root/radiance/ray/src/hd/sm.c
Revision: 3.2
Committed: Thu Aug 20 16:47:21 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 3.1: +7 -7 lines
switched to barycentric coordinates
fixed background poly rendering
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * sm.c
9 */
10 #include "standard.h"
11
12 #include "object.h"
13
14 #include "sm_list.h"
15 #include "sm_geom.h"
16 #include "sm.h"
17
18
19 SM *smMesh = NULL;
20 double smDist_sum=0;
21 int smNew_tri_cnt=0;
22
23 #ifdef TEST_DRIVER
24 VIEW View = {0,{0,0,0},{0,0,-1},{0,1,0},60,60,0};
25 VIEW Current_View = {0,{0,0,0},{0,0,-1},{0,1,0},60,60,0};
26 int Pick_cnt =0;
27 int Pick_tri = -1,Picking = FALSE;
28 FVECT Pick_point[500],Pick_origin,Pick_dir;
29 FVECT Pick_v0[500], Pick_v1[500], Pick_v2[500];
30 FVECT P0,P1,P2;
31 FVECT FrustumNear[4],FrustumFar[4];
32 double dev_zmin=.01,dev_zmax=1000;
33 #endif
34
35 smDir(sm,ps,id)
36 SM *sm;
37 FVECT ps;
38 int id;
39 {
40 FVECT p;
41
42 VCOPY(p,SM_NTH_WV(sm,id));
43 point_on_sphere(ps,p,SM_VIEW_CENTER(sm));
44 }
45
46 smClear_mesh(sm)
47 SM *sm;
48 {
49 /* Reset the triangle counters */
50 SM_TRI_CNT(sm) = 0;
51 SM_NUM_TRIS(sm) = 0;
52 SM_FREE_TRIS(sm) = -1;
53 }
54
55 smClear_flags(sm,which)
56 SM *sm;
57 int which;
58 {
59 int i;
60
61 if(which== -1)
62 for(i=0; i < T_FLAGS;i++)
63 bzero(SM_NTH_FLAGS(sm,i),T_TOTAL_FLAG_BYTES(SM_MAX_TRIS(sm)));
64 else
65 bzero(SM_NTH_FLAGS(sm,which),T_TOTAL_FLAG_BYTES(SM_MAX_TRIS(sm)));
66 }
67
68 smClear_locator(sm)
69 SM *sm;
70 {
71 STREE *st;
72
73 st = SM_LOCATOR(sm);
74
75 stClear(st);
76 }
77
78 smInit_locator(sm,center,base)
79 SM *sm;
80 FVECT center,base[4];
81 {
82 STREE *st;
83
84 st = SM_LOCATOR(sm);
85
86 stInit(st,center,base);
87
88 }
89
90 smClear(sm)
91 SM *sm;
92 {
93 smClear_samples(sm);
94 smClear_mesh(sm);
95 smClear_locator(sm);
96 }
97
98 int
99 smAlloc_tris(sm,max_verts,max_tris)
100 SM *sm;
101 int max_verts,max_tris;
102 {
103 int i,nbytes,vbytes,fbytes;
104
105 vbytes = max_verts*sizeof(VERT);
106 fbytes = T_TOTAL_FLAG_BYTES(max_tris);
107 nbytes = vbytes + max_tris*sizeof(TRI) +T_FLAGS*fbytes + 8;
108 for(i = 1024; nbytes > i; i <<= 1)
109 ;
110 /* check if casting works correctly */
111 max_tris = (i-vbytes-8)/(sizeof(TRI) + T_FLAG_BYTES);
112 fbytes = T_TOTAL_FLAG_BYTES(max_tris);
113
114 SM_BASE(sm)=(char *)malloc(vbytes+max_tris*sizeof(TRI)+T_FLAGS*fbytes);
115
116 if (SM_BASE(sm) == NULL)
117 return(0);
118
119 SM_TRIS(sm) = (TRI *)SM_BASE(sm);
120 SM_VERTS(sm) = (VERT *)(SM_TRIS(sm) + max_tris);
121
122 SM_NTH_FLAGS(sm,0) = (int4 *)(SM_VERTS(sm) + max_verts);
123 for(i=1; i < T_FLAGS; i++)
124 SM_NTH_FLAGS(sm,i) = (int4 *)(SM_NTH_FLAGS(sm,i-1)+fbytes/sizeof(int4));
125
126 SM_MAX_VERTS(sm) = max_verts;
127 SM_MAX_TRIS(sm) = max_tris;
128
129 smClear_mesh(sm);
130
131 return(max_tris);
132 }
133
134
135
136 int
137 smAlloc_locator(sm)
138 SM *sm;
139 {
140 STREE *st;
141
142 st = SM_LOCATOR(sm);
143
144 st = stAlloc(st);
145
146 if(st)
147 return(TRUE);
148 else
149 return(FALSE);
150 }
151
152 /* Initialize/clear global smL sample list for at least n samples */
153 smAlloc(max_samples)
154 register int max_samples;
155 {
156 unsigned nbytes;
157 register unsigned i;
158 int total_points;
159 int max_tris;
160
161 /* If this is the first call, allocate sample,vertex and triangle lists */
162 if(!smMesh)
163 {
164 if(!(smMesh = (SM *)malloc(sizeof(SM))))
165 error(SYSTEM,"smAlloc():Unable to allocate memory");
166 bzero(smMesh,sizeof(SM));
167 }
168 else
169 { /* If existing structure: first deallocate */
170 if(SM_BASE(smMesh))
171 free(SM_BASE(smMesh));
172 if(SM_SAMP_BASE(smMesh))
173 free(SM_SAMP_BASE(smMesh));
174 }
175
176 /* First allocate at least n samples + extra points:at least enough
177 necessary to form the BASE MESH- Default = 4;
178 */
179 max_samples = smAlloc_samples(smMesh, max_samples,SM_EXTRA_POINTS);
180
181 total_points = max_samples + SM_EXTRA_POINTS;
182 max_tris = total_points*2;
183
184 /* Now allocate space for mesh vertices and triangles */
185 max_tris = smAlloc_tris(smMesh, total_points, max_tris);
186
187 /* Initialize the structure for point,triangle location.
188 */
189 smAlloc_locator(smMesh);
190
191 }
192
193
194
195 smInit_mesh(sm,vp)
196 SM *sm;
197 FVECT vp;
198 {
199
200 /* NOTE: Should be elsewhere?*/
201 smDist_sum = 0;
202 smNew_tri_cnt = 0;
203
204 VCOPY(SM_VIEW_CENTER(smMesh),vp);
205 smClear_locator(sm);
206 smInit_locator(sm,vp,0);
207 smClear_aux_samples(sm);
208 smClear_mesh(sm);
209 smCreate_base_mesh(sm,SM_DEFAULT);
210 }
211
212 /*
213 * int
214 * smInit(n) : Initialize/clear data structures for n entries
215 * int n;
216 *
217 * This routine allocates/initializes the sample, mesh, and point-location
218 * structures for at least n samples.
219 * If n is <= 0, then clear data structures. Returns number samples
220 * actually allocated.
221 */
222
223 int
224 smInit(n)
225 register int n;
226 {
227 int max_vertices;
228
229 sleep(10);
230
231 /* If n <=0, Just clear the existing structures */
232 if(n <= 0)
233 {
234 smClear(smMesh);
235 return(0);
236 }
237
238 /* Total mesh vertices includes the sample points and the extra vertices
239 to form the base mesh
240 */
241 max_vertices = n + SM_EXTRA_POINTS;
242
243 /* If the current mesh contains enough room, clear and return */
244 if(smMesh && max_vertices <= SM_MAX_VERTS(smMesh))
245 {
246 smClear(smMesh);
247 return(SM_MAX_SAMP(smMesh));
248 }
249 /* Otherwise- mesh must be allocated with the appropriate number of
250 samples
251 */
252 smAlloc(n);
253
254 return(SM_MAX_SAMP(smMesh));
255 }
256
257
258 int
259 smLocator_apply_func(sm,v0,v1,v2,func,arg)
260 SM *sm;
261 FVECT v0,v1,v2;
262 int (*func)();
263 char *arg;
264 {
265 STREE *st;
266 char found;
267 FVECT p0,p1,p2;
268
269 st = SM_LOCATOR(sm);
270
271 point_on_sphere(p0,v0,SM_VIEW_CENTER(sm));
272 point_on_sphere(p1,v1,SM_VIEW_CENTER(sm));
273 point_on_sphere(p2,v2,SM_VIEW_CENTER(sm));
274
275 found = stApply_to_tri_cells(st,p0,p1,p2,func,arg);
276
277 return(found);
278 }
279
280
281 int
282 smLocator_add_tri(sm,t_id,v0_id,v1_id,v2_id)
283 SM *sm;
284 int t_id;
285 int v0_id,v1_id,v2_id;
286 {
287 STREE *st;
288 FVECT p0,p1,p2;
289
290 st = SM_LOCATOR(sm);
291
292 smDir(sm,p0,v0_id);
293 smDir(sm,p1,v1_id);
294 smDir(sm,p2,v2_id);
295
296 stAdd_tri(st,t_id,p0,p1,p2);
297
298 return(1);
299 }
300
301 /* Add a triangle to the base array with vertices v1-v2-v3 */
302 int
303 smAdd_tri(sm, v0_id,v1_id,v2_id,tptr)
304 SM *sm;
305 int v0_id,v1_id,v2_id;
306 TRI **tptr;
307 {
308 int t_id;
309 TRI *t;
310
311
312 if(SM_TRI_CNT(sm)+1 > SM_MAX_TRIS(sm))
313 error(SYSTEM,"smAdd_tri():Too many triangles");
314
315 /* Get the id for the next available triangle */
316 SM_FREE_TRI_ID(sm,t_id);
317 if(t_id == -1)
318 return(t_id);
319
320 t = SM_NTH_TRI(sm,t_id);
321 T_CLEAR_NBRS(t);
322
323 if(SM_BASE_ID(sm,v0_id) || SM_BASE_ID(sm,v1_id) || SM_BASE_ID(sm,v2_id))
324 {
325 smClear_tri_flags(sm,t_id);
326 SM_SET_NTH_T_BASE(sm,t_id);
327 }
328 else
329 {
330 SM_CLEAR_NTH_T_BASE(sm,t_id);
331 SM_SET_NTH_T_ACTIVE(sm,t_id);
332 SM_SET_NTH_T_LRU(sm,t_id);
333 SM_SET_NTH_T_NEW(sm,t_id);
334 SM_NUM_TRIS(sm)++;
335 smNew_tri_cnt++;
336 }
337 /* set the triangle vertex ids */
338 T_NTH_V(t,0) = v0_id;
339 T_NTH_V(t,1) = v1_id;
340 T_NTH_V(t,2) = v2_id;
341
342 SM_NTH_VERT(sm,v0_id) = t_id;
343 SM_NTH_VERT(sm,v1_id) = t_id;
344 SM_NTH_VERT(sm,v2_id) = t_id;
345
346 /* Add triangle to the locator */
347 smLocator_add_tri(sm,t_id,v0_id,v1_id,v2_id);
348 if(t)
349 *tptr = t;
350 /* return initialized triangle */
351 return(t_id);
352 }
353
354 int
355 smClosest_vertex_in_tri(sm,v0_id,v1_id,v2_id,p,eps)
356 SM *sm;
357 int v0_id,v1_id,v2_id;
358 FVECT p;
359 double eps;
360 {
361 FVECT v;
362 double d,d0,d1,d2;
363 int closest = -1;
364
365 if(v0_id != -1)
366 {
367 smDir(sm,v,v0_id);
368 d0 = DIST(p,v);
369 if(eps < 0 || d0 < eps)
370 {
371 closest = v0_id;
372 d = d0;
373 }
374 }
375 if(v1_id != -1)
376 {
377 smDir(sm,v,v1_id);
378 d1 = DIST(p,v);
379 if(closest== -1)
380 {
381 if(eps < 0 || d1 < eps)
382 {
383 closest = v1_id;
384 d = d1;
385 }
386 }
387 else
388 if(d1 < d2)
389 {
390 if((eps < 0) || d1 < eps)
391 {
392 closest = v1_id;
393 d = d1;
394 }
395 }
396 else
397 if((eps < 0) || d2 < eps)
398 {
399 closest = v2_id;
400 d = d2;
401 }
402 }
403 if(v2_id != -1)
404 {
405 smDir(sm,v,v2_id);
406 d2 = DIST(p,v);
407 if((eps < 0) || d2 < eps)
408 if(closest== -1 ||(d2 < d))
409 return(v2_id);
410 }
411 return(closest);
412 }
413
414
415 int
416 smClosest_vertex_in_w_tri(sm,v0_id,v1_id,v2_id,p)
417 SM *sm;
418 int v0_id,v1_id,v2_id;
419 FVECT p;
420 {
421 FVECT v;
422 double d,d0,d1,d2;
423 int closest;
424
425 VCOPY(v,SM_NTH_WV(sm,v0_id));
426 d = d0 = DIST(p,v);
427 closest = v0_id;
428
429 VCOPY(v,SM_NTH_WV(sm,v1_id));
430 d1 = DIST(p,v);
431 if(d1 < d2)
432 {
433 closest = v1_id;
434 d = d1;
435 }
436 VCOPY(v,SM_NTH_WV(sm,v2_id));
437 d2 = DIST(p,v);
438 if(d2 < d)
439 return(v2_id);
440 else
441 return(closest);
442 }
443
444 void
445 smTris_swap_edge(sm,t_id,t1_id,e,e1,tn_id,tn1_id)
446 SM *sm;
447 int t_id,t1_id;
448 int e,e1;
449 int **tn_id,**tn1_id;
450
451 {
452 TRI *t,*t1;
453 TRI *ta,*tb;
454 int verts[3],enext,eprev,e1next,e1prev;
455 TRI *n;
456 FVECT p1,p2,p3;
457 int ta_id,tb_id;
458 /* swap diagonal (e relative to t, and e1 relative to t1)
459 defined by quadrilateral
460 formed by t,t1- swap for the opposite diagonal
461 */
462 t = SM_NTH_TRI(sm,t_id);
463 t1 = SM_NTH_TRI(sm,t1_id);
464 enext = (e+1)%3;
465 eprev = (e+2)%3;
466 e1next = (e1+1)%3;
467 e1prev = (e1+2)%3;
468 verts[e] = T_NTH_V(t,e);
469 verts[enext] = T_NTH_V(t1,e1prev);
470 verts[eprev] = T_NTH_V(t,eprev);
471 ta_id = smAdd_tri(sm,verts[0],verts[1],verts[2],&ta);
472
473 verts[e1] = T_NTH_V(t1,e1);
474 verts[e1next] = T_NTH_V(t,eprev);
475 verts[e1prev] = T_NTH_V(t1,e1prev);
476 tb_id = smAdd_tri(sm,verts[0],verts[1],verts[2],&tb);
477
478 /* set the neighbors */
479 T_NTH_NBR(ta,e) = T_NTH_NBR(t1,e1next);
480 T_NTH_NBR(tb,e1) = T_NTH_NBR(t,enext);
481 T_NTH_NBR(ta,enext) = tb_id;
482 T_NTH_NBR(tb,e1next) = ta_id;
483 T_NTH_NBR(ta,eprev) = T_NTH_NBR(t,eprev);
484 T_NTH_NBR(tb,e1prev) = T_NTH_NBR(t1,e1prev);
485
486 /* Reset neighbor pointers of original neighbors */
487 n = SM_NTH_TRI(sm,T_NTH_NBR(t,enext));
488 T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = tb_id;
489 n = SM_NTH_TRI(sm,T_NTH_NBR(t,eprev));
490 T_NTH_NBR(n,T_NTH_NBR_PTR(t_id,n)) = ta_id;
491
492 n = SM_NTH_TRI(sm,T_NTH_NBR(t1,e1next));
493 T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = ta_id;
494 n = SM_NTH_TRI(sm,T_NTH_NBR(t1,e1prev));
495 T_NTH_NBR(n,T_NTH_NBR_PTR(t1_id,n)) = tb_id;
496
497 /* Delete two parent triangles */
498 smDelete_tri(sm,t_id);
499 smDelete_tri(sm,t1_id);
500 *tn_id = ta_id;
501 *tn1_id = tb_id;
502 }
503
504 /* MUST add check for constrained edges */
505 char
506 smFix_tris(sm,id,tlist)
507 SM *sm;
508 int id;
509 LIST *tlist;
510 {
511 TRI *t,*t_opp;
512 FVECT p,p1,np,p2,p3;
513 int swapped = 0;
514 int e,e1,e_id;
515 char debug = 0;
516 int t_id,t_opp_id;
517
518 VCOPY(p,SM_NTH_WV(sm,id));
519 VSUB(p,p,SM_VIEW_CENTER(sm));
520 while(tlist)
521 {
522 t_id = (int)pop_list(&tlist);
523 t = SM_NTH_TRI(sm,t_id);
524 e = (T_WHICH_V(t,id)+1)%3;
525 t_opp_id = T_NTH_NBR(t,e);
526 t_opp = SM_NTH_TRI(sm,t_opp_id);
527
528 smDir(sm,p1,T_NTH_V(t_opp,0));
529 smDir(sm,p2,T_NTH_V(t_opp,1));
530 smDir(sm,p3,T_NTH_V(t_opp,2));
531 if(point_in_cone(p,p1,p2,p3))
532 {
533 swapped = 1;
534 e1 = T_NTH_NBR_PTR(t_id,t_opp);
535 /* check list for t_opp and Remove if there */
536 remove_from_list(t_opp_id,&tlist);
537
538 smTris_swap_edge(sm,t_id,t_opp_id,e,e1,&t_id,&t_opp_id);
539 tlist = push_data(tlist,t_id);
540 tlist = push_data(tlist,t_opp_id);
541 }
542 }
543 return(swapped);
544 }
545
546 /* Give the vertex "id" and a triangle "t" that it belongs to- return the
547 next nbr in a counter clockwise order about vertex "id"
548 */
549 int
550 smTri_next_ccw_nbr(sm,t,id)
551 SM *sm;
552 TRI *t;
553 int id;
554 {
555 int t_id;
556 int tri;
557
558 /* Want the edge for which "id" is the destination */
559 t_id = (T_WHICH_V(t,id)+ 2)% 3;
560 tri = T_NTH_NBR(t,t_id);
561 return(tri);
562 }
563
564 void
565 smReplace_point(sm,tri,id,nid)
566 SM *sm;
567 TRI *tri;
568 int id,nid;
569 {
570 TRI *t;
571 int t_id;
572
573 T_NTH_V(tri,T_WHICH_V(tri,id)) = nid;
574
575 t_id = smTri_next_ccw_nbr(sm,t,nid);
576 while((t= SM_NTH_TRI(sm,t_id)) != tri)
577 {
578 T_NTH_V(t,T_WHICH_V(t,id)) = nid;
579 t_id = smTri_next_ccw_nbr(sm,t,nid);
580 }
581 }
582
583
584 smClear_tri_flags(sm,id)
585 SM *sm;
586 int id;
587 {
588 int i;
589
590 for(i=0; i < T_FLAGS; i++)
591 SM_CLEAR_NTH_T_FLAG(sm,id,i);
592
593 }
594
595 /* Locate the point-id in the point location structure: */
596 int
597 smReplace_vertex(sm,c,dir,p,tri_id,snew_id,type,which)
598 SM *sm;
599 COLR c;
600 FVECT dir,p;
601 int tri_id,snew_id;
602 char type,which;
603 {
604 int n_id,s_id;
605 TRI *tri;
606
607 tri = SM_NTH_TRI(sm,tri_id);
608 /* Get the sample that corresponds to the "which" vertex of "tri" */
609 /* NEED: have re-init that sets clock flag */
610 /* If this is a base-sample: create a new sample and replace
611 all references to the base sample with references to the
612 new sample
613 */
614 s_id = T_NTH_V(tri,which);
615 if(SM_BASE_ID(sm,s_id))
616 {
617 if(snew_id != -1)
618 n_id = smAdd_sample_point(sm,c,dir,p);
619 else
620 n_id = snew_id;
621 smReplace_point(sm,tri,s_id,n_id);
622 s_id = n_id;
623 }
624 else /* If the sample exists, reset the values */
625 /* NOTE: This test was based on the SPHERICAL coordinates
626 of the point: If we are doing a multiple-sample-per
627 SPHERICAL pixel: we will want to test for equality-
628 and do other processing: for now: SINGLE SAMPLE PER
629 PIXEL
630 */
631 /* NOTE: snew_id needs to be marked as invalid?*/
632 if(snew_id == -1)
633 smInit_sample(sm,s_id,c,dir,p);
634 else
635 smReset_sample(sm,s_id,snew_id);
636 return(s_id);
637 }
638
639
640 /* Locate the point-id in the point location structure: */
641 int
642 smInsert_point_in_tri(sm,c,dir,p,s_id,tri_id)
643 SM *sm;
644 COLR c;
645 FVECT dir,p;
646 int s_id,tri_id;
647 {
648 TRI *tri,*t0,*t1,*t2,*nbr;
649 int v0_id,v1_id,v2_id,n_id;
650 int t0_id,t1_id,t2_id;
651 LIST *tlist;
652 FVECT npt;
653
654 if(s_id == SM_INVALID)
655 s_id = smAdd_sample_point(sm,c,dir,p);
656
657 tri = SM_NTH_TRI(sm,tri_id);
658 v0_id = T_NTH_V(tri,0);
659 v1_id = T_NTH_V(tri,1);
660 v2_id = T_NTH_V(tri,2);
661
662 n_id = -1;
663 if(SM_BASE_ID(sm,v0_id)||SM_BASE_ID(sm,v1_id)||SM_BASE_ID(sm,v2_id))
664 {
665 smDir(sm,npt,s_id);
666 /* Change to an add and delete */
667 t0_id = (SM_BASE_ID(sm,v0_id))?v0_id:-1;
668 t1_id = (SM_BASE_ID(sm,v1_id))?v1_id:-1;
669 t2_id = (SM_BASE_ID(sm,v2_id))?v2_id:-1;
670 n_id = smClosest_vertex_in_tri(sm,t0_id,t1_id,t2_id,npt,P_REPLACE_EPS);
671 }
672 t0_id = smAdd_tri(sm,s_id,v0_id,v1_id,&t0);
673 t1_id = smAdd_tri(sm,s_id,v1_id,v2_id,&t1);
674 t2_id = smAdd_tri(sm,s_id,v2_id,v0_id,&t2);
675
676 /* Set the neighbor pointers for the new tris */
677 T_NTH_NBR(t0,0) = t2_id;
678 T_NTH_NBR(t0,1) = T_NTH_NBR(tri,0);
679 T_NTH_NBR(t0,2) = t1_id;
680 T_NTH_NBR(t1,0) = t0_id;
681 T_NTH_NBR(t1,1) = T_NTH_NBR(tri,1);
682 T_NTH_NBR(t1,2) = t2_id;
683 T_NTH_NBR(t2,0) = t1_id;
684 T_NTH_NBR(t2,1) = T_NTH_NBR(tri,2);
685 T_NTH_NBR(t2,2) = t0_id;
686
687 /* Reset the neigbor pointers for the neighbors of the original */
688 nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,0));
689 T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t0_id;
690 nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,1));
691 T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t1_id;
692 nbr = SM_NTH_TRI(sm,T_NTH_NBR(tri,2));
693 T_NTH_NBR(nbr,T_NTH_NBR_PTR(tri_id,nbr)) = t2_id;
694
695 smDelete_tri(sm,tri_id);
696
697 /* Fix up the new triangles*/
698 tlist = push_data(NULL,t0_id);
699 tlist = push_data(tlist,t1_id);
700 tlist = push_data(tlist,t2_id);
701
702 smFix_tris(sm,s_id,tlist);
703
704 if(n_id != -1)
705 smDelete_point(sm,n_id);
706
707 return(s_id);
708 }
709
710
711 int
712 smPointLocate(sm,pt,type,which,norm)
713 SM *sm;
714 FVECT pt;
715 char *type,*which;
716 char norm;
717 {
718 STREE *st;
719 int tri;
720 FVECT npt;
721
722 st = SM_LOCATOR(sm);
723 if(norm)
724 {
725 point_on_sphere(npt,pt,SM_VIEW_CENTER(sm));
726 tri = stPoint_locate(st,npt,type,which);
727 }
728 else
729 tri = stPoint_locate(st,pt,type,which);
730 return(tri);
731 }
732
733 QUADTREE
734 smPointLocateCell(sm,pt,type,which,norm)
735 SM *sm;
736 FVECT pt;
737 char *type,*which;
738 char norm;
739 {
740 STREE *st;
741 QUADTREE qt;
742 FVECT npt;
743
744 st = SM_LOCATOR(sm);
745 if(norm)
746 {
747 point_on_sphere(npt,pt,SM_VIEW_CENTER(sm));
748
749 qt = stPoint_locate_cell(st,npt,type,which);
750 }
751 else
752 qt = stPoint_locate_cell(st,pt,type,which);
753
754 return(qt);
755 }
756
757 int
758 smAdd_sample_to_mesh(sm,c,dir,pt,s_id)
759 SM *sm;
760 COLR c;
761 FVECT dir,pt;
762 int s_id;
763 {
764 int t_id;
765 char type,which;
766 double d;
767 FVECT p;
768
769 /* If new, foreground pt */
770 if(pt)
771 {
772 /* NOTE: This should be elsewhere! */
773 d = DIST(pt,SM_VIEW_CENTER(smMesh));
774 smDist_sum += 1.0/d;
775 /************************************/
776 t_id = smPointLocate(smMesh,pt,&type,&which,TRUE);
777 if(type==GT_FACE)
778 s_id = smInsert_point_in_tri(smMesh,c,dir,pt,s_id,t_id);
779 else
780 if(type==GT_VERTEX)
781 s_id = smReplace_vertex(smMesh,c,dir,pt,t_id,s_id,type,which);
782 #ifdef DEBUG
783 else
784 eputs("smAdd_sample_to_mesh(): unrecognized type\n");
785 #endif
786 }
787 else if(s_id != -1)
788 {
789 VCOPY(p,SM_NTH_WV(sm,s_id));
790 if(SM_NTH_W_DIR(sm,s_id) != -1)
791 {
792 /* NOTE: This should be elsewhere! */
793 d = DIST(p,SM_VIEW_CENTER(smMesh));
794 smDist_sum += 1.0/d;
795 /************************************/
796 }
797 t_id = smPointLocate(smMesh,p,&type,&which,TRUE);
798 if(type==GT_FACE)
799 s_id = smInsert_point_in_tri(smMesh,c,dir,p,s_id,t_id);
800 else
801 if(type==GT_VERTEX)
802 s_id = smReplace_vertex(smMesh,c,dir,p,t_id,s_id,type,which);
803 #ifdef DEBUG
804 else
805 eputs("smAdd_sample_to_mesh(): unrecognized type\n");
806 #endif
807 }
808 /* Is a BG(sky point) */
809 else
810 {
811 t_id = smPointLocate(smMesh,dir,&type,&which,FALSE);
812 if(type==GT_FACE)
813 s_id = smInsert_point_in_tri(smMesh,c,dir,NULL,s_id,t_id);
814 else
815 if(type==GT_VERTEX)
816 s_id = smReplace_vertex(smMesh,c,dir,NULL,t_id,s_id,type,which);
817 #ifdef DEBUG
818 else
819 eputs("smAdd_sample_to_mesh(): unrecognized type\n");
820 #endif
821 }
822 return(s_id);
823 }
824
825 /*
826 * int
827 * smNewSamp(c, dir, p) : register new sample point and return index
828 * COLR c; : pixel color (RGBE)
829 * FVECT dir; : ray direction vector
830 * FVECT p; : world intersection point
831 *
832 * Add new sample point to data structures, removing old values as necessary.
833 * New sample representation will be output in next call to smUpdate().
834 * If the point is a sky point: then v=NULL
835 */
836 int
837 smNewSamp(c,dir,p)
838 COLR c;
839 FVECT dir;
840 FVECT p;
841
842 {
843 int s_id;
844
845 /* First check if this the first sample: if so initialize mesh */
846 if(SM_NUM_SAMP(smMesh) == 0)
847 #ifdef TEST_DRIVER
848 smInit_mesh(smMesh,View.vp);
849 #else
850 smInit_mesh(smMesh,odev.v.vp);
851 #endif
852 s_id = smAdd_sample_to_mesh(smMesh,c,dir,p,-1);
853 #if 0
854 {
855 char buff[100];
856 sprintf(buff,"Added sample %d\n",s_id);
857 eputs(buff);
858 }
859 #endif
860 return(s_id);
861
862 }
863 /*
864 * int
865 * smFindsamp(orig, dir): intersect ray with 3D rep. and find closest sample
866 * FVECT orig, dir;
867 *
868 * Find the closest sample to the given ray. Return -1 on failure.
869 */
870
871 /*
872 * smClean() : display has been wiped clean
873 *
874 * Called after display has been effectively cleared, meaning that all
875 * geometry must be resent down the pipeline in the next call to smUpdate().
876 */
877
878
879 /*
880 * smUpdate(vp, qua) : update OpenGL output geometry for view vp
881 * VIEW *vp; : desired view
882 * int qua; : quality level (percentage on linear time scale)
883 *
884 * Draw new geometric representation using OpenGL calls. Assume that the
885 * view has already been set up and the correct frame buffer has been
886 * selected for drawing. The quality level is on a linear scale, where 100%
887 * is full (final) quality. It is not necessary to redraw geometry that has
888 * been output since the last call to smClean().
889 */
890
891
892 int
893 smClear_vert(sm,id)
894 SM *sm;
895 int id;
896 {
897 if(SM_INVALID_POINT_ID(sm,id))
898 return(FALSE);
899
900 SM_NTH_VERT(sm,id) = SM_INVALID;
901
902 return(TRUE);
903 }
904
905 int
906 smAdd_base_vertex(sm,v,d)
907 SM *sm;
908 FVECT v,d;
909 {
910 int id;
911
912 /* First add coordinate to the sample array */
913 id = smAdd_aux_point(sm,v,d);
914 if(id == -1)
915 return(SM_INVALID);
916 /* Initialize triangle pointer to -1 */
917 smClear_vert(sm,id);
918 return(id);
919 }
920
921
922
923 /* Initialize a the point location DAG based on a 6 triangle tesselation
924 of the unit sphere centered on the view center. The DAG structure
925 contains 6 roots: one for each initial base triangle
926 */
927
928 int
929 smCreate_base_mesh(sm,type)
930 SM *sm;
931 int type;
932 {
933 int i,id;
934 int p[4],ids[4];
935 int v0_id,v1_id,v2_id;
936 TRI *tris[4];
937 FVECT d,pt,cntr;
938
939 /* First insert the base vertices into the sample point array */
940
941 for(i=0; i < 4; i++)
942 {
943 VADD(cntr,stDefault_base[i],SM_VIEW_CENTER(sm));
944 point_on_sphere(d,cntr,SM_VIEW_CENTER(sm));
945 id = smAdd_base_vertex(sm,cntr,d);
946 /* test to make sure vertex allocated */
947 if(id != -1)
948 p[i] = id;
949 else
950 return(0);
951 }
952 /* Create the base triangles */
953 for(i=0;i < 4; i++)
954 {
955 v0_id = p[stTri_verts[i][0]];
956 v1_id = p[stTri_verts[i][1]];
957 v2_id = p[stTri_verts[i][2]];
958 if((ids[i] = smAdd_tri(sm, v0_id,v1_id,v2_id,&(tris[i])))== -1)
959 return(0);
960 }
961 /* Set neighbors */
962
963 T_NTH_NBR(tris[0],0) = ids[3];
964 T_NTH_NBR(tris[0],1) = ids[2];
965 T_NTH_NBR(tris[0],2) = ids[1];
966
967 T_NTH_NBR(tris[1],0) = ids[3];
968 T_NTH_NBR(tris[1],1) = ids[0];
969 T_NTH_NBR(tris[1],2) = ids[2];
970
971 T_NTH_NBR(tris[2],0) = ids[3];
972 T_NTH_NBR(tris[2],1) = ids[1];
973 T_NTH_NBR(tris[2],2) = ids[0];
974
975 T_NTH_NBR(tris[3],0) = ids[1];
976 T_NTH_NBR(tris[3],1) = ids[2];
977 T_NTH_NBR(tris[3],2) = ids[0];
978 return(1);
979
980 }
981
982
983 int
984 smNext_tri_flag_set(sm,i,which,b)
985 SM *sm;
986 int i,which;
987 char b;
988 {
989
990 for(; i < SM_TRI_CNT(sm);i++)
991 {
992 if(!SM_IS_NTH_T_FLAG(sm,i,which))
993 continue;
994
995 if(!b)
996 break;
997 if((b==1) && !SM_BG_TRI(sm,i))
998 break;
999 if((b==2) && SM_BG_TRI(sm,i))
1000 break;
1001 }
1002
1003 return(i);
1004 }
1005
1006
1007 int
1008 smNext_valid_tri(sm,i)
1009 SM *sm;
1010 int i;
1011 {
1012
1013 while( i < SM_TRI_CNT(sm) && !T_IS_VALID(SM_NTH_TRI(sm,i)))
1014 i++;
1015
1016 return(i);
1017 }
1018
1019
1020
1021 qtTri_verts_from_id(t_id,v0,v1,v2)
1022 int t_id;
1023 FVECT v0,v1,v2;
1024 {
1025 TRI *t;
1026 int v0_id,v1_id,v2_id;
1027
1028 t = SM_NTH_TRI(smMesh,t_id);
1029 v0_id = T_NTH_V(t,0);
1030 v1_id = T_NTH_V(t,1);
1031 v2_id = T_NTH_V(t,2);
1032
1033 smDir(smMesh,v0,v0_id);
1034 smDir(smMesh,v1,v1_id);
1035 smDir(smMesh,v2,v2_id);
1036
1037 }
1038
1039
1040 int
1041 smIntersectTriSet(sm,t_set,orig,dir,pt)
1042 SM *sm;
1043 OBJECT *t_set;
1044 FVECT orig,dir,pt;
1045 {
1046 OBJECT *optr;
1047 int i,t_id,v_id;
1048 TRI *tri;
1049 FVECT p0,p1,p2;
1050 char type,which;
1051 int p0_id,p1_id,p2_id;
1052
1053 for(optr = QT_SET_PTR(t_set),i = QT_SET_CNT(t_set); i > 0; i--)
1054 {
1055 t_id = QT_SET_NEXT_ELEM(optr);
1056 tri = SM_NTH_TRI(sm,t_id);
1057 p0_id = T_NTH_V(tri,0);
1058 p1_id = T_NTH_V(tri,1);
1059 p2_id = T_NTH_V(tri,2);
1060 VCOPY(p0,SM_NTH_WV(sm,p0_id));
1061 VCOPY(p1,SM_NTH_WV(sm,p1_id));
1062 VCOPY(p2,SM_NTH_WV(sm,p2_id));
1063 if(type = ray_intersect_tri(orig,dir,p0,p1,p2,pt,&which))
1064 {
1065 if(type==GT_VERTEX)
1066 return(T_NTH_V(tri,which));
1067 v_id = smClosest_vertex_in_w_tri(sm,p0_id,p1_id,p2_id,pt);
1068 return(v_id);
1069 }
1070 }
1071 return(-1);
1072 }
1073
1074 /*
1075 * int
1076 * smTraceRay(SM *sm,FVECT orig, FVECT dir,FVECT v0,FVECT v1,FVECT v2,FVECT r)
1077 *
1078 * Intersect the ray with triangle v0v1v2, return intersection point in r
1079 *
1080 * Assumes orig,v0,v1,v2 are in spherical coordinates, and orig is
1081 * unit
1082 */
1083 char
1084 smTraceRay(sm,orig,dir,v0,v1,v2,r)
1085 SM *sm;
1086 FVECT orig,dir;
1087 FVECT v0,v1,v2;
1088 FVECT r;
1089 {
1090 FVECT n,p[3],d;
1091 double pt[3],r_eps;
1092 char i;
1093 int which;
1094
1095 /* Find the plane equation for the triangle defined by the edge v0v1 and
1096 the view center*/
1097 VCROSS(n,v0,v1);
1098 /* Intersect the ray with this plane */
1099 i = intersect_ray_plane(orig,dir,n,0.0,&(pt[0]),p[0]);
1100 if(i)
1101 which = 0;
1102 else
1103 which = -1;
1104
1105 VCROSS(n,v1,v2);
1106 i = intersect_ray_plane(orig,dir,n,0.0,&(pt[1]),p[1]);
1107 if(i)
1108 if((which==-1) || pt[1] < pt[0])
1109 which = 1;
1110
1111 VCROSS(n,v2,v0);
1112 i = intersect_ray_plane(orig,dir,n,0.0,&(pt[2]),p[2]);
1113 if(i)
1114 if((which==-1) || pt[2] < pt[which])
1115 which = 2;
1116
1117 if(which != -1)
1118 {
1119 /* Return point that is K*eps along projection of the ray on
1120 the sphere to push intersection point p[which] into next cell
1121 */
1122 normalize(p[which]);
1123 /* Calculate the ray perpendicular to the intersection point: approx
1124 the direction moved along the sphere a distance of K*epsilon*/
1125 r_eps = -DOT(p[which],dir);
1126 VSUM(n,dir,p[which],r_eps);
1127 /* Calculate the length along ray p[which]-dir needed to move to
1128 cause a move along the sphere of k*epsilon
1129 */
1130 r_eps = DOT(n,dir);
1131 VSUM(r,p[which],dir,(20*FTINY)/r_eps);
1132 normalize(r);
1133 return(TRUE);
1134 }
1135 else
1136 {
1137 /* Unable to find intersection: move along ray and try again */
1138 r_eps = -DOT(orig,dir);
1139 VSUM(n,dir,orig,r_eps);
1140 r_eps = DOT(n,dir);
1141 VSUM(r,orig,dir,(20*FTINY)/r_eps);
1142 normalize(r);
1143 #ifdef DEBUG
1144 eputs("smTraceRay:Ray does not intersect triangle");
1145 #endif
1146 return(FALSE);
1147 }
1148 }
1149
1150
1151 /*
1152 * int
1153 * smFindSamp(FVECT orig, FVECT dir)
1154 *
1155 * Find the closest sample to the given ray. Returns sample id, -1 on failure.
1156 * "dir" is assumed to be normalized
1157 */
1158 int
1159 smFindSamp(orig,dir)
1160 FVECT orig,dir;
1161 {
1162 FVECT r,v0,v1,v2,a,b,p;
1163 OBJECT os[MAXCSET+1],t_set[MAXSET+1];
1164 QUADTREE qt;
1165 int s_id;
1166 double d;
1167
1168 /* r is the normalized vector from the view center to the current
1169 * ray point ( starting with "orig"). Find the cell that r falls in,
1170 * and test the ray against all triangles stored in the cell. If
1171 * the test fails, trace the projection of the ray across to the
1172 * next cell it intersects: iterate until either an intersection
1173 * is found, or the projection ray is // to the direction. The sample
1174 * corresponding to the triangle vertex closest to the intersection
1175 * point is returned.
1176 */
1177
1178 /* First test if "orig" coincides with the View_center or if "dir" is
1179 parallel to r formed by projecting "orig" on the sphere. In
1180 either case, do a single test against the cell containing the
1181 intersection of "dir" and the sphere
1182 */
1183 point_on_sphere(b,orig,SM_VIEW_CENTER(smMesh));
1184 d = -DOT(b,dir);
1185 if(EQUAL_VEC3(orig,SM_VIEW_CENTER(smMesh)) || EQUAL(fabs(d),1.0))
1186 {
1187 qt = smPointLocateCell(smMesh,dir,NULL,NULL,FALSE);
1188 /* Test triangles in the set for intersection with Ray:returns
1189 first found
1190 */
1191 qtgetset(t_set,qt);
1192 s_id = smIntersectTriSet(smMesh,t_set,orig,dir,p);
1193 #ifdef TEST_DRIVER
1194 VCOPY(Pick_point[0],p);
1195 #endif
1196 return(s_id);
1197 }
1198 else
1199 {
1200 /* Starting with orig, Walk along projection of ray onto sphere */
1201 point_on_sphere(r,orig,SM_VIEW_CENTER(smMesh));
1202 qt = smPointLocateCell(smMesh,r,NULL,NULL,FALSE);
1203 qtgetset(t_set,qt);
1204 /* os will contain all triangles seen thus far */
1205 setcopy(os,t_set);
1206
1207 /* Calculate ray perpendicular to dir: when projection ray is // to dir,
1208 the dot product will become negative.
1209 */
1210 VSUM(a,b,dir,d);
1211 d = DOT(a,b);
1212 while(d > 0)
1213 {
1214 s_id = smIntersectTriSet(smMesh,t_set,orig,dir,p);
1215 #ifdef TEST_DRIVER
1216 VCOPY(Pick_point[0],p);
1217 #endif
1218 if(s_id != EMPTY)
1219 return(s_id);
1220 /* Find next cell that projection of ray intersects */
1221 smTraceRay(smMesh,r,dir,v0,v1,v2,r);
1222 qt = smPointLocateCell(smMesh,r,NULL,NULL,FALSE);
1223 qtgetset(t_set,qt);
1224 /* Check triangles in set against those seen so far(os):only
1225 check new triangles for intersection (t_set')
1226 */
1227 check_set(t_set,os);
1228 d = DOT(a,r);
1229 }
1230 }
1231 #ifdef DEBUG
1232 eputs("smFindSamp():Pick Ray did not intersect mesh");
1233 #endif
1234 return(EMPTY);
1235 }
1236
1237
1238 smRebuild_mesh(sm,vptr)
1239 SM *sm;
1240 VIEW *vptr;
1241 {
1242 int i;
1243 FVECT dir;
1244 COLR c;
1245 FVECT p,ov;
1246
1247 /* Clear the mesh- and rebuild using the current sample array */
1248 #ifdef TEST_DRIVER
1249 View = *vptr;
1250 #endif
1251
1252 VSUB(ov,vptr->vp,SM_VIEW_CENTER(sm));
1253 smInit_mesh(sm,vptr->vp);
1254
1255 SM_FOR_ALL_SAMPLES(sm,i)
1256 {
1257 if(SM_NTH_W_DIR(sm,i)==-1)
1258 VADD(SM_NTH_WV(sm,i),SM_NTH_WV(sm,i),ov);
1259 smAdd_sample_to_mesh(sm,NULL,NULL,NULL,i);
1260 }
1261 }
1262
1263
