--- ray/src/hd/rhpict2.c 1999/03/05 17:03:38 3.2 +++ ray/src/hd/rhpict2.c 2003/06/30 14:59:12 3.12 @@ -1,24 +1,27 @@ -/* Copyright (c) 1999 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: rhpict2.c,v 3.12 2003/06/30 14:59:12 schorsch Exp $"; #endif - /* * Rendering routines for rhpict. */ +#include + #include "holo.h" #include "view.h" +#include "random.h" #ifndef DEPS -#define DEPS 0.01 /* depth epsilon */ +#define DEPS 0.02 /* depth epsilon */ #endif +#ifndef PEPS +#define PEPS 0.04 /* pixel value epsilon */ +#endif #ifndef MAXRAD #define MAXRAD 64 /* maximum kernel radius */ #endif #ifndef NNEIGH -#define NNEIGH 7 /* find this many neighbors */ +#define NNEIGH 5 /* find this many neighbors */ #endif #define NINF 16382 @@ -34,12 +37,15 @@ static char SCCSid[] = "$SunId$ SGI"; #define CLR4(f,i) FL4OP(f,i,&=~) #define TGL4(f,i) FL4OP(f,i,^=) #define FL4NELS(n) (((n)+0x1f)>>5) -#define CLR4ALL(f,n) bzero((char *)(f),FL4NELS(n)*sizeof(int4)) +#define CLR4ALL(f,n) memset((char *)(f),'\0',FL4NELS(n)*sizeof(int32)) #endif -static int4 *pixFlags; /* pixel occupancy flags */ +static int32 *pixFlags; /* pixel occupancy flags */ static float pixWeight[MAXRAD2]; /* pixel weighting function */ +static short isqrttab[MAXRAD2]; /* integer square root table */ +#define isqrt(i2) (isqrttab[i2]) + extern VIEW myview; /* current output view */ extern COLOR *mypixel; /* pixels being rendered */ extern float *myweight; /* weights (used to compute final pixels) */ @@ -57,7 +63,7 @@ register HDBEAMI *hb; double d, prox; COLOR col; int n; - register int4 p; + register int32 p; if (!hdbcoord(gc, hb->h, hb->b)) error(CONSISTENCY, "bad beam in render_beam"); @@ -105,100 +111,157 @@ register HDBEAMI *hb; int -kill_occl(h, v, nl, n) /* check for occlusion errors */ +kill_occl(h, v, nl, nd, n) /* check for occlusion errors */ int h, v; -short nl[NNEIGH][2]; +register short nl[NNEIGH][2]; +int nd[NNEIGH]; int n; { short forequad[2][2]; int d; - register int4 i; + register int i; + register int32 p; - if (n <= 0) + if (n <= 0) { +#ifdef DEBUG + error(WARNING, "neighborless sample in kill_occl"); +#endif return(1); + } + p = v*hres + h; forequad[0][0] = forequad[0][1] = forequad[1][0] = forequad[1][1] = 0; for (i = n; i--; ) { - d = (h-nl[i][0])*(h-nl[i][0]) + (v-nl[i][1])*(v-nl[i][1]); - if (mydepth[nl[i][1]*hres+nl[i][0]] < - mydepth[v*hres+h]*(1.-DEPS*d)) + d = isqrt(nd[i]); + if (mydepth[nl[i][1]*hres+nl[i][0]]*(1.+DEPS*d) < mydepth[p]) forequad[nl[i][0] 1) { - i = v*hres + h; - setcolor(mypixel[i], 0., 0., 0.); - myweight[i] = 0.; /* occupancy reset afterwards */ + if (forequad[0][0]+forequad[0][1]+forequad[1][0]+forequad[1][1] > 2) { + setcolor(mypixel[p], 0., 0., 0.); + myweight[p] = 0.; /* occupancy reset afterwards */ } return(1); } int -grow_samp(h, v, nl, n) /* grow sample point appropriately */ +smooth_samp(h, v, nl, nd, n) /* grow sample point smoothly */ int h, v; register short nl[NNEIGH][2]; +int nd[NNEIGH]; int n; { + int dis[NNEIGH], ndis; COLOR mykern[MAXRAD2]; - float mykw[MAXRAD2]; - int4 maxr2; - double w; - register int4 p, r2; - int maxr, h2, v2; + int maxr2; + double d; + register int32 p; + register int r2; + int i, r, maxr, h2, v2; if (n <= 0) return(1); p = v*hres + h; /* build kernel values */ - maxr2 = (h-nl[n-1][0])*(h-nl[n-1][0]) + (v-nl[n-1][1])*(v-nl[n-1][1]); + maxr2 = nd[n-1]; DCHECK(maxr2>=MAXRAD2, CONSISTENCY, "out of range neighbor"); - for (r2 = maxr2+1; --r2; ) { - copycolor(mykern[r2], mypixel[p]); - mykw[r2] = pixWeight[r2]; - if (2*r2 >= maxr2) /* soften skirt */ - mykw[r2] *= (2*(maxr2-r2)+1.0)/maxr2; - scalecolor(mykern[r2], mykw[r2]); + maxr = isqrt(maxr2); + for (v2 = 1; v2 <= maxr; v2++) + for (h2 = 0; h2 <= v2; h2++) { + r2 = h2*h2 + v2*v2; + if (r2 > maxr2) break; + copycolor(mykern[r2], mypixel[p]); + scalecolor(mykern[r2], pixWeight[r2]); + } + ndis = 0; /* find discontinuities */ + for (i = n; i--; ) { + r = isqrt(nd[i]); + d = mydepth[nl[i][1]*hres+nl[i][0]] / mydepth[p]; + d = d>=1. ? d-1. : 1.-d; + if (d > r*DEPS || bigdiff(mypixel[p], + mypixel[nl[i][1]*hres+nl[i][0]], r*PEPS)) + dis[ndis++] = i; } - maxr = sqrt((double)maxr2) + .99; /* stamp out that kernel */ + /* stamp out that kernel */ for (v2 = v-maxr; v2 <= v+maxr; v2++) { - if (v2 < 0) continue; - if (v2 >= vres) break; + if (v2 < 0) v2 = 0; + else if (v2 >= vres) break; for (h2 = h-maxr; h2 <= h+maxr; h2++) { - if (h2 < 0) continue; - if (h2 >= hres) break; - r2 = (v2-v)*(v2-v) + (h2-h)*(h2-h); + if (h2 < 0) h2 = 0; + else if (h2 >= hres) break; + r2 = (h2-h)*(h2-h) + (v2-v)*(v2-v); if (r2 > maxr2) continue; if (CHK4(pixFlags, v2*hres+h2)) continue; /* occupied */ + for (i = ndis; i--; ) { + r = (h2-nl[dis[i]][0])*(h2-nl[dis[i]][0]) + + (v2-nl[dis[i]][1])*(v2-nl[dis[i]][1]); + if (r < r2) break; + } + if (i >= 0) continue; /* outside edge */ addcolor(mypixel[v2*hres+h2], mykern[r2]); - myweight[v2*hres+h2] += mykw[r2]*myweight[v*hres+h]; + myweight[v2*hres+h2] += pixWeight[r2] * myweight[p]; } } return(1); } -pixFlush() /* done with beams -- flush pixel values */ +int +random_samp(h, v, nl, nd, n, rf) /* gather samples randomly */ +int h, v; +register short nl[NNEIGH][2]; +int nd[NNEIGH]; +int n; +double *rf; { + float rnt[NNEIGH]; + double rvar; + register int32 p, pn; + register int ni; + + if (n <= 0) + return(1); + p = v*hres + h; + if (*rf <= FTINY) /* straight Voronoi regions */ + ni = 0; + else { /* weighted choice */ + DCHECK(nd[n-1]>=MAXRAD2, CONSISTENCY, "out of range neighbor"); + rnt[0] = pixWeight[nd[0]]; + for (ni = 1; ni < n; ni++) + rnt[ni] = rnt[ni-1] + pixWeight[nd[ni]]; + rvar = rnt[n-1]*pow(frandom(), 1. / *rf); + for (ni = 0; rvar > rnt[ni]+FTINY; ni++) + ; + } + pn = nl[ni][1]*hres + nl[ni][0]; + addcolor(mypixel[p], mypixel[pn]); + myweight[p] += myweight[pn]; + return(1); +} + + +pixFinish(ransamp) /* done with beams -- compute pixel values */ +double ransamp; +{ + if (pixWeight[0] <= FTINY) + init_wfunc(); /* initialize weighting function */ reset_flags(); /* set occupancy flags */ - meet_neighbors(kill_occl); /* eliminate occlusion errors */ + meet_neighbors(1,kill_occl,NULL); /* identify occlusion errors */ reset_flags(); /* reset occupancy flags */ - if (pixWeight[0] <= FTINY) { /* initialize weighting function */ - register int r; - for (r = MAXRAD2; --r; ) - pixWeight[r] = G0NORM/sqrt((double)r); - pixWeight[0] = 1.; - } - meet_neighbors(grow_samp); /* grow valid samples over image */ - free((char *)pixFlags); /* free pixel flags */ + if (ransamp >= 0.) /* spread samples over image */ + meet_neighbors(0,random_samp,&ransamp); + else + meet_neighbors(1,smooth_samp,NULL); + free((void *)pixFlags); /* free pixel flags */ pixFlags = NULL; } reset_flags() /* allocate/set/reset occupancy flags */ { - register int p; + register int32 p; if (pixFlags == NULL) { - pixFlags = (int4 *)calloc(FL4NELS(hres*vres), sizeof(int4)); + pixFlags = (int32 *)calloc(FL4NELS(hres*vres), sizeof(int32)); CHECK(pixFlags==NULL, SYSTEM, "out of memory in reset_flags"); } else CLR4ALL(pixFlags, hres*vres); @@ -208,29 +271,46 @@ reset_flags() /* allocate/set/reset occupancy flags } +init_wfunc() /* initialize weighting function */ +{ + register int r2; + register double d; + + for (r2 = MAXRAD2; --r2; ) { + d = sqrt((double)r2); + pixWeight[r2] = G0NORM/d; + isqrttab[r2] = d + 0.99; + } + pixWeight[0] = 1.; + isqrttab[0] = 0; +} + + int -findneigh(nl, h, v, rnl) /* find NNEIGH neighbors for pixel */ +findneigh(nl, nd, h, v, rnl) /* find NNEIGH neighbors for pixel */ short nl[NNEIGH][2]; +int nd[NNEIGH]; int h, v; register short (*rnl)[NNEIGH]; { int nn = 0; - int4 d, ld, nd[NNEIGH+1]; - int n, hoff; + int d, n, hoff; register int h2, n2; - ld = MAXRAD2; - for (hoff = 1; hoff < hres; hoff = (hoff<0) - hoff) { + nd[NNEIGH-1] = MAXRAD2; + for (hoff = 0; hoff < hres; hoff = (hoff<=0) - hoff) { h2 = h + hoff; if (h2 < 0 | h2 >= hres) continue; - if ((h2-h)*(h2-h) >= ld) + if ((h2-h)*(h2-h) >= nd[NNEIGH-1]) break; for (n = 0; n < NNEIGH && rnl[h2][n] < NINF; n++) { d = (h2-h)*(h2-h) + (v-rnl[h2][n])*(v-rnl[h2][n]); - if (d >= ld) + if (d == 0 | d >= nd[NNEIGH-1]) continue; - for (n2 = nn; ; n2--) { /* insert neighbor */ + if (nn < NNEIGH) /* insert neighbor */ + nn++; + for (n2 = nn; n2--; ) { if (!n2 || d >= nd[n2-1]) { nd[n2] = d; nl[n2][0] = h2; @@ -241,20 +321,19 @@ register short (*rnl)[NNEIGH]; nl[n2][0] = nl[n2-1][0]; nl[n2][1] = nl[n2-1][1]; } - if (nn < NNEIGH) - nn++; - else - ld = nd[NNEIGH-1]; } } return(nn); } -meet_neighbors(nf) /* run through samples and their neighbors */ +meet_neighbors(occ, nf, dp) /* run through samples and their neighbors */ +int occ; int (*nf)(); +char *dp; { short ln[NNEIGH][2]; + int nd[NNEIGH]; int h, v, n, v2; register short (*rnl)[NNEIGH]; /* initialize bottom row list */ @@ -273,10 +352,12 @@ int (*nf)(); v = 0; /* do each row */ for ( ; ; ) { for (h = 0; h < hres; h++) { - if (!CHK4(pixFlags, v*hres+h)) - continue; /* no one home */ - n = findneigh(ln, h, v, rnl); - (*nf)(h, v, ln, n); /* call on neighbors */ + if (!CHK4(pixFlags, v*hres+h) != !occ) + continue; /* occupancy mismatch */ + /* find neighbors */ + n = findneigh(ln, nd, h, v, rnl); + /* call on neighbors */ + (*nf)(h, v, ln, nd, n, dp); } if (++v >= vres) /* reinitialize row list */ break; @@ -291,5 +372,5 @@ int (*nf)(); } } } - free((char *)rnl); /* free row list */ + free((void *)rnl); /* free row list */ }
