--- ray/src/hd/sm.c 1998/12/30 13:44:15 3.11 +++ ray/src/hd/sm.c 1999/01/05 16:52:37 3.12 @@ -18,9 +18,13 @@ static char SCCSid[] = "$SunId$ SGI"; SM *smMesh = NULL; double smDist_sum=0; +#define S_INC 1000 int smNew_tri_cnt=0; -double smMinSampDiff = 4.25e-4; /* min edge length in radians */ +int smNew_tri_size=0; +T_DEPTH *smNew_tris= NULL; +#define SM_MIN_SAMP_DIFF 1e-3 /* min edge length in radians */ + /* Each edge extends .5536 radians - 31.72 degrees */ static FVECT icosa_verts[162] = {{-0.018096,0.495400,0.868477},{0.018614,-0.554780,0.831789}, @@ -696,23 +700,21 @@ int v0_id,v1_id,v2_id; SM_NTH_VERT(sm,v1_id) = t_id; SM_NTH_VERT(sm,v2_id) = t_id; + smClear_tri_flags(sm,t_id); if(SM_BASE_ID(sm,v0_id) || SM_BASE_ID(sm,v1_id) || SM_BASE_ID(sm,v2_id)) { - smClear_tri_flags(sm,t_id); SM_SET_NTH_T_BASE(sm,t_id); } else - { - SM_CLR_NTH_T_BASE(sm,t_id); - SM_SET_NTH_T_ACTIVE(sm,t_id); - SM_SET_NTH_T_NEW(sm,t_id); - S_SET_FLAG(T_NTH_V(t,0)); - S_SET_FLAG(T_NTH_V(t,1)); - S_SET_FLAG(T_NTH_V(t,2)); - SM_SAMPLE_TRIS(sm)++; - smNew_tri_cnt++; - } + { + S_SET_FLAG(T_NTH_V(t,0)); + S_SET_FLAG(T_NTH_V(t,1)); + S_SET_FLAG(T_NTH_V(t,2)); + } + SM_SET_NTH_T_ACTIVE(sm,t_id); + SM_SAMPLE_TRIS(sm)++; + /* return initialized triangle */ return(t_id); } @@ -813,16 +815,10 @@ smTris_swap_edge(sm,t_id,t1_id,e,e1,tn_id,tn1_id,add_p remove_from_list(t_id,add_ptr); remove_from_list(t1_id,add_ptr); -#if 1 + smDelete_tri(sm,t_id); smDelete_tri(sm,t1_id); -#else - *del_ptr = push_data(*del_ptr,t_id); - *del_ptr = push_data(*del_ptr,t1_id); -#endif - - *tn_id = ta_id; *tn1_id = tb_id; @@ -848,6 +844,19 @@ Ltri_error: error(CONSISTENCY,"Invalid tri: smTris_swap_edge()\n"); } +add_new_tri(id) +int id; +{ + if(smNew_tri_cnt == smNew_tri_size) + { + smNew_tri_size += S_INC; + smNew_tris=(T_DEPTH *)realloc(smNew_tris,sizeof(T_DEPTH)*smNew_tri_size); + if(!smNew_tris) + error(SYSTEM,"Out of memory in add_new_tris()\n"); + } + smNew_tris[smNew_tri_cnt++].tri = id; +} + smUpdate_locator(sm,add_list) SM *sm; LIST *add_list; @@ -855,6 +864,15 @@ LIST *add_list; int t_id,i; TRI *t; OBJECT *optr; + LIST *list; + + list = add_list; + while(list) + { + t_id = LIST_DATA(list); + add_new_tri(t_id); + list = LIST_NEXT(list); + } while(add_list) { @@ -874,7 +892,7 @@ LIST *tlist,*add_list; FVECT p,p0,p1,p2; int e,e1,swapped = 0; int t_id,t_opp_id; - LIST *del_list=NULL; + LIST *del_list=NULL,*lptr; VSUB(p,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm)); while(tlist) @@ -911,13 +929,7 @@ LIST *tlist,*add_list; tlist = push_data(tlist,t_opp_id); } } -#if 0 - while(del_list) - { - t_id = pop_list(&del_list); - smDelete_tri(sm,t_id); - } -#endif + smUpdate_locator(sm,add_list); return(swapped); @@ -969,7 +981,10 @@ smInsert_samp(sm,s_id,tri_id,on,which) FVECT npt; TRI *tri,*nbr,*topp; - + if(tri_id==18611 && s_id == 2243) + sleep(1); + if(s_id == 2649 && tri_id == 13302) + sleep(1); add_list = NULL; for(i=0; i<3;i++) v_id[i] = T_NTH_V(SM_NTH_TRI(sm,tri_id),i); @@ -1228,12 +1243,6 @@ int *onptr,*whichptr; optr = qtqueryset(qt); tri_id = smTri_in_set(sm,tpt,optr,onptr,whichptr); -#ifdef DEBUG - if(!T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,tri_id),0))) || - !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,tri_id),1))) || - !T_IS_VALID(SM_NTH_TRI(sm,T_NTH_NBR(SM_NTH_TRI(sm,tri_id),2)))) - eputs("Invalid tri nbrs smPointLocateTri()\n"); -#endif return(tri_id); } @@ -1287,29 +1296,22 @@ smTest_sample(sm,tri_id,dir,p,rptr) for(i=0; i<3; i++) { - if(SM_BASE_ID(sm,vid[i])) - { - bcnt++; - continue; - } - if(SM_DIR_ID(sm,vid[i])) - dcnt++; - VSUB(diff[i],SM_NTH_WV(sm,vid[i]),p); - /* If same world point: replace */ + if(SM_BASE_ID(sm,vid[i])) + bcnt++; + if(SM_DIR_ID(sm,vid[i])) + dcnt++; + } /* TEST 1: If the new sample is close in ws, and close in the spherical projection to one of the triangle vertex samples */ +#if 0 norm = FALSE; - if(bcnt + dcnt != 3) - { VSUB(spt,p,SM_VIEW_CENTER(sm)); ds = DOT(spt,spt); dnear = FHUGE; for(i=0; i<3; i++) { - if(SM_BASE_ID(sm,vid[i]) || SM_DIR_ID(sm,vid[i])) - continue; d = DOT(diff[i],diff[i])/ds; if(d < dnear) { @@ -1318,11 +1320,23 @@ smTest_sample(sm,tri_id,dir,p,rptr) } } - if(dnear <= smMinSampDiff*smMinSampDiff) + if(dnear <= SM_MIN_SAMP_DIFF*SM_MIN_SAMP_DIFF) { /* Pick the point with dir closest to that of the canonical view if it is the new sample: mark existing point for deletion */ + if(SM_BASE_ID(sm,nearid)) + { + *rptr = nearid; + return(TRUE); + } + if(SM_DIR_ID(sm,nearid)) + return(FALSE); + if(!dir) + { + *rptr = nearid; + return(TRUE); + } normalize(spt); norm = TRUE; VSUB(npt,SM_NTH_WV(sm,nearid),SM_VIEW_CENTER(sm)); @@ -1330,27 +1344,26 @@ smTest_sample(sm,tri_id,dir,p,rptr) d = fdir2diff(SM_NTH_W_DIR(sm,nearid), npt); d2 = 2. - 2.*DOT(dir,spt); /* The existing sample is a better sample:punt */ - if(d2 > d) + if(d2 > d) return(FALSE); - else - { - /* The new sample is better: mark the existing one + else + { + /* The new sample is better: mark the existing one for deletion after the new one is added*/ - *rptr = nearid; - return(TRUE); - } + *rptr = nearid; + return(TRUE); } - } + } + /* TEST 3: If the spherical projection of new is < S_REPLACE_EPS from a base point: Edge length is constrained to subtend <45 degrees: original base mesh edges are approx 32 degrees- so have about 13 degrees to work in: S_REPLACE_EPS is the square of the radian value */ + if(bcnt) { dnear = FHUGE; - if(bcnt + dcnt ==3) - VSUB(spt,p,SM_VIEW_CENTER(sm)); if(!norm) normalize(spt); @@ -1360,7 +1373,7 @@ smTest_sample(sm,tri_id,dir,p,rptr) continue; VSUB(npt,SM_NTH_WV(sm,vid[i]),SM_VIEW_CENTER(sm)); d = DIST_SQ(npt,spt); - if(d < S_REPLACE_EPS && d < dnear) + if(dnear <= SM_MIN_SAMP_DIFF*SM_MIN_SAMP_DIFF && d< near) { dnear = d; nearid = vid[i]; @@ -1373,22 +1386,81 @@ smTest_sample(sm,tri_id,dir,p,rptr) return(TRUE); } } +#else + { + FVECT nearpt; + dnear = FHUGE; + VSUB(spt,p,SM_VIEW_CENTER(sm)); + ds = DOT(spt,spt); + normalize(spt); + + for(i=0; i<3; i++) + { + VSUB(npt,SM_NTH_WV(sm,vid[i]),SM_VIEW_CENTER(sm)); + + if(!SM_BASE_ID(sm,vid[i]) || !SM_DIR_ID(sm,vid[i])) + normalize(npt); + + d = DIST_SQ(npt,spt); + if(d < SM_MIN_SAMP_DIFF*SM_MIN_SAMP_DIFF && d < dnear) + { + dnear = d; + nearid = vid[i]; + VCOPY(nearpt,npt); + } + + } + if(dnear != FHUGE) + { + /* Pick the point with dir closest to that of the canonical view + if it is the new sample: mark existing point for deletion + */ + if(SM_BASE_ID(sm,nearid)) + { + *rptr = nearid; + return(TRUE); + } + if(SM_DIR_ID(sm,nearid)) + return(FALSE); + if(!dir) + { + *rptr = nearid; + return(TRUE); + } + d = fdir2diff(SM_NTH_W_DIR(sm,nearid), nearpt); + d2 = 2. - 2.*DOT(dir,spt); + /* The existing sample is a better sample:punt */ + if(d2 > d) + return(FALSE); + else + { + /* The new sample is better: mark the existing one + for deletion after the new one is added*/ + *rptr = nearid; + return(TRUE); + } + } + } +#endif /* TEST 4: If the addition of the new sample point would introduce a "puncture" or cause new triangles with large depth differences:dont add: */ if(bcnt || dcnt) return(TRUE); + /* If the new point is in front of the existing points- add */ dv = DIST_SQ(SM_NTH_WV(sm,vid[0]),SM_VIEW_CENTER(sm)); if(ds < dv) return(TRUE); d01 = DIST_SQ(SM_NTH_WV(sm,vid[1]),SM_NTH_WV(sm,vid[0])); + VSUB(diff[0],SM_NTH_WV(sm,vid[0]),p); s0 = DOT(diff[0],diff[0]); if(s0 < S_REPLACE_SCALE*d01) return(TRUE); + d12 = DIST_SQ(SM_NTH_WV(sm,vid[2]),SM_NTH_WV(sm,vid[1])); if(s0 < S_REPLACE_SCALE*d12) return(TRUE); @@ -1396,9 +1468,11 @@ smTest_sample(sm,tri_id,dir,p,rptr) if(s0 < S_REPLACE_SCALE*d20) return(TRUE); d = MIN3(d01,d12,d20); - s1 = DOT(diff[1],diff[1]); + VSUB(diff[1],SM_NTH_WV(sm,vid[1]),p); + s1 = DOT(diff[1],diff[1]); if(s1 < S_REPLACE_SCALE*d) return(TRUE); + VSUB(diff[2],SM_NTH_WV(sm,vid[2]),p); s2 = DOT(diff[2],diff[2]); if(s2 < S_REPLACE_SCALE*d) return(TRUE); @@ -1417,37 +1491,13 @@ smTest_sample(sm,tri_id,dir,p,rptr) int -smAlloc_samp(sm) -SM *sm; -{ - int s_id,replaced,cnt; - SAMP *s; - FVECT p; - - s = SM_SAMP(sm); - s_id = sAlloc_samp(s,&replaced); - - cnt=0; - while(replaced) - { - if(smRemoveVertex(sm,s_id)) - break; - s_id = sAlloc_samp(s,&replaced); - cnt++; - if(cnt > S_MAX_SAMP(s)) - error(CONSISTENCY,"smAlloc_samp():unable to find free samp\n"); - } - return(s_id); -} - -int smReplace_samp(sm,c,dir,p,s_id,t_id,o_id,on,which) SM *sm; COLR c; FVECT dir,p; int s_id,t_id,o_id,on,which; { - int tonemap,v_id; + int tonemap,v_id,tri_id; TRI *t,*tri; tri = SM_NTH_TRI(sm,t_id); @@ -1462,7 +1512,11 @@ smReplace_samp(sm,c,dir,p,s_id,t_id,o_id,on,which) T_NTH_V(tri,which) = s_id; if(!(SM_BASE_ID(sm,T_NTH_V(tri,(which+1)%3)) || SM_BASE_ID(sm,T_NTH_V(tri,(which+2)%3)))) + { SM_CLR_NTH_T_BASE(sm,t_id); + + } + add_new_tri(t_id); t_id = smTri_next_ccw_nbr(sm,tri,v_id); while(t_id != INVALID) { @@ -1472,42 +1526,97 @@ smReplace_samp(sm,c,dir,p,s_id,t_id,o_id,on,which) /* Check if still a base triangle */ if(!(SM_BASE_ID(sm,T_NTH_V(t,(which+1)%3)) || SM_BASE_ID(sm,T_NTH_V(t,(which+2)%3)))) - SM_CLR_NTH_T_BASE(sm,t_id); + { + SM_CLR_NTH_T_BASE(sm,t_id); + } + add_new_tri(t_id); t_id = smTri_next_ccw_nbr(sm,t,v_id); } return(s_id); } - else - if(on == ON_V || !p) + if(dir) + { + /* If world point */ + /* if existing point is a dir: leave */ + if(SM_DIR_ID(sm,v_id)) + return(INVALID); + if(on == ON_V) { tonemap = (SM_TONE_MAP(sm) > v_id); sInit_samp(SM_SAMP(sm),v_id,c,dir,p,o_id,tonemap); + add_new_tri(t_id); + tri_id = smTri_next_ccw_nbr(sm,tri,v_id); + while(tri_id != t_id) + { + t = SM_NTH_TRI(sm,tri_id); + add_new_tri(tri_id); + tri_id = smTri_next_ccw_nbr(sm,t,v_id); + } return(v_id); } - else /* on == ON_P */ - { - FVECT spt,npt; - double d,d2; + /* on == ON_P */ + else + { + FVECT spt,npt; + double d,d2; - /* Need to check which sample is preferable */ - VSUB(spt,p,SM_VIEW_CENTER(sm)); - normalize(spt); + /* Need to check which sample is preferable */ + VSUB(spt,p,SM_VIEW_CENTER(sm)); + normalize(spt); - VSUB(npt,SM_NTH_WV(sm,v_id),SM_VIEW_CENTER(sm)); - normalize(npt); - d = fdir2diff(SM_NTH_W_DIR(sm,v_id), npt); - d2 = 2. - 2.*DOT(dir,spt); + VSUB(npt,SM_NTH_WV(sm,v_id),SM_VIEW_CENTER(sm)); + normalize(npt); + d = fdir2diff(SM_NTH_W_DIR(sm,v_id), npt); + d2 = 2. - 2.*DOT(dir,spt); /* The existing sample is a better sample:punt */ - if(d2 < d) - { - /* The new sample has better information- replace values */ - tonemap = (SM_TONE_MAP(sm) > v_id); - sInit_samp(SM_SAMP(sm),v_id,c,dir,p,o_id,tonemap); - } - return(v_id); + if(d2 < d) + { + /* The new sample has better information- replace values */ + tonemap = (SM_TONE_MAP(sm) > v_id); + sInit_samp(SM_SAMP(sm),v_id,c,dir,p,o_id,tonemap); + add_new_tri(t_id); + tri_id = smTri_next_ccw_nbr(sm,tri,v_id); + while(tri_id != t_id) + { + t = SM_NTH_TRI(sm,tri_id); + add_new_tri(tri_id); + tri_id = smTri_next_ccw_nbr(sm,t,v_id); + } + } + return(v_id); + } + } + else + { /* New point is a dir */ + return(INVALID); } } +int +smAlloc_samp(sm) +SM *sm; +{ + int s_id,replaced,cnt; + SAMP *s; + FVECT p; + + s = SM_SAMP(sm); + s_id = sAlloc_samp(s,&replaced); + + cnt=0; + while(replaced) + { + if(smRemoveVertex(sm,s_id)) + break; + s_id = sAlloc_samp(s,&replaced); + cnt++; + if(cnt > S_MAX_SAMP(s)) + error(CONSISTENCY,"smAlloc_samp():unable to find free samp\n"); + } + return(s_id); +} + + /* Add sample to the mesh: the sample can be a world space or directional point. If o_id !=INVALID, @@ -1536,30 +1645,42 @@ smAdd_samp(sm,c,dir,p,o_id) /* Must do this first-as may change mesh */ s_id = smAlloc_samp(sm); + if(s_id== 2649) + r_id = INVALID; /* If sample is a world space point */ if(p) { - t_id = smPointLocateTri(sm,p,&on,&which); - if(t_id == INVALID) + while(1) + { + t_id = smPointLocateTri(sm,p,&on,&which); + if(t_id == INVALID) { #ifdef DEBUG - eputs("smAddSamp(): unable to locate tri containing sample \n"); + eputs("smAddSamp(): unable to locate tri containing sample \n"); #endif + smUnalloc_samp(sm,s_id); + return(INVALID); + } + /* If spherical projection coincides with existing sample: replace */ + if((on == ON_V || on == ON_P)) + { + if((n_id = smReplace_samp(sm,c,dir,p,s_id,t_id,o_id,on,which))!= s_id) + smUnalloc_samp(sm,s_id); + return(n_id); + } + if((!(smTest_sample(sm,t_id,dir,p,&r_id)))) + { smUnalloc_samp(sm,s_id); return(INVALID); } - /* If spherical projection coincides with existing sample: replace */ - if((on == ON_V || on == ON_P)) - { - if((n_id = smReplace_samp(sm,c,dir,p,s_id,t_id,o_id,on,which))!= s_id) - smUnalloc_samp(sm,s_id); - return(n_id); + if(r_id != INVALID) + { + smRemoveVertex(sm,r_id); + sDelete_samp(SM_SAMP(sm),r_id); + } + else + break; } - if((!(smTest_sample(sm,t_id,dir,p,&r_id)))) - { - smUnalloc_samp(sm,s_id); - return(INVALID); - } /* If sample is being added in the middle of the sample array: tone map individually */ @@ -1571,8 +1692,11 @@ smAdd_samp(sm,c,dir,p,o_id) else { VADD(wpt,dir,SM_VIEW_CENTER(sm)); - t_id = smPointLocateTri(sm,wpt,&on,&which); - if(t_id == INVALID) + while(1) + { if(s_id == 2299) + t_id = INVALID; + t_id = smPointLocateTri(sm,wpt,&on,&which); + if(t_id == INVALID) { #ifdef DEBUG eputs("smAddSamp(): unable to locate tri containing sample \n"); @@ -1580,14 +1704,28 @@ smAdd_samp(sm,c,dir,p,o_id) smUnalloc_samp(sm,s_id); return(INVALID); } - if(on == ON_V || on == ON_P) - { - if((n_id = smReplace_samp(sm,c,wpt,NULL,s_id,t_id,o_id,on,which))!= s_id) + if(on == ON_V || on == ON_P) + { + if((n_id=smReplace_samp(sm,c,NULL,wpt,s_id,t_id,o_id,on,which))!=s_id) + smUnalloc_samp(sm,s_id); + return(n_id); + } + if((!(smTest_sample(sm,t_id,NULL,wpt,&r_id)))) + { smUnalloc_samp(sm,s_id); - return(n_id); - } + return(INVALID); + } + + if(r_id != INVALID) + { + smRemoveVertex(sm,r_id); + sDelete_samp(SM_SAMP(sm),r_id); + } + else + break; + } /* Allocate space for a sample and initialize */ - sInit_samp(SM_SAMP(sm),s_id,c,wpt,NULL,o_id,(SM_TONE_MAP(sm)>s_id)); + sInit_samp(SM_SAMP(sm),s_id,c,NULL,wpt,o_id,(SM_TONE_MAP(sm)>s_id)); } if(!SM_DIR_ID(sm,s_id)) { @@ -1598,12 +1736,6 @@ smAdd_samp(sm,c,dir,p,o_id) } smInsert_samp(sm,s_id,t_id,on,which); - /* If new sample replaces existing one- remove that vertex now */ - if(r_id != INVALID) - { - smRemoveVertex(sm,r_id); - sDelete_samp(SM_SAMP(sm),r_id); - } return(s_id); } @@ -1626,9 +1758,7 @@ FVECT p; { int s_id; - /* First check if this the first sample: if so initialize mesh */ - if(SM_NUM_SAMP(smMesh) == 0) { smInit_sm(smMesh,odev.v.vp); @@ -1809,8 +1939,10 @@ smRebuild_mesh(sm,v) } } - +#if 0 smNew_tri_cnt = SM_SAMPLE_TRIS(sm); +#endif + #ifdef DEBUG fprintf(stderr,"smRebuild_mesh():done\n"); #endif @@ -2147,14 +2279,17 @@ mark_active_tris(argptr,root,qt) t_id = QT_SET_NEXT_ELEM(optr); /* Set the render flag */ tri = SM_NTH_TRI(smMesh,t_id); - if(!T_IS_VALID(tri) || SM_IS_NTH_T_BASE(smMesh,t_id)) + if(!T_IS_VALID(tri)) continue; SM_SET_NTH_T_ACTIVE(smMesh,t_id); /* Set the Active bits of the Vertices */ - S_SET_FLAG(T_NTH_V(tri,0)); - S_SET_FLAG(T_NTH_V(tri,1)); - S_SET_FLAG(T_NTH_V(tri,2)); - } + if(!SM_IS_NTH_T_BASE(smMesh,t_id)) + { + S_SET_FLAG(T_NTH_V(tri,0)); + S_SET_FLAG(T_NTH_V(tri,1)); + S_SET_FLAG(T_NTH_V(tri,2)); + } + } }
