1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rhpict2.c,v 3.14 2003/07/27 22:12:02 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* Rendering routines for rhpict. |
6 |
7 |
8 |
#include <string.h> |
9 |
10 |
#include "holo.h" |
11 |
#include "view.h" |
12 |
#include "random.h" |
13 |
14 |
#ifndef DEPS |
15 |
#define DEPS 0.02 /* depth epsilon */ |
16 |
#endif |
17 |
#ifndef PEPS |
18 |
#define PEPS 0.04 /* pixel value epsilon */ |
19 |
#endif |
20 |
#ifndef MAXRAD |
21 |
#define MAXRAD 64 /* maximum kernel radius */ |
22 |
#endif |
23 |
#ifndef NNEIGH |
24 |
#define NNEIGH 5 /* find this many neighbors */ |
25 |
#endif |
26 |
27 |
#define NINF 16382 |
28 |
29 |
#define MAXRAD2 (MAXRAD*MAXRAD+1) |
30 |
31 |
#define G0NORM 0.286 /* ground zero normalization (1/x integral) */ |
32 |
33 |
#ifndef FL4OP |
34 |
#define FL4OP(f,i,op) ((f)[(i)>>5] op (1L<<((i)&0x1f))) |
35 |
#define CHK4(f,i) FL4OP(f,i,&) |
36 |
#define SET4(f,i) FL4OP(f,i,|=) |
37 |
#define CLR4(f,i) FL4OP(f,i,&=~) |
38 |
#define TGL4(f,i) FL4OP(f,i,^=) |
39 |
#define FL4NELS(n) (((n)+0x1f)>>5) |
40 |
#define CLR4ALL(f,n) memset((char *)(f),'\0',FL4NELS(n)*sizeof(int32)) |
41 |
#endif |
42 |
43 |
static int32 *pixFlags; /* pixel occupancy flags */ |
44 |
static float pixWeight[MAXRAD2]; /* pixel weighting function */ |
45 |
static short isqrttab[MAXRAD2]; /* integer square root table */ |
46 |
47 |
#define isqrt(i2) (isqrttab[i2]) |
48 |
49 |
extern VIEW myview; /* current output view */ |
50 |
extern COLOR *mypixel; /* pixels being rendered */ |
51 |
extern float *myweight; /* weights (used to compute final pixels) */ |
52 |
extern float *mydepth; /* depth values (visibility culling) */ |
53 |
extern int hres, vres; /* current horizontal and vertical res. */ |
54 |
55 |
extern void pixFinish(double ransamp); |
56 |
extern void pixBeam(BEAM *bp, HDBEAMI *hb); |
57 |
58 |
typedef int (sampfunc)(int h, int v, short nl[NNEIGH][2], int nd[NNEIGH], |
59 |
int n, double *rf); |
60 |
static sampfunc kill_occl; |
61 |
static sampfunc smooth_samp; |
62 |
static sampfunc random_samp; |
63 |
static void meet_neighbors(int occ, sampfunc *nf, double *dp); |
64 |
static void reset_flags(void); |
65 |
static void init_wfunc(void); |
66 |
static int findneigh(short nl[NNEIGH][2], int nd[NNEIGH], int h, int v, |
67 |
register short (*rnl)[NNEIGH]); |
68 |
69 |
70 |
extern void |
71 |
pixBeam( /* render a particular beam */ |
72 |
BEAM *bp, |
73 |
register HDBEAMI *hb |
74 |
75 |
76 |
GCOORD gc[2]; |
77 |
register RAYVAL *rv; |
78 |
FVECT rorg, rdir, wp, ip; |
79 |
double d, prox; |
80 |
COLOR col; |
81 |
int n; |
82 |
register int32 p; |
83 |
84 |
if (!hdbcoord(gc, hb->h, hb->b)) |
85 |
error(CONSISTENCY, "bad beam in render_beam"); |
86 |
for (n = bp->nrm, rv = hdbray(bp); n--; rv++) { |
87 |
/* reproject each sample */ |
88 |
hdray(rorg, rdir, hb->h, gc, rv->r); |
89 |
if (rv->d < DCINF) { |
90 |
d = hddepth(hb->h, rv->d); |
91 |
VSUM(wp, rorg, rdir, d); |
92 |
VSUB(ip, wp, myview.vp); |
93 |
d = DOT(ip,rdir); |
94 |
prox = d*d/DOT(ip,ip); /* cos(diff_angle)^32 */ |
95 |
prox *= prox; prox *= prox; prox *= prox; prox *= prox; |
96 |
} else { |
97 |
if (myview.type == VT_PAR || myview.vaft > FTINY) |
98 |
continue; /* inf. off view */ |
99 |
VSUM(wp, myview.vp, rdir, FHUGE); |
100 |
prox = 1.; |
101 |
102 |
viewloc(ip, &myview, wp); /* frustum clipping */ |
103 |
if (ip[2] < 0.) |
104 |
continue; |
105 |
if (ip[0] < 0. || ip[0] >= 1.) |
106 |
continue; |
107 |
if (ip[1] < 0. || ip[1] >= 1.) |
108 |
continue; |
109 |
if (myview.vaft > FTINY && ip[2] > myview.vaft - myview.vfore) |
110 |
continue; /* not exact for VT_PER */ |
111 |
p = (int)(ip[1]*vres)*hres + (int)(ip[0]*hres); |
112 |
if (mydepth[p] > FTINY) { /* check depth */ |
113 |
if (ip[2] > mydepth[p]*(1.+DEPS)) |
114 |
continue; |
115 |
if (ip[2] < mydepth[p]*(1.-DEPS)) { |
116 |
setcolor(mypixel[p], 0., 0., 0.); |
117 |
myweight[p] = 0.; |
118 |
119 |
120 |
colr_color(col, rv->v); |
121 |
scalecolor(col, prox); |
122 |
addcolor(mypixel[p], col); |
123 |
myweight[p] += prox; |
124 |
mydepth[p] = ip[2]; |
125 |
126 |
127 |
128 |
129 |
static int |
130 |
kill_occl( /* check for occlusion errors */ |
131 |
int h, |
132 |
int v, |
133 |
register short nl[NNEIGH][2], |
134 |
int nd[NNEIGH], |
135 |
int n, |
136 |
double *rf |
137 |
138 |
139 |
short forequad[2][2]; |
140 |
int d; |
141 |
register int i; |
142 |
register int32 p; |
143 |
144 |
if (n <= 0) { |
145 |
#ifdef DEBUG |
146 |
error(WARNING, "neighborless sample in kill_occl"); |
147 |
#endif |
148 |
return(1); |
149 |
150 |
p = v*hres + h; |
151 |
forequad[0][0] = forequad[0][1] = forequad[1][0] = forequad[1][1] = 0; |
152 |
for (i = n; i--; ) { |
153 |
d = isqrt(nd[i]); |
154 |
if (mydepth[nl[i][1]*hres+nl[i][0]]*(1.+DEPS*d) < mydepth[p]) |
155 |
forequad[nl[i][0]<h][nl[i][1]<v] = 1; |
156 |
157 |
if (forequad[0][0]+forequad[0][1]+forequad[1][0]+forequad[1][1] > 2) { |
158 |
159 |
myweight[p] = 0.; /* occupancy reset afterwards */ |
160 |
161 |
return(1); |
162 |
163 |
164 |
165 |
static int |
166 |
smooth_samp( /* grow sample point smoothly */ |
167 |
int h, |
168 |
int v, |
169 |
170 |
int nd[NNEIGH], |
171 |
int n, |
172 |
double *rf |
173 |
174 |
175 |
int dis[NNEIGH], ndis; |
176 |
COLOR mykern[MAXRAD2]; |
177 |
int maxr2; |
178 |
double d; |
179 |
register int32 p; |
180 |
register int r2; |
181 |
int i, r, maxr, h2, v2; |
182 |
183 |
if (n <= 0) |
184 |
return(1); |
185 |
p = v*hres + h; /* build kernel values */ |
186 |
maxr2 = nd[n-1]; |
187 |
DCHECK(maxr2>=MAXRAD2, CONSISTENCY, "out of range neighbor"); |
188 |
maxr = isqrt(maxr2); |
189 |
for (v2 = 1; v2 <= maxr; v2++) |
190 |
for (h2 = 0; h2 <= v2; h2++) { |
191 |
r2 = h2*h2 + v2*v2; |
192 |
if (r2 > maxr2) break; |
193 |
copycolor(mykern[r2], mypixel[p]); |
194 |
scalecolor(mykern[r2], pixWeight[r2]); |
195 |
196 |
ndis = 0; /* find discontinuities */ |
197 |
198 |
r = isqrt(nd[i]); |
199 |
d = mydepth[nl[i][1]*hres+nl[i][0]] / mydepth[p]; |
200 |
d = d>=1. ? d-1. : 1.-d; |
201 |
if (d > r*DEPS || bigdiff(mypixel[p], |
202 |
mypixel[nl[i][1]*hres+nl[i][0]], r*PEPS)) |
203 |
dis[ndis++] = i; |
204 |
205 |
/* stamp out that kernel */ |
206 |
for (v2 = v-maxr; v2 <= v+maxr; v2++) { |
207 |
if (v2 < 0) v2 = 0; |
208 |
else if (v2 >= vres) break; |
209 |
for (h2 = h-maxr; h2 <= h+maxr; h2++) { |
210 |
if (h2 < 0) h2 = 0; |
211 |
else if (h2 >= hres) break; |
212 |
r2 = (h2-h)*(h2-h) + (v2-v)*(v2-v); |
213 |
if (r2 > maxr2) continue; |
214 |
if (CHK4(pixFlags, v2*hres+h2)) |
215 |
continue; /* occupied */ |
216 |
for (i = ndis; i--; ) { |
217 |
r = (h2-nl[dis[i]][0])*(h2-nl[dis[i]][0]) + |
218 |
(v2-nl[dis[i]][1])*(v2-nl[dis[i]][1]); |
219 |
if (r < r2) break; |
220 |
221 |
if (i >= 0) continue; /* outside edge */ |
222 |
addcolor(mypixel[v2*hres+h2], mykern[r2]); |
223 |
myweight[v2*hres+h2] += pixWeight[r2] * myweight[p]; |
224 |
225 |
226 |
return(1); |
227 |
228 |
229 |
230 |
static int |
231 |
random_samp( /* gather samples randomly */ |
232 |
int h, |
233 |
int v, |
234 |
235 |
int nd[NNEIGH], |
236 |
int n, |
237 |
double *rf |
238 |
239 |
240 |
float rnt[NNEIGH]; |
241 |
double rvar; |
242 |
register int32 p, pn; |
243 |
register int ni; |
244 |
245 |
if (n <= 0) |
246 |
return(1); |
247 |
p = v*hres + h; |
248 |
if (*rf <= FTINY) /* straight Voronoi regions */ |
249 |
ni = 0; |
250 |
else { /* weighted choice */ |
251 |
DCHECK(nd[n-1]>=MAXRAD2, CONSISTENCY, "out of range neighbor"); |
252 |
rnt[0] = pixWeight[nd[0]]; |
253 |
for (ni = 1; ni < n; ni++) |
254 |
rnt[ni] = rnt[ni-1] + pixWeight[nd[ni]]; |
255 |
rvar = rnt[n-1]*pow(frandom(), 1. / *rf); |
256 |
for (ni = 0; rvar > rnt[ni]+FTINY; ni++) |
257 |
258 |
259 |
pn = nl[ni][1]*hres + nl[ni][0]; |
260 |
addcolor(mypixel[p], mypixel[pn]); |
261 |
myweight[p] += myweight[pn]; |
262 |
return(1); |
263 |
264 |
265 |
266 |
extern void |
267 |
pixFinish( /* done with beams -- compute pixel values */ |
268 |
double ransamp |
269 |
270 |
271 |
if (pixWeight[0] <= FTINY) |
272 |
init_wfunc(); /* initialize weighting function */ |
273 |
reset_flags(); /* set occupancy flags */ |
274 |
meet_neighbors(1,kill_occl,NULL); /* identify occlusion errors */ |
275 |
reset_flags(); /* reset occupancy flags */ |
276 |
if (ransamp >= 0.) /* spread samples over image */ |
277 |
meet_neighbors(0,random_samp,&ransamp); |
278 |
else |
279 |
meet_neighbors(1,smooth_samp,NULL); |
280 |
free((void *)pixFlags); /* free pixel flags */ |
281 |
pixFlags = NULL; |
282 |
283 |
284 |
285 |
static void |
286 |
reset_flags(void) /* allocate/set/reset occupancy flags */ |
287 |
288 |
register int32 p; |
289 |
290 |
if (pixFlags == NULL) { |
291 |
pixFlags = (int32 *)calloc(FL4NELS(hres*vres), sizeof(int32)); |
292 |
CHECK(pixFlags==NULL, SYSTEM, "out of memory in reset_flags"); |
293 |
} else |
294 |
CLR4ALL(pixFlags, hres*vres); |
295 |
for (p = hres*vres; p--; ) |
296 |
if (myweight[p] > FTINY) |
297 |
SET4(pixFlags, p); |
298 |
299 |
300 |
301 |
static void |
302 |
init_wfunc(void) /* initialize weighting function */ |
303 |
304 |
register int r2; |
305 |
register double d; |
306 |
307 |
for (r2 = MAXRAD2; --r2; ) { |
308 |
d = sqrt((double)r2); |
309 |
pixWeight[r2] = G0NORM/d; |
310 |
isqrttab[r2] = d + 0.99; |
311 |
312 |
pixWeight[0] = 1.; |
313 |
isqrttab[0] = 0; |
314 |
315 |
316 |
317 |
static int |
318 |
findneigh( /* find NNEIGH neighbors for pixel */ |
319 |
320 |
int nd[NNEIGH], |
321 |
int h, |
322 |
int v, |
323 |
register short (*rnl)[NNEIGH] |
324 |
325 |
326 |
int nn = 0; |
327 |
int d, n, hoff; |
328 |
register int h2, n2; |
329 |
330 |
nd[NNEIGH-1] = MAXRAD2; |
331 |
for (hoff = 0; hoff < hres; hoff = (hoff<=0) - hoff) { |
332 |
h2 = h + hoff; |
333 |
if ((h2 < 0) | (h2 >= hres)) |
334 |
continue; |
335 |
if ((h2-h)*(h2-h) >= nd[NNEIGH-1]) |
336 |
break; |
337 |
for (n = 0; n < NNEIGH && rnl[h2][n] < NINF; n++) { |
338 |
d = (h2-h)*(h2-h) + (v-rnl[h2][n])*(v-rnl[h2][n]); |
339 |
if ((d == 0) | (d >= nd[NNEIGH-1])) |
340 |
continue; |
341 |
if (nn < NNEIGH) /* insert neighbor */ |
342 |
nn++; |
343 |
for (n2 = nn; n2--; ) { |
344 |
if (!n2 || d >= nd[n2-1]) { |
345 |
nd[n2] = d; |
346 |
nl[n2][0] = h2; |
347 |
nl[n2][1] = rnl[h2][n]; |
348 |
break; |
349 |
350 |
nd[n2] = nd[n2-1]; |
351 |
nl[n2][0] = nl[n2-1][0]; |
352 |
nl[n2][1] = nl[n2-1][1]; |
353 |
354 |
355 |
356 |
return(nn); |
357 |
358 |
359 |
360 |
static void |
361 |
meet_neighbors( /* run through samples and their neighbors */ |
362 |
int occ, |
363 |
sampfunc *nf, |
364 |
double *dp |
365 |
366 |
367 |
short ln[NNEIGH][2]; |
368 |
int nd[NNEIGH]; |
369 |
int h, v, n, v2; |
370 |
register short (*rnl)[NNEIGH]; |
371 |
/* initialize bottom row list */ |
372 |
rnl = (short (*)[NNEIGH])malloc(NNEIGH*sizeof(short)*hres); |
373 |
CHECK(rnl==NULL, SYSTEM, "out of memory in meet_neighbors"); |
374 |
for (h = 0; h < hres; h++) { |
375 |
for (n = v = 0; v < vres; v++) |
376 |
if (CHK4(pixFlags, v*hres+h)) { |
377 |
rnl[h][n++] = v; |
378 |
if (n >= NNEIGH) |
379 |
break; |
380 |
381 |
while (n < NNEIGH) |
382 |
rnl[h][n++] = NINF; |
383 |
384 |
v = 0; /* do each row */ |
385 |
for ( ; ; ) { |
386 |
387 |
if (!CHK4(pixFlags, v*hres+h) != !occ) |
388 |
continue; /* occupancy mismatch */ |
389 |
/* find neighbors */ |
390 |
n = findneigh(ln, nd, h, v, rnl); |
391 |
/* call on neighbors */ |
392 |
(*nf)(h, v, ln, nd, n, dp); |
393 |
394 |
if (++v >= vres) /* reinitialize row list */ |
395 |
break; |
396 |
for (h = 0; h < hres; h++) |
397 |
for (v2 = rnl[h][NNEIGH-1]+1; v2 < vres; v2++) { |
398 |
if (v2 - v > v - rnl[h][0]) |
399 |
break; /* not close enough */ |
400 |
if (CHK4(pixFlags, v2*hres+h)) { |
401 |
for (n = 0; n < NNEIGH-1; n++) |
402 |
rnl[h][n] = rnl[h][n+1]; |
403 |
rnl[h][NNEIGH-1] = v2; |
404 |
405 |
406 |
407 |
free((void *)rnl); /* free row list */ |
408 |
