--- ray/src/hd/sm.c 1998/08/19 17:45:23 3.1 +++ ray/src/hd/sm.c 1998/08/20 16:47:21 3.2 @@ -731,9 +731,9 @@ char norm; } QUADTREE -smPointLocateCell(sm,pt,v0,v1,v2,type,which,norm) +smPointLocateCell(sm,pt,type,which,norm) SM *sm; -FVECT pt,v0,v1,v2; +FVECT pt; char *type,*which; char norm; { @@ -746,10 +746,10 @@ char norm; { point_on_sphere(npt,pt,SM_VIEW_CENTER(sm)); - qt = stPoint_locate_cell(st,npt,v0,v1,v2,type,which); + qt = stPoint_locate_cell(st,npt,type,which); } else - qt = stPoint_locate_cell(st,pt,v0,v1,v2,type,which); + qt = stPoint_locate_cell(st,pt,type,which); return(qt); } @@ -1184,7 +1184,7 @@ FVECT orig,dir; d = -DOT(b,dir); if(EQUAL_VEC3(orig,SM_VIEW_CENTER(smMesh)) || EQUAL(fabs(d),1.0)) { - qt = smPointLocateCell(smMesh,dir,v0,v1,v2,NULL,NULL,FALSE); + qt = smPointLocateCell(smMesh,dir,NULL,NULL,FALSE); /* Test triangles in the set for intersection with Ray:returns first found */ @@ -1199,7 +1199,7 @@ FVECT orig,dir; { /* Starting with orig, Walk along projection of ray onto sphere */ point_on_sphere(r,orig,SM_VIEW_CENTER(smMesh)); - qt = smPointLocateCell(smMesh,r,v0,v1,v2,NULL,NULL,FALSE); + qt = smPointLocateCell(smMesh,r,NULL,NULL,FALSE); qtgetset(t_set,qt); /* os will contain all triangles seen thus far */ setcopy(os,t_set); @@ -1219,7 +1219,7 @@ FVECT orig,dir; return(s_id); /* Find next cell that projection of ray intersects */ smTraceRay(smMesh,r,dir,v0,v1,v2,r); - qt = smPointLocateCell(smMesh,r,v0,v1,v2,NULL,NULL,FALSE); + qt = smPointLocateCell(smMesh,r,NULL,NULL,FALSE); qtgetset(t_set,qt); /* Check triangles in set against those seen so far(os):only check new triangles for intersection (t_set')
