1 |
/* Copyright (c) 1999 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Rendering routines for rhpict. |
9 |
10 |
11 |
#include "holo.h" |
12 |
#include "view.h" |
13 |
#include "random.h" |
14 |
15 |
#ifndef DEPS |
16 |
#define DEPS 0.02 /* depth epsilon */ |
17 |
#endif |
18 |
#ifndef PEPS |
19 |
#define PEPS 0.04 /* pixel value epsilon */ |
20 |
#endif |
21 |
#ifndef MAXRAD |
22 |
#define MAXRAD 64 /* maximum kernel radius */ |
23 |
#endif |
24 |
#ifndef NNEIGH |
25 |
#define NNEIGH 7 /* find this many neighbors */ |
26 |
#endif |
27 |
28 |
#define NINF 16382 |
29 |
30 |
#define MAXRAD2 (MAXRAD*MAXRAD+1) |
31 |
32 |
#define G0NORM 0.286 /* ground zero normalization (1/x integral) */ |
33 |
34 |
#ifndef FL4OP |
35 |
#define FL4OP(f,i,op) ((f)[(i)>>5] op (1L<<((i)&0x1f))) |
36 |
#define CHK4(f,i) FL4OP(f,i,&) |
37 |
#define SET4(f,i) FL4OP(f,i,|=) |
38 |
#define CLR4(f,i) FL4OP(f,i,&=~) |
39 |
#define TGL4(f,i) FL4OP(f,i,^=) |
40 |
#define FL4NELS(n) (((n)+0x1f)>>5) |
41 |
#define CLR4ALL(f,n) bzero((char *)(f),FL4NELS(n)*sizeof(int4)) |
42 |
#endif |
43 |
44 |
static int4 *pixFlags; /* pixel occupancy flags */ |
45 |
static float pixWeight[MAXRAD2]; /* pixel weighting function */ |
46 |
static short isqrttab[MAXRAD2]; /* integer square root table */ |
47 |
48 |
#define isqrt(i2) ((int)isqrttab[(int)(i2)]) |
49 |
50 |
extern VIEW myview; /* current output view */ |
51 |
extern COLOR *mypixel; /* pixels being rendered */ |
52 |
extern float *myweight; /* weights (used to compute final pixels) */ |
53 |
extern float *mydepth; /* depth values (visibility culling) */ |
54 |
extern int hres, vres; /* current horizontal and vertical res. */ |
55 |
56 |
57 |
pixBeam(bp, hb) /* render a particular beam */ |
58 |
BEAM *bp; |
59 |
register HDBEAMI *hb; |
60 |
61 |
GCOORD gc[2]; |
62 |
register RAYVAL *rv; |
63 |
FVECT rorg, rdir, wp, ip; |
64 |
double d, prox; |
65 |
COLOR col; |
66 |
int n; |
67 |
register int4 p; |
68 |
69 |
if (!hdbcoord(gc, hb->h, hb->b)) |
70 |
error(CONSISTENCY, "bad beam in render_beam"); |
71 |
for (n = bp->nrm, rv = hdbray(bp); n--; rv++) { |
72 |
/* reproject each sample */ |
73 |
hdray(rorg, rdir, hb->h, gc, rv->r); |
74 |
if (rv->d < DCINF) { |
75 |
d = hddepth(hb->h, rv->d); |
76 |
VSUM(wp, rorg, rdir, d); |
77 |
VSUB(ip, wp, myview.vp); |
78 |
d = DOT(ip,rdir); |
79 |
prox = d*d/DOT(ip,ip); /* cos(diff_angle)^32 */ |
80 |
prox *= prox; prox *= prox; prox *= prox; prox *= prox; |
81 |
} else { |
82 |
if (myview.type == VT_PAR || myview.vaft > FTINY) |
83 |
continue; /* inf. off view */ |
84 |
VSUM(wp, myview.vp, rdir, FHUGE); |
85 |
prox = 1.; |
86 |
87 |
viewloc(ip, &myview, wp); /* frustum clipping */ |
88 |
if (ip[2] < 0.) |
89 |
continue; |
90 |
if (ip[0] < 0. || ip[0] >= 1.) |
91 |
continue; |
92 |
if (ip[1] < 0. || ip[1] >= 1.) |
93 |
continue; |
94 |
if (myview.vaft > FTINY && ip[2] > myview.vaft - myview.vfore) |
95 |
continue; /* not exact for VT_PER */ |
96 |
p = (int)(ip[1]*vres)*hres + (int)(ip[0]*hres); |
97 |
if (mydepth[p] > FTINY) { /* check depth */ |
98 |
if (ip[2] > mydepth[p]*(1.+DEPS)) |
99 |
continue; |
100 |
if (ip[2] < mydepth[p]*(1.-DEPS)) { |
101 |
setcolor(mypixel[p], 0., 0., 0.); |
102 |
myweight[p] = 0.; |
103 |
104 |
105 |
colr_color(col, rv->v); |
106 |
scalecolor(col, prox); |
107 |
addcolor(mypixel[p], col); |
108 |
myweight[p] += prox; |
109 |
mydepth[p] = ip[2]; |
110 |
111 |
112 |
113 |
114 |
int |
115 |
kill_occl(h, v, nl, n) /* check for occlusion errors */ |
116 |
int h, v; |
117 |
register short nl[NNEIGH][2]; |
118 |
int n; |
119 |
120 |
short forequad[2][2]; |
121 |
int d; |
122 |
register int4 i, p; |
123 |
124 |
if (n <= 0) { |
125 |
#ifdef DEBUG |
126 |
error(WARNING, "neighborless sample in kill_occl"); |
127 |
#endif |
128 |
return(1); |
129 |
130 |
p = v*hres + h; |
131 |
forequad[0][0] = forequad[0][1] = forequad[1][0] = forequad[1][1] = 0; |
132 |
for (i = n; i--; ) { |
133 |
d = (h-nl[i][0])*(h-nl[i][0]) + (v-nl[i][1])*(v-nl[i][1]); |
134 |
d = isqrt(d); |
135 |
if (mydepth[nl[i][1]*hres+nl[i][0]]*(1.+DEPS*d) < mydepth[p]) |
136 |
forequad[nl[i][0]<h][nl[i][1]<v] = 1; |
137 |
138 |
if (forequad[0][0]+forequad[0][1]+forequad[1][0]+forequad[1][1] > 2) { |
139 |
140 |
myweight[p] = 0.; /* occupancy reset afterwards */ |
141 |
142 |
return(1); |
143 |
144 |
145 |
146 |
int |
147 |
smooth_samp(h, v, nl, n) /* grow sample point smoothly */ |
148 |
int h, v; |
149 |
150 |
int n; |
151 |
152 |
int dis[NNEIGH], ndis; |
153 |
COLOR mykern[MAXRAD2]; |
154 |
int4 maxr2; |
155 |
double d; |
156 |
register int4 p, r2; |
157 |
int i, r, maxr, h2, v2; |
158 |
159 |
if (n <= 0) |
160 |
return(1); |
161 |
p = v*hres + h; /* build kernel values */ |
162 |
maxr2 = (h-nl[n-1][0])*(h-nl[n-1][0]) + (v-nl[n-1][1])*(v-nl[n-1][1]); |
163 |
DCHECK(maxr2>=MAXRAD2, CONSISTENCY, "out of range neighbor"); |
164 |
maxr = isqrt(maxr2); |
165 |
for (v2 = 1; v2 <= maxr; v2++) |
166 |
for (h2 = 0; h2 <= v2; h2++) { |
167 |
r2 = h2*h2 + v2*v2; |
168 |
if (r2 > maxr2) break; |
169 |
copycolor(mykern[r2], mypixel[p]); |
170 |
scalecolor(mykern[r2], pixWeight[r2]); |
171 |
172 |
ndis = 0; /* find discontinuities */ |
173 |
174 |
r2 = (h-nl[i][0])*(h-nl[i][0]) + (v-nl[i][1])*(v-nl[i][1]); |
175 |
r = isqrt(r2); |
176 |
d = mydepth[nl[i][1]*hres+nl[i][0]] / mydepth[p]; |
177 |
d = d>=1. ? d-1. : 1.-d; |
178 |
if (d > r*DEPS || bigdiff(mypixel[p], |
179 |
mypixel[nl[i][1]*hres+nl[i][0]], r*PEPS)) |
180 |
dis[ndis++] = i; |
181 |
182 |
/* stamp out that kernel */ |
183 |
for (v2 = v-maxr; v2 <= v+maxr; v2++) { |
184 |
if (v2 < 0) v2 = 0; |
185 |
else if (v2 >= vres) break; |
186 |
for (h2 = h-maxr; h2 <= h+maxr; h2++) { |
187 |
if (h2 < 0) h2 = 0; |
188 |
else if (h2 >= hres) break; |
189 |
r2 = (h2-h)*(h2-h) + (v2-v)*(v2-v); |
190 |
if (r2 > maxr2) continue; |
191 |
if (CHK4(pixFlags, v2*hres+h2)) |
192 |
continue; /* occupied */ |
193 |
for (i = ndis; i--; ) { |
194 |
r = (h2-nl[dis[i]][0])*(h2-nl[dis[i]][0]) + |
195 |
(v2-nl[dis[i]][1])*(v2-nl[dis[i]][1]); |
196 |
if (r < r2) break; |
197 |
198 |
if (i >= 0) continue; /* outside edge */ |
199 |
addcolor(mypixel[v2*hres+h2], mykern[r2]); |
200 |
myweight[v2*hres+h2] += pixWeight[r2] * myweight[p]; |
201 |
202 |
203 |
return(1); |
204 |
205 |
206 |
207 |
int |
208 |
random_samp(h, v, nl, n) /* grow sample point noisily */ |
209 |
int h, v; |
210 |
211 |
int n; |
212 |
213 |
float nwt[NNEIGH]; |
214 |
int4 maxr2; |
215 |
216 |
register int i; |
217 |
int maxr, h2, v2; |
218 |
COLOR ctmp; |
219 |
220 |
if (n <= 0) |
221 |
return(1); |
222 |
p = v*hres + h; /* compute kernel radius */ |
223 |
224 |
225 |
226 |
/* compute neighbor weights */ |
227 |
228 |
r2 = (nl[i][0]-h)*(nl[i][0]-h) + (nl[i][1]-v)*(nl[i][1]-v); |
229 |
nwt[i] = pixWeight[r2]; |
230 |
231 |
/* sample kernel */ |
232 |
233 |
234 |
235 |
236 |
237 |
238 |
239 |
240 |
241 |
242 |
if (frandom() > pixWeight[r2]) { |
243 |
/* pick neighbor instead */ |
244 |
i = random() % n; |
245 |
r2 = nl[i][1]*hres + nl[i][0]; |
246 |
copycolor(ctmp, mypixel[r2]); |
247 |
scalecolor(ctmp, nwt[i]); |
248 |
addcolor(mypixel[v2*hres+h2], ctmp); |
249 |
myweight[v2*hres+h2] += nwt[i] * myweight[r2]; |
250 |
continue; |
251 |
252 |
addcolor(mypixel[v2*hres+h2], mypixel[p]); |
253 |
myweight[v2*hres+h2] += myweight[p]; |
254 |
255 |
256 |
return(1); |
257 |
258 |
259 |
260 |
pixFinish(ransamp) /* done with beams -- compute pixel values */ |
261 |
int ransamp; |
262 |
263 |
if (pixWeight[0] <= FTINY) |
264 |
init_wfunc(); /* initialize weighting function */ |
265 |
reset_flags(); /* set occupancy flags */ |
266 |
meet_neighbors(kill_occl); /* eliminate occlusion errors */ |
267 |
reset_flags(); /* reset occupancy flags */ |
268 |
if (ransamp) /* spread samples over image */ |
269 |
meet_neighbors(random_samp); |
270 |
else |
271 |
meet_neighbors(smooth_samp); |
272 |
free((char *)pixFlags); /* free pixel flags */ |
273 |
pixFlags = NULL; |
274 |
275 |
276 |
277 |
reset_flags() /* allocate/set/reset occupancy flags */ |
278 |
279 |
register int4 p; |
280 |
281 |
if (pixFlags == NULL) { |
282 |
pixFlags = (int4 *)calloc(FL4NELS(hres*vres), sizeof(int4)); |
283 |
CHECK(pixFlags==NULL, SYSTEM, "out of memory in reset_flags"); |
284 |
} else |
285 |
CLR4ALL(pixFlags, hres*vres); |
286 |
for (p = hres*vres; p--; ) |
287 |
if (myweight[p] > FTINY) |
288 |
SET4(pixFlags, p); |
289 |
290 |
291 |
292 |
init_wfunc() /* initialize weighting function */ |
293 |
294 |
register int4 r2; |
295 |
register double d; |
296 |
297 |
for (r2 = MAXRAD2; --r2; ) { |
298 |
d = sqrt((double)r2); |
299 |
pixWeight[r2] = G0NORM/d; |
300 |
isqrttab[r2] = d + 0.99; |
301 |
302 |
pixWeight[0] = 1.; |
303 |
isqrttab[0] = 0; |
304 |
305 |
306 |
307 |
int |
308 |
findneigh(nl, h, v, rnl) /* find NNEIGH neighbors for pixel */ |
309 |
310 |
int h, v; |
311 |
register short (*rnl)[NNEIGH]; |
312 |
313 |
int nn = 0; |
314 |
int4 d, nd[NNEIGH]; |
315 |
int n, hoff; |
316 |
register int h2, n2; |
317 |
318 |
nd[NNEIGH-1] = MAXRAD2; |
319 |
for (hoff = 1; hoff < hres; hoff = (hoff<0) - hoff) { |
320 |
h2 = h + hoff; |
321 |
if (h2 < 0 | h2 >= hres) |
322 |
continue; |
323 |
if ((h2-h)*(h2-h) >= nd[NNEIGH-1]) |
324 |
break; |
325 |
for (n = 0; n < NNEIGH && rnl[h2][n] < NINF; n++) { |
326 |
d = (h2-h)*(h2-h) + (v-rnl[h2][n])*(v-rnl[h2][n]); |
327 |
if (d >= nd[NNEIGH-1]) |
328 |
continue; |
329 |
if (nn < NNEIGH) /* insert neighbor */ |
330 |
nn++; |
331 |
for (n2 = nn; n2--; ) { |
332 |
if (!n2 || d >= nd[n2-1]) { |
333 |
nd[n2] = d; |
334 |
nl[n2][0] = h2; |
335 |
nl[n2][1] = rnl[h2][n]; |
336 |
break; |
337 |
338 |
nd[n2] = nd[n2-1]; |
339 |
nl[n2][0] = nl[n2-1][0]; |
340 |
nl[n2][1] = nl[n2-1][1]; |
341 |
342 |
343 |
344 |
return(nn); |
345 |
346 |
347 |
348 |
meet_neighbors(nf) /* run through samples and their neighbors */ |
349 |
int (*nf)(); |
350 |
351 |
short ln[NNEIGH][2]; |
352 |
int h, v, n, v2; |
353 |
354 |
/* initialize bottom row list */ |
355 |
rnl = (short (*)[NNEIGH])malloc(NNEIGH*sizeof(short)*hres); |
356 |
CHECK(rnl==NULL, SYSTEM, "out of memory in meet_neighbors"); |
357 |
for (h = 0; h < hres; h++) { |
358 |
for (n = v = 0; v < vres; v++) |
359 |
if (CHK4(pixFlags, v*hres+h)) { |
360 |
rnl[h][n++] = v; |
361 |
if (n >= NNEIGH) |
362 |
break; |
363 |
364 |
while (n < NNEIGH) |
365 |
rnl[h][n++] = NINF; |
366 |
367 |
v = 0; /* do each row */ |
368 |
for ( ; ; ) { |
369 |
370 |
if (!CHK4(pixFlags, v*hres+h)) |
371 |
continue; /* no one home */ |
372 |
n = findneigh(ln, h, v, rnl); |
373 |
(*nf)(h, v, ln, n); /* call on neighbors */ |
374 |
375 |
if (++v >= vres) /* reinitialize row list */ |
376 |
break; |
377 |
for (h = 0; h < hres; h++) |
378 |
for (v2 = rnl[h][NNEIGH-1]+1; v2 < vres; v2++) { |
379 |
if (v2 - v > v - rnl[h][0]) |
380 |
break; /* not close enough */ |
381 |
if (CHK4(pixFlags, v2*hres+h)) { |
382 |
for (n = 0; n < NNEIGH-1; n++) |
383 |
rnl[h][n] = rnl[h][n+1]; |
384 |
rnl[h][NNEIGH-1] = v2; |
385 |
386 |
387 |
388 |
free((char *)rnl); /* free row list */ |
389 |
