root/radiance/ray/src/hd/rhpict2.c
Revision: 3.18
Committed: Thu May 14 20:58:03 2020 UTC (5 years, 1 month ago) by greg
CVS Tags: rad5R4, rad5R3, HEAD
# User Rev Content
1 gwlarson 3.1 #ifndef lint
2 greg 3.18 static const char RCSid[] = "$Id: rhpict2.c,v 3.17 2018/10/05 19:19:16 greg Exp $";
3 gwlarson 3.1 #endif
4     /*
5     * Rendering routines for rhpict.
6     */
7
8 schorsch 3.12 #include <string.h>
9
10 gwlarson 3.1 #include "holo.h"
11     #include "view.h"
12 gwlarson 3.6 #include "random.h"
13 gwlarson 3.1
14 gwlarson 3.2 #ifndef DEPS
15 gwlarson 3.3 #define DEPS 0.02 /* depth epsilon */
16 gwlarson 3.2 #endif
17 gwlarson 3.3 #ifndef PEPS
18     #define PEPS 0.04 /* pixel value epsilon */
19     #endif
20 gwlarson 3.2 #ifndef MAXRAD
21     #define MAXRAD 64 /* maximum kernel radius */
22     #endif
23     #ifndef NNEIGH
24 gwlarson 3.9 #define NNEIGH 5 /* find this many neighbors */
25 gwlarson 3.2 #endif
26
27     #define NINF 16382
28
29     #define MAXRAD2 (MAXRAD*MAXRAD+1)
30
31     #define G0NORM 0.286 /* ground zero normalization (1/x integral) */
32
33     #ifndef FL4OP
34     #define FL4OP(f,i,op) ((f)[(i)>>5] op (1L<<((i)&0x1f)))
35     #define CHK4(f,i) FL4OP(f,i,&)
36     #define SET4(f,i) FL4OP(f,i,|=)
37     #define CLR4(f,i) FL4OP(f,i,&=~)
38     #define TGL4(f,i) FL4OP(f,i,^=)
39     #define FL4NELS(n) (((n)+0x1f)>>5)
40 schorsch 3.12 #define CLR4ALL(f,n) memset((char *)(f),'\0',FL4NELS(n)*sizeof(int32))
41 gwlarson 3.2 #endif
42
43 greg 3.11 static int32 *pixFlags; /* pixel occupancy flags */
44 gwlarson 3.2 static float pixWeight[MAXRAD2]; /* pixel weighting function */
45 gwlarson 3.3 static short isqrttab[MAXRAD2]; /* integer square root table */
46 gwlarson 3.2
47 gwlarson 3.9 #define isqrt(i2) (isqrttab[i2])
48 gwlarson 3.3
49 gwlarson 3.1 extern VIEW myview; /* current output view */
50     extern COLOR *mypixel; /* pixels being rendered */
51     extern float *myweight; /* weights (used to compute final pixels) */
52 gwlarson 3.2 extern float *mydepth; /* depth values (visibility culling) */
53 gwlarson 3.1 extern int hres, vres; /* current horizontal and vertical res. */
54
55 schorsch 3.15 extern void pixFinish(double ransamp);
56     extern void pixBeam(BEAM *bp, HDBEAMI *hb);
57 gwlarson 3.1
58 schorsch 3.15 typedef int (sampfunc)(int h, int v, short nl[NNEIGH][2], int nd[NNEIGH],
59     int n, double *rf);
60     static sampfunc kill_occl;
61     static sampfunc smooth_samp;
62     static sampfunc random_samp;
63     static void meet_neighbors(int occ, sampfunc *nf, double *dp);
64     static void reset_flags(void);
65     static void init_wfunc(void);
66     static int findneigh(short nl[NNEIGH][2], int nd[NNEIGH], int h, int v,
67 greg 3.17 short (*rnl)[NNEIGH]);
68 schorsch 3.15
69
70 greg 3.17 void
71 schorsch 3.15 pixBeam( /* render a particular beam */
72     BEAM *bp,
73 greg 3.17 HDBEAMI *hb
74 schorsch 3.15 )
75 gwlarson 3.1 {
76     GCOORD gc[2];
77 greg 3.17 RAYVAL *rv;
78 gwlarson 3.1 FVECT rorg, rdir, wp, ip;
79     double d, prox;
80     COLOR col;
81 gwlarson 3.2 int n;
82 greg 3.17 int32 p;
83 gwlarson 3.1
84     if (!hdbcoord(gc, hb->h, hb->b))
85     error(CONSISTENCY, "bad beam in render_beam");
86     for (n = bp->nrm, rv = hdbray(bp); n--; rv++) {
87     /* reproject each sample */
88     hdray(rorg, rdir, hb->h, gc, rv->r);
89     if (rv->d < DCINF) {
90     d = hddepth(hb->h, rv->d);
91     VSUM(wp, rorg, rdir, d);
92     VSUB(ip, wp, myview.vp);
93     d = DOT(ip,rdir);
94 gwlarson 3.2 prox = d*d/DOT(ip,ip); /* cos(diff_angle)^32 */
95     prox *= prox; prox *= prox; prox *= prox; prox *= prox;
96 gwlarson 3.1 } else {
97     if (myview.type == VT_PAR || myview.vaft > FTINY)
98     continue; /* inf. off view */
99     VSUM(wp, myview.vp, rdir, FHUGE);
100 gwlarson 3.2 prox = 1.;
101 gwlarson 3.1 }
102 greg 3.18 if (viewloc(ip, &myview, wp) != VL_GOOD)
103 greg 3.16 continue; /* frustum clipping */
104 gwlarson 3.1 if (myview.vaft > FTINY && ip[2] > myview.vaft - myview.vfore)
105 gwlarson 3.2 continue; /* not exact for VT_PER */
106 gwlarson 3.1 p = (int)(ip[1]*vres)*hres + (int)(ip[0]*hres);
107 gwlarson 3.2 if (mydepth[p] > FTINY) { /* check depth */
108     if (ip[2] > mydepth[p]*(1.+DEPS))
109     continue;
110     if (ip[2] < mydepth[p]*(1.-DEPS)) {
111     setcolor(mypixel[p], 0., 0., 0.);
112     myweight[p] = 0.;
113     }
114     }
115 gwlarson 3.1 colr_color(col, rv->v);
116 gwlarson 3.2 scalecolor(col, prox);
117 gwlarson 3.1 addcolor(mypixel[p], col);
118 gwlarson 3.2 myweight[p] += prox;
119     mydepth[p] = ip[2];
120 gwlarson 3.1 }
121 gwlarson 3.2 }
122
123
124 schorsch 3.15 static int
125     kill_occl( /* check for occlusion errors */
126     int h,
127     int v,
128 greg 3.17 short nl[NNEIGH][2],
129 schorsch 3.15 int nd[NNEIGH],
130     int n,
131     double *rf
132     )
133 gwlarson 3.2 {
134     short forequad[2][2];
135     int d;
136 greg 3.17 int i;
137     int32 p;
138 gwlarson 3.2
139 gwlarson 3.5 if (n <= 0) {
140     #ifdef DEBUG
141     error(WARNING, "neighborless sample in kill_occl");
142     #endif
143 gwlarson 3.2 return(1);
144 gwlarson 3.5 }
145 gwlarson 3.3 p = v*hres + h;
146 gwlarson 3.2 forequad[0][0] = forequad[0][1] = forequad[1][0] = forequad[1][1] = 0;
147     for (i = n; i--; ) {
148 gwlarson 3.9 d = isqrt(nd[i]);
149 gwlarson 3.3 if (mydepth[nl[i][1]*hres+nl[i][0]]*(1.+DEPS*d) < mydepth[p])
150 gwlarson 3.2 forequad[nl[i][0]<h][nl[i][1]<v] = 1;
151     }
152 gwlarson 3.3 if (forequad[0][0]+forequad[0][1]+forequad[1][0]+forequad[1][1] > 2) {
153     setcolor(mypixel[p], 0., 0., 0.);
154     myweight[p] = 0.; /* occupancy reset afterwards */
155 gwlarson 3.2 }
156     return(1);
157     }
158
159
160 schorsch 3.15 static int
161     smooth_samp( /* grow sample point smoothly */
162     int h,
163     int v,
164 greg 3.17 short nl[NNEIGH][2],
165 schorsch 3.15 int nd[NNEIGH],
166     int n,
167     double *rf
168     )
169 gwlarson 3.2 {
170 gwlarson 3.3 int dis[NNEIGH], ndis;
171 gwlarson 3.2 COLOR mykern[MAXRAD2];
172 gwlarson 3.9 int maxr2;
173 gwlarson 3.5 double d;
174 greg 3.17 int32 p;
175     int r2;
176 gwlarson 3.3 int i, r, maxr, h2, v2;
177 gwlarson 3.2
178     if (n <= 0)
179     return(1);
180     p = v*hres + h; /* build kernel values */
181 gwlarson 3.9 maxr2 = nd[n-1];
182 gwlarson 3.2 DCHECK(maxr2>=MAXRAD2, CONSISTENCY, "out of range neighbor");
183 gwlarson 3.3 maxr = isqrt(maxr2);
184     for (v2 = 1; v2 <= maxr; v2++)
185     for (h2 = 0; h2 <= v2; h2++) {
186     r2 = h2*h2 + v2*v2;
187     if (r2 > maxr2) break;
188     copycolor(mykern[r2], mypixel[p]);
189     scalecolor(mykern[r2], pixWeight[r2]);
190     }
191     ndis = 0; /* find discontinuities */
192     for (i = n; i--; ) {
193 gwlarson 3.9 r = isqrt(nd[i]);
194 gwlarson 3.3 d = mydepth[nl[i][1]*hres+nl[i][0]] / mydepth[p];
195     d = d>=1. ? d-1. : 1.-d;
196     if (d > r*DEPS || bigdiff(mypixel[p],
197     mypixel[nl[i][1]*hres+nl[i][0]], r*PEPS))
198     dis[ndis++] = i;
199 gwlarson 3.2 }
200 gwlarson 3.3 /* stamp out that kernel */
201 gwlarson 3.2 for (v2 = v-maxr; v2 <= v+maxr; v2++) {
202 gwlarson 3.3 if (v2 < 0) v2 = 0;
203     else if (v2 >= vres) break;
204 gwlarson 3.2 for (h2 = h-maxr; h2 <= h+maxr; h2++) {
205 gwlarson 3.3 if (h2 < 0) h2 = 0;
206     else if (h2 >= hres) break;
207     r2 = (h2-h)*(h2-h) + (v2-v)*(v2-v);
208 gwlarson 3.2 if (r2 > maxr2) continue;
209     if (CHK4(pixFlags, v2*hres+h2))
210     continue; /* occupied */
211 gwlarson 3.3 for (i = ndis; i--; ) {
212     r = (h2-nl[dis[i]][0])*(h2-nl[dis[i]][0]) +
213     (v2-nl[dis[i]][1])*(v2-nl[dis[i]][1]);
214     if (r < r2) break;
215     }
216     if (i >= 0) continue; /* outside edge */
217 gwlarson 3.2 addcolor(mypixel[v2*hres+h2], mykern[r2]);
218 gwlarson 3.5 myweight[v2*hres+h2] += pixWeight[r2] * myweight[p];
219 gwlarson 3.2 }
220     }
221     return(1);
222     }
223
224
225 schorsch 3.15 static int
226     random_samp( /* gather samples randomly */
227     int h,
228     int v,
229 greg 3.17 short nl[NNEIGH][2],
230 schorsch 3.15 int nd[NNEIGH],
231     int n,
232     double *rf
233     )
234 gwlarson 3.2 {
235 gwlarson 3.9 float rnt[NNEIGH];
236     double rvar;
237 greg 3.17 int32 p, pn;
238     int ni;
239 gwlarson 3.6
240     if (n <= 0)
241     return(1);
242 gwlarson 3.9 p = v*hres + h;
243     if (*rf <= FTINY) /* straight Voronoi regions */
244     ni = 0;
245     else { /* weighted choice */
246     DCHECK(nd[n-1]>=MAXRAD2, CONSISTENCY, "out of range neighbor");
247     rnt[0] = pixWeight[nd[0]];
248     for (ni = 1; ni < n; ni++)
249     rnt[ni] = rnt[ni-1] + pixWeight[nd[ni]];
250     rvar = rnt[n-1]*pow(frandom(), 1. / *rf);
251     for (ni = 0; rvar > rnt[ni]+FTINY; ni++)
252     ;
253 gwlarson 3.6 }
254 gwlarson 3.9 pn = nl[ni][1]*hres + nl[ni][0];
255     addcolor(mypixel[p], mypixel[pn]);
256     myweight[p] += myweight[pn];
257 gwlarson 3.6 return(1);
258     }
259
260
261 greg 3.17 void
262 schorsch 3.15 pixFinish( /* done with beams -- compute pixel values */
263     double ransamp
264     )
265 gwlarson 3.6 {
266 gwlarson 3.5 if (pixWeight[0] <= FTINY)
267     init_wfunc(); /* initialize weighting function */
268 gwlarson 3.2 reset_flags(); /* set occupancy flags */
269 gwlarson 3.9 meet_neighbors(1,kill_occl,NULL); /* identify occlusion errors */
270 gwlarson 3.2 reset_flags(); /* reset occupancy flags */
271 gwlarson 3.7 if (ransamp >= 0.) /* spread samples over image */
272 gwlarson 3.9 meet_neighbors(0,random_samp,&ransamp);
273 gwlarson 3.6 else
274 gwlarson 3.9 meet_neighbors(1,smooth_samp,NULL);
275 greg 3.10 free((void *)pixFlags); /* free pixel flags */
276 gwlarson 3.2 pixFlags = NULL;
277     }
278
279
280 schorsch 3.15 static void
281     reset_flags(void) /* allocate/set/reset occupancy flags */
282 gwlarson 3.2 {
283 greg 3.17 int32 p;
284 gwlarson 3.2
285     if (pixFlags == NULL) {
286 greg 3.11 pixFlags = (int32 *)calloc(FL4NELS(hres*vres), sizeof(int32));
287 gwlarson 3.2 CHECK(pixFlags==NULL, SYSTEM, "out of memory in reset_flags");
288     } else
289     CLR4ALL(pixFlags, hres*vres);
290     for (p = hres*vres; p--; )
291     if (myweight[p] > FTINY)
292     SET4(pixFlags, p);
293 gwlarson 3.4 }
294
295
296 schorsch 3.15 static void
297     init_wfunc(void) /* initialize weighting function */
298 gwlarson 3.4 {
299 greg 3.17 int r2;
300     double d;
301 gwlarson 3.4
302 gwlarson 3.6 for (r2 = MAXRAD2; --r2; ) {
303     d = sqrt((double)r2);
304     pixWeight[r2] = G0NORM/d;
305     isqrttab[r2] = d + 0.99;
306     }
307 gwlarson 3.4 pixWeight[0] = 1.;
308     isqrttab[0] = 0;
309 gwlarson 3.2 }
310
311
312 schorsch 3.15 static int
313     findneigh( /* find NNEIGH neighbors for pixel */
314     short nl[NNEIGH][2],
315     int nd[NNEIGH],
316     int h,
317     int v,
318 greg 3.17 short (*rnl)[NNEIGH]
319 schorsch 3.15 )
320 gwlarson 3.2 {
321     int nn = 0;
322 gwlarson 3.9 int d, n, hoff;
323 greg 3.17 int h2, n2;
324 gwlarson 3.2
325 gwlarson 3.3 nd[NNEIGH-1] = MAXRAD2;
326 gwlarson 3.9 for (hoff = 0; hoff < hres; hoff = (hoff<=0) - hoff) {
327 gwlarson 3.2 h2 = h + hoff;
328 schorsch 3.14 if ((h2 < 0) | (h2 >= hres))
329 gwlarson 3.2 continue;
330 gwlarson 3.3 if ((h2-h)*(h2-h) >= nd[NNEIGH-1])
331 gwlarson 3.2 break;
332     for (n = 0; n < NNEIGH && rnl[h2][n] < NINF; n++) {
333     d = (h2-h)*(h2-h) + (v-rnl[h2][n])*(v-rnl[h2][n]);
334 schorsch 3.14 if ((d == 0) | (d >= nd[NNEIGH-1]))
335 gwlarson 3.2 continue;
336 gwlarson 3.3 if (nn < NNEIGH) /* insert neighbor */
337     nn++;
338     for (n2 = nn; n2--; ) {
339 gwlarson 3.2 if (!n2 || d >= nd[n2-1]) {
340     nd[n2] = d;
341     nl[n2][0] = h2;
342     nl[n2][1] = rnl[h2][n];
343     break;
344     }
345     nd[n2] = nd[n2-1];
346     nl[n2][0] = nl[n2-1][0];
347     nl[n2][1] = nl[n2-1][1];
348     }
349     }
350     }
351     return(nn);
352     }
353
354
355 schorsch 3.15 static void
356     meet_neighbors( /* run through samples and their neighbors */
357     int occ,
358     sampfunc *nf,
359     double *dp
360     )
361 gwlarson 3.2 {
362     short ln[NNEIGH][2];
363 gwlarson 3.9 int nd[NNEIGH];
364 gwlarson 3.2 int h, v, n, v2;
365 greg 3.17 short (*rnl)[NNEIGH];
366 gwlarson 3.2 /* initialize bottom row list */
367     rnl = (short (*)[NNEIGH])malloc(NNEIGH*sizeof(short)*hres);
368     CHECK(rnl==NULL, SYSTEM, "out of memory in meet_neighbors");
369     for (h = 0; h < hres; h++) {
370     for (n = v = 0; v < vres; v++)
371     if (CHK4(pixFlags, v*hres+h)) {
372     rnl[h][n++] = v;
373     if (n >= NNEIGH)
374     break;
375     }
376     while (n < NNEIGH)
377     rnl[h][n++] = NINF;
378     }
379     v = 0; /* do each row */
380     for ( ; ; ) {
381     for (h = 0; h < hres; h++) {
382 gwlarson 3.9 if (!CHK4(pixFlags, v*hres+h) != !occ)
383     continue; /* occupancy mismatch */
384     /* find neighbors */
385     n = findneigh(ln, nd, h, v, rnl);
386     /* call on neighbors */
387     (*nf)(h, v, ln, nd, n, dp);
388 gwlarson 3.2 }
389     if (++v >= vres) /* reinitialize row list */
390     break;
391     for (h = 0; h < hres; h++)
392     for (v2 = rnl[h][NNEIGH-1]+1; v2 < vres; v2++) {
393     if (v2 - v > v - rnl[h][0])
394     break; /* not close enough */
395     if (CHK4(pixFlags, v2*hres+h)) {
396     for (n = 0; n < NNEIGH-1; n++)
397     rnl[h][n] = rnl[h][n+1];
398     rnl[h][NNEIGH-1] = v2;
399     }
400     }
401     }
402 greg 3.10 free((void *)rnl); /* free row list */
403 gwlarson 3.1 }
