--- ray/src/hd/rhpict2.c 1999/03/05 17:03:38 3.2 +++ ray/src/hd/rhpict2.c 1999/03/08 14:09:11 3.3 @@ -12,8 +12,11 @@ static char SCCSid[] = "$SunId$ SGI"; #include "view.h" #ifndef DEPS -#define DEPS 0.01 /* depth epsilon */ +#define DEPS 0.02 /* depth epsilon */ #endif +#ifndef PEPS +#define PEPS 0.04 /* pixel value epsilon */ +#endif #ifndef MAXRAD #define MAXRAD 64 /* maximum kernel radius */ #endif @@ -39,7 +42,10 @@ static char SCCSid[] = "$SunId$ SGI"; static int4 *pixFlags; /* pixel occupancy flags */ static float pixWeight[MAXRAD2]; /* pixel weighting function */ +static short isqrttab[MAXRAD2]; /* integer square root table */ +#define isqrt(i2) ((int)isqrttab[(int)(i2)]) + extern VIEW myview; /* current output view */ extern COLOR *mypixel; /* pixels being rendered */ extern float *myweight; /* weights (used to compute final pixels) */ @@ -107,26 +113,26 @@ register HDBEAMI *hb; int kill_occl(h, v, nl, n) /* check for occlusion errors */ int h, v; -short nl[NNEIGH][2]; +register short nl[NNEIGH][2]; int n; { short forequad[2][2]; int d; - register int4 i; + register int4 i, p; if (n <= 0) return(1); + p = v*hres + h; forequad[0][0] = forequad[0][1] = forequad[1][0] = forequad[1][1] = 0; for (i = n; i--; ) { d = (h-nl[i][0])*(h-nl[i][0]) + (v-nl[i][1])*(v-nl[i][1]); - if (mydepth[nl[i][1]*hres+nl[i][0]] < - mydepth[v*hres+h]*(1.-DEPS*d)) + d = isqrt(d); + if (mydepth[nl[i][1]*hres+nl[i][0]]*(1.+DEPS*d) < mydepth[p]) forequad[nl[i][0] 1) { - i = v*hres + h; - setcolor(mypixel[i], 0., 0., 0.); - myweight[i] = 0.; /* occupancy reset afterwards */ + if (forequad[0][0]+forequad[0][1]+forequad[1][0]+forequad[1][1] > 2) { + setcolor(mypixel[p], 0., 0., 0.); + myweight[p] = 0.; /* occupancy reset afterwards */ } return(1); } @@ -138,38 +144,56 @@ int h, v; register short nl[NNEIGH][2]; int n; { + int dis[NNEIGH], ndis; COLOR mykern[MAXRAD2]; - float mykw[MAXRAD2]; int4 maxr2; - double w; + double w, d; register int4 p, r2; - int maxr, h2, v2; + int i, r, maxr, h2, v2; if (n <= 0) return(1); p = v*hres + h; /* build kernel values */ maxr2 = (h-nl[n-1][0])*(h-nl[n-1][0]) + (v-nl[n-1][1])*(v-nl[n-1][1]); DCHECK(maxr2>=MAXRAD2, CONSISTENCY, "out of range neighbor"); - for (r2 = maxr2+1; --r2; ) { - copycolor(mykern[r2], mypixel[p]); - mykw[r2] = pixWeight[r2]; - if (2*r2 >= maxr2) /* soften skirt */ - mykw[r2] *= (2*(maxr2-r2)+1.0)/maxr2; - scalecolor(mykern[r2], mykw[r2]); + maxr = isqrt(maxr2); + for (v2 = 1; v2 <= maxr; v2++) + for (h2 = 0; h2 <= v2; h2++) { + r2 = h2*h2 + v2*v2; + if (r2 > maxr2) break; + copycolor(mykern[r2], mypixel[p]); + scalecolor(mykern[r2], pixWeight[r2]); + } + ndis = 0; /* find discontinuities */ + for (i = n; i--; ) { + r2 = (h-nl[i][0])*(h-nl[i][0]) + (v-nl[i][1])*(v-nl[i][1]); + r = isqrt(r2); + d = mydepth[nl[i][1]*hres+nl[i][0]] / mydepth[p]; + d = d>=1. ? d-1. : 1.-d; + if (d > r*DEPS || bigdiff(mypixel[p], + mypixel[nl[i][1]*hres+nl[i][0]], r*PEPS)) + dis[ndis++] = i; } - maxr = sqrt((double)maxr2) + .99; /* stamp out that kernel */ + /* stamp out that kernel */ for (v2 = v-maxr; v2 <= v+maxr; v2++) { - if (v2 < 0) continue; - if (v2 >= vres) break; + if (v2 < 0) v2 = 0; + else if (v2 >= vres) break; for (h2 = h-maxr; h2 <= h+maxr; h2++) { - if (h2 < 0) continue; - if (h2 >= hres) break; - r2 = (v2-v)*(v2-v) + (h2-h)*(h2-h); + if (h2 < 0) h2 = 0; + else if (h2 >= hres) break; + r2 = (h2-h)*(h2-h) + (v2-v)*(v2-v); if (r2 > maxr2) continue; if (CHK4(pixFlags, v2*hres+h2)) continue; /* occupied */ + for (i = ndis; i--; ) { + r = (h2-nl[dis[i]][0])*(h2-nl[dis[i]][0]) + + (v2-nl[dis[i]][1])*(v2-nl[dis[i]][1]); + if (r < r2) break; + } + if (i >= 0) continue; /* outside edge */ addcolor(mypixel[v2*hres+h2], mykern[r2]); - myweight[v2*hres+h2] += mykw[r2]*myweight[v*hres+h]; + myweight[v2*hres+h2] += pixWeight[r2] * + myweight[v*hres+h]; } } return(1); @@ -182,10 +206,18 @@ pixFlush() /* done with beams -- flush pixel values meet_neighbors(kill_occl); /* eliminate occlusion errors */ reset_flags(); /* reset occupancy flags */ if (pixWeight[0] <= FTINY) { /* initialize weighting function */ - register int r; - for (r = MAXRAD2; --r; ) - pixWeight[r] = G0NORM/sqrt((double)r); + register int i, j, r2; + double d; + for (i = 1; i <= MAXRAD; i++) + for (j = 0; j <= i; j++) { + r2 = i*i + j*j; + if (r2 >= MAXRAD2) break; + d = sqrt((double)r2); + pixWeight[r2] = G0NORM/d; + isqrttab[r2] = d + 0.99; + } pixWeight[0] = 1.; + isqrttab[0] = 0; } meet_neighbors(grow_samp); /* grow valid samples over image */ free((char *)pixFlags); /* free pixel flags */ @@ -215,22 +247,24 @@ int h, v; register short (*rnl)[NNEIGH]; { int nn = 0; - int4 d, ld, nd[NNEIGH+1]; + int4 d, nd[NNEIGH]; int n, hoff; register int h2, n2; - ld = MAXRAD2; + nd[NNEIGH-1] = MAXRAD2; for (hoff = 1; hoff < hres; hoff = (hoff<0) - hoff) { h2 = h + hoff; if (h2 < 0 | h2 >= hres) continue; - if ((h2-h)*(h2-h) >= ld) + if ((h2-h)*(h2-h) >= nd[NNEIGH-1]) break; for (n = 0; n < NNEIGH && rnl[h2][n] < NINF; n++) { d = (h2-h)*(h2-h) + (v-rnl[h2][n])*(v-rnl[h2][n]); - if (d >= ld) + if (d >= nd[NNEIGH-1]) continue; - for (n2 = nn; ; n2--) { /* insert neighbor */ + if (nn < NNEIGH) /* insert neighbor */ + nn++; + for (n2 = nn; n2--; ) { if (!n2 || d >= nd[n2-1]) { nd[n2] = d; nl[n2][0] = h2; @@ -241,10 +275,6 @@ register short (*rnl)[NNEIGH]; nl[n2][0] = nl[n2-1][0]; nl[n2][1] = nl[n2-1][1]; } - if (nn < NNEIGH) - nn++; - else - ld = nd[NNEIGH-1]; } } return(nn);
