid[nearid])) + return(FALSE); + if(!dir) + return(FALSE); + if(SM_DIR_ID(sm,vid[nearid])) + { + *rptr = vid[nearid]; + return(TRUE); + } + decodedir(edir,SM_NTH_W_DIR(sm,vid[nearid])); + if(nearid == 0) + d = DOT(edir,n0); + else + if(nearid == 1) + d = DOT(edir,n1); + else + d = DOT(edir,n2); + d2 = DOT(dir,ns); + /* The existing sample is a better sample:punt */ + if(d2 >= d) + return(FALSE); + else + { + /* The new sample is better: mark existing one for deletion*/ + *rptr = vid[nearid]; + return(TRUE); + } + } - for(i=0; i<3; i++) +/* Now test if sample epsilon is within circumcircle of enclosing tri + if not punt: + */ { - - VSUB(npt,SM_NTH_WV(sm,vid[i]),SM_VIEW_CENTER(sm)); - - if(!SM_BASE_ID(sm,vid[i]) || !SM_DIR_ID(sm,vid[i])) - normalize(npt); + double ab[3],ac[3],r[3]; - d = DIST_SQ(npt,spt); - if(d < SM_MIN_SAMP_DIFF*SM_MIN_SAMP_DIFF && d < dnear) + VSUB(ab,n2,n1); + VSUB(ac,n0,n2); + VCROSS(r,ab,ac); + dp = DOT(r,n1); + dp1 = DOT(r,ns); + if(dp1*dp1 + COS_VERT_EPS*DOT(r,r) < dp*dp) { - dnear = d; - nearid = vid[i]; - VCOPY(nearpt,npt); +#ifdef DEBUG + eputs("smTest_samp:rejecting samp,cant guarantee not within eps\n"); +#endif + return(FALSE); } - } - if(dnear != FHUGE) +#ifdef DEBUG +#if DEBUG > 1 + if(on == ON_E) { - /* Pick the point with dir closest to that of the canonical view - if it is the new sample: mark existing point for deletion - */ - if(SM_BASE_ID(sm,nearid)) - { - *rptr = nearid; - return(TRUE); - } - if(SM_DIR_ID(sm,nearid)) - return(FALSE); - if(!dir) - { - *rptr = nearid; - return(TRUE); - } - d = fdir2diff(SM_NTH_W_DIR(sm,nearid), nearpt); - d2 = 2. - 2.*DOT(dir,spt); - /* The existing sample is a better sample:punt */ - if(d2 > d) - return(FALSE); - else - { - /* The new sample is better: mark the existing one - for deletion after the new one is added*/ - *rptr = nearid; - return(TRUE); - } - } + TRI *topp; + int opp_id; + FVECT vopp; + + topp = SM_NTH_TRI(sm,T_NTH_NBR(tri,which)); + opp_id = T_NTH_V(topp, T_NTH_NBR_PTR(tri_id,topp)); + /* first check if valid tri created*/ + VSUB(vopp,SM_NTH_WV(sm,opp_id),SM_VIEW_CENTER(sm)); + normalize(vopp); + VCROSS(n,ns,vopp); + normalize(n); + if(which==2) + dp = DOT(n,n0) * DOT(n,n1); + else + if(which==0) + dp = DOT(n,n1) * DOT(n,n2); + else + dp = DOT(n,n2) * DOT(n,n0); + if(dp > 0.0) + { + eputs("smInsert_samp_mesh: couldn't split edge: rejecting\n"); + /* test epsilon for edge */ + return(FALSE); + } } -#endif +#endif +#endif /* TEST 4: If the addition of the new sample point would introduce a "puncture" or cause new triangles with large depth differences:dont add: @@ -1450,9 +1990,7 @@ smTest_sample(sm,tri_id,dir,p,rptr) if(bcnt || dcnt) return(TRUE); - /* If the new point is in front of the existing points- add */ - dv = DIST_SQ(SM_NTH_WV(sm,vid[0]),SM_VIEW_CENTER(sm)); - if(ds < dv) + if(ds < d0) return(TRUE); d01 = DIST_SQ(SM_NTH_WV(sm,vid[1]),SM_NTH_WV(sm,vid[0])); @@ -1480,24 +2018,22 @@ smTest_sample(sm,tri_id,dir,p,rptr) /* TEST 5: Check to see if triangle is relatively large and should therefore be subdivided anyway. - */ - dv *= DIST_SQ(SM_NTH_WV(sm,vid[1]),SM_VIEW_CENTER(sm)); - dv *= DIST_SQ(SM_NTH_WV(sm,vid[2]),SM_VIEW_CENTER(sm)); - if (d01*d12*d20/dv > S_REPLACE_TRI) + */ + d0 = d0*d0*DIST_SQ(SM_NTH_WV(sm,vid[1]),SM_VIEW_CENTER(sm)); + d0 *= DIST_SQ(SM_NTH_WV(sm,vid[2]),SM_VIEW_CENTER(sm)); + if (d01*d12*d20/d0 > S_REPLACE_TRI) return(TRUE); return(FALSE); } - - int -smReplace_samp(sm,c,dir,p,s_id,t_id,o_id,on,which) +smReplace_samp(sm,c,dir,p,np,s_id,t_id,o_id,on,which) SM *sm; COLR c; - FVECT dir,p; + FVECT dir,p,np; int s_id,t_id,o_id,on,which; { - int tonemap,v_id,tri_id; + int v_id,tri_id; TRI *t,*tri; tri = SM_NTH_TRI(sm,t_id); @@ -1505,91 +2041,45 @@ smReplace_samp(sm,c,dir,p,s_id,t_id,o_id,on,which) /* If it is a base id, need new sample */ if(SM_BASE_ID(sm,v_id)) - { - tonemap = (SM_TONE_MAP(sm) > s_id); - sInit_samp(SM_SAMP(sm),s_id,c,dir,p,o_id,tonemap); - SM_NTH_VERT(sm,s_id) = t_id; - T_NTH_V(tri,which) = s_id; - if(!(SM_BASE_ID(sm,T_NTH_V(tri,(which+1)%3)) || - SM_BASE_ID(sm,T_NTH_V(tri,(which+2)%3)))) + return(v_id); + + if(EQUAL_VEC3(p,SM_NTH_WV(sm,v_id))) + return(INVALID); + + if(dir) + { /* If world point */ + FVECT odir,no; + double d,d1; + int dir_id; + /* if existing point is a not a dir, compare directions */ + if(!(dir_id = SM_DIR_ID(sm,v_id))) { - SM_CLR_NTH_T_BASE(sm,t_id); - + decodedir(odir, SM_NTH_W_DIR(sm,v_id)); + VSUB(no,SM_NTH_WV(sm,v_id),SM_VIEW_CENTER(sm)); + d = DOT(dir,np); + d1 = DOT(odir,np); + /* The existing sample is a better sample:punt */ } - add_new_tri(t_id); - t_id = smTri_next_ccw_nbr(sm,tri,v_id); - while(t_id != INVALID) + if(dir_id || (d*d*DOT(no,no) > d1*d1)) { - t = SM_NTH_TRI(sm,t_id); - which = T_WHICH_V(t,v_id); - T_NTH_V(t,which) = s_id; - /* Check if still a base triangle */ - if(!(SM_BASE_ID(sm,T_NTH_V(t,(which+1)%3)) || - SM_BASE_ID(sm,T_NTH_V(t,(which+2)%3)))) - { - SM_CLR_NTH_T_BASE(sm,t_id); - } - add_new_tri(t_id); - t_id = smTri_next_ccw_nbr(sm,t,v_id); - } - return(s_id); - } - if(dir) - { - /* If world point */ - /* if existing point is a dir: leave */ - if(SM_DIR_ID(sm,v_id)) - return(INVALID); - if(on == ON_V) - { - tonemap = (SM_TONE_MAP(sm) > v_id); - sInit_samp(SM_SAMP(sm),v_id,c,dir,p,o_id,tonemap); - add_new_tri(t_id); + /* The new sample has better information- replace values */ + sInit_samp(SM_SAMP(sm),v_id,c,dir,p,o_id); + if(!SM_IS_NTH_T_NEW(sm,t_id)) + SM_SET_NTH_T_NEW(sm,t_id); tri_id = smTri_next_ccw_nbr(sm,tri,v_id); while(tri_id != t_id) { t = SM_NTH_TRI(sm,tri_id); - add_new_tri(tri_id); + if(!SM_IS_NTH_T_NEW(sm,tri_id)) + SM_SET_NTH_T_NEW(sm,tri_id); tri_id = smTri_next_ccw_nbr(sm,t,v_id); } - return(v_id); } - /* on == ON_P */ - else - { - FVECT spt,npt; - double d,d2; - - /* Need to check which sample is preferable */ - VSUB(spt,p,SM_VIEW_CENTER(sm)); - normalize(spt); - - VSUB(npt,SM_NTH_WV(sm,v_id),SM_VIEW_CENTER(sm)); - normalize(npt); - d = fdir2diff(SM_NTH_W_DIR(sm,v_id), npt); - d2 = 2. - 2.*DOT(dir,spt); - /* The existing sample is a better sample:punt */ - if(d2 < d) - { - /* The new sample has better information- replace values */ - tonemap = (SM_TONE_MAP(sm) > v_id); - sInit_samp(SM_SAMP(sm),v_id,c,dir,p,o_id,tonemap); - add_new_tri(t_id); - tri_id = smTri_next_ccw_nbr(sm,tri,v_id); - while(tri_id != t_id) - { - t = SM_NTH_TRI(sm,tri_id); - add_new_tri(tri_id); - tri_id = smTri_next_ccw_nbr(sm,t,v_id); - } - } return(v_id); - } } - else - { /* New point is a dir */ - return(INVALID); - } + else /* New point is a dir */ + return(INVALID); + } int @@ -1602,16 +2092,10 @@ SM *sm; s = SM_SAMP(sm); s_id = sAlloc_samp(s,&replaced); - - cnt=0; while(replaced) { - if(smRemoveVertex(sm,s_id)) - break; + smRemoveVertex(sm,s_id); s_id = sAlloc_samp(s,&replaced); - cnt++; - if(cnt > S_MAX_SAMP(s)) - error(CONSISTENCY,"smAlloc_samp():unable to find free samp\n"); } return(s_id); } @@ -1637,46 +2121,74 @@ smAdd_samp(sm,c,dir,p,o_id) FVECT dir,p; int o_id; { - int t_id,s_id,r_id,on,which,n_id; - double d; - FVECT wpt; + int t_id,s_id,r_id,on,which,n_id,nbr_id; + double ds,d0; + FVECT wpt,ns,n0,n1,n2; + QUADTREE qt,parent; + TRI *t; r_id = INVALID; - + nbr_id = INVALID; /* Must do this first-as may change mesh */ s_id = smAlloc_samp(sm); - if(s_id== 2649) - r_id = INVALID; + + SM_S_NTH_QT(sm,s_id)= EMPTY; /* If sample is a world space point */ if(p) { + VSUB(ns,p,SM_VIEW_CENTER(sm)); + ds = normalize(ns); while(1) { - t_id = smPointLocateTri(sm,p,&on,&which); + t_id = smSample_locate_tri(sm,ns,s_id,&on,&which,&nbr_id); + qt = SM_S_NTH_QT(sm,s_id); if(t_id == INVALID) { #ifdef DEBUG eputs("smAddSamp(): unable to locate tri containing sample \n"); #endif smUnalloc_samp(sm,s_id); + qtremovelast(qt,s_id); return(INVALID); } /* If spherical projection coincides with existing sample: replace */ - if((on == ON_V || on == ON_P)) + if(on == ON_V) { - if((n_id = smReplace_samp(sm,c,dir,p,s_id,t_id,o_id,on,which))!= s_id) - smUnalloc_samp(sm,s_id); - return(n_id); + n_id = smReplace_samp(sm,c,dir,p,ns,s_id,t_id,o_id,on,which); + if(n_id != s_id) + { + smUnalloc_samp(sm,s_id); +#if 0 + fprintf(stderr,"Unallocating sample %d\n",s_id); +#endif + qtremovelast(qt,s_id); + } + return(n_id); } - if((!(smTest_sample(sm,t_id,dir,p,&r_id)))) - { + t = SM_NTH_TRI(sm,t_id); + VSUB(n0,SM_NTH_WV(sm,T_NTH_V(t,0)),SM_VIEW_CENTER(sm)); + d0 = normalize(n0); + VSUB(n1,SM_NTH_WV(sm,T_NTH_V(t,1)),SM_VIEW_CENTER(sm)); + normalize(n1); + VSUB(n2,SM_NTH_WV(sm,T_NTH_V(t,2)),SM_VIEW_CENTER(sm)); + normalize(n2); + if((!(smTest_samp(sm,t_id,dir,p,&r_id,ns,n0,n1,n2,ds,d0,on,which)))) + { smUnalloc_samp(sm,s_id); +#if 0 + fprintf(stderr,"Unallocating sample %d\n",s_id); +#endif + qtremovelast(qt,s_id); return(INVALID); } if(r_id != INVALID) { smRemoveVertex(sm,r_id); - sDelete_samp(SM_SAMP(sm),r_id); + if(nbr_id == r_id) + { + qtremovelast(qt,s_id); + SM_S_NTH_QT(sm,s_id) = EMPTY; + } } else break; @@ -1685,57 +2197,63 @@ smAdd_samp(sm,c,dir,p,o_id) map individually */ /* Initialize sample */ - sInit_samp(SM_SAMP(sm),s_id,c,dir,p,o_id,(SM_TONE_MAP(sm)>s_id)); - + sInit_samp(SM_SAMP(sm),s_id,c,dir,p,o_id); + /* If not base or sky point, add distance from center to average*/ + smDist_sum += 1.0/ds; + smInsert_samp_mesh(sm,s_id,t_id,ns,n0,n1,n2,on,which); } /* If sample is a direction vector */ else { VADD(wpt,dir,SM_VIEW_CENTER(sm)); while(1) - { if(s_id == 2299) - t_id = INVALID; - t_id = smPointLocateTri(sm,wpt,&on,&which); + { + t_id = smSample_locate_tri(sm,dir,s_id,&on,&which,&nbr_id); + qt = SM_S_NTH_QT(sm,s_id); +#ifdef DEBUG if(t_id == INVALID) { -#ifdef DEBUG - eputs("smAddSamp(): unable to locate tri containing sample \n"); + eputs("smAddSamp():can't locate tri containing samp\n"); + smUnalloc_samp(sm,s_id); + qtremovelast(qt,s_id); + return(INVALID); + } #endif + if(on == ON_V) + { smUnalloc_samp(sm,s_id); + qtremovelast(qt,s_id); return(INVALID); } - if(on == ON_V || on == ON_P) - { - if((n_id=smReplace_samp(sm,c,NULL,wpt,s_id,t_id,o_id,on,which))!=s_id) - smUnalloc_samp(sm,s_id); - return(n_id); + t = SM_NTH_TRI(sm,t_id); + VSUB(n0,SM_NTH_WV(sm,T_NTH_V(t,0)),SM_VIEW_CENTER(sm)); + d0 = normalize(n0); + VSUB(n1,SM_NTH_WV(sm,T_NTH_V(t,1)),SM_VIEW_CENTER(sm)); + normalize(n1); + VSUB(n2,SM_NTH_WV(sm,T_NTH_V(t,2)),SM_VIEW_CENTER(sm)); + normalize(n2); + if(!smTest_samp(sm,t_id,NULL,wpt,&r_id,dir,n0,n1,n2,1.0,d0,on,which)) + { + smUnalloc_samp(sm,s_id); + qtremovelast(qt,s_id); + return(INVALID); } - if((!(smTest_sample(sm,t_id,NULL,wpt,&r_id)))) - { - smUnalloc_samp(sm,s_id); - return(INVALID); + if(r_id != INVALID) + { + smRemoveVertex(sm,r_id); + if(nbr_id == r_id) + { + qtremovelast(qt,s_id); + SM_S_NTH_QT(sm,s_id) = EMPTY; + } + } + else + break; } - - if(r_id != INVALID) - { - smRemoveVertex(sm,r_id); - sDelete_samp(SM_SAMP(sm),r_id); - } - else - break; - } /* Allocate space for a sample and initialize */ - sInit_samp(SM_SAMP(sm),s_id,c,NULL,wpt,o_id,(SM_TONE_MAP(sm)>s_id)); + sInit_samp(SM_SAMP(sm),s_id,c,NULL,wpt,o_id); + smInsert_samp_mesh(sm,s_id,t_id,dir,n0,n1,n2,on,which); } - if(!SM_DIR_ID(sm,s_id)) - { - /* If not a base or sky point, add distance from the - viewcenter to average*/ - d = DIST(SM_NTH_WV(sm,s_id),SM_VIEW_CENTER(sm)); - smDist_sum += 1.0/d; - } - smInsert_samp(sm,s_id,t_id,on,which); - return(s_id); } @@ -1757,7 +2275,6 @@ FVECT dir; FVECT p; { int s_id; - /* First check if this the first sample: if so initialize mesh */ if(SM_NUM_SAMP(smMesh) == 0) { @@ -1767,6 +2284,23 @@ FVECT p; /* Add the sample to the mesh */ s_id = smAdd_samp(smMesh,c,dir,p,INVALID); +#if 0 + { + int i; + FILE *fp; + if(s_id == 10000) + { + fp = fopen("test.xyz","w"); + for(i=0; i < s_id; i++) + if(!SM_DIR_ID(smMesh,i)) + fprintf(fp,"%f %f %f %d %d %d \n",SM_NTH_WV(smMesh,i)[0], + SM_NTH_WV(smMesh,i)[1],SM_NTH_WV(smMesh,i)[2], + SM_NTH_RGB(smMesh,i)[0],SM_NTH_RGB(smMesh,i)[1], + SM_NTH_RGB(smMesh,i)[2]); + fclose(fp); + } + } +#endif return(s_id); } @@ -1799,17 +2333,18 @@ SM *sm; int type; { int i,s_id,tri_id,nbr_id; - int p[SM_EXTRA_POINTS],ids[SM_BASE_TRIS]; + int p[SM_BASE_POINTS],ids[SM_BASE_TRIS]; int v0_id,v1_id,v2_id; FVECT d,pt,cntr,v0,v1,v2; TRI *t; /* First insert the base vertices into the sample point array */ - for(i=0; i < SM_EXTRA_POINTS; i++) + for(i=0; i < SM_BASE_POINTS; i++) { VADD(cntr,icosa_verts[i],SM_VIEW_CENTER(sm)); p[i] = smAdd_base_vertex(sm,cntr); + smInsert_samp(sm,p[i],icosa_verts[i],NULL); } /* Create the base triangles */ for(i=0;i < SM_BASE_TRIS; i++) @@ -1817,79 +2352,17 @@ int type; v0_id = p[icosa_tris[i][0]]; v1_id = p[icosa_tris[i][1]]; v2_id = p[icosa_tris[i][2]]; - ids[i] = smAdd_tri(sm, v0_id,v1_id,v2_id); + ids[i] = smAdd_tri(sm, v0_id,v1_id,v2_id,&t); /* Set neighbors */ for(nbr_id=0; nbr_id < 3; nbr_id++) T_NTH_NBR(SM_NTH_TRI(sm,ids[i]),nbr_id) = icosa_nbrs[i][nbr_id]; } - for(i=0;i < SM_BASE_TRIS; i++) - { - t = SM_NTH_TRI(sm,ids[i]); - smLocator_add_tri(sm,ids[i],T_NTH_V(t,0),T_NTH_V(t,1),T_NTH_V(t,2)); - } return(1); } - -int -smNext_tri_flag_set(sm,i,which,b) - SM *sm; - int i,which; - int b; -{ - - for(; i < SM_NUM_TRI(sm);i++) - { - - if(!T_IS_VALID(SM_NTH_TRI(sm,i))) - continue; - if(!SM_IS_NTH_T_FLAG(sm,i,which)) - continue; - if(!b) - break; - if((b==1) && !SM_BG_TRI(sm,i)) - break; - if((b==2) && SM_BG_TRI(sm,i)) - break; - } - - return(i); -} - - -int -smNext_valid_tri(sm,i) - SM *sm; - int i; -{ - - while( i < SM_NUM_TRI(sm) && !T_IS_VALID(SM_NTH_TRI(sm,i))) - i++; - - return(i); -} - - - -qtTri_from_id(t_id,v0,v1,v2) -int t_id; -FVECT v0,v1,v2; -{ - TRI *t; - - t = SM_NTH_TRI(smMesh,t_id); - if(!T_IS_VALID(t)) - return(0); - VSUB(v0,SM_T_NTH_WV(smMesh,t,0),SM_VIEW_CENTER(smMesh)); - VSUB(v1,SM_T_NTH_WV(smMesh,t,1),SM_VIEW_CENTER(smMesh)); - VSUB(v2,SM_T_NTH_WV(smMesh,t,2),SM_VIEW_CENTER(smMesh)); - return(1); -} - - -smRebuild_mesh(sm,v) +smRebuild(sm,v) SM *sm; VIEW *v; { @@ -1898,53 +2371,55 @@ smRebuild_mesh(sm,v) double d; #ifdef DEBUG - fprintf(stderr,"smRebuild_mesh(): rebuilding...."); + fprintf(stderr,"smRebuild(): rebuilding...."); #endif + smCull(sm,v,SM_ALL_LEVELS); /* Clear the mesh- and rebuild using the current sample array */ /* Remember the current number of samples */ cnt = SM_NUM_SAMP(sm); /* Calculate the difference between the current and new viewpoint*/ /* Will need to subtract this off of sky points */ VCOPY(ov,SM_VIEW_CENTER(sm)); - /* Initialize the mesh to 0 samples and the base triangles */ + /* Initialize the mesh to 0 samples and the base triangles */ + smInit_sm(sm,v->vp); /* Go through all samples and add in if in the new view frustum, and the dir is <= 30 degrees from new view */ - smInit_sm(sm,v->vp); for(i=0; i < cnt; i++) { /* First check if sample visible(conservative approx: if one of tris attached to sample is in frustum) */ if(!S_IS_FLAG(i)) continue; - - /* Next test if direction > 30 from current direction */ + + /* Next test if direction > 30 degrees from current direction */ if(SM_NTH_W_DIR(sm,i)!=-1) { VSUB(p,SM_NTH_WV(sm,i),v->vp); - normalize(p); decodedir(dir,SM_NTH_W_DIR(sm,i)); - d = 2. - 2.*DOT(dir,p); - if (d > MAXDIFF2) + d = DOT(dir,p); + if (d*d < MAXDIFF2*DOT(p,p)) continue; VCOPY(p,SM_NTH_WV(sm,i)); smAdd_samp(sm,NULL,dir,p,i); } else { + /* If the direction is > 45 degrees from current view direction: + throw out + */ VSUB(dir,SM_NTH_WV(sm,i),ov); + if(DOT(dir,v->vdir) < MAXDIR) + continue; + VADD(SM_NTH_WV(sm,i),dir,SM_VIEW_CENTER(sm)); smAdd_samp(sm,NULL,dir,NULL,i); } } -#if 0 - smNew_tri_cnt = SM_SAMPLE_TRIS(sm); -#endif - #ifdef DEBUG - fprintf(stderr,"smRebuild_mesh():done\n"); + fprintf(stderr,"smRebuild():done\n"); #endif } @@ -1960,85 +2435,33 @@ intersect_tri_set(t_set,orig,dir,pt) TRI *t; double d,d1; - optr = QT_SET_PTR(t_set); + optr = t_set; for(i = QT_SET_CNT(t_set); i > 0; i--) { t_id = QT_SET_NEXT_ELEM(optr); t = SM_NTH_TRI(smMesh,t_id); - if(!T_IS_VALID(t)) + if(!T_IS_VALID(t) || SM_IS_NTH_T_BASE(smMesh,t_id)|| + SM_IS_NTH_T_BG(smMesh,t_id)) continue; pid0 = T_NTH_V(t,0); pid1 = T_NTH_V(t,1); pid2 = T_NTH_V(t,2); - if(base = SM_IS_NTH_T_BASE(smMesh,t_id)) - if(SM_BASE_ID(smMesh,pid0) && SM_BASE_ID(smMesh,pid1) && - SM_BASE_ID(smMesh,pid2)) - continue; VCOPY(p0,SM_NTH_WV(smMesh,pid0)); VCOPY(p1,SM_NTH_WV(smMesh,pid1)); VCOPY(p2,SM_NTH_WV(smMesh,pid2)); if(ray_intersect_tri(orig,dir,p0,p1,p2,p)) { - if(!base) - { - d = DIST_SQ(p,p0); - d1 = DIST_SQ(p,p1); - if(d < d1) - { - d1 = DIST_SQ(p,p2); - id = (d1 < d)?pid2:pid0; - } - else - { - d = DIST_SQ(p,p2); - id = (d < d1)? pid2:pid1; - } - } + d = DIST_SQ(p,p0); + d1 = DIST_SQ(p,p1); + if(d < d1) + { + d1 = DIST_SQ(p,p2); + id = (d1 < d)?pid2:pid0; + } else { - if(SM_BASE_ID(smMesh,pid0)) - { - if(SM_BASE_ID(smMesh,pid1)) - id = pid2; - else - if(SM_BASE_ID(smMesh,pid2)) - id = pid1; - else - { - d = DIST_SQ(p,p1); - d1 = DIST_SQ(p,p2); - if(d < d1) - id = pid1; - else - id = pid2; - } - } - else - { - if(SM_BASE_ID(smMesh,pid1)) - { - if(SM_BASE_ID(smMesh,pid2)) - id = pid0; - else - { - d = DIST_SQ(p,p0); - d1 = DIST_SQ(p,p2); - if(d < d1) - id = pid0; - else - id = pid2; - } - } - else - { - d = DIST_SQ(p,p0); - d1 = DIST_SQ(p,p1); - if(d < d1) - id = pid0; - else - id = pid1; - } - } + d = DIST_SQ(p,p2); + id = (d < d1)? pid2:pid1; } if(pt) VCOPY(pt,p); @@ -2161,71 +2584,49 @@ FVECT orig,dir; /* orig will be updated-so preserve original value */ if(!smMesh) return; -#ifdef TEST_DRIVER - Picking= TRUE; -#endif if(EQUAL_VEC3(orig,SM_VIEW_CENTER(smMesh))) { - qt = smPointLocateCell(smMesh,dir); + qt = smPoint_locate_cell(smMesh,dir); if(QT_IS_EMPTY(qt)) goto Lerror; ts = qtqueryset(qt); s_id = intersect_tri_set(ts,orig,dir,p); -#ifdef DEBUG_TEST_DRIVER - VCOPY(Pick_point[0],p); -#endif -#ifdef DEBUG - fprintf(stderr,"Simple pick returning %d\n",s_id); -#endif - return(s_id); } d = point_on_sphere(b,orig,SM_VIEW_CENTER(smMesh)); if(EQUAL_VEC3(b,dir)) { - qt = smPointLocateCell(smMesh,dir); + qt = smPoint_locate_cell(smMesh,dir); if(QT_IS_EMPTY(qt)) goto Lerror; ts = qtqueryset(qt); s_id = intersect_tri_set(ts,orig,dir,p); -#ifdef DEBUG_TEST_DRIVER - VCOPY(Pick_point[0],p); -#endif -#ifdef DEBUG - fprintf(stderr,"Simple pick2 returning %d\n",s_id); -#endif - return(s_id); + return(s_id); } if(OPP_EQUAL_VEC3(b,dir)) { - qt = smPointLocateCell(smMesh,orig); + qt = smPoint_locate_cell(smMesh,orig); if(QT_IS_EMPTY(qt)) goto Lerror; ts = qtqueryset(qt); s_id = intersect_tri_set(ts,orig,dir,p); -#ifdef DEBUG_TEST_DRIVER - VCOPY(Pick_point[0],p); -#endif - if(s_id != INVALID) - { + if(s_id != INVALID) + { #ifdef DEBUG fprintf(stderr,"Front pick returning %d\n",s_id); #endif return(s_id); - } - qt = smPointLocateCell(smMesh,dir); - if(QT_IS_EMPTY(qt)) - goto Lerror; - ts = qtqueryset(qt); - s_id = intersect_tri_set(ts,orig,dir,p); -#ifdef DEBUG_TEST_DRIVER - VCOPY(Pick_point[0],p); -#endif + } + qt = smPoint_locate_cell(smMesh,dir); + if(QT_IS_EMPTY(qt)) + goto Lerror; + ts = qtqueryset(qt); + s_id = intersect_tri_set(ts,orig,dir,p); #ifdef DEBUG fprintf(stderr,"Back pick returning %d\n",s_id); #endif - return(s_id); + return(s_id); } { OBJECT t_set[QT_MAXCSET + 1]; @@ -2244,10 +2645,8 @@ FVECT orig,dir; F_ARGS(func) = (int *)(&rt); stTrace_ray(SM_LOCATOR(smMesh),o,dir,func); s_id = rt.t_id; + } -#ifdef DEBUG - fprintf(stderr,"Trace pick returning %d\n",s_id); -#endif return(s_id); Lerror: @@ -2258,14 +2657,23 @@ Lerror: } +null_func(argptr,root,qt,n) + int *argptr; + int root; + QUADTREE qt; + int n; +{ + /* do nothing */ +} -mark_active_tris(argptr,root,qt) +mark_active_samples(argptr,root,qt,n) int *argptr; int root; QUADTREE qt; + int n; { - OBJECT *os,*optr; - register int i,t_id; + OBJECT *os; + register int i,s_id,t_id,tri_id; TRI *tri; if(QT_IS_EMPTY(qt) || QT_LEAF_IS_FLAG(qt)) @@ -2274,51 +2682,57 @@ mark_active_tris(argptr,root,qt) /* For each triangle in the set, set the which flag*/ os = qtqueryset(qt); - for (i = QT_SET_CNT(os), optr = QT_SET_PTR(os); i > 0; i--) + for (i = QT_SET_CNT(os); i > 0; i--) { - t_id = QT_SET_NEXT_ELEM(optr); - /* Set the render flag */ - tri = SM_NTH_TRI(smMesh,t_id); - if(!T_IS_VALID(tri)) - continue; - SM_SET_NTH_T_ACTIVE(smMesh,t_id); - /* Set the Active bits of the Vertices */ - if(!SM_IS_NTH_T_BASE(smMesh,t_id)) + s_id = QT_SET_NEXT_ELEM(os); + S_SET_FLAG(s_id); + + tri_id = SM_NTH_VERT(smMesh,s_id); + /* Set the active flag for all adjacent triangles */ + tri = SM_NTH_TRI(smMesh,tri_id); + SM_SET_NTH_T_ACTIVE(smMesh,tri_id); + while((t_id = smTri_next_ccw_nbr(smMesh,tri,s_id)) != tri_id) { - S_SET_FLAG(T_NTH_V(tri,0)); - S_SET_FLAG(T_NTH_V(tri,1)); - S_SET_FLAG(T_NTH_V(tri,2)); + tri = SM_NTH_TRI(smMesh,t_id); + SM_SET_NTH_T_ACTIVE(smMesh,t_id); } } - } +} - -mark_tris_in_frustum(view) +smCull(sm,view,n) + SM *sm; VIEW *view; + int n; { FVECT nr[4],far[4]; FPEQ peq; int debug=0; FUNC f; - F_FUNC(f) = mark_active_tris; - F_ARGS(f) = NULL; + /* First clear all the quadtree node flags */ + qtClearAllFlags(); + F_ARGS(f) = NULL; + /* If marking samples down to leaves */ + if(n == SM_ALL_LEVELS) + { /* Mark triangles in approx. view frustum as being active:set LRU counter: for use in discarding samples when out of space + */ + F_FUNC(f) = mark_active_samples; + smClear_flags(sm,T_ACTIVE_FLAG); + /* Clear all of the active sample flags*/ + sClear_all_flags(SM_SAMP(sm)); + } + else + /* Just mark qtree flags */ + F_FUNC(f) = null_func; + + /* calculate the world space coordinates of the view frustum: Radiance often has no far clipping plane: but driver will set dev_zmin,dev_zmax to satisfy OGL - */ - - /* First clear all the quadtree node and triangle active flags */ - qtClearAllFlags(); - smClear_flags(smMesh,T_ACTIVE_FLAG); - /* Clear all of the active sample flags*/ - sClear_all_flags(SM_SAMP(smMesh)); - - - /* calculate the world space coordinates of the view frustum */ + */ calculate_view_frustum(view->vp,view->hvec,view->vvec,view->horiz, view->vert, dev_zmin,dev_zmax,nr,far); @@ -2339,83 +2753,93 @@ mark_tris_in_frustum(view) Also set the triangles LRU clock counter */ - if(EQUAL_VEC3(view->vp,SM_VIEW_CENTER(smMesh))) + if(EQUAL_VEC3(view->vp,SM_VIEW_CENTER(sm))) {/* Near face triangles */ - smLocator_apply(smMesh,nr[0],nr[2],nr[3],f); - smLocator_apply(smMesh,nr[2],nr[0],nr[1],f); + smLocator_apply(sm,nr[0],nr[2],nr[3],f,n); + smLocator_apply(sm,nr[2],nr[0],nr[1],f,n); return; } /* Test the view against the planes: and swap orientation if inside:*/ tri_plane_equation(nr[0],nr[2],nr[3], &peq,FALSE); - if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) + if(PT_ON_PLANE(SM_VIEW_CENTER(sm),peq) < 0.0) {/* Near face triangles */ - smLocator_apply(smMesh,nr[3],nr[2],nr[0],f); - smLocator_apply(smMesh,nr[1],nr[0],nr[2],f); + smLocator_apply(sm,nr[3],nr[2],nr[0],f,n); + smLocator_apply(sm,nr[1],nr[0],nr[2],f,n); } else {/* Near face triangles */ - smLocator_apply(smMesh,nr[0],nr[2],nr[3],f); - smLocator_apply(smMesh,nr[2],nr[0],nr[1],f); + smLocator_apply(sm,nr[0],nr[2],nr[3],f,n); + smLocator_apply(sm,nr[2],nr[0],nr[1],f,n); } tri_plane_equation(nr[0],far[3],far[0], &peq,FALSE); - if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) + if(PT_ON_PLANE(SM_VIEW_CENTER(sm),peq) < 0.0) { /* Right face triangles */ - smLocator_apply(smMesh,far[0],far[3],nr[0],f); - smLocator_apply(smMesh,nr[3],nr[0],far[3],f); + smLocator_apply(sm,far[0],far[3],nr[0],f,n); + smLocator_apply(sm,nr[3],nr[0],far[3],f,n); } else {/* Right face triangles */ - smLocator_apply(smMesh,nr[0],far[3],far[0],f); - smLocator_apply(smMesh,far[3],nr[0],nr[3],f); + smLocator_apply(sm,nr[0],far[3],far[0],f,n); + smLocator_apply(sm,far[3],nr[0],nr[3],f,n); } tri_plane_equation(nr[1],far[2],nr[2], &peq,FALSE); if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) { /* Left face triangles */ - smLocator_apply(smMesh,nr[2],far[2],nr[1],f); - smLocator_apply(smMesh,far[1],nr[1],far[2],f); + smLocator_apply(sm,nr[2],far[2],nr[1],f,n); + smLocator_apply(sm,far[1],nr[1],far[2],f,n); } else { /* Left face triangles */ - smLocator_apply(smMesh,nr[1],far[2],nr[2],f); - smLocator_apply(smMesh,far[2],nr[1],far[1],f); + smLocator_apply(sm,nr[1],far[2],nr[2],f,n); + smLocator_apply(sm,far[2],nr[1],far[1],f,n); } tri_plane_equation(nr[0],far[0],nr[1], &peq,FALSE); - if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) + if(PT_ON_PLANE(SM_VIEW_CENTER(sm),peq) < 0.0) {/* Top face triangles */ - smLocator_apply(smMesh,nr[1],far[0],nr[0],f); - smLocator_apply(smMesh,far[1],far[0],nr[1],f); + smLocator_apply(sm,nr[1],far[0],nr[0],f,n); + smLocator_apply(sm,far[1],far[0],nr[1],f,n); } else {/* Top face triangles */ - smLocator_apply(smMesh,nr[0],far[0],nr[1],f); - smLocator_apply(smMesh,nr[1],far[0],far[1],f); + smLocator_apply(sm,nr[0],far[0],nr[1],f,n); + smLocator_apply(sm,nr[1],far[0],far[1],f,n); } tri_plane_equation(nr[3],nr[2],far[3], &peq,FALSE); - if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) + if(PT_ON_PLANE(SM_VIEW_CENTER(sm),peq) < 0.0) {/* Bottom face triangles */ - smLocator_apply(smMesh,far[3],nr[2],nr[3],f); - smLocator_apply(smMesh,far[3],far[2],nr[2],f); + smLocator_apply(sm,far[3],nr[2],nr[3],f,n); + smLocator_apply(sm,far[3],far[2],nr[2],f,n); } else { /* Bottom face triangles */ - smLocator_apply(smMesh,nr[3],nr[2],far[3],f); - smLocator_apply(smMesh,nr[2],far[2],far[3],f); + smLocator_apply(sm,nr[3],nr[2],far[3],f,n); + smLocator_apply(sm,nr[2],far[2],far[3],f,n); } tri_plane_equation(far[2],far[0],far[1], &peq,FALSE); - if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) + if(PT_ON_PLANE(SM_VIEW_CENTER(sm),peq) < 0.0) {/* Far face triangles */ - smLocator_apply(smMesh,far[0],far[2],far[1],f); - smLocator_apply(smMesh,far[2],far[0],far[3],f); + smLocator_apply(sm,far[0],far[2],far[1],f,n); + smLocator_apply(sm,far[2],far[0],far[3],f,n); } else {/* Far face triangles */ - smLocator_apply(smMesh,far[1],far[2],far[0],f); - smLocator_apply(smMesh,far[3],far[0],far[2],f); + smLocator_apply(sm,far[1],far[2],far[0],f,n); + smLocator_apply(sm,far[3],far[0],far[2],f,n); } } + + + + + + + + + +
