root/radiance/ray/src/hd/rhpict2.c
Revision: 3.13
Committed: Mon Jul 7 17:21:51 2003 UTC (22 years, 1 month ago) by greg
Changes since 3.12: +2 -1 lines
2 static const char RCSid[] = "$Id: rhpict2.c,v 3.12 2003/06/30 14:59:12 schorsch Exp $";
5 * Rendering routines for rhpict.
6 */
7
8 #include <string.h>
9
10 #include "holo.h"
11 #include "view.h"
12 #include "random.h"
13
14 #ifndef DEPS
15 #define DEPS 0.02 /* depth epsilon */
16 #endif
17 #ifndef PEPS
18 #define PEPS 0.04 /* pixel value epsilon */
19 #endif
20 #ifndef MAXRAD
21 #define MAXRAD 64 /* maximum kernel radius */
22 #endif
23 #ifndef NNEIGH
24 #define NNEIGH 5 /* find this many neighbors */
25 #endif
26
27 #define NINF 16382
28
29 #define MAXRAD2 (MAXRAD*MAXRAD+1)
30
31 #define G0NORM 0.286 /* ground zero normalization (1/x integral) */
32
33 #ifndef FL4OP
34 #define FL4OP(f,i,op) ((f)[(i)>>5] op (1L<<((i)&0x1f)))
35 #define CHK4(f,i) FL4OP(f,i,&)
36 #define SET4(f,i) FL4OP(f,i,|=)
37 #define CLR4(f,i) FL4OP(f,i,&=~)
38 #define TGL4(f,i) FL4OP(f,i,^=)
39 #define FL4NELS(n) (((n)+0x1f)>>5)
40 #define CLR4ALL(f,n) memset((char *)(f),'\0',FL4NELS(n)*sizeof(int32))
41 #endif
42
43 static int32 *pixFlags; /* pixel occupancy flags */
44 static float pixWeight[MAXRAD2]; /* pixel weighting function */
45 static short isqrttab[MAXRAD2]; /* integer square root table */
46
47 #define isqrt(i2) (isqrttab[i2])
48
49 extern VIEW myview; /* current output view */
50 extern COLOR *mypixel; /* pixels being rendered */
51 extern float *myweight; /* weights (used to compute final pixels) */
52 extern float *mydepth; /* depth values (visibility culling) */
53 extern int hres, vres; /* current horizontal and vertical res. */
54
55
56 void
57 pixBeam(bp, hb) /* render a particular beam */
58 BEAM *bp;
59 register HDBEAMI *hb;
60 {
61 GCOORD gc[2];
62 register RAYVAL *rv;
63 FVECT rorg, rdir, wp, ip;
64 double d, prox;
65 COLOR col;
66 int n;
67 register int32 p;
68
69 if (!hdbcoord(gc, hb->h, hb->b))
70 error(CONSISTENCY, "bad beam in render_beam");
71 for (n = bp->nrm, rv = hdbray(bp); n--; rv++) {
72 /* reproject each sample */
73 hdray(rorg, rdir, hb->h, gc, rv->r);
74 if (rv->d < DCINF) {
75 d = hddepth(hb->h, rv->d);
76 VSUM(wp, rorg, rdir, d);
77 VSUB(ip, wp, myview.vp);
78 d = DOT(ip,rdir);
79 prox = d*d/DOT(ip,ip); /* cos(diff_angle)^32 */
80 prox *= prox; prox *= prox; prox *= prox; prox *= prox;
81 } else {
82 if (myview.type == VT_PAR || myview.vaft > FTINY)
83 continue; /* inf. off view */
84 VSUM(wp, myview.vp, rdir, FHUGE);
85 prox = 1.;
86 }
87 viewloc(ip, &myview, wp); /* frustum clipping */
88 if (ip[2] < 0.)
89 continue;
90 if (ip[0] < 0. || ip[0] >= 1.)
91 continue;
92 if (ip[1] < 0. || ip[1] >= 1.)
93 continue;
94 if (myview.vaft > FTINY && ip[2] > myview.vaft - myview.vfore)
95 continue; /* not exact for VT_PER */
96 p = (int)(ip[1]*vres)*hres + (int)(ip[0]*hres);
97 if (mydepth[p] > FTINY) { /* check depth */
98 if (ip[2] > mydepth[p]*(1.+DEPS))
99 continue;
100 if (ip[2] < mydepth[p]*(1.-DEPS)) {
101 setcolor(mypixel[p], 0., 0., 0.);
102 myweight[p] = 0.;
103 }
104 }
105 colr_color(col, rv->v);
106 scalecolor(col, prox);
107 addcolor(mypixel[p], col);
108 myweight[p] += prox;
109 mydepth[p] = ip[2];
110 }
111 }
112
113
114 int
115 kill_occl(h, v, nl, nd, n) /* check for occlusion errors */
116 int h, v;
117 register short nl[NNEIGH][2];
118 int nd[NNEIGH];
119 int n;
120 {
121 short forequad[2][2];
122 int d;
123 register int i;
124 register int32 p;
125
126 if (n <= 0) {
127 #ifdef DEBUG
128 error(WARNING, "neighborless sample in kill_occl");
129 #endif
130 return(1);
131 }
132 p = v*hres + h;
133 forequad[0][0] = forequad[0][1] = forequad[1][0] = forequad[1][1] = 0;
134 for (i = n; i--; ) {
135 d = isqrt(nd[i]);
136 if (mydepth[nl[i][1]*hres+nl[i][0]]*(1.+DEPS*d) < mydepth[p])
137 forequad[nl[i][0]<h][nl[i][1]<v] = 1;
138 }
139 if (forequad[0][0]+forequad[0][1]+forequad[1][0]+forequad[1][1] > 2) {
140 setcolor(mypixel[p], 0., 0., 0.);
141 myweight[p] = 0.; /* occupancy reset afterwards */
142 }
143 return(1);
144 }
145
146
147 int
148 smooth_samp(h, v, nl, nd, n) /* grow sample point smoothly */
149 int h, v;
150 register short nl[NNEIGH][2];
151 int nd[NNEIGH];
152 int n;
153 {
154 int dis[NNEIGH], ndis;
155 COLOR mykern[MAXRAD2];
156 int maxr2;
157 double d;
158 register int32 p;
159 register int r2;
160 int i, r, maxr, h2, v2;
161
162 if (n <= 0)
163 return(1);
164 p = v*hres + h; /* build kernel values */
165 maxr2 = nd[n-1];
166 DCHECK(maxr2>=MAXRAD2, CONSISTENCY, "out of range neighbor");
167 maxr = isqrt(maxr2);
168 for (v2 = 1; v2 <= maxr; v2++)
169 for (h2 = 0; h2 <= v2; h2++) {
170 r2 = h2*h2 + v2*v2;
171 if (r2 > maxr2) break;
172 copycolor(mykern[r2], mypixel[p]);
173 scalecolor(mykern[r2], pixWeight[r2]);
174 }
175 ndis = 0; /* find discontinuities */
176 for (i = n; i--; ) {
177 r = isqrt(nd[i]);
178 d = mydepth[nl[i][1]*hres+nl[i][0]] / mydepth[p];
179 d = d>=1. ? d-1. : 1.-d;
180 if (d > r*DEPS || bigdiff(mypixel[p],
181 mypixel[nl[i][1]*hres+nl[i][0]], r*PEPS))
182 dis[ndis++] = i;
183 }
184 /* stamp out that kernel */
185 for (v2 = v-maxr; v2 <= v+maxr; v2++) {
186 if (v2 < 0) v2 = 0;
187 else if (v2 >= vres) break;
188 for (h2 = h-maxr; h2 <= h+maxr; h2++) {
189 if (h2 < 0) h2 = 0;
190 else if (h2 >= hres) break;
191 r2 = (h2-h)*(h2-h) + (v2-v)*(v2-v);
192 if (r2 > maxr2) continue;
193 if (CHK4(pixFlags, v2*hres+h2))
194 continue; /* occupied */
195 for (i = ndis; i--; ) {
196 r = (h2-nl[dis[i]][0])*(h2-nl[dis[i]][0]) +
197 (v2-nl[dis[i]][1])*(v2-nl[dis[i]][1]);
198 if (r < r2) break;
199 }
200 if (i >= 0) continue; /* outside edge */
201 addcolor(mypixel[v2*hres+h2], mykern[r2]);
202 myweight[v2*hres+h2] += pixWeight[r2] * myweight[p];
203 }
204 }
205 return(1);
206 }
207
208
209 int
210 random_samp(h, v, nl, nd, n, rf) /* gather samples randomly */
211 int h, v;
212 register short nl[NNEIGH][2];
213 int nd[NNEIGH];
214 int n;
215 double *rf;
216 {
217 float rnt[NNEIGH];
218 double rvar;
219 register int32 p, pn;
220 register int ni;
221
222 if (n <= 0)
223 return(1);
224 p = v*hres + h;
225 if (*rf <= FTINY) /* straight Voronoi regions */
226 ni = 0;
227 else { /* weighted choice */
228 DCHECK(nd[n-1]>=MAXRAD2, CONSISTENCY, "out of range neighbor");
229 rnt[0] = pixWeight[nd[0]];
230 for (ni = 1; ni < n; ni++)
231 rnt[ni] = rnt[ni-1] + pixWeight[nd[ni]];
232 rvar = rnt[n-1]*pow(frandom(), 1. / *rf);
233 for (ni = 0; rvar > rnt[ni]+FTINY; ni++)
234 ;
235 }
236 pn = nl[ni][1]*hres + nl[ni][0];
237 addcolor(mypixel[p], mypixel[pn]);
238 myweight[p] += myweight[pn];
239 return(1);
240 }
241
242
243 pixFinish(ransamp) /* done with beams -- compute pixel values */
244 double ransamp;
245 {
246 if (pixWeight[0] <= FTINY)
247 init_wfunc(); /* initialize weighting function */
248 reset_flags(); /* set occupancy flags */
249 meet_neighbors(1,kill_occl,NULL); /* identify occlusion errors */
250 reset_flags(); /* reset occupancy flags */
251 if (ransamp >= 0.) /* spread samples over image */
252 meet_neighbors(0,random_samp,&ransamp);
253 else
254 meet_neighbors(1,smooth_samp,NULL);
255 free((void *)pixFlags); /* free pixel flags */
256 pixFlags = NULL;
257 }
258
259
260 reset_flags() /* allocate/set/reset occupancy flags */
261 {
262 register int32 p;
263
264 if (pixFlags == NULL) {
265 pixFlags = (int32 *)calloc(FL4NELS(hres*vres), sizeof(int32));
266 CHECK(pixFlags==NULL, SYSTEM, "out of memory in reset_flags");
267 } else
268 CLR4ALL(pixFlags, hres*vres);
269 for (p = hres*vres; p--; )
270 if (myweight[p] > FTINY)
271 SET4(pixFlags, p);
272 }
273
274
275 init_wfunc() /* initialize weighting function */
276 {
277 register int r2;
278 register double d;
279
280 for (r2 = MAXRAD2; --r2; ) {
281 d = sqrt((double)r2);
282 pixWeight[r2] = G0NORM/d;
283 isqrttab[r2] = d + 0.99;
284 }
285 pixWeight[0] = 1.;
286 isqrttab[0] = 0;
287 }
288
289
290 int
291 findneigh(nl, nd, h, v, rnl) /* find NNEIGH neighbors for pixel */
292 short nl[NNEIGH][2];
293 int nd[NNEIGH];
294 int h, v;
295 register short (*rnl)[NNEIGH];
296 {
297 int nn = 0;
298 int d, n, hoff;
299 register int h2, n2;
300
301 nd[NNEIGH-1] = MAXRAD2;
302 for (hoff = 0; hoff < hres; hoff = (hoff<=0) - hoff) {
303 h2 = h + hoff;
304 if (h2 < 0 | h2 >= hres)
305 continue;
306 if ((h2-h)*(h2-h) >= nd[NNEIGH-1])
307 break;
308 for (n = 0; n < NNEIGH && rnl[h2][n] < NINF; n++) {
309 d = (h2-h)*(h2-h) + (v-rnl[h2][n])*(v-rnl[h2][n]);
310 if (d == 0 | d >= nd[NNEIGH-1])
311 continue;
312 if (nn < NNEIGH) /* insert neighbor */
313 nn++;
314 for (n2 = nn; n2--; ) {
315 if (!n2 || d >= nd[n2-1]) {
316 nd[n2] = d;
317 nl[n2][0] = h2;
318 nl[n2][1] = rnl[h2][n];
319 break;
320 }
321 nd[n2] = nd[n2-1];
322 nl[n2][0] = nl[n2-1][0];
323 nl[n2][1] = nl[n2-1][1];
324 }
325 }
326 }
327 return(nn);
328 }
329
330
331 meet_neighbors(occ, nf, dp) /* run through samples and their neighbors */
332 int occ;
333 int (*nf)();
334 char *dp;
335 {
336 short ln[NNEIGH][2];
337 int nd[NNEIGH];
338 int h, v, n, v2;
339 register short (*rnl)[NNEIGH];
340 /* initialize bottom row list */
341 rnl = (short (*)[NNEIGH])malloc(NNEIGH*sizeof(short)*hres);
342 CHECK(rnl==NULL, SYSTEM, "out of memory in meet_neighbors");
343 for (h = 0; h < hres; h++) {
344 for (n = v = 0; v < vres; v++)
345 if (CHK4(pixFlags, v*hres+h)) {
346 rnl[h][n++] = v;
347 if (n >= NNEIGH)
348 break;
349 }
350 while (n < NNEIGH)
351 rnl[h][n++] = NINF;
352 }
353 v = 0; /* do each row */
354 for ( ; ; ) {
355 for (h = 0; h < hres; h++) {
356 if (!CHK4(pixFlags, v*hres+h) != !occ)
357 continue; /* occupancy mismatch */
358 /* find neighbors */
359 n = findneigh(ln, nd, h, v, rnl);
360 /* call on neighbors */
361 (*nf)(h, v, ln, nd, n, dp);
362 }
363 if (++v >= vres) /* reinitialize row list */
364 break;
365 for (h = 0; h < hres; h++)
366 for (v2 = rnl[h][NNEIGH-1]+1; v2 < vres; v2++) {
367 if (v2 - v > v - rnl[h][0])
368 break; /* not close enough */
369 if (CHK4(pixFlags, v2*hres+h)) {
370 for (n = 0; n < NNEIGH-1; n++)
371 rnl[h][n] = rnl[h][n+1];
372 rnl[h][NNEIGH-1] = v2;
373 }
374 }
375 }
376 free((void *)rnl); /* free row list */
377 }
