--- ray/src/hd/sm.c 1999/01/05 16:52:37 3.12 +++ ray/src/hd/sm.c 1999/03/05 16:33:17 3.14 @@ -21,9 +21,8 @@ double smDist_sum=0; #define S_INC 1000 int smNew_tri_cnt=0; int smNew_tri_size=0; -T_DEPTH *smNew_tris= NULL; -#define SM_MIN_SAMP_DIFF 1e-3 /* min edge length in radians */ +#define SM_MIN_SAMP_DIFF 1e-4/* min edge length in radians */ /* Each edge extends .5536 radians - 31.72 degrees */ static FVECT icosa_verts[162] = @@ -243,16 +242,6 @@ smDir(sm,ps,id) normalize(ps); } -smDir_in_cone(sm,ps,id) - SM *sm; - FVECT ps; - int id; -{ - - VSUB(ps,SM_NTH_WV(sm,id),SM_VIEW_CENTER(sm)); - normalize(ps); -} - smClear_flags(sm,which) SM *sm; int which; @@ -449,7 +438,7 @@ smAlloc(max_samples) total_points = n + SM_EXTRA_POINTS; - max_tris = total_points*4; + max_tris = total_points*2; /* Now allocate space for mesh vertices and triangles */ max_tris = smAlloc_mesh(smMesh, total_points, max_tris); @@ -492,7 +481,6 @@ smInit(n) { int max_vertices; - /* If n <=0, Just clear the existing structures */ if(n <= 0) { @@ -521,10 +509,11 @@ smInit(n) } -smLocator_apply(sm,v0,v1,v2,func) +smLocator_apply(sm,v0,v1,v2,func,n) SM *sm; FVECT v0,v1,v2; FUNC func; + int n; { STREE *st; FVECT tri[3]; @@ -534,12 +523,10 @@ smLocator_apply(sm,v0,v1,v2,func) VSUB(tri[0],v0,SM_VIEW_CENTER(sm)); VSUB(tri[1],v1,SM_VIEW_CENTER(sm)); VSUB(tri[2],v2,SM_VIEW_CENTER(sm)); - stVisit(st,tri,func); + stVisit(st,tri,func,n); } - -/* NEW INSERTION!!! ******************************************************/ QUADTREE insert_tri(argptr,root,qt,q0,q1,q2,t0,t1,t2,dt10,dt21,dt02,scale, s0,s1,s2,sq0,sq1,sq2,rev,f,n) @@ -700,20 +687,21 @@ int v0_id,v1_id,v2_id; SM_NTH_VERT(sm,v1_id) = t_id; SM_NTH_VERT(sm,v2_id) = t_id; - smClear_tri_flags(sm,t_id); if(SM_BASE_ID(sm,v0_id) || SM_BASE_ID(sm,v1_id) || SM_BASE_ID(sm,v2_id)) - { SM_SET_NTH_T_BASE(sm,t_id); - } - else - { - S_SET_FLAG(T_NTH_V(t,0)); - S_SET_FLAG(T_NTH_V(t,1)); - S_SET_FLAG(T_NTH_V(t,2)); - } + + if(SM_DIR_ID(sm,v0_id) || SM_DIR_ID(sm,v1_id) || SM_DIR_ID(sm,v2_id)) + SM_SET_NTH_T_BG(sm,t_id); + + S_SET_FLAG(T_NTH_V(t,0)); + S_SET_FLAG(T_NTH_V(t,1)); + S_SET_FLAG(T_NTH_V(t,2)); + SM_SET_NTH_T_ACTIVE(sm,t_id); + SM_SET_NTH_T_NEW(sm,t_id); SM_SAMPLE_TRIS(sm)++; + smNew_tri_cnt++; /* return initialized triangle */ return(t_id); @@ -844,35 +832,12 @@ Ltri_error: error(CONSISTENCY,"Invalid tri: smTris_swap_edge()\n"); } -add_new_tri(id) -int id; -{ - if(smNew_tri_cnt == smNew_tri_size) - { - smNew_tri_size += S_INC; - smNew_tris=(T_DEPTH *)realloc(smNew_tris,sizeof(T_DEPTH)*smNew_tri_size); - if(!smNew_tris) - error(SYSTEM,"Out of memory in add_new_tris()\n"); - } - smNew_tris[smNew_tri_cnt++].tri = id; -} - smUpdate_locator(sm,add_list) SM *sm; LIST *add_list; { - int t_id,i; + int t_id; TRI *t; - OBJECT *optr; - LIST *list; - - list = add_list; - while(list) - { - t_id = LIST_DATA(list); - add_new_tri(t_id); - list = LIST_NEXT(list); - } while(add_list) { @@ -914,9 +879,9 @@ LIST *tlist,*add_list; if(!T_IS_VALID(t_opp)) error(CONSISTENCY,"Invalid trismFix_tris()\n"); #endif - smDir_in_cone(sm,p0,T_NTH_V(t_opp,0)); - smDir_in_cone(sm,p1,T_NTH_V(t_opp,1)); - smDir_in_cone(sm,p2,T_NTH_V(t_opp,2)); + smDir(sm,p0,T_NTH_V(t_opp,0)); + smDir(sm,p1,T_NTH_V(t_opp,1)); + smDir(sm,p2,T_NTH_V(t_opp,2)); if(point_in_cone(p,p0,p1,p2)) { swapped = 1; @@ -981,10 +946,6 @@ smInsert_samp(sm,s_id,tri_id,on,which) FVECT npt; TRI *tri,*nbr,*topp; - if(tri_id==18611 && s_id == 2243) - sleep(1); - if(s_id == 2649 && tri_id == 13302) - sleep(1); add_list = NULL; for(i=0; i<3;i++) v_id[i] = T_NTH_V(SM_NTH_TRI(sm,tri_id),i); @@ -1399,7 +1360,7 @@ smTest_sample(sm,tri_id,dir,p,rptr) VSUB(npt,SM_NTH_WV(sm,vid[i]),SM_VIEW_CENTER(sm)); - if(!SM_BASE_ID(sm,vid[i]) || !SM_DIR_ID(sm,vid[i])) + if(!SM_BASE_ID(sm,vid[i]) && !SM_DIR_ID(sm,vid[i])) normalize(npt); d = DIST_SQ(npt,spt); @@ -1489,7 +1450,43 @@ smTest_sample(sm,tri_id,dir,p,rptr) return(FALSE); } +smReplace_base_samp(sm,b_id,s_id,tri,t_id,which) +SM *sm; +int b_id,s_id; +TRI *tri; +int t_id,which; +{ + TRI *t; + SM_NTH_VERT(sm,s_id) = t_id; + T_NTH_V(tri,which) = s_id; + if(!(SM_BASE_ID(sm,T_NTH_V(tri,(which+1)%3)) || + SM_BASE_ID(sm,T_NTH_V(tri,(which+2)%3)))) + SM_CLR_NTH_T_BASE(sm,t_id); + if(!SM_IS_NTH_T_NEW(sm,t_id)) + { + smNew_tri_cnt++; + SM_SET_NTH_T_NEW(sm,t_id); + } + t_id = smTri_next_ccw_nbr(sm,tri,b_id); + while(t_id != INVALID) + { + t = SM_NTH_TRI(sm,t_id); + which = T_WHICH_V(t,b_id); + T_NTH_V(t,which) = s_id; + /* Check if still a base triangle */ + if(!(SM_BASE_ID(sm,T_NTH_V(t,(which+1)%3)) || + SM_BASE_ID(sm,T_NTH_V(t,(which+2)%3)))) + SM_CLR_NTH_T_BASE(sm,t_id); + if(!SM_IS_NTH_T_NEW(sm,t_id)) + { + smNew_tri_cnt++; + SM_SET_NTH_T_NEW(sm,t_id); + } + t_id = smTri_next_ccw_nbr(sm,t,b_id); + } +} + int smReplace_samp(sm,c,dir,p,s_id,t_id,o_id,on,which) SM *sm; @@ -1497,7 +1494,7 @@ smReplace_samp(sm,c,dir,p,s_id,t_id,o_id,on,which) FVECT dir,p; int s_id,t_id,o_id,on,which; { - int tonemap,v_id,tri_id; + int v_id,tri_id; TRI *t,*tri; tri = SM_NTH_TRI(sm,t_id); @@ -1506,32 +1503,8 @@ smReplace_samp(sm,c,dir,p,s_id,t_id,o_id,on,which) /* If it is a base id, need new sample */ if(SM_BASE_ID(sm,v_id)) { - tonemap = (SM_TONE_MAP(sm) > s_id); - sInit_samp(SM_SAMP(sm),s_id,c,dir,p,o_id,tonemap); - SM_NTH_VERT(sm,s_id) = t_id; - T_NTH_V(tri,which) = s_id; - if(!(SM_BASE_ID(sm,T_NTH_V(tri,(which+1)%3)) || - SM_BASE_ID(sm,T_NTH_V(tri,(which+2)%3)))) - { - SM_CLR_NTH_T_BASE(sm,t_id); - - } - add_new_tri(t_id); - t_id = smTri_next_ccw_nbr(sm,tri,v_id); - while(t_id != INVALID) - { - t = SM_NTH_TRI(sm,t_id); - which = T_WHICH_V(t,v_id); - T_NTH_V(t,which) = s_id; - /* Check if still a base triangle */ - if(!(SM_BASE_ID(sm,T_NTH_V(t,(which+1)%3)) || - SM_BASE_ID(sm,T_NTH_V(t,(which+2)%3)))) - { - SM_CLR_NTH_T_BASE(sm,t_id); - } - add_new_tri(t_id); - t_id = smTri_next_ccw_nbr(sm,t,v_id); - } + sInit_samp(SM_SAMP(sm),s_id,c,dir,p,o_id); + smReplace_base_samp(sm,v_id,s_id,tri,t_id,which); return(s_id); } if(dir) @@ -1542,14 +1515,23 @@ smReplace_samp(sm,c,dir,p,s_id,t_id,o_id,on,which) return(INVALID); if(on == ON_V) { - tonemap = (SM_TONE_MAP(sm) > v_id); - sInit_samp(SM_SAMP(sm),v_id,c,dir,p,o_id,tonemap); - add_new_tri(t_id); + sInit_samp(SM_SAMP(sm),v_id,c,dir,p,o_id); + + if(!SM_IS_NTH_T_NEW(sm,t_id)) + { + smNew_tri_cnt++; + SM_SET_NTH_T_NEW(sm,t_id); + } tri_id = smTri_next_ccw_nbr(sm,tri,v_id); while(tri_id != t_id) { t = SM_NTH_TRI(sm,tri_id); - add_new_tri(tri_id); + if(!SM_IS_NTH_T_NEW(sm,tri_id)) + { + smNew_tri_cnt++; + SM_SET_NTH_T_NEW(sm,tri_id); + } + tri_id = smTri_next_ccw_nbr(sm,t,v_id); } return(v_id); @@ -1572,14 +1554,22 @@ smReplace_samp(sm,c,dir,p,s_id,t_id,o_id,on,which) if(d2 < d) { /* The new sample has better information- replace values */ - tonemap = (SM_TONE_MAP(sm) > v_id); - sInit_samp(SM_SAMP(sm),v_id,c,dir,p,o_id,tonemap); - add_new_tri(t_id); + sInit_samp(SM_SAMP(sm),v_id,c,dir,p,o_id); + if(!SM_IS_NTH_T_NEW(sm,t_id)) + { + smNew_tri_cnt++; + SM_SET_NTH_T_NEW(sm,t_id); + } + tri_id = smTri_next_ccw_nbr(sm,tri,v_id); while(tri_id != t_id) { t = SM_NTH_TRI(sm,tri_id); - add_new_tri(tri_id); + if(!SM_IS_NTH_T_NEW(sm,tri_id)) + { + smNew_tri_cnt++; + SM_SET_NTH_T_NEW(sm,tri_id); + } tri_id = smTri_next_ccw_nbr(sm,t,v_id); } } @@ -1645,8 +1635,6 @@ smAdd_samp(sm,c,dir,p,o_id) /* Must do this first-as may change mesh */ s_id = smAlloc_samp(sm); - if(s_id== 2649) - r_id = INVALID; /* If sample is a world space point */ if(p) { @@ -1664,9 +1652,10 @@ smAdd_samp(sm,c,dir,p,o_id) /* If spherical projection coincides with existing sample: replace */ if((on == ON_V || on == ON_P)) { - if((n_id = smReplace_samp(sm,c,dir,p,s_id,t_id,o_id,on,which))!= s_id) - smUnalloc_samp(sm,s_id); - return(n_id); + n_id = smReplace_samp(sm,c,dir,p,s_id,t_id,o_id,on,which); + if(n_id!= s_id) + smUnalloc_samp(sm,s_id); + return(n_id); } if((!(smTest_sample(sm,t_id,dir,p,&r_id)))) { @@ -1685,7 +1674,7 @@ smAdd_samp(sm,c,dir,p,o_id) map individually */ /* Initialize sample */ - sInit_samp(SM_SAMP(sm),s_id,c,dir,p,o_id,(SM_TONE_MAP(sm)>s_id)); + sInit_samp(SM_SAMP(sm),s_id,c,dir,p,o_id); } /* If sample is a direction vector */ @@ -1693,39 +1682,38 @@ smAdd_samp(sm,c,dir,p,o_id) { VADD(wpt,dir,SM_VIEW_CENTER(sm)); while(1) - { if(s_id == 2299) - t_id = INVALID; - t_id = smPointLocateTri(sm,wpt,&on,&which); - if(t_id == INVALID) - { + { + t_id = smPointLocateTri(sm,wpt,&on,&which); + if(t_id == INVALID) + { #ifdef DEBUG - eputs("smAddSamp(): unable to locate tri containing sample \n"); + eputs("smAddSamp(): can'tlocate tri containing samp\n"); #endif - smUnalloc_samp(sm,s_id); - return(INVALID); + smUnalloc_samp(sm,s_id); + return(INVALID); + } + if(on == ON_V || on == ON_P) + { + n_id=smReplace_samp(sm,c,NULL,wpt,s_id,t_id,o_id,on,which); + if(n_id !=s_id) + smUnalloc_samp(sm,s_id); + return(n_id); + } + if((!(smTest_sample(sm,t_id,NULL,wpt,&r_id)))) + { + smUnalloc_samp(sm,s_id); + return(INVALID); + } + if(r_id != INVALID) + { + smRemoveVertex(sm,r_id); + sDelete_samp(SM_SAMP(sm),r_id); + } + else + break; } - if(on == ON_V || on == ON_P) - { - if((n_id=smReplace_samp(sm,c,NULL,wpt,s_id,t_id,o_id,on,which))!=s_id) - smUnalloc_samp(sm,s_id); - return(n_id); - } - if((!(smTest_sample(sm,t_id,NULL,wpt,&r_id)))) - { - smUnalloc_samp(sm,s_id); - return(INVALID); - } - - if(r_id != INVALID) - { - smRemoveVertex(sm,r_id); - sDelete_samp(SM_SAMP(sm),r_id); - } - else - break; - } /* Allocate space for a sample and initialize */ - sInit_samp(SM_SAMP(sm),s_id,c,NULL,wpt,o_id,(SM_TONE_MAP(sm)>s_id)); + sInit_samp(SM_SAMP(sm),s_id,c,NULL,wpt,o_id); } if(!SM_DIR_ID(sm,s_id)) { @@ -1832,63 +1820,6 @@ int type; } - -int -smNext_tri_flag_set(sm,i,which,b) - SM *sm; - int i,which; - int b; -{ - - for(; i < SM_NUM_TRI(sm);i++) - { - - if(!T_IS_VALID(SM_NTH_TRI(sm,i))) - continue; - if(!SM_IS_NTH_T_FLAG(sm,i,which)) - continue; - if(!b) - break; - if((b==1) && !SM_BG_TRI(sm,i)) - break; - if((b==2) && SM_BG_TRI(sm,i)) - break; - } - - return(i); -} - - -int -smNext_valid_tri(sm,i) - SM *sm; - int i; -{ - - while( i < SM_NUM_TRI(sm) && !T_IS_VALID(SM_NTH_TRI(sm,i))) - i++; - - return(i); -} - - - -qtTri_from_id(t_id,v0,v1,v2) -int t_id; -FVECT v0,v1,v2; -{ - TRI *t; - - t = SM_NTH_TRI(smMesh,t_id); - if(!T_IS_VALID(t)) - return(0); - VSUB(v0,SM_T_NTH_WV(smMesh,t,0),SM_VIEW_CENTER(smMesh)); - VSUB(v1,SM_T_NTH_WV(smMesh,t,1),SM_VIEW_CENTER(smMesh)); - VSUB(v2,SM_T_NTH_WV(smMesh,t,2),SM_VIEW_CENTER(smMesh)); - return(1); -} - - smRebuild_mesh(sm,v) SM *sm; VIEW *v; @@ -1900,6 +1831,7 @@ smRebuild_mesh(sm,v) #ifdef DEBUG fprintf(stderr,"smRebuild_mesh(): rebuilding...."); #endif + smCull(sm,v,SM_ALL_LEVELS); /* Clear the mesh- and rebuild using the current sample array */ /* Remember the current number of samples */ cnt = SM_NUM_SAMP(sm); @@ -1939,10 +1871,6 @@ smRebuild_mesh(sm,v) } } -#if 0 - smNew_tri_cnt = SM_SAMPLE_TRIS(sm); -#endif - #ifdef DEBUG fprintf(stderr,"smRebuild_mesh():done\n"); #endif @@ -1965,80 +1893,28 @@ intersect_tri_set(t_set,orig,dir,pt) { t_id = QT_SET_NEXT_ELEM(optr); t = SM_NTH_TRI(smMesh,t_id); - if(!T_IS_VALID(t)) + if(!T_IS_VALID(t) || SM_IS_NTH_T_BASE(smMesh,t_id)|| + SM_IS_NTH_T_BG(smMesh,t_id)) continue; pid0 = T_NTH_V(t,0); pid1 = T_NTH_V(t,1); pid2 = T_NTH_V(t,2); - if(base = SM_IS_NTH_T_BASE(smMesh,t_id)) - if(SM_BASE_ID(smMesh,pid0) && SM_BASE_ID(smMesh,pid1) && - SM_BASE_ID(smMesh,pid2)) - continue; VCOPY(p0,SM_NTH_WV(smMesh,pid0)); VCOPY(p1,SM_NTH_WV(smMesh,pid1)); VCOPY(p2,SM_NTH_WV(smMesh,pid2)); if(ray_intersect_tri(orig,dir,p0,p1,p2,p)) { - if(!base) - { - d = DIST_SQ(p,p0); - d1 = DIST_SQ(p,p1); - if(d < d1) - { - d1 = DIST_SQ(p,p2); - id = (d1 < d)?pid2:pid0; - } - else - { - d = DIST_SQ(p,p2); - id = (d < d1)? pid2:pid1; - } - } + d = DIST_SQ(p,p0); + d1 = DIST_SQ(p,p1); + if(d < d1) + { + d1 = DIST_SQ(p,p2); + id = (d1 < d)?pid2:pid0; + } else { - if(SM_BASE_ID(smMesh,pid0)) - { - if(SM_BASE_ID(smMesh,pid1)) - id = pid2; - else - if(SM_BASE_ID(smMesh,pid2)) - id = pid1; - else - { - d = DIST_SQ(p,p1); - d1 = DIST_SQ(p,p2); - if(d < d1) - id = pid1; - else - id = pid2; - } - } - else - { - if(SM_BASE_ID(smMesh,pid1)) - { - if(SM_BASE_ID(smMesh,pid2)) - id = pid0; - else - { - d = DIST_SQ(p,p0); - d1 = DIST_SQ(p,p2); - if(d < d1) - id = pid0; - else - id = pid2; - } - } - else - { - d = DIST_SQ(p,p0); - d1 = DIST_SQ(p,p1); - if(d < d1) - id = pid0; - else - id = pid1; - } - } + d = DIST_SQ(p,p2); + id = (d < d1)? pid2:pid1; } if(pt) VCOPY(pt,p); @@ -2175,10 +2051,6 @@ FVECT orig,dir; #ifdef DEBUG_TEST_DRIVER VCOPY(Pick_point[0],p); #endif -#ifdef DEBUG - fprintf(stderr,"Simple pick returning %d\n",s_id); -#endif - return(s_id); } d = point_on_sphere(b,orig,SM_VIEW_CENTER(smMesh)); @@ -2192,9 +2064,6 @@ FVECT orig,dir; #ifdef DEBUG_TEST_DRIVER VCOPY(Pick_point[0],p); #endif -#ifdef DEBUG - fprintf(stderr,"Simple pick2 returning %d\n",s_id); -#endif return(s_id); } if(OPP_EQUAL_VEC3(b,dir)) @@ -2244,10 +2113,8 @@ FVECT orig,dir; F_ARGS(func) = (int *)(&rt); stTrace_ray(SM_LOCATOR(smMesh),o,dir,func); s_id = rt.t_id; + } -#ifdef DEBUG - fprintf(stderr,"Trace pick returning %d\n",s_id); -#endif return(s_id); Lerror: @@ -2258,11 +2125,20 @@ Lerror: } +null_func(argptr,root,qt,n) + int *argptr; + int root; + QUADTREE qt; + int n; +{ + /* do nothing */ +} -mark_active_tris(argptr,root,qt) +mark_active_tris(argptr,root,qt,n) int *argptr; int root; QUADTREE qt; + int n; { OBJECT *os,*optr; register int i,t_id; @@ -2283,42 +2159,47 @@ mark_active_tris(argptr,root,qt) continue; SM_SET_NTH_T_ACTIVE(smMesh,t_id); /* Set the Active bits of the Vertices */ - if(!SM_IS_NTH_T_BASE(smMesh,t_id)) - { - S_SET_FLAG(T_NTH_V(tri,0)); - S_SET_FLAG(T_NTH_V(tri,1)); - S_SET_FLAG(T_NTH_V(tri,2)); - } + S_SET_FLAG(T_NTH_V(tri,0)); + S_SET_FLAG(T_NTH_V(tri,1)); + S_SET_FLAG(T_NTH_V(tri,2)); } } -mark_tris_in_frustum(view) +smCull(sm,view,n) + SM *sm; VIEW *view; + int n; { FVECT nr[4],far[4]; FPEQ peq; int debug=0; FUNC f; - F_FUNC(f) = mark_active_tris; - F_ARGS(f) = NULL; + /* First clear all the quadtree node flags */ + qtClearAllFlags(); + F_ARGS(f) = NULL; + /* If marking samples down to leaves */ + if(n == SM_ALL_LEVELS) + { /* Mark triangles in approx. view frustum as being active:set LRU counter: for use in discarding samples when out of space + */ + F_FUNC(f) = mark_active_tris; + smClear_flags(sm,T_ACTIVE_FLAG); + /* Clear all of the active sample flags*/ + sClear_all_flags(SM_SAMP(sm)); + } + else + /* Just mark qtree flags */ + F_FUNC(f) = null_func; + + /* calculate the world space coordinates of the view frustum: Radiance often has no far clipping plane: but driver will set dev_zmin,dev_zmax to satisfy OGL - */ - - /* First clear all the quadtree node and triangle active flags */ - qtClearAllFlags(); - smClear_flags(smMesh,T_ACTIVE_FLAG); - /* Clear all of the active sample flags*/ - sClear_all_flags(SM_SAMP(smMesh)); - - - /* calculate the world space coordinates of the view frustum */ + */ calculate_view_frustum(view->vp,view->hvec,view->vvec,view->horiz, view->vert, dev_zmin,dev_zmax,nr,far); @@ -2339,80 +2220,80 @@ mark_tris_in_frustum(view) Also set the triangles LRU clock counter */ - if(EQUAL_VEC3(view->vp,SM_VIEW_CENTER(smMesh))) + if(EQUAL_VEC3(view->vp,SM_VIEW_CENTER(sm))) {/* Near face triangles */ - smLocator_apply(smMesh,nr[0],nr[2],nr[3],f); - smLocator_apply(smMesh,nr[2],nr[0],nr[1],f); + smLocator_apply(sm,nr[0],nr[2],nr[3],f,n); + smLocator_apply(sm,nr[2],nr[0],nr[1],f,n); return; } /* Test the view against the planes: and swap orientation if inside:*/ tri_plane_equation(nr[0],nr[2],nr[3], &peq,FALSE); - if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) + if(PT_ON_PLANE(SM_VIEW_CENTER(sm),peq) < 0.0) {/* Near face triangles */ - smLocator_apply(smMesh,nr[3],nr[2],nr[0],f); - smLocator_apply(smMesh,nr[1],nr[0],nr[2],f); + smLocator_apply(sm,nr[3],nr[2],nr[0],f,n); + smLocator_apply(sm,nr[1],nr[0],nr[2],f,n); } else {/* Near face triangles */ - smLocator_apply(smMesh,nr[0],nr[2],nr[3],f); - smLocator_apply(smMesh,nr[2],nr[0],nr[1],f); + smLocator_apply(sm,nr[0],nr[2],nr[3],f,n); + smLocator_apply(sm,nr[2],nr[0],nr[1],f,n); } tri_plane_equation(nr[0],far[3],far[0], &peq,FALSE); - if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) + if(PT_ON_PLANE(SM_VIEW_CENTER(sm),peq) < 0.0) { /* Right face triangles */ - smLocator_apply(smMesh,far[0],far[3],nr[0],f); - smLocator_apply(smMesh,nr[3],nr[0],far[3],f); + smLocator_apply(sm,far[0],far[3],nr[0],f,n); + smLocator_apply(sm,nr[3],nr[0],far[3],f,n); } else {/* Right face triangles */ - smLocator_apply(smMesh,nr[0],far[3],far[0],f); - smLocator_apply(smMesh,far[3],nr[0],nr[3],f); + smLocator_apply(sm,nr[0],far[3],far[0],f,n); + smLocator_apply(sm,far[3],nr[0],nr[3],f,n); } tri_plane_equation(nr[1],far[2],nr[2], &peq,FALSE); if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) { /* Left face triangles */ - smLocator_apply(smMesh,nr[2],far[2],nr[1],f); - smLocator_apply(smMesh,far[1],nr[1],far[2],f); + smLocator_apply(sm,nr[2],far[2],nr[1],f,n); + smLocator_apply(sm,far[1],nr[1],far[2],f,n); } else { /* Left face triangles */ - smLocator_apply(smMesh,nr[1],far[2],nr[2],f); - smLocator_apply(smMesh,far[2],nr[1],far[1],f); + smLocator_apply(sm,nr[1],far[2],nr[2],f,n); + smLocator_apply(sm,far[2],nr[1],far[1],f,n); } tri_plane_equation(nr[0],far[0],nr[1], &peq,FALSE); - if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) + if(PT_ON_PLANE(SM_VIEW_CENTER(sm),peq) < 0.0) {/* Top face triangles */ - smLocator_apply(smMesh,nr[1],far[0],nr[0],f); - smLocator_apply(smMesh,far[1],far[0],nr[1],f); + smLocator_apply(sm,nr[1],far[0],nr[0],f,n); + smLocator_apply(sm,far[1],far[0],nr[1],f,n); } else {/* Top face triangles */ - smLocator_apply(smMesh,nr[0],far[0],nr[1],f); - smLocator_apply(smMesh,nr[1],far[0],far[1],f); + smLocator_apply(sm,nr[0],far[0],nr[1],f,n); + smLocator_apply(sm,nr[1],far[0],far[1],f,n); } tri_plane_equation(nr[3],nr[2],far[3], &peq,FALSE); - if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) + if(PT_ON_PLANE(SM_VIEW_CENTER(sm),peq) < 0.0) {/* Bottom face triangles */ - smLocator_apply(smMesh,far[3],nr[2],nr[3],f); - smLocator_apply(smMesh,far[3],far[2],nr[2],f); + smLocator_apply(sm,far[3],nr[2],nr[3],f,n); + smLocator_apply(sm,far[3],far[2],nr[2],f,n); } else { /* Bottom face triangles */ - smLocator_apply(smMesh,nr[3],nr[2],far[3],f); - smLocator_apply(smMesh,nr[2],far[2],far[3],f); + smLocator_apply(sm,nr[3],nr[2],far[3],f,n); + smLocator_apply(sm,nr[2],far[2],far[3],f,n); } tri_plane_equation(far[2],far[0],far[1], &peq,FALSE); - if(PT_ON_PLANE(SM_VIEW_CENTER(smMesh),peq) < 0.0) + if(PT_ON_PLANE(SM_VIEW_CENTER(sm),peq) < 0.0) {/* Far face triangles */ - smLocator_apply(smMesh,far[0],far[2],far[1],f); - smLocator_apply(smMesh,far[2],far[0],far[3],f); + smLocator_apply(sm,far[0],far[2],far[1],f,n); + smLocator_apply(sm,far[2],far[0],far[3],f,n); } else {/* Far face triangles */ - smLocator_apply(smMesh,far[1],far[2],far[0],f); - smLocator_apply(smMesh,far[3],far[0],far[2],f); + smLocator_apply(sm,far[1],far[2],far[0],f,n); + smLocator_apply(sm,far[3],far[0],far[2],f,n); } }
